  4. Adapter ws und socketio
    1.0k
    6.1k
20 Beiträge 7 Kommentatoren 3.4k Aufrufe 7 Beobachtet
    @el_rob
    Dann ist jetzt zumindest die Laufzeitumgebung aktuell.
    el_rob
    @thomas-braun sagte in Adapter ws und socketio:
    @el_rob
    😂 ...wäre aber trotzdem schön, wenn auch der Adapter wieder liefe! 😉
    Hier die Ausgabe von iob diag
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.8.4-2-pve
        Architecture: x86-64
    model name      : Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     15:31:18 up 45 min,  2 users,  load average: 1.16, 1.29, 1.17
    CPU threads: 2
    *** Time and Time Zones ***
                   Local time: Fri 2024-04-26 15:31:18 CEST
               Universal time: Fri 2024-04-26 13:31:18 UTC
                     RTC time: n/a
                    Time zone: Europe/Zurich (CEST, +0200)
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    admin
    /home/admin
    admin sudo users iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            8.6G        3.4G        5.1G        114K        105M        5.2G
    Swap:             0B          0B          0B
    Total:          8.6G        3.4G        5.1G
             8192 M total memory
             3236 M used memory
             3195 M active memory
                0 M inactive memory
             4854 M free memory
                0 M buffer memory
              101 M swap cache
                0 M total swap
                0 M used swap
                0 M free swap
    *** FAILED SERVICES ***
      UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
    2 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                 Type      Size  Used Avail Use% Mounted on
    pmx-data/subvol-100-disk-0 zfs        17G  5.3G   12G  33% /
    none                       tmpfs     492K  4.0K  488K   1% /dev
    udev                       devtmpfs   16G     0   16G   0% /dev/tty
    tmpfs                      tmpfs      16G     0   16G   0% /dev/shm
    tmpfs                      tmpfs     6.3G  108K  6.3G   1% /run
    tmpfs                      tmpfs     5.0M     0  5.0M   0% /run/lock
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET SOURCE                     FSTYPE OPTIONS
    /      pmx-data/subvol-100-disk-0 zfs    rw,relatime,xattr,posixacl,casesensitive
    /var:
    365M    /var/
    285M    /var/cache
    283M    /var/cache/apt
    237M    /var/cache/apt/archives
    67M     /var/lib
    Archived and active journals take up 453.5K in the file system.
    /opt/iobroker/backups:
    1.8G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    631M    /opt/iobroker/iobroker-data/
    308M    /opt/iobroker/iobroker-data/esphome.0/.esphome
    275M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build
    219M    /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/nachttischlampe-rob/.pioenvs/nachttischlampe-rob/libFrameworkArduino.a
    9.7M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build/bedside-lamp-2/.pioenvs/bedside-lamp-2/firmware.elf
    9.7M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build/bedside-lamp-1/.pioenvs/bedside-lamp-1/firmware.elf
    9.4M    /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
    8.2M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.20.2
    /usr/bin/node           v18.20.2
    /usr/bin/npm            10.5.0
    /usr/bin/npx            10.5.0
    /usr/bin/corepack       0.25.2
    nodejs:
      Installed: 18.20.2-1nodesource1
      Candidate: 18.20.2-1nodesource1
      Version table:
     *** 18.20.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.20.1-1nodesource1 1001
         18.20.0-1nodesource1 1001
         18.19.1-1nodesource1 1001
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org bookworm-security/main amd64 Packages
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.19
    admin:          6.17.6
    javascript:     8.0.3
    Adapters from github:   1
    Adapter State
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.bambulab.0               : bambulab              : iobroker                                 -  enabled, port: 8883
    + system.adapter.calendar.0               : calendar              : iobroker                                 -  enabled, port: 8095
    + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
      system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
    + system.adapter.esphome.0                : esphome               : iobroker                                 -  enabled
    + system.adapter.fakeroku.0               : fakeroku              : iobroker                                 -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
      system.adapter.garmin.0                 : garmin                : iobroker                                 - disabled
      system.adapter.hyperion_ng.0            : hyperion_ng           : iobroker                                 - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.linkeddevices.0          : linkeddevices         : iobroker                                 -  enabled
    + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
    + system.adapter.mielecloudservice.0      : mielecloudservice     : iobroker                                 -  enabled
    + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
    + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
    + system.adapter.omada.0                  : omada                 : iobroker                                 -  enabled, port: 8043
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
      system.adapter.robonect.0               : robonect              : iobroker                                 - disabled
      system.adapter.roomba.0                 : roomba                : iobroker                                 - disabled
    + system.adapter.scheduler.0              : scheduler             : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.snmp.0                   : snmp                  : iobroker                                 - disabled
      system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
      system.adapter.squeezeboxrpc.0          : squeezeboxrpc         : iobroker                                 - disabled, port: 9000
    + system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
    + system.adapter.swiss-weather-api.0      : swiss-weather-api     : iobroker                                 -  enabled
    + system.adapter.telegram-menu.0          : telegram-menu         : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
      system.adapter.web-speedy.0             : web-speedy            : iobroker                                 - disabled
    + system.adapter.withings.0               : withings              : iobroker                                 -  enabled
    + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
    + system.adapter.zwave2.0                 : zwave2                : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.17.6   , installed 6.17.6
    Adapter    "backitup"     : 2.11.0   , installed 2.11.0
    Adapter    "bambulab"     : 0.3.2    , installed 0.3.2
    Adapter    "calendar"     : 1.2.0    , installed 1.2.0
    Adapter    "device-watcher": 2.12.0  , installed 2.12.0
    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
    Adapter    "email"        : 1.2.2    , installed 1.2.2
    Adapter    "esphome"      : 0.5.0-beta.8, installed 0.5.0-beta.8
    Adapter    "fakeroku"     : 0.2.2    , installed 0.2.2
    Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
    Adapter    "garmin"       : 0.1.1    , installed 0.1.1
    Adapter    "harmony"      : 1.4.0    , installed 1.4.0
    Adapter    "hyperion_ng"  : 0.1.23   , installed 0.1.23
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 8.0.3    , installed 8.0.3
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
    Adapter    "logparser"    : 2.2.2    , installed 2.2.2
    Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "proxmox"      : 2.2.3    , installed 2.2.3
    Adapter    "robonect"     : 1.3.4    , installed 1.3.4
    Adapter    "roomba"       : 1.2.2    , installed 1.2.2
    Adapter    "scheduler"    : 1.3.10   , installed 1.3.10
    Adapter    "shelly"       : 6.9.0    , installed 6.9.0
    Adapter    "snmp"         : 3.2.0    , installed 3.2.0
    Adapter    "socketio"     : 6.6.1    , installed 6.6.1
    Adapter    "squeezeboxrpc": 1.3.10   , installed 1.3.10
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "swiss-weather-api": 2.1.0, installed 2.1.0
    Adapter    "telegram"     : 3.2.1    , installed 3.2.1
    Adapter    "telegram-menu": 1.6.3    , installed 1.6.3
    Adapter    "vis-2"        : 2.9.51   , installed 2.9.51
    Adapter    "vis-2-widgets-material": 1.3.30, installed 1.3.30
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "web-speedy"   : 0.2.0    , installed 0.2.0
    Adapter    "withings"     : 0.0.13   , installed 0.0.13
    Adapter    "ws"           : 2.6.1    , installed 2.6.1
    Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
    Adapter    "zwave2"       : 3.1.0    , installed 3.1.0
    Objects and States
    Objects:        41540
    States:         35417
    Hit:2 http://security.debian.org bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       1429027    5208/io.shelly.0
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1163027    1/systemd
    tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1001       1431317    5304/python3
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1424950    4978/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1424957    4978/iobroker.js-co
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          1165300    296/master
    tcp        0      0 192.168.99.5:9093       0.0.0.0:*               LISTEN      1001       1442870    5843/io.fakeroku.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          1163029    1/systemd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          1164954    1/systemd
    tcp6       0      0 :::51989                :::*                    LISTEN      1001       1428790    5161/io.nuki-extend
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          1165301    296/master
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       1437293    5704/io.simple-api.
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1425052    4999/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1438917    5749/io.web.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1163028    1/systemd
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       1442871    5843/io.fakeroku.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1429502    5283/io.esphome.0
    udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1001       1431323    5304/python3
    udp        0      0 192.168.99.5:5353       0.0.0.0:*                           1001       1431322    5304/python3
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1431318    5304/python3
    udp6       0      0 :::111                  :::*                                0          1163030    1/systemd
    2024-04-26 15:31:40.480  - debug: mielecloudservice.0 (5131) Device 000176952557: Value {"processAction":[2],"light":[],"ambientLight":[],"startTime":[],"ventilationStep":[],"programId":[],"targetTemperature":[],"deviceName":true,"powerOn":false,"powerOff":true,"colors":[],"modes":[],"runOnTime":[]} | typeof value object
    2024-04-26 15:31:40.480  - debug: mielecloudservice.0 (5131) KnownDevice before updating actions on it: {"lastMessage":1714137684144,"icon":"icons/2.svg","API_ID":"000176952557","deviceType":2,"name":"Trockner","actions":{"processAction":[2],"light":[],"ambientLight":[],"startTime":[],"ventilationStep":[],"programId":[],"targetTemperature":[],"deviceName":true,"powerOn":false,"powerOff":true,"colors":[],"modes":[],"runOnTime":[]},"programs":[{"programId":1,"program":"Automatic plus","parameters":{}},{"programId":2,"program":"Baumwolle","parameters":{}},{"programId":3,"program":"Pflegeleicht","parameters":{}},{"programId":4,"program":"Finish Wolle","parameters":{}},{"programId":5,"program":"Feinwäsche","parameters":{}},{"programId":6,"program":"Lüften warm","parameters":{}},{"programId":7,"program":"Lüften kalt","parameters":{}},{"programId":8,"program":"Express","parameters":{}},{"programId":9,"program":"Baumwolle ","parameters":{}},{"programId":10,"program":"Vorbügeln","parameters":{}},{"programId":11,"program":"Baumwolle Hygiene","parameters":{}},{"programId":12,"program":"Imprägnieren","parameters":{}},{"programId":13,"program":"Jeans","parameters":{}},{"programId":14,"program":"Oberhemden","parameters":{}},{"programId":15,"program":"Sportwäsche","parameters":{}},{"programId":16,"program":"Outdoor","parameters":{}},{"programId":17,"program":"Finish Seide","parameters":{}},{"programId":19,"program":"Kopfkissen","parameters":{}},{"programId":20,"program":"Kopfkissen groß","parameters":{}},{"programId":22,"program":"Korbprogramm","parameters":{}},{"programId":24,"program":"Finish Dampf","parameters":{}},{"programId":25,"program":"Extra leise","parameters":{}},{"programId":31,"program":"Bettwäsche","parameters":{}},{"programId":60,"program":"","parameters":{}}]}
    2024-04-26 15:31:40.552  - silly: mielecloudservice.0 (5131) States user redis pmessage mielecloudservice.0.000176952557.ACTIONS.*/mielecloudservice.0.000176952557.ACTIONS.Nickname:{"val":"Trockner","ack":true,"ts":1714138300543,"q":0,"from":"system.adapter.mielecloudservice.0","user":"system.user.admin","lc":1686909005271}
    2024-04-26 15:31:40.561  - silly: mielecloudservice.0 (5131) States user redis pmessage mielecloudservice.0.000176952557.ACTIONS.*/mielecloudservice.0.000176952557.ACTIONS.startTime:{"val":"0:00","ack":true,"ts":1714138300547,"q":0,"from":"system.adapter.mielecloudservice.0","user":"system.user.admin","lc":1712052964855}
    2024-04-26 15:31:40.566  - silly: mielecloudservice.0 (5131) States user redis pmessage mielecloudservice.0.000176952557.ACTIONS.*/mielecloudservice.0.000176952557.ACTIONS.LastActionResult:{"val":"","ack":true,"ts":1714138300548,"q":0,"from":"system.adapter.mielecloudservice.0","user":"system.user.admin","lc":1650957714882}
    2024-04-26 15:31:40.569  - silly: mielecloudservice.0 (5131) States user redis pmessage mielecloudservice.0.000176952557.ACTIONS.*/mielecloudservice.0.000176952557.ACTIONS.Power:{"val":true,"ack":true,"ts":1714138300548,"q":0,"from":"system.adapter.mielecloudservice.0","user":"system.user.admin","lc":1714137719678}
    2024-04-26 15:31:40.569  - silly: mielecloudservice.0 (5131) States user redis pmessage mielecloudservice.0.000176952557.ACTIONS.*/mielecloudservice.0.000176952557.ACTIONS.Start:{"val":true,"ack":true,"ts":1714138300548,"q":0,"from":"system.adapter.mielecloudservice.0","user":"system.user.admin","lc":1650957714903}
    2024-04-26 15:31:40.569  - silly: mielecloudservice.0 (5131) States user redis pmessage mielecloudservice.0.000176952557.ACTIONS.*/mielecloudservice.0.000176952557.ACTIONS.Stop:{"val":true,"ack":true,"ts":1714138300548,"q":0,"from":"system.adapter.mielecloudservice.0","user":"system.user.admin","lc":1650957714903}
    2024-04-26 15:31:40.569  - silly: mielecloudservice.0 (5131) States user redis pmessage mielecloudservice.0.000176952557.ACTIONS.*/mielecloudservice.0.000176952557.ACTIONS.Light:{"val":false,"ack":true,"ts":1714138300548,"q":0,"from":"system.adapter.mielecloudservice.0","user":"system.user.admin","lc":1650957714968}
    2024-04-26 15:31:40.569  - debug: mielecloudservice.0 (5131) Programs for device Trockner are already registered. Skipping Query.
    2024-04-26 15:31:41.001  - info: javascript.0 (7348) script.js.Statusänderungen.tumbler_laufzeit: Update 1714138301001-946681200000 => 213182:31:41
    2024-04-26 15:31:42.001  - info: javascript.0 (7348) script.js.Statusänderungen.tumbler_laufzeit: Update 1714138302001-946681200000 => 213182:31:42
    2024-04-26 15:31:43.000  - info: javascript.0 (7348) script.js.Statusänderungen.tumbler_laufzeit: Update 1714138303000-946681200000 => 213182:31:42
    2024-04-26 15:31:44.001  - info: javascript.0 (7348) script.js.Statusänderungen.tumbler_laufzeit: Update 1714138304001-946681200000 => 213182:31:44
    2024-04-26 15:31:44.110  - info: javascript.0 (7348) script.js.Statusänderungen.temperature_change_json: Temperature Sensor JSON updated
    2024-04-26 15:31:44.110  - info: javascript.0 (7348) script.js.Statusänderungen.wetterdaten_aktuell_json: Weatherdata updated
    2024-04-26 15:31:44.113  - info: javascript.0 (7348) script.js.Statusänderungen.temperature_change_json: Temperature Sensor JSON updated
    2024-04-26 15:31:44.113  - info: javascript.0 (7348) script.js.Statusänderungen.wetterdaten_aktuell_json: Weatherdata updated
    2024-04-26 15:31:44.290  - debug: mielecloudservice.0 (5131) Received PING message by SSE: {"type":"ping","data":"ping","lastEventId":"","origin":"https://api.mcs3.miele.com"}
    2024-04-26 15:31:45.000  - info: javascript.0 (7348) script.js.Statusänderungen.tumbler_laufzeit: Update 1714138305000-946681200000 => 213182:31:45
    2024-04-26 15:31:46.001  - info: javascript.0 (7348) script.js.Statusänderungen.tumbler_laufzeit: Update 1714138306001-946681200000 => 213182:31:46
    2024-04-26 15:31:47.001  - info: javascript.0 (7348) script.js.Statusänderungen.tumbler_laufzeit: Update 1714138307001-946681200000 => 213182:31:47
    2024-04-26 15:31:48.001  - info: javascript.0 (7348) script.js.Statusänderungen.tumbler_laufzeit: Update 1714138308001-946681200000 => 213182:31:48
    2024-04-26 15:31:49.001  - info: javascript.0 (7348) script.js.Statusänderungen.tumbler_laufzeit: Update 1714138309001-946681200000 => 213182:31:49
    2024-04-26 15:31:50.000  - info: javascript.0 (7348) script.js.Statusänderungen.tumbler_laufzeit: Update 1714138310000-946681200000 => 213182:31:50
    DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
    • E el_rob
      @el_rob
      Skript v.2023-10-10
      *** BASE SYSTEM ***
        Virtualization: lxc
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 2
                       RTC time: n/a
                RTC in local TZ: no
      admin
      /home/admin
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:             0B          0B          0B
               8192 M total memory
               3236 M used memory
                  0 M inactive memory
               4854 M free memory
                  0 M buffer memory
                101 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      *** FILESYSTEM ***
      /var:
      365M    /var/
      285M    /var/cache
      283M    /var/cache/apt
      67M     /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.5.0
      /usr/bin/npx            10.5.0
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.17.6
      javascript:     8.0.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        41540
      States:         35417
      Pending Updates: 0
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @el_rob stell mal die LOGLevels von Silly auf was Vernünftiges um - das haut Dir sonst das LOG voll.
      Lehrling seit 1975 !!!
      • E el_rob
        @el_rob
        Skript v.2023-10-10
        *** BASE SYSTEM ***
          Virtualization: lxc
        Docker          : false
        Kernel          : x86_64
        Userland        : amd64
        CPU threads: 2
                         RTC time: n/a
                  RTC in local TZ: no
        admin
        /home/admin
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Swap:             0B          0B          0B
                 8192 M total memory
                 3236 M used memory
                    0 M inactive memory
                 4854 M free memory
                    0 M buffer memory
                  101 M swap cache
                    0 M total swap
                    0 M used swap
                    0 M free swap
        *** FILESYSTEM ***
        /var:
        365M    /var/
        285M    /var/cache
        283M    /var/cache/apt
        67M     /var/lib
        USB-Devices by-id:
        /usr/bin/npm            10.5.0
        /usr/bin/npx            10.5.0
        nodejs:
          Version table:
             18.13.0+dfsg1-1 500
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.17.6
        javascript:     8.0.3
        Adapter State
        + instance is alive
        Objects and States
        Objects:        41540
        States:         35417
        Pending Updates: 0
        @el_rob sagte in Adapter ws und socketio:
        CPU threads: 2
        Gönn der Kiste ein paar Umdrehungen mehr.
        Boot Target: graphical.target
        sudo systemctl set-default multi-user.target
        Gönn der Kiste ein wenig Swap.
        Setz den mielecloudservice auf ein gescheites LogLevel, wenn du den nicht gerade debuggst.
        • E Offline
          el_rob
          @DJMarc75 @Thomas-Braun
          Danke für eure Hinweise.
          Beim Miele-Adapter habe ich das Log-Level bewusst auf Silly, weil ich gerade an einem JS in Zusammenhang mit diesem Adapter rumbastle und einfach das komplette Logging sehen wollte. Wird danach aber wieder auf "Info" umgestellt.
          Habe der Kiste jetzt 4 Kerne und 512M Swap gegeben, sowie multi-user.target als default gesetzt.
          Nun muss ich nur den socket.io-Adapter irgendwie wieder zum Laufen bringen, da meine selbst programmierte Android-App daran hängt... Habe jetzt mal auf der Github-Seite des Adapters ein Bug-Issue eröffnet.
          • I Offline
            I Offline
            inkblot_de
            schrieb am zuletzt editiert von inkblot_de
            Habe das gleiche Problem, mir scheint in der main.js folgendes das Problem zu sein:
            const LE = utils.commonTools.letsEncrypt;
            LetsEncrypt wurde im adapter-core wohl entfernt:
            https://github.com/ioBroker/adapter-core/commit/d07b06aa0d25ca83ca50a1ef4167322e5036fb4f
            Deswegen führt LE.createServerAsync schätze ich zu dem Fehler.
            EDIT:
            Ich habe in /opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js in Zeile 127 den entfernten Code:
            letsEncrypt: resolveNamedModule("letsencrypt"),
            wieder hinzugefügt, danach startet der Adapter wieder. Scheint also wirklich das Problem hier zu sein. Zumindest bei mir.
            foxriver76F E 2 Antworten Letzte Antwort
            • I inkblot_de
              EDIT:
              foxriver76F Offline
              foxriver76F Offline
              foxriver76
              schrieb am zuletzt editiert von foxriver76
              @inkblot_de Jop ist uns durch die Lappen gegangen müssen wir anpassen https://github.com/ioBroker/ioBroker.socketio/blob/3023b11254c4170c01daff2c7fcc88e7b81df5c1/main.js#L9
              Videotutorials & mehr
              • I inkblot_de
                EDIT:
                el_rob
                @inkblot_de sagte in Adapter ws und socketio:
                Top, das hat's gebracht!!! Vielen Dank für's Teilen, mein socket.io-Adapter läuft jetzt auch wieder 🙂
                • foxriver76F Offline
                  foxriver76F Offline
                  foxriver76
                  socket-io 6.7.0 sollte es wieder tun
                  I E 2 Antworten Letzte Antwort
                  • foxriver76F foxriver76
                    I Offline
                    I Offline
                    inkblot_de
                    @foxriver76 said in Adapter ws und socketio:
                    Danke für das schnelle Update :-)
                      el_rob
                      @foxriver76 sagte in Adapter ws und socketio:
                      Top, läuft wieder 👍 Vielen Dank für das schnelle Update!!!
