  4. nach Update nicht mehr erreichbar
15 Beiträge 3 Kommentatoren 1.5k Aufrufe 3 Beobachtet
  • P Peguschwein
    Copy text starting here:
                            v.2023-10-10
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Kernel:                 aarch64
    Userland:               armhf
    Timezone:               Europe/Zurich (CEST, +0200)
    User-ID:                1000
    X-Server:               true
    Pending OS-Updates:     1
    sudo: unable to execute /usr/local/bin/node: No such file or directory
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.20.2
    /home/iobroker/.diag.sh: line 487: /usr/local/bin/node: No such file or directory
                            /usr/local/bin/node
                            /usr/local/bin/npm              10.5.0
                            /usr/local/bin/npx              10.5.0
                            /usr/local/bin/corepack         0.25.2
    Recommended versions are nodejs  and npm
    *** nodejs is NOT correctly installed ***
    Wrong installation path detected. This needs to be fixed.
    Please check
    https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
    for more information on how to fix these errors.
    MEMORY:
    Mem:            3.8G        269M        2.7G         35M        813M        3.4G
    Swap:            99M          0B         99M
    Total:          3.9G        269M        2.8G
    Active iob-Instances:   0
    ioBroker Core:          js-controller
                            admin
    ioBroker Status:
    Objects:                0
    States:                 0
    Size of iob-Database:
    26M     /opt/iobroker/iobroker-data/objects.jsonl
    20M     /opt/iobroker/iobroker-data/states.jsonl
    === Mark text until here for copying ===
    CodierknechtC Offline
    Codierknecht
    @peguschwein
    1. Desktop abschalten
    2. Das ist das summary und nicht die Langfassung
    HmIP|ZigBee|Tasmota|Unifi
    Zabbix Certified Specialist
    • P Peguschwein
                              v.2023-10-10
               Icon name: computer
            Architecture: arm64
      Kernel:                 aarch64
      Userland:               armhf
      User-ID:                1000
      X-Server:               true
                              /usr/local/bin/node
      Please check
      MEMORY:
      Swap:            99M          0B         99M
                              admin
      ioBroker Status:
      Objects:                0
      States:                 0
      @peguschwein
      Die Langfassung
      Aber nodejs haste schon 'irgendwie' reingekloppt...
      Wo kommt ihr eigentlich immer auf diesen schrägen Mumpitz?
      iob nodejs-update
      ausführen.
      P 2 Antworten Letzte Antwort
        @peguschwein
        Die Langfassung
        iob nodejs-update
        ausführen.
        Peguschwein
        nodejs:
        Installed: 18.20.2-1nodesource1
        Candidate: 18.20.2-1nodesource1
        Version table:
        *** 18.20.2-1nodesource1 600
        500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
        18.20.1-1nodesource1 600
        18.20.0-1nodesource1 600
        18.19.1-1nodesource1 600
        18.19.0-1nodesource1 600
        18.18.2-1nodesource1 600
        18.18.1-1nodesource1 600
        18.18.0-1nodesource1 600
        18.17.1-1nodesource1 600
        18.17.0-1nodesource1 600
        18.16.1-1nodesource1 600
        18.16.0-1nodesource1 600
        18.15.0-1nodesource1 600
        18.14.2-1nodesource1 600
        18.14.1-1nodesource1 600
        18.14.0-1nodesource1 600
        18.13.0-1nodesource1 600
        18.12.0-1nodesource1 600
        18.11.0-1nodesource1 600
        18.10.0-1nodesource1 600
        18.9.1-1nodesource1 600
        18.9.0-1nodesource1 600
        18.8.0-1nodesource1 600
        18.7.0-1nodesource1 600
        18.6.0-1nodesource1 600
        18.5.0-1nodesource1 600
        18.4.0-1nodesource1 600
        18.3.0-1nodesource1 600
        18.2.0-1nodesource1 600
        18.1.0-1nodesource1 600
        18.0.0-1nodesource1 600
        12.22.12~dfsg-1~deb11u4 500
        Nothing to do - Your installation is using the correct paths.
        Nothing to do - Your version is the recommended one.
        You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands.
        Please DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation!
          @peguschwein
          Die Langfassung
          iob nodejs-update
          ausführen.
          Peguschwein
          Jetzt komme ich wider ins admin. Das Vis läuft noch nicht mal weitersehen
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
          Model           : Raspberry Pi 4 Model B Rev 1.2
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : armhf
          Systemuptime and Load:
           23:04:01 up 7 min,  3 users,  load average: 1.57, 1.25, 0.69
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Wed 2024-04-10 23:04:02 CEST
                     Universal time: Wed 2024-04-10 21:04:02 UTC
                           RTC time: n/a
                          Time zone: Europe/Zurich (CEST, +0200)
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       true
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            3.8G        960M        1.6G         35M        1.2G        2.7G
          Swap:            99M          0B         99M
          Total:          3.9G        960M        1.7G
                   3794 M total memory
                    961 M used memory
                   1249 M active memory
                    705 M inactive memory
                   1644 M free memory
                     66 M buffer memory
                   1122 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          /dev/root      ext4       59G   15G   42G  27% /
          devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
          tmpfs          tmpfs     759M  1.2M  758M   1% /run
          /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
          tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
          [Wed Apr 10 22:56:15 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:7E:42:FA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e1ebcabe-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
          [Wed Apr 10 22:56:16 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Wed Apr 10 22:56:16 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Wed Apr 10 22:56:18 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          TARGET  SOURCE         FSTYPE OPTIONS
          /       /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          3.9G    /var/
          2.6G    /var/log
          1.8G    /var/log/journal/23473c6d808b4036aec27aa37939623a
          992M    /var/cache
          Archived and active journals take up 1.7G in the file system.
          /opt/iobroker/backups:
          134M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          3.7G    /opt/iobroker/iobroker-data/
          3.2G    /opt/iobroker/iobroker-data/history
          318M    /opt/iobroker/iobroker-data/files
          86M     /opt/iobroker/iobroker-data/backup-objects
          76M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
          22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
          22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
          8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js
          USB-Devices by-id:
          find: '/dev/serial/by-id/': No such file or directory
          *** NodeJS-Installation ***
          /usr/bin/node           v18.20.2
          /usr/bin/npm            10.5.0
          /usr/bin/npx            10.5.0
          /usr/bin/corepack       0.25.2
          nodejs:
            Version table:
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.19
          admin:          6.13.16
          javascript:     7.8.0
          Adapters from github:   0
          Adapter State
            system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
            system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
            system.adapter.device-reminder.0        : device-reminder       : raspberrypi                              -  enabled
            system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
            system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              -  enabled
            system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
            system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
            system.adapter.fusionsolar.0            : fusionsolar           : raspberrypi                              -  enabled
            system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              -  enabled
            system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              -  enabled
            system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
            system.adapter.modbus.0                 : modbus                : raspberrypi                              - disabled
            system.adapter.modbus.1                 : modbus                : raspberrypi                              -  enabled
            system.adapter.node-red.0               : node-red              : raspberrypi                              - disabled, port: 1880, bind: 0.0.0.0
            system.adapter.octoprint.0              : octoprint             : raspberrypi                              - disabled
            system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
            system.adapter.sun2000-modbus.0         : sun2000-modbus        : raspberrypi                              - disabled, port: 502
            system.adapter.sun2000.0                : sun2000               : raspberrypi                              -  enabled, port: 502
            system.adapter.swiss-weather-api.0      : swiss-weather-api     : raspberrypi                              - disabled
            system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
            system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
            system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
            system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
            system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.13.16  , installed 6.13.16
          Adapter    "backitup"     : 2.10.11  , installed 2.10.11
          Adapter    "discovery"    : 4.4.0    , installed 4.4.0
          Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
          Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
          Adapter    "javascript"   : 7.8.0    , installed 7.8.0
          Controller "js-controller": 5.0.19   , installed 5.0.19
          Adapter    "modbus"       : 6.1.0    , installed 6.1.0
          Adapter    "node-red"     : 5.2.0    , installed 5.2.0
          Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
          Adapter    "sun2000-modbus": 0.0.2   , installed 0.1.3
          Adapter    "swiss-weather-api": 2.1.0, installed 2.1.0
          Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
          Objects and States
          Objects:        13503
          States:         12373
          Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:3 https://repos.influxdata.com/debian stable InRelease
          Hit:4 https://repos.influxdata.com/debian bullseye InRelease
          Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
          Hit:6 https://packages.grafana.com/oss/deb stable InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15363      537/cupsd
          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       29773      3250/node-red
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1796       559/sshd: /usr/sbin
          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      117        16751      804/influxd
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       21648      1527/iobroker.js-co
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       19678      1527/iobroker.js-co
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       21719      1598/io.admin.0
          tcp6       0      0 :::8086                 :::*                    LISTEN      117        19098      804/influxd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          1806       559/sshd: /usr/sbin
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15362      537/cupsd
          tcp6       0      0 :::3000                 :::*                    LISTEN      116        21643      1526/grafana
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1639       402/avahi-daemon: r
          udp        0      0 0.0.0.0:46974           0.0.0.0:*                           108        1641       402/avahi-daemon: r
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15376      595/cups-browsed
          udp6       0      0 :::5353                 :::*                                108        1640       402/avahi-daemon: r
          udp6       0      0 :::56709                :::*                                108        1642       402/avahi-daemon: r
          udp6       0      0 fe80::84a1:1516:ba6:546 :::*                                0          15573      416/NetworkManager
          2024-04-10 23:05:13.156  - info: host.raspberrypi iobroker install email@1.2.2 using installedFrom
          2024-04-10 23:05:15.640  - info: node-red.0 (3217) starting. Version 5.2.0 in /opt/iobroker/node_modules/iobroker.node-red, node: v18.20.2, js-controller: 5.0.19
          2024-04-10 23:05:18.063  - info: node-red.0 (3217) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
          2024-04-10 23:05:18.072  - info: node-red.0 (3217) Node-RED started successfully (PID: 3250)
          2024-04-10 23:05:19.212  - info: admin.0 (1598) ==> Connected system.user.admin from ::ffff:192.168.0.43
          2024-04-10 23:05:20.625  - info: node-red.0 (3217) Node-RED: 10 Apr 23:05:20 - [info]
          Willkommen bei Node-RED
          2024-04-10 23:05:20.628  - info: node-red.0 (3217) Node-RED: 10 Apr 23:05:20 - [info] Node-RED Version: v3.1.8
          2024-04-10 23:05:20.630  - info: node-red.0 (3217) Node-RED: 10 Apr 23:05:20 - [info] Node.js  Version: v18.20.2
          10 Apr 23:05:20 - [info] Linux 6.1.21-v8+ arm LE
          2024-04-10 23:05:20.881  - info: host.raspberrypi iobroker npm-install: NPM version: 10.5.0Installing iobroker.email@1.2.2... (System call)
          2024-04-10 23:05:22.633  - info: node-red.0 (3217) Node-RED: 10 Apr 23:05:22 - [info] Paletten-Nodes werden geladen
          2024-04-10 23:05:30.884  - info: node-red.0 (3217) Node-RED: 10 Apr 23:05:30 - [info] Dashboard version 3.6.1 started at /ui
          2024-04-10 23:05:32.530  - info: node-red.0 (3217) Node-RED: 10 Apr 23:05:32 - [info] Polymer started at /polymer
          2024-04-10 23:05:34.176  - info: node-red.0 (3217) Node-RED: 10 Apr 23:05:34 - [info] Einstellungsdatei: /opt/iobroker/iobroker-data/node-red/settings.js
          2024-04-10 23:05:34.184  - info: node-red.0 (3217) Node-RED: 10 Apr 23:05:34 - [info] Kontextspeicher: default [module=localfilesystem]
          2024-04-10 23:05:34.260  - info: node-red.0 (3217) Node-RED: 10 Apr 23:05:34 - [info] Benutzerverzeichnis: /opt/iobroker/iobroker-data/node-red/
          2024-04-10 23:05:34.262  - warn: node-red.0 (3217) Node-RED: 10 Apr 23:05:34 - [warn] Projekte deaktiviert: editorTheme.projects.enabled=false
          2024-04-10 23:05:34.271  - info: node-red.0 (3217) Node-RED: 10 Apr 23:05:34 - [info] Flow-Datei: /opt/iobroker/iobroker-data/node-red/flows.json
          2024-04-10 23:05:34.330  - info: node-red.0 (3217) Node-RED: 10 Apr 23:05:34 - [info] Server wird jetzt auf http://127.0.0.1:1880/ ausgeführt
          2024-04-10 23:05:34.526  - info: node-red.0 (3217) Node-RED: 10 Apr 23:05:34 - [info] Flows werden gestartet
          2024-04-10 23:05:34.631  - info: node-red.0 (3217) Node-RED: 10 Apr 23:05:34 - [info] Flows sind gestartet
          CodierknechtC Thomas BraunT 2 Antworten Letzte Antwort
          • P Peguschwein
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
            Docker          : false
            Kernel          : aarch64
            Userland        : armhf
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server:       true
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:            99M          0B         99M
                     3794 M total memory
                      961 M used memory
                     1644 M free memory
                       66 M buffer memory
                     1122 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            3.9G    /var/
            2.6G    /var/log
            992M    /var/cache
            USB-Devices by-id:
            /usr/bin/npm            10.5.0
            /usr/bin/npx            10.5.0
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.13.16
            javascript:     7.8.0
            Adapter State
            + instance is alive
            Objects and States
            Objects:        13503
            States:         12373
            Pending Updates: 0
            Codierknecht
            @peguschwein
            X-Server:       true
            Den solltest Du noch abschalten.
            Desktop hat auf 'nem Server nix zu suchen. Macht mehr Ärger als Nutzen.
            P 1 Antwort Letzte Antwort
            • CodierknechtC Codierknecht
              @peguschwein
              X-Server:       true
              Peguschwein
              @codierknecht Wo finde ich das wieder ? Das ist kein Installiertes Adapter oder ? Sorry bin noch greenhorn oder schon zu alt für das
              • P Peguschwein
                Codierknecht
                @peguschwein
                sudo systemctl set-default multi-user.target
                sudo reboot
                • P Peguschwein
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : armhf
                  CPU threads: 4
                  Current issues:
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  /home/pi
                  X-Server:       true
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:            99M          0B         99M
                           3794 M total memory
                            961 M used memory
                           1644 M free memory
                             66 M buffer memory
                           1122 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /var:
                  3.9G    /var/
                  2.6G    /var/log
                  992M    /var/cache
                  USB-Devices by-id:
                  /usr/bin/npm            10.5.0
                  /usr/bin/npx            10.5.0
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.13.16
                  javascript:     7.8.0
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        13503
                  States:         12373
                  Pending Updates: 0
                  @peguschwein
                  Bei nächster Gelegenheit das System NEU als reine 64Bit-Installation aufsetzen.
                  Vis läuft ja auch nicht.
                  iob start vis
                  Schmeiß die stable-Quelle für influx raus. bullseye ist oldstable.
                    @peguschwein
                    iob start vis
                    Peguschwein
                    Jetzt läuft es wieder. Puls ist runter gegangen. Es waren noch nicht alle Adapter gestartet
                    PI5 legt schon da. Warte aber noch etwas ab bis VIS2 stable ist bzw 1-2 Adapter fehlen mir noch
                    Danke euch viel viel mals
                    • P Peguschwein
                      @peguschwein sagte in nach Update nicht mehr erreichbar:
                      Magst du noch verraten wie du zu der windschiefen nodejs-Installation gekommen bist?
                        Peguschwein
                        @thomas-braun Das würde ich dir gerne verraten. Aber so ganz nachvollziehen kann ich es nicht mehr. Ich habe doktor google gefragt aber je mehr ich gegogelt hab je älter waren die Treads. Und geschrieben wird viel. Aber eines kann ich sagen etwas ist schief gelaufen und ich bin super glücklich das alles wieder läuft. PV Überschusssteuerung usw.
                        In Zukunft solllte ein "sudo udate" und ein "sudo upgrade" reichen.
                        Also nochmals vielen Dank ich denke ich sollte ab in die Kiste in ein paar Stunden klingelts es wieder
                        gruss Peguschwein alias Rene
                        • P Peguschwein
                          Warum bekommt man eigentlich auf diese Frage nie eine konkrete Antwort?
                          Bin ich immer wieder drüber erstaunt.
                          Die Befehle lauten
                          sudo apt update
                          sudo apt upgrade
