  4. [gelöst] X/Y Koordinaten eines Bildes in VIS abhängig einer CCU Variable
    6.0k
91 Beiträge 13 Kommentatoren 17.8k Aufrufe 8 Beobachtet
  • P Pistus
    @chka Wenn ich Dein Skript in Skripte speicher, wird die Protokolldatei mit Warnungen vollgeschrieben.
    2024-04-20 10:42:00.023 - warn: javascript.0 (19119) You are assigning a string to the state "javascript.0.Sonnenstand.Elevation" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
    2024-04-20 10:42:00.026 - warn: javascript.0 (19119) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1819:20)
    2024-04-20 10:42:00.027 - warn: javascript.0 (19119) at Object.Sonnenstand_berechnen (script.js.Sonnenstand.Sonnenstand:48:5)
    2024-04-20 10:42:00.027 - warn: javascript.0 (19119) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1620:34)
    2024-04-20 10:42:00.027 - warn: javascript.0 (19119) at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
    2024-04-20 10:42:00.028 - warn: javascript.0 (19119) at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
    2024-04-20 10:42:00.028 - warn: javascript.0 (19119) at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
    2024-04-20 10:42:00.028 - warn: javascript.0 (19119) at listOnTimeout (node:internal/timers:569:17)
    2024-04-20 10:42:00.029 - warn: javascript.0 (19119) at processTimers (node:internal/timers:512:7)
    2024-04-20 10:42:00.044 - info: javascript.0 (19119) State value to set for "javascript.0.Sonnenstand.Elevation" has to be type "number" but received type "string"
    chka
    @pistus bei MIR ist javascript.0.Sonnenstand.Elevation eine number bei DIR ein string.
    das hat nichts mit speichern zu tun, sondern es läuft was erste Mal durch!
    INTEL NUC BOXNUC6I3SYH i3-6100U - Proxmox
    Speicher: Transcend MTS800 M.2 SSD 128GB SATA III, MLC
    RAM: 40Gig Crucial 8GB DDR4 CT2K8G4SFS824A + 32GB DDR4CT32G4SFD8266
    P 1 Antwort Letzte Antwort
    • C chka
      Pistus
      schrieb am zuletzt editiert von Pistus
      @chka Die Daten für Azimuth und Elevation kommen doch aus der Systemkonfiguration.
      Bei diesem Skript für den Sonnenstand gibt es keine Fehlermeldung und Warnungen.
      const suncalc = require('suncalc2');
      const result = getObject('system.config');
      const lat = result.common.latitude;
      const long = result.common.longitude;
      //const result = getObject("system.adapter.javascript.0");
      //const lat = result.native.latitude;
      //const long = result.native.longitude;
      const idEle = 'Sonnenstand.Elevation';
      const idAzi = 'Sonnenstand.Azimuth';
      createState(idEle, 0, {type: 'number', unit: '°'});
      createState(idAzi, 0, {type: 'number', unit: '°'});
      function Sonnenstand_berechnen () {
          var now = new Date();
          var sunpos = suncalc.getPosition(now, lat, long);
          var h = sunpos.altitude * 180 / Math.PI;
          var a = sunpos.azimuth * 180 / Math.PI + 180;
          setState(idEle, Math.round(10 * h) / 10, true);
          //setState(idAzi, Math.round(a), true);
          setState(idAzi, Math.round(Math.round(10 * a) / 10), true);
      schedule("* * * * *", Sonnenstand_berechnen);
      Hier wird aber im Skript der Typ number programmiert
      C 1 Antwort Letzte Antwort
      • P Pistus
        chka
        @pistus dies script läuft bei mir seit jahren
        /* System Sonnenstand
        Sonne Azimut und Elevation in Variablen schreiben
        erstellt: 06.07.2015 nach ioBroker Forum http://forum.iobroker.net/viewtopic.php?f=21&t=975&sid=6f0ba055de5f82eed6809424f49ca93b#p7635
        var suncalc = require('suncalc'),
            result = getObject("system.adapter.javascript.0"),
            lat = result.native.latitude,
        createState('Sonnenstand.Elevation', 0, {unit: '°'});
        createState('Sonnenstand.Azimut', 0, {unit: '°'});
        createState('Sonnenstand.X', 0, {unit: 'px'});
        createState('Sonnenstand.Y', 0, {unit: 'px'});
        createState('Sonnenstand.HTML');
        //Hier die Koordinaten einstellen
        var Xm = 500; //500
        var Ym = 250; // 250
        var rot = 90; // Winkel in dem Grundriss gegenüber Nord verdreht ist
        var r  = 250;
            //log("-----------------------------------------------");
           // log("latitude : " + result.native.latitude,'info');
           // log("longitude: " + result.native.longitude,'info');
           // log("sunpos: " + sunpos,'info');
            var h = sunpos.altitude * 180 / Math.PI,
            Formel: https://www-user.tu-chemnitz.de/~heha/viewchm.php/hs/SelfDXD.chm/directxgraphics/theorie/dg_ber.html
            radWinkel:= 40 / 180 * Pi;            // radWinkel = 0.698131...
            x_koordinate:= cos( radWinkel ) * 5;  // x_koordinate = 3,830222...
            y_koordinate:= sin( radWinkel ) * 5;  // y_koordinate = 3,213938...
            var azimuth = a.toFixed();//sunpos.azimuth;
            var radWinkel =( azimuth -90 - rot )/ 180 * Math.PI;
            var x = (Math.cos(radWinkel)* r)+Xm;
            var y = (Math.sin(radWinkel) * r)+Ym;
            setState("javascript.0.Sonnenstand.Elevation",h.toFixed(1));
            setState("javascript.0.Sonnenstand.Azimut",a.toFixed());
            setState("javascript.0.Sonnenstand.X",x.toFixed());
            setState("javascript.0.Sonnenstand.Y",y.toFixed());
          setState("javascript.0.Sonnenstand.HTML",'<img src="/vis/img/10_sun.png" height="50" width="50" style="float: left; margin: '+ y.toFixed() +'px 0px 0px '+x.toFixed()+'px;" >');
           // setState("javascript.0.Sonnenstand.HTML",'<img src="/vis/img/Weather-Sun-icon.png" height="50" width="50" vspace="'+ y.toFixed() +'" hspace="'+x.toFixed()+'">');
        schedule("*/1 * * * *", Sonnenstand_berechnen);
        Sonnenstand_berechnen(); // bei Scriptstart
        mehr kann ich dazu nicht sagen
        • C chka
          erstellt: 06.07.2015 nach ioBroker Forum http://forum.iobroker.net/viewtopic.php?f=21&amp;t=975&amp;sid=6f0ba055de5f82eed6809424f49ca93b#p7635
          var Xm = 500; //500
          var r  = 250;
          Pistus
          @chka Deshalb habe ich ja versucht Dein Skript bei mir zu installieren.
          Ich muss passen, weil ich einfach nicht weiter komme.
          • P Pistus
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            @pistus sagte in [gelöst] X/Y Koordinaten eines Bildes in VIS abhängig einer CCU Variable:
            Ein Skript wird nicht installiert sondern im JavaSkriptAdapter angelegt.
            Zusätzlich dann folgendes beachten:
            https://forum.iobroker.net/topic/5190/gelöst-x-y-koordinaten-eines-bildes-in-vis-abhängig-einer-ccu-variable/12
            Lehrling seit 1975 !!!
            • DJMarc75D DJMarc75
              Pistus
              @djmarc75 Das Skript wurde im JavaSkriptAdapter angelegt.
              in Vis muss das Widget basic string genommen werden und und als QuellID javascript.0.Sonnenstand.HTML.
              Im Widget steht aber eine hm Id. Ich habe aber kein hm.
              • P Pistus
                chka
                @pistus dann ignoriere die id einfach was steht denn beid dir in der
                <img src="/vis/img/10_sun.png" height="50" width="50" style="float: left; margin: 125px 0px 0px 717px;" >
                • C chka
                  Pistus
                  @chka
                  <img src="/vis-2.0/main/10_sun.png" height="100" width="100" style="float: left; margin: 156px 0px 0px 732px;">
                  Edit: Die URL ist
                  http://192.168.178.64:8082/vis-2/?main#Sonnenstand
                  • P Pistus
                    @chka
                    Edit: Die URL ist
                    chka
                    @pistus wenn der wert sich jetzt ändert dann passt das doch.
                    Dein Problem ist jetzt das es in vis2 nicht angezeigt wird?
                    • C chka
                      Pistus
                      @chka Die Sonne wird angezeigt, ändert aber nicht Ihre Position. Dazu kommen die unzähligen Warnmeldungen in der Protokolldatei.
                      • P Pistus
                        HomoranH Offline
                        HomoranH Offline
                        liegen an dem falschen Datentyp deines Datenpunktes.
                        Zeig doch bitte mal die Objektdaten davon.
                          Pistus
                          • P Pistus
                            HomoranH Offline
                            HomoranH Offline
                            @pistus
                            • Expertenmodus an
                            • dann rechts auf den dann erscheinenden Bleistift
                            • Reiter Objektdaten
                            • den Inhalt hier in code-tags posten.
                              @pistus
                              • Expertenmodus an
                              Pistus
                                "common": {
                                  "unit": "°",
                                  "name": "Sonnenstand.Azimut",
                                  "role": "state",
                                  "type": "mixed"
                                "native": {
                                  "unit": "°",
                                  "role": "state",
                                  "type": "mixed"
                                "type": "state",
                                "from": "system.adapter.javascript.0",
                                "user": "system.user.admin",
                                "ts": 1713353051011,
                                "_id": "javascript.0.Sonnenstand.Azimut",
                                "acl": {
                                  "object": 1636,
                                  "state": 1636,
                                  "owner": "system.user.admin",
                                "common": {
                                  "type": "number",
                                  "unit": "°",
                                  "name": "Sonnenstand.Elevation",
                                  "role": "state"
                                "native": {
                                  "type": "number",
                                  "unit": "°",
                                  "role": "state"
                                "type": "state",
                                "ts": 1711981079388,
                                "_id": "javascript.0.Sonnenstand.Elevation",
                                "acl": {
                                  "object": 1636,
                                  "state": 1636,
                                "common": {
                                  "name": "Sonnenstand.HTML",
                                  "role": "state",
                                  "type": "mixed"
                                "native": {},
                                "type": "state",
                                "ts": 1713353051014,
                                "_id": "javascript.0.Sonnenstand.HTML",
                                "acl": {
                                  "object": 1636,
                                  "state": 1636,
                              • P Pistus
                                  "common": {
                                    "unit": "°",
                                    "role": "state",
                                    "type": "mixed"
                                  "native": {
                                    "unit": "°",
                                    "role": "state",
                                    "type": "mixed"
                                  "type": "state",
                                  "acl": {
                                    "object": 1636,
                                    "state": 1636,
                                  "common": {
                                    "type": "number",
                                    "unit": "°",
                                    "role": "state"
                                  "native": {
                                    "type": "number",
                                    "unit": "°",
                                    "role": "state"
                                  "type": "state",
                                  "acl": {
                                    "object": 1636,
                                    "state": 1636,
                                  "common": {
                                    "role": "state",
                                    "type": "mixed"
                                  "native": {},
                                  "type": "state",
                                  "acl": {
                                    "object": 1636,
                                    "state": 1636,
                                HomoranH Offline
                                HomoranH Offline
                                @pistus Danke!
                                Azimut ist mixed, Elevation ist Number.
                                Und genau dort kommt doch die Meldung
                                2024-04-17 16:11:00.043 - info: javascript.0 (19119) State value to set for "javascript.0.Sonnenstand.Elevation" has to be type "number" but received type "string
                                Das Script scheint da einen String hineinzuschreiben
                                @chka sagte in [gelöst] X/Y Koordinaten eines Bildes in VIS abhängig einer CCU Variable:
                                ich kann kein Javascript, aber das dürfte einen String ergeben
                                  @pistus Danke!
                                  chka
                                  einfach alles auf mixed und gut so wird es normalerweise auch angelegt
                                  • C chka
                                    Pistus
                                    @chka Was muss ich im Skript ändern?
                                    • P Pistus
                                      HomoranH Offline
                                      HomoranH Offline
                                      ich kann kein Javascript, aber eine Wandlung in Zahl, sollte helfen.
                                      Oder am anderen Ende angreifen und
                                      (wobei ich gar nicht weiss ob es mixed offiziell überhaupt noch gibt)
                                        Pistus
                                        @homoran Schau bitte mal hier
                                        link text
                                        C HomoranH 2 Antworten Letzte Antwort
                                        • P Pistus
                                          link text
                                          chka
                                          @pistus änder doch bitte einfach das objet in den type mixed oder number
