  3. Off Topic
  4. Philips HUE : Bedeutung der Datenpunkte (ZigBee Adapter)
    6.0k
38 Beiträge 3 Kommentatoren 2.4k Aufrufe 2 Beobachtet
  • L legro
    @asgothian
    Oh je, bei mir scheint das System ja komplett durcheinander zu sein.
    	Zeit
    Nachricht
    host.raspiBullseye
    2024-03-25 11:01:55.289	info	Restart adapter system.adapter.info.0 because enabled
    host.raspiBullseye
    2024-03-25 11:01:55.289	error	instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspiBullseye
    2024-03-25 11:01:55.288	error	Caught by controller[1]: Node.js v18.19.0
    host.raspiBullseye
    2024-03-25 11:01:55.288	error	Caught by controller[1]: at node:internal/main/run_main_module:28:49
    host.raspiBullseye
    2024-03-25 11:01:55.288	error	Caught by controller[1]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
    host.raspiBullseye
    2024-03-25 11:01:55.288	error	Caught by controller[1]: at Module._load (node:internal/modules/cjs/loader:1013:12)
    host.raspiBullseye
    2024-03-25 11:01:55.288	error	Caught by controller[1]: at Module.load (node:internal/modules/cjs/loader:1197:32)
    host.raspiBullseye
    2024-03-25 11:01:55.288	error	Caught by controller[1]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    host.raspiBullseye
    2024-03-25 11:01:55.288	error	Caught by controller[1]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
    host.raspiBullseye
    2024-03-25 11:01:55.287	error	Caught by controller[1]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.info/main.js:58:18)
    host.raspiBullseye
    2024-03-25 11:01:55.287	error	Caught by controller[1]: at getSystemVersions (/opt/iobroker/node_modules/iobroker.info/main.js:89:11)
    host.raspiBullseye
    2024-03-25 11:01:55.287	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'log')
    host.raspiBullseye
    2024-03-25 11:01:55.287	error	Caught by controller[1]: ^
    host.raspiBullseye
    2024-03-25 11:01:55.287	error	Caught by controller[1]: adapter.log.error("Could not check npm version: " + e);
    host.raspiBullseye
    2024-03-25 11:01:55.287	error	Caught by controller[1]: /opt/iobroker/node_modules/iobroker.info/main.js:89
    host.raspiBullseye
    2024-03-25 11:01:55.286	error	Caught by controller[0]: /bin/sh: 1: npm: not found
    host.raspiBullseye
    2024-03-25 11:01:52.588	info	instance system.adapter.info.0 started with pid 484277
    zigbee.0
    2024-03-25 11:01:45.486	error	No converter available for '' with key 'alert'
    Ob die letzte Meldung von ZigBee daher überhaupt sinnvoll ist?
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @legro
    Das passt schon. Anscheinend ist zumindest bei dieser Lampe der key „alert“ nicht unterstützt. Das besagt die Meldung „no converter available for …“
    A.
    L 1 Antwort Letzte Antwort
    • AsgothianA Asgothian
      @legro
      A.
      legro
      @asgothian sagte in Philips HUE : Bedeutung der Datenpunkte (ZigBee Adapter):
      @legro
      Danke für deine Unterstützung.
      Ein Blinken sollte ich ggf. durch ein eigenes JavaScript hinbekommen. Der Flaschenhals, dass man nur wenige Befehle im HUE-System senden kann, soll ja an der Bridge liegen. Das ich diese durch den CC26X2R1 und eueren Adapter ersetze, sollte das ganze sich hoffentlich realisieren lassen.
      Ansonsten warte ich halt ein paar Wochen.😬
      Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
      • L legro
        @legro
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @legro schau mal nach ob du mit dem Effekt „blink“ arbeiten kannst. Der existiert ggf. Als datenpunkt, ansonsten als send_payload mit {“effect”:”blink”}
        Was auch noch interessant ist - wird das device von den exposes oder den vom zigbee adapter manuell erzeugten states gesteuert. Dazu bitte die device Bezeichnung in die Ausschlussliste eingtragen und den Adapter neu starten.
        A.
        L 2 Antworten Letzte Antwort
        • L legro
          Scheint leider nicht zu funktionieren.
          pi@raspiBullseye:~ $ sudo apt install nodejs=18.19.0-1nodesource1
          Reading package lists... Done
          Package nodejs is not available, but is referred to by another package.
          This may mean that the package is missing, has been obsoleted, or
          is only available from another source
          However the following packages replace it:
            nodejs-doc
          E: Version '18.19.0-1nodesource1' for 'nodejs' was not found
          @legro sagte in Philips HUE : Bedeutung der Datenpunkte (ZigBee Adapter):
          Dann versuch es so:
          iob stop
          iob fix
          iob nodejs-update 18
            Dann versuch es so:
            iob stop
            iob fix
            legro
            vielen Dank für deine Unterstützung!
            Das habe ich versucht. Die riesige Ausgabe von iob diag vermag ich jedoch nicht zu kopieren, um sie hier zu posten. Daher hier bloß die Ausgabe zu Summary. Danach zu urteilen, hat auch dies nicht funktioniert: nodejs ist noch immer nicht korrekt installiert.
            			v.2023-10-10
             Static hostname: raspiBullseye
                   Icon name: computer
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
            Installation: 		native
            Kernel: 		aarch64
            Userland: 		arm64
            Timezone: 		Europe/Berlin (CET, +0100)
            User-ID: 		1000
            X-Server: 		false
            Boot Target: 		multi-user.target
            Pending OS-Updates: 	1
            Pending iob updates: 	11
            Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.0
            			/usr/bin/node 		v18.19.0
            /home/iobroker/.diag.sh: line 488: npm: command not found
            /home/iobroker/.diag.sh: line 489: npx: command not found
            /home/iobroker/.diag.sh: line 490: corepack: command not found
            Recommended versions are nodejs 18.19.1 and npm 10.2.4
            *** nodejs is NOT correctly installed ***
            Wrong installation path detected. This needs to be fixed.
            Please check
            https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
            for more information on how to fix these errors.
            MEMORY:
            Mem:            8.2G        3.3G        2.0G        1.1M        3.1G        4.9G
            Swap:           104M          0B        104M
            Total:          8.3G        3.3G        2.1G
            Active iob-Instances: 	33
            Active repo(s): stable
            ioBroker Core: 		js-controller 		5.0.12
            			admin 			6.13.15
            ioBroker Status: 	iobroker is running on this host.
            Objects type: jsonl
            States  type: jsonl
            + system.adapter.admin.0                  : admin                 : raspiBullseye                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.web.0                    : web                   : raspiBullseye                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            Objects: 		23857
            States: 		18743
            Size of iob-Database:
            28M	/opt/iobroker/iobroker-data/objects.jsonl
            31M	/opt/iobroker/iobroker-data/states.jsonl
            • L legro
              			v.2023-10-10
                     Icon name: computer
                  Architecture: arm64
              Kernel: 		aarch64
              Userland: 		arm64
              User-ID: 		1000
              X-Server: 		false
              Please check
              MEMORY:
              Swap:           104M          0B        104M
              			admin 			6.13.15
              Objects type: jsonl
              States  type: jsonl
              Objects: 		23857
              States: 		18743
              Warum nicht?
              sudo apt update
              apt policy nodejs
              sagt nun?
              Und an
              musst du auch dringend ran, wenn nodejs wieder richtig tickt.
                Warum nicht?
                sudo apt update
                apt policy nodejs
                sagt nun?
                Und an
                legro
                @thomas-braun sagte in Philips HUE : Bedeutung der Datenpunkte (ZigBee Adapter):
                Warum nicht?
                Weil ich's nicht aus dem Terminalfenster komplett kopieren kann.
                sagt nun?
                pi@raspiBullseye:~ $ sudo apt update
                Get:1 http://security.debian.org/debian-security bookworm-security InRelease [48.0 kB]
                Hit:2 http://archive.raspberrypi.org/debian bookworm InRelease
                Hit:3 http://deb.debian.org/debian bookworm InRelease
                Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
                Hit:6 https://apt.grafana.com stable InRelease
                Hit:7 https://repos.influxdata.com/debian stable InRelease
                Hit:8 https://deb.nodesource.com/node_18.x nodistro InRelease
                Fetched 48.0 kB in 2s (20.0 kB/s)
                2 packages can be upgraded. Run 'apt list --upgradable' to see them.
                pi@raspiBullseye:~ $ apt policy nodejs
                nodejs:
                  Installed: 18.19.0+dfsg-6~deb12u1
                  Candidate: 18.19.1-1nodesource1
                  Version table:
                     18.19.1-1nodesource1 1001
                        500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                 *** 18.19.0+dfsg-6~deb12u1 500
                        500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
                     18.19.0-1nodesource1 1001
                     18.18.2-1nodesource1 1001
                     18.18.1-1nodesource1 1001
                     18.18.0-1nodesource1 1001
                     18.17.1-1nodesource1 1001
                     18.17.0-1nodesource1 1001
                     18.16.1-1nodesource1 1001
                     18.16.0-1nodesource1 1001
                     18.15.0-1nodesource1 1001
                     18.14.2-1nodesource1 1001
                     18.14.1-1nodesource1 1001
                     18.14.0-1nodesource1 1001
                     18.13.0+dfsg1-1 500
                        500 http://deb.debian.org/debian bookworm/main arm64 Packages
                     18.13.0-1nodesource1 1001
                     18.12.0-1nodesource1 1001
                     18.11.0-1nodesource1 1001
                     18.10.0-1nodesource1 1001
                     18.9.1-1nodesource1 1001
                     18.9.0-1nodesource1 1001
                     18.8.0-1nodesource1 1001
                     18.7.0-1nodesource1 1001
                     18.6.0-1nodesource1 1001
                     18.5.0-1nodesource1 1001
                     18.4.0-1nodesource1 1001
                     18.3.0-1nodesource1 1001
                     18.2.0-1nodesource1 1001
                     18.1.0-1nodesource1 1001
                     18.0.0-1nodesource1 1001
                Für mich sind das alles noch mehr oder weniger Böhmische Dörfer.
                Und an
                Oh je, du machst mir Hoffnung auf weitere Abenteuer.😉
                • L legro
                  Warum nicht?
                  sagt nun?
                  nodejs:
                    Version table:
                       18.13.0+dfsg1-1 500
                  Und an
                  @legro
                  Passt doch.
                  sudo apt full-upgrade
                  Warum nicht? Mit der Maus markieren, kopieren, im Forum einfügen...
                  Bei dir scheint aber auch das OS nicht richtig aufgesetzt worden zu sein. Ist der Versuch gewesen, von Version 11 'Bullseye' per Dist-Upgrade auf 12 'Bookworm' zu kommen, stimmt's?
                    @legro
                    Passt doch.
                    legro
                    Passt doch.
                    .., aber nur dank deiner großartigen Hilfe. Ich selbst hätte keine Chance gehabt.
                    Das mag schon sein. Ich hatte damals eine Anleitung - wenn ich mich recht entsinne war die von dir - übernommen, um mein System auf Bullseye zu bringen. Du rietest jedoch generell von solchem Vorgehen ab und stattdessen lieber eine Neuinstallation vorzunehmen. Ja, hätte ich das mal getan.
                    Dann habe ich erneut das Bullseye nach (deiner?) Anleitung auf Bookworm aktualisiert. Dabei habe ich wohl ziemlich viel falsch gemacht. Jedenfalls besteht mein System aus allen möglichen Überresten aus allen alten Systemen. Da hilft nur eines: Deinem Rat folgend alles neu aufzusetzen.
                    Durch deine Unterstützung mutig geworden, habe ich das ein oder andere noch ausgeführt. Hier nun das Ergebnis ..
                    			v.2023-10-10
                           Icon name: computer
                        Architecture: arm64
                    Kernel: 		aarch64
                    Userland: 		arm64
                    User-ID: 		1000
                    X-Server: 		false
                    Pending OS-Updates: 	0
                    Please check
                    MEMORY:
                    Mem:            8.2G        3.4G        1.6G        1.1M        3.4G        4.8G
                    Swap:           104M          0B        104M
                    Total:          8.3G        3.4G        1.7G
                    			admin 			6.13.15
                    Objects type: jsonl
                    States  type: jsonl
                    Objects: 		23857
                    States: 		18684
                    30M	/opt/iobroker/iobroker-data/objects.jsonl
                    15M	/opt/iobroker/iobroker-data/states.jsonl
                    • L legro
                      Passt doch.
                      			v.2023-10-10
                             Icon name: computer
                          Architecture: arm64
                      Kernel: 		aarch64
                      Userland: 		arm64
                      User-ID: 		1000
                      X-Server: 		false
                      Please check
                      MEMORY:
                      Swap:           104M          0B        104M
                      			admin 			6.13.15
                      Objects type: jsonl
                      States  type: jsonl
                      Objects: 		23857
                      States: 		18684
                      @legro
                      Bitte mal die vollständigen Ein- und Ausgaben zu
                      sudo apt update
                      apt policy nodejs
                        A.
                        legro
                        Nachdem ich eine wahre Odyssee in Sachen Linux hinter mir habe - @Thomas-Braun hat mich glücklicherweise kräftig unterstützt - kann ich mich nun endlich wieder dem ZigBee-Adapter widmen.
                        .. ansonsten als send_payload mit {“effect”:”blink”}
                        Hurra! Das funktioniert.
                        Ich steuere die Lampe entweder direkt über die Oberfläche des Adapters oder über die vom Adapter erzeugten Datenpunkten im ioBroker. Was du mit exposes meinst, verstehe ich leider erst gar nicht.
                        Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
                        • L legro
                          Die ist aber noch nicht zuende.
                          sudo apt update
                          apt policy nodejs
                          sagt nun?
                            sudo apt update
                            apt policy nodejs
                            sagt nun?
                            legro
                            apt policy nodejs
                            .. sagt folgendes ..
                            nodejs:
                              Installed: 18.19.1-1nodesource1
                              Version table:
                             *** 18.19.1-1nodesource1 1001
                                 18.13.0+dfsg1-1 500
                            Diese drei Zeilen hatte ich fast genau so eingegeben. Ich hatte lediglich upgrade anstelle von full-upgrade ausgeführt. Der Unterschied: Bei letzterem wurde piVCCU3 erneut aktualisiert.
                            • L legro
                              apt policy nodejs
                              nodejs:
                                Version table:
                                   18.13.0+dfsg1-1 500
                              @legro
                              Dann sollte jetzt die Zusammenfassung von
                              iob diag
                              auch anders aussehen.
                              • L legro
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                @legro sagte in Philips HUE : Bedeutung der Datenpunkte (ZigBee Adapter):.
                                Dazu muss ich einen kleinen Exkurs in die Vergangenheit machen. Früher war es so das wir für alle zigbee Geräte die datenpunkte explizit im Zigbee Adapter definieren mussten. Das war viel Arbeit und hat zu seltsamen Konstellationen bei den Datenpunkten geführt. Dann wurde im zigbee-herdsman-converters das System der “exposes” etabliert. Darüber geben die converter für jedes Gerät vor welche datenpunkte angelegt wérden sollen. Das haben wir auch übernommen - allerdings wurde aus Kompatibilitätsgründen darauf verzichtet die explizit im zigbee-Adapter definierten datenpunkte zu entfernen.
                                Für Geräte die vor 2020 integriert wurden gilt daher das sie ggf. Über explizit im zigbee adapter definierte states gesteuert werden. Dieses Verhalten kann übersteuert werden - dafür gibt es in der Konfiguration die „Ausschluss-Liste“. Alle Gerätetypen die in dieser Liste aufgeführt werden ignorieren die im Zigbee-Adapter definierten states und nutzen die exposes der zigbee-herdsman-converter als Template für die zu nutzenden datenpunkte.
                                A.
                                  @legro
                                  iob diag
                                  legro
                                  iob diag
                                  In der Tat, das tut sie.🙂
                                  			v.2023-10-10
                                         Icon name: computer
                                      Architecture: arm64
                                  Kernel: 		aarch64
                                  Userland: 		arm64
                                  User-ID: 		1000
                                  X-Server: 		false
                                  Pending iob updates: 	12
                                  Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.1
                                  			/usr/bin/node 		v18.19.1
                                  			/usr/bin/npm 		10.2.4
                                  			/usr/bin/npx 		10.2.4
                                  			/usr/bin/corepack 	0.22.0
                                  MEMORY:
                                  Mem:            8.2G        3.5G        1.5G        1.1M        3.4G        4.7G
                                  Swap:           104M          0B        104M
                                  Total:          8.3G        3.5G        1.6G
                                  Active iob-Instances: 	34
                                  			admin 			6.13.15
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Objects: 		23857
                                  States: 		18685
                                  41M	/opt/iobroker/iobroker-data/objects.jsonl
                                  9.9M	/opt/iobroker/iobroker-data/states.jsonl
                                  Für mich sieht's so aus wie : erstmalig ohne Fehl und Tadel.
                                  • L legro
                                    iob diag
                                    			v.2023-10-10
                                           Icon name: computer
                                        Architecture: arm64
                                    Kernel: 		aarch64
                                    Userland: 		arm64
                                    User-ID: 		1000
                                    X-Server: 		false
                                    			/usr/bin/npm 		10.2.4
                                    			/usr/bin/npx 		10.2.4
                                    MEMORY:
                                    Swap:           104M          0B        104M
                                    			admin 			6.13.15
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Objects: 		23857
                                    States: 		18685
                                    Nicht ganz ohne Fehl und Tadel.
                                    Da steht bei einer richtigen Installation ein Kernel 6.6.20 drin.
                                    Und da soll Null drin stehen. ioBroker updaten!
                                      A.
                                      legro
                                      schrieb am zuletzt editiert von legro
                                      Dazu muss ich einen kleinen Exkurs in die Vergangenheit machen. ..
                                      Das Ganze werde ich mir wohl noch mehrmals zu Gemüte führen müssen, bis ich alles verstanden habe. Mein vorläufiges Verständnis: Es wird alles über Payload gesteuert mittels eine JSON gesteuert à la {"option" : "wert"}. Oder liege ich damit daneben?
                                      Vielen Dank für deine ausführlichen Erläuterungen.
                                      • L Offline
                                        legro
                                        Ich habe nach Anleitung den ioBroker aktualisiert. Statt 12 sind's nun immer noch 11 pending updates. Sind damit die Adapter gemeint; in der iob diag Ausgabe werden 11 Adapter als updatable angezeigt. Diese sind jedoch bereits auf der aktuellen Version aus dem staple Repository.
                                        Wie krieg' ich die Kernel Version auf 6.6.20? Auf der Website von Raspberry steht, das man statt apt den Befehl apt-get verwenden sollte. Ist das der Grund, warum es nicht klappt?
                                        Irgendwie kommt mir das wie ein Fass ohne Boden vor.
                                        Hier die vollständige Ausgabe von iob diag ..
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                               Icon name: computer
                                            Architecture: arm64
                                        Model		: Raspberry Pi 4 Model B Rev 1.4
                                        Docker          : false
                                        Virtualization  : none
                                        Kernel          : aarch64
                                        Userland        : arm64
                                        Systemuptime and Load:
                                         16:23:12 up  1:23,  3 users,  load average: 0.30, 0.95, 1.33
                                        CPU threads: 4
                                        *** RASPBERRY THROTTLING ***
                                        Current issues:
                                        Previously detected issues:
                                        *** Time and Time Zones ***
                                                       Local time: Mon 2024-03-25 16:23:12 CET
                                                   Universal time: Mon 2024-03-25 15:23:12 UTC
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        *** User and Groups ***
                                        pi
                                        /home/pi
                                        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                        *** X-Server-Setup ***
                                        X-Server: 	false
                                        Desktop:
                                        Terminal: 	tty
                                        *** MEMORY ***
                                        Mem:            8.2G        795M        4.2G        1.1M        3.3G        7.4G
                                        Swap:           104M          0B        104M
                                        Total:          8.3G        795M        4.3G
                                                 7811 M total memory
                                                  758 M used memory
                                                 2059 M active memory
                                                 1469 M inactive memory
                                                 4011 M free memory
                                                  157 M buffer memory
                                                 3030 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        *** FAILED SERVICES ***
                                          UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                                        * iobroker.service loaded failed failed ioBroker Server
                                        1 loaded units listed.
                                        *** FILESYSTEM ***
                                        /dev/root      ext4      110G  9.8G   96G  10% /
                                        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                                        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                                        tmpfs          tmpfs     1.6G  964K  1.6G   1% /run
                                        tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                                        /dev/sda1      vfat      253M   32M  221M  13% /boot
                                        tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
                                        [Mon Mar 25 14:59:56 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:BE:B7:5E vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=5ace6bce-02 rootfstype=ext4 fsck.repair=yes rootwait
                                        [Mon Mar 25 14:59:58 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                                        [Mon Mar 25 14:59:58 2024] EXT4-fs (sda2): write access will be enabled during recovery
                                        [Mon Mar 25 14:59:58 2024] EXT4-fs (sda2): orphan cleanup on readonly fs
                                        [Mon Mar 25 14:59:58 2024] EXT4-fs (sda2): 5 orphan inodes deleted
                                        [Mon Mar 25 14:59:58 2024] EXT4-fs (sda2): recovery complete
                                        [Mon Mar 25 14:59:58 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                                        [Mon Mar 25 14:59:58 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                        [Mon Mar 25 15:00:00 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                                        TARGET  SOURCE    FSTYPE OPTIONS
                                        /       /dev/sda2 ext4   rw,noatime
                                        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                                        /var:
                                        4.4G	/var/
                                        2.2G	/var/log
                                        2.1G	/var/log/journal/71ce3d9ea88f4118a23250ffbeda1105
                                        1.8G	/var/lib
                                        Archived and active journals take up 2.0G in the file system.
                                        /opt/iobroker/backups:
                                        16K	/opt/iobroker/backups/
                                        /opt/iobroker/iobroker-data:
                                        437M	/opt/iobroker/iobroker-data/
                                        296M	/opt/iobroker/iobroker-data/files
                                        97M	/opt/iobroker/iobroker-data/backup-objects
                                        67M	/opt/iobroker/iobroker-data/files/javascript.admin
                                        48M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                                        24M	/opt/iobroker/iobroker-data/states.jsonl
                                        22M	/opt/iobroker/iobroker-data/objects.jsonl
                                        22M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                                        22M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
                                        8.9M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
                                        USB-Devices by-id:
                                        /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L1100QXL-if00
                                        /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L1100QXL-if03
                                        *** NodeJS-Installation ***
                                        /usr/bin/npm 		10.2.4
                                        /usr/bin/npx 		10.2.4
                                        nodejs:
                                          Version table:
                                             18.13.0+dfsg1-1 500
                                        No problems detected
                                        Errors in npm tree:
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        iobroker is not running on this host.
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Core adapters versions
                                        js-controller: 	5.0.19
                                        admin: 		6.13.15
                                        javascript: 	7.1.6
                                        Adapters from github: 	0
                                        Adapter State
                                          system.adapter.apple-find-me.0          : apple-find-me         : raspiBullseye                            - disabled
                                          system.adapter.apple-find-me.1          : apple-find-me         : raspiBullseye                            - disabled
                                          system.adapter.apple-find-me.2          : apple-find-me         : raspiBullseye                            - disabled
                                          system.adapter.backitup.0               : backitup              : raspiBullseye                            -  enabled
                                          system.adapter.birthdays.0              : birthdays             : raspiBullseye                            -  enabled
                                          system.adapter.bydhvs.0                 : bydhvs                : raspiBullseye                            -  enabled
                                          system.adapter.daikin.0                 : daikin                : raspiBullseye                            -  enabled
                                          system.adapter.daikin.1                 : daikin                : raspiBullseye                            -  enabled
                                          system.adapter.daikin.2                 : daikin                : raspiBullseye                            -  enabled
                                          system.adapter.daswetter.0              : daswetter             : raspiBullseye                            -  enabled
                                          system.adapter.device-reminder.0        : device-reminder       : raspiBullseye                            -  enabled
                                          system.adapter.dwd.0                    : dwd                   : raspiBullseye                            -  enabled
                                          system.adapter.feiertage.0              : feiertage             : raspiBullseye                            -  enabled
                                          system.adapter.fronius.0                : fronius               : raspiBullseye                            -  enabled
                                          system.adapter.hm-rega.0                : hm-rega               : raspiBullseye                            -  enabled
                                          system.adapter.hm-rpc.0                 : hm-rpc                : raspiBullseye                            -  enabled, port: 0
                                          system.adapter.hm-rpc.1                 : hm-rpc                : raspiBullseye                            -  enabled, port: 0
                                          system.adapter.hue.0                    : hue                   : raspiBullseye                            -  enabled, port: 80
                                          system.adapter.ical.0                   : ical                  : raspiBullseye                            -  enabled
                                          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspiBullseye                            - disabled
                                          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspiBullseye                            -  enabled
                                          system.adapter.icons-icons8.0           : icons-icons8          : raspiBullseye                            - disabled
                                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspiBullseye                            - disabled
                                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspiBullseye                            - disabled
                                          system.adapter.influxdb.0               : influxdb              : raspiBullseye                            -  enabled, port: 8086
                                          system.adapter.info.0                   : info                  : raspiBullseye                            -  enabled
                                          system.adapter.javascript.0             : javascript            : raspiBullseye                            -  enabled
                                          system.adapter.modbus.0                 : modbus                : raspiBullseye                            - disabled
                                          system.adapter.modbus.1                 : modbus                : raspiBullseye                            - disabled
                                          system.adapter.modbus.2                 : modbus                : raspiBullseye                            -  enabled
                                          system.adapter.netatmo.0                : netatmo               : raspiBullseye                            -  enabled
                                          system.adapter.nuki-extended.0          : nuki-extended         : raspiBullseye                            -  enabled
                                          system.adapter.pushover.0               : pushover              : raspiBullseye                            -  enabled
                                          system.adapter.rpi2.0                   : rpi2                  : raspiBullseye                            -  enabled
                                          system.adapter.scenes.0                 : scenes                : raspiBullseye                            -  enabled
                                          system.adapter.shelly.0                 : shelly                : raspiBullseye                            -  enabled, port: 1882, bind: 0.0.0.0
                                          system.adapter.simple-api.0             : simple-api            : raspiBullseye                            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                          system.adapter.tankerkoenig.0           : tankerkoenig          : raspiBullseye                            -  enabled
                                          system.adapter.telegram.0               : telegram              : raspiBullseye                            -  enabled, port: 8443, bind: 0.0.0.0
                                          system.adapter.tr-064.0                 : tr-064                : raspiBullseye                            -  enabled
                                          system.adapter.trashschedule.0          : trashschedule         : raspiBullseye                            -  enabled
                                          system.adapter.tuya.0                   : tuya                  : raspiBullseye                            -  enabled
                                          system.adapter.viessmannapi.0           : viessmannapi          : raspiBullseye                            -  enabled
                                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspiBullseye                            - disabled
                                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspiBullseye                            - disabled
                                          system.adapter.vis-icontwo.0            : vis-icontwo           : raspiBullseye                            - disabled
                                          system.adapter.vis-inventwo.0           : vis-inventwo          : raspiBullseye                            -  enabled
                                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspiBullseye                            - disabled
                                          system.adapter.vis-map.0                : vis-map               : raspiBullseye                            - disabled
                                          system.adapter.vis-material-advanced.0  : vis-material-advanced : raspiBullseye                            - disabled
                                          system.adapter.vis-metro.0              : vis-metro             : raspiBullseye                            - disabled
                                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspiBullseye                            - disabled
                                          system.adapter.vis.0                    : vis                   : raspiBullseye                            -  enabled
                                          system.adapter.yahka.0                  : yahka                 : raspiBullseye                            -  enabled
                                          system.adapter.zigbee.0                 : zigbee                : raspiBullseye                            -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L1100QXL-if00
                                        + instance is alive
                                        ioBroker-Repositories
                                        live-beta     : http://iobroker.live/repo/sources-dist-latest.json
                                        live-stable   : http://iobroker.live/repo/sources-dist.json
                                        Installed ioBroker-Instances
                                        Used repository: stable
                                        Adapter    "admin"        : 6.13.16  , installed 6.13.15 [Updatable]
                                        Adapter    "backitup"     : 2.10.11  , installed 2.10.11
                                        Adapter    "birthdays"    : 2.4.1    , installed 2.4.1
                                        Adapter    "bydhvs"       : 1.5.0    , installed 1.5.0
                                        Adapter    "daikin"       : 1.4.2    , installed 1.4.2
                                        Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                                        Adapter    "device-reminder": 3.1.2  , installed 1.2.9  [Updatable]
                                        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                                        Adapter    "fronius"      : 2.0.2    , installed 1.1.3  [Updatable]
                                        Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
                                        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                                        Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
                                        Adapter    "hue"          : 3.10.2   , installed 3.10.2
                                        Adapter    "ical"         : 1.13.3   , installed 1.13.3
                                        Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                                        Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                                        Adapter    "influxdb"     : 4.0.2    , installed 3.2.0  [Updatable]
                                        Adapter    "javascript"   : 7.8.0    , installed 7.1.6  [Updatable]
                                        Controller "js-controller": 5.0.19   , installed 5.0.19
                                        Adapter    "modbus"       : 6.1.0    , installed 6.1.0
                                        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                                        Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
                                        Adapter    "pushover"     : 3.0.6    , installed 3.0.6
                                        Adapter    "shelly"       : 6.8.0    , installed 6.6.1  [Updatable]
                                        Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                                        Adapter    "tankerkoenig" : 3.3.7    , installed 2.1.1  [Updatable]
                                        Adapter    "telegram"     : 3.1.0    , installed 3.0.1  [Updatable]
                                        Adapter    "trashschedule": 3.2.0    , installed 2.3.0  [Updatable]
                                        Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                                        Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
                                        Adapter    "vis"          : 1.5.4    , installed 1.5.4
                                        Adapter    "vis-icontwo"  : 1.5.0    , installed 1.3.0  [Updatable]
                                        Adapter    "vis-map"      : 1.0.5    , installed 1.0.4  [Updatable]
                                        Adapter    "web"          : 6.2.3    , installed 6.2.3
                                        Adapter    "ws"           : 2.5.10   , installed 2.5.10
                                        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                                        Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
                                        Objects and States
                                        Objects: 	23856
                                        States: 	18685
                                        Hit:1 http://archive.raspberrypi.org/debian bookworm InRelease
                                        Hit:2 http://deb.debian.org/debian bookworm InRelease
                                        Hit:4 http://security.debian.org/debian-security bookworm-security InRelease
                                        Hit:5 https://apt.grafana.com stable InRelease
                                        Hit:6 https://repos.influxdata.com/debian stable InRelease
                                        Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                                        Hit:8 https://apt.pivccu.de/piVCCU stable InRelease
                                        Pending Updates: 0
                                        *** Listening Ports ***
                                        tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          12987      996/dnsmasq
                                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      112        12949      924/mosquitto
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15458      928/sshd: /usr/sbin
                                        tcp        0      0 192.168.4.58:3000       0.0.0.0:*               LISTEN      111        15540      1064/grafana
                                        tcp6       0      0 :::1883                 :::*                    LISTEN      112        12950      924/mosquitto
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          15460      928/sshd: /usr/sbin
                                        tcp6       0      0 :::8086                 :::*                    LISTEN      999        15502      891/influxd
                                        udp        0      0 0.0.0.0:56773           0.0.0.0:*                           108        1723       429/avahi-daemon: r
                                        udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          12986      996/dnsmasq
                                        udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          12983      996/dnsmasq
                                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14766      773/dhclient
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1721       429/avahi-daemon: r
                                        udp6       0      0 :::42119                :::*                                108        1724       429/avahi-daemon: r
                                        udp6       0      0 :::5353                 :::*                                108        1722       429/avahi-daemon: r
                                        2024-03-25 16:19:04.649  - error: host.raspiBullseye Caught by controller[0]:     at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                        2024-03-25 16:19:04.650  - error: host.raspiBullseye Caught by controller[0]:     at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                                        2024-03-25 16:19:04.650  - error: host.raspiBullseye Caught by controller[0]:     at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:726:40)
                                        2024-03-25 16:19:04.651  - error: host.raspiBullseye Caught by controller[0]:     at Shelly._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7711:34)
                                        2024-03-25 16:19:04.651  - error: host.raspiBullseye Caught by controller[0]:     at runNextTicks (node:internal/process/task_queues:60:5)
                                        2024-03-25 16:19:04.652  - error: host.raspiBullseye Caught by controller[0]:     at processImmediate (node:internal/timers:447:9)
                                        2024-03-25 16:19:04.652  - warn: host.raspiBullseye instance system.adapter.shelly.0 terminated due to SIGTERM
                                        2024-03-25 16:19:04.652  - info: host.raspiBullseye instance system.adapter.shelly.0 terminated with code null ()
                                        2024-03-25 16:19:04.653  - info: host.raspiBullseye All instances are stopped.
                                        2024-03-25 16:19:04.771  - warn: host.raspiBullseye instance system.adapter.zigbee.0 terminated due to SIGTERM
                                        2024-03-25 16:19:04.772  - info: host.raspiBullseye instance system.adapter.zigbee.0 terminated with code null ()
                                        2024-03-25 16:19:04.772  - info: host.raspiBullseye All instances are stopped.
                                        2024-03-25 16:19:04.841  - warn: host.raspiBullseye instance system.adapter.web.0 terminated due to SIGTERM
                                        2024-03-25 16:19:04.842  - info: host.raspiBullseye instance system.adapter.web.0 terminated with code null ()
                                        2024-03-25 16:19:04.842  - info: host.raspiBullseye All instances are stopped.
                                        2024-03-25 16:19:04.842  - warn: host.raspiBullseye instance system.adapter.fronius.0 terminated due to SIGTERM
                                        2024-03-25 16:19:04.842  - info: host.raspiBullseye instance system.adapter.fronius.0 terminated with code null ()
                                        2024-03-25 16:19:04.843  - info: host.raspiBullseye All instances are stopped.
                                        2024-03-25 16:19:04.880  - warn: host.raspiBullseye instance system.adapter.tankerkoenig.0 terminated due to SIGTERM
                                        2024-03-25 16:19:04.880  - info: host.raspiBullseye instance system.adapter.tankerkoenig.0 terminated with code null ()
                                        2024-03-25 16:19:04.881  - info: host.raspiBullseye All instances are stopped.
                                        2024-03-25 16:19:04.960  - warn: host.raspiBullseye instance system.adapter.tuya.0 terminated due to SIGTERM
                                        2024-03-25 16:19:04.960  - info: host.raspiBullseye instance system.adapter.tuya.0 terminated with code null ()
                                        2024-03-25 16:19:04.961  - info: host.raspiBullseye All instances are stopped.
                                        2024-03-25 16:19:05.036  - info: host.raspiBullseye terminated
                                        Die Zusammenfassung liefert nun ..
                                        			v.2023-10-10
                                               Icon name: computer
                                            Architecture: arm64
                                        Kernel: 		aarch64
                                        Userland: 		arm64
                                        User-ID: 		1000
                                        X-Server: 		false
                                        			/usr/bin/npm 		10.2.4
                                        			/usr/bin/npx 		10.2.4
                                        MEMORY:
                                        Mem:            8.2G        797M        4.2G        1.1M        3.3G        7.4G
                                        Swap:           104M          0B        104M
                                        Total:          8.3G        797M        4.3G
                                        Active iob-Instances: 	1
                                        ioBroker Core: 		js-controller 		5.0.19
                                        			admin 			6.13.15
                                        ioBroker Status: 	iobroker is not running on this host.
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Objects: 		23856
                                        States: 		18685
                                        • L legro
                                          Skript v.2023-10-10
                                          *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm64
                                          Docker          : false
                                          Kernel          : aarch64
                                          Userland        : arm64
                                          CPU threads: 4
                                          Current issues:
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          pi
                                          /home/pi
                                          X-Server: 	false
                                          Desktop:
                                          Terminal: 	tty
                                          *** MEMORY ***
                                          Swap:           104M          0B        104M
                                                   7811 M total memory
                                                    758 M used memory
                                                   4011 M free memory
                                                    157 M buffer memory
                                                   3030 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          Raspberry only:
                                          oom events: 0
                                          *** FILESYSTEM ***
                                          /var:
                                          4.4G	/var/
                                          2.2G	/var/log
                                          1.8G	/var/lib
                                          USB-Devices by-id:
                                          /usr/bin/npm 		10.2.4
                                          /usr/bin/npx 		10.2.4
                                          nodejs:
                                            Version table:
                                               18.13.0+dfsg1-1 500
                                          Errors in npm tree:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          admin: 		6.13.15
                                          javascript: 	7.1.6
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects: 	23856
                                          States: 	18685
                                          Pending Updates: 0
                                          			v.2023-10-10
                                                 Icon name: computer
                                              Architecture: arm64
                                          Kernel: 		aarch64
                                          Userland: 		arm64
                                          User-ID: 		1000
                                          X-Server: 		false
                                          			/usr/bin/npm 		10.2.4
                                          			/usr/bin/npx 		10.2.4
                                          MEMORY:
                                          Swap:           104M          0B        104M
                                          			admin 			6.13.15
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Objects: 		23856
                                          States: 		18685
                                          Gar nicht. Neuinstallation von Raspberry OS 12, wie überall empfohlen.
                                          iob update
                                          iob upgrade all
                                          liefert?
