  4. io Broker lässt sich nicht updaten (Linux)
71 Beiträge 4 Kommentatoren 3.6k Aufrufe 3 Beobachtet
  • hans1990H hans1990
    @homoran said in io Broker lässt sich nicht updaten (Linux):
    beobachte dann über Konsole mit iob logs --watch und nicht irgendwo eingreifen
    Das ist das Ergebnis (nur die letzten Zeilen, da sonst zu lange):
    2024-04-26 16:23:05.616  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
    2024-04-26 16:23:05.617  - error: host.rasphj Caught by controller[0]:   throw err;
    2024-04-26 16:23:05.618  - error: host.rasphj Caught by controller[0]:   ^
    2024-04-26 16:23:05.618  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools'
    2024-04-26 16:23:05.618  - error: host.rasphj Caught by controller[0]: Require stack:
    2024-04-26 16:23:05.619  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.discovery/main.js
    2024-04-26 16:23:05.619  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
    2024-04-26 16:23:05.619  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
    2024-04-26 16:23:05.619  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
    2024-04-26 16:23:05.620  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
    2024-04-26 16:23:05.620  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.discovery/main.js:17:21)
    2024-04-26 16:23:05.620  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
    2024-04-26 16:23:05.620  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
    2024-04-26 16:23:05.621  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
    2024-04-26 16:23:05.621  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
    2024-04-26 16:23:05.621  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
    2024-04-26 16:23:05.621  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2024-04-26 16:23:05.622  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.discovery/main.js' ]
    2024-04-26 16:23:05.622  - error: host.rasphj Caught by controller[0]: }
    2024-04-26 16:23:05.622  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
    2024-04-26 16:23:05.623  - error: host.rasphj instance system.adapter.discovery.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-04-26 16:23:05.623  - info: host.rasphj Adapter system.adapter.discovery.0 needs rebuild and will be restarted afterwards.
    2024-04-26 16:23:05.624  - info: host.rasphj system.adapter.discovery.0 will be rebuilt
    2024-04-26 16:23:05.838  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
    2024-04-26 16:23:05.838  - error: host.rasphj Caught by controller[0]:   throw err;
    2024-04-26 16:23:05.838  - error: host.rasphj Caught by controller[0]:   ^
    2024-04-26 16:23:05.838  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js'
    2024-04-26 16:23:05.839  - error: host.rasphj Caught by controller[0]: Require stack:
    2024-04-26 16:23:05.839  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
    2024-04-26 16:23:05.839  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
    2024-04-26 16:23:05.839  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
    2024-04-26 16:23:05.839  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
    2024-04-26 16:23:05.839  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
    2024-04-26 16:23:05.840  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:18:18)
    2024-04-26 16:23:05.840  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
    2024-04-26 16:23:05.840  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
    2024-04-26 16:23:05.840  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
    2024-04-26 16:23:05.840  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
    2024-04-26 16:23:05.840  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
    2024-04-26 16:23:05.841  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2024-04-26 16:23:05.841  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/main.js' ]
    2024-04-26 16:23:05.841  - error: host.rasphj Caught by controller[0]: }
    2024-04-26 16:23:05.841  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
    2024-04-26 16:23:05.841  - error: host.rasphj instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-04-26 16:23:05.841  - info: host.rasphj Adapter system.adapter.admin.0 needs rebuild and will be restarted afterwards.
    2024-04-26 16:23:05.842  - info: host.rasphj system.adapter.admin.0 will be rebuilt
    2024-04-26 16:23:05.907  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
    2024-04-26 16:23:05.907  - error: host.rasphj Caught by controller[0]:   throw err;
    2024-04-26 16:23:05.907  - error: host.rasphj Caught by controller[0]:   ^
    2024-04-26 16:23:05.908  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
    2024-04-26 16:23:05.908  - error: host.rasphj Caught by controller[0]: Require stack:
    2024-04-26 16:23:05.908  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
    2024-04-26 16:23:05.908  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
    2024-04-26 16:23:05.908  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
    2024-04-26 16:23:05.908  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
    2024-04-26 16:23:05.909  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
    2024-04-26 16:23:05.909  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
    2024-04-26 16:23:05.909  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
    2024-04-26 16:23:05.909  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
    2024-04-26 16:23:05.909  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
    2024-04-26 16:23:05.909  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
    2024-04-26 16:23:05.910  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
    2024-04-26 16:23:05.910  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2024-04-26 16:23:05.910  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
    2024-04-26 16:23:05.910  - error: host.rasphj Caught by controller[0]: }
    2024-04-26 16:23:05.910  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
    2024-04-26 16:23:05.910  - error: host.rasphj instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-04-26 16:23:05.911  - info: host.rasphj Adapter system.adapter.web.0 needs rebuild of iobroker.js-controller and will be restarted afterwards.
    2024-04-26 16:23:05.911  - info: host.rasphj system.adapter.web.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules","module":"iobroker.js-controller","version":"5.0.19"})
    2024-04-26 16:23:09.675  - info: host.rasphj iobroker npm-install: NPM version: 10.5.0
    2024-04-26 16:23:09.678  - info: host.rasphj iobroker npm-install: Installing iobroker.heytech@1.0.5... (System call)
    2024-04-26 16:23:15.923  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T14_23_10_738Z-debug-0.log
    2024-04-26 16:23:15.924  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
    2024-04-26 16:23:16.955  - info: host.rasphj iobroker npm-install: exit 25
    2024-04-26 16:23:17.956  - warn: host.rasphj adapter "discovery" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
    2024-04-26 16:23:17.957  - info: host.rasphj iobroker rebuild
    2024-04-26 16:23:19.754  - info: host.rasphj iobroker npm-rebuild: Rebuilding native modules ...
    2024-04-26 16:23:48.352  - info: vis.0 (18269) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v18.20.2, js-controller: 5.0.19
    2024-04-26 16:23:48.637  - info: vis.0 (18269) vis license is OK.
    2024-04-26 16:23:49.642  - info: vis.0 (18269) Terminated (NO_ERROR): Without reason
    2024-04-26 16:24:23.351  - info: host.rasphj iobroker npm-rebuild: rebuilt dependencies successfully
    2024-04-26 16:24:23.385  - info: host.rasphj iobroker npm-rebuild:
    2024-04-26 16:24:23.386  - info: host.rasphj iobroker npm-rebuild: Rebuilding native modules done
    2024-04-26 16:24:24.399  - info: host.rasphj iobroker npm-rebuild: exit 0
    2024-04-26 16:24:24.692  - info: host.rasphj instance system.adapter.discovery.0 started with pid 18660
    2024-04-26 16:24:24.702  - info: host.rasphj instance system.adapter.admin.0 started with pid 18661
    2024-04-26 16:24:24.711  - info: host.rasphj instance system.adapter.web.0 started with pid 18662
    2024-04-26 16:24:25.405  - warn: host.rasphj startInstance cannot find adapter "heytech@1.0.5". Try to install it... 4 attempt
    2024-04-26 16:24:25.406  - info: host.rasphj iobroker install heytech@1.0.5 using installedVersion
    2024-04-26 16:24:26.853  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
    2024-04-26 16:24:26.854  - error: host.rasphj Caught by controller[0]:   throw err;
    2024-04-26 16:24:26.854  - error: host.rasphj Caught by controller[0]:   ^
    2024-04-26 16:24:26.855  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools'
    2024-04-26 16:24:26.855  - error: host.rasphj Caught by controller[0]: Require stack:
    2024-04-26 16:24:26.855  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.discovery/main.js
    2024-04-26 16:24:26.856  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
    2024-04-26 16:24:26.856  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
    2024-04-26 16:24:26.856  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
    2024-04-26 16:24:26.857  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
    2024-04-26 16:24:26.857  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.discovery/main.js:17:21)
    2024-04-26 16:24:26.858  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
    2024-04-26 16:24:26.858  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
    2024-04-26 16:24:26.858  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
    2024-04-26 16:24:26.859  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
    2024-04-26 16:24:26.859  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
    2024-04-26 16:24:26.859  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2024-04-26 16:24:26.860  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.discovery/main.js' ]
    2024-04-26 16:24:26.860  - error: host.rasphj Caught by controller[0]: }
    2024-04-26 16:24:26.860  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
    2024-04-26 16:24:26.861  - error: host.rasphj instance system.adapter.discovery.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-04-26 16:24:26.861  - info: host.rasphj Rebuild for adapter system.adapter.discovery.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    2024-04-26 16:24:26.863  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
    2024-04-26 16:24:26.864  - error: host.rasphj Caught by controller[0]:   throw err;
    2024-04-26 16:24:26.864  - error: host.rasphj Caught by controller[0]:   ^
    2024-04-26 16:24:26.865  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js'
    2024-04-26 16:24:26.865  - error: host.rasphj Caught by controller[0]: Require stack:
    2024-04-26 16:24:26.865  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
    2024-04-26 16:24:26.865  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
    2024-04-26 16:24:26.866  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
    2024-04-26 16:24:26.866  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
    2024-04-26 16:24:26.866  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
    2024-04-26 16:24:26.867  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:18:18)
    2024-04-26 16:24:26.867  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
    2024-04-26 16:24:26.868  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
    2024-04-26 16:24:26.868  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
    2024-04-26 16:24:26.868  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
    2024-04-26 16:24:26.869  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
    2024-04-26 16:24:26.869  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2024-04-26 16:24:26.869  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/main.js' ]
    2024-04-26 16:24:26.870  - error: host.rasphj Caught by controller[0]: }
    2024-04-26 16:24:26.870  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
    2024-04-26 16:24:26.870  - error: host.rasphj instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-04-26 16:24:26.871  - info: host.rasphj Rebuild for adapter system.adapter.admin.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    2024-04-26 16:24:27.173  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
    2024-04-26 16:24:27.174  - error: host.rasphj Caught by controller[0]:   throw err;
    2024-04-26 16:24:27.174  - error: host.rasphj Caught by controller[0]:   ^
    2024-04-26 16:24:27.174  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
    2024-04-26 16:24:27.174  - error: host.rasphj Caught by controller[0]: Require stack:
    2024-04-26 16:24:27.175  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
    2024-04-26 16:24:27.175  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
    2024-04-26 16:24:27.175  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
    2024-04-26 16:24:27.176  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
    2024-04-26 16:24:27.176  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
    2024-04-26 16:24:27.176  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
    2024-04-26 16:24:27.177  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
    2024-04-26 16:24:27.177  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
    2024-04-26 16:24:27.177  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
    2024-04-26 16:24:27.178  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
    2024-04-26 16:24:27.178  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
    2024-04-26 16:24:27.178  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2024-04-26 16:24:27.178  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
    2024-04-26 16:24:27.178  - error: host.rasphj Caught by controller[0]: }
    2024-04-26 16:24:27.179  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
    2024-04-26 16:24:27.179  - error: host.rasphj instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-04-26 16:24:27.179  - info: host.rasphj Adapter system.adapter.web.0 needs rebuild and will be restarted afterwards.
    2024-04-26 16:24:27.180  - info: host.rasphj system.adapter.web.0 will be rebuilt
    2024-04-26 16:24:30.676  - info: host.rasphj iobroker npm-install: NPM version: 10.5.0
    2024-04-26 16:24:30.679  - info: host.rasphj iobroker npm-install: Installing iobroker.heytech@1.0.5... (System call)
    2024-04-26 16:24:38.037  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T14_24_31_757Z-debug-0.log
    2024-04-26 16:24:38.038  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
    2024-04-26 16:24:39.069  - info: host.rasphj iobroker npm-install: exit 25
    2024-04-26 16:24:40.070  - warn: host.rasphj adapter "web" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
    2024-04-26 16:24:40.071  - info: host.rasphj iobroker rebuild
    2024-04-26 16:24:41.868  - info: host.rasphj iobroker npm-rebuild: Rebuilding native modules ...
    2024-04-26 16:25:11.870  - info: vis.0 (19415) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v18.20.2, js-controller: 5.0.19
    2024-04-26 16:25:12.181  - info: vis.0 (19415) vis license is OK.
    2024-04-26 16:25:13.263  - info: vis.0 (19415) Terminated (NO_ERROR): Without reason
    2024-04-26 16:25:38.876  - info: host.rasphj iobroker npm-rebuild: rebuilt dependencies successfully
    2024-04-26 16:25:38.912  - info: host.rasphj iobroker npm-rebuild:
    2024-04-26 16:25:38.913  - info: host.rasphj iobroker npm-rebuild: Rebuilding native modules done
    2024-04-26 16:25:39.928  - info: host.rasphj iobroker npm-rebuild: exit 0
    2024-04-26 16:25:40.067  - info: host.rasphj instance system.adapter.web.0 started with pid 19767
    2024-04-26 16:25:40.931  - error: host.rasphj Cannot download and install adapter "heytech@1.0.5". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
    2024-04-26 16:25:41.921  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
    2024-04-26 16:25:41.921  - error: host.rasphj Caught by controller[0]:   throw err;
    2024-04-26 16:25:41.921  - error: host.rasphj Caught by controller[0]:   ^
    2024-04-26 16:25:41.922  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
    2024-04-26 16:25:41.922  - error: host.rasphj Caught by controller[0]: Require stack:
    2024-04-26 16:25:41.922  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
    2024-04-26 16:25:41.922  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
    2024-04-26 16:25:41.922  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
    2024-04-26 16:25:41.923  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
    2024-04-26 16:25:41.923  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
    2024-04-26 16:25:41.923  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
    2024-04-26 16:25:41.923  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
    2024-04-26 16:25:41.923  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
    2024-04-26 16:25:41.923  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
    2024-04-26 16:25:41.924  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
    2024-04-26 16:25:41.924  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
    2024-04-26 16:25:41.924  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2024-04-26 16:25:41.924  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
    2024-04-26 16:25:41.924  - error: host.rasphj Caught by controller[0]: }
    2024-04-26 16:25:41.925  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
    2024-04-26 16:25:41.925  - error: host.rasphj instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-04-26 16:25:41.925  - info: host.rasphj Rebuild for adapter system.adapter.web.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    @hans-jürgen-strudler sagte in io Broker lässt sich nicht updaten (Linux):
    20
    da isser ja!
    Der Rest ist natürlich Mist.
    Jetzt hast du node und Controller upgedatet.
    Außerdem hattest du ja noch extraneous im npm log gehabt.
    Vielleicht hat @thomas-braun noch ne Idee.
    hans1990H 1 Antwort Letzte Antwort
      hans1990H Offline
      hans1990H Offline
      hans1990
      @hans-jürgen-strudler said in io Broker lässt sich nicht updaten (Linux):
      hier ein Auszug von den Error Zeilen
      2024-04-26 16:12:44.343  - error: host.rasphj iobroker npm-install: host.rasphj Invalid version of "admin". Installed "5.1.25", required ">=5.1.28"
      2024-04-26 16:12:46.377  - warn: host.rasphj startInstance cannot find adapter "net-tools". Try to install it... 1 attempt
      2024-04-26 16:13:07.751  - error: host.rasphj iobroker npm-install: host.rasphj Invalid version of "admin". Installed "5.1.25", required ">=6.13.15"
      2024-04-26 16:13:09.784  - warn: host.rasphj startInstance cannot find adapter "ping". Try to install it... 1 attempt
      2024-04-26 16:13:24.644  - warn: host.rasphj startInstance cannot find adapter "shuttercontrol@1.2.1". Try to install it... 1 attempt
      2024-04-26 16:13:40.311  - warn: host.rasphj startInstance cannot find adapter "heytech@1.0.5". Try to install it... 1 attempt
      2024-04-26 16:13:50.827  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T14_13_45_983Z-debug-0.log
      2024-04-26 16:13:50.828  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
      2024-04-26 16:13:52.864  - warn: host.rasphj startInstance cannot find adapter "flot". Try to install it... 1 attempt
      2024-04-26 16:13:57.708  - warn: host.rasphj startInstance cannot find adapter "elero-usb-transmitter@0.5.2". Try to install it... 1 attempt
      2024-04-26 16:16:00.502  - warn: host.rasphj startInstance cannot find adapter "history@1.9.14". Try to install it... 1 attempt
      2024-04-26 16:16:18.909  - error: host.rasphj iobroker npm-install: host.rasphj Invalid version of "admin". Installed "5.1.25", required ">=5.1.28"
      2024-04-26 16:16:20.940  - warn: host.rasphj startInstance cannot find adapter "sonoff@2.4.5". Try to install it... 1 attempt
      2024-04-26 16:16:36.159  - warn: host.rasphj startInstance cannot find adapter "nuki-extended@2.3.1". Try to install it... 1 attempt
      2024-04-26 16:16:55.100  - warn: host.rasphj startInstance cannot find adapter "rpi2@1.3.1". Try to install it... 1 attempt
      2024-04-26 16:16:59.371  - warn: nuki-extended.0 (14121) Callback not attached because too many Callbacks attached to the Nuki Bridge already! Please delete a callback!
      2024-04-26 16:17:36.447  - warn: host.rasphj adapter "discovery" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
      2024-04-26 16:18:04.280  - warn: host.rasphj Slave controller detected disconnection. Stop all instances.
      2024-04-26 16:18:05.121  - error: host.rasphj Cannot find view "system" for search "instance" : Connection is closed.
      2024-04-26 16:18:05.123  - error: host.rasphj Cannot find view "system" for search "instance" : Connection is closed.
      2024-04-26 16:18:05.124  - error: host.rasphj Cannot find view "system" for search "instance" : Connection is closed.
      2024-04-26 16:18:05.144  - error: host.rasphj Cannot find view "system" for search "instance" : Connection is closed.
      2024-04-26 16:18:25.102  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
      2024-04-26 16:18:25.103  - error: host.rasphj Caught by controller[0]:   throw err;
      2024-04-26 16:18:25.104  - error: host.rasphj Caught by controller[0]:   ^
      2024-04-26 16:18:25.104  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js'
      2024-04-26 16:18:25.105  - error: host.rasphj Caught by controller[0]: Require stack:
      2024-04-26 16:18:25.105  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
      2024-04-26 16:18:25.105  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
      2024-04-26 16:18:25.106  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
      2024-04-26 16:18:25.106  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
      2024-04-26 16:18:25.107  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
      2024-04-26 16:18:25.108  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:18:18)
      2024-04-26 16:18:25.108  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
      2024-04-26 16:18:25.108  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
      2024-04-26 16:18:25.109  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
      2024-04-26 16:18:25.109  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
      2024-04-26 16:18:25.109  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
      2024-04-26 16:18:25.110  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
      2024-04-26 16:18:25.110  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/main.js' ]
      2024-04-26 16:18:25.110  - error: host.rasphj Caught by controller[0]: }
      2024-04-26 16:18:25.111  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
      2024-04-26 16:18:25.111  - error: host.rasphj instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-04-26 16:18:35.188  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T14_18_29_163Z-debug-0.log
      2024-04-26 16:18:35.189  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
      2024-04-26 16:18:37.280  - warn: host.rasphj adapter "admin" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
      2024-04-26 16:18:49.984  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
      2024-04-26 16:18:49.984  - error: host.rasphj Caught by controller[0]:   throw err;
      2024-04-26 16:18:49.985  - error: host.rasphj Caught by controller[0]:   ^
      2024-04-26 16:18:49.986  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools'
      2024-04-26 16:18:49.986  - error: host.rasphj Caught by controller[0]: Require stack:
      2024-04-26 16:18:49.987  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.discovery/main.js
      2024-04-26 16:18:49.987  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
      2024-04-26 16:18:49.987  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
      2024-04-26 16:18:49.988  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
      2024-04-26 16:18:49.988  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
      2024-04-26 16:18:49.989  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.discovery/main.js:17:21)
      2024-04-26 16:18:49.989  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
      2024-04-26 16:18:49.990  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
      2024-04-26 16:18:49.990  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
      2024-04-26 16:18:49.991  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
      2024-04-26 16:18:49.992  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
      2024-04-26 16:18:49.993  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
      2024-04-26 16:18:49.993  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.discovery/main.js' ]
      2024-04-26 16:18:49.994  - error: host.rasphj Caught by controller[0]: }
      2024-04-26 16:18:49.994  - error: host.rasphj Caught by controller[1]: Node.js v18.20.2
      2024-04-26 16:18:49.995  - error: host.rasphj instance system.adapter.discovery.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        20
        da isser ja!
        hans1990H Offline
        hans1990H Offline
        hans1990
        kann das helfen?
          teilweise vollkommen ok!
          Die Adapter müssen für das neue node neu gebaut werden. 1st attempt ist also korrekt.
          Andere Adapter benötigen eine höhere Version vom admin, bei dem es allerdings klemmt
          heytech ist anscheinend zu alt und nicht mehr unterstützt, oder über github installiert worden???
          warum das hängt sehe ich jetzt nicht
            kann das helfen?
            kann das helfen?
            lass erst einmal alle Eingriffe sein!
            gibt es neuere log Zeilen als von 16:25?
              kann das helfen?
              hans1990H Offline
              hans1990H Offline
              hans1990
              Nein. Das war die letzte Zeile
                hast du sonst noch was gemacht?
                iob stop
                iob update
                iob upgrade self
                Ich hab versucht den Fehler zu reproduzieren.
                Leider hab ich nicht gespeichert wie die node Version zu hoch war, aber es sah ca. so aus:
                Copy to Clipboard
                npm ERR! notsup Required: {"node":"8<=  node => 13"}
                npm ERR! notsup Actual:   {"npm":"6.14.16","node":"18.20."}
                auf der Weboberfläche wurde ich informiert, dass das File System geändert wird. das dürfte gerade laufen.
                iob stop
                hattest du iobroker gestoppt, während dieser dabei war die Adapter neu zu bauen?
                  hans1990H Offline
                  hans1990H Offline
                  hans1990
                  Das weiß ich nicht mehr woher ich es installiert habe.
                    und bei einem neuen iob logs --watch??
                    ok, dann ist da was schiefgelaufen :-(
                    bitte wenn nichts neues kommt aktuellen iob diag posten
                      iob stop
                      hans1990H Offline
                      hans1990H Offline
                      hans1990
                      ich war auf der Weboberfläche und er hat mich informiert, dass das Filesystem geändert wird.
                      sonst war nichts
                        sonst war nichts
                        sonst war nichts
                        und wann hattest du den controller upgedatet?
                        ohne node v18.20.2 ging das doch nicht
                          sonst war nichts
                          dass das Filesystem geändert wird ist mir nicht bekannt!
                          vielleich die Datenbank von file zu jsonl???
                          Vorhin schriebst du
                          ist es normal, dass die Weboberfläche derzeit nicht erreichbar ist?
                          wie bist du denn dann darauf gekommen?
                            sonst war nichts
                            hans1990H Offline
                            hans1990H Offline
                            hans1990
                            das war nach
                            iob nodejs-update
                              hans1990H Offline
                              hans1990H Offline
                              hans1990
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                                 Static hostname: rasphj
                                       Icon name: computer
                                Operating System: Raspbian GNU/Linux 11 (bullseye)
                                          Kernel: Linux 6.1.21-v8+
                                    Architecture: arm64
                              Model           : Raspberry Pi 4 Model B Rev 1.1
                              Docker          : false
                              Virtualization  : none
                              Kernel          : aarch64
                              Userland        : armhf
                              Systemuptime and Load:
                               17:18:36 up  3:03,  1 user,  load average: 2.09, 0.61, 0.31
                              CPU threads: 4
                              *** RASPBERRY THROTTLING ***
                              Current issues:
                              Previously detected issues:
                              *** Time and Time Zones ***
                                             Local time: Fri 2024-04-26 17:18:36 CEST
                                         Universal time: Fri 2024-04-26 15:18:36 UTC
                                               RTC time: n/a
                                              Time zone: Europe/Vienna (CEST, +0200)
                                            NTP service: active
                                        RTC in local TZ: no
                              *** User and Groups ***
                              pi
                              /home/pi
                              pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                              *** X-Server-Setup ***
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            3.8G        589M        1.5G        0.0K        1.7G        3.1G
                              Swap:            99M          0B         99M
                              Total:          3.9G        589M        1.6G
                                       3794 M total memory
                                        589 M used memory
                                        635 M active memory
                                       1380 M inactive memory
                                       1530 M free memory
                                        169 M buffer memory
                                       1504 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FAILED SERVICES ***
                              0 loaded units listed.
                              *** FILESYSTEM ***
                              /dev/root      ext4       59G  4.6G   52G   9% /
                              devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                              tmpfs          tmpfs     759M  820K  759M   1% /run
                              /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
                              tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                              [Fri Apr 26 14:15:03 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:45:7D:BA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d53cc083-02 rootfstype=ext4 fsck.repair=yes rootwait
                              [Fri Apr 26 14:15:04 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                              [Fri Apr 26 14:15:04 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                              [Fri Apr 26 14:15:06 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                              TARGET  SOURCE         FSTYPE OPTIONS
                              /       /dev/mmcblk0p2 ext4   rw,noatime
                              `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                              /var:
                              1.7G    /var/
                              1.3G    /var/log/journal/3e23e34d17484a28b9473f69f7d9d21c
                              1.3G    /var/log
                              202M    /var/cache
                              Archived and active journals take up 1.2G in the file system.
                              /opt/iobroker/backups:
                              24M     /opt/iobroker/backups/
                              /opt/iobroker/iobroker-data:
                              202M    /opt/iobroker/iobroker-data/
                              87M     /opt/iobroker/iobroker-data/history
                              52M     /opt/iobroker/iobroker-data/files
                              45M     /opt/iobroker/iobroker-data/backup-objects
                              27M     /opt/iobroker/iobroker-data/files/javascript.admin
                              9.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
                              6.3M    /opt/iobroker/iobroker-data/objects.json.migrated
                              6.3M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                              6.2M    /opt/iobroker/iobroker-data/objects.jsonl
                              4.4M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
                              USB-Devices by-id:
                              find: '/dev/serial/by-id/': No such file or directory
                              *** NodeJS-Installation ***
                              /usr/bin/nodejs         v18.20.2
                              /usr/bin/node           v18.20.2
                              /usr/bin/npm            10.5.0
                              /usr/bin/npx            10.5.0
                              /usr/bin/corepack       0.25.2
                              nodejs:
                                Installed: 18.20.2-1nodesource1
                                Candidate: 18.20.2-1nodesource1
                                Version table:
                               *** 18.20.2-1nodesource1 600
                                      500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                   18.20.1-1nodesource1 600
                                   18.20.0-1nodesource1 600
                                   18.19.1-1nodesource1 600
                                   18.19.0-1nodesource1 600
                                   18.18.2-1nodesource1 600
                                   18.18.1-1nodesource1 600
                                   18.18.0-1nodesource1 600
                                   18.17.1-1nodesource1 600
                                   18.17.0-1nodesource1 600
                                   18.16.1-1nodesource1 600
                                   18.16.0-1nodesource1 600
                                   18.15.0-1nodesource1 600
                                   18.14.2-1nodesource1 600
                                   18.14.1-1nodesource1 600
                                   18.14.0-1nodesource1 600
                                   18.13.0-1nodesource1 600
                                   18.12.0-1nodesource1 600
                                   18.11.0-1nodesource1 600
                                   18.10.0-1nodesource1 600
                                   18.9.1-1nodesource1 600
                                   18.9.0-1nodesource1 600
                                   18.8.0-1nodesource1 600
                                   18.7.0-1nodesource1 600
                                   18.6.0-1nodesource1 600
                                   18.5.0-1nodesource1 600
                                   18.4.0-1nodesource1 600
                                   18.3.0-1nodesource1 600
                                   18.2.0-1nodesource1 600
                                   18.1.0-1nodesource1 600
                                   18.0.0-1nodesource1 600
                                   12.22.12~dfsg-1~deb11u4 500
                              No problems detected
                              Errors in npm tree:
                              *** ioBroker-Installation ***
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Core adapters versions
                              admin:          5.1.25
                              javascript:     5.2.13
                              Adapters from github:   0
                              Adapter State
                                system.adapter.admin.0                  : admin                 : rasphj                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                system.adapter.admin.1                  : admin                 : rasphj                                   - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.backitup.0               : backitup              : rasphj                                   -  enabled
                                system.adapter.discovery.0              : discovery             : rasphj                                   -  enabled
                                system.adapter.elero-usb-transmitter.0  : elero-usb-transmitter : rasphj                                   - disabled
                                system.adapter.flot.0                   : flot                  : rasphj                                   -  enabled
                                system.adapter.heytech.0                : heytech               : rasphj                                   - disabled, port: 1002
                              + system.adapter.history.0                : history               : rasphj                                   -  enabled
                                system.adapter.homee.0                  : homee                 : rasphj                                   - disabled
                              + system.adapter.javascript.0             : javascript            : rasphj                                   -  enabled
                                system.adapter.net-tools.0              : net-tools             : rasphj                                   - disabled
                              + system.adapter.nuki-extended.0          : nuki-extended         : rasphj                                   -  enabled
                              + system.adapter.nuki.0                   : nuki                  : rasphj                                   -  enabled
                              + system.adapter.octoprint.0              : octoprint             : rasphj                                   -  enabled
                                system.adapter.ping.0                   : ping                  : rasphj                                   - disabled
                              + system.adapter.rpi2.0                   : rpi2                  : rasphj                                   -  enabled
                              + system.adapter.shelly.0                 : shelly                : rasphj                                   -  enabled, port: 1883, bind: 0.0.0.0
                                system.adapter.shuttercontrol.0         : shuttercontrol        : rasphj                                   - disabled
                              + system.adapter.sonoff.0                 : sonoff                : rasphj                                   -  enabled, port: 1883, bind: 0.0.0.0
                                system.adapter.synology.0               : synology              : rasphj                                   - disabled, port: 5000
                                system.adapter.vis-timeandweather.0     : vis-timeandweather    : rasphj                                   -  enabled
                                system.adapter.vis.0                    : vis                   : rasphj                                   -  enabled
                                system.adapter.web.0                    : web                   : rasphj                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              + system.adapter.wled.0                   : wled                  : rasphj                                   -  enabled
                              + instance is alive
                              ioBroker-Repositories
                              Active repo(s): stable
                              Installed ioBroker-Instances
                              Used repository: stable
                              Adapter    "admin"        : 6.13.16  , installed 5.1.25 [Updatable]
                              Adapter    "backitup"     : 2.11.0   , installed 2.2.2  [Updatable]
                              Adapter    "discovery"    : 4.4.0    , installed 2.7.3  [Updatable]
                              Adapter    "elero-usb-transmitter": 0.5.2, installed 0.5.2
                              Adapter    "homee"        : 1.2.0    , installed 1.2.0
                              Adapter    "javascript"   : 7.8.0    , installed 5.2.13 [Updatable]
                              Controller "js-controller": 5.0.19   , installed 5.0.19
                              Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
                              Adapter    "nuki"         : 1.6.0    , installed 1.5.0  [Updatable]
                              Adapter    "nuki-extended": 2.6.5    , installed 2.3.1  [Updatable]
                              Adapter    "octoprint"    : 5.1.0    , installed 1.1.1  [Updatable]
                              Adapter    "rpi2"         : 1.3.2    , installed 1.3.1  [Updatable]
                              Adapter    "shelly"       : 6.8.0    , installed 4.0.7  [Updatable]
                              Adapter    "shuttercontrol": 1.7.0   , installed 1.2.1  [Updatable]
                              Adapter    "socketio"     : 6.6.1    , installed 6.6.1
                              Adapter    "sonoff"       : 3.0.3    , installed 2.4.5  [Updatable]
                              Adapter    "synology"     : 3.1.0    , installed 3.1.0
                              Adapter    "vis"          : 1.5.4    , installed 1.4.5  [Updatable]
                              Adapter    "vis-timeandweather": 1.2.2, installed 1.1.7 [Updatable]
                              Adapter    "web"          : 6.2.5    , installed 3.4.9  [Updatable]
                              Adapter    "wled"         : 0.7.2    , installed 0.6.3  [Updatable]
                              Objects and States
                              Objects:        3146
                              States:         2056
                              Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                              Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                              Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                              Reading package lists...
                              Pending Updates: 0
                              *** Listening Ports ***
                              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       145618     23162/io.sonoff.0
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       145498     23046/iobroker.js-c
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       144524     23046/iobroker.js-c
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11069      520/sshd: /usr/sbin
                              tcp6       0      0 :::51989                :::*                    LISTEN      1001       145658     23186/io.nuki-exten
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          11071      520/sshd: /usr/sbin
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       147919     24059/io.wled.0
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14706      388/avahi-daemon: r
                              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       147929     23996/io.shelly.0
                              udp        0      0 0.0.0.0:52988           0.0.0.0:*                           108        14708      388/avahi-daemon: r
                              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13180      729/dhcpcd
                              udp6       0      0 :::546                  :::*                                0          11105      729/dhcpcd
                              udp6       0      0 :::5353                 :::*                                108        14707      388/avahi-daemon: r
                              udp6       0      0 :::48970                :::*                                108        14709      388/avahi-daemon: r
                              2024-04-26 17:19:53.598  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                              2024-04-26 17:19:53.598  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                              2024-04-26 17:19:53.598  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                              2024-04-26 17:19:53.599  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                              2024-04-26 17:19:53.599  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                              2024-04-26 17:19:53.599  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                              2024-04-26 17:19:53.600  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                              2024-04-26 17:19:53.600  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                              2024-04-26 17:19:53.600  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                              2024-04-26 17:19:53.600  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                              2024-04-26 17:19:53.601  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                              2024-04-26 17:19:53.601  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                              2024-04-26 17:19:53.601  - error: host.rasphj Caught by controller[0]: }
                              2024-04-26 17:19:53.601  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                              2024-04-26 17:19:53.602  - error: host.rasphj instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                              2024-04-26 17:19:53.602  - info: host.rasphj Adapter system.adapter.web.0 needs rebuild of iobroker.js-controller and will be restarted afterwards.
                              2024-04-26 17:19:53.602  - info: host.rasphj system.adapter.web.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules","module":"iobroker.js-controller","version":"5.0.19"})
                              2024-04-26 17:19:57.139  - info: host.rasphj iobroker npm-install: NPM version: 10.5.0
                              2024-04-26 17:19:57.142  - info: host.rasphj iobroker npm-install: Installing iobroker.heytech@1.0.5... (System call)
                              2024-04-26 17:20:05.490  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T15_19_58_387Z-debug-0.log
                              2024-04-26 17:20:05.491  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
                              2024-04-26 17:20:06.531  - info: host.rasphj iobroker npm-install: exit 25
                              2024-04-26 17:20:07.531  - warn: host.rasphj adapter "admin" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                              2024-04-26 17:20:07.532  - info: host.rasphj iobroker rebuild iobroker.js-controller@5.0.19 --path /opt/iobroker/node_modules
                              2024-04-26 17:20:09.540  - info: host.rasphj iobroker npm-rebuild: Rebuilding native module "iobroker.js-controller@5.0.19" in /opt/iobroker/node_modules ...
                                das war nach
                                iob nodejs-update
                                das war nach
                                also hast du iobroker gestoppt, während er dabei war alles neu zu bauen.
                                da er das weitestgehend alphabetisch nacht, warcer möglicherweise gerade beim admin 😡
                                  Vorhin schriebst du
                                  hans1990H Offline
                                  hans1990H Offline
                                  hans1990
                                  ja genau das wars. das war die Info auf der Web oberfläche und dann war diese nachher nicht mehr erreichbar
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : armhf
                                    CPU threads: 4
                                    Current issues:
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    pi
                                    /home/pi
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:            99M          0B         99M
                                             3794 M total memory
                                              589 M used memory
                                              635 M active memory
                                             1530 M free memory
                                              169 M buffer memory
                                             1504 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /var:
                                    1.7G    /var/
                                    1.3G    /var/log
                                    202M    /var/cache
                                    USB-Devices by-id:
                                    /usr/bin/npm            10.5.0
                                    /usr/bin/npx            10.5.0
                                    nodejs:
                                      Version table:
                                    Errors in npm tree:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          5.1.25
                                    javascript:     5.2.13
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        3146
                                    States:         2056
                                    Pending Updates: 0
                                    da sind doch noch logeinträge nach 16:25!!!!
                                    er war also noch nicht fertig!!
                                    @homoran sagte in io Broker lässt sich nicht updaten (Linux):
                                      hans1990H Offline
                                      hans1990H Offline
                                      hans1990
                                      schrieb am zuletzt editiert von hans1990
                                      Macht es sinn nochmal vom backup zu starten?
                                      iob nodejs-update
                                      iob stop
                                      iob update
                                      iob upgrade self
                                      iob start
                                      Weboberfläche erst öffnen wenn die adapter fertig neu sind?
                                      Wie würdest du nach dem Befehl
                                      iob nodejs-update
                                      weiter vorgehen?
                                      Danke für deine Geduld und Hilfe!
                                        iob nodejs-update
                                        iob stop
                                        iob update
                                        iob upgrade self
                                        iob start
                                        iob nodejs-update
                                        weiter vorgehen?
                                        iob nodejs-update
                                        Kannst du dir sparen, das ist ja jetzt die richtige Version.
                                        Ist jetzt im LogFile Ruhe eingekehrt?
                                        iob update
                                        sagt?
                                          iob nodejs-update
                                          iob update
                                          sagt?
                                          hans1990H Offline
                                          hans1990H Offline
                                          hans1990
                                          @thomas-braun said in io Broker lässt sich nicht updaten (Linux):
                                          iob update
                                          sagt?
                                          pi@rasphj:~ $ iob update
                                          ja war ruhig - hab dann einen reboot gemacht und ist wieder hier hängen geblieben
                                          2024-04-26 17:46:13.582  - info: host.rasphj Rebuild for adapter system.adapter.admin.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                          2024-04-26 17:46:13.929  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                                          2024-04-26 17:46:13.929  - error: host.rasphj Caught by controller[0]:   throw err;
                                          2024-04-26 17:46:13.930  - error: host.rasphj Caught by controller[0]:   ^
                                          2024-04-26 17:46:13.930  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
                                          2024-04-26 17:46:13.930  - error: host.rasphj Caught by controller[0]: Require stack:
                                          2024-04-26 17:46:13.931  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
                                          2024-04-26 17:46:13.931  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                                          2024-04-26 17:46:13.931  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                                          2024-04-26 17:46:13.932  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                                          2024-04-26 17:46:13.932  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                                          2024-04-26 17:46:13.932  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                                          2024-04-26 17:46:13.933  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                                          2024-04-26 17:46:13.933  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                                          2024-04-26 17:46:13.934  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                                          2024-04-26 17:46:13.934  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                                          2024-04-26 17:46:13.934  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                                          2024-04-26 17:46:13.935  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                          2024-04-26 17:46:13.935  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                                          2024-04-26 17:46:13.935  - error: host.rasphj Caught by controller[0]: }
                                          2024-04-26 17:46:13.936  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                                          2024-04-26 17:46:13.936  - error: host.rasphj instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                          2024-04-26 17:46:13.936  - info: host.rasphj Rebuild for adapter system.adapter.web.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                          2024-04-26 17:46:17.534  - info: host.rasphj iobroker npm-install: NPM version: 10.5.0
                                          2024-04-26 17:46:17.538  - info: host.rasphj iobroker npm-install: Installing iobroker.heytech@1.0.5... (System call)
                                          2024-04-26 17:46:24.616  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T15_46_18_637Z-debug-0.log
                                          2024-04-26 17:46:24.617  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
                                          2024-04-26 17:46:25.653  - info: host.rasphj iobroker npm-install: exit 25
                                          2024-04-26 17:46:26.655  - error: host.rasphj Cannot download and install adapter "heytech@1.0.5". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
