  4. Trigger nach einiger Zeit inaktiv
    5.2k
23 Beiträge 8 Kommentatoren 2.7k Aufrufe 5 Beobachtet
  • O oxident
    So, hier noch die diag-Ausgabe. Seht ihr da Probleme?
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: iobrokernano
           Icon name: computer
              Kernel: Linux 6.1.25
        Architecture: arm64
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     06:28:44 up 25 days, 19:16,  2 users,  load average: 2.46, 1.96, 1.89
    CPU threads: 8
    *** Time and Time Zones ***
                   Local time: Fri 2024-03-08 06:28:44 CET
               Universal time: Fri 2024-03-08 05:28:44 UTC
                     RTC time: Fri 2024-03-08 05:28:44
                  NTP service: n/a
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi sudo iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:             16G        7.1G        784M        3.3M        9.1G        9.6G
    Swap:             0B          0B          0B
    Total:           16G        7.1G        784M
            15948 M total memory
             6785 M used memory
             5235 M active memory
             9275 M inactive memory
              747 M free memory
              483 M buffer memory
             8187 M swap cache
                0 M total swap
                0 M used swap
                0 M free swap
    *** FAILED SERVICES ***
      UNIT                     LOAD   ACTIVE SUB    DESCRIPTION
    * nvmf-autoconnect.service loaded failed failed Connect NVMe-oF subsystems automatically during boot
    1 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  7.8G     0  7.8G   0% /dev
    tmpfs          tmpfs     1.6G  2.4M  1.6G   1% /run
    overlay        overlay   226G   15G  200G   7% /
    tmpfs          tmpfs     7.8G     0  7.8G   0% /dev/shm
    tmpfs          tmpfs     5.0M   24K  5.0M   1% /run/lock
    /dev/nvme0n1p1 ext4      469G   11G  434G   3% /mnt/nvm
    tmpfs          tmpfs     1.6G  8.0K  1.6G   1% /run/user/1000
    TARGET   SOURCE         FSTYPE OPTIONS
    /mnt/nvm /dev/nvme0n1p1 ext4   rw,noatime
    /var:
    971M    /var/
    485M    /var/lib
    302M    /var/lib/redis
    270M    /var/log
    253M    /var/log/journal/50d54139eb13431da5406ad3b6f26fbc
    Archived and active journals take up 50.3M in the file system.
    /opt/iobroker/backups:
    5.1G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    205M    /opt/iobroker/iobroker-data/
    186M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build/poolsensors
    15M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/poolsensors/.pioenvs/poolsensors/esp-idf/bt/libbt.a
    9.5M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build/poolsensors/.pioenvs/poolsensors/build.ninja
    8.7M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build/poolsensors/.pioenvs/poolsensors/compile_commands.json
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    5.0M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build/poolsensors/.pioenvs/poolsensors/esp-idf/driver/libdriver.a
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.1
    /usr/bin/node           v18.19.1
    /usr/bin/npm            10.2.4
    /usr/bin/npx            10.2.4
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.1-1nodesource1
      Candidate: 18.19.1-1nodesource1
      Version table:
     *** 18.19.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 https://mirrors.aliyun.com/debian-security bookworm-security/main arm64 Packages
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 https://mirrors.aliyun.com/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! missing: chroma-js@^2.4.2, required by iobroker.javascript@7.8.0
    npm ERR! missing: dewpoint@^1.0.0, required by iobroker.javascript@7.8.0
    npm ERR! missing: moment-duration-format@^2.3.2, required by iobroker.javascript@7.8.0
    npm ERR! invalid: moment-timezone@0.5.44 /opt/iobroker/node_modules/moment-timezone
    npm ERR! invalid: webuntis@1.22.1 /opt/iobroker/node_modules/webuntis
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-03-08T05_28_52_939Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    At least one iobroker host is running.
    Objects type: redis
    States  type: redis
    Core adapters versions
    js-controller:  5.0.19
    admin:          6.13.16
    javascript:     7.8.0
    Adapters from github:   30
    Adapter State
      system.adapter.acme.0                   : acme                  : iobrokernano                             - disabled, port: 80, bind: 192.168.37.200
    + system.adapter.admin.0                  : admin                 : iobrokernano                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa-shoppinglist.0     : alexa-shoppinglist    : iobrokernano                             -  enabled
    + system.adapter.alexa2.0                 : alexa2                : iobrokernano                             -  enabled
      system.adapter.alias-manager.0          : alias-manager         : iobrokernano                             -  enabled
    + system.adapter.backitup.0               : backitup              : iobrokernano                             -  enabled
      system.adapter.blueconnect.0            : blueconnect           : iobrokernano                             -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobrokernano                             -  enabled
      system.adapter.daswetter.0              : daswetter             : iobrokernano                             -  enabled
    + system.adapter.deconz.0                 : deconz                : iobrokernano                             -  enabled, port: 80
    + system.adapter.device-watcher.0         : device-watcher        : iobrokernano                             -  enabled
    + system.adapter.discovery.0              : discovery             : iobrokernano                             -  enabled
      system.adapter.dwd.0                    : dwd                   : iobrokernano                             -  enabled
    + system.adapter.echarts.0                : echarts               : iobrokernano                             -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobrokernano                             -  enabled
    + system.adapter.esphome.0                : esphome               : iobrokernano                             -  enabled
    + system.adapter.fronius.0                : fronius               : iobrokernano                             -  enabled
    + system.adapter.fullcalendar.0           : fullcalendar          : iobrokernano                             -  enabled
      system.adapter.growatt.0                : growatt               : iobrokernano                             - disabled
    + system.adapter.gruenbeck.0              : gruenbeck             : iobrokernano                             -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobrokernano                             -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobrokernano                             -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobrokernano                             -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobrokernano                             -  enabled, port: 0
      system.adapter.hp-ilo.0                 : hp-ilo                : iobrokernano                             - disabled
      system.adapter.ical.0                   : ical                  : iobrokernano                             -  enabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : iobrokernano                             -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobrokernano                             -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobrokernano                             -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobrokernano                             -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobrokernano                             -  enabled
    + system.adapter.iot.0                    : iot                   : iobrokernano                             -  enabled
    + system.adapter.javascript.0             : javascript            : iobrokernano                             -  enabled
      system.adapter.javascript.1             : javascript            : iobrokernano                             - disabled
      system.adapter.javascript.2             : javascript            : iobrokernano                             - disabled
    + system.adapter.klf200.0                 : klf200                : iobrokernano                             -  enabled
      system.adapter.lametric.0               : lametric              : iobrokernano                             - disabled
    + system.adapter.linux-control.0          : linux-control         : iobrokernano                             -  enabled
    + system.adapter.melcloud.0               : melcloud              : iobrokernano                             -  enabled
    + system.adapter.mielecloudservice.0      : mielecloudservice     : iobrokernano                             -  enabled
      system.adapter.modbus.0                 : modbus                : iobrokernano                             - disabled
      system.adapter.modbus.1                 : modbus                : iobrokernano                             - disabled
    + system.adapter.modbus.2                 : modbus                : iobrokernano                             -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobrokernano                             -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.nanoleaf-lightpanels.0   : nanoleaf-lightpanels  : iobrokernano                             -  enabled, port: 16021
    + system.adapter.nanoleaf-lightpanels.1   : nanoleaf-lightpanels  : iobrokernano                             -  enabled, port: 16021
    + system.adapter.net-tools.0              : net-tools             : iobrokernano                             -  enabled
    + system.adapter.nina.0                   : nina                  : iobrokernano                             -  enabled
    + system.adapter.nuki-extended.0          : nuki-extended         : iobrokernano                             -  enabled
    + system.adapter.nut.0                    : nut                   : iobrokernano                             -  enabled
      system.adapter.openweathermap.0         : openweathermap        : iobrokernano                             -  enabled
    + system.adapter.parcel.0                 : parcel                : iobrokernano                             -  enabled
    + system.adapter.ping.0                   : ping                  : iobrokernano                             -  enabled
      system.adapter.proxmox.0                : proxmox               : iobrokernano                             - disabled, port: 8006
    + system.adapter.puppeteer.0              : puppeteer             : iobrokernano                             -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : iobrokernano                             -  enabled
    + system.adapter.pvforecast.1             : pvforecast            : iobrokernano                             -  enabled
    + system.adapter.radar-trap.0             : radar-trap            : iobrokernano                             -  enabled
      system.adapter.roborock.0               : roborock              : iobrokernano                             - disabled
    + system.adapter.scenes.0                 : scenes                : iobrokernano                             -  enabled
    + system.adapter.senec.0                  : senec                 : iobrokernano                             -  enabled
    + system.adapter.shelly.0                 : shelly                : iobrokernano                             -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobrokernano                             -  enabled, port: 18087, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.smartthings.0            : smartthings           : iobrokernano                             -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobrokernano                             -  enabled
      system.adapter.systeminfo.0             : systeminfo            : iobrokernano                             - disabled
    + system.adapter.telegram.0               : telegram              : iobrokernano                             -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : iobrokernano                             -  enabled
    + system.adapter.tibberlink.0             : tibberlink            : iobrokernano                             -  enabled
    + system.adapter.time-switch.0            : time-switch           : iobrokernano                             -  enabled
    + system.adapter.traccar.0                : traccar               : iobrokernano                             -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobrokernano                             -  enabled
      system.adapter.unifi-protect.0          : unifi-protect         : iobrokernano                             - disabled
    + system.adapter.unifi.0                  : unifi                 : iobrokernano                             -  enabled
      system.adapter.ve.0                     : ve                    : iobrokernano                             - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobrokernano                             -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobrokernano                             -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobrokernano                             -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobrokernano                             -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobrokernano                             -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobrokernano                             -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobrokernano                             -  enabled
      system.adapter.vis-map.0                : vis-map               : iobrokernano                             -  enabled
      system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobrokernano                             -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobrokernano                             -  enabled
      system.adapter.vis-metro.0              : vis-metro             : iobrokernano                             -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : iobrokernano                             -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobrokernano                             -  enabled
      system.adapter.vis.0                    : vis                   : iobrokernano                             - disabled
    + system.adapter.vw-connect.0             : vw-connect            : iobrokernano                             -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobrokernano                             -  enabled
    + system.adapter.web.0                    : web                   : iobrokernano                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.web.1                    : web                   : iobrokernano                             -  enabled, port: 9082, bind: 192.168.37.200 (SSL), run as: admin
      system.adapter.web.2                    : web                   : iobrokernano                             - disabled, port: 8085, bind: 192.168.37.200, run as: admin
    + system.adapter.webuntis.0               : webuntis              : iobrokernano                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.windows-control.0        : windows-control       : iobrokernano                             -  enabled
    + system.adapter.wled.0                   : wled                  : iobrokernano                             -  enabled
    + system.adapter.wolf-smartset.0          : wolf-smartset         : iobrokernano                             -  enabled
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "acme"         : 0.1.2    , installed 0.1.2
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "alexa-shoppinglist": 0.1.5, installed 0.1.5
    Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.10.11  , installed 2.10.11
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
    Adapter    "deconz"       : 1.3.23   , installed 1.3.23
    Adapter    "device-watcher": 2.9.6   , installed 2.10.1
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "fronius"      : 2.0.2    , installed 2.0.2
    Adapter    "fullcalendar" : 2.3.4    , installed 2.3.4
    Adapter    "growatt"      : 3.2.3    , installed 3.2.3
    Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
    Adapter    "hp-ilo"       : 1.0.6    , installed 1.0.6
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "klf200"       : 1.2.0    , installed 1.2.0
    Adapter    "lametric"     : 3.1.3    , installed 3.1.3
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "melcloud"     : 1.3.7    , installed 1.3.7
    Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
    Adapter    "modbus"       : 6.1.0    , installed 6.1.0
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "nanoleaf-lightpanels": 1.4.0, installed 1.4.0
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "openweathermap": 1.0.4   , installed 1.0.4
    Adapter    "proxmox"      : 2.2.3    , installed 2.2.3
    Adapter    "puppeteer"    : 0.2.8    , installed 0.2.8
    Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
    Adapter    "roborock"     : 0.4.4    , installed 0.5.1
    Adapter    "senec"        : 1.6.11   , installed 1.6.11
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "smartthings"  : 0.0.4    , installed 0.1.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
    Adapter    "telegram"     : 3.1.0    , installed 3.1.0
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "tibberlink"   : 2.2.2    , installed 2.2.2
    Adapter    "traccar"      : 1.1.4    , installed 1.1.4
    Adapter    "trashschedule": 3.2.0    , installed 3.2.0
    Adapter    "unifi"        : 0.6.7    , installed 0.6.7
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
    Adapter    "vis-map"      : 1.0.5    , installed 1.0.5
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
    Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.3
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "webuntis"     : 0.3.4    , installed 0.3.4
    Adapter    "windows-control": 0.1.5  , installed 0.1.5
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "wolf-smartset": 1.1.1    , installed 1.1.1
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Objects and States
    Objects:        79702
    States:         67880
    Hit:1 https://repos.influxdata.com/debian stable InRelease
    Hit:2 https://deb.nodesource.com/node_18.x nodistro InRelease
    Hit:3 https://mirrors.aliyun.com/debian bookworm InRelease
    Hit:4 https://mirrors.aliyun.com/debian-security bookworm-security InRelease
    Hit:5 https://mirrors.aliyun.com/debian bookworm-updates InRelease
    Hit:6 https://mirrors.aliyun.com/debian bookworm-backports InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          16875      1/systemd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          29872      829/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       69305001   1208933/io.mqtt.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       69305000   1208933/io.mqtt.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       69304891   1208839/io.shelly.0
    tcp        0      0 0.0.0.0:2001            0.0.0.0:*               LISTEN      1001       69306465   1208753/io.hm-rpc.0
    tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1001       69305716   1208805/io.hm-rpc.1
    tcp        0      0 127.0.0.1:45583         0.0.0.0:*               LISTEN      1001       69311964   1209576/chromium
    tcp        0      0 0.0.0.0:9292            0.0.0.0:*               LISTEN      1001       69301616   1208871/io.hm-rpc.2
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      107        29877      818/redis-server 12
    tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1001       163363541  3782953/python3
    tcp        0      0 192.168.37.200:9082     0.0.0.0:*               LISTEN      1001       69316011   1210605/io.web.1
    tcp6       0      0 :::111                  :::*                    LISTEN      0          16876      1/systemd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          29874      829/sshd: /usr/sbin
    tcp6       0      0 :::18087                :::*                    LISTEN      1001       69304720   1208689/io.simple-a
    tcp6       0      0 :::51989                :::*                    LISTEN      1001       69300781   1208789/io.nuki-ext
    tcp6       0      0 :::3040                 :::*                    LISTEN      1001       69309701   1209337/io.radar-tr
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        256542     23498/influxd
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       69307549   1209219/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       69302482   1208575/io.admin.0
    tcp6       0      0 ::1:6379                :::*                    LISTEN      107        29878      818/redis-server 12
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          28549      1/systemd
    udp        0      0 192.168.37.200:123      0.0.0.0:*                           102        34992898   65661/ntpd
    udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          684664     65661/ntpd
    udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          684660     65661/ntpd
    udp        0      0 0.0.0.0:59240           0.0.0.0:*                           109        17103      762/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       69307433   1209166/io.nanoleaf
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       69306157   1209081/io.nanoleaf
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       69305524   1208617/io.deconz.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       163367411  3782871/io.esphome.
    udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1001       163363547  3782953/python3
    udp        0      0 192.168.37.200:5353     0.0.0.0:*                           1001       163363546  3782953/python3
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       163363542  3782953/python3
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       69304061   1209033/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           109        17101      762/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          28550      1/systemd
    udp6       0      0 fd69:fddb:1bdd:5934:123 :::*                                102        81568225   65661/ntpd
    udp6       0      0 fe80::a4f4:94ff:fec:123 :::*                                102        34992903   65661/ntpd
    udp6       0      0 ::1:123                 :::*                                0          684668     65661/ntpd
    udp6       0      0 :::123                  :::*                                0          684657     65661/ntpd
    udp6       0      0 :::1900                 :::*                                1001       69305526   1208617/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       69305525   1208617/io.deconz.0
    udp6       0      0 :::5353                 :::*                                109        17102      762/avahi-daemon: r
    udp6       0      0 :::38479                :::*                                109        17104      762/avahi-daemon: r
    2024-03-08 06:23:00.760  - info: host.iobrokernano instance system.adapter.esphome.0 scheduled normal terminated and will be restarted on schedule.
    2024-03-08 06:23:00.761  - info: host.iobrokernano Restart adapter system.adapter.esphome.0 because enabled
    2024-03-08 06:23:01.893  - info: host.iobrokernano instance system.adapter.esphome.0 started with pid 3780534
    2024-03-08 06:24:00.036  - info: host.iobrokernano instance system.adapter.dwd.0 started with pid 3780718
    2024-03-08 06:24:00.733  - info: host.iobrokernano instance system.adapter.esphome.0 scheduled normal terminated and will be restarted on schedule.
    2024-03-08 06:24:00.733  - info: host.iobrokernano Restart adapter system.adapter.esphome.0 because enabled
    2024-03-08 06:24:01.879  - info: host.iobrokernano instance system.adapter.esphome.0 started with pid 3780738
    2024-03-08 06:24:03.731  - info: host.iobrokernano instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-03-08 06:25:00.056  - info: host.iobrokernano instance system.adapter.blueconnect.0 started with pid 3781231
    2024-03-08 06:25:00.676  - info: host.iobrokernano instance system.adapter.esphome.0 scheduled normal terminated and will be restarted on schedule.
    2024-03-08 06:25:00.676  - info: host.iobrokernano Restart adapter system.adapter.esphome.0 because enabled
    2024-03-08 06:25:01.784  - info: host.iobrokernano instance system.adapter.esphome.0 started with pid 3781262
    2024-03-08 06:25:12.255  - info: host.iobrokernano instance system.adapter.blueconnect.0 terminated with code 0 (NO_ERROR)
    2024-03-08 06:26:00.697  - info: host.iobrokernano instance system.adapter.esphome.0 scheduled normal terminated and will be restarted on schedule.
    2024-03-08 06:26:00.698  - info: host.iobrokernano Restart adapter system.adapter.esphome.0 because enabled
    2024-03-08 06:26:01.873  - info: host.iobrokernano instance system.adapter.esphome.0 started with pid 3781437
    2024-03-08 06:27:00.766  - info: host.iobrokernano instance system.adapter.esphome.0 scheduled normal terminated and will be restarted on schedule.
    2024-03-08 06:27:00.767  - info: host.iobrokernano Restart adapter system.adapter.esphome.0 because enabled
    2024-03-08 06:27:01.890  - info: host.iobrokernano instance system.adapter.esphome.0 started with pid 3781946
    2024-03-08 06:28:00.701  - info: host.iobrokernano instance system.adapter.esphome.0 scheduled normal terminated and will be restarted on schedule.
    2024-03-08 06:28:00.702  - info: host.iobrokernano Restart adapter system.adapter.esphome.0 because enabled
    2024-03-08 06:28:01.862  - info: host.iobrokernano instance system.adapter.esphome.0 started with pid 3782136
    2024-03-08 06:29:00.757  - info: host.iobrokernano instance system.adapter.esphome.0 scheduled normal terminated and will be restarted on schedule.
    2024-03-08 06:29:00.758  - info: host.iobrokernano Restart adapter system.adapter.esphome.0 because enabled
    2024-03-08 06:29:01.911  - info: host.iobrokernano instance system.adapter.esphome.0 started with pid 3782871
    MartinPM Online
    MartinPM Online
    MartinP
    @oxident
    Errors in npm tree:
    • MartinPM MartinP
      @oxident
      Errors in npm tree:
      CodierknechtC Offline
      Codierknecht
      @oxident
      Da stellt sich die Frage: Wie sind z.B. chroma-js oder dewpoint auf das System gekommen?
      "von Hand" oder über den JS-Adapter?
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
      • O Offline
        O Offline
        oxident
        @MartinP @Codierknecht Stimmt, ist mir auch gerade aufgefallen. Die NPM waren ganz regulär als Module im JS-Adapter eingetragen. Habe sie jetzt dort entfernt und neu eingetragen. Danach gab's keine Meldungen mehr beim diag.
        Ich sehe das doch richtig, dass der JS-Adapter beim Start sämtliche States, also auch die, auf die ich keine Trigger habe, abonniert, oder?
        Dann wäre es ja noch komischer, wenn einzelne Trigger spontan nicht mehr "feuern"...
        • O oxident
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : arm64
          CPU threads: 8
                        NTP service: n/a
                    RTC in local TZ: no
          pi
          /home/pi
          pi sudo iobroker
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:             0B          0B          0B
                   6785 M used memory
                    747 M free memory
                    483 M buffer memory
                   8187 M swap cache
                      0 M total swap
                      0 M used swap
                      0 M free swap
          *** FILESYSTEM ***
          /var:
          971M    /var/
          485M    /var/lib
          302M    /var/lib/redis
          270M    /var/log
          USB-Devices by-id:
          /usr/bin/npm            10.2.4
          /usr/bin/npx            10.2.4
          nodejs:
            Version table:
               18.13.0+dfsg1-1 500
          Errors in npm tree:
          ioBroker Status
          Objects type: redis
          States  type: redis
          admin:          6.13.16
          javascript:     7.8.0
          Adapter State
          + instance is alive
          Objects and States
          Objects:        79702
          States:         67880
          Pending Updates: 0
          @oxident sagte in Trigger nach einiger Zeit inaktiv:
          Setz den pi noch in die Gruppe adm rein.
          sudo usermod -a -G adm pi
          sudo systemctl set-default multi-user.target
          Schalt einen kleinen SWAP ein. Hab den Befehl aber gerade nicht im Kopf.
          Schau dir an was mit dem Service nvmf-autoconnect los ist.
          30 Adapter aus dem GitHub????
          Die 'Katze'/GitHub ist NICHT deine reguläre Installationsquelle! Setz das soweit wie möglich auf Versionen aus einem Repo.
          Schalt die bookworm-backports aus.
          Warum startet der esphome.0 im Minutentakt neu?
          O 1 Antwort Letzte Antwort
            O Offline
            O Offline
            oxident
            @thomas-braun Danke für Deine wertvollen Hinweise. Setze ich gleich um.
            Ich nitze einige Adapter die es im stable nicht gibt und z.B. beim Influx-Adapter verursacht die aktuelle stable bei mir massive CPU-Last. Vermutlich wegen eines Bugs, der bei Abfragen immer alle Datensätze (anstelle eines bestimmten Zeitraums) durchläuft.
            Ansonsten versuche ich wirklich, bei allen Adaptern im stable zu bleiben.
            Beim ESPHome liegt es meiner Meinung nach an einer schlechten Verbindung zum Endgerät (ESP32 im Außenbereich).
            • O oxident
              30 Adapter aus dem GitHub...
                O Offline
                O Offline
                oxident
                @thomas-braun said in Trigger nach einiger Zeit inaktiv:
                Ja, das ist das einzig verbleibende Problem.
                Die restlichen Punkte habe ich jetzt alle umgesetzt:
                • Swapfile mit 4GB angelegt
                • pi zur Gruppe hinzugefügt und multi-user.target gesetzt
                • nvmf-autoconnect war bei mir unnötig und eh "broken" (der Kernel der Distro unterstützt das gar nicht) -> jetzt disabled
                • bookworm-backports ausgeschaltet
                • esphome.0 war in der Tat ein Fehler von mir (zu blöd für Cron) ... danke @thomas-braun für den Hinweis!
                • O oxident
                  Warum sooo riesig?
                  @thomas-braun sagte in Trigger nach einiger Zeit inaktiv:
                  gibt's die alle noch nicht im Repo?
                  wenn doch, über das Repo drüberinstallieren
                    Warum sooo riesig?
                    O Offline
                    O Offline
                    oxident
                    @homoran said in Trigger nach einiger Zeit inaktiv:
                    Warum sooo riesig?
                    Ehrlich gesagt, Bauchgefühl. Mein RK3588 hat eine 1TB NVMe und davon nutze ich, trotz InfluxDB so gut wie nichts.
                    In der Tat gibt's einige davon mittlerweile im Stable-Repo und die installiere ich gerade drüber. Jedoch bleiben einige über (z. B. Energiefluss-Erweitert oder MDW) die entweder nicht im Stable sind oder aber ein paar fiese Bugs (zumindest für mich, siehe Influx oder auch Senec) haben.
                    • O oxident
                      Warum sooo riesig?
                      Codierknecht
                      Die Größe des SWAP ist ja nicht von Deiner Platte abhängig, sondern vom RAM.
                      Bei mehr als 8 GB sind 512 MB empfohlen.
                      • CodierknechtC Codierknecht
                        O Offline
                        O Offline
                        oxident
                        @codierknecht said in Trigger nach einiger Zeit inaktiv:
                        Huch, das wusste ich nicht und hab's auch ehrlich gesagt nicht vorher recherchiert. Dachte immer, "besser haben als brauchen" ;-)
                        Werde ich gleich mal anpassen, obwohl er jetzt nach ein paar Stunden Betrieb sich noch nichts vom Swap genehmigt hat. Sind auch noch ~10GB vom RAM.
                        • O Offline
                          O Offline
                          oxident
                          Okay, bin jetzt runter auf 12 Github-Adapter und der Swap wurde angepasst.
                          Bleibt nur noch eine Kuriosität: Aus irgendeinem Grund tauchen die oben erwähnten fehlenden NPMs bei jedem Neustart von IoBroker bestehen. Nur ein gezielter Neustart der JS-Instanz scheint diese dann erneut zu installieren ("npm install chroma-js" wird dann z. B. ausgeführt).
                          Kann es dafür einen logischen Grund geben?
                          Ansonsten sieht's jetzt, dank Eurer Hilfe, so aus:
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : arm64
                           14:16:27 up 29 min,  2 users,  load average: 2.18, 2.23, 2.08
                          CPU threads: 8
                                         Local time: Fri 2024-03-08 14:16:27 CET
                                     Universal time: Fri 2024-03-08 13:16:27 UTC
                                           RTC time: Fri 2024-03-08 13:16:27
                                        NTP service: n/a
                                    RTC in local TZ: no
                          pi
                          /home/pi
                          pi adm sudo iobroker
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          Boot Target:    multi-user.target
                          *** MEMORY ***
                          Mem:             16G        5.5G        9.8G        2.8M        1.7G         11G
                          Swap:           4.3G          0B        4.3G
                          Total:           21G        5.5G         14G
                                   5221 M used memory
                                    411 M active memory
                                   5736 M inactive memory
                                   9338 M free memory
                                    162 M buffer memory
                                   1479 M swap cache
                                   4095 M total swap
                                      0 M used swap
                                   4095 M free swap
                          0 loaded units listed.
                          *** FILESYSTEM ***
                          tmpfs          tmpfs     1.6G  2.0M  1.6G   1% /run
                          /dev/nvme0n1p1 ext4      469G   12G  434G   3% /mnt/nvm
                          [Fri Mar  8 13:46:36 2024] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.dtbo_idx=0 androidboot.verifiedbootstate=orange earlycon=uart8250,mmio32,0xfeb50000 console=ttyFIQ0 coherent_pool=1m irqchip.gicv3_pseudo_nmi=0 rw root=/dev/mmcblk2p8 rootfstype=ext4 rootflags=discard data=/dev/mmcblk2p9 consoleblank=0 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
                          [Fri Mar  8 13:46:38 2024] EXT4-fs (mmcblk2p8): mounted filesystem with ordered data mode. Quota mode: none.
                          [Fri Mar  8 13:46:38 2024] EXT4-fs (mmcblk2p9): mounted filesystem with ordered data mode. Quota mode: none.
                          [Fri Mar  8 13:46:38 2024] EXT4-fs (mmcblk2p9): re-mounted. Quota mode: none.
                          [Fri Mar  8 13:46:40 2024] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Quota mode: none.
                          /var:
                          967M    /var/
                          481M    /var/lib
                          302M    /var/lib/redis
                          271M    /var/log
                          Archived and active journals take up 252.9M in the file system.
                          259M    /opt/iobroker/iobroker-data/
                          240M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build/poolsensors
                          22M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/poolsensors/.pioenvs/poolsensors/firmware.elf
                          13M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/poolsensors/.pioenvs/poolsensors/poolsensors.map
                          USB-Devices by-id:
                          /usr/bin/npm            10.2.4
                          /usr/bin/npx            10.2.4
                          nodejs:
                            Version table:
                               18.13.0+dfsg1-1 500
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: redis
                          States  type: redis
                          admin:          6.13.16
                          javascript:     7.8.0
                          Adapters from github:   16
                          Adapter State
                          + instance is alive
                          Adapter    "device-watcher": 2.10.5  , installed 2.10.5
                          Adapter    "roborock"     : 0.4.4    , installed 0.5.4
                          Objects and States
                          Objects:        79970
                          States:         68203
                          Hit:2 https://mirrors.aliyun.com/debian bookworm InRelease
                          Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Pending Updates: 0
                          tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1001       89783      6105/python3
                          tcp        0      0 192.168.37.200:9082     0.0.0.0:*               LISTEN      1001       48770      3313/io.web.1
                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          317        1/init
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4430       883/sshd: /usr/sbin
                          tcp        0      0 0.0.0.0:2001            0.0.0.0:*               LISTEN      1001       30815      1300/io.hm-rpc.0
                          tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1001       32886      1488/io.hm-rpc.1
                          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       3832       1330/io.shelly.0
                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       30232      1472/io.mqtt.0
                          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       30233      1472/io.mqtt.0
                          tcp        0      0 127.0.0.1:37255         0.0.0.0:*               LISTEN      1001       39810      2253/chromium
                          tcp        0      0 0.0.0.0:9292            0.0.0.0:*               LISTEN      1001       32055      1315/io.hm-rpc.2
                          tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      107        3378       871/redis-server 12
                          tcp6       0      0 ::1:6379                :::*                    LISTEN      107        3379       871/redis-server 12
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       3733       1166/io.admin.0
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       43845      2436/io.web.0
                          tcp6       0      0 :::8086                 :::*                    LISTEN      999        14943      1040/influxd
                          tcp6       0      0 :::111                  :::*                    LISTEN      0          318        1/init
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          31822      883/sshd: /usr/sbin
                          tcp6       0      0 :::18087                :::*                    LISTEN      1001       33814      1510/io.simple-api.
                          tcp6       0      0 :::3040                 :::*                    LISTEN      1001       34582      1901/io.radar-trap.
                          tcp6       0      0 :::51989                :::*                    LISTEN      1001       887        1526/io.nuki-extend
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       42747      2481/io.nanoleaf-li
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       43665      2363/io.nanoleaf-li
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       15003      1193/io.deconz.0
                          udp        0      0 0.0.0.0:34836           0.0.0.0:*                           109        4391       756/avahi-daemon: r
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       95242      5978/io.esphome.0
                          udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1001       89789      6105/python3
                          udp        0      0 192.168.37.200:5353     0.0.0.0:*                           1001       89788      6105/python3
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       89784      6105/python3
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       37229      2005/io.wled.0
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           109        4389       756/avahi-daemon: r
                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17676      1/init
                          udp        0      0 192.168.37.200:123      0.0.0.0:*                           102        3431       1029/ntpd
                          udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          3403       1029/ntpd
                          udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          3399       1029/ntpd
                          udp6       0      0 :::1900                 :::*                                1001       15005      1193/io.deconz.0
                          udp6       0      0 :::1900                 :::*                                1001       15004      1193/io.deconz.0
                          udp6       0      0 :::36195                :::*                                109        4392       756/avahi-daemon: r
                          udp6       0      0 :::5353                 :::*                                109        4390       756/avahi-daemon: r
                          udp6       0      0 :::111                  :::*                                0          17677      1/init
                          udp6       0      0 fdcf:9dad:fec3:4ad8:123 :::*                                102        3605       1029/ntpd
                          udp6       0      0 fe80::a4f4:94ff:fec:123 :::*                                102        3434       1029/ntpd
                          udp6       0      0 ::1:123                 :::*                                0          3405       1029/ntpd
                          udp6       0      0 :::123                  :::*                                0          3396       1029/ntpd
                          2024-03-08 14:14:17.462  - info: javascript.0 (11571) Watch /home/iobroker/javascript/Fenster/
                          2024-03-08 14:14:17.462  - info: javascript.0 (11571) Watch /home/iobroker/javascript/Garten/Bewässerung/
                          2024-03-08 14:14:17.462  - info: javascript.0 (11571) Watch /home/iobroker/javascript/Garten/Pool/
                          2024-03-08 14:14:17.463  - info: javascript.0 (11571) Watch /home/iobroker/javascript/Garten/
                          2024-03-08 14:14:17.464  - info: javascript.0 (11571) Watch /home/iobroker/javascript/Heizung/Konvertierungen/
                          2024-03-08 14:14:17.464  - info: javascript.0 (11571) Watch /home/iobroker/javascript/Klima/
                          2024-03-08 14:14:17.464  - info: javascript.0 (11571) Watch /home/iobroker/javascript/Netzwerk/
                          2024-03-08 14:14:17.465  - info: javascript.0 (11571) Watch /home/iobroker/javascript/Schalter/DG/
                          2024-03-08 14:14:17.465  - info: javascript.0 (11571) Watch /home/iobroker/javascript/Schalter/EG/
                          2024-03-08 14:14:17.465  - info: javascript.0 (11571) Watch /home/iobroker/javascript/Schalter/OG/
                          2024-03-08 14:14:17.466  - info: javascript.0 (11571) Watch /home/iobroker/javascript/Schalter/
                          2024-03-08 14:14:17.466  - info: javascript.0 (11571) Watch /home/iobroker/javascript/System/Instanzen/
                          2024-03-08 14:14:17.466  - info: javascript.0 (11571) Watch /home/iobroker/javascript/System/VIS/
                          2024-03-08 14:14:17.467  - info: javascript.0 (11571) Watch /home/iobroker/javascript/System/
                          2024-03-08 14:14:17.467  - info: javascript.0 (11571) Watch /home/iobroker/javascript/Test/
                          2024-03-08 14:14:17.467  - info: javascript.0 (11571) Watch /home/iobroker/javascript/Verbrauch/
                          2024-03-08 14:14:17.467  - info: javascript.0 (11571) Watch /home/iobroker/javascript/common/
                          2024-03-08 14:14:17.468  - info: javascript.0 (11571) Watch /home/iobroker/javascript/global/
                          2024-03-08 14:15:00.029  - info: host.iobrokernano instance system.adapter.blueconnect.0 started with pid 11708
                          2024-03-08 14:15:12.147  - info: host.iobrokernano instance system.adapter.blueconnect.0 terminated with code 0 (NO_ERROR)
                          2024-03-08 14:15:41.295  - warn: web.0 (2436) Empty pattern on subscribe!
                          2024-03-08 14:16:00.034  - info: host.iobrokernano instance system.adapter.dwd.0 started with pid 12222
                          2024-03-08 14:16:02.905  - info: host.iobrokernano instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          ... und bisher funktionieren auch alle Trigger 😊
