  4. Adapter ws und socketio
    1.0k
    6.1k
20 Beiträge 7 Kommentatoren 3.4k Aufrufe 7 Beobachtet
    @el_rob sagte in Adapter ws und socketio:
    node: v18.19.1
    Vermutlich die dfsg-Version.
    Stell das auf die nodesource-Variante um.
    iob nodejs-update
    el_rob
    @thomas-braun sagte in Adapter ws und socketio:
    node: v18.19.1
    iob nodejs-update
    Ne, daran scheint es nicht zu liegen...
    ioBroker nodejs updater 2023-10-13
    Recommended nodejs-version is: 18.20.2
    Checking your installation now. Please be patient!
    Your current setup is:
    /usr/bin/nodejs         v18.20.2
    /usr/bin/node           v18.20.2
    /usr/bin/npm            10.5.0
    /usr/bin/npx            10.5.0
    /usr/bin/corepack       0.25.2
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 18.20.2-1nodesource1
      Candidate: 18.20.2-1nodesource1
      Version table:
     *** 18.20.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.20.1-1nodesource1 1001
         18.20.0-1nodesource1 1001
         18.19.1-1nodesource1 1001
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org bookworm-security/main amd64 Packages
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    Nothing to do - Your installation is using the correct paths.
    Nothing to do - Your version is the recommended one.
    • E el_rob
      node: v18.19.1
      iob nodejs-update
      /usr/bin/npm            10.5.0
      /usr/bin/npx            10.5.0
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      @el_rob
      Dann ist jetzt zumindest die Laufzeitumgebung aktuell.
      E 1 Antwort Letzte Antwort
        @el_rob
        el_rob
        @el_rob
        😂 ...wäre aber trotzdem schön, wenn auch der Adapter wieder liefe! 😉
        Hier die Ausgabe von iob diag
        Skript v.2023-10-10
        *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer-container
                 Chassis: container ☐
          Virtualization: lxc
                  Kernel: Linux 6.8.4-2-pve
            Architecture: x86-64
        model name      : Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         15:31:18 up 45 min,  2 users,  load average: 1.16, 1.29, 1.17
        CPU threads: 2
        *** Time and Time Zones ***
                       Local time: Fri 2024-04-26 15:31:18 CEST
                   Universal time: Fri 2024-04-26 13:31:18 UTC
                         RTC time: n/a
                        Time zone: Europe/Zurich (CEST, +0200)
                      NTP service: inactive
                  RTC in local TZ: no
        *** User and Groups ***
        admin
        /home/admin
        admin sudo users iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:            8.6G        3.4G        5.1G        114K        105M        5.2G
        Swap:             0B          0B          0B
        Total:          8.6G        3.4G        5.1G
                 8192 M total memory
                 3236 M used memory
                 3195 M active memory
                    0 M inactive memory
                 4854 M free memory
                    0 M buffer memory
                  101 M swap cache
                    0 M total swap
                    0 M used swap
                    0 M free swap
        *** FAILED SERVICES ***
          UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
        * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
        2 loaded units listed.
        *** FILESYSTEM ***
        Filesystem                 Type      Size  Used Avail Use% Mounted on
        pmx-data/subvol-100-disk-0 zfs        17G  5.3G   12G  33% /
        none                       tmpfs     492K  4.0K  488K   1% /dev
        udev                       devtmpfs   16G     0   16G   0% /dev/tty
        tmpfs                      tmpfs      16G     0   16G   0% /dev/shm
        tmpfs                      tmpfs     6.3G  108K  6.3G   1% /run
        tmpfs                      tmpfs     5.0M     0  5.0M   0% /run/lock
        dmesg: read kernel buffer failed: Operation not permitted
        TARGET SOURCE                     FSTYPE OPTIONS
        /      pmx-data/subvol-100-disk-0 zfs    rw,relatime,xattr,posixacl,casesensitive
        /var:
        365M    /var/
        285M    /var/cache
        283M    /var/cache/apt
        237M    /var/cache/apt/archives
        67M     /var/lib
        Archived and active journals take up 453.5K in the file system.
        /opt/iobroker/backups:
        1.8G    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        631M    /opt/iobroker/iobroker-data/
        308M    /opt/iobroker/iobroker-data/esphome.0/.esphome
        275M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build
        219M    /opt/iobroker/iobroker-data/files
        13M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/nachttischlampe-rob/.pioenvs/nachttischlampe-rob/libFrameworkArduino.a
        9.7M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build/bedside-lamp-2/.pioenvs/bedside-lamp-2/firmware.elf
        9.7M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build/bedside-lamp-1/.pioenvs/bedside-lamp-1/firmware.elf
        9.4M    /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
        8.2M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        USB-Devices by-id:
        find: '/dev/serial/by-id/': No such file or directory
        *** NodeJS-Installation ***
        /usr/bin/npm            10.5.0
        /usr/bin/npx            10.5.0
        nodejs:
          Version table:
             18.13.0+dfsg1-1 500
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.19
        admin:          6.17.6
        javascript:     8.0.3
        Adapters from github:   1
        Adapter State
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        + system.adapter.bambulab.0               : bambulab              : iobroker                                 -  enabled, port: 8883
        + system.adapter.calendar.0               : calendar              : iobroker                                 -  enabled, port: 8095
        + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
          system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
        + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
        + system.adapter.esphome.0                : esphome               : iobroker                                 -  enabled
        + system.adapter.fakeroku.0               : fakeroku              : iobroker                                 -  enabled
        + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
          system.adapter.garmin.0                 : garmin                : iobroker                                 - disabled
          system.adapter.hyperion_ng.0            : hyperion_ng           : iobroker                                 - disabled
          system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
          system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        + system.adapter.linkeddevices.0          : linkeddevices         : iobroker                                 -  enabled
        + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
        + system.adapter.mielecloudservice.0      : mielecloudservice     : iobroker                                 -  enabled
        + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
        + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
        + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
        + system.adapter.omada.0                  : omada                 : iobroker                                 -  enabled, port: 8043
        + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
        + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
          system.adapter.robonect.0               : robonect              : iobroker                                 - disabled
          system.adapter.roomba.0                 : roomba                : iobroker                                 - disabled
        + system.adapter.scheduler.0              : scheduler             : iobroker                                 -  enabled
        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          system.adapter.snmp.0                   : snmp                  : iobroker                                 - disabled
          system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
          system.adapter.squeezeboxrpc.0          : squeezeboxrpc         : iobroker                                 - disabled, port: 9000
        + system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
        + system.adapter.swiss-weather-api.0      : swiss-weather-api     : iobroker                                 -  enabled
        + system.adapter.telegram-menu.0          : telegram-menu         : iobroker                                 -  enabled
        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
        + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
          system.adapter.web-speedy.0             : web-speedy            : iobroker                                 - disabled
        + system.adapter.withings.0               : withings              : iobroker                                 -  enabled
        + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
        + system.adapter.zwave2.0                 : zwave2                : iobroker                                 -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): beta
        Installed ioBroker-Instances
        Used repository: beta
        Adapter    "admin"        : 6.17.6   , installed 6.17.6
        Adapter    "backitup"     : 2.11.0   , installed 2.11.0
        Adapter    "bambulab"     : 0.3.2    , installed 0.3.2
        Adapter    "calendar"     : 1.2.0    , installed 1.2.0
        Adapter    "device-watcher": 2.12.0  , installed 2.12.0
        Adapter    "discovery"    : 4.5.0    , installed 4.5.0
        Adapter    "email"        : 1.2.2    , installed 1.2.2
        Adapter    "esphome"      : 0.5.0-beta.8, installed 0.5.0-beta.8
        Adapter    "fakeroku"     : 0.2.2    , installed 0.2.2
        Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
        Adapter    "garmin"       : 0.1.1    , installed 0.1.1
        Adapter    "harmony"      : 1.4.0    , installed 1.4.0
        Adapter    "hyperion_ng"  : 0.1.23   , installed 0.1.23
        Adapter    "info"         : 2.0.0    , installed 2.0.0
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Adapter    "javascript"   : 8.0.3    , installed 8.0.3
        Controller "js-controller": 5.0.19   , installed 5.0.19
        Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
        Adapter    "logparser"    : 2.2.2    , installed 2.2.2
        Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
        Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
        Adapter    "nut"          : 1.6.0    , installed 1.6.0
        Adapter    "proxmox"      : 2.2.3    , installed 2.2.3
        Adapter    "robonect"     : 1.3.4    , installed 1.3.4
        Adapter    "roomba"       : 1.2.2    , installed 1.2.2
        Adapter    "scheduler"    : 1.3.10   , installed 1.3.10
        Adapter    "shelly"       : 6.9.0    , installed 6.9.0
        Adapter    "snmp"         : 3.2.0    , installed 3.2.0
        Adapter    "socketio"     : 6.6.1    , installed 6.6.1
        Adapter    "squeezeboxrpc": 1.3.10   , installed 1.3.10
        Adapter    "statistics"   : 2.4.0    , installed 2.4.0
        Adapter    "swiss-weather-api": 2.1.0, installed 2.1.0
        Adapter    "telegram"     : 3.2.1    , installed 3.2.1
        Adapter    "telegram-menu": 1.6.3    , installed 1.6.3
        Adapter    "vis-2"        : 2.9.51   , installed 2.9.51
        Adapter    "vis-2-widgets-material": 1.3.30, installed 1.3.30
        Adapter    "web"          : 6.2.5    , installed 6.2.5
        Adapter    "web-speedy"   : 0.2.0    , installed 0.2.0
        Adapter    "withings"     : 0.0.13   , installed 0.0.13
        Adapter    "ws"           : 2.6.1    , installed 2.6.1
        Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
        Adapter    "zwave2"       : 3.1.0    , installed 3.1.0
        Objects and States
        Objects:        41540
        States:         35417
        Hit:2 http://security.debian.org bookworm-security InRelease
        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       1429027    5208/io.shelly.0
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1163027    1/systemd
        tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1001       1431317    5304/python3
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1424950    4978/iobroker.js-co
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1424957    4978/iobroker.js-co
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          1165300    296/master
        tcp        0      0 192.168.99.5:9093       0.0.0.0:*               LISTEN      1001       1442870    5843/io.fakeroku.0
        tcp6       0      0 :::111                  :::*                    LISTEN      0          1163029    1/systemd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          1164954    1/systemd
        tcp6       0      0 :::51989                :::*                    LISTEN      1001       1428790    5161/io.nuki-extend
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          1165301    296/master
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       1437293    5704/io.simple-api.
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1425052    4999/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1438917    5749/io.web.0
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1163028    1/systemd
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       1442871    5843/io.fakeroku.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1429502    5283/io.esphome.0
        udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1001       1431323    5304/python3
        udp        0      0 192.168.99.5:5353       0.0.0.0:*                           1001       1431322    5304/python3
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1431318    5304/python3
        udp6       0      0 :::111                  :::*                                0          1163030    1/systemd
        2024-04-26 15:31:40.480  - debug: mielecloudservice.0 (5131) Device 000176952557: Value {"processAction":[2],"light":[],"ambientLight":[],"startTime":[],"ventilationStep":[],"programId":[],"targetTemperature":[],"deviceName":true,"powerOn":false,"powerOff":true,"colors":[],"modes":[],"runOnTime":[]} | typeof value object
        2024-04-26 15:31:40.480  - debug: mielecloudservice.0 (5131) KnownDevice before updating actions on it: {"lastMessage":1714137684144,"icon":"icons/2.svg","API_ID":"000176952557","deviceType":2,"name":"Trockner","actions":{"processAction":[2],"light":[],"ambientLight":[],"startTime":[],"ventilationStep":[],"programId":[],"targetTemperature":[],"deviceName":true,"powerOn":false,"powerOff":true,"colors":[],"modes":[],"runOnTime":[]},"programs":[{"programId":1,"program":"Automatic plus","parameters":{}},{"programId":2,"program":"Baumwolle","parameters":{}},{"programId":3,"program":"Pflegeleicht","parameters":{}},{"programId":4,"program":"Finish Wolle","parameters":{}},{"programId":5,"program":"Feinwäsche","parameters":{}},{"programId":6,"program":"Lüften warm","parameters":{}},{"programId":7,"program":"Lüften kalt","parameters":{}},{"programId":8,"program":"Express","parameters":{}},{"programId":9,"program":"Baumwolle ","parameters":{}},{"programId":10,"program":"Vorbügeln","parameters":{}},{"programId":11,"program":"Baumwolle Hygiene","parameters":{}},{"programId":12,"program":"Imprägnieren","parameters":{}},{"programId":13,"program":"Jeans","parameters":{}},{"programId":14,"program":"Oberhemden","parameters":{}},{"programId":15,"program":"Sportwäsche","parameters":{}},{"programId":16,"program":"Outdoor","parameters":{}},{"programId":17,"program":"Finish Seide","parameters":{}},{"programId":19,"program":"Kopfkissen","parameters":{}},{"programId":20,"program":"Kopfkissen groß","parameters":{}},{"programId":22,"program":"Korbprogramm","parameters":{}},{"programId":24,"program":"Finish Dampf","parameters":{}},{"programId":25,"program":"Extra leise","parameters":{}},{"programId":31,"program":"Bettwäsche","parameters":{}},{"programId":60,"program":"","parameters":{}}]}
        2024-04-26 15:31:40.552  - silly: mielecloudservice.0 (5131) States user redis pmessage mielecloudservice.0.000176952557.ACTIONS.*/mielecloudservice.0.000176952557.ACTIONS.Nickname:{"val":"Trockner","ack":true,"ts":1714138300543,"q":0,"from":"system.adapter.mielecloudservice.0","user":"system.user.admin","lc":1686909005271}
        2024-04-26 15:31:40.561  - silly: mielecloudservice.0 (5131) States user redis pmessage mielecloudservice.0.000176952557.ACTIONS.*/mielecloudservice.0.000176952557.ACTIONS.startTime:{"val":"0:00","ack":true,"ts":1714138300547,"q":0,"from":"system.adapter.mielecloudservice.0","user":"system.user.admin","lc":1712052964855}
        2024-04-26 15:31:40.566  - silly: mielecloudservice.0 (5131) States user redis pmessage mielecloudservice.0.000176952557.ACTIONS.*/mielecloudservice.0.000176952557.ACTIONS.LastActionResult:{"val":"","ack":true,"ts":1714138300548,"q":0,"from":"system.adapter.mielecloudservice.0","user":"system.user.admin","lc":1650957714882}
        2024-04-26 15:31:40.569  - silly: mielecloudservice.0 (5131) States user redis pmessage mielecloudservice.0.000176952557.ACTIONS.*/mielecloudservice.0.000176952557.ACTIONS.Power:{"val":true,"ack":true,"ts":1714138300548,"q":0,"from":"system.adapter.mielecloudservice.0","user":"system.user.admin","lc":1714137719678}
        2024-04-26 15:31:40.569  - silly: mielecloudservice.0 (5131) States user redis pmessage mielecloudservice.0.000176952557.ACTIONS.*/mielecloudservice.0.000176952557.ACTIONS.Start:{"val":true,"ack":true,"ts":1714138300548,"q":0,"from":"system.adapter.mielecloudservice.0","user":"system.user.admin","lc":1650957714903}
        2024-04-26 15:31:40.569  - silly: mielecloudservice.0 (5131) States user redis pmessage mielecloudservice.0.000176952557.ACTIONS.*/mielecloudservice.0.000176952557.ACTIONS.Stop:{"val":true,"ack":true,"ts":1714138300548,"q":0,"from":"system.adapter.mielecloudservice.0","user":"system.user.admin","lc":1650957714903}
        2024-04-26 15:31:40.569  - silly: mielecloudservice.0 (5131) States user redis pmessage mielecloudservice.0.000176952557.ACTIONS.*/mielecloudservice.0.000176952557.ACTIONS.Light:{"val":false,"ack":true,"ts":1714138300548,"q":0,"from":"system.adapter.mielecloudservice.0","user":"system.user.admin","lc":1650957714968}
        2024-04-26 15:31:40.569  - debug: mielecloudservice.0 (5131) Programs for device Trockner are already registered. Skipping Query.
        2024-04-26 15:31:41.001  - info: javascript.0 (7348) script.js.Statusänderungen.tumbler_laufzeit: Update 1714138301001-946681200000 => 213182:31:41
        2024-04-26 15:31:42.001  - info: javascript.0 (7348) script.js.Statusänderungen.tumbler_laufzeit: Update 1714138302001-946681200000 => 213182:31:42
        2024-04-26 15:31:43.000  - info: javascript.0 (7348) script.js.Statusänderungen.tumbler_laufzeit: Update 1714138303000-946681200000 => 213182:31:42
        2024-04-26 15:31:44.001  - info: javascript.0 (7348) script.js.Statusänderungen.tumbler_laufzeit: Update 1714138304001-946681200000 => 213182:31:44
        2024-04-26 15:31:44.110  - info: javascript.0 (7348) script.js.Statusänderungen.temperature_change_json: Temperature Sensor JSON updated
        2024-04-26 15:31:44.110  - info: javascript.0 (7348) script.js.Statusänderungen.wetterdaten_aktuell_json: Weatherdata updated
        2024-04-26 15:31:44.113  - info: javascript.0 (7348) script.js.Statusänderungen.temperature_change_json: Temperature Sensor JSON updated
        2024-04-26 15:31:44.113  - info: javascript.0 (7348) script.js.Statusänderungen.wetterdaten_aktuell_json: Weatherdata updated
        2024-04-26 15:31:44.290  - debug: mielecloudservice.0 (5131) Received PING message by SSE: {"type":"ping","data":"ping","lastEventId":"","origin":"https://api.mcs3.miele.com"}
        2024-04-26 15:31:45.000  - info: javascript.0 (7348) script.js.Statusänderungen.tumbler_laufzeit: Update 1714138305000-946681200000 => 213182:31:45
        2024-04-26 15:31:46.001  - info: javascript.0 (7348) script.js.Statusänderungen.tumbler_laufzeit: Update 1714138306001-946681200000 => 213182:31:46
        2024-04-26 15:31:47.001  - info: javascript.0 (7348) script.js.Statusänderungen.tumbler_laufzeit: Update 1714138307001-946681200000 => 213182:31:47
        2024-04-26 15:31:48.001  - info: javascript.0 (7348) script.js.Statusänderungen.tumbler_laufzeit: Update 1714138308001-946681200000 => 213182:31:48
        2024-04-26 15:31:49.001  - info: javascript.0 (7348) script.js.Statusänderungen.tumbler_laufzeit: Update 1714138309001-946681200000 => 213182:31:49
        2024-04-26 15:31:50.000  - info: javascript.0 (7348) script.js.Statusänderungen.tumbler_laufzeit: Update 1714138310000-946681200000 => 213182:31:50
        DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
        • E el_rob
          @el_rob
          Skript v.2023-10-10
          *** BASE SYSTEM ***
            Virtualization: lxc
          Docker          : false
          Kernel          : x86_64
          Userland        : amd64
          CPU threads: 2
                           RTC time: n/a
                    RTC in local TZ: no
          admin
          /home/admin
          X-Server:       false
          Desktop:
          Terminal:
          *** MEMORY ***
          Swap:             0B          0B          0B
                   8192 M total memory
                   3236 M used memory
                      0 M inactive memory
                   4854 M free memory
                      0 M buffer memory
                    101 M swap cache
                      0 M total swap
                      0 M used swap
                      0 M free swap
          *** FILESYSTEM ***
          /var:
          365M    /var/
          285M    /var/cache
          283M    /var/cache/apt
          67M     /var/lib
          USB-Devices by-id:
          /usr/bin/npm            10.5.0
          /usr/bin/npx            10.5.0
          nodejs:
            Version table:
               18.13.0+dfsg1-1 500
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.17.6
          javascript:     8.0.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        41540
          States:         35417
          Pending Updates: 0
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          @el_rob stell mal die LOGLevels von Silly auf was Vernünftiges um - das haut Dir sonst das LOG voll.
          Lehrling seit 1975 !!!
          • E el_rob
            @el_rob
            Skript v.2023-10-10
            *** BASE SYSTEM ***
              Virtualization: lxc
            Docker          : false
            Kernel          : x86_64
            Userland        : amd64
            CPU threads: 2
                             RTC time: n/a
                      RTC in local TZ: no
            admin
            /home/admin
            X-Server:       false
            Desktop:
            Terminal:
            *** MEMORY ***
            Swap:             0B          0B          0B
                     8192 M total memory
                     3236 M used memory
                        0 M inactive memory
                     4854 M free memory
                        0 M buffer memory
                      101 M swap cache
                        0 M total swap
                        0 M used swap
                        0 M free swap
            *** FILESYSTEM ***
            /var:
            365M    /var/
            285M    /var/cache
            283M    /var/cache/apt
            67M     /var/lib
            USB-Devices by-id:
            /usr/bin/npm            10.5.0
            /usr/bin/npx            10.5.0
            nodejs:
              Version table:
                 18.13.0+dfsg1-1 500
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.17.6
            javascript:     8.0.3
            Adapter State
            + instance is alive
            Objects and States
            Objects:        41540
            States:         35417
            Pending Updates: 0
            CPU threads: 2
            Gönn der Kiste ein paar Umdrehungen mehr.
            Boot Target: graphical.target
            sudo systemctl set-default multi-user.target
            Gönn der Kiste ein wenig Swap.
            Setz den mielecloudservice auf ein gescheites LogLevel, wenn du den nicht gerade debuggst.
            • E Offline
              el_rob
              @DJMarc75 @Thomas-Braun
              Danke für eure Hinweise.
              Beim Miele-Adapter habe ich das Log-Level bewusst auf Silly, weil ich gerade an einem JS in Zusammenhang mit diesem Adapter rumbastle und einfach das komplette Logging sehen wollte. Wird danach aber wieder auf "Info" umgestellt.
              Habe der Kiste jetzt 4 Kerne und 512M Swap gegeben, sowie multi-user.target als default gesetzt.
              Nun muss ich nur den socket.io-Adapter irgendwie wieder zum Laufen bringen, da meine selbst programmierte Android-App daran hängt... Habe jetzt mal auf der Github-Seite des Adapters ein Bug-Issue eröffnet.
              • I Offline
                I Offline
                inkblot_de
                schrieb am zuletzt editiert von inkblot_de
                Habe das gleiche Problem, mir scheint in der main.js folgendes das Problem zu sein:
                const LE = utils.commonTools.letsEncrypt;
                LetsEncrypt wurde im adapter-core wohl entfernt:
                https://github.com/ioBroker/adapter-core/commit/d07b06aa0d25ca83ca50a1ef4167322e5036fb4f
                Deswegen führt LE.createServerAsync schätze ich zu dem Fehler.
                EDIT:
                Ich habe in /opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js in Zeile 127 den entfernten Code:
                letsEncrypt: resolveNamedModule("letsencrypt"),
                wieder hinzugefügt, danach startet der Adapter wieder. Scheint also wirklich das Problem hier zu sein. Zumindest bei mir.
                foxriver76F E 2 Antworten Letzte Antwort
                • I inkblot_de
                  EDIT:
                  foxriver76F Offline
                  foxriver76F Offline
                  foxriver76
                  schrieb am zuletzt editiert von foxriver76
                  @inkblot_de Jop ist uns durch die Lappen gegangen müssen wir anpassen https://github.com/ioBroker/ioBroker.socketio/blob/3023b11254c4170c01daff2c7fcc88e7b81df5c1/main.js#L9
                  Videotutorials & mehr
                  • I inkblot_de
                    EDIT:
                    el_rob
                    @inkblot_de sagte in Adapter ws und socketio:
                    Top, das hat's gebracht!!! Vielen Dank für's Teilen, mein socket.io-Adapter läuft jetzt auch wieder 🙂
                    • foxriver76F Offline
                      foxriver76F Offline
                      foxriver76
                      socket-io 6.7.0 sollte es wieder tun
                      I E 2 Antworten Letzte Antwort
                      • foxriver76F foxriver76
                        I Offline
                        I Offline
                        inkblot_de
                        @foxriver76 said in Adapter ws und socketio:
                        Danke für das schnelle Update :-)
                          el_rob
                          @foxriver76 sagte in Adapter ws und socketio:
                          Top, läuft wieder 👍 Vielen Dank für das schnelle Update!!!
