  4. ioBroker Admin-GUI lässt sich nicht mehr öffnen
40 Beiträge 3 Kommentatoren 6.3k Aufrufe 2 Beobachtet
  • D danielos
    @thomas-braun Sehr gerne, danke...
    			v.2023-10-10
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.4.79-v7l+
          Architecture: arm
    Installation: 		native
    Kernel: 		armv7l
    Userland: 		armhf
    Timezone: 		Europe/Berlin (CET, +0100)
    User-ID: 		1000
    X-Server: 		false
    Boot Target: 		graphical.target
    Pending OS-Updates: 	33
    node:internal/modules/cjs/loader:1137
      throw err;
    Error: Cannot find module 'graceful-fs'
    Require stack:
    - /opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/fs-extra/lib/fs/index.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/fs-extra/lib/index.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js
    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
        at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
        at Module._load (node:internal/modules/cjs/loader:975:27)
        at Module.require (node:internal/modules/cjs/loader:1225:19)
        at require (node:internal/modules/helpers:177:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/fs-extra/lib/fs/index.js:5:12)
        at Module._compile (node:internal/modules/cjs/loader:1356:14)
        at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
        at Module.load (node:internal/modules/cjs/loader:1197:32)
        at Module._load (node:internal/modules/cjs/loader:1013:12)
        at Module.require (node:internal/modules/cjs/loader:1225:19) {
      code: 'MODULE_NOT_FOUND',
      requireStack: [
        '/opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/fs-extra/lib/fs/index.js',
        '/opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/fs-extra/lib/index.js',
        '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js',
        '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    Node.js v18.19.1
    Pending iob updates: 	0
    Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.1
    			/usr/bin/node 		v18.19.1
    			/usr/bin/npm 		10.5.0
    			/usr/bin/npx 		10.5.0
    			/usr/bin/corepack 	0.22.0
    Recommended versions are nodejs  and npm
    MEMORY:
    Mem:           3.8G        135M        3.0G        8.0M        694M        3.5G
    Swap:           99M          0B         99M
    Total:         3.9G        135M        3.1G
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.19.1
    Active iob-Instances: 	0
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.19.1
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.19.1
    ioBroker Core: 		js-controller
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.19.1
    			admin
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.19.1
    ioBroker Status:
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.19.1
    Objects: 		0
    States: 		0
    Size of iob-Database:
    23M	/opt/iobroker/iobroker-data/objects.jsonl
    16M	/opt/iobroker/iobroker-data/objects.json.migrated
    16M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
    6.6M	/opt/iobroker/iobroker-data/states.jsonl
    4.4M	/opt/iobroker/iobroker-data/states.json.migrated
    4.4M	/opt/iobroker/iobroker-data/states.json.bak.migrated
    0	/opt/iobroker/iobroker-data/states.json.broken
    @danielos sagte in ioBroker Admin-GUI lässt sich nicht mehr öffnen:
    SUMMARY
    ist nicht die
    @thomas-braun sagte in ioBroker Admin-GUI lässt sich nicht mehr öffnen:
    Langfassung
    • D danielos
      			v.2023-10-10
               Icon name: computer
            Architecture: arm
      Kernel: 		armv7l
      Userland: 		armhf
      User-ID: 		1000
      X-Server: 		false
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.1
      			/usr/bin/npm 		10.5.0
      			/usr/bin/npx 		10.5.0
      MEMORY:
      Swap:           99M          0B         99M
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.1
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.1
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.1
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.1
      			admin
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.1
      ioBroker Status:
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.1
      Objects: 		0
      States: 		0
        	/usr/bin/npm 		10.5.0
      Falsche Version. Da muss 10.2.4 gemeldet werden. Haste also von Hand rumgefummelt. npm wird NIE separat angepackt, das kommt immer in passender Version beim Paket nodejs mit.
      Also:
      sudo apt update
      sudo apt install --reinstall nodejs
      Dann
      cd /opt/iobroker
      sudo -H -u iobroker npm install iobroker.js-controller
          	/usr/bin/npm 		10.5.0
        Also:
        sudo apt update
        Dann
        cd /opt/iobroker
        danielos
        schrieb am zuletzt editiert von danielos
        @thomas-braun Ja, ich habe im Netz geschaut, was man machen muss, wenn die Fehlermeldung kommt. War aber scheinbar keine gute Idee.. :-(
        Ich habe nun alles gemacht. Es gab folgende (Fehler)-Meldung bei der Installation:
        pi@raspberrypi:~ $ sudo apt update
        Holen:1 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
        Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
        OK:3 https://deb.nodesource.com/node_18.x nodistro InRelease
        E: Für das Depot »http://raspbian.raspberrypi.org/raspbian buster InRelease« wurde der »Suite«-Wert von »stable« in »oldoldstable« geändert.
        N: Sie müssen dies explizit bestätigen, bevor Aktualisierungen von diesem Depot angewendet werden können. Lesen Sie die apt-secure(8)-Handbuchseite, wenn Sie weitere Informationen benötigen.
        E: Für das Depot »http://archive.raspberrypi.org/debian buster InRelease« wurde der »Suite«-Wert von »testing« in »oldoldstable« geändert.
        Möchten Sie diese Änderungen übernehmen und mit der Aktualisierung von diesem Depot fortfahren? [j/N] j
        Holen:4 http://archive.raspberrypi.org/debian buster/main armhf Packages [400 kB]
        Es wurden 447 kB in 3 s geholt (162 kB/s).
        E: Fehlschlag beim Holen von http://raspbian.raspberrypi.org/raspbian/dists/buster/InRelease
        E: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
        pi@raspberrypi:~ $ sudo apt install --reinstall nodejs
        Abhängigkeitsbaum wird aufgebaut.... 0%
        0 aktualisiert, 0 neu installiert, 1 erneut installiert, 0 zu entfernen und 65 nicht aktualisiert.
        Es müssen noch 0 B von 27,1 MB an Archiven heruntergeladen werden.
        Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
        (Lese Datenbank ... 63494 Dateien und Verzeichnisse sind derzeit installiert.)
        Vorbereitung zum Entpacken von .../nodejs_18.19.1-1nodesource1_armhf.deb ...
        Detected old npm client, removing...
        Entpacken von nodejs (18.19.1-1nodesource1) über (18.19.1-1nodesource1) ...
        nodejs (18.19.1-1nodesource1) wird eingerichtet ...
        Trigger für man-db (2.8.5-2) werden verarbeitet ...
        pi@raspberrypi:~ $ cd /opt/iobroker
        pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
        npm WARN skipping integrity check for git dependency ssh://git@github.com/92lleo/ioBroker.solaredge.git
        npm WARN tar zlib: unexpected end of file
        npm WARN tarball cached data for iobroker.icons-fatcow-hosting@https://registry.npmjs.org/iobroker.icons-fatcow-hosting/-/iobroker.icons-fatcow-hosting-0.1.0.tgz (sha512-PnrPbAfpdXki9YSZzZKe48U8qgsPhpFfLjroZyL8t5/XfxHnm+HXiZoM+vGzKj0VwCpcS246SNbu4jMuodg5zQ==) seems to be corrupted. Refreshing cache.
        npm WARN tarball cached data for echarts@https://registry.npmjs.org/echarts/-/echarts-5.5.0.tgz (sha512-rNYnNCzqDAPCr4m/fqyUFv7fD9qIsd50S6GDFgO1DxZhncCsNsG7IfUlAlvZe5oSEQxtsjnHiUuppzccry93Xw==) seems to be corrupted. Refreshing cache.
        npm WARN tarball cached data for typescript@https://registry.npmjs.org/typescript/-/typescript-4.9.5.tgz (sha512-1FXk9E2Hm+QzZQ7z+McJiHL4NW1F2EzMu9Nq9i3zAaGqibafqYwCVU6WyWAuyQRRzOlxou8xZSyXLEN8oKj24g==) seems to be corrupted. Refreshing cache.
        npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
        npm WARN deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
        npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
        npm WARN deprecated abab@2.0.6: Use your platform's native atob() and btoa() methods instead
        npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
        npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
        npm WARN deprecated w3c-hr-time@1.0.2: Use your platform's native performance.now() and performance.timeOrigin.
        npm WARN deprecated domexception@4.0.0: Use your platform's native DOMException instead
        npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
        npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        npm WARN deprecated @azure/msal-node@1.18.4: A newer major version of this library is available. Please upgrade to the latest available version.
        npm WARN deprecated later@1.2.0: Please upgrade to the maintained and new drop-in replacement @breejs/later at https://github.com/breejs/later 🚀 Thanks and happy hacking! 🚀  @niftylettuce
        npm WARN deprecated hafas-client@5.26.5: I don't have the capacity to maintain older versions of hafas-client, sorry. Please use hafas-client@latest.
        npm WARN deprecated @azure/msal-browser@2.38.3: A newer major version of this library is available. Please upgrade to the latest available version.
        npm WARN cleanup Failed to remove some directories [
        npm WARN cleanup   [
        npm WARN cleanup     '/opt/iobroker/node_modules/mdns',
        npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/mdns'] {
        npm WARN cleanup       errno: -39,
        npm WARN cleanup       code: 'ENOTEMPTY',
        npm WARN cleanup       syscall: 'rmdir',
        npm WARN cleanup       path: '/opt/iobroker/node_modules/mdns'
        npm WARN cleanup     }
        npm WARN cleanup   ],
        npm WARN cleanup   [
        npm WARN cleanup     '/opt/iobroker/node_modules/unix-dgram',
        npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/unix-dgram'] {
        npm WARN cleanup       path: '/opt/iobroker/node_modules/unix-dgram'
        npm WARN cleanup     }
        npm WARN cleanup   ],
        npm WARN cleanup   [
        npm WARN cleanup     }
        npm WARN cleanup   ],
        npm WARN cleanup   [
        npm WARN cleanup     }
        npm WARN cleanup   ]
        npm WARN cleanup ]
        npm ERR! code 22
        npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
        npm ERR! command failed
        npm ERR! command sh -c node iobroker.js setup first
        npm ERR! No connection to databases possible ...
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-16T10_05_30_688Z-debug-0.log
        Und nach einem erneuten stop / fix / start / diag heisst's folgendes:
        			v.2023-10-10
                 Icon name: computer
              Architecture: arm
        Kernel: 		armv7l
        Userland: 		armhf
        User-ID: 		1000
        X-Server: 		false
        Pending OS-Updates: 	60
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.1
        			/usr/bin/npm 		10.2.4
        			/usr/bin/npx 		10.2.4
        MEMORY:
        Mem:           3.8G        156M        3.0G         24M        634M        3.5G
        Swap:           99M          0B         99M
        Total:         3.9G        156M        3.1G
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.1
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.1
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.1
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.1
        			admin
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.1
        ioBroker Status:
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.1
        Objects: 		0
        States: 		0
        Also scheinbar hat's noch nicht alles behoben.... der Start vom Admin-Adapter wird noch mit der selben Fehlermeldung abgebrochen:
        pi@raspberrypi:~ $ iob start admin.0
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.1
        • D danielos
          npm WARN cleanup   [
          npm WARN cleanup     }
          npm WARN cleanup   ],
          npm WARN cleanup   [
          npm WARN cleanup     }
          npm WARN cleanup   ],
          npm WARN cleanup   [
          npm WARN cleanup     }
          npm WARN cleanup   ],
          npm WARN cleanup   [
          npm WARN cleanup     }
          npm WARN cleanup   ]
          npm WARN cleanup ]
          npm ERR! code 22
          			v.2023-10-10
                   Icon name: computer
                Architecture: arm
          Kernel: 		armv7l
          Userland: 		armhf
          User-ID: 		1000
          X-Server: 		false
            throw err;
          Require stack:
            requireStack: [
          Node.js v18.19.1
          			/usr/bin/npm 		10.2.4
          			/usr/bin/npx 		10.2.4
          MEMORY:
          Swap:           99M          0B         99M
            throw err;
          Require stack:
            requireStack: [
          Node.js v18.19.1
            throw err;
          Require stack:
            requireStack: [
          Node.js v18.19.1
            throw err;
          Require stack:
            requireStack: [
          Node.js v18.19.1
            throw err;
          Require stack:
            requireStack: [
          Node.js v18.19.1
          			admin
            throw err;
          Require stack:
            requireStack: [
          Node.js v18.19.1
          ioBroker Status:
            throw err;
          Require stack:
            requireStack: [
          Node.js v18.19.1
          Objects: 		0
          States: 		0
            throw err;
          Require stack:
            requireStack: [
          Node.js v18.19.1
          @danielos
          sudo apt update
          sudo apt upgrade
            @danielos
            sudo apt update
            sudo apt upgrade
            danielos
            @thomas-braun Gemacht und dann wieder stop / fix ... Resultat leider immer noch unverändert, wie es scheint.
            			v.2023-10-10
                     Icon name: computer
                  Architecture: arm
            Kernel: 		armv7l
            Userland: 		armhf
            User-ID: 		1000
            X-Server: 		false
            Pending OS-Updates: 	0
              throw err;
            Require stack:
              requireStack: [
            Node.js v18.19.1
            This system needs to be REBOOTED NOW!
            			/usr/bin/npm 		10.2.4
            			/usr/bin/npx 		10.2.4
            MEMORY:
            Mem:           3.8G        174M        2.9G         80M        780M        3.4G
            Swap:           99M          0B         99M
            Total:         3.9G        174M        3.0G
              throw err;
            Require stack:
              requireStack: [
            Node.js v18.19.1
              throw err;
            Require stack:
              requireStack: [
            Node.js v18.19.1
              throw err;
            Require stack:
              requireStack: [
            Node.js v18.19.1
              throw err;
            Require stack:
              requireStack: [
            Node.js v18.19.1
            			admin
              throw err;
            Require stack:
              requireStack: [
            Node.js v18.19.1
            ioBroker Status:
              throw err;
            Require stack:
              requireStack: [
            Node.js v18.19.1
            Objects: 		0
            States: 		0
            • D danielos
              			v.2023-10-10
                       Icon name: computer
                    Architecture: arm
              Kernel: 		armv7l
              Userland: 		armhf
              User-ID: 		1000
              X-Server: 		false
                throw err;
              Require stack:
                requireStack: [
              Node.js v18.19.1
              			/usr/bin/npm 		10.2.4
              			/usr/bin/npx 		10.2.4
              MEMORY:
              Swap:           99M          0B         99M
                throw err;
              Require stack:
                requireStack: [
              Node.js v18.19.1
                throw err;
              Require stack:
                requireStack: [
              Node.js v18.19.1
                throw err;
              Require stack:
                requireStack: [
              Node.js v18.19.1
                throw err;
              Require stack:
                requireStack: [
              Node.js v18.19.1
              			admin
                throw err;
              Require stack:
                requireStack: [
              Node.js v18.19.1
              ioBroker Status:
                throw err;
              Require stack:
                requireStack: [
              Node.js v18.19.1
              Objects: 		0
              States: 		0
              Bitte auch mal lesen was das Tool dir sagt.
                danielos
                @thomas-braun Ja, wirklich übersehen. Geändert hat sich aber auch nach einem Neustart leider nichts. Alle pakete scheinen nun aktuell zu sein aber einfach das graceful-fs wird noch immer vermisst.
                • D danielos
                  @danielos
                  Versuche
                  iob stop
                  sudo -H -u iobroker npm cache clean --force
                  cd /opt/iobroker
                  iob start
                  • D danielos
                    Das ist nicht richtig. Dein Betriebssystem ist jetzt auf dem letzten Stand.
                    Abgekündigt ist es aber immer noch.
                      danielos
                      @thomas-braun Ja, das stimmt natürlich. Ich meinte mehr die Fehlermeldung ist noch identisch. Die Befehle habe ich ausgeführt...und juhuu, es scheint wieder zu klappen. Das admin-Update läuft zwar immer noch nicht durch wenn ich's klicke, aber das Interface ist mal wieder aufrufbar. Danke vielmals für deine Geduld und deine Unterstützung. Sehr geschätzt!!
                      • D danielos
                        @danielos und welche Bedingungen für das Update erfüllen deine veralteten Versionen nicht?
                          danielos
                          Gute Frage...
                          Would you like to upgrade admin from @6.2.23 to @6.13.16 now? [(y)es, (n)o]: y
                          Update admin from @6.2.23 to @6.13.16
                          host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
                          NPM version: 10.2.4
                          Installing iobroker.admin@6.13.16... (System call)
                          host.raspberrypi Cannot install iobroker.admin@6.13.16: 217
                          Abbruch ohne genauere Informationen...
                          • D danielos
                            Gute Frage...
                            NPM version: 10.2.4
                            hast du mit --debug gestartet?
                            was steht im Admin?
                            so etwas?
                            • D danielos
                              Gute Frage...
                              NPM version: 10.2.4
                              @danielos
                              Und jetzt die Langfassung von
                              iob diag
                                was steht im Admin?
                                so etwas?
                                danielos
                                pi@raspberrypi:~ $ iobroker upgrade admin --debug
                                  throw err;
                                Error: Cannot find module 'readdirp'
                                Require stack:
                                - /opt/iobroker/node_modules/chokidar/index.js
                                - /opt/iobroker/node_modules/@iobroker/js-controller-cli/lib/cli/cliLogs.js
                                - /opt/iobroker/node_modules/@iobroker/js-controller-cli/index.js
                                - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                                    at Object.<anonymous> (/opt/iobroker/node_modules/chokidar/index.js:7:18)
                                  requireStack: [
                                    '/opt/iobroker/node_modules/chokidar/index.js',
                                    '/opt/iobroker/node_modules/@iobroker/js-controller-cli/lib/cli/cliLogs.js',
                                    '/opt/iobroker/node_modules/@iobroker/js-controller-cli/index.js',
                                    '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                                Node.js v18.19.1
                                • D danielos
                                    throw err;
                                  Require stack:
                                    requireStack: [
                                  Node.js v18.19.1
                                  @danielos
                                  Da ist der js-controller nicht richtig installiert/kaputt.
                                  Richtig sollte das so aussehen:
                                  echad@chet:/opt/iobroker $ npm ls readdirp
                                  iobroker.inst@3.0.0 /opt/iobroker
                                  `-- iobroker.js-controller@5.0.19
                                    `-- @iobroker/js-controller-cli@5.0.19
                                      `-- chokidar@3.5.3
                                        `-- readdirp@3.6.0
                                    @danielos
                                    iob diag
                                    danielos
                                    Einige Dinge werden nun angezeigt....
                                    			v.2023-10-10
                                             Icon name: computer
                                                Kernel: Linux 5.10.103-v7l+
                                          Architecture: arm
                                    Kernel: 		armv7l
                                    Userland: 		armhf
                                    User-ID: 		1000
                                    X-Server: 		false
                                      throw err;
                                    Require stack:
                                      requireStack: [
                                    Node.js v18.19.1
                                    			/usr/bin/npm 		10.2.4
                                    			/usr/bin/npx 		10.2.4
                                    MEMORY:
                                    Mem:           3.8G        152M        3.0G        8.0M        658M        3.5G
                                    Swap:           99M          0B         99M
                                    Total:         3.9G        152M        3.1G
                                      throw err;
                                    Require stack:
                                      requireStack: [
                                    Node.js v18.19.1
                                      throw err;
                                    Require stack:
                                      requireStack: [
                                    Node.js v18.19.1
                                      throw err;
                                    Require stack:
                                      requireStack: [
                                    Node.js v18.19.1
                                      throw err;
                                    Require stack:
                                      requireStack: [
                                    Node.js v18.19.1
                                    			admin
                                      throw err;
                                    Require stack:
                                      requireStack: [
                                    Node.js v18.19.1
                                    ioBroker Status:
                                      throw err;
                                    Require stack:
                                      requireStack: [
                                    Node.js v18.19.1
                                    Objects: 		0
                                    States: 		0
                                    6.7M	/opt/iobroker/iobroker-data/states.jsonl
                                    Und ja, js-controller scheint nicht richtig zu laufen...
                                    pi@raspberrypi:~ $ npm ls readdirp
                                    pi@ /home/pi
                                    └── (empty)
                                    Thomas BraunT D 2 Antworten Letzte Antwort
                                    • D danielos
                                      			v.2023-10-10
                                               Icon name: computer
                                            Architecture: arm
                                      Kernel: 		armv7l
                                      Userland: 		armhf
                                      User-ID: 		1000
                                      X-Server: 		false
                                        throw err;
                                      Require stack:
                                        requireStack: [
                                      Node.js v18.19.1
                                      			/usr/bin/npm 		10.2.4
                                      			/usr/bin/npx 		10.2.4
                                      MEMORY:
                                      Swap:           99M          0B         99M
                                        throw err;
                                      Require stack:
                                        requireStack: [
                                      Node.js v18.19.1
                                        throw err;
                                      Require stack:
                                        requireStack: [
                                      Node.js v18.19.1
                                        throw err;
                                      Require stack:
                                        requireStack: [
                                      Node.js v18.19.1
                                        throw err;
                                      Require stack:
                                        requireStack: [
                                      Node.js v18.19.1
                                      			admin
                                        throw err;
                                      Require stack:
                                        requireStack: [
                                      Node.js v18.19.1
                                      ioBroker Status:
                                        throw err;
                                      Require stack:
                                        requireStack: [
                                      Node.js v18.19.1
                                      Objects: 		0
                                      States: 		0
                                      pi@ /home/pi
                                      └── (empty)
                                      Du stehst nicht im richtigen Verzeichnis...
                                      cd /opt/iobroker
                                      npm ls readdirp
                                      Und die SUMMARY ist nicht die Langfassung. Das ist der Kram davor in der Ausgabe.
                                      • D danielos
                                        			v.2023-10-10
                                                 Icon name: computer
                                              Architecture: arm
                                        Kernel: 		armv7l
                                        Userland: 		armhf
                                        User-ID: 		1000
                                        X-Server: 		false
                                          throw err;
                                        Require stack:
                                          requireStack: [
                                        Node.js v18.19.1
                                        			/usr/bin/npm 		10.2.4
                                        			/usr/bin/npx 		10.2.4
                                        MEMORY:
                                        Swap:           99M          0B         99M
                                          throw err;
                                        Require stack:
                                          requireStack: [
                                        Node.js v18.19.1
                                          throw err;
                                        Require stack:
                                          requireStack: [
                                        Node.js v18.19.1
                                          throw err;
                                        Require stack:
                                          requireStack: [
                                        Node.js v18.19.1
                                          throw err;
                                        Require stack:
                                          requireStack: [
                                        Node.js v18.19.1
                                        			admin
                                          throw err;
                                        Require stack:
                                          requireStack: [
                                        Node.js v18.19.1
                                        ioBroker Status:
                                          throw err;
                                        Require stack:
                                          requireStack: [
                                        Node.js v18.19.1
                                        Objects: 		0
                                        States: 		0
                                        pi@ /home/pi
                                        └── (empty)
                                        danielos
                                        @danielos
                                          throw err;
                                        Require stack:
                                          requireStack: [
                                        Entsprechend lässt sich admin nicht mehr starten...
                                        • D danielos
                                          @danielos
                                            throw err;
                                          Require stack:
                                            requireStack: [
                                          @danielos
                                          iob stop
                                          cd /opt/iobroker
                                          iob start
