  4. Adapter "smartmeter"
    1.0k
3.6k Beiträge 281 Kommentatoren 3.1m Aufrufe 162 Beobachtet
  • C Offline
    Creator
    #760
    Ich bin auch etwas überfragt.
    Habe versucht 1.10 zu installieren aber bin wohl nicht schlau genug dazu.
    host.iobroker	2017-12-14 17:28:39.532	info	Update repository 'default' under 'http://download.iobroker.net/sources-dist.json'
    iobroker	2017-12-14 17:28:38.996	info	exit 0
    iobroker	2017-12-14 17:28:38.851	info	upload [0] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/index.html index.html text/html
    iobroker	2017-12-14 17:28:38.758	info	upload [1] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/questionmark.png questionmark.png image/png
    iobroker	2017-12-14 17:28:38.660	info	upload [2] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/smartmeter.jpg smartmeter.jpg image/jpeg
    iobroker	2017-12-14 17:28:38.555	info	upload [3] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/smartmeter.png smartmeter.png image/png
    iobroker	2017-12-14 17:28:38.460	info	upload [4] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/tooltip.css tooltip.css text/css
    iobroker	2017-12-14 17:28:38.422	info	got /opt/iobroker/node_modules/iobroker.smartmeter/admin
    iobroker	2017-12-14 17:28:32.619	info	prebuild-install info unpack required /opt/iobroker/node_modules/iobroker.smartmeter/node_modules/serialport/build/Release/serialport.node successfullyprebuild-install info install Successfully installed prebuilt binary!
    iobroker	2017-12-14 17:28:32.613	info	prebuild-install info unpack resolved to /opt/iobroker/node_modules/iobroker.smartmeter/node_modules/serialport/build/Release/serialport.node
    iobroker	2017-12-14 17:28:32.507	info	prebuild-install info unpacking @ /root/.npm/_prebuilds/https-github.com-EmergingTechnologyAdvisors-node-serialport-releases-download-v6.0.4-serialport-v6.0.4-node-v48-linux-x64.tar.gz
    iobroker	2017-12-14 17:28:32.507	info	prebuild-install info looking for cached prebuild @ /root/.npm/_prebuilds/https-github.com-EmergingTechnologyAdvisors-node-serialport-releases-download-v6.0.4-serialport-v6.0.4-node-v48-linux-x64.tar.gzprebuild-install info found cached prebuild
    iobroker	2017-12-14 17:28:32.501	info	prebuild-install info looking for local prebuild @ prebuilds/serialport-v6.0.4-node-v48-linux-x64.tar.gz
    iobroker	2017-12-14 17:28:32.494	info	info begin Prebuild-install version 2.4.1
    iobroker	2017-12-14 17:28:32.487	info	prebuild-install
    javascript.0	2017-12-14 17:28:22.250	info	script.js.Licht.IndirektesLichtFlur: Indirektes Licht aus
    iobroker	2017-12-14 17:28:02.150	info	npm install https://github.com/Apollon77/ioBroker.smartmeter/tarball/master --production --prefix '/opt/iobroker' (System call)
    iobroker	2017-12-14 17:28:01.874	info	install https://github.com/Apollon77/ioBroker.smartmeter/tarball/master
    iobroker	2017-12-14 17:28:01.066	info	url 'https://github.com/Apollon77/ioBroker.smartmeter/tarball/master' smartmeter
    javascript.0	2017-12-14 17:27:22.237	info	script.js.Licht.IndirektesLichtFlur: Reset Timer
    javascript.0	2017-12-14 17:27:22.236	info	script.js.Licht.IndirektesLichtFlur: BWM Flur OG reagiert!
    javascript.0	2017-12-14 17:27:19.702	info	script.js.Licht.IndirektesLichtFlur: Reset Timer
    javascript.0	2017-12-14 17:27:19.701	info	script.js.Licht.IndirektesLichtFlur: BWM Flur DG reagiert!
    host.iobroker	2017-12-14 17:27:07.932	info	Update repository 'default' under 'http://download.iobroker.net/sources-dist.json'
    host.iobroker	2017-12-14 17:26:55.255	error	Cannot write files: /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/smartmeter.admin/_data.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/smartmeter.admin/_data.json'
    iobroker	2017-12-14 17:26:54.602	info	exit 0
    iobroker	2017-12-14 17:26:54.485	info	host.iobroker Counted 1 states of smartmeterhost.iobroker Deleting 1 object(s).
    iobroker	2017-12-14 17:26:54.315	info	host.iobroker Counted 1 states (system.adapter.smartmeter.*) from states
    iobroker	2017-12-14 17:26:54.256	info	host.iobroker no instances of adapter smartmeter found
    iobroker	2017-12-14 17:26:54.080	info	host.iobroker delete /opt/iobroker/node_modules/iobroker.smartmeter
    iobroker	2017-12-14 17:26:52.936	info	del smartmeter
    Die Installation läuft durch. Als installierter Adapter wird dieser auch angezeigt, aber bei den Instanzen finde ich den nicht.
    Warum?
    • apollon77A Offline
      #761
      @röstkartoffel: ist ne Debug Meldung … nehme ich raus.
      @creator: hast du die alte Instanz gelöscht? Dann unter Adapter in der Zeile vom smartmeter das „+“ nutzen
      • C Offline
        Creator
        #762
        Ich konnte den Fehler jetzt eingrenzen und wohl auch beheben.
        Zur weiteren Diagnose habe ich "strace" genutzt und mir den Prozess angeschaut der auf "D" stand.
        Folgendes war die Ausgabe:
        root@iobroker:~# strace -p 9670
        Process 9670 attached
        futex(0x7f7792d8a9d0, FUTEX_WAIT, 9676, NULL
        FUTEX_WAIT weist nach Recherchen auf ein Bug im Kernel hin. Debian 8 Kernel 3.xxx
        Die Anpassung des Kernels wäre kein Problem gewesen, aber da ich Host System von openmediavault auf Ubuntu Server wechseln wollte,
        habe ich die VM auch fix neu installiert.
        Jetzt läuft es wie gewünscht, zumindest fast…
        host.iobroker	2017-12-17 13:13:14.479	info	Restart adapter system.adapter.smartmeter.0 because enabled
        host.iobroker	2017-12-17 13:13:14.478	error	instance system.adapter.smartmeter.0 terminated with code null ()
        host.iobroker	2017-12-17 13:13:14.477	warn	instance system.adapter.smartmeter.0 terminated due to SIGSEGV
        smartmeter.0	2017-12-17 13:13:13.931	info	SerialResponseTransport do not support sending of Data! Ignore them
        smartmeter.0	2017-12-17 13:13:02.172	info	Received 8 values, 5 updated
        smartmeter.0	2017-12-17 13:13:01.918	info	SerialResponseTransport do not support sending of Data! Ignore them
        smartmeter.0	2017-12-17 13:12:50.167	info	Received 8 values, 5 updated
        smartmeter.0	2017-12-17 13:12:49.910	info	SerialResponseTransport do not support sending of Data! Ignore them
        Läuft aber normal weiter. Was ist das denn nun für ein Fehler?
          #763
          Mit dem sigsegv? Das haben einige. Meine Recherche landete bei Fehler im nodejs speichermanagement … Adapter startet automatisch neu und alles ist gut ;-)
            sven12
            #764
            ich betreibe 2 smartmeter, komischerweise gibt es nur beim smartmeter.1 den Fehler SIGABRT.
            Der smartmeter.0 läuft ohne Probleme
            Ob es wohl damit zu tun hat, das der smartmeter.0 einen ftdi chip und der smartmeter.1 einen CP2104 chip hat?
            Beides sind Leseköpfe von Udo aus dem Volkszähler Forum
            System ist ein debian 9 amd64 auf Z83 MiniPC
            Hier mal ein Log Auszug:
            ! smartmeter.0 2017-12-22 05:34:41.614 info Received 10 values, 3 updated
            ! host.iobroker-z83 2017-12-22 05:34:32.722 info Restart adapter system.adapter.smartmeter.1 because enabled
            ! host.iobroker-z83 2017-12-22 05:34:32.722 error instance system.adapter.smartmeter.1 terminated with code null ()
            ! host.iobroker-z83 2017-12-22 05:34:32.722 warn instance system.adapter.smartmeter.1 terminated due to SIGABRT
            ! host.iobroker-z83 2017-12-22 05:34:32.722 error Caught by controller[17]: ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
            ! host.iobroker-z83 2017-12-22 05:34:32.722 error Caught by controller[17]: 7ffef4b94000-7ffef4b96000 r-xp 00000000 00:00 0 [vdso]
            ! host.iobroker-z83 2017-12-22 05:34:32.722 error Caught by controller[17]: 7ffef4b92000-7ffef4b94000 r–p 00000000 00:00 0 [vvar]
            ! host.iobroker-z83 2017-12-22 05:34:32.722 error Caught by controller[17]: 7ffef4b0e000-7ffef4b2f000 rw-p 00000000 00:00 0 [stack]
            ! host.iobroker-z83 2017-12-22 05:34:32.722 error Caught by controller[17]: 7f2611bb1000-7f2611bb2000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.721 error Caught by controller[17]: 7f2611bb0000-7f2611bb1000 rw-p 00024000 b3:02 262147 /lib/x86_64-linux-gnu/ld-2.24.so
            ! host.iobroker-z83 2017-12-22 05:34:32.721 error Caught by controller[17]: 7f2611baf000-7f2611bb0000 r–p 00023000 b3:02 262147 /lib/x86_64-linux-gnu/ld-2.24.so
            ! host.iobroker-z83 2017-12-22 05:34:32.721 error Caught by controller[17]: 7f2611ba9000-7f2611baf000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.721 error Caught by controller[17]: 7f2611ba8000-7f2611ba9000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.721 error Caught by controller[17]: 7f2611ba7000-7f2611ba8000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.721 error Caught by controller[17]: 7f2611ba0000-7f2611ba5000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.721 error Caught by controller[17]: 7f261198c000-7f26119af000 r-xp 00000000 b3:02 262147 /lib/x86_64-linux-gnu/ld-2.24.so
            ! host.iobroker-z83 2017-12-22 05:34:32.721 error Caught by controller[17]: 7f261198b000-7f261198c000 rw-p 00003000 b3:02 262155 /lib/x86_64-linux-gnu/libdl-2.24.so
            ! host.iobroker-z83 2017-12-22 05:34:32.721 error Caught by controller[17]: 7f261198a000-7f261198b000 r–p 00002000 b3:02 262155 /lib/x86_64-linux-gnu/libdl-2.24.so
            ! host.iobroker-z83 2017-12-22 05:34:32.720 error Caught by controller[17]: 7f261178b000-7f261198a000 –-p 00003000 b3:02 262155 /lib/x86_64-linux-gnu/libdl-2.24.so
            ! host.iobroker-z83 2017-12-22 05:34:32.720 error Caught by controller[17]: 7f2611788000-7f261178b000 r-xp 00000000 b3:02 262155 /lib/x86_64-linux-gnu/libdl-2.24.so
            ! host.iobroker-z83 2017-12-22 05:34:32.720 error Caught by controller[17]: 7f2611787000-7f2611788000 rw-p 00007000 b3:02 262169 /lib/x86_64-linux-gnu/librt-2.24.so
            ! host.iobroker-z83 2017-12-22 05:34:32.720 error Caught by controller[17]: 7f2611786000-7f2611787000 r–p 00006000 b3:02 262169 /lib/x86_64-linux-gnu/librt-2.24.so
            ! host.iobroker-z83 2017-12-22 05:34:32.720 error Caught by controller[17]: 7f2611587000-7f2611786000 –-p 00007000 b3:02 262169 /lib/x86_64-linux-gnu/librt-2.24.so
            ! host.iobroker-z83 2017-12-22 05:34:32.720 error Caught by controller[17]: 7f2611580000-7f2611587000 r-xp 00000000 b3:02 262169 /lib/x86_64-linux-gnu/librt-2.24.so
            ! host.iobroker-z83 2017-12-22 05:34:32.720 error Caught by controller[17]: 7f261157c000-7f2611580000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.720 error Caught by controller[17]: 7f261157a000-7f261157c000 rw-p 0017c000 b3:02 1315527 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.22
            ! host.iobroker-z83 2017-12-22 05:34:32.719 error Caught by controller[17]: 7f2611570000-7f261157a000 r–p 00172000 b3:02 1315527 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.22
            ! host.iobroker-z83 2017-12-22 05:34:32.719 error Caught by controller[17]: 7f2611370000-7f2611570000 –-p 00172000 b3:02 1315527 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.22
            ! host.iobroker-z83 2017-12-22 05:34:32.719 error Caught by controller[17]: 7f26111fe000-7f2611370000 r-xp 00000000 b3:02 1315527 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.22
            ! host.iobroker-z83 2017-12-22 05:34:32.719 error Caught by controller[17]: 7f26111fd000-7f26111fe000 rw-p 00103000 b3:02 262156 /lib/x86_64-linux-gnu/libm-2.24.so
            ! host.iobroker-z83 2017-12-22 05:34:32.719 error Caught by controller[17]: 7f26111fc000-7f26111fd000 r–p 00102000 b3:02 262156 /lib/x86_64-linux-gnu/libm-2.24.so
            ! host.iobroker-z83 2017-12-22 05:34:32.719 error Caught by controller[17]: 7f2610ffd000-7f26111fc000 –-p 00103000 b3:02 262156 /lib/x86_64-linux-gnu/libm-2.24.so
            ! host.iobroker-z83 2017-12-22 05:34:32.719 error Caught by controller[17]: 7f2610efa000-7f2610ffd000 r-xp 00000000 b3:02 262156 /lib/x86_64-linux-gnu/libm-2.24.so
            ! host.iobroker-z83 2017-12-22 05:34:32.719 error Caught by controller[17]: 7f2610ef9000-7f2610efa000 rw-p 00016000 b3:02 262148 /lib/x86_64-linux-gnu/libgcc_s.so.1
            ! host.iobroker-z83 2017-12-22 05:34:32.718 error Caught by controller[17]: 7f2610ef8000-7f2610ef9000 r–p 00015000 b3:02 262148 /lib/x86_64-linux-gnu/libgcc_s.so.1
            ! host.iobroker-z83 2017-12-22 05:34:32.718 error Caught by controller[17]: 7f2610cf9000-7f2610ef8000 –-p 00016000 b3:02 262148 /lib/x86_64-linux-gnu/libgcc_s.so.1
            ! host.iobroker-z83 2017-12-22 05:34:32.718 error Caught by controller[17]: 7f2610ce3000-7f2610cf9000 r-xp 00000000 b3:02 262148 /lib/x86_64-linux-gnu/libgcc_s.so.1
            ! host.iobroker-z83 2017-12-22 05:34:32.718 error Caught by controller[17]: 7f2610cdf000-7f2610ce3000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.718 error Caught by controller[17]: 7f2610cde000-7f2610cdf000 rw-p 00018000 b3:02 262167 /lib/x86_64-linux-gnu/libpthread-2.24.so
            ! host.iobroker-z83 2017-12-22 05:34:32.718 error Caught by controller[17]: 7f2610cdd000-7f2610cde000 r–p 00017000 b3:02 262167 /lib/x86_64-linux-gnu/libpthread-2.24.so
            ! host.iobroker-z83 2017-12-22 05:34:32.718 error Caught by controller[17]: 7f2610ade000-7f2610cdd000 –-p 00018000 b3:02 262167 /lib/x86_64-linux-gnu/libpthread-2.24.so
            ! host.iobroker-z83 2017-12-22 05:34:32.718 error Caught by controller[17]: 7f2610ac6000-7f2610ade000 r-xp 00000000 b3:02 262167 /lib/x86_64-linux-gnu/libpthread-2.24.so
            ! host.iobroker-z83 2017-12-22 05:34:32.718 error Caught by controller[17]: 7f2610ac2000-7f2610ac6000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.717 error Caught by controller[17]: 7f2610ac0000-7f2610ac2000 rw-p 00199000 b3:02 262152 /lib/x86_64-linux-gnu/libc-2.24.so
            ! host.iobroker-z83 2017-12-22 05:34:32.717 error Caught by controller[17]: 7f2610abc000-7f2610ac0000 r–p 00195000 b3:02 262152 /lib/x86_64-linux-gnu/libc-2.24.so
            ! host.iobroker-z83 2017-12-22 05:34:32.717 error Caught by controller[17]: 7f26108bc000-7f2610abc000 –-p 00195000 b3:02 262152 /lib/x86_64-linux-gnu/libc-2.24.so
            ! host.iobroker-z83 2017-12-22 05:34:32.717 error Caught by controller[17]: 7f2610727000-7f26108bc000 r-xp 00000000 b3:02 262152 /lib/x86_64-linux-gnu/libc-2.24.so
            ! host.iobroker-z83 2017-12-22 05:34:32.717 error Caught by controller[17]: 7f260ff27000-7f2610727000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.717 error Caught by controller[17]: 7f260ff26000-7f260ff27000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.717 error Caught by controller[17]: 7f260f726000-7f260ff26000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.717 error Caught by controller[17]: 7f260f725000-7f260f726000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.716 error Caught by controller[17]: 7f260ef25000-7f260f725000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.716 error Caught by controller[17]: 7f260ef24000-7f260ef25000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.716 error Caught by controller[17]: 7f260e724000-7f260ef24000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.716 error Caught by controller[17]: 7f260e723000-7f260e724000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.716 error Caught by controller[17]: 7f260e722000-7f260e723000 rw-p 0000e000 b3:02 1330734 /opt/iobroker/node_modules/iobroker.smartmeter/node_modules/serialport/build/Release/serialport.node
            ! host.iobroker-z83 2017-12-22 05:34:32.716 error Caught by controller[17]: 7f260e721000-7f260e722000 r–p 0000d000 b3:02 1330734 /opt/iobroker/node_modules/iobroker.smartmeter/node_modules/serialport/build/Release/serialport.node
            ! host.iobroker-z83 2017-12-22 05:34:32.716 error Caught by controller[17]: 7f260e521000-7f260e721000 –-p 0000d000 b3:02 1330734 /opt/iobroker/node_modules/iobroker.smartmeter/node_modules/serialport/build/Release/serialport.node
            ! host.iobroker-z83 2017-12-22 05:34:32.716 error Caught by controller[17]: 7f260e514000-7f260e521000 r-xp 00000000 b3:02 1330734 /opt/iobroker/node_modules/iobroker.smartmeter/node_modules/serialport/build/Release/serialport.node
            ! host.iobroker-z83 2017-12-22 05:34:32.715 error Caught by controller[17]: 7f260dd14000-7f260e514000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.715 error Caught by controller[17]: 7f260dd13000-7f260dd14000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.715 error Caught by controller[17]: 7f260d513000-7f260dd13000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.715 error Caught by controller[17]: 7f260d512000-7f260d513000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.715 error Caught by controller[17]: 7f260cd12000-7f260d512000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.715 error Caught by controller[17]: 7f260cd11000-7f260cd12000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.715 error Caught by controller[17]: 7f260c511000-7f260cd11000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.715 error Caught by controller[17]: 7f260c510000-7f260c511000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.714 error Caught by controller[17]: 7f26081c9000-7f260c000000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.714 error Caught by controller[17]: 7f2608000000-7f26081c9000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.714 error Caught by controller[17]: 7f2604213000-7f2608000000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.714 error Caught by controller[17]: 7f2604000000-7f2604213000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.714 error Caught by controller[17]: 7f2600213000-7f2604000000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.714 error Caught by controller[17]: 7f2600000000-7f2600213000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.714 error Caught by controller[17]: 7f25fc029000-7f2600000000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.714 error Caught by controller[17]: 7f25fc000000-7f25fc029000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.714 error Caught by controller[17]: 7f25f8163000-7f25fc000000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.713 error Caught by controller[17]: 7f25f8000000-7f25f8163000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.713 error Caught by controller[17]: 7f25f4021000-7f25f8000000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.713 error Caught by controller[17]: 7f25f4000000-7f25f4021000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.713 error Caught by controller[17]: 7f25f0021000-7f25f4000000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.712 error Caught by controller[17]: 7f25f0000000-7f25f0021000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.712 error Caught by controller[17]: 7f25ec021000-7f25f0000000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.711 error Caught by controller[17]: 7f25ec000000-7f25ec021000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.711 error Caught by controller[17]: 7f25e8021000-7f25ec000000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.711 error Caught by controller[17]: 7f25e8000000-7f25e8021000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.711 error Caught by controller[17]: 3e883cb00000-3e883cc00000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.711 error Caught by controller[17]: 3ccba4f00000-3ccba5000000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.711 error Caught by controller[17]: 3c1815000000-3c1815100000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.711 error Caught by controller[17]: 399b1dd00000-399b1de00000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.711 error Caught by controller[17]: 37d75a500000-37d75a513000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.710 error Caught by controller[17]: 32981bdd6000-32981c196000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.710 error Caught by controller[17]: 32981bd96000-32981bdd6000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.710 error Caught by controller[17]: 31a24ba00000-31a24baf5000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.710 error Caught by controller[17]: 2feb7cb00000-2feb7cc00000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.710 error Caught by controller[17]: 2bd2fab00000-2bd2fac00000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.710 error Caught by controller[17]: 2ba3cb200000-2ba3cb300000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.710 error Caught by controller[17]: 29c3b7e00000-29c3b7f00000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.710 error Caught by controller[17]: 29124f200000-29124f300000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.709 error Caught by controller[17]: 28d7b4800000-28d7b4900000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.709 error Caught by controller[17]: 287097500000-287097600000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.709 error Caught by controller[17]: 20d06fb00000-20d06fc00000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.709 error Caught by controller[17]: 20a87ad00000-20a87ae00000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.709 error Caught by controller[17]: 2099236ff000-209942c7b000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.709 error Caught by controller[17]: 209923606000-2099236ff000 rwxp 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.709 error Caught by controller[17]: 209923605000-209923606000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.708 error Caught by controller[17]: 209923600000-209923605000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.707 error Caught by controller[17]: 2099235ff000-209923600000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.706 error Caught by controller[17]: 209923506000-2099235ff000 rwxp 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.706 error Caught by controller[17]: 209923505000-209923506000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.706 error Caught by controller[17]: 209923500000-209923505000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.706 error Caught by controller[17]: 209923100000-209923500000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.706 error Caught by controller[17]: 209923047000-209923100000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.706 error Caught by controller[17]: 209923006000-209923047000 rwxp 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.706 error Caught by controller[17]: 209923005000-209923006000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.706 error Caught by controller[17]: 209923000000-209923005000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.705 error Caught by controller[17]: 209922f08000-209923000000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.705 error Caught by controller[17]: 209922f06000-209922f08000 rwxp 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.705 error Caught by controller[17]: 209922f05000-209922f06000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.705 error Caught by controller[17]: 209922f00000-209922f05000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.705 error Caught by controller[17]: 209922e08000-209922f00000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.705 error Caught by controller[17]: 209922e06000-209922e08000 rwxp 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.705 error Caught by controller[17]: 209922e05000-209922e06000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.705 error Caught by controller[17]: 209922e00000-209922e05000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.704 error Caught by controller[17]: 209922d08000-209922e00000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.704 error Caught by controller[17]: 209922d06000-209922d08000 rwxp 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.704 error Caught by controller[17]: 209922d05000-209922d06000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.704 error Caught by controller[17]: 209922d00000-209922d05000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.704 error Caught by controller[17]: 209922c7b000-209922d00000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.704 error Caught by controller[17]: 208f26a00000-208f26b00000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.704 error Caught by controller[17]: 1f5078c00000-1f5078d00000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.704 error Caught by controller[17]: 1e6c92a00000-1e6c92b00000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.703 error Caught by controller[17]: 1e2103100000-1e2103200000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.703 error Caught by controller[17]: 1a4b65c00000-1a4b65d00000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.703 error Caught by controller[17]: 1726f2200000-1726f2300000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.703 error Caught by controller[17]: 17013c400000-17013c500000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.703 error Caught by controller[17]: 16b807280000-16b807287000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.703 error Caught by controller[17]: 16b807260000-16b807280000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.703 error Caught by controller[17]: 16b807247000-16b807260000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.702 error Caught by controller[17]: 147330200000-147330300000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.702 error Caught by controller[17]: 13edd1500000-13edd1600000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.702 error Caught by controller[17]: 1250fbe00000-1250fbf00000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.702 error Caught by controller[17]: d977b700000-d977b800000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.702 error Caught by controller[17]: d3f79a00000-d3f79b00000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.702 error Caught by controller[17]: cb499800000-cb499900000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.702 error Caught by controller[17]: 7a14a800000-7a14a900000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.702 error Caught by controller[17]: 79ea1700000-79ea1800000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.701 error Caught by controller[17]: 7377e100000-7377e200000 –-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.701 error Caught by controller[17]: 549d3000000-549d3100000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.701 error Caught by controller[17]: 037c4000-042a9000 rw-p 00000000 00:00 0 [heap]
            ! host.iobroker-z83 2017-12-22 05:34:32.701 error Caught by controller[17]: 01e14000-01e29000 rw-p 00000000 00:00 0
            ! host.iobroker-z83 2017-12-22 05:34:32.701 error Caught by controller[17]: 01dfc000-01e14000 rw-p 017fc000 b3:02 1325111 /usr/bin/node
            ! host.iobroker-z83 2017-12-22 05:34:32.701 error Caught by controller[17]: 00400000-01bfd000 r-xp 00000000 b3:02 1325111 /usr/bin/node
            ! host.iobroker-z83 2017-12-22 05:34:32.701 error Caught by controller[16]: ======= Memory map: ========
            ! host.iobroker-z83 2017-12-22 05:34:32.701 error Caught by controller[16]: io.smartmeter.1[0x7b9ded]
            ! host.iobroker-z83 2017-12-22 05:34:32.700 error Caught by controller[15]: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf1)[0x7f26107472b1]
            ! host.iobroker-z83 2017-12-22 05:34:32.700 error Caught by controller[15]: io.smartmeter.1(_ZN4node5StartEiPPc+0x580)[0x10ab2b0]
            ! host.iobroker-z83 2017-12-22 05:34:32.700 error Caught by controller[14]: io.smartmeter.1(uv_run+0x156)[0x1323046]
            ! host.iobroker-z83 2017-12-22 05:34:32.700 error Caught by controller[13]: io.smartmeter.1[0x13341a8]
            ! host.iobroker-z83 2017-12-22 05:34:32.700 error Caught by controller[12]: io.smartmeter.1[0x13226bb]
            ! host.iobroker-z83 2017-12-22 05:34:32.700 error Caught by controller[11]: io.smartmeter.1[0x1320605]
            ! host.iobroker-z83 2017-12-22 05:34:32.700 error Caught by controller[10]: io.smartmeter.1[0x10c5a14]
            ! host.iobroker-z83 2017-12-22 05:34:32.699 error Caught by controller[9]: io.smartmeter.1(ZN4node11UVExceptionEPN2v87IsolateEiPKcS4_S4_S4+0xe3)[0x109faf3]
            ! host.iobroker-z83 2017-12-22 05:34:32.699 error Caught by controller[8]: io.smartmeter.1(ZN2v86String6ConcatENS_5LocalIS0_EES2+0x82)[0x97d9f2]
            ! host.iobroker-z83 2017-12-22 05:34:32.699 error Caught by controller[7]: io.smartmeter.1(ZN2v88internal7Factory13NewConsStringENS0_6HandleINS0_6StringEEES4+0x96)[0xc6cc86]
            ! host.iobroker-z83 2017-12-22 05:34:32.699 error Caught by controller[6]: io.smartmeter.1(_ZN2v88internal7Factory3NewINS0_10ConsStringEEENS0_6HandleIT_EENS4_INS0_3MapEEENS0_15AllocationSpaceE+0x6a)[0xc6ca9a]
            ! host.iobroker-z83 2017-12-22 05:34:32.699 error Caught by controller[5]: io.smartmeter.1(_ZN2v88internal4Heap14CollectGarbageENS0_16GarbageCollectorEPKcS4_NS_15GCCallbackFlagsE+0x14a)[0xca9a2a]
            ! host.iobroker-z83 2017-12-22 05:34:32.699 error Caught by controller[4]: io.smartmeter.1(_ZN2v88internal4Heap24PerformGarbageCollectionENS0_16GarbageCollectorENS_15GCCallbackFlagsE+0x150)[0xca9080]
            ! host.iobroker-z83 2017-12-22 05:34:32.699 error Caught by controller[3]: io.smartmeter.1(_ZN2v88internal4Heap8ScavengeEv+0x71c)[0xca348c]
            ! host.iobroker-z83 2017-12-22 05:34:32.699 error Caught by controller[2]: /lib/x86_64-linux-gnu/libc.so.6(+0x777de)[0x7f261079e7de]
            ! host.iobroker-z83 2017-12-22 05:34:32.698 error Caught by controller[2]: /lib/x86_64-linux-gnu/libc.so.6(+0x76f96)[0x7f261079df96]
            ! host.iobroker-z83 2017-12-22 05:34:32.698 error Caught by controller[1]: /lib/x86_64-linux-gnu/libc.so.6(+0x70bcb)[0x7f2610797bcb]
            ! host.iobroker-z83 2017-12-22 05:34:32.698 error Caught by controller[1]: ======= Backtrace: =========
            ! host.iobroker-z83 2017-12-22 05:34:32.697 error Caught by controller[0]: *** Error in `io.smartmeter.1': free(): invalid pointer: 0x00000000038f73d8 ***
            Normalerweise bekomme ich so etwas im Logfile:
            host.iobroker-z83	2017-12-22 04:29:54.575	info	Restart adapter system.adapter.smartmeter.1 because enabled
            host.iobroker-z83	2017-12-22 04:29:54.575	error	instance system.adapter.smartmeter.1 terminated with code null ()
            host.iobroker-z83	2017-12-22 04:29:54.574	warn	instance system.adapter.smartmeter.1 terminated due to SIGSEGV
            Heute Morgen dann der große Auszug siehe Spoiler
            • wendy2702W Online
              wendy2702W Online
              #765
              Moin,
              Bedeutet du hast zwei unterschiedliche USB-Seriel Adapter!?
              Um zu prüfen ob deine Theorie stimmt könntest du doch einfach mal die beiden Adapter tauschen und beobachten ob der Fehler mit wandert.
              Geht der Fehler mit, liegt es zu 99% am Adapter. Bliebt der Fehler bei Smartmeter.1 hat es eine andere Ursache.
                #766
                Diese ganzen SIGSEGV oder SIGABRT, wie ich bisher recherchiert hatte, kommen von irgendwechen Fehlern im Speichermanagement. Dachte bisher immer das es nodejs-Buffer-Implementierung ist, aber theoretisch kann natürlich auch der drunter liegende Treiber mitspielen.
                  sven12
                  #767
                  @wendy2702:
                  Gruß `
                  Ja einen USB Adpater von Udo hatte ich schon lange, dann später als die PV Anlage installiert wurde, habe ich mir noch einen bei Ihm besorgt.
                  Scheinbar hat er früher ftdi verbaut und heute den cp2104
                  Adapter habe ich jetzt getauscht mal abwarten was das log morgen sagt.
                  Sven
                    sven12
                    #768
                    So da brauchten wir nicht so lange warten :(
                    host.iobroker-z83	2017-12-22 18:52:44.130	info	Restart adapter system.adapter.smartmeter.0 because enabled
                    host.iobroker-z83	2017-12-22 18:52:44.130	error	instance system.adapter.smartmeter.0 terminated with code null ()
                    host.iobroker-z83	2017-12-22 18:52:44.129	warn	instance system.adapter.smartmeter.0 terminated due to SIGSEGV
                    smartmeter.1	2017-12-22 18:52:32.952	info	Received 7 values, 0 updated
                    Also wandert der Fehler und man kann sagen der cp2104 macht den Ärger….
                      klassisch
                      #769
                      @sven12:
                      Also wandert der Fehler und man kann sagen der cp2104 macht den Ärger…. `
                      Gut zu wissen, vielen Dank für die Untersuchungen! Gibt ja etliches, was über so einen Adapter angeschlossen wird. Ich kaufe meist die CH340G. Die sind billig und gelten als recht friedfertig. Allerdings habe ich derzeit keinen im Langzeiteinsatz am ioBroker.
                        sven12
                        #770
                        Noch was….
                        host.iobroker-z83	2017-12-22 19:20:22.791	error	instance system.adapter.smartmeter.0 terminated with code 0 (OK)
                        host.iobroker-z83	2017-12-22 19:20:22.791	error	Caught by controller[0]: at SerialPort. (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/serialport/lib/serialport.js:180:16)
                        host.iobroker-z83	2017-12-22 19:20:22.791	error	Caught by controller[0]: at SerialPort._read (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/serialport/lib/serialport.js:303:8)
                        host.iobroker-z83	2017-12-22 19:20:22.791	error	Caught by controller[0]: at Object.fs.read (fs.js:689:11)
                        host.iobroker-z83	2017-12-22 19:20:22.791	error	Caught by controller[0]: at TypeError (native)
                        host.iobroker-z83	2017-12-22 19:20:22.790	error	Caught by controller[0]: TypeError: fd must be a file descriptor
                        smartmeter.0	2017-12-22 19:20:22.229	warn	Exception: TypeError: fd must be a file descriptor
                        smartmeter.0	2017-12-22 19:20:22.228	error	TypeError: fd must be a file descriptor at TypeError (native) at Object.fs.read (fs.js:689:11) at SerialPort._read (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/serialport/l
                        smartmeter.0	2017-12-22 19:20:22.227	error	uncaught exception: fd must be a file descriptor
                        Wieder zurück gewechselt…
                        ! host.iobroker-z83 2017-12-22 20:39:32.495 info Restart adapter system.adapter.smartmeter.0 because enabled
                        ! host.iobroker-z83 2017-12-22 20:39:32.495 error instance system.adapter.smartmeter.0 terminated with code null ()
                        ! host.iobroker-z83 2017-12-22 20:39:32.495 warn instance system.adapter.smartmeter.0 terminated due to SIGABRT
                        ! Caught 2017-12-22 20:39:32.494 error by controller[6]: ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
                        ! Caught 2017-12-22 20:39:32.494 error by controller[6]: 7ffc67dfe000-7ffc67e00000 r-xp 00000000 00:00 0 [vdso]
                        ! Caught 2017-12-22 20:39:32.494 error by controller[6]: 7ffc67dfc000-7ffc67dfe000 r–p 00000000 00:00 0 [vvar]
                        ! Caught 2017-12-22 20:39:32.494 error by controller[6]: 7ffc67ddb000-7ffc67dfc000 rw-p 00000000 00:00 0 [stack]
                        ! Caught 2017-12-22 20:39:32.494 error by controller[6]: 7ffa40ab4000-7ffa40ab5000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.493 error by controller[6]: 7ffa40ab3000-7ffa40ab4000 rw-p 00024000 b3:02 262147 /lib/x86_64-linux-gnu/ld-2.24.so
                        ! Caught 2017-12-22 20:39:32.493 error by controller[6]: 7ffa40ab2000-7ffa40ab3000 r–p 00023000 b3:02 262147 /lib/x86_64-linux-gnu/ld-2.24.so
                        ! Caught 2017-12-22 20:39:32.493 error by controller[6]: 7ffa40aac000-7ffa40ab2000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.493 error by controller[6]: 7ffa40aab000-7ffa40aac000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.493 error by controller[6]: 7ffa40aaa000-7ffa40aab000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.493 error by controller[6]: 7ffa40aa3000-7ffa40aa8000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.493 error by controller[6]: 7ffa4088f000-7ffa408b2000 r-xp 00000000 b3:02 262147 /lib/x86_64-linux-gnu/ld-2.24.so
                        ! Caught 2017-12-22 20:39:32.492 error by controller[6]: 7ffa4088e000-7ffa4088f000 rw-p 00003000 b3:02 262155 /lib/x86_64-linux-gnu/libdl-2.24.so
                        ! Caught 2017-12-22 20:39:32.492 error by controller[6]: 7ffa4088d000-7ffa4088e000 r–p 00002000 b3:02 262155 /lib/x86_64-linux-gnu/libdl-2.24.so
                        ! Caught 2017-12-22 20:39:32.492 error by controller[6]: 7ffa4068e000-7ffa4088d000 –-p 00003000 b3:02 262155 /lib/x86_64-linux-gnu/libdl-2.24.so
                        ! Caught 2017-12-22 20:39:32.492 error by controller[6]: 7ffa4068b000-7ffa4068e000 r-xp 00000000 b3:02 262155 /lib/x86_64-linux-gnu/libdl-2.24.so
                        ! Caught 2017-12-22 20:39:32.491 error by controller[6]: 7ffa4068a000-7ffa4068b000 rw-p 00007000 b3:02 262169 /lib/x86_64-linux-gnu/librt-2.24.so
                        ! Caught 2017-12-22 20:39:32.491 error by controller[6]: 7ffa40689000-7ffa4068a000 r–p 00006000 b3:02 262169 /lib/x86_64-linux-gnu/librt-2.24.so
                        ! Caught 2017-12-22 20:39:32.491 error by controller[6]: 7ffa4048a000-7ffa40689000 –-p 00007000 b3:02 262169 /lib/x86_64-linux-gnu/librt-2.24.so
                        ! Caught 2017-12-22 20:39:32.491 error by controller[6]: 262169 /lib/x86_64-linux-gnu/librt-2.24.so
                        ! Caught 2017-12-22 20:39:32.491 error by controller[5]: 7ffa40483000-7ffa4048a000 r-xp 00000000 b3:02
                        ! Caught 2017-12-22 20:39:32.491 error by controller[5]: 7ffa4047f000-7ffa40483000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.490 error by controller[5]: 7ffa4047d000-7ffa4047f000 rw-p 0017c000 b3:02 1315527 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.22
                        ! Caught 2017-12-22 20:39:32.490 error by controller[5]: 7ffa40473000-7ffa4047d000 r–p 00172000 b3:02 1315527 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.22
                        ! Caught 2017-12-22 20:39:32.490 error by controller[5]: 7ffa40273000-7ffa40473000 –-p 00172000 b3:02 1315527 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.22
                        ! Caught 2017-12-22 20:39:32.490 error by controller[5]: 7ffa40101000-7ffa40273000 r-xp 00000000 b3:02 1315527 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.22
                        ! Caught 2017-12-22 20:39:32.490 error by controller[5]: 7ffa40100000-7ffa40101000 rw-p 00103000 b3:02 262156 /lib/x86_64-linux-gnu/libm-2.24.so
                        ! Caught 2017-12-22 20:39:32.489 error by controller[5]: 7ffa400ff000-7ffa40100000 r–p 00102000 b3:02 262156 /lib/x86_64-linux-gnu/libm-2.24.so
                        ! Caught 2017-12-22 20:39:32.489 error by controller[5]: 7ffa3ff00000-7ffa400ff000 –-p 00103000 b3:02 262156 /lib/x86_64-linux-gnu/libm-2.24.so
                        ! Caught 2017-12-22 20:39:32.489 error by controller[5]: 7ffa3fdfd000-7ffa3ff00000 r-xp 00000000 b3:02 262156 /lib/x86_64-linux-gnu/libm-2.24.so
                        ! Caught 2017-12-22 20:39:32.489 error by controller[5]: 7ffa3fdfc000-7ffa3fdfd000 rw-p 00016000 b3:02 262148 /lib/x86_64-linux-gnu/libgcc_s.so.1
                        ! Caught 2017-12-22 20:39:32.488 error by controller[5]: 7ffa3fdfb000-7ffa3fdfc000 r–p 00015000 b3:02 262148 /lib/x86_64-linux-gnu/libgcc_s.so.1
                        ! Caught 2017-12-22 20:39:32.485 error by controller[5]: 7ffa3fbfc000-7ffa3fdfb000 –-p 00016000 b3:02 262148 /lib/x86_64-linux-gnu/libgcc_s.so.1
                        ! Caught 2017-12-22 20:39:32.485 error by controller[5]: 7ffa3fbe6000-7ffa3fbfc000 r-xp 00000000 b3:02 262148 /lib/x86_64-linux-gnu/libgcc_s.so.1
                        ! Caught 2017-12-22 20:39:32.485 error by controller[5]: 7ffa3fbe2000-7ffa3fbe6000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.485 error by controller[5]: 7ffa3fbe1000-7ffa3fbe2000 rw-p 00018000 b3:02 262167 /lib/x86_64-linux-gnu/libpthread-2.24.so
                        ! Caught 2017-12-22 20:39:32.485 error by controller[5]: 7ffa3fbe0000-7ffa3fbe1000 r–p 00017000 b3:02 262167 /lib/x86_64-linux-gnu/libpthread-2.24.so
                        ! Caught 2017-12-22 20:39:32.485 error by controller[5]: 7ffa3f9e1000-7ffa3fbe0000 –-p 00018000 b3:02 262167 /lib/x86_64-linux-gnu/libpthread-2.24.so
                        ! Caught 2017-12-22 20:39:32.484 error by controller[5]: 7ffa3f9c9000-7ffa3f9e1000 r-xp 00000000 b3:02 262167 /lib/x86_64-linux-gnu/libpthread-2.24.so
                        ! Caught 2017-12-22 20:39:32.484 error by controller[5]: 7ffa3f9c5000-7ffa3f9c9000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.484 error by controller[5]: 7ffa3f9c3000-7ffa3f9c5000 rw-p 00199000 b3:02 262152 /lib/x86_64-linux-gnu/libc-2.24.so
                        ! Caught 2017-12-22 20:39:32.484 error by controller[5]: 7ffa3f9bf000-7ffa3f9c3000 r–p 00195000 b3:02 262152 /lib/x86_64-linux-gnu/libc-2.24.so
                        ! Caught 2017-12-22 20:39:32.483 error by controller[5]: 7ffa3f7bf000-7ffa3f9bf000 –-p 00195000 b3:02 262152 /lib/x86_64-linux-gnu/libc-2.24.so
                        ! Caught 2017-12-22 20:39:32.483 error by controller[5]: 7ffa3f62a000-7ffa3f7bf000 r-xp 00000000 b3:02 262152 /lib/x86_64-linux-gnu/libc-2.24.so
                        ! Caught 2017-12-22 20:39:32.483 error by controller[5]: 7ffa3ee2a000-7ffa3f62a000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.483 error by controller[5]: 7ffa3ee29000-7ffa3ee2a000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.483 error by controller[5]: 7ffa3e629000-7ffa3ee29000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.483 error by controller[5]: 7ffa3e628000-7ffa3e629000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.482 error by controller[5]: 7ffa3de28000-7ffa3e628000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.482 error by controller[5]: 7ffa3de27000-7ffa3de28000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.482 error by controller[5]: 7ffa3d627000-7ffa3de27000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.482 error by controller[5]: 7ffa3d626000-7ffa3d627000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.482 error by controller[5]: 7ffa3d625000-7ffa3d626000 rw-p 0000e000 b3:02 1330734 /opt/iobroker/node_modules/iobroker.smartmeter/node_modules/serialport/build/Release/serialport.node
                        ! Caught 2017-12-22 20:39:32.481 error by controller[5]: 7ffa3d624000-7ffa3d625000 r–p 0000d000 b3:02 1330734 /opt/iobroker/node_modules/iobroker.smartmeter/node_modules/serialport/build/Release/serialport.node
                        ! Caught 2017-12-22 20:39:32.481 error by controller[5]: 7ffa3d424000-7ffa3d624000 –-p 0000d000 b3:02 1330734 /opt/iobroker/node_modules/iobroker.smartmeter/node_modules/serialport/build/Release/serialport.node
                        ! Caught 2017-12-22 20:39:32.481 error by controller[5]: 7ffa3d417000-7ffa3d424000 r-xp 00000000 b3:02 1330734 /opt/iobroker/node_modules/iobroker.smartmeter/node_modules/serialport/build/Release/serialport.node
                        ! Caught 2017-12-22 20:39:32.481 error by controller[5]: 7ffa3cc17000-7ffa3d417000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.481 error by controller[5]: 7ffa3cc16000-7ffa3cc17000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.480 error by controller[5]: 7ffa3c416000-7ffa3cc16000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.480 error by controller[5]: 7ffa3c415000-7ffa3c416000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.480 error by controller[5]: 7ffa38212000-7ffa3c000000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.480 error by controller[5]: 7ffa38000000-7ffa38212000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.480 error by controller[5]: 7ffa37800000-7ffa38000000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.480 error by controller[5]: 7ffa377ff000-7ffa37800000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.480 error by controller[5]: 7ffa36fff000-7ffa377ff000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.479 error by controller[5]: 7ffa36ffe000-7ffa36fff000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.479 error by controller[5]: 7ffa30213000-7ffa34000000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.479 error by controller[5]: 7ffa30000000-7ffa30213000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.479 error by controller[5]: 7ffa2c213000-7ffa30000000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.479 error by controller[5]: 7ffa2c000000-7ffa2c213000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.478 error by controller[5]: 7ffa28212000-7ffa2c000000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.478 error by controller[5]: 7ffa28000000-7ffa28212000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.478 error by controller[5]: 7ffa24021000-7ffa28000000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.478 error by controller[5]: 7ffa24000000-7ffa24021000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.478 error by controller[5]: 7ffa20029000-7ffa24000000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.478 error by controller[5]: 7ffa20000000-7ffa20029000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.477 error by controller[5]: 7ffa1c021000-7ffa20000000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.476 error by controller[5]: 7ffa1c000000-7ffa1c021000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.476 error by controller[5]: 7ffa18021000-7ffa1c000000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.476 error by controller[5]: 7ffa18000000-7ffa18021000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.476 error by controller[5]: 7ffa10021000-7ffa14000000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.475 error by controller[5]: 7ffa10000000-7ffa10021000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.475 error by controller[5]: 3f65c3d00000-3f65c3e00000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.475 error by controller[5]: 3e2373300000-3e2373400000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.475 error by controller[5]: 3b77c2f00000-3b77c3000000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.475 error by controller[5]: 38dc7ce00000-38dc7cf00000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.474 error by controller[5]: 35e898c00000-35e898d00000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.474 error by controller[5]: 3510d9300000-3510d9400000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.474 error by controller[5]: 334fd8a00000-334fd8b00000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.474 error by controller[5]: 2f992b400000-2f992b500000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.474 error by controller[5]: 2c7ce1200000-2c7ce1300000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.474 error by controller[5]: 28578cf00000-28578d000000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.474 error by controller[5]: 28523e600000-28523e613000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.473 error by controller[5]: 2773dc0ff000-2773fb650000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.473 error by controller[5]: 2773dc006000-2773dc0ff000 rwxp 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.473 error by controller[5]: 2773dc005000-2773dc006000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.473 error by controller[5]: 2773dc000000-2773dc005000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.473 error by controller[5]: 2773dbfff000-2773dc000000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.473 error by controller[5]: 2773dbf06000-2773dbfff000 rwxp 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.472 error by controller[5]: 2773dbf05000-2773dbf06000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.472 error by controller[5]: 2773dbf00000-2773dbf05000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.472 error by controller[5]: 2773dbb00000-2773dbf00000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.472 error by controller[5]: 2773dba47000-2773dbb00000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.472 error by controller[5]: 2773dba06000-2773dba47000 rwxp 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.471 error by controller[5]: 2773dba05000-2773dba06000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.471 error by controller[5]: 2773dba00000-2773dba05000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.471 error by controller[5]: 2773db908000-2773dba00000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.471 error by controller[5]: 2773db906000-2773db908000 rwxp 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.471 error by controller[5]: 2773db905000-2773db906000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.471 error by controller[5]: 2773db900000-2773db905000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.470 error by controller[5]: 2773db808000-2773db900000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.470 error by controller[5]: 2773db806000-2773db808000 rwxp 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.470 error by controller[5]: 2773db805000-2773db806000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.470 error by controller[5]: 2773db800000-2773db805000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.470 error by controller[5]: 2773db708000-2773db800000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.470 error by controller[5]: 2773db706000-2773db708000 rwxp 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.469 error by controller[5]: 2773db705000-2773db706000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.469 error by controller[5]: 2773db700000-2773db705000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.469 error by controller[5]: 2773db650000-2773db700000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.469 error by controller[5]: 274141f00000-274142000000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.469 error by controller[5]: 265f38e00000-265f38f00000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.469 error by controller[5]: 255b8e700000-255b8e800000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.469 error by controller[5]: 247ba7f00000-247ba8000000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.468 error by controller[5]: 2474f4d80000-2474f4d9a000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.468 error by controller[5]: 2474f4d60000-2474f4d80000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.468 error by controller[5]: 2474f4d5a000-2474f4d60000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.468 error by controller[5]: 202ead600000-202ead700000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.468 error by controller[5]: 1fa8b5400000-1fa8b5500000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.467 error by controller[5]: 1efa5ee00000-1efa5ef00000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.467 error by controller[5]: 1d0bd7700000-1d0bd7800000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.467 error by controller[5]: 1c700f000000-1c700f100000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.467 error by controller[5]: 14ee90d00000-14ee90e00000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.467 error by controller[5]: 12e98d500000-12e98d600000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.467 error by controller[5]: 1075e4500000-1075e4600000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.466 error by controller[5]: 104776900000-104776a00000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.466 error by controller[5]: f015c100000-f015c200000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.466 error by controller[5]: ef127200000-ef127300000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.466 error by controller[5]: cbd89600000-cbd89700000 –-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.466 error by controller[5]: 857b0500000-857b0600000 rw-p 00000000 00:00 0
                        ! Caught 2017-12-22 20:39:32.466 error by controller[5]: 6faf8900000-6faf8a00000 rw-p 00000000 00:00 0
                        • hg6806H Offline
                          hg6806H Offline
                          hg6806
                          #771
                          Moin!
                          Erst einmal vielen Dank für den Adapter.
                          Habe zwei IR Köpfe an einem Raspi angeschlossen, auf dem auch ioBroker läuft und hat auf Anhieb funktioniert.
                          Wie weit kann man nun mit dem Abfrageintervall runter?
                          Hatte über Nacht 60 Sek., gab keine Fehler, und Prozessorlast ist normal.
                          Sind 5 Sek. noch ok? Hätte gerne recht aktuelle Werte. Installiert sind zwei Instanzen 1.0.0
                          Viele Grüße
                            #772
                            Aus Sicht des Adapters geht auch 0 Sekunden ;-)) Versuchs doch …
                            • J Offline
                              jhg
                              #773
                              ich habe auch eine Frage zu diesem Adapter:
                              Nach Umzug meiner Installation von Raspi 2 mit Jessie auf Raspi3 mit Stretch werden keine Daten mehr vom Lesekopf empfangen.
                              Auf der Konsole werden auch keine entsprechenden Daten gezeigt.
                              Der Lesekopf hat über mehrere Monate verlässlich Daten geliefert. Ein Defekt scheint ausgeschlossen.
                              Hat jemand hierzu eine Idee?
                              • wendy2702W Online
                                wendy2702W Online
                                #774
                                Das kann viele Ursachen haben.
                                Serialport installiert?
                                Wird der lesekopf vom Pi erkannt und hast du das richtige Device im Adapter eingestellt?
                                Logfile mit Fehlermeldung vorhanden?
                                Gruß und guten Rutsch
                                  #775
                                  @jhg:
                                  Nach Umzug meiner Installation von Raspi 2 mit Jessie auf Raspi3 mit Stretch `
                                  gleiche Frage wie im anderen Thread hier:
                                  wie hast du den Umzug gemacht?
                                  • J Offline
                                    jhg
                                    #776
                                    Umzug wurde per Script durchgeführt.
                                    Alles gezippt auf ein NAS und von dort zurückkopiert.
                                    Hat bisher auch immer problemlos funktioniert, habe ich schon einige Male getestet.
                                    Natürlich noch nie in Verbindung mit einem Hardwareumzug und gleichzeitiger Änderung des OS.
                                    Habe jetzt den Adapter nochmal installiert.
                                    Nun erhalte ich die Fehlermeldung:
                                    smartmeter.0 2017-12-31 20:40:10.376 error No or too long answer from Serial Device after last request.
                                    Und wenn ich per ssh verbunden bin:
                                    cat /dev/ttyUSB0 | od -tx1
                                    cat: /dev/ttyUSB0: Datei oder Verzeichnis nicht gefunden
                                    0000000
                                    Es ist ein Lesekopf von Volkszähler.org.
                                    Das sieht mir nach einem Anfängerfehler in der Bedienung aus, aber ich komm nicht drauf. :-(
                                    Danke für eure Hilfe.
                                    • wendy2702W Online
                                      wendy2702W Online
                                      #777
                                      Ist das den überhaupt ttyUSB0 ?
                                      Mal mit DMESG prüfen
                                        #778
                                        @jhg:
                                        Alles gezippt auf ein NAS und von dort zurückkopiert. `
                                        Hast du wegen der anderen OS-Version ein reinstall ausgeführt.
                                        ggf. muss der serialport neu kompiliert werden.
                                        rainer
                                          #779
                                          @wendy2702:
                                          Mal mit DMESG prüfen `
                                          Das wäre auch meine Frage zusammen mit der von Homoran.
                                          Serialport wird kompiliert, also reicht ein kopieren von files ggf nicht aus. Ggf Adapter neu installieren.
                                          Aber vor allem: wenn das os selbst sagt das ein device nicht vorhanden ist Sinn kann man davon erst recht nicht lesen.
                                          Also Finde erst einmal raus wie das device vom lesekopf im System heißt.
