  4. <gelöst> Serieller Port defekt
    6.8k
362 Beiträge 11 Kommentatoren 87.5k Aufrufe 9 Beobachtet
  • S searcher57
    @homoran ```
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: Raspi42GB
           Icon name: computer
              Kernel: Linux 6.6.28+rpt-rpi-v8
        Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     20:32:33 up  2:40,  2 users,  load average: 0.13, 0.09, 0.09
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Mon 2024-04-29 20:32:33 CEST
               Universal time: Mon 2024-04-29 18:32:33 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            8.2G        978M        6.3G        1.2M        1.0G        7.2G
    Swap:           104M          0B        104M
    Total:          8.3G        978M        6.4G
             7810 M total memory
              933 M used memory
              940 M active memory
              700 M inactive memory
             6042 M free memory
               53 M buffer memory
              903 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     782M  1.2M  780M   1% /run
    /dev/mmcblk0p2 ext4       59G  3.3G   52G   6% /
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
    /dev/sda1      exfat      29G   29M   29G   1% /mnt/usb0
    tmpfs          tmpfs     781M     0  781M   0% /run/user/1000
    [Mon Apr 29 17:52:08 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:43:B6:26 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=d1e7c568-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Mon Apr 29 17:52:10 2024] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
    [Mon Apr 29 17:52:12 2024] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    |-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/mnt/usb0      /dev/sda1      exfat  rw,relatime,fmask=0000,dmask=0000,allow_utime=0022,iocharset=utf8,errors=remount-ro
    /var:
    538M    /var/
    205M    /var/cache
    199M    /var/cache/apt
    173M    /var/lib
    141M    /var/lib/apt/lists
    Archived and active journals take up 60.0M in the file system.
    /opt/iobroker/backups:
    1.6M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    107M    /opt/iobroker/iobroker-data/
    77M     /opt/iobroker/iobroker-data/files
    57M     /opt/iobroker/iobroker-data/files/javascript.admin
    38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    37M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
    6.4M    /opt/iobroker/iobroker-data/states.jsonl
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    6.2M    /opt/iobroker/iobroker-data/objects.jsonl
    6.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/344.2eef1017.chunk.js.map
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.20.2
    /usr/bin/node           v18.20.2
    /usr/bin/npm            10.5.0
    /usr/bin/npx            10.5.0
    /usr/bin/corepack       0.25.2
    nodejs:
      Installed: 18.20.2-1nodesource1
      Candidate: 18.20.2-1nodesource1
      Version table:
     *** 18.20.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.20.1-1nodesource1 1001
         18.20.0-1nodesource1 1001
         18.19.1-1nodesource1 1001
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.19
    admin:          6.13.16
    javascript:     7.8.0
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : Raspi42GB                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : Raspi42GB                                -  enabled
    + system.adapter.discovery.0              : discovery             : Raspi42GB                                -  enabled
    + system.adapter.javascript.0             : javascript            : Raspi42GB                                -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : Raspi42GB                                -  enabled
    + system.adapter.shelly.0                 : shelly                : Raspi42GB                                -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.smartmeter.0             : smartmeter            : Raspi42GB                                -  enabled
      system.adapter.telegram.0               : telegram              : Raspi42GB                                - disabled, port: 8443, bind: 0.0.0.0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "backitup"     : 2.11.0   , installed 2.11.0
    Adapter    "discovery"    : 4.4.0    , installed 4.4.0
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "shelly"       : 6.9.0    , installed 6.9.0
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "telegram"     : 3.2.1    , installed 3.2.1
    Objects and States
    Objects:        1023
    States:         676
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       4734       694/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       4744       694/iobroker.js-con
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5893       701/sshd: /usr/sbin
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5904       701/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       680        781/io.admin.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4652       557/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       6931       1094/io.shelly.0
    udp        0      0 0.0.0.0:43046           0.0.0.0:*                           1001       7414       1094/io.shelly.0
    udp        0      0 0.0.0.0:49027           0.0.0.0:*                           104        4654       557/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        4653       557/avahi-daemon: r
    udp6       0      0 :::39625                :::*                                104        4655       557/avahi-daemon: r
    2024-04-29 20:30:00.035  - info: javascript.0 (1228) script.js.Haushalt.Strom.Verbrauch.Shelly: Shelly Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 0
    2024-04-29 20:30:27.300  - error: rpi2.0 (2260) Cannot evaluate: Dateisystem    1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf
    /dev/mmcblk0p2  60819080 3435724  54275028    6% /
    /1024
    2024-04-29 20:30:27.302  - error: rpi2.0 (2260) Cannot evaluate: Dateisystem    1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf
    /1024
    2024-04-29 20:31:27.305  - error: rpi2.0 (2260) Cannot evaluate: Dateisystem    1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf
    /dev/mmcblk0p2  60819080 3435752  54275000    6% /
    /1024
    2024-04-29 20:31:27.306  - error: rpi2.0 (2260) Cannot evaluate: Dateisystem    1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf
    /1024
    2024-04-29 20:32:27.299  - error: rpi2.0 (2260) Cannot evaluate: Dateisystem    1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf
    /dev/mmcblk0p2  60819080 3435800  54274952    6% /
    /1024
    2024-04-29 20:32:27.301  - error: rpi2.0 (2260) Cannot evaluate: Dateisystem    1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf
    /1024
    2024-04-29 20:33:27.262  - error: rpi2.0 (2260) Cannot evaluate: Dateisystem    1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf
    /dev/mmcblk0p2  60819080 3324276  54386476    6% /
    /1024
    2024-04-29 20:33:27.263  - error: rpi2.0 (2260) Cannot evaluate: Dateisystem    1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf
    /1024
    #282
    @searcher57
    Ob/wie das funktioniert kann ich mangels Hardware an den GPIOs nicht verifizieren. Aber die Dateien werden zumindest angelegt:
    echad@chet:~ $ ls -la /dev/gpio*
    crw-rw---- 1 root gpio 254, 0 Apr 29 19:12 /dev/gpiochip0
    crw-rw---- 1 root gpio 254, 1 Apr 29 19:12 /dev/gpiochip1
    crw-rw---- 1 root gpio 238, 0 Apr 29 19:12 /dev/gpiomem
    echad@chet:~ $
    Die user müssen dann hier noch in die Gruppe 'gpio' gepackt werden, falls nicht schon ohnehin drin.
      @searcher57 sagte in <gelöst> Serieller Port defekt:
      bookworm
      seltsam, weil
      @laser sagte in <gelöst> Serieller Port defekt:
      der Adapter RPI2.0 kann die GPIO nicht mehr lesen und schreiben. Auch beim Raspi4.
      searcher57
      #283
      @homoran Ja, das habe ich doch geschrieben! Die serielle funktioniert, aber RPI2 nicht.
        @searcher57
        echad@chet:~ $
        searcher57
        #284
        @thomas-braun said in <gelöst> Serieller Port defekt:
        Die user müssen dann hier noch in die Gruppe 'gpio' gepackt werden.
        Ok, wie macht man das?
        • S searcher57
          #285
          Erst schauen, ob das überhaupt erforderlich ist.
          sudo -u iobroker id
          Bei mir war das alles schon richtig.
          • S searcher57
            #286
            aber @Laser meint dass es auch am 4er nicht klappt.
            oder wird hier Lesekopf und restliche GPIOs wild durcheinander gewürfelt?
            Dieser Thread bezieht sich auf TTY Leseköpfe
              sudo -u iobroker id
              searcher57
              #287
              sudo -u iobroker id
              pi@Raspi42GB:~ $ sudo -u iobroker id
              uid=1001(iobroker) gid=1001(iobroker) Gruppen=1001(iobroker),5(tty),20(dialout),29(audio),44(video),109(bluetooth),993(gpio),994(i2c)
              • S searcher57
                sudo -u iobroker id
                #288
                993(gpio)
                Alles okay, der user iobroker ist in der Gruppe drin.
                  searcher57
                  #289
                  Ich hoffe, dass ich mich richtig ausdrücke.
                  1. Der Stromzähler ist bei mir an GPIO14/15 und 3,3V/0V angeschlossen, nachdem ich die serielle Schnittstelle in der Konsole aktiviert habe.
                  2. Der Gaszähler ist an GPIO22 und +3,3V angeschlossen und funktioniert seit geschätzten 3 Wochen ohne Grund nicht mehr.
                  • S searcher57
                    #290
                    @searcher57 dann solltest du für den rpi2 einen getrennten Thread aufmachen.
                    Diese GPIOs haben nichts mit dem seriellen Port zu tun.
                    Und genau darum geht es in diesem Thread. So steht es auch im Threadtitel
                    und bitte in diesem Thread diese beiden unterschiedlichen Themen nicht vermischen!
                      searcher57
                      schrieb am zuletzt editiert von searcher57
                      #291
                      Ok, habe ich verstanden. Aber ich habe seit einigen Tagen nur noch Probleme und werfe dadurch einiges durcheinander.
                      Das Problem RPI2 wird wohl nur durch den Entwickler gelöst, leider...!
                      • S searcher57
                        #292
                        und der braucht dafür strukturiert Informationen, so wie z.B @Thomas-Braun sie hier zusammenträgt.
                        Thomas BraunT S 2 Antworten Letzte Antwort
                          #293
                          @homoran sagte in <gelöst> Serieller Port defekt:
                          Ist aber nur mutmaßen, da ich wie gesagt nix an den GPIOs hängen habe und deswegen da nix testen kann.
                            searcher57
                            #294
                            Dann danke ich Euch beiden und hoffe, dass es irgendwann eine Lösung gibt!👍 👍
                              searcher57
                              #295
                              Faxnummer und ich faxe Dir mein PI4 mit Anschlüssen rüber!😁
                                searcher57
                                #296
                                Entschuldige, wenn ich Dir hier antworte, denn ich weiß nicht, ob das woanders hingehört? Langsam verliere ich die Lust den Befehl: "sudo apt full-upgrade" auszuführen. Denn sehr oft funktionieren anschließend einige Adapter nicht mehr. Siehe heute der smartmeter-Adapter (Auslesen des Stromzählers). Ich warte bis heute auf eine Lösung des rpi2.0 Adapters (Auslesen des Gaszählers). Diese haben monatelang hervorragend funktioniert, aber durch ein regelmäßiges "sudo apt full-upgrade" zerstört man sich ein lauffähiges System! Hoffentlich werde ich nicht gleich wieder von den "Devolepern" an den Pranger gestellt, wie in der Vergangenheit. Wenn das hier nicht der richtige Platz für eine Kritik ist, dann nenne mir doch bitte diesen.
                                • S searcher57
                                  #297
                                  Kurze Antwort:
                                  Quatsch.
                                    Kurze Antwort:
                                    Quatsch.
                                    searcher57
                                    #298
                                    Kurze Antwort:
                                    Quatsch.
                                    Danke!
                                      Kurze Antwort:
                                      Quatsch.
                                      searcher57
                                      #299
                                      Kurze Antwort:
                                      Quatsch.
                                      Das sind die Antworten, die ich in einem Forum erwarte!👍
                                      Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                                      • S searcher57
                                        Kurze Antwort:
                                        Quatsch.
                                        #300
                                        Kurze Antwort:
                                        Quatsch.
                                        Gut.
                                        • S searcher57
                                          Kurze Antwort:
                                          Quatsch.
                                          #301
                                          Was willst du denn hören?
                                          Natürlich ist das Quatsch, alleine weil du da eine Ursache siehst, die es nicht gibt.
                                          Die Probleme, die du anscheinend hast haben mit dem full upgrade alleine nichts zu tun
