  4. Problem mit Zigbee-Adapter
22 Beiträge 4 Kommentatoren 2.7k Aufrufe 3 Beobachtet
    @guitardoc
    Log Files sagen?
    guitardoc
    zigbee.0
    2024-03-26 09:07:01.766	info	List of port: [{"path":"/dev/ttyACM0"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
    zigbee.0
    2024-03-26 08:30:20.458	info	List of port: [{"path":"/dev/ttyACM0"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
    zigbee.0
    2024-03-26 08:21:01.836	warn	DeviceAvailability:Stopping to ping 0xa4c1382ad59e8217 TS011F after 7 ping attempts
    zigbee.0
    2024-03-26 08:14:28.056	info	List of port: [{"path":"/dev/ttyACM0"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
    zigbee.0
    2024-03-26 08:10:34.433	info	List of port: [{"path":"/dev/ttyACM0"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
    zigbee.0
    2024-03-26 08:10:21.759	info	debug devices set to []
    zigbee.0
    2024-03-26 08:10:21.741	info	Zigbee started
    zigbee.0
    2024-03-26 08:10:21.741	info	0xa4c1384349047469 (addr 2519): TS0203 - TuYa Door sensor (EndDevice)
    zigbee.0
    2024-03-26 08:10:21.741	info	0x54ef441000017f65 (addr 13881): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
    zigbee.0
    2024-03-26 08:10:21.740	info	0x54ef441000018e3f (addr 57521): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
    zigbee.0
    2024-03-26 08:10:21.738	info	0xa4c1382ad59e8217 (addr 30035): A1Z - Nous Smart plug (with power monitoring) (Router)
    zigbee.0
    2024-03-26 08:10:21.720	info	Currently 4 devices are joined:
    zigbee.0
    2024-03-26 08:10:21.718	info	Unable to set transmit power, unsupported function.
    zigbee.0
    2024-03-26 08:10:21.682	info	--> transmitPower : normal
    zigbee.0
    2024-03-26 08:10:21.677	info	Unable to disable LED, unsupported function.
    zigbee.0
    2024-03-26 08:10:21.658	info	Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":120,"maintrel":0,"revision":"0x26780700"}}
    zigbee.0
    2024-03-26 08:10:21.143	info	Installed Version: iobroker.zigbee@1.10.1
    zigbee.0
    2024-03-26 08:10:21.060	info	Starting Zigbee npm ...
    zigbee.0
    2024-03-26 08:10:21.059	info	delete old Backup files. keep only last 10
    zigbee.0
    2024-03-26 08:10:21.028	info	starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.1, js-controller: 5.0.19
    zigbee.0
    2024-03-26 08:10:16.460	info	terminating
    zigbee.0
    2024-03-26 08:10:16.231	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0
    2024-03-26 08:10:16.230	info	terminating
    zigbee.0
    2024-03-26 08:10:15.731	info	Zigbee: disabling joining new devices.
    zigbee.0
    2024-03-26 08:10:15.730	info	cleaned everything up...
    zigbee.0
    2024-03-26 08:10:15.730	info	Got terminate signal TERMINATE_YOURSELF
    zigbee.0
    2024-03-26 08:09:30.220	info	List of port: [{"path":"/dev/ttyACM0"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
    zigbee.0
    2024-03-26 08:07:46.559	info	List of port: [{"path":"/dev/ttyACM0"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
    zigbee.0
    2024-03-26 08:06:15.979	info	List of port: [{"path":"/dev/ttyACM0"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
    zigbee.0
    2024-03-26 07:59:32.716	info	List of port: [{"path":"/dev/ttyACM0"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
    zigbee.0
    2024-03-26 07:59:02.624	info	List of port: [{"path":"/dev/ttyACM0"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
    zigbee.0
    2024-03-26 07:58:52.070	info	Zigbee started
    zigbee.0
    2024-03-26 07:58:52.070	info	0xa4c1384349047469 (addr 2519): TS0203 - TuYa Door sensor (EndDevice)
    zigbee.0
    2024-03-26 07:58:52.070	info	0x54ef441000017f65 (addr 13881): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
    zigbee.0
    2024-03-26 07:58:52.069	info	0x54ef441000018e3f (addr 57521): GZCGQ01LM - Xiaomi MiJia light intensity sensor (EndDevice)
    zigbee.0
    2024-03-26 07:58:52.068	info	0xa4c1382ad59e8217 (addr 30035): A1Z - Nous Smart plug (with power monitoring) (Router)
    zigbee.0
    2024-03-26 07:58:52.063	info	Currently 4 devices are joined:
    zigbee.0
    2024-03-26 07:58:52.062	info	Unable to set transmit power, unsupported function.
    zigbee.0
    2024-03-26 07:58:52.029	info	--> transmitPower : normal
    zigbee.0
    2024-03-26 07:58:52.025	info	Unable to disable LED, unsupported function.
    zigbee.0
    2024-03-26 07:58:47.479	info	debug devices set to []
    zigbee.0
    2024-03-26 07:58:47.342	info	Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":120,"maintrel":0,"revision":"0x26780700"}}
    zigbee.0
    2024-03-26 07:58:47.226	info	Installed Version: iobroker.zigbee@1.10.1
    zigbee.0
    2024-03-26 07:58:47.052	info	Starting Zigbee npm ...
    zigbee.0
    2024-03-26 07:58:47.052	info	delete old Backup files. keep only last 10
    zigbee.0
    2024-03-26 07:58:47.028	info	starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.1, js-controller: 5.0.19
    zigbee.0
    2024-03-26 07:58:43.382	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0
    2024-03-26 07:58:43.382	info	terminating
    zigbee.0
    2024-03-26 07:58:42.882	info	Zigbee: disabling joining new devices.
    zigbee.0
    2024-03-26 07:58:42.881	info	cleaned everything up...
    zigbee.0
    2024-03-26 07:58:42.881	info	Got terminate signal TERMINATE_YOURSELF
    zigbee.0
    2024-03-26 07:58:36.538	info	List of port: [{"path":"/dev/ttyACM0"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
    zigbee.0
    2024-03-26 07:58:13.174	info	List of port: [{"path":"/dev/ttyACM0"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"}]
    Das ist ab dem Neustart des Adapters heute früh. Der eine Sensor wurde gefunden, den anderen musste ich erst per Knopf aufwecken (das müsste der Eintrag 08:21 gewesen sein).
    Weiß nicht wo die Logs von gestern Abend nach dem Neustart des Proxmox zu finden sind (falls es diese noch gibt)?
    F 1 Antwort Letzte Antwort
    • G guitardoc
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      fraeggle
      @guitardoc
      Wie hast du den Zigbee in den Container verlinkt?
      Hatte sowas mit meinen 2 RFLINK. Nachdem ich den ID Path im Hostsystem genommen hab wurden die
      beim Neustart nicht mehr "vertauscht".
      • F fraeggle
        @guitardoc
        @fraeggle sagte in Problem mit Zigbee-Adapter:
        Deswegen verwendet man diese ja auch.
        G F 2 Antworten Letzte Antwort
          guitardoc
          Jetzt wurde der Moment erreicht, wo ihr mich verloren habt...
          Zigbee im Container, ID Path im Hostsystem, Bahnhof... :-)
          Kann das jemand Kundiges für mich übersetzen?
            fraeggle
            Du kannst auch mit Vendor ID arbeiten. Sofern diese Eindeutig sind.
            Beispiele:
            ATTRS{idVendor}=="1a86", ATTRS{idProduct}=="7523"
            Oder
            ENV{ID_PATH}=="pci-0000:00:15.0-usb-0:4:1.0"
            Ich hatte das Problem, das Vendor ID halt nicht eindeutig waren. Aber auch sonst hab ich die Erfahrung gemacht, dass
            ID_PATH besser funktioniert.
            • F fraeggle
              Beispiele:
              Oder
              @fraeggle
              Dann musst du aber die udev-Regeln anpassen. Musst du alles nicht, wenn du es dem Kernel überlässt das zu regeln und auf den by-id-Link gehst.
              • G guitardoc
                @guitardoc
                Zeig mal die Einstellungen im Adapter.
                Unter COM-Port sollte da der Link auf das Gerät aus
                ls -la /dev/serial/by-id
                eingetragen sein und nicht /dev/ttyWASAUCHIMMER
                G 1 Antwort Letzte Antwort
                  @guitardoc
                  guitardoc
                  schrieb am zuletzt editiert von guitardoc
                  @thomas-braun said in Problem mit Zigbee-Adapter:
                  total 0
                  drwxr-xr-x 2 root root 60 Mar 25 20:33 .
                  drwxr-xr-x 3 root root 60 Mar 25 20:33 ..
                  ---------- 1 root root  0 Mar 25 20:33 usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2285504-if00
                  • G guitardoc
                    total 0
                    @guitardoc
                    Und den Link hast du jetzt in den Einstellungen drin? Mit ganzem Pfad?
                    Aber zuvor sauber in den LXC durchreichen.
                      @guitardoc
                      guitardoc
                      @thomas-braun Das könnte das Problem sein. Da steht drin:
                      Was müsste ich da eintragen (ganzer Pfad)?
                      • G guitardoc
                        @guitardoc
                        Halt den ganzen, absoluten Pfad:
                        /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2285504-if00
                        Nutzt dir aber nichts, solange das Gerät nicht richtig durchgereicht wurde und mit den richtigen Rechten versehen wurde.
                        Die Baud-Rate muss soweit ich mich erinnere auch umgestellt werden. Weiß aber den Wert nicht mehr.
                          @guitardoc
                          guitardoc
                          @thomas-braun Ich erinnere mich, dass ich da irgendwas seltsames eintragen musste, damit der Stick durchgereicht wird. Aber frag mich nicht wo ich da was eingetragen hab... und ob das richtig war...
                          • G guitardoc
                            @guitardoc sagte in Problem mit Zigbee-Adapter:
                            Ja, LXC-Standard-Prozedur.
                            Offenbar nicht.
                              Offenbar nicht.
                              guitardoc
                              @thomas-braun Hmm, was kann ich denn dann machen?
                              Thomas BraunT DJMarc75D 2 Antworten Letzte Antwort
                              • G guitardoc
                                @guitardoc
                                Nachlesen wie man es richtig macht. Das ist ja nun nichts ungewöhnliches. Dürfte es zig Anleitungen zu geben. Ich meine das steht sogar in der Installationsanleitung zum ioBroker drin.
                                • G guitardoc
                                  DJMarc75D Offline
                                  DJMarc75D Offline
                                  DJMarc75
                                  Diese Anleitung befolgen ;)
                                  https://www.iobroker.net/#de/documentation/install/proxmox.md
                                  Nach unten scrollen und die Schritte zum Durchreichen an LXC befolgen.
                                  Lehrling seit 1975 !!!
                                    @fraeggle
                                    fraeggle
                                    @thomas-braun sagte in Problem mit Zigbee-Adapter:
                                    @fraeggle
                                    Ja, das ist richtig.
                                    Da es aber bei mir mit Vendor nicht ging, wegen doppelten Namen (Ja das gibt es leider tatsächlich, nämlich RFLINK),
                                    hab ich ID_PATH verwendet. Ist zum ersten mal raussuchen etwas komisch zu finden, aber funktioniert solange das Gerät am gleichen USB bleibt auch mit 2 Gleichen VendorID und ProductID.
                                    War die einzige Möglichkeit, da es sonst immer wieder zu verwechslungen der RFLINK's kam.
                                    @guitardoc
                                    Die Anleitung die @DJMarc75 verlinkt hat, ist da ganz gut.
                                    • G Offline
                                      guitardoc
                                      Die Anleitung hatte ich schon abgearbeitet als ich den LXC eingerichtet hab. Da ist auch immer noch alles richtig drin, hab ich gerade noch mal geprüft. Allerdings ein Punkt ist anders. Die Rechte stehen nicht auf nobody nogroup, sondern auf
                                      crw-rw-rw-  1 root dialout 166,     0 Mar 26 14:17 ttyACM0
                                      Wenn ich jetzt im Adapter statt /dev/ttyACM0 den Pfad /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2285504-if00 setze, dann bleibt der Adapter gelb und gibt folgende Fehlermeldung aus:
                                      zigbee.0
                                      2024-03-26 15:16:23.394	error	Error herdsman start
                                      zigbee.0
                                      2024-03-26 15:16:23.394	error	Failed to start Zigbee
                                      zigbee.0
                                      2024-03-26 15:16:23.394	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2285504-if00'"
                                      PS. Im iobroker LXC stehen die Rechte natürlich richtig auf
                                      crw-rw-rw- 1 nobody nogroup 166, 0 Mar 26 15:36 ttyACM0
                                      Oben (root dialout) waren die Rechte des Proxmox angegeben. Sorry für das Verwirrspiel...
                                      Also das Durchreichen hab ich so gemacht wie in der Anleitung beschrieben. Aber wie gesagt, es funktioniert nicht, wenn ich den ganzen Pfad angebe.
                                      • G guitardoc
                                        zigbee.0
                                        zigbee.0
                                        zigbee.0
                                        guitardoc
                                        Oder muss ich schon beim Durchreichen irgendwo den ganzen Pfad angeben? Ich hab es so gemacht wie in der Anleitung beschrieben.
                                        • G guitardoc
                                          guitardoc
                                          Ich hab jetzt auch mal spaßeshalber die Baudrate runtergesetzt wie in der Beschreibung zum Adapter erwähnt - von 115200 auf 38400.
                                          Es bleibt das gleiche Problem. Wenn der Adapter neu gestartet wird, dann muss ich die Sensoren per Knopfdruck aufwecken, sonst werden keine Daten übertragen. Wenn sie dann aufgeweckt sind, dann funktionieren sie bis zum nächsten Adapter-Neustart. Dann spaziere ich wieder am Haus entlang und drücke fleißig Knöpfchen…
                                          Bin ich der einzige, der diese Helligkeitssensoren hat? Falls jemand anderes die gleichen oder ähnliche hat, könnte er das mal testen?
