[gelöst] MQTT Adapter schaltet Rolladen beim neustart
ich habe beim neu Aufsetzen von meinem iobroker das Problem dass er auf einmal bei jedem Neustart vom MQTT Adapter meine Rollladen Shellies schaltet und meine Rollladen runter fährt. hat jemand eine Idee was da falsch läuft? Finde es nicht.
Christian
Christian
@mickym Im Log steht nur:
mqtt.0 2024-03-18 17:04:52.872 info Client [shellyswitch25-C45BBE7642B7] subscribes on "mqtt.0.shellies.Rollladen-Süd-Gross.relay.0.command" mqtt.0 2024-03-18 17:04:52.864 info Client [shellyswitch25-C45BBE7642B7] subscribes on "mqtt.0.shellies.Rollladen-Süd-Gross.relay.1.command" mqtt.0 2024-03-18 17:04:52.853 info Client [shellyswitch25-C45BBE7642B7] subscribes on "mqtt.0.shellies.Rollladen-Süd-Gross.roller.0.command" mqtt.0 2024-03-18 17:04:52.850 info Client [shellyswitch25-C45BBE7642B7] subscribes on "mqtt.0.shellies.Rollladen-Süd-Gross.roller.0.command.pos" mqtt.0 2024-03-18 17:04:52.847 info Client [shellyswitch25-C45BBE7642B7] subscribes on "mqtt.0.shellies.Rollladen-Süd-Gross.command" mqtt.0 2024-03-18 17:04:52.794 info Client [shellyswitch25-C45BBE7642B7] subscribes on "mqtt.0.shellies.command" mqtt.0 2024-03-18 17:04:52.746 info Client [shellyswitch25-C45BBE7642B7] connected with secret 1710781492743_9939 mqtt.0 2024-03-18 17:04:51.233 info Client [shellyswitch25-C45BBE765D8B] publishOnSubscribe mqtt.0 2024-03-18 17:04:51.231 info Client [shellyswitch25-C45BBE765D8B] publishOnSubscribe mqtt.0 2024-03-18 17:04:51.224 info Client [shellyswitch25-C45BBE765D8B] publishOnSubscribe mqtt.0 2024-03-18 17:04:51.195 info Client [shellyswitch25-C45BBE765D8B] publishOnSubscribe mqtt.0 2024-03-18 17:04:51.193 info Client [shellyswitch25-C45BBE765D8B] publishOnSubscribe mqtt.0 2024-03-18 17:04:51.190 info Client [shellyswitch25-C45BBE765D8B] publishOnSubscribe mqtt.0 2024-03-18 17:04:51.029 info Client [shellyswitch25-C45BBE765D8B] subscribes on "mqtt.0.shellies.Rolladen-Ost.relay.0.command" mqtt.0 2024-03-18 17:04:51.025 info Client [shellyswitch25-C45BBE765D8B] subscribes on "mqtt.0.shellies.Rolladen-Ost.relay.1.command" mqtt.0 2024-03-18 17:04:51.022 info Client [shellyswitch25-C45BBE765D8B] subscribes on "mqtt.0.shellies.Rolladen-Ost.roller.0.command" mqtt.0 2024-03-18 17:04:50.992 info Client [shellyswitch25-C45BBE765D8B] subscribes on "mqtt.0.shellies.Rolladen-Ost.roller.0.command.pos" mqtt.0 2024-03-18 17:04:50.990 info Client [shellyswitch25-C45BBE765D8B] subscribes on "mqtt.0.shellies.Rolladen-Ost.command" mqtt.0 2024-03-18 17:04:50.987 info Client [shellyswitch25-C45BBE765D8B] subscribes on "mqtt.0.shellies.command" mqtt.0 2024-03-18 17:04:50.902 info Client [shellyswitch25-C45BBE765D8B] connected with secret 1710781490899_3115 -
Ja das ist ja richtig. Betreibst du den Adapter als Server/Broker?
Oder hast Du in den mqtt-Einstellungen auch nur irgendwas angehakt?
Am Besten ist es alle Haken rauszunehmen - grundsätzlich!
@mickym danke für den Tip aber ich hatte schon nur den Haken bei "Nur bei Änderung publizieren", den habe ich jetzt raus genommen und beim Neustart des Adapters hat er wieder die Rollladen runter gefahren.
Der Haken "Publish on subscribe" o.ä. unter dem Tab "Server settings" muss rausgenommen werden.
@marc-berg Danke das war der richtige Hinweis! Jetzt funktioniert es.
