  4. Node-Red
  5. Node Red unter Verbrauchswert ausschalten; Zeit X überprüfen
    6.4k
30 Beiträge 2 Kommentatoren 3.9k Aufrufe 1 Beobachtet
  • mickymM mickym
    @speedyblade Was geht denn nicht? - Simuliere mit einer Inject Node
    Bei mir tut das - hier der Import:
    [{"id":"be819e72c7061018","type":"trigger","z":"27cc87995d951128","name":"","op1":"","op2":"true","op1type":"nul","op2type":"bool","duration":"5","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":880,"y":2040,"wires":[["76e0bdd57834682e"]]},{"id":"71ef549593e22ebc","type":"switch","z":"27cc87995d951128","name":">=0.1W & <=2W","property":"payload","propertyType":"msg","rules":[{"t":"btwn","v":"0.1","vt":"num","v2":"2","v2t":"num"},{"t":"else"}],"checkall":"false","repair":false,"outputs":2,"x":470,"y":2060,"wires":[["be819e72c7061018"],["ad5bb04d6ab2a5bc"]]},{"id":"ad5bb04d6ab2a5bc","type":"change","z":"27cc87995d951128","name":"","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":680,"y":2080,"wires":[["be819e72c7061018"]]},{"id":"76e0bdd57834682e","type":"debug","z":"27cc87995d951128","name":"Ausgabe","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1060,"y":2040,"wires":[]},{"id":"7b67129ae4f5e1b2","type":"inject","z":"27cc87995d951128","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"0.5","payloadType":"num","x":230,"y":2040,"wires":[["71ef549593e22ebc"]]},{"id":"3253b2c45f52ae5c","type":"inject","z":"27cc87995d951128","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"2.5","payloadType":"num","x":230,"y":2080,"wires":[["71ef549593e22ebc"]]}]
    Es wird true ausgegeben, solange innerhalb von 5 s kein anderer Wert ausserhalb des Bereiches ankommt.
    SpeedyBlade
    schrieb am zuletzt editiert von SpeedyBlade
    "bei dem Change: 2 Regeln"...wie bekomme ich das "True" vom Trigger auf ein "False"?
    dies funktioniert leider nicht
    • S SpeedyBlade
      mickymM Offline
      mickymM Offline
      mickym
      @speedyblade Na das ist doch logisch dass das nicht funktioniert.
      Die Regeln werden nacheinander abgearbeitet und somit wird true in false gewandelt und dann in der nächsten Regel von false in true.
      Somit kommt IMMER true raus!!!
      Entweder gehst du den Umweg über einen anderen Datentyp oder Du nutzt JSONATA.
      [{"id":"a2d172906a0da2d1","type":"inject","z":"27cc87995d951128","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":350,"y":2220,"wires":[["0908c548b6730d44"]]},{"id":"9f5050ef1bca1f4d","type":"inject","z":"27cc87995d951128","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"false","payloadType":"bool","x":350,"y":2260,"wires":[["0908c548b6730d44"]]},{"id":"877f320de1de7259","type":"debug","z":"27cc87995d951128","name":"toggle","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":710,"y":2240,"wires":[]},{"id":"0908c548b6730d44","type":"change","z":"27cc87995d951128","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$not(payload)\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":530,"y":2240,"wires":[["877f320de1de7259"]]}]
      • S SpeedyBlade
        mickymM Offline
        mickymM Offline
        mickym
        @speedyblade Wenn Du aber AUSSCHALTEN willst warum machst DU nicht einfach in der TRIGGER Node ein false.
        Für Alexa änderst Du doch die payload sowieso. Also brauchst Du doch gar nicht wandeln!!
        S 2 Antworten Letzte Antwort
        • mickymM mickym
          SpeedyBlade
          scheint nun zu funktionieren
          hab das nun so gelöst...
          weil das true brauch ich da ja eh nie ;)
          für mein Verständnis
          wird hier der payload einfach invertiert?
          • mickymM mickym
            SpeedyBlade
            @mickym
            wenn die nette Dame damit was anfangen kann, hast du natürlich Recht
            wird gleich getestet => soeben getestet...Alexa ist true oder false egal...in dem Fall hab ich das nun so gelöst...
            besten Dank...
            muss ganz ehrlich sagen, ich liebe das Forum, da wird einem so schnell geholfen 👍 👍 👍
            • S SpeedyBlade
              mickymM Offline
              mickymM Offline
              mickym
              @speedyblade
              Ja Du siehst ja im JSONATA Editor eine Kurzerklärung
              • mickymM mickym
                @speedyblade
                SpeedyBlade
                @mickym
                ich möchte eh mal eine NodeRed Schulung machen...vielleicht kannst du ja was empfehlen.
                Das was ich bis dato gemacht habe...try and error ;)
                noch ne Frage...
                wie bekomme ich da noch ein "und" rein?
                und zwar soll Shelly nur aktiviert werden, wenn der die Leistung erreicht ist und auch der Shelly Plug S ein ist und genau letzteres muss ich noch mit rein bringen, ansonsten meldet die Tante nämlich immer, wenn der Plug S ausgeschalten wurde, nochmals...
                • S SpeedyBlade
                  @mickym
                  noch ne Frage...
                  mickymM Offline
                  mickymM Offline
                  mickym
                  @speedyblade sagte in Node Red unter Verbrauchswert ausschalten; Zeit X überprüfen:
                  Indem Du die Abfragen in Serie schaltest. Sprich indem Du im positiv Ast über die Get-Node den Zustand holst und dann mit einer weiteren Switch Node filterst.
                  • S SpeedyBlade
                    @mickym
                    noch ne Frage...
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @speedyblade Hier hatte ich mal ein paar Links zusammengestellt: https://forum.iobroker.net/post/470328
                    • mickymM mickym
                      SpeedyBlade
                      @mickym sagte in Node Red unter Verbrauchswert ausschalten; Zeit X überprüfen:
                      Get-Node
                      wo bekomme ich die "Get-Node"?
                      • S SpeedyBlade
                        Get-Node
                        mickymM Offline
                        mickymM Offline
                        mickym
                        Get-Node
                        Wieso die sind doch alle da?
                        • mickymM mickym
                          Get-Node
                          SpeedyBlade
                          • S SpeedyBlade
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @speedyblade
                            Datentyp???? - Du musst fragen ob true ist und nicht strings vergleichen
                            • mickymM mickym
                              @speedyblade
                              SpeedyBlade
                              das meinst du?
                              • S SpeedyBlade
                                das meinst du?
                                mickymM Offline
                                mickymM Offline
                                mickym
                                @speedyblade ja
                                • mickymM mickym
                                  @speedyblade ja
                                  SpeedyBlade
                                  @mickym
                                  irgendwie schaltet der so nun aber nicht mehr :(
                                  "id": "f8080a011db92103",
                                  "type": "template",
                                  "z": "aa961794.080218",
                                  "g": "598174313e10476d",
                                  "name": "Waschvorgang beendet",
                                  "field": "payload",
                                  "fieldType": "msg",
                                  "format": "handlebars",
                                  "syntax": "mustache",
                                  "template": "<speak> \n<s>Der Waschvorgang ist beendet, bitte die Wäsche nun trocknen!</s>\n</speak>",
                                  "output": "str",
                                  "x": 870,
                                  "y": 3760,
                                  "wires": [
                                  "6a36a8f4a3373c26"
                                  "id": "1d9e971bfbac9b9c",
                                  "type": "switch",
                                  "name": "zw. 0,0 - 2,0",
                                  "property": "payload",
                                  "propertyType": "msg",
                                  "rules": [
                                  "t": "btwn",
                                  "v": "0.0",
                                  "vt": "num",
                                  "v2": "2.0",
                                  "v2t": "num"
                                  "t": "else"
                                  "checkall": "false",
                                  "repair": false,
                                  "outputs": 2,
                                  "x": 250,
                                  "y": 3760,
                                  "wires": [
                                  "2b8bd472c67f5ff5"
                                  "644c6d663ca6d02e"
                                  "id": "5c161379df3ad577",
                                  "type": "trigger",
                                  "name": "",
                                  "op1": "",
                                  "op2": "false",
                                  "op1type": "nul",
                                  "op2type": "bool",
                                  "duration": "15",
                                  "extend": false,
                                  "overrideDelay": false,
                                  "units": "s",
                                  "reset": "",
                                  "bytopic": "all",
                                  "topic": "topic",
                                  "outputs": 1,
                                  "x": 630,
                                  "y": 3840,
                                  "wires": [
                                  "4641a1744f9f817d",
                                  "f8080a011db92103"
                                  "id": "644c6d663ca6d02e",
                                  "type": "change",
                                  "name": "",
                                  "rules": [
                                  "t": "set",
                                  "p": "reset",
                                  "pt": "msg",
                                  "to": "true",
                                  "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 280,
                                  "y": 3840,
                                  "wires": [
                                  "5c161379df3ad577"
                                  "id": "4641a1744f9f817d",
                                  "type": "delay",
                                  "name": "",
                                  "pauseType": "delay",
                                  "timeout": "15",
                                  "timeoutUnits": "seconds",
                                  "rate": "1",
                                  "nbRateUnits": "10",
                                  "rateUnits": "second",
                                  "randomFirst": "1",
                                  "randomLast": "5",
                                  "randomUnits": "seconds",
                                  "drop": true,
                                  "allowrate": false,
                                  "outputs": 1,
                                  "x": 890,
                                  "y": 3840,
                                  "wires": [
                                  "392397818a8cebec"
                                  "id": "9059ca436bcf8d07",
                                  "type": "switch",
                                  "name": "wenn Shelly ein",
                                  "rules": [
                                  "t": "true"
                                  "repair": false,
                                  "outputs": 1,
                                  "x": 600,
                                  "y": 3760,
                                  "wires": [
                                  "5c161379df3ad577"
                                  "id": "2b8bd472c67f5ff5",
                                  "type": "ioBroker get",
                                  "name": "Shelly Status",
                                  "topic": "",
                                  "attrname": "payload",
                                  "payloadType": "value",
                                  "errOnInvalidState": "nothing",
                                  "x": 430,
                                  "y": 3760,
                                  "wires": [
                                  "9059ca436bcf8d07"
                                  "id": "bb143b342373c4b3",
                                  "type": "inject",
                                  "name": "",
                                  "props": [
                                  "p": "payload"
                                  "p": "topic",
                                  "vt": "str"
                                  "repeat": "",
                                  "crontab": "",
                                  "once": false,
                                  "onceDelay": 0.1,
                                  "topic": "",
                                  "payload": "",
                                  "payloadType": "date",
                                  "x": 100,
                                  "y": 3760,
                                  "wires": [
                                  "1d9e971bfbac9b9c"
                                  "id": "392397818a8cebec",
                                  "type": "debug",
                                  "name": "debug 5",
                                  "active": true,
                                  "tosidebar": true,
                                  "console": false,
                                  "tostatus": false,
                                  "complete": "false",
                                  "statusVal": "",
                                  "statusType": "auto",
                                  "x": 1070,
                                  "y": 3840,
                                  "wires": []
                                  "id": "6a36a8f4a3373c26",
                                  "type": "debug",
                                  "name": "debug 6",
                                  "active": true,
                                  "tosidebar": true,
                                  "console": false,
                                  "tostatus": false,
                                  "statusVal": "",
                                  "x": 1090,
                                  "y": 3760,
                                  "wires": []
                                  • S SpeedyBlade
                                    @mickym
                                    "type": "template",
                                    "field": "payload",
                                    "fieldType": "msg",
                                    "output": "str",
                                    "x": 870,
                                    "y": 3760,
                                    "wires": [
                                    "6a36a8f4a3373c26"
                                    "type": "switch",
                                    "rules": [
                                    "t": "btwn",
                                    "v": "0.0",
                                    "vt": "num",
                                    "v2": "2.0",
                                    "v2t": "num"
                                    "t": "else"
                                    "repair": false,
                                    "outputs": 2,
                                    "x": 250,
                                    "y": 3760,
                                    "wires": [
                                    "2b8bd472c67f5ff5"
                                    "644c6d663ca6d02e"
                                    "type": "trigger",
                                    "name": "",
                                    "op1": "",
                                    "op2": "false",
                                    "op1type": "nul",
                                    "op2type": "bool",
                                    "duration": "15",
                                    "extend": false,
                                    "units": "s",
                                    "reset": "",
                                    "bytopic": "all",
                                    "topic": "topic",
                                    "outputs": 1,
                                    "x": 630,
                                    "y": 3840,
                                    "wires": [
                                    "4641a1744f9f817d",
                                    "f8080a011db92103"
                                    "type": "change",
                                    "name": "",
                                    "rules": [
                                    "t": "set",
                                    "p": "reset",
                                    "pt": "msg",
                                    "to": "true",
                                    "tot": "bool"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 280,
                                    "y": 3840,
                                    "wires": [
                                    "5c161379df3ad577"
                                    "type": "delay",
                                    "name": "",
                                    "timeout": "15",
                                    "rate": "1",
                                    "randomFirst": "1",
                                    "randomLast": "5",
                                    "drop": true,
                                    "allowrate": false,
                                    "outputs": 1,
                                    "x": 890,
                                    "y": 3840,
                                    "wires": [
                                    "392397818a8cebec"
                                    "type": "switch",
                                    "rules": [
                                    "t": "true"
                                    "repair": false,
                                    "outputs": 1,
                                    "x": 600,
                                    "y": 3760,
                                    "wires": [
                                    "5c161379df3ad577"
                                    "topic": "",
                                    "x": 430,
                                    "y": 3760,
                                    "wires": [
                                    "9059ca436bcf8d07"
                                    "type": "inject",
                                    "name": "",
                                    "props": [
                                    "p": "payload"
                                    "p": "topic",
                                    "vt": "str"
                                    "repeat": "",
                                    "crontab": "",
                                    "once": false,
                                    "onceDelay": 0.1,
                                    "topic": "",
                                    "payload": "",
                                    "x": 100,
                                    "y": 3760,
                                    "wires": [
                                    "1d9e971bfbac9b9c"
                                    "type": "debug",
                                    "name": "debug 5",
                                    "active": true,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "statusVal": "",
                                    "x": 1070,
                                    "y": 3840,
                                    "wires": []
                                    "type": "debug",
                                    "name": "debug 6",
                                    "active": true,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "statusVal": "",
                                    "x": 1090,
                                    "y": 3760,
                                    "wires": []
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    @speedyblade
                                    1. Zum einen ein Flow zu exportieren muss immer in CodeTags sein.
                                    2. Nutze halt INJECT und Debug Nodes.
                                    In meinem Flow habe ich Dir doch 2 Inject Nodes mit unterschiedlichen Werten gezeigt. Dann nutz die halt und schau wie weit Dein Nachrichtenobjekt kommt.
                                    Wenn es vorher gegangen ist und jetzt nicht mehr, dann liegt es wohl an diesen beiden Nodes:
                                    Also mach eine Inject Node vorne dran und hinter die Switch node eine debug Node und schau ob die Nachrichten durchkommen wenn der Shelly eingeschaltet ist.
                                    Wenn nur connected im Status steht wurde die get Node entweder nicht getriggert oder der DP ist falsch oder wurde nicht ausgelesen.
                                    • mickymM mickym
                                      @speedyblade
                                      SpeedyBlade
                                      so funktioniert es...
                                      • S SpeedyBlade
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        @speedyblade Du hast hoffentlich nicht im Adapter eingestellt, dass alle iobroker Werte in Strings gewandelt werden.
                                        • mickymM mickym
                                          SpeedyBlade
                                          das war wohl so im Standard eigestellt
                                          was ist mit Zeichenfolge gemeint?
