  4. Alle Updates schlagen fehl...
9 Beiträge 5 Kommentatoren 1.1k Aufrufe 6 Beobachtet
    spaceduck
    schrieb am zuletzt editiert von spaceduck
    hab seit einiger Zeit das Thema das ich keinen einzigen Adapter mehr updaten kann. Hier mal ein Beispiel aus der Shell für vis-map. Die Meldungen sind bei jedem Adapter identisch. Beim Update über die WebGUI wirft er noch zusätzlich einen "ERROR: process exited with code 25"
    NPM: 10.2.4
    nodejs: v18.19.1
    Hat da Irgendjemand eine Idee?
    Would you like to upgrade vis-map from @1.0.5 to @1.1.0 now? [(y)es, (n)o]: y
    Update vis-map from @1.0.5 to @1.1.0
    NPM version: 10.2.4
    Installing iobroker.vis-map@1.1.0... (System call)
    npm ERR! code EJSONPARSE
    npm ERR! path /volume1/opt/iobroker/package.json
    npm ERR! JSON.parse Unexpected token "r" (0x72) in JSON at position 1965 while parsing near "...roker.ws\":\"2.5.10\"}}roker.vis-metro\": \"1..."
    npm ERR! JSON.parse Failed to parse JSON data.
    npm ERR! JSON.parse Note: package.json must be actual JSON, not just JavaScript.
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-23T06_52_19_383Z-debug-0.log
    host.Attila-2 Cannot install iobroker.vis-map@1.1.0: 1
    0 verbose cli /usr/bin/node /usr/bin/npm
    1 info using npm@10.2.4
    2 info using node@v18.19.1
    3 timing npm:load:whichnode Completed in 1ms
    4 timing config:load:defaults Completed in 2ms
    5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 1ms
    6 timing config:load:builtin Completed in 1ms
    7 timing config:load:cli Completed in 6ms
    8 timing config:load:env Completed in 0ms
    9 timing config:load:file:/volume1/opt/iobroker/.npmrc Completed in 15ms
    10 timing config:load:project Completed in 20ms
    11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
    12 timing config:load:user Completed in 0ms
    13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
    14 timing config:load:global Completed in 0ms
    15 timing config:load:setEnvs Completed in 2ms
    16 timing config:load Completed in 32ms
    17 timing npm:load:configload Completed in 32ms
    18 timing config:load:flatten Completed in 3ms
    19 timing npm:load:mkdirpcache Completed in 1ms
    20 timing npm:load:mkdirplogs Completed in 0ms
    21 verbose title npm install iobroker.vis-map@1.1.0
    22 verbose argv "install" "--save-exact" "--loglevel" "error" "iobroker.vis-map@1.1.0"
    23 timing npm:load:setTitle Completed in 1ms
    24 timing npm:load:display Completed in 1ms
    25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2024-03-23T06_52_19_383Z-
    26 verbose logfile /home/iobroker/.npm/_logs/2024-03-23T06_52_19_383Z-debug-0.log
    27 timing npm:load:logFile Completed in 10ms
    28 timing npm:load:timers Completed in 0ms
    29 timing npm:load:configScope Completed in 0ms
    30 timing npm:load Completed in 67ms
    31 timing arborist:ctor Completed in 1ms
    32 silly logfile start cleaning logs, removing 100 files
    33 timing idealTree Completed in 132ms
    34 timing command:install Completed in 137ms
    35 verbose stack JSONParseError: Unexpected token "r" (0x72) in JSON at position 1965 while parsing near "...roker.ws\":\"2.5.10\"}}roker.vis-metro\": \"1..."
    35 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json-fast/lib/index.js:7:61
    35 verbose stack     at async #initTree (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:280:21)
    35 verbose stack     at async Arborist.buildIdealTree (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:193:7)
    35 verbose stack     at async Promise.all (index 1)
    35 verbose stack     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:159:5)
    35 verbose stack     at async Install.exec (/usr/lib/node_modules/npm/lib/commands/install.js:152:5)
    35 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli-entry.js:61:5)
    36 verbose cwd /volume1/opt/iobroker
    37 verbose Linux 5.15.0-101-generic
    38 verbose node v18.19.1
    39 verbose npm  v10.2.4
    40 error code EJSONPARSE
    41 error path /volume1/opt/iobroker/package.json
    42 error JSON.parse Unexpected token "r" (0x72) in JSON at position 1965 while parsing near "...roker.ws\":\"2.5.10\"}}roker.vis-metro\": \"1..."
    43 error JSON.parse Failed to parse JSON data.
    43 error JSON.parse Note: package.json must be actual JSON, not just JavaScript.
    44 verbose exit 1
    45 timing npm Completed in 2257ms
    46 verbose unfinished npm timer reify 1711176741496
    47 verbose unfinished npm timer reify:loadTrees 1711176741498
    48 verbose unfinished npm timer idealTree:init 1711176741499
    49 verbose code 1
    50 error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-23T06_52_19_383Z-debug-0.log
    HP Gen8 16GB / Ubuntu Server 20.04 LTS - Nein, ein Server braucht keine GUI…;-)
    • S spaceduck
      NPM: 10.2.4
      nodejs: v18.19.1
      NPM version: 10.2.4
      44 verbose exit 1
      49 verbose code 1
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @spaceduck
      iob stop
      iob fix
      iob start
      warten !
      dann Updates testen :)
      Lehrling seit 1975 !!!
      • DJMarc75D DJMarc75
        @spaceduck
        iob stop
        iob fix
        iob start
        warten !
        spaceduck
        @djmarc75
        iobroker fix hab ich schon versucht, bringt leider nix.
        • S spaceduck
          @djmarc75
          Meister MopperM Offline
          Meister Mopper
          @spaceduck sagte in Alle Updates schlagen fehl...:
          @djmarc75
          Na dann schieb mal bitte ein iob diag hinterher und stell das komplette Ergebnis in </> Codetags hier rein.
          Proxmox und HA ...
            spaceduck
            @meister-mopper
            das kannte ich noch gar nicht, diag meldet was mit nodejs
            Vermutlich der Pfad... /usr/local/bin/npx
            			v.2023-10-10
             Static hostname: Attila-2
                   Icon name: computer-desktop
                     Chassis: desktop
            Operating System: Ubuntu 22.04.4 LTS
                      Kernel: Linux 5.15.0-101-generic
                Architecture: x86-64
             Hardware Vendor: HP
              Hardware Model: ProLiant MicroServer Gen8
            Installation: 		native
            Kernel: 		x86_64
            Userland: 		amd64
            Timezone: 		Europe/Berlin (CET, +0100)
            User-ID: 		1005
            X-Server: 		false
            Boot Target: 		graphical.target
            Pending OS-Updates: 	0
            Pending iob updates: 	12
            Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.1
            			/usr/bin/node 		v18.19.1
            			/usr/bin/npm 		10.2.4
            			/usr/local/bin/npx 		8.6.0
            			/usr/bin/corepack 	0.22.0
            Recommended versions are nodejs 18.19.1 and npm 10.2.4
            *** nodejs is NOT correctly installed ***
            Wrong installation path detected. This needs to be fixed.
            Please check
            https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
            for more information on how to fix these errors.
            MEMORY:
            Mem:             15G        8.9G        209M         50M        6.8G        6.6G
            Swap:           4.1G        2.2G        1.9G
            Total:           19G         11G        2.1G
            Active iob-Instances: 	29
            Active repo(s): Beta (latest)
            ioBroker Core: 		js-controller 		5.0.19
            			admin 			6.14.1
            ioBroker Status: 	iobroker is running on this host.
            Objects type: jsonl
            States  type: jsonl
            + system.adapter.admin.0                  : admin                 : Attila-2                                 -  enabled, port: 8081, bind: 192.168.178.88, run as: admin
            + system.adapter.web.0                    : web                   : Attila-2                                 -  enabled, port: 8082, bind: 192.168.178.88, run as: admin
            Objects: 		44649
            States: 		44729
            Size of iob-Database:
            45M	/opt/iobroker/iobroker-data/objects.jsonl
            58M	/opt/iobroker/iobroker-data/states.jsonl
            • S spaceduck
              @meister-mopper
              			v.2023-10-10
                       Chassis: desktop
               Hardware Vendor: HP
              Kernel: 		x86_64
              Userland: 		amd64
              User-ID: 		1005
              X-Server: 		false
              			/usr/bin/npm 		10.2.4
              Please check
              MEMORY:
              Total:           19G         11G        2.1G
              			admin 			6.14.1
              Objects type: jsonl
              States  type: jsonl
              Objects: 		44649
              States: 		44729
              Stell das auf multi-user.target:
              sudo systemctl set-default multi-user.target
              Dann fix nodejs:
              iob stop
              iob fix
              iob nodejs-update
                Dann fix nodejs:
                iob stop
                iob fix
                iob nodejs-update
                spaceduck
                Erl. hat aber leider nix gebracht.
                Egal welchen Adapter ich updaten möchte, er wirft immer die identische Fehlermeldung:
                ERR! JSON.parse Unexpected token "r" (0x72) in JSON at position 1965 while parsing near "...roker.ws\":\"2.5.10\"}}roker.vis-metro\": \"1..."npm ERR! JSON.parse Failed to parse JSON data.npm ERR! JSON.parse Note: package.json must be actual JSON, not just JavaScript.npm ERR!
                • Selbst wenn ich den Metro Adapter lösche kommt diese Meldung,
                • Diese Meldung ist mir nicht klar, welche Datei meckert er an? "parsing near" ist nicht gerade präzise, die Pfade sind nicht eindeutig. Ich hab alle Dateien angeschaut die in Frage kommen, finde da keinen Fehler drin.
                • S spaceduck
                  mcm1957M Online
                  mcm1957M Online
                  mcm1957
                  @spaceduck
                  Die Datei package.json ist nicht parsebar.
                  Auf Grund der vorhergehenden Zeile tippe ich auf /opt/iobroker/pacakge.json. Check diese Mal auf einwandfreie Syntax. Siehst so aus als würde da am Ende noch was von metro stehen was danicht hingeört.
                  ABER sicher die Datei jedenfalls bevor du was änderst.
                  Support Repositoryverwaltung.
                  LESEN - gute Forenbeitrage
                  • mcm1957M mcm1957
                    @spaceduck
                    spaceduck
                    @mcm57
                    Dein Tipp war goldrichtig, die Datei package.json war vermurkst - ich hab es korrigiert und jetzt funktioniert es!
                    Danke!!!
