  4. io Broker lässt sich nicht updaten (Linux)
71 Beiträge 4 Kommentatoren 3.6k Aufrufe 3 Beobachtet
  • hans1990H hans1990
    @hans-jürgen-strudler said in io Broker lässt sich nicht updaten (Linux):
    (nur die letzten Zeilen, da sonst zu lange):
    hier ein Auszug von den Error Zeilen
    2024-04-26 16:12:44.343  - error: host.rasphj iobroker npm-install: host.rasphj Invalid version of "admin". Installed "5.1.25", required ">=5.1.28"
    2024-04-26 16:12:46.377  - warn: host.rasphj startInstance cannot find adapter "net-tools". Try to install it... 1 attempt
    2024-04-26 16:13:07.751  - error: host.rasphj iobroker npm-install: host.rasphj Invalid version of "admin". Installed "5.1.25", required ">=6.13.15"
    2024-04-26 16:13:09.784  - warn: host.rasphj startInstance cannot find adapter "ping". Try to install it... 1 attempt
    2024-04-26 16:13:24.644  - warn: host.rasphj startInstance cannot find adapter "shuttercontrol@1.2.1". Try to install it... 1 attempt
    2024-04-26 16:13:40.311  - warn: host.rasphj startInstance cannot find adapter "heytech@1.0.5". Try to install it... 1 attempt
    2024-04-26 16:13:50.827  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T14_13_45_983Z-debug-0.log
    2024-04-26 16:13:50.828  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
    2024-04-26 16:13:52.864  - warn: host.rasphj startInstance cannot find adapter "flot". Try to install it... 1 attempt
    2024-04-26 16:13:57.708  - warn: host.rasphj startInstance cannot find adapter "elero-usb-transmitter@0.5.2". Try to install it... 1 attempt
    2024-04-26 16:16:00.502  - warn: host.rasphj startInstance cannot find adapter "history@1.9.14". Try to install it... 1 attempt
    2024-04-26 16:16:18.909  - error: host.rasphj iobroker npm-install: host.rasphj Invalid version of "admin". Installed "5.1.25", required ">=5.1.28"
    2024-04-26 16:16:20.940  - warn: host.rasphj startInstance cannot find adapter "sonoff@2.4.5". Try to install it... 1 attempt
    2024-04-26 16:16:36.159  - warn: host.rasphj startInstance cannot find adapter "nuki-extended@2.3.1". Try to install it... 1 attempt
    2024-04-26 16:16:55.100  - warn: host.rasphj startInstance cannot find adapter "rpi2@1.3.1". Try to install it... 1 attempt
    2024-04-26 16:16:59.371  - warn: nuki-extended.0 (14121) Callback not attached because too many Callbacks attached to the Nuki Bridge already! Please delete a callback!
    2024-04-26 16:17:36.447  - warn: host.rasphj adapter "discovery" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
    2024-04-26 16:18:04.280  - warn: host.rasphj Slave controller detected disconnection. Stop all instances.
    2024-04-26 16:18:05.121  - error: host.rasphj Cannot find view "system" for search "instance" : Connection is closed.
    2024-04-26 16:18:05.123  - error: host.rasphj Cannot find view "system" for search "instance" : Connection is closed.
    2024-04-26 16:18:05.124  - error: host.rasphj Cannot find view "system" for search "instance" : Connection is closed.
    2024-04-26 16:18:05.144  - error: host.rasphj Cannot find view "system" for search "instance" : Connection is closed.
    2024-04-26 16:18:25.102  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
    2024-04-26 16:18:25.103  - error: host.rasphj Caught by controller[0]:   throw err;
    2024-04-26 16:18:25.104  - error: host.rasphj Caught by controller[0]:   ^
    2024-04-26 16:18:25.104  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js'
    2024-04-26 16:18:25.105  - error: host.rasphj Caught by controller[0]: Require stack:
    2024-04-26 16:18:25.105  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
    2024-04-26 16:18:25.105  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
    2024-04-26 16:18:25.106  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
    2024-04-26 16:18:25.106  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
    2024-04-26 16:18:25.107  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
    2024-04-26 16:18:25.108  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:18:18)
    2024-04-26 16:18:25.108  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
    2024-04-26 16:18:25.108  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
    2024-04-26 16:18:25.109  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
    2024-04-26 16:18:25.109  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
    2024-04-26 16:18:25.109  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
    2024-04-26 16:18:25.110  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2024-04-26 16:18:25.110  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/main.js' ]
    2024-04-26 16:18:25.110  - error: host.rasphj Caught by controller[0]: }
    2024-04-26 16:18:25.111  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
    2024-04-26 16:18:25.111  - error: host.rasphj instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-04-26 16:18:35.188  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T14_18_29_163Z-debug-0.log
    2024-04-26 16:18:35.189  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
    2024-04-26 16:18:37.280  - warn: host.rasphj adapter "admin" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
    2024-04-26 16:18:49.984  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
    2024-04-26 16:18:49.984  - error: host.rasphj Caught by controller[0]:   throw err;
    2024-04-26 16:18:49.985  - error: host.rasphj Caught by controller[0]:   ^
    2024-04-26 16:18:49.986  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools'
    2024-04-26 16:18:49.986  - error: host.rasphj Caught by controller[0]: Require stack:
    2024-04-26 16:18:49.987  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.discovery/main.js
    2024-04-26 16:18:49.987  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
    2024-04-26 16:18:49.987  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
    2024-04-26 16:18:49.988  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
    2024-04-26 16:18:49.988  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
    2024-04-26 16:18:49.989  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.discovery/main.js:17:21)
    2024-04-26 16:18:49.989  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
    2024-04-26 16:18:49.990  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
    2024-04-26 16:18:49.990  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
    2024-04-26 16:18:49.991  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
    2024-04-26 16:18:49.992  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
    2024-04-26 16:18:49.993  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2024-04-26 16:18:49.993  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.discovery/main.js' ]
    2024-04-26 16:18:49.994  - error: host.rasphj Caught by controller[0]: }
    2024-04-26 16:18:49.994  - error: host.rasphj Caught by controller[1]: Node.js v18.20.2
    2024-04-26 16:18:49.995  - error: host.rasphj instance system.adapter.discovery.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-04-26 16:25:41.925  - info: host.rasphj Rebuild for adapter system.adapter.web.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    @hans-jürgen-strudler sagte in io Broker lässt sich nicht updaten (Linux):
    teilweise vollkommen ok!
    Die Adapter müssen für das neue node neu gebaut werden. 1st attempt ist also korrekt.
    Andere Adapter benötigen eine höhere Version vom admin, bei dem es allerdings klemmt
    heytech ist anscheinend zu alt und nicht mehr unterstützt, oder über github installiert worden???
    warum das hängt sehe ich jetzt nicht
    hans1990H 1 Antwort Letzte Antwort
      @homoran said in io Broker lässt sich nicht updaten (Linux):
      Vielleicht hat @thomas-braun noch ne Idee.
      kann das helfen?
      kann das helfen?
      lass erst einmal alle Eingriffe sein!
      gibt es neuere log Zeilen als von 16:25?
        kann das helfen?
        hans1990H Offline
        hans1990H Offline
        hans1990
        Nein. Das war die letzte Zeile
          hast du sonst noch was gemacht?
          iob stop
          iob update
          iob upgrade self
          Ich hab versucht den Fehler zu reproduzieren.
          Leider hab ich nicht gespeichert wie die node Version zu hoch war, aber es sah ca. so aus:
          Copy to Clipboard
          npm ERR! notsup Required: {"node":"8<=  node => 13"}
          npm ERR! notsup Actual:   {"npm":"6.14.16","node":"18.20."}
          auf der Weboberfläche wurde ich informiert, dass das File System geändert wird. das dürfte gerade laufen.
          iob stop
          hattest du iobroker gestoppt, während dieser dabei war die Adapter neu zu bauen?
            hans1990H Offline
            hans1990H Offline
            hans1990
            Das weiß ich nicht mehr woher ich es installiert habe.
              und bei einem neuen iob logs --watch??
              ok, dann ist da was schiefgelaufen :-(
              bitte wenn nichts neues kommt aktuellen iob diag posten
                iob stop
                hans1990H Offline
                hans1990H Offline
                hans1990
                ich war auf der Weboberfläche und er hat mich informiert, dass das Filesystem geändert wird.
                sonst war nichts
                  sonst war nichts
                  sonst war nichts
                  und wann hattest du den controller upgedatet?
                  ohne node v18.20.2 ging das doch nicht
                    sonst war nichts
                    dass das Filesystem geändert wird ist mir nicht bekannt!
                    vielleich die Datenbank von file zu jsonl???
                    Vorhin schriebst du
                    ist es normal, dass die Weboberfläche derzeit nicht erreichbar ist?
                    wie bist du denn dann darauf gekommen?
                      sonst war nichts
                      hans1990H Offline
                      hans1990H Offline
                      hans1990
                      das war nach
                      iob nodejs-update
                        hans1990H Offline
                        hans1990H Offline
                        hans1990
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                           Static hostname: rasphj
                                 Icon name: computer
                          Operating System: Raspbian GNU/Linux 11 (bullseye)
                                    Kernel: Linux 6.1.21-v8+
                              Architecture: arm64
                        Model           : Raspberry Pi 4 Model B Rev 1.1
                        Docker          : false
                        Virtualization  : none
                        Kernel          : aarch64
                        Userland        : armhf
                        Systemuptime and Load:
                         17:18:36 up  3:03,  1 user,  load average: 2.09, 0.61, 0.31
                        CPU threads: 4
                        *** RASPBERRY THROTTLING ***
                        Current issues:
                        Previously detected issues:
                        *** Time and Time Zones ***
                                       Local time: Fri 2024-04-26 17:18:36 CEST
                                   Universal time: Fri 2024-04-26 15:18:36 UTC
                                         RTC time: n/a
                                        Time zone: Europe/Vienna (CEST, +0200)
                                      NTP service: active
                                  RTC in local TZ: no
                        *** User and Groups ***
                        pi
                        /home/pi
                        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                        *** X-Server-Setup ***
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            3.8G        589M        1.5G        0.0K        1.7G        3.1G
                        Swap:            99M          0B         99M
                        Total:          3.9G        589M        1.6G
                                 3794 M total memory
                                  589 M used memory
                                  635 M active memory
                                 1380 M inactive memory
                                 1530 M free memory
                                  169 M buffer memory
                                 1504 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FAILED SERVICES ***
                        0 loaded units listed.
                        *** FILESYSTEM ***
                        /dev/root      ext4       59G  4.6G   52G   9% /
                        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                        tmpfs          tmpfs     759M  820K  759M   1% /run
                        /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
                        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                        [Fri Apr 26 14:15:03 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:45:7D:BA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d53cc083-02 rootfstype=ext4 fsck.repair=yes rootwait
                        [Fri Apr 26 14:15:04 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                        [Fri Apr 26 14:15:04 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                        [Fri Apr 26 14:15:06 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                        TARGET  SOURCE         FSTYPE OPTIONS
                        /       /dev/mmcblk0p2 ext4   rw,noatime
                        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                        /var:
                        1.7G    /var/
                        1.3G    /var/log/journal/3e23e34d17484a28b9473f69f7d9d21c
                        1.3G    /var/log
                        202M    /var/cache
                        Archived and active journals take up 1.2G in the file system.
                        /opt/iobroker/backups:
                        24M     /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        202M    /opt/iobroker/iobroker-data/
                        87M     /opt/iobroker/iobroker-data/history
                        52M     /opt/iobroker/iobroker-data/files
                        45M     /opt/iobroker/iobroker-data/backup-objects
                        27M     /opt/iobroker/iobroker-data/files/javascript.admin
                        9.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
                        6.3M    /opt/iobroker/iobroker-data/objects.json.migrated
                        6.3M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                        6.2M    /opt/iobroker/iobroker-data/objects.jsonl
                        4.4M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
                        USB-Devices by-id:
                        find: '/dev/serial/by-id/': No such file or directory
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs         v18.20.2
                        /usr/bin/node           v18.20.2
                        /usr/bin/npm            10.5.0
                        /usr/bin/npx            10.5.0
                        /usr/bin/corepack       0.25.2
                        nodejs:
                          Installed: 18.20.2-1nodesource1
                          Candidate: 18.20.2-1nodesource1
                          Version table:
                         *** 18.20.2-1nodesource1 600
                                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                             18.20.1-1nodesource1 600
                             18.20.0-1nodesource1 600
                             18.19.1-1nodesource1 600
                             18.19.0-1nodesource1 600
                             18.18.2-1nodesource1 600
                             18.18.1-1nodesource1 600
                             18.18.0-1nodesource1 600
                             18.17.1-1nodesource1 600
                             18.17.0-1nodesource1 600
                             18.16.1-1nodesource1 600
                             18.16.0-1nodesource1 600
                             18.15.0-1nodesource1 600
                             18.14.2-1nodesource1 600
                             18.14.1-1nodesource1 600
                             18.14.0-1nodesource1 600
                             18.13.0-1nodesource1 600
                             18.12.0-1nodesource1 600
                             18.11.0-1nodesource1 600
                             18.10.0-1nodesource1 600
                             18.9.1-1nodesource1 600
                             18.9.0-1nodesource1 600
                             18.8.0-1nodesource1 600
                             18.7.0-1nodesource1 600
                             18.6.0-1nodesource1 600
                             18.5.0-1nodesource1 600
                             18.4.0-1nodesource1 600
                             18.3.0-1nodesource1 600
                             18.2.0-1nodesource1 600
                             18.1.0-1nodesource1 600
                             18.0.0-1nodesource1 600
                             12.22.12~dfsg-1~deb11u4 500
                        No problems detected
                        Errors in npm tree:
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Core adapters versions
                        js-controller:  5.0.19
                        admin:          5.1.25
                        javascript:     5.2.13
                        Adapters from github:   0
                        Adapter State
                          system.adapter.admin.0                  : admin                 : rasphj                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          system.adapter.admin.1                  : admin                 : rasphj                                   - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                        + system.adapter.backitup.0               : backitup              : rasphj                                   -  enabled
                          system.adapter.discovery.0              : discovery             : rasphj                                   -  enabled
                          system.adapter.elero-usb-transmitter.0  : elero-usb-transmitter : rasphj                                   - disabled
                          system.adapter.flot.0                   : flot                  : rasphj                                   -  enabled
                          system.adapter.heytech.0                : heytech               : rasphj                                   - disabled, port: 1002
                        + system.adapter.history.0                : history               : rasphj                                   -  enabled
                          system.adapter.homee.0                  : homee                 : rasphj                                   - disabled
                        + system.adapter.javascript.0             : javascript            : rasphj                                   -  enabled
                          system.adapter.net-tools.0              : net-tools             : rasphj                                   - disabled
                        + system.adapter.nuki-extended.0          : nuki-extended         : rasphj                                   -  enabled
                        + system.adapter.nuki.0                   : nuki                  : rasphj                                   -  enabled
                        + system.adapter.octoprint.0              : octoprint             : rasphj                                   -  enabled
                          system.adapter.ping.0                   : ping                  : rasphj                                   - disabled
                        + system.adapter.rpi2.0                   : rpi2                  : rasphj                                   -  enabled
                        + system.adapter.shelly.0                 : shelly                : rasphj                                   -  enabled, port: 1883, bind: 0.0.0.0
                          system.adapter.shuttercontrol.0         : shuttercontrol        : rasphj                                   - disabled
                        + system.adapter.sonoff.0                 : sonoff                : rasphj                                   -  enabled, port: 1883, bind: 0.0.0.0
                          system.adapter.synology.0               : synology              : rasphj                                   - disabled, port: 5000
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : rasphj                                   -  enabled
                          system.adapter.vis.0                    : vis                   : rasphj                                   -  enabled
                          system.adapter.web.0                    : web                   : rasphj                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        + system.adapter.wled.0                   : wled                  : rasphj                                   -  enabled
                        + instance is alive
                        ioBroker-Repositories
                        Active repo(s): stable
                        Installed ioBroker-Instances
                        Used repository: stable
                        Adapter    "admin"        : 6.13.16  , installed 5.1.25 [Updatable]
                        Adapter    "backitup"     : 2.11.0   , installed 2.2.2  [Updatable]
                        Adapter    "discovery"    : 4.4.0    , installed 2.7.3  [Updatable]
                        Adapter    "elero-usb-transmitter": 0.5.2, installed 0.5.2
                        Adapter    "homee"        : 1.2.0    , installed 1.2.0
                        Adapter    "javascript"   : 7.8.0    , installed 5.2.13 [Updatable]
                        Controller "js-controller": 5.0.19   , installed 5.0.19
                        Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
                        Adapter    "nuki"         : 1.6.0    , installed 1.5.0  [Updatable]
                        Adapter    "nuki-extended": 2.6.5    , installed 2.3.1  [Updatable]
                        Adapter    "octoprint"    : 5.1.0    , installed 1.1.1  [Updatable]
                        Adapter    "rpi2"         : 1.3.2    , installed 1.3.1  [Updatable]
                        Adapter    "shelly"       : 6.8.0    , installed 4.0.7  [Updatable]
                        Adapter    "shuttercontrol": 1.7.0   , installed 1.2.1  [Updatable]
                        Adapter    "socketio"     : 6.6.1    , installed 6.6.1
                        Adapter    "sonoff"       : 3.0.3    , installed 2.4.5  [Updatable]
                        Adapter    "synology"     : 3.1.0    , installed 3.1.0
                        Adapter    "vis"          : 1.5.4    , installed 1.4.5  [Updatable]
                        Adapter    "vis-timeandweather": 1.2.2, installed 1.1.7 [Updatable]
                        Adapter    "web"          : 6.2.5    , installed 3.4.9  [Updatable]
                        Adapter    "wled"         : 0.7.2    , installed 0.6.3  [Updatable]
                        Objects and States
                        Objects:        3146
                        States:         2056
                        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                        Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                        Reading package lists...
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       145618     23162/io.sonoff.0
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       145498     23046/iobroker.js-c
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       144524     23046/iobroker.js-c
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11069      520/sshd: /usr/sbin
                        tcp6       0      0 :::51989                :::*                    LISTEN      1001       145658     23186/io.nuki-exten
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          11071      520/sshd: /usr/sbin
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       147919     24059/io.wled.0
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14706      388/avahi-daemon: r
                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       147929     23996/io.shelly.0
                        udp        0      0 0.0.0.0:52988           0.0.0.0:*                           108        14708      388/avahi-daemon: r
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13180      729/dhcpcd
                        udp6       0      0 :::546                  :::*                                0          11105      729/dhcpcd
                        udp6       0      0 :::5353                 :::*                                108        14707      388/avahi-daemon: r
                        udp6       0      0 :::48970                :::*                                108        14709      388/avahi-daemon: r
                        2024-04-26 17:19:53.598  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                        2024-04-26 17:19:53.598  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                        2024-04-26 17:19:53.598  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                        2024-04-26 17:19:53.599  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                        2024-04-26 17:19:53.599  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                        2024-04-26 17:19:53.599  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                        2024-04-26 17:19:53.600  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                        2024-04-26 17:19:53.600  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                        2024-04-26 17:19:53.600  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                        2024-04-26 17:19:53.600  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                        2024-04-26 17:19:53.601  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                        2024-04-26 17:19:53.601  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                        2024-04-26 17:19:53.601  - error: host.rasphj Caught by controller[0]: }
                        2024-04-26 17:19:53.601  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                        2024-04-26 17:19:53.602  - error: host.rasphj instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2024-04-26 17:19:53.602  - info: host.rasphj Adapter system.adapter.web.0 needs rebuild of iobroker.js-controller and will be restarted afterwards.
                        2024-04-26 17:19:53.602  - info: host.rasphj system.adapter.web.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules","module":"iobroker.js-controller","version":"5.0.19"})
                        2024-04-26 17:19:57.139  - info: host.rasphj iobroker npm-install: NPM version: 10.5.0
                        2024-04-26 17:19:57.142  - info: host.rasphj iobroker npm-install: Installing iobroker.heytech@1.0.5... (System call)
                        2024-04-26 17:20:05.490  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T15_19_58_387Z-debug-0.log
                        2024-04-26 17:20:05.491  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
                        2024-04-26 17:20:06.531  - info: host.rasphj iobroker npm-install: exit 25
                        2024-04-26 17:20:07.531  - warn: host.rasphj adapter "admin" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                        2024-04-26 17:20:07.532  - info: host.rasphj iobroker rebuild iobroker.js-controller@5.0.19 --path /opt/iobroker/node_modules
                        2024-04-26 17:20:09.540  - info: host.rasphj iobroker npm-rebuild: Rebuilding native module "iobroker.js-controller@5.0.19" in /opt/iobroker/node_modules ...
                          das war nach
                          iob nodejs-update
                          das war nach
                          also hast du iobroker gestoppt, während er dabei war alles neu zu bauen.
                          da er das weitestgehend alphabetisch nacht, warcer möglicherweise gerade beim admin 😡
                            Vorhin schriebst du
                            hans1990H Offline
                            hans1990H Offline
                            hans1990
                            ja genau das wars. das war die Info auf der Web oberfläche und dann war diese nachher nicht mehr erreichbar
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : armhf
                              CPU threads: 4
                              Current issues:
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              /home/pi
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:            99M          0B         99M
                                       3794 M total memory
                                        589 M used memory
                                        635 M active memory
                                       1530 M free memory
                                        169 M buffer memory
                                       1504 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /var:
                              1.7G    /var/
                              1.3G    /var/log
                              202M    /var/cache
                              USB-Devices by-id:
                              /usr/bin/npm            10.5.0
                              /usr/bin/npx            10.5.0
                              nodejs:
                                Version table:
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          5.1.25
                              javascript:     5.2.13
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        3146
                              States:         2056
                              Pending Updates: 0
                              da sind doch noch logeinträge nach 16:25!!!!
                              er war also noch nicht fertig!!
                              @homoran sagte in io Broker lässt sich nicht updaten (Linux):
                                hans1990H Offline
                                hans1990H Offline
                                hans1990
                                schrieb am zuletzt editiert von hans1990
                                Macht es sinn nochmal vom backup zu starten?
                                iob nodejs-update
                                iob stop
                                iob update
                                iob upgrade self
                                iob start
                                Weboberfläche erst öffnen wenn die adapter fertig neu sind?
                                Wie würdest du nach dem Befehl
                                iob nodejs-update
                                weiter vorgehen?
                                Danke für deine Geduld und Hilfe!
                                  iob nodejs-update
                                  iob stop
                                  iob update
                                  iob upgrade self
                                  iob start
                                  iob nodejs-update
                                  weiter vorgehen?
                                  iob nodejs-update
                                  Kannst du dir sparen, das ist ja jetzt die richtige Version.
                                  Ist jetzt im LogFile Ruhe eingekehrt?
                                  iob update
                                  sagt?
                                    iob nodejs-update
                                    iob update
                                    sagt?
                                    hans1990H Offline
                                    hans1990H Offline
                                    hans1990
                                    @thomas-braun said in io Broker lässt sich nicht updaten (Linux):
                                    iob update
                                    sagt?
                                    pi@rasphj:~ $ iob update
                                    ja war ruhig - hab dann einen reboot gemacht und ist wieder hier hängen geblieben
                                    2024-04-26 17:46:13.582  - info: host.rasphj Rebuild for adapter system.adapter.admin.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                    2024-04-26 17:46:13.929  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                                    2024-04-26 17:46:13.929  - error: host.rasphj Caught by controller[0]:   throw err;
                                    2024-04-26 17:46:13.930  - error: host.rasphj Caught by controller[0]:   ^
                                    2024-04-26 17:46:13.930  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
                                    2024-04-26 17:46:13.930  - error: host.rasphj Caught by controller[0]: Require stack:
                                    2024-04-26 17:46:13.931  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
                                    2024-04-26 17:46:13.931  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                                    2024-04-26 17:46:13.931  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                                    2024-04-26 17:46:13.932  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                                    2024-04-26 17:46:13.932  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                                    2024-04-26 17:46:13.932  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                                    2024-04-26 17:46:13.933  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                                    2024-04-26 17:46:13.933  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                                    2024-04-26 17:46:13.934  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                                    2024-04-26 17:46:13.934  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                                    2024-04-26 17:46:13.934  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                                    2024-04-26 17:46:13.935  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                    2024-04-26 17:46:13.935  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                                    2024-04-26 17:46:13.935  - error: host.rasphj Caught by controller[0]: }
                                    2024-04-26 17:46:13.936  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                                    2024-04-26 17:46:13.936  - error: host.rasphj instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    2024-04-26 17:46:13.936  - info: host.rasphj Rebuild for adapter system.adapter.web.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                    2024-04-26 17:46:17.534  - info: host.rasphj iobroker npm-install: NPM version: 10.5.0
                                    2024-04-26 17:46:17.538  - info: host.rasphj iobroker npm-install: Installing iobroker.heytech@1.0.5... (System call)
                                    2024-04-26 17:46:24.616  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T15_46_18_637Z-debug-0.log
                                    2024-04-26 17:46:24.617  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
                                    2024-04-26 17:46:25.653  - info: host.rasphj iobroker npm-install: exit 25
                                    2024-04-26 17:46:26.655  - error: host.rasphj Cannot download and install adapter "heytech@1.0.5". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
                                      iob update
                                      sagt?
                                      iob upgrade heytech@1.0.6
                                        hans1990H Offline
                                        hans1990H Offline
                                        hans1990
                                        pi@rasphj:~ $ iob upgrade heytech@1.0.6
                                        Adapter "heytech"        is not installed.
                                          iob update
                                          sagt?
                                          Ja da wirst du die Installation unterbrochen haben und der admin ist jetzt in einem undefinierten Zustand.
                                          ich gab jetzt den vollständigen Pfad zum Adapter directory nicht im Kopf. Thomas wird es dir sagen
