  4. IOBroker hängt sich nach Crash und Neuinstallation oft auf
118 Beiträge 8 Kommentatoren 17.7k Aufrufe 5 Beobachtet
  • G Greenhorn
    Sorry, hatte Probleme mich über den PC einzuloggen. Hier der iob diag:
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer
              Kernel: Linux 6.1.0-rpi8-rpi-v8
        Architecture: arm64
    Model		: Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     19:02:17 up 2 days, 22:26,  4 users,  load average: 0.39, 0.38, 0.27
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Tue 2024-04-16 19:02:17 CEST
               Universal time: Tue 2024-04-16 17:02:17 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    simon
    /home/simon
    simon adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal: 	tty
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:            4.0G        3.0G        727M         14M        329M        962M
    Swap:           104M         99M        5.0M
    Total:          4.1G        3.1G        732M
             3793 M total memory
             2875 M used memory
             2443 M active memory
              508 M inactive memory
              693 M free memory
               35 M buffer memory
              279 M swap cache
               99 M total swap
               95 M used swap
                4 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
      UNIT                               LOAD   ACTIVE SUB    DESCRIPTION
    * NetworkManager-wait-online.service loaded failed failed Network Manager Wait Online
    1 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.3M  379M   1% /run
    /dev/mmcblk0p2 ext4      117G  6.8G  104G   7% /
    tmpfs          tmpfs     1.9G  148K  1.9G   1% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   74M  437M  15% /boot/firmware
    tmpfs          tmpfs     380M   36K  380M   1% /run/user/1000
    [Sat Apr 13 20:35:23 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:0F:E4:E2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=ccc359c3-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
    [Sat Apr 13 20:35:26 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat Apr 13 20:35:28 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET               SOURCE         FSTYPE      OPTIONS
    /                    /dev/mmcblk0p2 ext4        rw,noatime,commit=600
    |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    852M	/var/
    362M	/var/log/journal/8ec53d3bc1c549d5b36274323c1b8255
    362M	/var/log
    195M	/var/lib
    Archived and active journals take up 361.3M in the file system.
    /opt/iobroker/backups:
    13M	/opt/iobroker/backups/
    60K	/opt/iobroker/backups/tmpJavis0
    4.0K	/opt/iobroker/backups/tmpJavis0/states
    /opt/iobroker/iobroker-data:
    413M	/opt/iobroker/iobroker-data/
    175M	/opt/iobroker/iobroker-data/files
    57M	/opt/iobroker/iobroker-data/files/javascript.admin
    48M	/opt/iobroker/iobroker-data/backup-objects
    38M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    183M	/opt/iobroker/iobroker-data/objects.jsonl
    22M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
    7.2M	/opt/iobroker/iobroker-data/states.jsonl
    7.0M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4d856ba1ab6ed1196ded60ea8669f5d-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.19.1
    /usr/bin/node 		v18.19.1
    /usr/bin/npm 		10.2.4
    /usr/bin/npx 		10.2.4
    /usr/bin/corepack 	0.22.0
    nodejs:
      Installed: 18.19.1-1nodesource1
      Candidate: 18.20.2-1nodesource1
      Version table:
         18.20.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.20.1-1nodesource1 1001
         18.20.0-1nodesource1 1001
     *** 18.19.1-1nodesource1 1001
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	5.0.19
    admin: 		6.13.16
    javascript: 	7.8.0
    Adapters from github: 	0
    Adapter State
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
    + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
    + system.adapter.iwg-vpn.0                : iwg-vpn               : iobroker                                 -  enabled
      system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
      system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
      system.adapter.link.0                   : link                  : iobroker                                 - disabled
    + system.adapter.midea.0                  : midea                 : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.96
      system.adapter.odl.0                    : odl                   : iobroker                                 -  enabled
    + system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4d856ba1ab6ed1196ded60ea8669f5d-if00-port0
      system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "backitup"     : 2.11.0   , installed 2.10.11 [Updatable]
    Adapter    "discovery"    : 4.4.0    , installed 4.4.0
    Adapter    "hmip"         : 1.22.0   , installed 1.22.0
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "iwg-vpn"      : 3.0.0    , installed 3.0.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "link"         : 0.5.12   , installed 0.5.12
    Adapter    "midea"        : 0.0.7    , installed 0.0.7
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "odl"          : 3.0.1    , installed 3.0.1
    Adapter    "reolink"      : 1.0.3    , installed 1.0.3
    Adapter    "shelly"       : 6.8.0    , installed 6.6.1  [Updatable]
    Adapter    "socketio"     : 6.6.1    , installed 6.6.0  [Updatable]
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-hqwidgets": 1.5.1    , installed 1.4.0  [Updatable]
    Adapter    "web"          : 6.2.5    , installed 6.2.3  [Updatable]
    Adapter    "ws"           : 2.5.11   , installed 2.5.10 [Updatable]
    Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
    Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.4 [Updatable]
    Objects and States
    ^[[CObjects: 	4246
    States: 	1
    ^[[CHit:1 http://deb.debian.org/debian bookworm InRelease
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 80
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1303626    11435/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1303619    11435/iobroker.js-c
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          952339     8870/cupsd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16750      802/sshd: /usr/sbin
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          952338     8870/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          16752      802/sshd: /usr/sbin
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          950376     8871/cups-browsed
    udp        0      0 0.0.0.0:33770           0.0.0.0:*                           104        16466      555/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        16464      555/avahi-daemon: r
    udp6       0      0 :::53891                :::*                                104        16467      555/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        16465      555/avahi-daemon: r
    2024-04-16 19:20:49.401  - info: host.iobroker Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
    2024-04-16 19:20:49.402  - info: host.iobroker hostname: iobroker, node: v18.19.1
    2024-04-16 19:20:49.403  - info: host.iobroker ip addresses: 192.168.178.96 fe80::894:7c1f:7703:754a 192.168.178.116 fe80::faf9:9eff:7542:7f35
    2024-04-16 19:21:03.677  - info: host.iobroker connected to Objects and States
    2024-04-16 19:21:03.736  - info: host.iobroker added notifications configuration of host
    2024-04-16 19:21:04.600  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeCurrent"
    2024-04-16 19:21:04.601  - info: host.iobroker 20 instances found
    2024-04-16 19:21:04.650  - info: host.iobroker starting 14 instances
    2024-04-16 19:21:04.779  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewest"
    2024-04-16 19:21:04.798  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewestNext"
    2024-04-16 19:21:04.863  - info: host.iobroker instance system.adapter.admin.0 started with pid 12229
    2024-04-16 19:21:04.900  - info: host.iobroker Delete state "system.host.iobroker.versions.npmCurrent"
    2024-04-16 19:21:04.964  - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewest"
    2024-04-16 19:21:05.025  - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewestNext"
    2024-04-16 19:21:05.095  - info: host.iobroker Some obsolete host states deleted.
    2024-04-16 19:21:08.175  - error: admin.0 (12229) admin.0 already running
    2024-04-16 19:21:08.181  - warn: admin.0 (12229) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-16 19:21:08.821  - info: host.iobroker instance system.adapter.backitup.0 started with pid 12250
    2024-04-16 19:21:08.875  - error: host.iobroker instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-16 19:21:08.876  - info: host.iobroker Restart adapter system.adapter.admin.0 because enabled
    2024-04-16 19:21:10.806  - error: backitup.0 (12250) backitup.0 already running
    2024-04-16 19:21:10.812  - warn: backitup.0 (12250) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-16 19:21:11.388  - error: host.iobroker instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-16 19:21:11.389  - info: host.iobroker Restart adapter system.adapter.backitup.0 because enabled
    2024-04-16 19:21:12.722  - info: host.iobroker instance system.adapter.hmip.0 started with pid 12261
    @greenhorn sagte in IOBroker hängt sich nach Crash und Neuinstallation oft auf:
    sudo systemctl set-default multi-host.target
    Hab ich so auch noch nicht gesehen:
    Objects and States
    ^[[CObjects: 	4246
    States: 	1
    1 State, aber 4246 objects? Merkwürdig.
    Pending OS-Updates: 80
    Pending iob updates: 7
    Update die Kiste. Akuter Update-Stau. Gilt auch für die iob-Adapter.
    • G Greenhorn
      Und hier noch das Summary:
      v.2023-10-10
      Icon name: computer
      Architecture: arm64
      Installation: native
      Kernel: aarch64
      Userland: arm64
      Timezone: Europe/Berlin (CEST, +0200)
      User-ID: 1000
      X-Server: false
      Nodejs-Installation: /usr/bin/nodejs v18.19.1
      /usr/bin/npm 10.2.4
      /usr/bin/npx 10.2.4
      Recommended versions are nodejs 18.20.2 and npm 10.5.0
      MEMORY:
      total used free shared buff/cache available
      Mem: 4.0G 2.9G 952M 14M 197M 1.0G
      Swap: 104M 104M 217K
      Total: 4.1G 3.1G 952M
      Active iob-Instances: 14
      ioBroker Core: js-controller 5.0.19
      admin 6.13.16
      ioBroker Status: iobroker is running on this host.
      Objects type: jsonl
      States type: jsonl
      • system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin
      • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects: 4246
      States: 1
      Size of iob-Database:
      236M /opt/iobroker/iobroker-data/objects.jsonl
      8.2M /opt/iobroker/iobroker-data/states.jsonl
      wendy2702W Online
      wendy2702W Online
      @greenhorn Pi 4 mit USB Stick und SSD ?
      Was für eine Stromversorgung?
      Mal eine zweite Session gestartet und dort mit
      top
      oder
      htop
      geschaut was passiert wenn du z.B. Jarvis startest?
      In der ersten Session mal Zeitgleich
       tail -f /opt/iobroker/log/iobroker.current.log
      laufen lassen und schauen was da im log kommt.
      Vielleicht gehen dir auch deine 4GB Speicher einfach aus je nachdem wie Aufwendig dein Jarvis und Javascript ist.
      G 3 Antworten Letzte Antwort
      • wendy2702W wendy2702
        top
        oder
        htop
        Greenhorn
        @wendy2702
        PI4, 4GB Ram mit SD-Karte, original Raspi Netzteil...
        G wendy2702W 2 Antworten Letzte Antwort
        • G Greenhorn
          @wendy2702
          Greenhorn
          @greenhorn
          Ram ist tastsächlich nicht mehr viel übrig: Gesamte RAM-Auslastung: 3162 Mb / Frei: 16% = 601 Mb [Server: iobroker - 15 Prozesse]
          • G Greenhorn
            @wendy2702
            wendy2702W Online
            wendy2702W Online
            SD Karte mit 128GB ?
            G 1 Antwort Letzte Antwort
              top
              oder
              htop
              Greenhorn
              @wendy2702
              Jarvis gestartet, iobroker hängt wieder :-(
              Hier mal das was htop bis dahin ausgespuckt hat:
              Last login: Tue Apr 16 19:35:02 on ttys001
              Linux iobroker 6.1.0-rpi8-rpi-v8 #1 SMP PREEMPT Debian 1:6.1.73-1+rpt1 (2024-01-25) aarch64
              permitted by applicable law.
              Last login: Tue Apr 16 19:01:52 2024 from fe80::18ad:f78b:e494:31be%eth0
              simon@iobroker:~ $ htop
                  0[||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||                     72.6%] Tasks: 82, 244 thr, 122 kthr; 4 running
                  1[|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||                          67.8%] Load average: 1.28 1.71 8.11
                  2[||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||                             65.3%] Uptime: 2 days, 23:02:49
                  3[||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||                           67.5%]
                Mem[|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||3.55G/3.70G]
                Swp[||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||95.8M/100.0M]
                [Main] [I/O]
                  PID USER       PRI  NI  VIRT   RES   SHR S  CPU%▽MEM%   TIME+  Command
                12537 iobroker    20   0  663M 52228 15120 S   0.0  1.3  0:00.00 io.iqontrol.0
                12538 iobroker    20   0  663M 52228 15120 S   0.0  1.3  0:00.00 io.iqontrol.0
                12539 iobroker    20   0  980M  127M 20796 S   0.0  3.4  0:00.03 io.zigbee.0
                12540 iobroker    20   0  980M  127M 20796 S   0.0  3.4  0:00.03 io.zigbee.0
                12541 iobroker    20   0  980M  127M 20796 S   0.0  3.4  0:00.02 io.zigbee.0
                12542 iobroker    20   0  980M  127M 20796 S   0.0  3.4  0:00.02 io.zigbee.0
                12557 iobroker    20   0  795M 55824 16632 S   0.0  1.4  0:00.00 io.midea.0
                12558 iobroker    20   0  795M 55824 16632 S   0.0  1.4  0:00.20 io.midea.0
                12559 iobroker    20   0  795M 55824 16632 S   0.0  1.4  0:00.31 io.midea.0
                12560 iobroker    20   0  795M 55824 16632 S   0.0  1.4  0:00.30 io.midea.0
                12561 iobroker    20   0  795M 55824 16632 S   0.0  1.4  0:00.29 io.midea.0
                12562 iobroker    20   0  795M 55824 16632 S   0.0  1.4  0:00.00 io.midea.0
                12564 iobroker    20   0  795M 55824 16632 S   0.0  1.4  0:00.01 io.midea.0
                12565 iobroker    20   0  795M 55824 16632 S   0.0  1.4  0:00.00 io.midea.0
                12566 iobroker    20   0  795M 55824 16632 S   0.0  1.4  0:00.00 io.midea.0
                12567 iobroker    20   0  795M 55824 16632 S   0.0  1.4  0:00.00 io.midea.0
                12569 iobroker    20   0  731M 62180 21880 S   0.0  1.6  0:00.00 io.web.0
                12570 iobroker    20   0  731M 62180 21880 S   0.0  1.6  0:00.18 io.web.0
                12571 iobroker    20   0  731M 62180 21880 S   0.0  1.6  0:00.25 io.web.0
                12572 iobroker    20   0  731M 62180 21880 S   0.0  1.6  0:00.24 io.web.0
                12573 iobroker    20   0  731M 62180 21880 S   0.0  1.6  0:00.20 io.web.0
                12574 iobroker    20   0  731M 62180 21880 S   0.0  1.6  0:00.00 io.web.0
                12581 iobroker    20   0  659M 48600 17456 S   0.0  1.3  0:00.00 io.reolink.0
                12582 iobroker    20   0  659M 48600 17456 S   0.0  1.3  0:00.08 io.reolink.0
                12583 iobroker    20   0  659M 48600 17456 S   0.0  1.3  0:00.23 io.reolink.0
                12584 iobroker    20   0  659M 48600 17456 S   0.0  1.3  0:00.15 io.reolink.0
                12585 iobroker    20   0  659M 48600 17456 S   0.0  1.3  0:00.19 io.reolink.0
                12586 iobroker    20   0  659M 48600 17456 S   0.0  1.3  0:00.00 io.reolink.0
                12588 iobroker    20   0  660M 49728 19656 S   0.0  1.3  0:00.00 io.iwg-vpn.0
                12589 iobroker    20   0  660M 49728 19656 S   0.0  1.3  0:00.19 io.iwg-vpn.0
                12590 iobroker    20   0  660M 49728 19656 S   0.0  1.3  0:00.17 io.iwg-vpn.0
                12591 iobroker    20   0  660M 49728 19656 S   0.0  1.3  0:00.10 io.iwg-vpn.0
                12592 iobroker    20   0  660M 49728 19656 S   0.0  1.3  0:00.11 io.iwg-vpn.0
                12593 iobroker    20   0  660M 49728 19656 S   0.0  1.3  0:00.00 io.iwg-vpn.0
                12594 iobroker    20   0  731M 62180 21880 S   0.0  1.6  0:00.00 io.web.0
                12595 iobroker    20   0  731M 62180 21880 S   0.0  1.6  0:00.00 io.web.0
                12596 iobroker    20   0  731M 62180 21880 S   0.0  1.6  0:00.00 io.web.0
                12597 iobroker    20   0  731M 62180 21880 S   0.0  1.6  0:00.00 io.web.0
                12598 iobroker    20   0  659M 48600 17456 S   0.0  1.3  0:00.00 io.reolink.0
                12599 iobroker    20   0  659M 48600 17456 S   0.0  1.3  0:00.00 io.reolink.0
                12600 iobroker    20   0  659M 48600 17456 S   0.0  1.3  0:00.00 io.reolink.0
                12601 iobroker    20   0  659M 48600 17456 S   0.0  1.3  0:00.00 io.reolink.0
                12602 iobroker    20   0  660M 49728 19656 S   0.0  1.3  0:00.00 io.iwg-vpn.0
                12603 iobroker    20   0  660M 49728 19656 S   0.0  1.3  0:00.00 io.iwg-vpn.0
                12604 iobroker    20   0  660M 49728 19656 S   0.0  1.3  0:00.00 io.iwg-vpn.0
                12605 iobroker    20   0  660M 49728 19656 S   0.0  1.3  0:00.00 io.iwg-vpn.0
                12799 root        20   0 19468  9192  7632 S   0.0  0.2  0:00.05 sshd: simon [priv]
                12808 simon       20   0 19728  6512  4688 S   0.5  0.2  0:00.29 sshd: simon@pts/1
                12809 simon       20   0  8104  4616  3012 S   0.0  0.1  0:00.07 -bash
                12826 iobroker    20   0 1238M  621M 38696 S   0.0 16.4  0:00.00 /usr/bin/node /opt/iobroker/node_modules/iobroker.jarvis/jarvis.js 0 info
                12831 iobroker    20   0 1238M  621M 38696 S   0.0 16.4  0:00.00 /usr/bin/node /opt/iobroker/node_modules/iobroker.jarvis/jarvis.js 0 info
                12832 iobroker    20   0 1238M  621M 38696 S   0.0 16.4  0:00.00 /usr/bin/node /opt/iobroker/node_modules/iobroker.jarvis/jarvis.js 0 info
                12833 iobroker    20   0 1238M  621M 38696 S   0.0 16.4  0:00.00 /usr/bin/node /opt/iobroker/node_modules/iobroker.jarvis/jarvis.js 0 info
                12834 iobroker    20   0 1238M  621M 38696 S   0.0 16.4  0:00.00 /usr/bin/node /opt/iobroker/node_modules/iobroker.jarvis/jarvis.js 0 info
                12835 iobroker    20   0 1238M  621M 38696 S   0.0 16.4  0:00.00 /usr/bin/node /opt/iobroker/node_modules/iobroker.jarvis/jarvis.js 0 info
              F1Help  F2Setup F3SearchF4FilterF5Tree  F6SortByF7Nice -F8Nice +F9Kill  F10Quit
                Greenhorn
                @wendy2702 ja...
                • G Offline
                  Greenhorn
                  Mist, jetzt bleibt wohl wieder nur Stecker ziehen...
                  wendy2702W Thomas BraunT 2 Antworten Letzte Antwort
                  • G Greenhorn
                    @wendy2702
                      [Main] [I/O]
                    wendy2702W Online
                    wendy2702W Online
                    Ich vermute dir geht der Speicher aus.
                    Stoppe mal zum testen alles ausser die zwingend notwendigen Instanzen und starte dann mal Jarvis
                    Ideal wäre für einen solchen fall ein Monitor und Tastatur am Pi
                    • G Greenhorn
                      wendy2702W Online
                      wendy2702W Online
                      Warte mal... eventuell rechnet der auch gerade nur wie verrückt
                      • G Greenhorn
                        NEIN! Zieh NIE, NIE, NIE einfach den Stecker.
                        Lass die Kiste rechnen oder schieß die wenn alle Stricke reißen sollten per Magic SysReq sauber ab.
                        G 2 Antworten Letzte Antwort
                          Greenhorn
                          @wendy2702
                          Monitor und Tastatur sind vorhanden...
                          Was wären die zwingend notwendigen Instanzen ? Skripte laufen momentan eh nicht, der Rest ist alles "unwichtig"
                            Greenhorn
                            OK, wie geht Magic SysReq ?
                            • G Greenhorn
                              @wendy2702
                              wendy2702W Online
                              wendy2702W Online
                              Admin und WEB wenn ich mich richtig erinnere
                              • G Greenhorn
                                @greenhorn
                                https://wiki.ubuntuusers.de/Magic_SysRQ/
                                Und hast du die Hausaufgaben wie 'System auf eine stabile Basis aktualisieren' schon erledigt?
                                  @greenhorn
                                  Greenhorn
                                  @thomas-braun Nein, Raspi hängt ja gerade...
                                    Greenhorn
                                    Versucht mit echo b | sudo tee /proc/sysrq-trigger , bekomme aber nichts rein, Raspi hängt...
                                    • G Greenhorn
                                      @greenhorn
                                      Soweit ich weiß ist SysReq beim Rpi ab Werk aktiv. Da kannst du direkt per
                                      Alt Druck und REISUB neustarten. Oder wie auch immer die Kombi auf deiner Tastatur genau ist. Gibt da ja durchaus unter Umständen Abweichungen.
                                        @greenhorn
                                        Greenhorn
                                        Jetzt wirds schwierig: Arbeite am Mac
                                        • G Greenhorn
                                          Das ganze funktioniert eh nur richtig mit einer physisch angeschlossenen Tastatur.
