  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Worx Adapter läuft nicht mehr
    2.8k
    4.9k
    4.1k
22 Beiträge 5 Kommentatoren 1.5k Aufrufe 6 Beobachtet
  • R RaWa
    @mcm57
    OK, update auf die aktuelle Version:
    2024-03-25 17:51:55.830 - info: host.IOBrokerPC iobroker host.IOBrokerPC Adapter "system.adapter.worx.0" is started
    2024-03-25 17:51:55.834 - info: host.IOBrokerPC "system.adapter.worx.0" enabled
    2024-03-25 17:51:55.886 - info: host.IOBrokerPC instance system.adapter.worx.0 started with pid 9496
    2024-03-25 17:51:56.625 - error: host.IOBrokerPC Caught by controller[0]: node:internal/modules/cjs/loader:1338
    2024-03-25 17:51:56.625 - error: host.IOBrokerPC Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
    2024-03-25 17:51:56.625 - error: host.IOBrokerPC Caught by controller[0]: ^
    2024-03-25 17:51:56.625 - error: host.IOBrokerPC Caught by controller[0]: Error: Das angegebene Modul wurde nicht gefunden.
    2024-03-25 17:51:56.625 - error: host.IOBrokerPC Caught by controller[0]: \\?\C:\ioBroker\node_modules\aws-crt\dist\bin\win32-x64-cruntime\aws-crt-nodejs.node
    2024-03-25 17:51:56.625 - error: host.IOBrokerPC Caught by controller[0]: at Module._extensions..node (node:internal/modules/cjs/loader:1338:18)
    2024-03-25 17:51:56.625 - error: host.IOBrokerPC Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1117:32)
    2024-03-25 17:51:56.625 - error: host.IOBrokerPC Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:958:12)
    2024-03-25 17:51:56.625 - error: host.IOBrokerPC Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1141:19)
    2024-03-25 17:51:56.625 - error: host.IOBrokerPC Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
    2024-03-25 17:51:56.625 - error: host.IOBrokerPC Caught by controller[0]: at Object. (C:\ioBroker\node_modules\aws-crt\dist\native\binding.js:104:19)
    2024-03-25 17:51:56.625 - error: host.IOBrokerPC Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1254:14)
    2024-03-25 17:51:56.625 - error: host.IOBrokerPC Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
    2024-03-25 17:51:56.625 - error: host.IOBrokerPC Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:958:12) {
    2024-03-25 17:51:56.625 - error: host.IOBrokerPC Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
    2024-03-25 17:51:56.625 - error: host.IOBrokerPC Caught by controller[0]: }
    2024-03-25 17:51:56.625 - error: host.IOBrokerPC Caught by controller[0]: Node.js v18.15.0
    2024-03-25 17:51:56.625 - error: host.IOBrokerPC instance system.adapter.worx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-03-25 17:51:56.625 - info: host.IOBrokerPC Restart adapter system.adapter.worx.0 because enabled
    2024-03-25 17:51:56.903 - info: host.IOBrokerPC iobroker exit 0
    Viele Grüße
    @rawa sagte in Worx Adapter läuft nicht mehr:
    Node.js v18.15.0
    Bring das auf einen aktuellen Stand. Und den Rest vom System auch. Mit alten Versionen kannst du gar nix sagen.
    • R RaWa
      nachdem ich meinen Mähroboter aus dem Winterschlaf geweckt habe, läuft der Adapter nicht mehr: "Keine Verbindung zum Host". Die Worx APP läuft, der Mäher natürlich auch. ID und Passwort sind richtig, viel mehr kann man nicht einstellen.
      Was mach ich falsch bzw. wie kann ich die Fehlersuche angehen ?
      Version 2.3.4 (Gleiches Problem mit der Github version)
      IOBroker Version: 6.12.0
      Läuft auf einem PC.
      Viele Grüße
      Lucky_ESA
      @rawa Ich antworte dir mal hier statt auf Github.
      Die gute Nachricht ist, dass der Adapter unter windows läuft. Die schlechte ist, dass du leider ein schlecht aktualisiertes System hast. Auch Linux User haben diese Fehlermeldung node_modules\aws-crt\dist\bin... Hier reicht meist ein iob fix...Sollte das System zu alt sein muss immer erst die Node und dann der JS-Controller aktualisiert werden. Das aws-crt Package gehört zu aws-iot-device-sdk-v2 was mir von Worx vorgegeben wird. Wir hatten auch aws-iot-device-sdk versucht, aber Worx trennt dann alle 15 Minuten die Verbindung. Daher kann ich nicht mehr zurück...
      Leider kenne ich mich mit Windows nicht aus aber vielleicht kann @sigi234 sagen, ob es ein iob fix für Windows gibt. Wenn nein, dann bleibt dir nur das:
      1. Worx unter Adapter deinstallieren (nicht nur unter Instanz)
      2. Volles Backup erstellen
      3. ioBroker deinstallieren
      4. iobroker neu installieren
      5. Worx installieren
      6. Backup aufspielen
      Gruß//Lucky
      sigi234S R 2 Antworten Letzte Antwort
      • L Lucky_ESA
        Gruß//Lucky
        sigi234S Online
        sigi234S Online
        @lucky_esa sagte in Worx Adapter läuft nicht mehr:
        Ja
        https://forum.iobroker.net/topic/63610/test-iobroker-unter-windows-installieren-2023-edition
        Zitat:
        Ist ioBroker erst einmal installiert, kann der Installer für folgende Aktionen verwendet werden:
        • Aktualisieren von Node.js auf die aktuell empfohlene Version
        • Ausführen des ioBroker Fixers
        • Löschen oder Anlegen von Regeln für die Windows Firewall, damit ioBroker auch von außen erreicht werden kann
        • Festlegen, ob ioBroker beim Start von Windows automatisch gestartet wird.
          Dafür installiert sich der Installer selbst und ist im Windows-Startmenü unter "ioBroker automation platform" - "ioBroker Setup" zu finden.
        Noch ein Hinweis :
        Der JS-Controller muss derzeit noch manuell upgedatet werden!
        R 1 Antwort Letzte Antwort
        • L Lucky_ESA
          Gruß//Lucky
          RaWa
          @lucky_esa Vielen Dank! Ich mach mich mal dran.
          • sigi234S sigi234
            Ja
            Noch ein Hinweis :
            RaWa
            @sigi234 Danke dir. Mal gespannt ob ich es hinbekomme.
            Schöne Ostern!
            • R RaWa
              Schöne Ostern!
              RaWa
              schrieb am zuletzt editiert von RaWa
              @Lucky_ESA so, ich denke ich habe alles erledigt (hoffentlich)
              Dummerweise läuft der worx adapter immer noch nicht.
              host.IOBrokerPC
              2024-04-01 16:50:02.175	info	Restart adapter system.adapter.worx.0 because enabled
              host.IOBrokerPC
              2024-04-01 16:50:02.175	error	instance system.adapter.worx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.IOBrokerPC
              2024-04-01 16:50:02.175	error	Caught by controller[0]: Node.js v18.20.0
              host.IOBrokerPC
              host.IOBrokerPC
              2024-04-01 16:50:02.175	error	Caught by controller[0]: }
              host.IOBrokerPC
              2024-04-01 16:50:02.175	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
              host.IOBrokerPC
              2024-04-01 16:50:02.175	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12) {
              host.IOBrokerPC
              2024-04-01 16:50:02.175	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
              host.IOBrokerPC
              2024-04-01 16:50:02.175	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
              host.IOBrokerPC
              2024-04-01 16:50:02.175	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
              host.IOBrokerPC
              2024-04-01 16:50:02.175	error	Caught by controller[0]: at Object.<anonymous> (C:\ioBroker\node_modules\aws-crt\dist\native\binding.js:104:19)
              host.IOBrokerPC
              2024-04-01 16:50:02.175	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
              host.IOBrokerPC
              2024-04-01 16:50:02.175	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
              host.IOBrokerPC
              host.IOBrokerPC
              host.IOBrokerPC
              2024-04-01 16:50:02.175	error	Caught by controller[0]: at Module._extensions..node (node:internal/modules/cjs/loader:1460:18)
              host.IOBrokerPC
              2024-04-01 16:50:02.175	error	Caught by controller[0]: \\?\C:\ioBroker\node_modules\aws-crt\dist\bin\win32-x64-cruntime\aws-crt-nodejs.node
              host.IOBrokerPC
              2024-04-01 16:50:02.175	error	Caught by controller[0]: Error: Das angegebene Modul wurde nicht gefunden.
              host.IOBrokerPC
              host.IOBrokerPC
              2024-04-01 16:50:02.175	error	Caught by controller[0]: ^
              host.IOBrokerPC
              2024-04-01 16:50:02.174	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
              host.IOBrokerPC
              2024-04-01 16:50:02.174	error	Caught by controller[0]: node:internal/modules/cjs/loader:1460
              host.IOBrokerPC
              2024-04-01 16:50:01.521	info	instance system.adapter.worx.0 started with pid 5088
              Windows 10
              Node.js: v18.20.0
              js controller 5.0.19
              worx Version 2.3.4
              hab ich was falsch gemacht bzw. vergessen ?
              Viele Grüße
              L 2 Antworten Letzte Antwort
              • R RaWa
                host.IOBrokerPC
                host.IOBrokerPC
                host.IOBrokerPC
                host.IOBrokerPC
                host.IOBrokerPC
                host.IOBrokerPC
                host.IOBrokerPC
                host.IOBrokerPC
                host.IOBrokerPC
                host.IOBrokerPC
                host.IOBrokerPC
                host.IOBrokerPC
                host.IOBrokerPC
                host.IOBrokerPC
                host.IOBrokerPC
                host.IOBrokerPC
                host.IOBrokerPC
                host.IOBrokerPC
                host.IOBrokerPC
                host.IOBrokerPC
                host.IOBrokerPC
                host.IOBrokerPC
                host.IOBrokerPC
                Windows 10
                Node.js: v18.20.0
                worx Version 2.3.4
                Viele Grüße
                Lucky_ESA
                @rawa Hast du den iob fix ausgeführt?
                • R RaWa
                  host.IOBrokerPC
                  host.IOBrokerPC
                  host.IOBrokerPC
                  host.IOBrokerPC
                  host.IOBrokerPC
                  host.IOBrokerPC
                  host.IOBrokerPC
                  host.IOBrokerPC
                  host.IOBrokerPC
                  host.IOBrokerPC
                  host.IOBrokerPC
                  host.IOBrokerPC
                  host.IOBrokerPC
                  host.IOBrokerPC
                  host.IOBrokerPC
                  host.IOBrokerPC
                  host.IOBrokerPC
                  host.IOBrokerPC
                  host.IOBrokerPC
                  host.IOBrokerPC
                  host.IOBrokerPC
                  host.IOBrokerPC
                  host.IOBrokerPC
                  Windows 10
                  Node.js: v18.20.0
                  worx Version 2.3.4
                  Viele Grüße
                  Lucky_ESA
                  schrieb am zuletzt editiert von Lucky_ESA
                  @rawa Habe heute mal versucht auf Windows 11 diesen Fehler zu simulieren. Egal was ich versucht habe um so eine Schiefe installation hinzubekommen, habe ich es einfach nicht geschafft. Der Adapter wird sauber installiert und funktioniert einwandfrei. Aus purer Verzweifelung habe ich dann die aws-crt-nodejs.node gelöscht. Das zeigt mit zumindest ein ähnliches Fehlerbild an.
                  Schau mal bitte ob du diesen Ordner hast.
                  Wenn nein, bis wohin kommst du? Wenn ja, dann entzippe den Anhang (aws-crt-nodejs.node) und lade diese Datei in den Ordner C:\ioBroker\node_modules\aws-crt\dist\bin\win32-x64-cruntime\
                  Der Adapter kann nun mit diesem Fehler umgehen und verwendet dann die alte Verbindung. Muss das morgen noch testen und dann lade ich es auf GIT hoch. Dann musst du von GIT installieren. Du musst aber vorher unter Adapter die Instanz deinstallieren.
                  aws-crt-nodejs.zip
                  Vision User dürfen auf keinen Fall derzeit von GIT laden. @hsteinme und ich implementieren derzeit komplett den Vision und Kress. Es werden sonst ungewünschte Datenpunkte erstellt.
                  Gruß//Lucky
                  • L Lucky_ESA
                    RaWa
                    @lucky_esa ja, habe ich
                    L 1 Antwort Letzte Antwort
                    • R RaWa
                      Lucky_ESA
                      Dann versuche mal mein nächsten Post umzusetzen. Habe die alte Verbindung bereits auf GIT. Aber bitte erst die Datei mal bei dir einfügen und schauen ob es funktioniert.
                      Gruß//Lucky
                      • L Lucky_ESA
                        Gruß//Lucky
                        RaWa
                        @lucky_esa Worx Adapter deinstalliert, Pfad war vorhanden. IoBroker gestoppt.
                        aws-crt-nodejs.node in .bak umbenannt, deine Datei entzipt und in das Verzeichnis kopiert. Worx installiert - gleiches Ergebnis, leider. Keine Verbindung mit Host.
                        host.IOBrokerPC
                        2024-04-03 22:22:37.321	info	Restart adapter system.adapter.worx.0 because enabled
                        host.IOBrokerPC
                        2024-04-03 22:22:37.321	error	instance system.adapter.worx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        host.IOBrokerPC
                        2024-04-03 22:22:37.321	error	Caught by controller[0]: Node.js v18.20.0
                        host.IOBrokerPC
                        host.IOBrokerPC
                        2024-04-03 22:22:37.321	error	Caught by controller[0]: }
                        host.IOBrokerPC
                        2024-04-03 22:22:37.321	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
                        host.IOBrokerPC
                        2024-04-03 22:22:37.321	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12) {
                        host.IOBrokerPC
                        2024-04-03 22:22:37.321	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
                        host.IOBrokerPC
                        2024-04-03 22:22:37.321	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                        host.IOBrokerPC
                        2024-04-03 22:22:37.321	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
                        host.IOBrokerPC
                        2024-04-03 22:22:37.321	error	Caught by controller[0]: at Object.<anonymous> (C:\ioBroker\node_modules\aws-crt\dist\native\binding.js:104:19)
                        host.IOBrokerPC
                        2024-04-03 22:22:37.320	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                        host.IOBrokerPC
                        2024-04-03 22:22:37.320	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
                        host.IOBrokerPC
                        2024-04-03 22:22:37.320	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
                        host.IOBrokerPC
                        2024-04-03 22:22:37.320	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
                        host.IOBrokerPC
                        2024-04-03 22:22:37.320	error	Caught by controller[0]: at Module._extensions..node (node:internal/modules/cjs/loader:1460:18)
                        host.IOBrokerPC
                        2024-04-03 22:22:37.320	error	Caught by controller[0]: \\?\C:\ioBroker\node_modules\aws-crt\dist\bin\win32-x64-cruntime\aws-crt-nodejs.node
                        host.IOBrokerPC
                        2024-04-03 22:22:37.320	error	Caught by controller[0]: Error: Das angegebene Modul wurde nicht gefunden.
                        host.IOBrokerPC
                        host.IOBrokerPC
                        2024-04-03 22:22:37.320	error	Caught by controller[0]: ^
                        host.IOBrokerPC
                        2024-04-03 22:22:37.320	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
                        host.IOBrokerPC
                        2024-04-03 22:22:37.320	error	Caught by controller[0]: node:internal/modules/cjs/loader:1460
                        host.IOBrokerPC
                        2024-04-03 22:22:35.757	info	instance system.adapter.worx.0 started with pid 6488
                        modbus.0
                        8396	2024-04-03 22:22:08.806	warn	On error: {"errno":-4078,"code":"ECONNREFUSED","syscall":"connect","address":"127.0.0.1","port":502}
                        modbus.0
                        8396	2024-04-03 22:22:08.806	error	Client in error state.
                        modbus.0
                        8396	2024-04-03 22:22:08.806	error	Socket Error
                        • L Lucky_ESA
                          Gruß//Lucky
                          RaWa
                          @lucky_esa habe das Gleiche noch einmal versucht. Nach dem deinstallieren des Worx Adapters hört der Pfad hier auf: C:\ioBroker\node_modules
                          Adapter installiert, Pfad wieder kompeltt da, die Datei gegen deine getauscht, dann den Adapter eingerichtet - leider auch negativ
                          • R RaWa
                            Lucky_ESA
                            @rawa
                            Irgendwas stimmt mit deinem Sytem nicht.
                            Als Workaround kannst du vom Git laden aber das löst eigentlich dein Problem nicht. Wenn die Datei vorhanden ist aber nicht geladen werden kann, ist leider ein Problem wobei ich dir nicht helfen kann.
                            Gruß//Lucky
