  4. io Broker lässt sich nicht updaten (Linux)
71 Beiträge 4 Kommentatoren 3.6k Aufrufe 3 Beobachtet
  • hans1990H hans1990
    @thomas-braun said in io Broker lässt sich nicht updaten (Linux):
    Und dann mal die Langfassung von
    Copy to Clipboardiob diag
    Bitte gerne
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: rasphj
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : armhf
    Systemuptime and Load:
     15:47:19 up  1:32,  1 user,  load average: 0.21, 0.10, 0.12
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Fri 2024-04-26 15:47:19 CEST
               Universal time: Fri 2024-04-26 13:47:19 UTC
                     RTC time: n/a
                    Time zone: Europe/Vienna (CEST, +0200)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.8G        668M        2.6G        0.0K        477M        3.2G
    Swap:            99M          0B         99M
    Total:          3.9G        668M        2.7G
             3794 M total memory
              668 M used memory
              498 M active memory
              478 M inactive memory
             2647 M free memory
               68 M buffer memory
              409 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       59G  4.2G   52G   8% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  820K  759M   1% /run
    /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Fri Apr 26 14:15:03 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:45:7D:BA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d53cc083-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Fri Apr 26 14:15:04 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Fri Apr 26 14:15:04 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Fri Apr 26 14:15:06 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    1.7G    /var/
    1.3G    /var/log/journal/3e23e34d17484a28b9473f69f7d9d21c
    1.3G    /var/log
    178M    /var/cache
    Archived and active journals take up 1.2G in the file system.
    /opt/iobroker/backups:
    24M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    193M    /opt/iobroker/iobroker-data/
    87M     /opt/iobroker/iobroker-data/history
    51M     /opt/iobroker/iobroker-data/files
    43M     /opt/iobroker/iobroker-data/backup-objects
    27M     /opt/iobroker/iobroker-data/files/javascript.admin
    9.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
    6.3M    /opt/iobroker/iobroker-data/objects.json.bak
    4.4M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
    3.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /home/iobroker/.diag.sh: line 277: nodejs: command not found
    /usr/bin/node           v12.22.12
    /usr/bin/npm            6.14.16
    /usr/bin/npx            6.14.16
    /home/iobroker/.diag.sh: line 281: corepack: command not found
    /home/iobroker/.diag.sh: line 288: nodejs: command not found
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 12.22.12-deb-1nodesource1
      Candidate: 12.22.12-deb-1nodesource1
      Version table:
     *** 12.22.12-deb-1nodesource1 600
            500 https://deb.nodesource.com/node_12.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    Errors in npm tree:
    npm ERR! invalid: iobroker.discovery@2.7.3 /opt/iobroker/node_modules/iobroker.discovery
    npm ERR! extraneous: mdns-discovery@0.2.6 /opt/iobroker/node_modules/mdns-discovery
    npm ERR! extraneous: netmask@2.0.2 /opt/iobroker/node_modules/netmask
    npm ERR! extraneous: node-mndp@0.0.3 /opt/iobroker/node_modules/node-mndp
    npm ERR! extraneous: node-ssdp@4.0.1 /opt/iobroker/node_modules/node-ssdp
    npm ERR! extraneous: serialport@9.2.8 /opt/iobroker/node_modules/serialport
    npm ERR! extraneous: iobroker.elero-usb-transmitter@0.5.2 /opt/iobroker/node_modules/iobroker.elero-usb-transmitter
    npm ERR! extraneous: iobroker.flot@1.10.7 /opt/iobroker/node_modules/iobroker.flot
    npm ERR! extraneous: iobroker.heytech@1.0.5 /opt/iobroker/node_modules/iobroker.heytech
    npm ERR! extraneous: iobroker.history@1.9.14 /opt/iobroker/node_modules/iobroker.history
    npm ERR! extraneous: iobroker.homee@1.2.0 /opt/iobroker/node_modules/iobroker.homee
    npm ERR! extraneous: iobroker.javascript@5.2.13 /opt/iobroker/node_modules/iobroker.javascript
    npm ERR! extraneous: iobroker.net-tools@0.1.7 /opt/iobroker/node_modules/iobroker.net-tools
    npm ERR! extraneous: iobroker.nuki@1.5.0 /opt/iobroker/node_modules/iobroker.nuki
    npm ERR! extraneous: iobroker.nuki-extended@2.3.1 /opt/iobroker/node_modules/iobroker.nuki-extended
    npm ERR! extraneous: iobroker.octoprint@1.1.1 /opt/iobroker/node_modules/iobroker.octoprint
    npm ERR! extraneous: iobroker.ping@1.5.0 /opt/iobroker/node_modules/iobroker.ping
    npm ERR! extraneous: iobroker.rpi2@1.3.1 /opt/iobroker/node_modules/iobroker.rpi2
    npm ERR! extraneous: iobroker.shelly@4.0.7 /opt/iobroker/node_modules/iobroker.shelly
    npm ERR! extraneous: iobroker.shuttercontrol@1.2.1 /opt/iobroker/node_modules/iobroker.shuttercontrol
    npm ERR! extraneous: iobroker.sonoff@2.4.5 /opt/iobroker/node_modules/iobroker.sonoff
    npm ERR! extraneous: iobroker.synology@1.1.3 /opt/iobroker/node_modules/iobroker.synology
    npm ERR! extraneous: iobroker.vis@1.4.5 /opt/iobroker/node_modules/iobroker.vis
    npm ERR! extraneous: iobroker.vis-timeandweather@1.1.7 /opt/iobroker/node_modules/iobroker.vis-timeandweather
    npm ERR! extraneous: iobroker.web@3.4.9 /opt/iobroker/node_modules/iobroker.web
    npm ERR! extraneous: iobroker.wled@0.6.3 /opt/iobroker/node_modules/iobroker.wled
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: file
    States  type: file
    Core adapters versions
    js-controller:  3.3.21
    admin:          5.1.25
    javascript:     5.2.13
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : rasphj                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.admin.1                  : admin                 : rasphj                                   - disabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : rasphj                                   -  enabled
    + system.adapter.discovery.0              : discovery             : rasphj                                   -  enabled
      system.adapter.elero-usb-transmitter.0  : elero-usb-transmitter : rasphj                                   - disabled
      system.adapter.flot.0                   : flot                  : rasphj                                   -  enabled
      system.adapter.heytech.0                : heytech               : rasphj                                   - disabled, port: 1002
    + system.adapter.history.0                : history               : rasphj                                   -  enabled
      system.adapter.homee.0                  : homee                 : rasphj                                   - disabled
    + system.adapter.javascript.0             : javascript            : rasphj                                   -  enabled
      system.adapter.net-tools.0              : net-tools             : rasphj                                   - disabled
    + system.adapter.nuki-extended.0          : nuki-extended         : rasphj                                   -  enabled
    + system.adapter.nuki.0                   : nuki                  : rasphj                                   -  enabled
    + system.adapter.octoprint.0              : octoprint             : rasphj                                   -  enabled
      system.adapter.ping.0                   : ping                  : rasphj                                   - disabled
    + system.adapter.rpi2.0                   : rpi2                  : rasphj                                   -  enabled
    + system.adapter.shelly.0                 : shelly                : rasphj                                   -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : rasphj                                   - disabled
    + system.adapter.sonoff.0                 : sonoff                : rasphj                                   -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.synology.0               : synology              : rasphj                                   - disabled, port: 5000
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : rasphj                                   -  enabled
      system.adapter.vis.0                    : vis                   : rasphj                                   -  enabled
    + system.adapter.web.0                    : web                   : rasphj                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wled.0                   : wled                  : rasphj                                   -  enabled
    + instance is alive
    ioBroker-Repositories
    default     : http://download.iobroker.net/sources-dist.json
    latest      : http://download.iobroker.net/sources-dist-latest.json
    Active repo: default
    Installed ioBroker-Instances
    Used repository: default
    hash unchanged, use cached sources
    update done
    Adapter    "admin"         : 6.13.16  , installed 5.1.25 [Updateable]
    Adapter    "backitup"      : 2.11.0   , installed 2.2.2 [Updateable]
    Adapter    "discovery"     : 4.4.0    , installed 2.7.3 [Updateable]
    Adapter    "elero-usb-transmitter": 0.5.2   , installed 0.5.2
    Adapter    "flot"          : 1.12.0   , installed 1.10.7 [Updateable]
    Adapter    "heytech"       : 1.0.6    , installed 1.0.5 [Updateable]
    Adapter    "history"       : 3.0.1    , installed 1.9.14 [Updateable]
    Adapter    "homee"         : 1.2.0    , installed 1.2.0
    Adapter    "javascript"    : 7.8.0    , installed 5.2.13 [Updateable]
    Controller "js-controller" : 5.0.19   , installed 3.3.21 [Updateable]
    Adapter    "net-tools"     : 1.0.11   , installed 0.1.7 [Updateable]
    Adapter    "nuki"          : 1.6.0    , installed 1.5.0 [Updateable]
    Adapter    "nuki-extended" : 2.6.5    , installed 2.3.1 [Updateable]
    Adapter    "octoprint"     : 5.1.0    , installed 1.1.1 [Updateable]
    Adapter    "ping"          : 1.6.2    , installed 1.5.0 [Updateable]
    Adapter    "rpi2"          : 1.3.2    , installed 1.3.1 [Updateable]
    Adapter    "shelly"        : 6.8.0    , installed 4.0.7 [Updateable]
    Adapter    "shuttercontrol": 1.7.0    , installed 1.2.1 [Updateable]
    Adapter    "simple-api"    : 2.7.2    , installed 2.6.2 [Updateable]
    Adapter    "socketio"      : 6.6.1    , installed 3.1.5 [Updateable]
    Adapter    "sonoff"        : 3.0.3    , installed 2.4.5 [Updateable]
    Adapter    "synology"      : 3.1.0    , installed 1.1.3 [Updateable]
    Adapter    "vis"           : 1.5.4    , installed 1.4.5 [Updateable]
    Adapter    "vis-timeandweather": 1.2.2   , installed 1.1.7 [Updateable]
    Adapter    "web"           : 6.2.5    , installed 3.4.9 [Updateable]
    Adapter    "wled"          : 0.7.2    , installed 0.6.3 [Updateable]
    Objects and States
    Objects:        3141
    States:         2051
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_12.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       55107      7146/io.sonoff.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       56976      7043/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       56983      7043/iobroker.js-co
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11069      520/sshd: /usr/sbin
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       60420      7455/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       57028      7061/io.admin.0
    tcp6       0      0 :::51989                :::*                    LISTEN      1001       57892      7162/io.nuki-extend
    tcp6       0      0 :::22                   :::*                    LISTEN      0          11071      520/sshd: /usr/sbin
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       59650      7530/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14706      388/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       58177      7506/io.shelly.0
    udp        0      0 0.0.0.0:52988           0.0.0.0:*                           108        14708      388/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13180      729/dhcpcd
    udp6       0      0 :::546                  :::*                                0          11105      729/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        14707      388/avahi-daemon: r
    udp6       0      0 :::48970                :::*                                108        14709      388/avahi-daemon: r
    2024-04-26 15:30:16.287  - info: vis.0 (7491) vis license is OK.
    2024-04-26 15:30:17.147  - info: vis.0 (7491) Terminated (NO_ERROR): Without reason
    2024-04-26 15:30:17.533  - error: nuki.0 (7412) Error: connect EHOSTUNREACH 10.0.0.1:8080
    2024-04-26 15:30:17.728  - info: host.rasphj instance system.adapter.vis.0 terminated while should be started once
    2024-04-26 15:30:18.444  - info: host.rasphj instance system.adapter.shelly.0 started with pid 7506
    2024-04-26 15:30:21.499  - info: shelly.0 (7506) starting. Version 4.0.7 in /opt/iobroker/node_modules/iobroker.shelly, node: v12.22.12, js-controller: 3.3.21
    2024-04-26 15:30:21.532  - info: shelly.0 (7506) Starting Adapter shelly.0 in version 4.0.7
    2024-04-26 15:30:21.559  - info: shelly.0 (7506) Starting Shelly adapter in CoAP modus.
    2024-04-26 15:30:21.632  - info: shelly.0 (7506) Listening for Shelly packets in the network
    2024-04-26 15:30:22.420  - info: host.rasphj instance system.adapter.wled.0 started with pid 7530
    2024-04-26 15:30:24.345  - info: wled.0 (7530) starting. Version 0.6.3 in /opt/iobroker/node_modules/iobroker.wled, node: v12.22.12, js-controller: 3.3.21
    2024-04-26 15:30:24.406  - info: wled.0 (7530) Try to contact 2 known devices
    2024-04-26 15:30:24.408  - info: wled.0 (7530) Try to contact : "WLED" on IP : 10.0.0.47
    2024-04-26 15:30:25.388  - info: shelly.0 (7506) Shelly device 10.0.0.44 (shelly1 / shelly1-E8DB84D63938 / SHSW-1#E8DB84D63938#1) with CoAP connected! Polltime set to 5 sec.
    2024-04-26 15:30:25.433  - info: shelly.0 (7506) State value to set for "shelly.0.SHSW-1#E8DB84D63938#1.Relay0.longpush" has to be type "string" but received type "boolean"
    2024-04-26 15:30:27.452  - info: wled.0 (7530) Try to contact : "WLED" on IP : 10.0.0.48
    2024-04-26 15:30:27.490  - info: wled.0 (7530) Initialising : " WLED" on IP :  10.0.0.48
    2024-04-26 15:30:27.596  - error: wled.0 (7530) Sentry disabled, error caught : State attribute definition missing for : cct with value : false
    2024-04-26 15:30:28.361  - info: wled.0 (7530) Bonjour service started, new  devices  will  be detected automatically
    2024-04-26 15:30:28.453  - info: wled.0 (7530) WLED connected
    2024-04-26 15:30:31.501  - info: shelly.0 (7506) Shelly device 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1) with CoAP connected! Polltime set to 5 sec.
    2024-04-26 15:30:34.319  - info: shelly.0 (7506) Shelly device 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1) with CoAP connected! Polltime set to 5 sec.
    2024-04-26 15:30:34.348  - info: shelly.0 (7506) State value to set for "shelly.0.SHSW-1#C45BBE6BC200#1.Relay0.longpush" has to be type "string" but received type "boolean"
    2024-04-26 15:30:38.368  - info: wled.0 (7530) WLED initialisation finalized, ready to do my job have fun !
    2024-04-26 15:30:39.321  - info: sonoff.0 (7146) Client [shelly1-E8DB84D63938] connected with secret 1714138239319_1606
                            v.2023-10-10
             Icon name: computer
          Architecture: arm64
    Kernel:                 aarch64
    Userland:               armhf
    Timezone:               Europe/Vienna (CEST, +0200)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    24
    /home/iobroker/.diag.sh: line 486: nodejs: command not found
    Nodejs-Installation:
    /home/iobroker/.diag.sh: line 490: corepack: command not found
    Recommended versions are nodejs  and npm
    Wrong installation path detected. This needs to be fixed.
    Please check
    https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
    for more information on how to fix these errors.
    MEMORY:
    Mem:            3.8G        725M        2.6G        0.0K        477M        3.2G
    Swap:            99M          0B         99M
    Total:          3.9G        725M        2.7G
    Active iob-Instances:   14
    ioBroker Core:          js-controller           3.3.21
                            admin                   5.1.25
    Objects type: file
    States  type: file
    Objects:                3141
    States:                 2052
    Size of iob-Database:
    412K    /opt/iobroker/iobroker-data/states.json.bak
    0       /opt/iobroker/iobroker-data/states.json.broken
    Hilft nur mehr eine neuinstallation? 🤧
    Lg
    @hans-jürgen-strudler sagte in io Broker lässt sich nicht updaten (Linux):
    Bitte gerne
    SUMMARY
    ist nicht
    @thomas-braun sagte in io Broker lässt sich nicht updaten (Linux):
    die Langfassung
    die kommt vor der Zusammenfassung
    hans1990H 1 Antwort Letzte Antwort
      Bitte gerne
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : armhf
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               3794 M total memory
                668 M used memory
                498 M active memory
               2647 M free memory
                 68 M buffer memory
                409 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      1.7G    /var/
      1.3G    /var/log
      178M    /var/cache
      USB-Devices by-id:
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: file
      States  type: file
      admin:          5.1.25
      javascript:     5.2.13
      Adapter State
      + instance is alive
      update done
      Objects and States
      Objects:        3141
      States:         2051
      Pending Updates: 0
                              v.2023-10-10
               Icon name: computer
            Architecture: arm64
      Kernel:                 aarch64
      Userland:               armhf
      User-ID:                1000
      X-Server:               false
      Please check
      MEMORY:
      Swap:            99M          0B         99M
                              admin                   5.1.25
      Objects type: file
      States  type: file
      Objects:                3141
      States:                 2052
      Lg
      wie hattest fu node installiert (oder versucht upzugraden)?
        Bitte gerne
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : armhf
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                 3794 M total memory
                  668 M used memory
                  498 M active memory
                 2647 M free memory
                   68 M buffer memory
                  409 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        1.7G    /var/
        1.3G    /var/log
        178M    /var/cache
        USB-Devices by-id:
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: file
        States  type: file
        admin:          5.1.25
        javascript:     5.2.13
        Adapter State
        + instance is alive
        update done
        Objects and States
        Objects:        3141
        States:         2051
        Pending Updates: 0
                                v.2023-10-10
                 Icon name: computer
              Architecture: arm64
        Kernel:                 aarch64
        Userland:               armhf
        User-ID:                1000
        X-Server:               false
        Please check
        MEMORY:
        Swap:            99M          0B         99M
                                admin                   5.1.25
        Objects type: file
        States  type: file
        Objects:                3141
        States:                 2052
        Lg
        das gibt es schon seit Jahren nicht mehr (unter dem Namen)
          aber es sah ca. so aus:
          in welchem Zusammenhang?
          hast du etwa npm alleine updaten wollen?
          hans1990H Offline
          hans1990H Offline
          hans1990
          Ich habe node auf 18.20 upgedatet, weil ich dachte dass das das upgrade self dann klappt.
          Zumindest hab ich die Fehlermeldung so verstanden.
          npm ERR! notsup Required: {"node":">=16.4.0"}
          npm ERR! notsup Actual:   {"npm":"6.14.16","node":"12.22.12"}
            Nein, das besagt, dass eine Version >=16.4.0 erforderlich ist, du aber nur 12.22.12 zur Verfügung stellst.
              sollte es auch wenn es richtig gemacht wird
              Deshalb die Frage
              @homoran sagte in io Broker lässt sich nicht updaten (Linux):
              wie hattest du node installiert (oder versucht upzugraden)?
                Bitte gerne
                SUMMARY
                ist nicht
                die Langfassung
                hans1990H Offline
                hans1990H Offline
                hans1990
                schrieb am zuletzt editiert von hans1990
                @Thomas-Braun
                Sorry Langfassung hab ich dazugegeben
                  @Thomas-Braun
                  @hans-jürgen-strudler Hast du jetzt ein Backup gefahren und weggesichert?
                    hans1990H Offline
                    hans1990H Offline
                    hans1990
                    @homoran said in io Broker lässt sich nicht updaten (Linux):
                    ja ist erledigt
                      ja ist erledigt
                      ja ist erledigt
                      Auch history?
                      Dann mach mal ein iob nodejs-update
                      und poste alles dazu
                        ja ist erledigt
                        Auch history?
                        hans1990H Offline
                        hans1990H Offline
                        hans1990
                        ioBroker nodejs updater 2023-10-13
                        No recommendation for a nodejs version found on your system. We recommend to install latest version from nodejs v18 tree.
                        Your current setup is:
                        We found these nodejs versions available for installation:
                        nodejs:
                          Version table:
                        Nothing to do - Your installation is using the correct paths.
                        You are running nodejs v12.22.12. Do you want to install latest version from nodejs v.18 tree?
                        Press <y> to continue or any other key to quit
                        Trying to update your installation now. Please be patient.
                        Waiting for ioBroker to shut down - Give me a minute...
                        *** These repos are active on your system:
                        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                        Reading package lists... Done
                        *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                        *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                        deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
                        Package: nodejs
                        Pin: origin deb.nodesource.com
                        Pin-Priority: 1001
                        *** These repos are active after the adjustments:
                        Get:3 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
                        Get:4 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [8410 B]
                        Fetched 20.6 kB in 1s (26.7 kB/s)
                        Installing the recommended nodejs version now!
                        /home/iobroker/.nodejs-update.sh: line 329: [: : integer expression expected
                        Exact recommended version unknown, installing a fallback!
                        (Reading database ... 54833 files and directories currently installed.)
                        Preparing to unpack .../nodejs_18.0.0-1nodesource1_armhf.deb ...
                        Detected old npm client, removing...
                        Unpacking nodejs (18.0.0-1nodesource1) over (12.22.12-deb-1nodesource1) ...
                        Setting up nodejs (18.0.0-1nodesource1) ...
                        Processing triggers for man-db (2.9.4-2) ...
                        Updating fallback to latest nodejs v18 release
                        (Reading database ... 55694 files and directories currently installed.)
                        Preparing to unpack .../nodejs_18.20.2-1nodesource1_armhf.deb ...
                        Unpacking nodejs (18.20.2-1nodesource1) over (18.0.0-1nodesource1) ...
                        Setting up nodejs (18.20.2-1nodesource1) ...
                        v18.20.2 has been installed! You are using the latest version now!
                        /home/iobroker/.nodejs-update.sh: line 346: [: : integer expression expected
                        Installing the recommended nodejs version!
                        We tried our best to update or fix your nodejs. Please run iob diag again to verify.
                        *** RESTARTING ioBroker NOW! ***
                         Please refresh or restart your browser in a few moments.
                          nodejs:
                            Version table:
                          Package: nodejs
                          Pin-Priority: 1001
                            hans1990H Offline
                            hans1990H Offline
                            hans1990
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : armhf
                             16:11:31 up  1:56,  1 user,  load average: 1.13, 0.84, 0.49
                            CPU threads: 4
                            Current issues:
                                           Local time: Fri 2024-04-26 16:11:31 CEST
                                       Universal time: Fri 2024-04-26 14:11:31 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            /home/pi
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            3.8G        258M        2.5G        0.0K        995M        3.5G
                            Swap:            99M          0B         99M
                            Total:          3.9G        258M        2.6G
                                     3794 M total memory
                                      258 M used memory
                                      287 M active memory
                                      775 M inactive memory
                                     2540 M free memory
                                      138 M buffer memory
                                      856 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /dev/root      ext4       59G  4.1G   52G   8% /
                            /var:
                            1.7G    /var/
                            1.3G    /var/log
                            202M    /var/cache
                            202M    /opt/iobroker/iobroker-data/
                            52M     /opt/iobroker/iobroker-data/files
                            45M     /opt/iobroker/iobroker-data/backup-objects
                            6.4M    /opt/iobroker/iobroker-data/objects.jsonl
                            6.3M    /opt/iobroker/iobroker-data/objects.json.migrated
                            6.3M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                            USB-Devices by-id:
                            /usr/bin/nodejs         v18.20.2
                            /usr/bin/node           v18.20.2
                            /usr/bin/npm            10.5.0
                            /usr/bin/npx            10.5.0
                            /usr/bin/corepack       0.25.2
                            nodejs:
                              Installed: 18.20.2-1nodesource1
                              Candidate: 18.20.2-1nodesource1
                              Version table:
                             *** 18.20.2-1nodesource1 600
                                    500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                 18.20.1-1nodesource1 600
                                 18.20.0-1nodesource1 600
                                 18.19.1-1nodesource1 600
                                 18.19.0-1nodesource1 600
                                 18.18.2-1nodesource1 600
                                 18.18.1-1nodesource1 600
                                 18.18.0-1nodesource1 600
                                 18.17.1-1nodesource1 600
                                 18.17.0-1nodesource1 600
                                 18.16.1-1nodesource1 600
                                 18.16.0-1nodesource1 600
                                 18.15.0-1nodesource1 600
                                 18.14.2-1nodesource1 600
                                 18.14.1-1nodesource1 600
                                 18.14.0-1nodesource1 600
                                 18.13.0-1nodesource1 600
                                 18.12.0-1nodesource1 600
                                 18.11.0-1nodesource1 600
                                 18.10.0-1nodesource1 600
                                 18.9.1-1nodesource1 600
                                 18.9.0-1nodesource1 600
                                 18.8.0-1nodesource1 600
                                 18.7.0-1nodesource1 600
                                 18.6.0-1nodesource1 600
                                 18.5.0-1nodesource1 600
                                 18.4.0-1nodesource1 600
                                 18.3.0-1nodesource1 600
                                 18.2.0-1nodesource1 600
                                 18.1.0-1nodesource1 600
                                 18.0.0-1nodesource1 600
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            js-controller:  5.0.19
                            admin:          5.1.25
                            javascript:     "javascript" not found
                            Adapter State
                            + instance is alive
                            Active repo(s): stable
                            Used repository: stable
                            Adapter    "admin"        : 6.13.16  , installed 5.1.25 [Updatable]
                            Adapter    "backitup"     : 2.11.0   , installed 2.2.2  [Updatable]
                            Adapter    "discovery"    : 4.4.0    , installed 2.7.3  [Updatable]
                            Controller "js-controller": 5.0.19   , installed 5.0.19
                            Adapter    "synology"     : 3.1.0    , installed 3.1.0
                            Objects and States
                            Objects:        3145
                            States:         2056
                            Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                            Pending Updates: 0
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       92947      12486/iobroker.js-c
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       93230      12486/iobroker.js-c
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       90108      12514/io.admin.0
                            2024-04-26 16:11:36.096  - error: host.rasphj instance system.adapter.discovery.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2024-04-26 16:11:36.097  - info: host.rasphj Adapter system.adapter.discovery.0 needs rebuild and will be restarted afterwards.
                            2024-04-26 16:11:36.103  - info: host.rasphj system.adapter.discovery.0 will be rebuilt
                            2024-04-26 16:11:38.074  - info: host.rasphj instance system.adapter.backitup.0 started with pid 12751
                            2024-04-26 16:11:42.464  - info: backitup.0 (12751) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.20.2, js-controller: 5.0.19
                            2024-04-26 16:11:42.526  - warn: backitup.0 (12751) Cannot read log file: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js'
                            Require stack:
                            - /opt/iobroker/node_modules/iobroker.backitup/lib/tools.js
                            - /opt/iobroker/node_modules/iobroker.backitup/main.js
                            2024-04-26 16:11:52.654  - info: host.rasphj iobroker npm-install: added 28 packages in 16s44 packages are looking for funding  run `npm fund` for details
                            2024-04-26 16:11:52.702  - info: host.rasphj iobroker npm-install: host.rasphj install adapter homee@1.2.0
                            2024-04-26 16:11:52.836  - info: host.rasphj iobroker npm-install: upload [4] homee.admin /opt/iobroker/node_modules/iobroker.homee/admin/custom_m.html custom_m.html text/html
                            2024-04-26 16:11:52.851  - info: host.rasphj iobroker npm-install: upload [3] homee.admin /opt/iobroker/node_modules/iobroker.homee/admin/homee.png homee.png image/png
                            2024-04-26 16:11:52.861  - info: host.rasphj iobroker npm-install: upload [2] homee.admin /opt/iobroker/node_modules/iobroker.homee/admin/index_m.html index_m.html text/html
                            2024-04-26 16:11:52.871  - info: host.rasphj iobroker npm-install: upload [1] homee.admin /opt/iobroker/node_modules/iobroker.homee/admin/jsonCustom.json jsonCustom.json application/json
                            2024-04-26 16:11:52.882  - info: host.rasphj iobroker npm-install: upload [0] homee.admin /opt/iobroker/node_modules/iobroker.homee/admin/words.js words.js application/javascript
                            2024-04-26 16:11:52.982  - info: host.rasphj iobroker npm-install: host.rasphj object system.adapter.homee created/updated
                            2024-04-26 16:11:54.057  - info: host.rasphj iobroker npm-install: exit 0
                            2024-04-26 16:11:55.059  - warn: host.rasphj startInstance cannot find adapter "synology". Try to install it... 1 attempt
                            2024-04-26 16:11:55.060  - info: host.rasphj iobroker install synology using installedVersion
                            2024-04-26 16:12:00.183  - info: host.rasphj iobroker npm-install: NPM version: 10.5.0
                            2024-04-26 16:12:00.188  - info: host.rasphj iobroker npm-install: Installing iobroker.synology@3.1.0... (System call)
                            2024-04-26 16:12:43.860  - info: host.rasphj iobroker npm-install:
                            2024-04-26 16:12:43.864  - info: host.rasphj iobroker npm-install: added 32 packages, and changed 1 package in 42s45 packages are looking for funding  run `npm fund` for details
                            2024-04-26 16:12:43.916  - info: host.rasphj iobroker npm-install: host.rasphj install adapter synology
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : armhf
                              CPU threads: 4
                              Current issues:
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              /home/pi
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:            99M          0B         99M
                                       3794 M total memory
                                        258 M used memory
                                        287 M active memory
                                       2540 M free memory
                                        138 M buffer memory
                                        856 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /var:
                              1.7G    /var/
                              1.3G    /var/log
                              202M    /var/cache
                              USB-Devices by-id:
                              /usr/bin/npm            10.5.0
                              /usr/bin/npx            10.5.0
                              nodejs:
                                Version table:
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          5.1.25
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        3145
                              States:         2056
                              Pending Updates: 0
                              Require stack:
                              hast du sonst noch was gemacht?
                              Edit
                              möglich dass er jetzt erst mal die Adapter neu baut.
                                Edit
                                hans1990H Offline
                                hans1990H Offline
                                hans1990
                                iob stop
                                iob update
                                iob upgrade self
                                Ich hab versucht den Fehler zu reproduzieren.
                                @hans-jürgen-strudler said in io Broker lässt sich nicht updaten (Linux):
                                Leider hab ich nicht gespeichert wie die node Version zu hoch war, aber es sah ca. so aus:
                                Copy to Clipboard
                                npm ERR! notsup Required: {"node":"8<=  node => 13"}
                                npm ERR! notsup Actual:   {"npm":"6.14.16","node":"18.20."}
                                auf der Weboberfläche wurde ich informiert, dass das File System geändert wird. das dürfte gerade laufen.
                                HomoranH 3 Antworten Letzte Antwort
                                  iob stop
                                  iob update
                                  iob upgrade self
                                  Copy to Clipboard
                                  Ich hab versucht
                                  bitte niemals nicht nix eigenmächtig machen, wenn dir verducht wird zu helfen
                                  Diesmal Teil 2
                                  https://forum.iobroker.net/post/884324
                                  bitte unbedingt lesen und beachten!
                                    iob stop
                                    iob update
                                    iob upgrade self
                                    Copy to Clipboard
                                    sah ca. so aus:
                                    und auch diesmal:
                                    aus dem Zusammenhang gerissen nutzt das gar nichts
                                      Ich hab versucht
                                      Diesmal Teil 2
                                      hans1990H Offline
                                      hans1990H Offline
                                      hans1990
                                      Stimmt war eine doofe Idee -
                                        @hans-jürgen-strudler Dann warte jetzt mal bis er mit dem Neubau aller Adapter fertig ist.
                                          sah ca. so aus:
                                          und auch diesmal:
                                          sah ca. so aus:
                                          und auch diesmal:
                                          @Hans-Jürgen-Strudler
                                          auf den controller kann sich das ja nicht bezogen haben, der ist ja jetzt auf v5.x
