  4. Iobroker Absturz bei Zigbeeadapter mit Conbee2 einschalten
55 Beiträge 7 Kommentatoren 8.3k Aufrufe 5 Beobachtet
  • N NFTVirus
    @thomas-braun und noch der Iobroker log:
    2024-04-02 08:29:06.663 - info: admin.0 (800) ==> Connected system.user.admin from ::ffff:192.168.178.91
    2024-04-02 13:25:45.374 - info: host.raspberrypi iobroker.js-controller version 5.0.19 js-controller starting
    2024-04-02 13:25:45.386 - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
    2024-04-02 13:25:45.387 - info: host.raspberrypi hostname: raspberrypi, node: v18.20.0
    2024-04-02 13:25:45.390 - info: host.raspberrypi ip addresses: 192.168.178.66 2001:9e8:af9f:500:ce7b:5d25:bfe2:ac05 fe80::6d01:3670:f9db:134d
    2024-04-02 13:25:47.899 - info: host.raspberrypi connected to Objects and States
    2024-04-02 13:25:47.972 - info: host.raspberrypi added notifications configuration of host
    2024-04-02 13:25:49.123 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeCurrent"
    2024-04-02 13:25:49.125 - info: host.raspberrypi 7 instances found
    2024-04-02 13:25:49.155 - info: host.raspberrypi starting 7 instances
    2024-04-02 13:25:49.252 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewest"
    2024-04-02 13:25:49.274 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewestNext"
    2024-04-02 13:25:49.341 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 733
    2024-04-02 13:25:49.360 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmCurrent"
    2024-04-02 13:25:49.419 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewest"
    2024-04-02 13:25:49.481 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewestNext"
    2024-04-02 13:25:49.539 - info: host.raspberrypi Some obsolete host states deleted.
    2024-04-02 13:25:53.226 - info: host.raspberrypi instance system.adapter.node-red.0 started with pid 744
    2024-04-02 13:25:53.659 - error: admin.0 (733) admin.0 already running
    2024-04-02 13:25:53.668 - warn: admin.0 (733) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-02 13:25:54.418 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-02 13:25:54.421 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
    2024-04-02 13:25:56.262 - error: node-red.0 (744) node-red.0 already running
    2024-04-02 13:25:56.269 - warn: node-red.0 (744) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-02 13:25:56.846 - error: host.raspberrypi instance system.adapter.node-red.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-02 13:25:56.848 - info: host.raspberrypi Restart adapter system.adapter.node-red.0 because enabled
    2024-04-02 13:25:57.208 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 755
    2024-04-02 13:25:59.984 - error: backitup.0 (755) backitup.0 already running
    2024-04-02 13:25:59.991 - warn: backitup.0 (755) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-02 13:26:00.581 - error: host.raspberrypi instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-02 13:26:00.582 - info: host.raspberrypi Restart adapter system.adapter.backitup.0 because enabled
    2024-04-02 13:26:01.205 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 768
    2024-04-02 13:26:05.220 - info: host.raspberrypi instance system.adapter.mqtt.0 started with pid 775
    2024-04-02 13:26:08.482 - error: mqtt.0 (775) mqtt.0 already running
    2024-04-02 13:26:08.491 - warn: mqtt.0 (775) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-02 13:26:09.103 - error: host.raspberrypi instance system.adapter.mqtt.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-02 13:26:09.105 - info: host.raspberrypi Restart adapter system.adapter.mqtt.0 because enabled
    2024-04-02 13:26:09.221 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 786
    2024-04-02 13:26:11.457 - info: zigbee.0 (768) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.0, js-controller: 5.0.19
    2024-04-02 13:26:11.672 - info: zigbee.0 (768) delete old Backup files. keep only last 10
    2024-04-02 13:26:11.676 - info: zigbee.0 (768) Starting Zigbee npm ...
    2024-04-02 13:26:12.398 - error: discovery.0 (786) discovery.0 already running
    2024-04-02 13:26:12.406 - warn: discovery.0 (786) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2024-04-02 13:26:12.474 - info: zigbee.0 (768) Installed Version: iobroker.zigbee@1.10.1
    2024-04-02 13:26:13.029 - error: host.raspberrypi instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2024-04-02 13:26:13.031 - info: host.raspberrypi Restart adapter system.adapter.discovery.0 because enabled
    2024-04-02 13:26:13.228 - info: host.raspberrypi instance system.adapter.wled.0 started with pid 809
    @nftvirus
    Das Dateisystem macht auch die Grätsche.
    Apr 02 13:17:03 raspberrypi systemd-fsck[276]: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
    Und wenn ich mich recht entsinne soll der ModemManager bei conbee auch ausgeschaltet werden.
    Apr 02 13:25:39 raspberrypi systemd[1]: Started ModemManager.service - Modem Manager.
    N 1 Antwort Letzte Antwort
      @nftvirus
      N Offline
      N Offline
      NFTVirus
      @thomas-braun Danke wegen dem Modem Manager wusste ich nicht habe ihn abgestellt. Wegen dem Dateisystem, kann ich da was machen um es zu fixen?
      • N NFTVirus
        @nftvirus sagte in Iobroker Absturz bei Zigbeeadapter mit Conbee2 einschalten:
        Neuinstallieren. Auf einem frischen Datenträger.
          N Offline
          N Offline
          NFTVirus
          schrieb am zuletzt editiert von NFTVirus
          @thomas-braun mh ok danke. Dann probiere ich das auch nochmal ist jetzt allerdings auch schon die 3. oder 4. Neuinstallation und die SD ist auch erst vor 2-3 Wochen aus der Packung gekommen und meine Hoffnung dass es die Probleme mit dem Stick löst sind auch begrenzt da diese von Anfang an bestanden.
          • N NFTVirus
            @nftvirus
            Machst du da auch immer eine frische Grundinstallation oder klatschst du da einen clone drauf? Die Kiste meldet nämlich auch eine Verschiebung der boot-Partition, das sollte bei einer ordentlichen Neuinstallation eigentlich nicht vorkommen.
              @nftvirus
              N Offline
              N Offline
              NFTVirus
              @thomas-braun habe jedes Mal komplett formatiert frisch Bookworm drauf gepackt und dann Iobroker komplett installiert. Keine Clone oder so. Kann natürlich sein das es jetzt durch das dauernde Neustarten der letzten Tage an denen ich versucht habe das Problem zu verstehen was zerschossen hat.
              • N NFTVirus
                @nftvirus
                Jedenfalls sieht diese Passage merkwürdig aus.
                Hab ich auf meinen Kisten noch nie gesehen.
                Apr 02 13:17:03 raspberrypi systemd-fsck[276]: fsck.fat 4.2 (2021-01-31)
                Apr 02 13:17:03 raspberrypi systemd-fsck[276]: There are differences between boot sector and its backup.
                Apr 02 13:17:03 raspberrypi systemd-fsck[276]: This is mostly harmless. Differences: (offset:original/backup)
                Apr 02 13:17:03 raspberrypi systemd-fsck[276]:   65:01/00
                Apr 02 13:17:03 raspberrypi systemd-fsck[276]:   Not automatically fixing this.
                Apr 02 13:17:03 raspberrypi systemd-fsck[276]:  Automatically removing dirty bit.
                Apr 02 13:17:03 raspberrypi systemd-fsck[276]: *** Filesystem was changed ***
                Apr 02 13:17:03 raspberrypi systemd-fsck[276]: Writing changes.
                Apr 02 13:17:03 raspberrypi systemd-fsck[276]: /dev/mmcblk0p1: 365 files, 31795/261115 clusters
                Apr 02 13:17:03 raspberrypi systemd[1]: Finished systemd-fsck@dev-disk-by\x2dpartuuid-42fe4a7c\x2d01.service - File System Check on /dev/disk/by-partuuid/42fe4a7c-01.
                Apr 02 13:17:03 raspberrypi systemd[1]: Mounting boot-firmware.mount - /boot/firmware...
                Apr 02 13:17:03 raspberrypi systemd[1]: Mounted boot-firmware.mount - /boot/firmware.
                  @nftvirus
                  N Offline
                  N Offline
                  NFTVirus
                  @thomas-braun Irgendwas läuft bei mir absolut schief. Versuche seit gestern alles neu zu installieren aber ich bekomme Iobroker einfach nicht installiert. Gestern habe ich nach etwa 4Stunden ohne Fortschritt an dieser Stelle:
                  #####) ⠴ reify:iobroker.admin: http fetch GET 200 https://registr
                  Abgebrochen und nochmal die Karte formatiert dann habe ich über Nacht laufen lassen und jetzt hängt er wieder an genau der selben Stelle.
                  • N NFTVirus
                    N Offline
                    N Offline
                    NFTVirus
                    @Thomas-Braun jetzt hat es beim 3. Versuch funktioniert. ich schaue dann man naclher ob ich den Zigbeeadapter irgendwie ans laufen bekomme.
                    • N NFTVirus
                      Mit dem RPi3 musst du Geduld haben...
                      Der ist nicht so flott.
                        N Offline
                        N Offline
                        NFTVirus
                        @thomas-braun hatte jetzt neue SD mit neuer Installation von Bookworm, dann Bookworm alle Updates gezogen und danach Iobroker installiert. Nichts weiter gemacht außer Zigbeeadapter installiert und direkt das selbe Spiel Iobrokerabsturz beim Einschalten des Adapters. Muss ich noch irgend etwas bei der nutzung vom Conbee 2 am Zigbee Adapter beachten? Vorher lief der Stick 2 Jahre am Deconz Adapter ohne Auffälligkeiten. I
                        • N NFTVirus
                          Eigentlich nicht. Der Stick liegt in /dev/serial/by-id herum?
                            N Offline
                            N Offline
                            NFTVirus
                            @thomas-braun ja liegt er habe ich gecheckt
                            • N NFTVirus
                              und im Log steht dazu was genau?
                                N Offline
                                N Offline
                                NFTVirus
                                @thomas-braun Kompletter Log siehe unten. Was jetzt gerade nach dem Absturz total komisch ist ist das der Zigbeeadapter komplett deinstalliert ist jetzt wo ich ihn neu gestartet habe.
                                2024-04-03 20:40:28.266 - info: admin.0 (697) ==> Connected system.user.admin from ::ffff:192.168.178.91
                                2024-04-03 20:40:28.510 - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                2024-04-03 20:42:56.674 - info: host.raspberrypi iobroker add zigbee --host raspberrypi
                                2024-04-03 20:43:02.528 - info: host.raspberrypi iobroker NPM version: 10.5.0
                                2024-04-03 20:43:02.533 - info: host.raspberrypi iobroker Installing iobroker.zigbee@1.10.1... (System call)
                                2024-04-03 20:43:28.959 - info: host.raspberrypi iobroker
                                2024-04-03 20:43:28.963 - info: host.raspberrypi iobroker added 21 packages in 25s60 packages are looking for funding run `npm fund` for details
                                2024-04-03 20:43:29.045 - info: host.raspberrypi iobroker host.raspberrypi install adapter zigbee
                                2024-04-03 20:43:29.184 - info: host.raspberrypi iobroker upload [327] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
                                2024-04-03 20:43:29.556 - info: host.raspberrypi iobroker upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad.png img/DIYRuZ_FreePad.png image/png
                                2024-04-03 20:43:30.172 - info: host.raspberrypi iobroker upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/bitron_motion.png img/bitron_motion.png image/png
                                2024-04-03 20:43:30.808 - info: host.raspberrypi iobroker upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hive.png img/hive.png image/png
                                2024-04-03 20:43:33.006 - info: host.raspberrypi iobroker upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lh_32Zb.png img/lh_32Zb.png image/png
                                2024-04-03 20:43:33.715 - info: host.raspberrypi iobroker upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_amaze.png img/philips_amaze.png image/png
                                2024-04-03 20:43:33.858 - info: host.raspberrypi iobroker upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_ambiance.png img/philips_hue_ambiance.png image/png
                                2024-04-03 20:43:34.045 - info: host.raspberrypi iobroker upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_e27_ambiance.png img/philips_hue_e27_ambiance.png image/png
                                2024-04-03 20:43:34.192 - info: host.raspberrypi iobroker upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_ltc021.png img/philips_hue_ltc021.png image/png
                                2024-04-03 20:43:34.331 - info: host.raspberrypi iobroker upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/plug.png img/plug.png image/png
                                2024-04-03 20:43:34.473 - info: host.raspberrypi iobroker upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_philipshue.png img/sensor_philipshue.png image/png
                                2024-04-03 20:43:34.619 - info: host.raspberrypi iobroker upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/smartthings_motion.png img/smartthings_motion.png image/png
                                2024-04-03 20:43:34.763 - info: host.raspberrypi iobroker upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ts0203.png img/ts0203.png image/png
                                2024-04-03 20:43:34.910 - info: host.raspberrypi iobroker upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_tyzs1l.png img/tuya_tyzs1l.png image/png
                                2024-04-03 20:43:34.930 - info: host.raspberrypi iobroker upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unavailable.png img/unavailable.png image/png
                                2024-04-03 20:43:34.948 - info: host.raspberrypi iobroker upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unknown.png img/unknown.png image/png
                                2024-04-03 20:43:34.966 - info: host.raspberrypi iobroker upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/wemo.png img/wemo.png image/png
                                2024-04-03 20:43:34.984 - info: host.raspberrypi iobroker upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_plug_eu.png img/xiaomi_plug_eu.png image/png
                                2024-04-03 20:43:35.003 - info: host.raspberrypi iobroker upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_wireless_switch.png img/xiaomi_wireless_switch.png image/png
                                2024-04-03 20:43:35.021 - info: host.raspberrypi iobroker upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27.png img/zbt_e27.png image/png
                                2024-04-03 20:43:35.041 - info: host.raspberrypi iobroker upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27_rgbw.png img/zbt_e27_rgbw.png image/png
                                2024-04-03 20:43:35.060 - info: host.raspberrypi iobroker upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_led_panel.png img/zbt_led_panel.png image/png
                                2024-04-03 20:43:35.078 - info: host.raspberrypi iobroker upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_smart_switch.png img/zbt_smart_switch.png image/png
                                2024-04-03 20:43:35.097 - info: host.raspberrypi iobroker upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zemismart_sw2.png img/zemismart_sw2.png image/png
                                2024-04-03 20:43:35.115 - info: host.raspberrypi iobroker upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index.html index.html text/html
                                2024-04-03 20:43:35.135 - info: host.raspberrypi iobroker upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index_m.html index_m.html text/html
                                2024-04-03 20:43:35.156 - info: host.raspberrypi iobroker upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/moment.min.js moment.min.js application/javascript
                                2024-04-03 20:43:35.175 - info: host.raspberrypi iobroker upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/shuffle.min.js shuffle.min.js application/javascript
                                2024-04-03 20:43:35.193 - info: host.raspberrypi iobroker upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/tab_m.html tab_m.html text/html
                                2024-04-03 20:43:35.212 - info: host.raspberrypi iobroker upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.css vis-network.min.css text/css
                                2024-04-03 20:43:35.233 - info: host.raspberrypi iobroker upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.js vis-network.min.js application/javascript
                                2024-04-03 20:43:35.261 - info: host.raspberrypi iobroker upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/words.js words.js application/javascript
                                2024-04-03 20:43:35.281 - info: host.raspberrypi iobroker upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.png zigbee.png image/png
                                2024-04-03 20:43:35.302 - info: host.raspberrypi iobroker upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.svg zigbee.svg image/svg+xml
                                2024-04-03 20:43:35.408 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee created/updated
                                2024-04-03 20:43:35.491 - info: host.raspberrypi iobroker host.raspberrypi create instance zigbee
                                2024-04-03 20:43:35.508 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.alive created
                                2024-04-03 20:43:35.520 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.connected created
                                2024-04-03 20:43:35.533 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.compactMode created
                                2024-04-03 20:43:35.545 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.cpu created
                                2024-04-03 20:43:35.560 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.cputime created
                                2024-04-03 20:43:35.572 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.memHeapUsed created
                                2024-04-03 20:43:35.586 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.memHeapTotal created
                                2024-04-03 20:43:35.599 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.memRss created
                                2024-04-03 20:43:35.611 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.uptime created
                                2024-04-03 20:43:35.623 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.inputCount created
                                2024-04-03 20:43:35.636 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.outputCount created
                                2024-04-03 20:43:35.648 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.eventLoopLag created
                                2024-04-03 20:43:35.661 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.sigKill created
                                2024-04-03 20:43:35.674 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.logLevel created
                                2024-04-03 20:43:35.686 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.0.exclude created
                                2024-04-03 20:43:35.698 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.0.exclude.all created
                                2024-04-03 20:43:35.709 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.0.info created
                                2024-04-03 20:43:35.720 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.0.info.connection created
                                2024-04-03 20:43:35.730 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.0.info.pairingMode created
                                2024-04-03 20:43:35.743 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.0.info.pairingCountdown created
                                2024-04-03 20:43:35.755 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.0.info.pairingMessage created
                                2024-04-03 20:43:35.765 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.0.info.groups created
                                2024-04-03 20:43:35.777 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.0.info.undefinedDevices created
                                2024-04-03 20:43:35.789 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.0.info.debugmessages created
                                2024-04-03 20:43:35.799 - info: host.raspberrypi iobroker host.raspberrypi Set default value of zigbee.0.exclude.all: []
                                2024-04-03 20:43:35.809 - info: host.raspberrypi iobroker host.raspberrypi Set default value of zigbee.0.info.connection: false
                                2024-04-03 20:43:35.826 - info: host.raspberrypi iobroker host.raspberrypi Set default value of zigbee.0.info.pairingMode: false
                                2024-04-03 20:43:35.838 - info: host.raspberrypi iobroker host.raspberrypi Set default value of zigbee.0.info.pairingCountdown: 0
                                2024-04-03 20:43:35.850 - info: host.raspberrypi iobroker host.raspberrypi Set default value of zigbee.0.info.pairingMessage:
                                2024-04-03 20:43:35.861 - info: host.raspberrypi iobroker host.raspberrypi Set default value of zigbee.0.info.groups:
                                2024-04-03 20:43:35.875 - info: host.raspberrypi iobroker host.raspberrypi Set default value of zigbee.0.info.undefinedDevices:
                                2024-04-03 20:43:35.886 - info: host.raspberrypi iobroker host.raspberrypi Set default value of zigbee.0.info.debugmessages:
                                2024-04-03 20:43:35.909 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0 created
                                2024-04-03 20:43:37.070 - info: host.raspberrypi iobroker exit 0
                                2024-04-03 20:43:38.969 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 925
                                2024-04-03 20:43:39.376 - info: admin.0 (697) ==> Connected system.user.admin from ::ffff:192.168.178.91
                                2024-04-03 20:43:48.266 - info: zigbee.0 (925) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.0, js-controller: 5.0.19
                                2024-04-03 20:43:48.322 - error: zigbee.0 (925) Serial port not selected! Go to settings page.
                                2024-04-03 20:43:49.053 - info: zigbee.0 (925) Starting Zigbee npm ...
                                2024-04-03 20:43:49.657 - info: zigbee.0 (925) Installed Version: iobroker.zigbee@1.10.1
                                2024-04-03 20:43:50.822 - error: zigbee.0 (925) Starting zigbee-herdsman problem : "No path provided and failed to auto detect path"
                                2024-04-03 20:43:50.824 - error: zigbee.0 (925) Failed to start Zigbee
                                2024-04-03 20:43:50.825 - error: zigbee.0 (925) Error herdsman start
                                2024-04-03 20:44:00.833 - info: zigbee.0 (925) Try to reconnect. 1 attempts left
                                2024-04-03 20:44:00.836 - info: zigbee.0 (925) Starting Zigbee npm ...
                                2024-04-03 20:44:00.877 - info: zigbee.0 (925) Installed Version: iobroker.zigbee@1.10.1
                                2024-04-03 20:44:01.192 - error: zigbee.0 (925) Starting zigbee-herdsman problem : "No path provided and failed to auto detect path"
                                2024-04-03 20:44:01.194 - error: zigbee.0 (925) Failed to start Zigbee
                                2024-04-03 20:44:01.196 - error: zigbee.0 (925) Error herdsman start
                                2024-04-03 20:43:53.442 - info: host.raspberrypi iobroker.js-controller version 5.0.19 js-controller starting
                                2024-04-03 20:43:53.455 - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                                2024-04-03 20:43:53.456 - info: host.raspberrypi hostname: raspberrypi, node: v18.20.0
                                2024-04-03 20:43:53.458 - info: host.raspberrypi ip addresses: 192.168.178.66 2001:9e8:afa6:4a00:2b:ede5:af51:9ea3 fe80::135:6df3:c21c:52ee
                                2024-04-03 20:43:54.688 - info: host.raspberrypi connected to Objects and States
                                2024-04-03 20:43:54.753 - info: host.raspberrypi added notifications configuration of host
                                2024-04-03 20:43:55.878 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeCurrent"
                                2024-04-03 20:43:55.881 - info: host.raspberrypi 3 instances found
                                2024-04-03 20:43:55.898 - info: host.raspberrypi starting 3 instances
                                2024-04-03 20:43:56.009 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 682
                                2024-04-03 20:43:56.025 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewest"
                                2024-04-03 20:43:56.085 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewestNext"
                                2024-04-03 20:43:56.146 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmCurrent"
                                2024-04-03 20:43:56.204 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewest"
                                2024-04-03 20:43:56.262 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewestNext"
                                2024-04-03 20:43:56.321 - info: host.raspberrypi Some obsolete host states deleted.
                                2024-04-03 20:43:59.952 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 693
                                2024-04-03 20:44:00.232 - error: admin.0 (682) admin.0 already running
                                2024-04-03 20:44:00.241 - warn: admin.0 (682) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                2024-04-03 20:44:00.990 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                2024-04-03 20:44:00.991 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
                                2024-04-03 20:44:02.761 - error: backitup.0 (693) backitup.0 already running
                                2024-04-03 20:44:02.769 - warn: backitup.0 (693) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                2024-04-03 20:44:03.344 - error: host.raspberrypi instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                2024-04-03 20:44:03.345 - info: host.raspberrypi Restart adapter system.adapter.backitup.0 because enabled
                                2024-04-03 20:44:03.938 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 704
                                2024-04-03 20:44:06.549 - error: discovery.0 (704) discovery.0 already running
                                2024-04-03 20:44:06.558 - warn: discovery.0 (704) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                2024-04-03 20:44:07.131 - error: host.raspberrypi instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                2024-04-03 20:44:07.133 - info: host.raspberrypi Restart adapter system.adapter.discovery.0 because enabled
                                2024-04-03 21:15:34.034 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 720
                                2024-04-03 21:15:36.350 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 727
                                2024-04-03 21:15:38.919 - info: admin.0 (720) starting. Version 6.13.16 in /opt/iobroker/node_modules/iobroker.admin, node: v18.20.0, js-controller: 5.0.19
                                2024-04-03 21:15:39.024 - info: admin.0 (720) requesting all objects
                                2024-04-03 21:15:40.523 - info: admin.0 (720) received all objects
                                2024-04-03 21:15:40.890 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 748
                                2024-04-03 21:15:41.681 - info: admin.0 (720) socket.io server listening on port 8081
                                2024-04-03 21:15:41.692 - info: admin.0 (720) http server listening on port 8081
                                2024-04-03 21:15:41.694 - info: admin.0 (720) Use link "http://127.0.0.1:8081" to configure.
                                2024-04-03 21:15:43.004 - info: backitup.0 (727) starting. Version 2.10.11 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.20.0, js-controller: 5.0.19
                                2024-04-03 21:15:43.209 - info: backitup.0 (727) [iobroker] backup will be activated at 02:48 every 1 day(s)
                                2024-04-03 21:15:45.430 - info: discovery.0 (748) starting. Version 4.4.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.20.0, js-controller: 5.0.19
                                2024-04-03 21:16:41.275 - info: admin.0 (720) ==> Connected system.user.admin from ::ffff:192.168.178.91
                                • N NFTVirus
                                  @nftvirus
                                  iob stop
                                  sudo apt update
                                  sudo apt full-upgrade
                                  sudo reboot
                                    @nftvirus
                                    iob stop
                                    sudo apt update
                                    sudo reboot
                                    N Offline
                                    N Offline
                                    NFTVirus
                                    @thomas-braun habe ich gemacht dann den Adapter neu installiert und wieder das selbe Ergebnis. beim einschalten des Adapters wird er Gelb und dann stürzt alles ab.
                                    Log file:
                                    2024-04-03 21:26:16.925 - info: admin.0 (720) <== Disconnect system.user.admin from ::ffff:192.168.178.91 admin
                                    2024-04-03 21:29:55.004 - info: host.raspberrypi received SIGTERM
                                    2024-04-03 21:29:55.007 - info: admin.0 (720) terminating http server on port 8081
                                    2024-04-03 21:29:55.007 - info: backitup.0 (727) cleaned everything up...
                                    2024-04-03 21:29:55.016 - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=true)
                                    2024-04-03 21:29:55.018 - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
                                    2024-04-03 21:29:55.019 - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=true)
                                    2024-04-03 21:29:55.044 - info: admin.0 (720) Got terminate signal TERMINATE_YOURSELF
                                    2024-04-03 21:29:55.046 - info: backitup.0 (727) Got terminate signal TERMINATE_YOURSELF
                                    2024-04-03 21:29:55.049 - info: discovery.0 (748) Got terminate signal TERMINATE_YOURSELF
                                    2024-04-03 21:29:55.060 - info: admin.0 (720) terminating
                                    2024-04-03 21:29:55.059 - info: host.raspberrypi stopInstance system.adapter.admin.0 send kill signal
                                    2024-04-03 21:29:55.065 - info: discovery.0 (748) terminating
                                    2024-04-03 21:29:55.066 - info: admin.0 (720) Terminated (NO_ERROR): Without reason
                                    2024-04-03 21:29:55.062 - info: backitup.0 (727) terminating
                                    2024-04-03 21:29:55.063 - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
                                    2024-04-03 21:29:55.064 - info: host.raspberrypi stopInstance system.adapter.discovery.0 send kill signal
                                    2024-04-03 21:29:55.073 - info: backitup.0 (727) Terminated (NO_ERROR): Without reason
                                    2024-04-03 21:29:55.081 - info: discovery.0 (748) Terminated (NO_ERROR): Without reason
                                    2024-04-03 21:29:55.516 - info: discovery.0 (748) terminating
                                    2024-04-03 21:29:55.529 - info: backitup.0 (727) terminating
                                    2024-04-03 21:29:55.529 - info: admin.0 (720) terminating
                                    2024-04-03 21:29:55.725 - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                                    2024-04-03 21:29:55.729 - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                                    2024-04-03 21:29:55.730 - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
                                    2024-04-03 21:29:55.731 - info: host.raspberrypi All instances are stopped.
                                    2024-04-03 21:29:55.860 - info: host.raspberrypi terminated
                                    2024-04-03 21:31:35.918 - info: host.raspberrypi iobroker.js-controller version 5.0.19 js-controller starting
                                    2024-04-03 21:31:35.929 - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                                    2024-04-03 21:31:35.931 - info: host.raspberrypi hostname: raspberrypi, node: v18.20.1
                                    2024-04-03 21:31:35.933 - info: host.raspberrypi ip addresses: 192.168.178.66 2001:9e8:afa6:4a00:2b:ede5:af51:9ea3 fe80::135:6df3:c21c:52ee
                                    2024-04-03 21:31:37.184 - info: host.raspberrypi connected to Objects and States
                                    2024-04-03 21:31:37.246 - info: host.raspberrypi added notifications configuration of host
                                    2024-04-03 21:31:37.252 - info: host.raspberrypi Node.js version has changed from 18.20.0 to 18.20.1
                                    2024-04-03 21:31:37.423 - info: host.raspberrypi Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                                    2024-04-03 21:31:38.423 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeCurrent"
                                    2024-04-03 21:31:38.427 - info: host.raspberrypi 3 instances found
                                    2024-04-03 21:31:38.444 - info: host.raspberrypi starting 3 instances
                                    2024-04-03 21:31:38.549 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 683
                                    2024-04-03 21:31:38.568 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewest"
                                    2024-04-03 21:31:38.581 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewestNext"
                                    2024-04-03 21:31:38.597 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmCurrent"
                                    2024-04-03 21:31:38.613 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewest"
                                    2024-04-03 21:31:38.628 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewestNext"
                                    2024-04-03 21:31:38.642 - info: host.raspberrypi Some obsolete host states deleted.
                                    2024-04-03 21:31:42.497 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 694
                                    2024-04-03 21:31:43.902 - info: admin.0 (683) starting. Version 6.13.16 in /opt/iobroker/node_modules/iobroker.admin, node: v18.20.1, js-controller: 5.0.19
                                    2024-04-03 21:31:43.996 - info: admin.0 (683) requesting all objects
                                    2024-04-03 21:31:46.757 - info: admin.0 (683) received all objects
                                    2024-04-03 21:31:47.369 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 719
                                    2024-04-03 21:31:48.452 - info: admin.0 (683) socket.io server listening on port 8081
                                    2024-04-03 21:31:48.462 - info: admin.0 (683) http server listening on port 8081
                                    2024-04-03 21:31:48.464 - info: admin.0 (683) Use link "http://127.0.0.1:8081" to configure.
                                    2024-04-03 21:31:49.773 - info: backitup.0 (694) starting. Version 2.10.11 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.20.1, js-controller: 5.0.19
                                    2024-04-03 21:31:49.967 - info: backitup.0 (694) [iobroker] backup will be activated at 02:48 every 1 day(s)
                                    2024-04-03 21:31:52.272 - info: discovery.0 (719) starting. Version 4.4.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.20.1, js-controller: 5.0.19
                                    2024-04-03 21:32:49.261 - info: admin.0 (683) ==> Connected system.user.admin from ::ffff:192.168.178.91
                                    2024-04-03 21:33:45.615 - info: host.raspberrypi iobroker add zigbee --host raspberrypi
                                    2024-04-03 21:33:49.109 - info: host.raspberrypi iobroker host.raspberrypi install adapter zigbee
                                    2024-04-03 21:33:53.559 - info: host.raspberrypi iobroker upload [327] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
                                    2024-04-03 21:33:53.903 - info: host.raspberrypi iobroker upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad.png img/DIYRuZ_FreePad.png image/png
                                    2024-04-03 21:33:54.548 - info: host.raspberrypi iobroker upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/bitron_motion.png img/bitron_motion.png image/png
                                    2024-04-03 21:33:55.245 - info: host.raspberrypi iobroker upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hive.png img/hive.png image/png
                                    2024-04-03 21:33:55.987 - info: host.raspberrypi iobroker upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lh_32Zb.png img/lh_32Zb.png image/png
                                    2024-04-03 21:33:56.797 - info: host.raspberrypi iobroker upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_amaze.png img/philips_amaze.png image/png
                                    2024-04-03 21:33:56.966 - info: host.raspberrypi iobroker upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_ambiance.png img/philips_hue_ambiance.png image/png
                                    2024-04-03 21:33:57.151 - info: host.raspberrypi iobroker upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_e27_ambiance.png img/philips_hue_e27_ambiance.png image/png
                                    2024-04-03 21:33:57.330 - info: host.raspberrypi iobroker upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_ltc021.png img/philips_hue_ltc021.png image/png
                                    2024-04-03 21:33:57.498 - info: host.raspberrypi iobroker upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/plug.png img/plug.png image/png
                                    2024-04-03 21:33:57.670 - info: host.raspberrypi iobroker upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_philipshue.png img/sensor_philipshue.png image/png
                                    2024-04-03 21:33:57.849 - info: host.raspberrypi iobroker upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/smartthings_motion.png img/smartthings_motion.png image/png
                                    2024-04-03 21:33:58.030 - info: host.raspberrypi iobroker upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ts0203.png img/ts0203.png image/png
                                    2024-04-03 21:33:58.220 - info: host.raspberrypi iobroker upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_tyzs1l.png img/tuya_tyzs1l.png image/png
                                    2024-04-03 21:33:58.238 - info: host.raspberrypi iobroker upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unavailable.png img/unavailable.png image/png
                                    2024-04-03 21:33:58.259 - info: host.raspberrypi iobroker upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unknown.png img/unknown.png image/png
                                    2024-04-03 21:33:58.277 - info: host.raspberrypi iobroker upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/wemo.png img/wemo.png image/png
                                    2024-04-03 21:33:58.297 - info: host.raspberrypi iobroker upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_plug_eu.png img/xiaomi_plug_eu.png image/png
                                    2024-04-03 21:33:58.333 - info: host.raspberrypi iobroker upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_wireless_switch.png img/xiaomi_wireless_switch.png image/png
                                    2024-04-03 21:33:58.351 - info: host.raspberrypi iobroker upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27.png img/zbt_e27.png image/png
                                    2024-04-03 21:33:58.369 - info: host.raspberrypi iobroker upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27_rgbw.png img/zbt_e27_rgbw.png image/png
                                    2024-04-03 21:33:58.389 - info: host.raspberrypi iobroker upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_led_panel.png img/zbt_led_panel.png image/png
                                    2024-04-03 21:33:58.407 - info: host.raspberrypi iobroker upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_smart_switch.png img/zbt_smart_switch.png image/png
                                    2024-04-03 21:33:58.426 - info: host.raspberrypi iobroker upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zemismart_sw2.png img/zemismart_sw2.png image/png
                                    2024-04-03 21:33:58.444 - info: host.raspberrypi iobroker upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index.html index.html text/html
                                    2024-04-03 21:33:58.462 - info: host.raspberrypi iobroker upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index_m.html index_m.html text/html
                                    2024-04-03 21:33:58.482 - info: host.raspberrypi iobroker upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/moment.min.js moment.min.js application/javascript
                                    2024-04-03 21:33:58.506 - info: host.raspberrypi iobroker upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/shuffle.min.js shuffle.min.js application/javascript
                                    2024-04-03 21:33:58.530 - info: host.raspberrypi iobroker upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/tab_m.html tab_m.html text/html
                                    2024-04-03 21:33:58.555 - info: host.raspberrypi iobroker upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.css vis-network.min.css text/css
                                    2024-04-03 21:33:58.593 - info: host.raspberrypi iobroker upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.js vis-network.min.js application/javascript
                                    2024-04-03 21:33:58.637 - info: host.raspberrypi iobroker upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/words.js words.js application/javascript
                                    2024-04-03 21:33:58.661 - info: host.raspberrypi iobroker upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.png zigbee.png image/png
                                    2024-04-03 21:33:58.679 - info: host.raspberrypi iobroker upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.svg zigbee.svg image/svg+xml
                                    2024-04-03 21:33:58.752 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee created/updated
                                    2024-04-03 21:33:58.815 - info: host.raspberrypi iobroker host.raspberrypi create instance zigbee
                                    2024-04-03 21:33:58.831 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.alive created
                                    2024-04-03 21:33:58.843 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.connected created
                                    2024-04-03 21:33:58.855 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.compactMode created
                                    2024-04-03 21:33:58.867 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.cpu created
                                    2024-04-03 21:33:58.880 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.cputime created
                                    2024-04-03 21:33:58.892 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.memHeapUsed created
                                    2024-04-03 21:33:58.904 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.memHeapTotal created
                                    2024-04-03 21:33:58.916 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.memRss created
                                    2024-04-03 21:33:58.929 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.uptime created
                                    2024-04-03 21:33:58.942 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.inputCount created
                                    2024-04-03 21:33:58.954 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.outputCount created
                                    2024-04-03 21:33:58.966 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.eventLoopLag created
                                    2024-04-03 21:33:58.980 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.sigKill created
                                    2024-04-03 21:33:58.991 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0.logLevel created
                                    2024-04-03 21:33:59.002 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.0.exclude created
                                    2024-04-03 21:33:59.013 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.0.exclude.all created
                                    2024-04-03 21:33:59.023 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.0.info created
                                    2024-04-03 21:33:59.033 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.0.info.connection created
                                    2024-04-03 21:33:59.043 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.0.info.pairingMode created
                                    2024-04-03 21:33:59.054 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.0.info.pairingCountdown created
                                    2024-04-03 21:33:59.069 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.0.info.pairingMessage created
                                    2024-04-03 21:33:59.081 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.0.info.groups created
                                    2024-04-03 21:33:59.092 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.0.info.undefinedDevices created
                                    2024-04-03 21:33:59.103 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.0.info.debugmessages created
                                    2024-04-03 21:33:59.113 - info: host.raspberrypi iobroker host.raspberrypi Set default value of zigbee.0.exclude.all: []
                                    2024-04-03 21:33:59.122 - info: host.raspberrypi iobroker host.raspberrypi Set default value of zigbee.0.info.connection: false
                                    2024-04-03 21:33:59.131 - info: host.raspberrypi iobroker host.raspberrypi Set default value of zigbee.0.info.pairingMode: false
                                    2024-04-03 21:33:59.140 - info: host.raspberrypi iobroker host.raspberrypi Set default value of zigbee.0.info.pairingCountdown: 0
                                    2024-04-03 21:33:59.149 - info: host.raspberrypi iobroker host.raspberrypi Set default value of zigbee.0.info.pairingMessage:
                                    2024-04-03 21:33:59.158 - info: host.raspberrypi iobroker host.raspberrypi Set default value of zigbee.0.info.groups:
                                    2024-04-03 21:33:59.167 - info: host.raspberrypi iobroker host.raspberrypi Set default value of zigbee.0.info.undefinedDevices:
                                    2024-04-03 21:33:59.177 - info: host.raspberrypi iobroker host.raspberrypi Set default value of zigbee.0.info.debugmessages:
                                    2024-04-03 21:33:59.194 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.zigbee.0 created
                                    2024-04-03 21:34:00.363 - info: host.raspberrypi iobroker exit 0
                                    2024-04-03 21:34:02.250 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 802
                                    2024-04-03 21:34:02.400 - info: admin.0 (683) ==> Connected system.user.admin from ::ffff:192.168.178.91
                                    2024-04-03 21:34:11.302 - info: zigbee.0 (802) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.1, js-controller: 5.0.19
                                    2024-04-03 21:34:11.352 - error: zigbee.0 (802) Serial port not selected! Go to settings page.
                                    2024-04-03 21:34:12.202 - info: zigbee.0 (802) Starting Zigbee npm ...
                                    2024-04-03 21:34:12.894 - info: zigbee.0 (802) Installed Version: iobroker.zigbee@1.10.1
                                    2024-04-03 21:34:14.115 - error: zigbee.0 (802) Starting zigbee-herdsman problem : "No path provided and failed to auto detect path"
                                    2024-04-03 21:34:14.117 - error: zigbee.0 (802) Failed to start Zigbee
                                    2024-04-03 21:34:14.118 - error: zigbee.0 (802) Error herdsman start
                                    2024-04-03 21:34:24.125 - info: zigbee.0 (802) Try to reconnect. 1 attempts left
                                    2024-04-03 21:34:24.127 - info: zigbee.0 (802) Starting Zigbee npm ...
                                    2024-04-03 21:34:24.151 - info: zigbee.0 (802) Installed Version: iobroker.zigbee@1.10.1
                                    2024-04-03 21:34:24.402 - error: zigbee.0 (802) Starting zigbee-herdsman problem : "No path provided and failed to auto detect path"
                                    2024-04-03 21:34:24.404 - error: zigbee.0 (802) Failed to start Zigbee
                                    2024-04-03 21:34:24.405 - error: zigbee.0 (802) Error herdsman start
                                    2024-04-03 21:35:16.419 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                                    2024-04-03 21:35:16.436 - info: zigbee.0 (802) Got terminate signal TERMINATE_YOURSELF
                                    2024-04-03 21:35:16.471 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                                    2024-04-03 21:35:16.441 - info: zigbee.0 (802) cleaned everything up...
                                    2024-04-03 21:35:16.449 - info: zigbee.0 (802) Zigbee: disabling joining new devices.
                                    2024-04-03 21:35:16.475 - warn: zigbee.0 (802) Failed to stop zigbee during startup
                                    2024-04-03 21:35:16.476 - info: zigbee.0 (802) terminating
                                    2024-04-03 21:35:16.479 - info: zigbee.0 (802) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2024-04-03 21:35:16.588 - info: admin.0 (683) <== Disconnect system.user.admin from ::ffff:192.168.178.91
                                    2024-04-03 21:35:16.944 - info: zigbee.0 (802) terminating
                                    2024-04-03 21:35:17.074 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2024-04-03 21:35:19.513 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 820
                                    2024-04-03 21:35:03.296 - info: host.raspberrypi iobroker.js-controller version 5.0.19 js-controller starting
                                    2024-04-03 21:35:03.307 - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                                    2024-04-03 21:35:03.308 - info: host.raspberrypi hostname: raspberrypi, node: v18.20.1
                                    2024-04-03 21:35:03.310 - info: host.raspberrypi ip addresses: 192.168.178.66 2001:9e8:afa6:4a00:2b:ede5:af51:9ea3 fe80::135:6df3:c21c:52ee
                                    2024-04-03 21:35:04.581 - info: host.raspberrypi connected to Objects and States
                                    2024-04-03 21:35:04.641 - info: host.raspberrypi added notifications configuration of host
                                    2024-04-03 21:35:05.759 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeCurrent"
                                    2024-04-03 21:35:05.800 - info: host.raspberrypi 4 instances found
                                    2024-04-03 21:35:05.819 - info: host.raspberrypi starting 4 instances
                                    2024-04-03 21:35:05.913 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewest"
                                    2024-04-03 21:35:05.939 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewestNext"
                                    2024-04-03 21:35:06.007 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 681
                                    2024-04-03 21:35:06.025 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmCurrent"
                                    2024-04-03 21:35:06.081 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewest"
                                    2024-04-03 21:35:06.146 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewestNext"
                                    2024-04-03 21:35:06.201 - info: host.raspberrypi Some obsolete host states deleted.
                                    2024-04-03 21:35:09.886 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 692
                                    2024-04-03 21:35:10.227 - error: admin.0 (681) admin.0 already running
                                    2024-04-03 21:35:10.237 - warn: admin.0 (681) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                    2024-04-03 21:35:10.971 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                    2024-04-03 21:35:10.973 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
                                    2024-04-03 21:35:12.754 - error: backitup.0 (692) backitup.0 already running
                                    2024-04-03 21:35:12.761 - warn: backitup.0 (692) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                    2024-04-03 21:35:13.342 - error: host.raspberrypi instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                    2024-04-03 21:35:13.343 - info: host.raspberrypi Restart adapter system.adapter.backitup.0 because enabled
                                    2024-04-03 21:35:13.868 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 705
                                    2024-04-03 21:35:17.883 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 745
                                    2024-04-03 21:35:21.239 - error: discovery.0 (745) discovery.0 already running
                                    2024-04-03 21:35:21.248 - warn: discovery.0 (745) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                    2024-04-03 21:35:21.867 - error: host.raspberrypi instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                    2024-04-03 21:35:21.870 - info: host.raspberrypi Restart adapter system.adapter.discovery.0 because enabled
                                    2024-04-03 21:35:22.666 - error: zigbee.0 (705) zigbee.0 already running
                                    2024-04-03 21:35:22.675 - warn: zigbee.0 (705) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                    2024-04-03 21:35:23.265 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                    2024-04-03 21:35:23.266 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
                                    2024-04-03 21:39:10.709 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 763
                                    2024-04-03 21:39:13.044 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 770
                                    2024-04-03 21:39:15.658 - info: admin.0 (763) starting. Version 6.13.16 in /opt/iobroker/node_modules/iobroker.admin, node: v18.20.1, js-controller: 5.0.19
                                    2024-04-03 21:39:15.757 - info: admin.0 (763) requesting all objects
                                    2024-04-03 21:39:17.285 - info: admin.0 (763) received all objects
                                    2024-04-03 21:39:18.285 - info: admin.0 (763) socket.io server listening on port 8081
                                    2024-04-03 21:39:18.294 - info: admin.0 (763) http server listening on port 8081
                                    2024-04-03 21:39:18.296 - info: admin.0 (763) Use link "http://127.0.0.1:8081" to configure.
                                    2024-04-03 21:39:19.158 - info: backitup.0 (770) starting. Version 2.10.11 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.20.1, js-controller: 5.0.19
                                    2024-04-03 21:39:19.385 - info: backitup.0 (770) [iobroker] backup will be activated at 02:48 every 1 day(s)
                                    2024-04-03 21:39:21.570 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 805
                                    2024-04-03 21:39:22.976 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 812
                                    2024-04-03 21:39:23.753 - info: admin.0 (763) ==> Connected system.user.admin from ::ffff:192.168.178.91
                                    2024-04-03 21:39:28.772 - info: discovery.0 (805) starting. Version 4.4.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.20.1, js-controller: 5.0.19
                                    2024-04-03 21:39:32.670 - info: zigbee.0 (812) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.1, js-controller: 5.0.19
                                    2024-04-03 21:39:32.721 - error: zigbee.0 (812) Serial port not selected! Go to settings page.
                                    2024-04-03 21:39:33.502 - info: zigbee.0 (812) Starting Zigbee npm ...
                                    2024-04-03 21:39:34.216 - info: zigbee.0 (812) Installed Version: iobroker.zigbee@1.10.1
                                    2024-04-03 21:39:35.378 - error: zigbee.0 (812) Starting zigbee-herdsman problem : "No path provided and failed to auto detect path"
                                    2024-04-03 21:39:35.380 - error: zigbee.0 (812) Failed to start Zigbee
                                    2024-04-03 21:39:35.381 - error: zigbee.0 (812) Error herdsman start
                                    Thomas BraunT Ro75R 2 Antworten Letzte Antwort
                                    • N NFTVirus
                                      Log file:
                                      Beim Com-Port trägst du
                                      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2466692-if00
                                      ein.
                                        ein.
                                        N Offline
                                        N Offline
                                        NFTVirus
                                        @thomas-braun Stand genau so drin habe es jetzt gerade nochmal versucht und ist wieder abgestürzt. Kann es an der Baudrate liegen? Nutze aktuell 115200
                                        • N NFTVirus
                                          @nftvirus
                                          Keine Ahnung.
                                          Im journal steht?
