  4. [gelöst]Kann node. js und NPM nicht updaten
31 Beiträge 5 Kommentatoren 2.9k Aufrufe 3 Beobachtet
  • D dirkheider
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     09:23:49 up 37 days, 55 min,  1 user,  load average: 1.05, 1.33, 1.45
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sun 2024-02-18 09:23:49 CET
               Universal time: Sun 2024-02-18 08:23:49 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            3.8G        2.5G        525M        0.0K        779M        1.2G
    Swap:            99M        5.0M         94M
    Total:          3.9G        2.5G        619M
             3794 M total memory
             2489 M used memory
             2534 M active memory
              443 M inactive memory
              525 M free memory
               62 M buffer memory
              716 M swap cache
               99 M total swap
                5 M used swap
               94 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       59G  7.0G   49G  13% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  1.1M  758M   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    /dev/sda1      vfat       29G  3.0G   26G  11% /media/usbstick
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Fri Jan 12 08:28:44 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:85:4B:66 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=70d9c91d-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Fri Jan 12 08:28:45 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Fri Jan 12 08:28:45 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Fri Jan 12 08:28:45 2024] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
    [Fri Jan 12 08:28:45 2024] EXT4-fs (mmcblk0p2): 4 orphan inodes deleted
    [Fri Jan 12 08:28:45 2024] EXT4-fs (mmcblk0p2): recovery complete
    [Fri Jan 12 08:28:46 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Fri Jan 12 08:28:46 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Fri Jan 12 08:28:48 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET            SOURCE         FSTYPE OPTIONS
    /                 /dev/mmcblk0p2 ext4   rw,noatime
    |-/boot           /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/media/usbstick /dev/sda1      vfat   rw,noatime,uid=1001,gid=1001,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
    /var:
    1.4G    /var/
    850M    /var/log
    849M    /var/log/journal/e65d0c5a6bb249ea952a43dc9a55bac2
    308M    /var/cache
    Archived and active journals take up 848.1M in the file system.
    /opt/iobroker/backups:
    499M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    417M    /opt/iobroker/iobroker-data/
    199M    /opt/iobroker/iobroker-data/files
    81M     /opt/iobroker/iobroker-data/backup-objects
    71M     /opt/iobroker/iobroker-data/node-red/node_modules
    44M     /opt/iobroker/iobroker-data/states.jsonl
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    23M     /opt/iobroker/iobroker-data/objects.jsonl
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    20M     /opt/iobroker/iobroker-data/node-red/node_modules/sharp/vendor/8.10.6/lib/libvips-cpp.so.42
    USB-Devices by-id:
    /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
    *** NodeJS-Installation ***
    /home/iobroker/.diag.sh: line 277: nodejs: command not found
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    /usr/bin/corepack       0.18.0
    /home/iobroker/.diag.sh: line 288: nodejs: command not found
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.13.16
    javascript:     7.8.0
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              -  enabled
    + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
      system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
    + system.adapter.followthesun.0           : followthesun          : raspberrypi                              -  enabled
    + system.adapter.fullcalendar.0           : fullcalendar          : raspberrypi                              -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 18701
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
    + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 12010
    + system.adapter.hm-rpc.3                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.mihome-lamp.0            : mihome-lamp           : raspberrypi                              -  enabled, port: 54321
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
    + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.onvif.0                  : onvif                 : raspberrypi                              -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
      system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
    + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
    + system.adapter.reolink.0                : reolink               : raspberrypi                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
    + system.adapter.samsung.0                : samsung               : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8111, bind: 0.0.0.0, run as: admin
      system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              - disabled
    + system.adapter.telegram.1               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
    + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.web.1                    : web                   : raspberrypi                              -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "device-watcher": 2.9.6   , installed 2.9.6
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "email"        : 1.2.2    , installed 1.2.2
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "followthesun" : 0.5.0    , installed 0.5.0
    Adapter    "fullcalendar" : 2.3.4    , installed 2.3.4
    Adapter    "fullybrowser" : 3.0.9    , installed 3.0.9
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "mihome-lamp"  : 1.1.0    , installed 1.1.0
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "node-red"     : 5.1.0    , installed 5.1.0
    Adapter    "onvif"        : 1.1.1    , installed 1.1.1
    Adapter    "openweathermap": 1.0.4   , installed 1.0.4
    Adapter    "pushover"     : 3.0.6    , installed 3.0.6
    Adapter    "reolink"      : 1.0.3    , installed 1.0.3
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
    Objects and States
    Objects:        20142
    States:         16026
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.178.40:49292    0.0.0.0:*               LISTEN      1001       43874317   3123164/io.hm-rpc.3
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12618      556/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          1890       579/lighttpd
    tcp        0      0 192.168.178.40:18701    0.0.0.0:*               LISTEN      1001       43872214   3123082/io.hm-rpc.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       43872822   3122880/iobroker.js
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       43869502   3122880/iobroker.js
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       43871820   3122993/node-red
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       43874349   3123250/io.mqtt.0
    tcp        0      0 192.168.178.40:12010    0.0.0.0:*               LISTEN      1001       43873356   3123112/io.hm-rpc.2
    tcp        0      0 192.168.178.40:12001    0.0.0.0:*               LISTEN      1001       43873053   3123097/io.hm-rpc.1
    tcp6       0      0 :::3000                 :::*                    LISTEN      1001       43874945   3123611/io.fullybro
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12620      556/sshd: /usr/sbin
    tcp6       0      0 :::80                   :::*                    LISTEN      0          1891       579/lighttpd
    tcp6       0      0 :::8111                 :::*                    LISTEN      1001       43876516   3123502/io.simple-a
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       43870883   3122898/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       43876407   3123412/io.web.0
    tcp6       0      0 :::8083                 :::*                    LISTEN      1001       43873852   3123432/io.web.1
    tcp6       0      0 :::8095                 :::*                    LISTEN      1001       43876076   3123622/io.onvif.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12547      411/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       43869916   3123206/io.shelly.0
    udp        0      0 0.0.0.0:42625           0.0.0.0:*                           108        12549      411/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15154      670/dhcpcd
    udp        0      0 0.0.0.0:53423           0.0.0.0:*                           1001       43876787   3123690/io.mihome-l
    udp6       0      0 :::5353                 :::*                                108        12548      411/avahi-daemon: r
    udp6       0      0 :::59769                :::*                                108        12550      411/avahi-daemon: r
    2024-02-18 09:11:17.342  - info: javascript.0 (3122936) script.js.Sammlung.Tablet_umschalten_Kamera: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2024-02-18 09:11:17.343  - info: javascript.0 (3122936) Start javascript script.js.Sammlung.Tablet_umschalten_Neo
    2024-02-18 09:11:17.351  - info: javascript.0 (3122936) script.js.Sammlung.Tablet_umschalten_Neo: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2024-02-18 09:11:17.365  - info: javascript.0 (3122936) Start javascript script.js.Sammlung.PC_an_aus
    2024-02-18 09:11:17.373  - info: javascript.0 (3122936) script.js.Sammlung.PC_an_aus: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2024-02-18 09:11:17.374  - info: javascript.0 (3122936) Start javascript script.js.Sammlung.Klingel_ein_ausschalten_mit_Handy_neu
    2024-02-18 09:11:17.381  - info: javascript.0 (3122936) script.js.Sammlung.Klingel_ein_ausschalten_mit_Handy_neu: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2024-02-18 09:11:17.384  - info: javascript.0 (3122936) Start javascript script.js.Beleuchtung.Ledstreifen_TV
    2024-02-18 09:11:17.392  - info: javascript.0 (3122936) script.js.Beleuchtung.Ledstreifen_TV: registered 4 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2024-02-18 09:12:30.301  - info: admin.0 (3122898) ==> Connected system.user.admin from ::ffff:192.168.178.62
    2024-02-18 09:12:54.710  - info: alexa2.0 (3123149) No smart home devices to query
    2024-02-18 09:12:58.692  - info: alexa2.0 (3123149) Subscribing to states...
    2024-02-18 09:12:58.703  - info: alexa2.0 (3123149) Deleting the following states: ["Smart-Home-Devices.0ed7dd37-5ec6-4e29-a2da-f6587e815023","Smart-Home-Devices.21b95856-695b-4faf-b3c7-94950a6e1f55","Smart-Home-Devices.30dcc6ad-8a1c-4aa6-b1f3-9e52bdd8d63e","Smart-Home-Devices.413aff1f-a6de-4ca8-aaf9-4714ab9fb974","Smart-Home-Devices.68e4d4f0-cdcd-48fd-912d-eaafbd688a24","Smart-Home-Devices.7e10b4d6-6463-4eb3-918d-6929c1e8358f","Smart-Home-Devices.7e34e12d-68b4-471c-b71a-cd5c1b08bbd7","Smart-Home-Devices.8ac119dd-80bd-4db0-869c-b1f08127b61f","Smart-Home-Devices.a893c44d-8436-468e-b9ec-ee1892279542","Smart-Home-Devices.b25c40b2-c8d4-4f2c-97f8-55f38386f070","Smart-Home-Devices.c09b63b3-bb2b-41b1-995f-f72c5fefc449","Smart-Home-Devices.c110e7e8-6bfc-47f7-be41-f92bfb7d004a","Smart-Home-Devices.c641e86a-04b0-4236-a7c5-e87263705526","Smart-Home-Devices.e88c2a2d-098b-42d9-9a26-278f847ce031","Smart-Home-Devices.ef438d97-f1eb-4cf8-a4f6-6a3a98a6feec","Smart-Home-Devices.f7521cc7-e0db-4acf-98cc-3af07d2c7889","Smart-Home-Devices.eba8e8ef-cac2-4671-9a3a-c2495fd7b42c","Smart-Home-Devices.8658ec07-64e9-40ff-9fa7-035639c7da8d","Smart-Home-Devices.0ed7dd37-5ec6-4e29-a2da-f6587e815023.#delete","Smart-Home-Devices.0ed7dd37-5ec6-4e29-a2da-f6587e815023.#enabled","Smart-Home-Devices.0ed7dd37-5ec6-4e29-a2da-f6587e815023.#includeInAllQuery","Smart-Home-Devices.0ed7dd37-5ec6-4e29-a2da-f6587e815023.#query","Smart-Home-Devices.0ed7dd37-5ec6-4e29-a2da-f6587e815023.Blind-Lift-rangeValue","Smart-Home-Devices.0ed7dd37-5ec6-4e29-a2da-f6587e815023.percentage","Smart-Home-Devices.21b95856-695b-4faf-b3c7-94950a6e1f55.#delete","Smart-Home-Devices.21b95856-695b-4faf-b3c7-94950a6e1f55.#enabled","Smart-Home-Devices.21b95856-695b-4faf-b3c7-94950a6e1f55.powerState","Smart-Home-Devices.30dcc6ad-8a1c-4aa6-b1f3-9e52bdd8d63e.#delete","Smart-Home-Devices.30dcc6ad-8a1c-4aa6-b1f3-9e52bdd8d63e.#enabled","Smart-Home-Devices.30dcc6ad-8a1c-4aa6-b1f3-9e52bdd8d63e.powerState","Smart-Home-Devices.413aff1f-a6de-4ca8-aaf9-4714ab9fb974.#delete","Smart-Home-Devices.413aff1f-a6de-4ca8-aaf9-4714ab9fb974.#enabled","Smart-Home-Devices.413aff1f-a6de-4ca8-aaf9-4714ab9fb974.#includeInAllQuery","Smart-Home-Devices.413aff1f-a6de-4ca8-aaf9-4714ab9fb974.#query","Smart-Home-Devices.413aff1f-a6de-4ca8-aaf9-4714ab9fb974.powerState","Smart-Home-Devices.68e4d4f0-cdcd-48fd-912d-eaafbd688a24.#delete","Smart-Home-Devices.68e4d4f0-cdcd-48fd-912d-eaafbd688a24.#enabled","Smart-Home-Devices.68e4d4f0-cdcd-48fd-912d-eaafbd688a24.#includeInAllQuery","Smart-Home-Devices.68e4d4f0-cdcd-48fd-912d-eaafbd688a24.#query","Smart-Home-Devices.68e4d4f0-cdcd-48fd-912d-eaafbd688a24.Blind-Lift-rangeValue","Smart-Home-Devices.68e4d4f0-cdcd-48fd-912d-eaafbd688a24.percentage","Smart-Home-Devices.7e10b4d6-6463-4eb3-918d-6929c1e8358f.#delete","Smart-Home-Devices.7e10b4d6-6463-4eb3-918d-6929c1e8358f.#enabled","Smart-Home-Devices.7e10b4d6-6463-4eb3-918d-6929c1e8358f.#includeInAllQuery","Smart-Home-Devices.7e10b4d6-6463-4eb3-918d-6929c1e8358f.#query","Smart-Home-Devices.7e10b4d6-6463-4eb3-918d-6929c1e8358f.connectivity","Smart-Home-Devices.7e10b4d6-6463-4eb3-918d-6929c1e8358f.connectivity-reason","Smart-Home-Devices.7e10b4d6-6463-4eb3-918d-6929c1e8358f.powerState","Smart-Home-Devices.7e34e12d-68b4-471c-b71a-cd5c1b08bbd7.#delete","Smart-Home-Devices.7e34e12d-68b4-471c-b71a-cd5c1b08bbd7.#enabled","Smart-Home-Devices.7e34e12d-68b4-471c-b71a-cd5c1b08bbd7.#includeInAllQuery","Smart-Home-Devices.7e34e12d-68b4-471c-b71a-cd5c1b08bbd7.#query","Smart-Home-Devices.7e34e12d-68b4-471c-b71a-cd5c1b08bbd7.powerState","Smart-Home-Devices.8ac119dd-80bd-4db0-869c-b1f08127b61f.#delete","Smart-Home-Devices.8ac119dd-80bd-4db0-869c-b1f08127b61f.#enabled","Smart-Home-Devices.8ac119dd-80bd-4db0-869c-b1f08127b61f.#includeInAllQuery","Smart-Home-Devices.8ac119dd-80bd-4db0-869c-b1f08127b61f.#query","Smart-Home-Devices.8ac119dd-80bd-4db0-869c-b1f08127b61f.brightness","Smart-Home-Devices.8ac119dd-80bd-4db0-869c-b1f08127b61f.color-brightness","Smart-Home-Devices.8ac119dd-80bd-4db0-869c-b1f08127b61f.color-hue","Smart-Home-Devices.8ac119dd-80bd-4db0-869c-b1f08127b61f.color-saturation","Smart-Home-Devices.8ac119dd-80bd-4db0-869c-b1f08127b61f.colorName","Smart-Home-Devices.8ac119dd-80bd-4db0-869c-b1f08127b61f.colorRgb","Smart-Home-Devices.8ac119dd-80bd-4db0-869c-b1f08127b61f.colorTemperatureInKelvin","Smart-Home-Devices.8ac119dd-80bd-4db0-869c-b1f08127b61f.colorTemperatureName","Smart-Home-Devices.8ac119dd-80bd-4db0-869c-b1f08127b61f.powerState","Smart-Home-Devices.a893c44d-8436-468e-b9ec-ee1892279542.#delete","Smart-Home-Devices.a893c44d-8436-468e-b9ec-ee1892279542.#enabled","Smart-Home-Devices.b25c40b2-c8d4-4f2c-97f8-55f38386f070.#delete","Smart-Home-Devices.b25c40b2-c8d4-4f2c-97f8-55f38386f070.#enabled","Smart-Home-Devices.b25c40b2-c8d4-4f2c-97f8-55f38386f070.#includeInAllQuery","Smart-Home-Devices.b25c40b2-c8d4-4f2c-97f8-55f38386f070.#query","Smart-Home-Devices.b25c40b2-c8d4-4f2c-97f8-55f38386f070.Camera-PrivacyMode-toggleState","Smart-Home-Devices.b25c40b2-c8d4-4f2c-97f8-55f38386f070.connectivity","Smart-Home-Devices.b25c40b2-c8d4-4f2c-97f8-55f38386f070.connectivity-reason","Smart-Home-Devices.c09b63b3-bb2b-41b1-995f-f72c5fefc449.#delete","Smart-Home-Devices.c09b63b3-bb2b-41b1-995f-f72c5fefc449.#enabled","Smart-Home-Devices.c09b63b3-bb2b-41b1-995f-f72c5fefc449.#includeInAllQuery","Smart-Home-Devices.c09b63b3-bb2b-41b1-995f-f72c5fefc449.#query","Smart-Home-Devices.c09b63b3-bb2b-41b1-995f-f72c5fefc449.detectionState","Smart-Home-Devices.c110e7e8-6bfc-47f7-be41-f92bfb7d004a.#delete","Smart-Home-Devices.c110e7e8-6bfc-47f7-be41-f92bfb7d004a.#enabled","Smart-Home-Devices.c110e7e8-6bfc-47f7-be41-f92bfb7d004a.#includeInAllQuery","Smart-Home-Devices.c110e7e8-6bfc-47f7-be41-f92bfb7d004a.#query","Smart-Home-Devices.c110e7e8-6bfc-47f7-be41-f92bfb7d004a.powerState","Smart-Home-Devices.c641e86a-04b0-4236-a7c5-e87263705526.#delete","Smart-Home-Devices.c641e86a-04b0-4236-a7c5-e87263705526.brightness","Smart-Home-Devices.c641e86a-04b0-4236-a7c5-e87263705526.color-brightness","Smart-Home-Devices.c641e86a-04b0-4236-a7c5-e87263705526.color-hue","Smart-Home-Devices.c641e86a-04b0-4236-a7c5-e87263705526.color-saturation","Smart-Home-Devices.c641e86a-04b0-4236-a7c5-e87263705526.colorName","Smart-Home-Devices.c641e86a-04b0-4236-a7c5-e87263705526.colorRgb","Smart-Home-Devices.c641e86a-04b0-4236-a7c5-e87263705526.colorTemperatureInKelvin","Smart-Home-Devices.c641e86a-04b0-4236-a7c5-e87263705526.colorTemperatureName","Smart-Home-Devices.c641e86a-04b0-4236-a7c5-e87263705526.powerState","Smart-Home-Devices.e88c2a2d-098b-42d9-9a26-278f847ce031.#delete","Smart-Home-Devices.e88c2a2d-098b-42d9-9a26-278f847ce031.#enabled","Smart-Home-Devices.e88c2a2d-098b-42d9-9a26-278f847ce031.#includeInAllQuery","Smart-Home-Devices.e88c2a2d-098b-42d9-9a26-278f847ce031.#query","Smart-Home-Devices.e88c2a2d-098b-42d9-9a26-278f847ce031.brightness","Smart-Home-Devices.e88c2a2d-098b-42d9-9a26-278f847ce031.color-brightness","Smart-Home-Devices.e88c2a2d-098b-42d9-9a26-278f847ce031.color-hue","Smart-Home-Devices.e88c2a2d-098b-42d9-9a26-278f847ce031.color-saturation","Smart-Home-Devices.e88c2a2d-098b-42d9-9a26-278f847ce031.colorName","Smart-Home-Devices.e88c2a2d-098b-42d9-9a26-278f847ce031.colorRgb","Smart-Home-Devices.e88c2a2d-098b-42d9-9a26-278f847ce031.colorTemperatureInKelvin","Smart-Home-Devices.e88c2a2d-098b-42d9-9a26-278f847ce031.colorTemperatureName","Smart-Home-Devices.e88c2a2d-098b-42d9-9a26-278f847ce031.powerState","Smart-Home-Devices.ef438d97-f1eb-4cf8-a4f6-6a3a98a6feec.#delete","Smart-Home-Devices.ef438d97-f1eb-4cf8-a4f6-6a3a98a6feec.#enabled","Smart-Home-Devices.f7521cc7-e0db-4acf-98cc-3af07d2c7889.#delete","Smart-Home-Devices.f7521cc7-e0db-4acf-98cc-3af07d2c7889.#enabled","Smart-Home-Devices.eba8e8ef-cac2-4671-9a3a-c2495fd7b42c.#enabled","Smart-Home-Devices.eba8e8ef-cac2-4671-9a3a-c2495fd7b42c.#delete","Smart-Home-Devices.eba8e8ef-cac2-4671-9a3a-c2495fd7b42c.powerState","Smart-Home-Devices.8658ec07-64e9-40ff-9fa7-035639c7da8d.#enabled","Smart-Home-Devices.8658ec07-64e9-40ff-9fa7-035639c7da8d.#delete","Smart-Home-Devices.8658ec07-64e9-40ff-9fa7-035639c7da8d.powerState"]
    2024-02-18 09:13:00.703  - info: alexa2.0 (3123149) Alexa-Push-Connection (macDms = true) established. Disable Polling
    2024-02-18 09:13:16.603  - info: alexa2.0 (3123149) Initialization Done ...
    2024-02-18 09:13:35.379  - info: admin.0 (3122898) ==> Connected system.user.admin from ::ffff:192.168.178.62
    2024-02-18 09:13:38.965  - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2024-02-18 09:18:54.367  - info: admin.0 (3122898) <== Disconnect system.user.admin from ::ffff:192.168.178.62
    2024-02-18 09:18:54.384  - info: admin.0 (3122898) <== Disconnect system.user.admin from ::ffff:192.168.178.62 admin
    2024-02-18 09:19:43.467  - info: shelly.0 (3123206) [CoAP] Device 192.168.178.24 (shelly1 / shelly1-E8DB84D21FD7 / SHSW-1#E8DB84D21FD7#1) connected! Polltime set to 15 sec.
    2024-02-18 09:22:00.656  - info: host.raspberrypi instance system.adapter.weatherunderground.0 started with pid 3126507
    2024-02-18 09:22:03.195  - info: weatherunderground.0 (3126507) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2024-02-18 09:22:03.523  - info: weatherunderground.0 (3126507) starting. Version 3.6.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v18.17.1, js-controller: 5.0.17
    2024-02-18 09:22:13.307  - info: weatherunderground.0 (3126507) Terminated (NO_ERROR): Without reason
    2024-02-18 09:22:13.850  - info: host.raspberrypi instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
    sorry:-)
    HomoranH Offline
    HomoranH Offline
    @dirkheider sagte in Kann node. js und NPM nicht updaten:
    dein Dateisystem hat einen Schuss abbekommen
    da bist du anscheinend noch im alten node Repo
    iob nodejs-update sollte das fixen
      dirkheider
      @homoran said in Kann node. js und NPM nicht updaten:
      iob nodejs-update
      Das hat funktioniert........ich liebe dieses Forum:-)))
      Danke dir......einen schönen Sonntag noch
      Samson71S HomoranH 2 Antworten Letzte Antwort
      • D dirkheider
        iob nodejs-update
        Samson71S Offline
        Samson71S Offline
        Samson71
        @dirkheider
        Das ändert aber nichts an dem Hinweis von @Homoran, dass Dein Dateisystem einen Weg hat.
        Markus
        Bitte beachten:
        • Samson71S Samson71
          @dirkheider
          dirkheider
          @samson71
          okay......was heißt das für mich?
          update hat auf jeden Fall funktioniert
          • D dirkheider
            iob nodejs-update
            HomoranH Offline
            HomoranH Offline
            @dirkheider sagte in [gelöst]Kann node. js und NPM nicht updaten:
            iob nodejs-update
            dann setze den Thread auf [gelöst]
            @samson71 sagte in [gelöst]Kann node. js und NPM nicht updaten:
            das knallt doch erst später, wenn sich niemand mehr an die verwaisten Dateifragmente erinnert 😁
              iob nodejs-update
              dirkheider
              schon passiert......
              muss ich noch irgendwas tun nun?, wegen dem Dateisystem?
              • D dirkheider
                @samson71
                Samson71S Offline
                Samson71S Offline
                Samson71
                @dirkheider
                Auf jeden Fall erstmal Daten sichern bzw. Backup machen. Läuft das auf einer SD-Karte? Dann ggf. neue Karte nehmen, frische Installation drauf, Backup einspielen.
                Markus
                Bitte beachten:
                • D dirkheider
                  HomoranH Offline
                  HomoranH Offline
                  Das System hat Dareireste am Wegesrand gefunden an denen kein Schild dranstand wohin sie gehören.
                  Also wurde aufgeräumt und die Fragmente vernichtet.
                  Wenn du Glück hast waren das Dateien, die jetzt beim Update neu geladen und geschrieben wurden.
                  ist eher unwahrscheinlich.
                  Also ist irgendwo 1 - 4 defekte Datei(en). was immer das für Auswirkungen hat.
                    dirkheider
                    Ah okay, es läuft alles ohne Fehler. Dann hoffe ich mal, dass es so bleibt.
                    Danke nochmal für die unkomplizierte Hilfe
                    Gruß Dirk
                    • D dirkheider
                      Gruß Dirk
                      HomoranH Offline
                      HomoranH Offline
                      da fällt mircein alter Spruch ein: "nur weil man es nicht sieht, heisst es nicht, dass es nicht da ist" ;-)
                        dirkheider
                        Da haste recht, aber wie soll ich das rausfinden woran es liegt?
                        HomoranH W 2 Antworten Letzte Antwort
                        • D dirkheider
                          HomoranH Offline
                          HomoranH Offline
                          kannst du ja leider nicht.
                          selbst bei einer kompletten Neuinstallation und der Wiederherstellung eines jetzt gemachten Backups, könnten historisierte Daten fehlen oder Konfigurationen defekt sein.
                          Da das letztere aber nur sehr kleine Dateien sind, ist die Wahrscheinlichkeit dass es im OS oder den node-modulen fehkt größer
                            dirkheider
                            also abwarten ob irgendwann etwas nicht mehr geht? :-)
                            • D dirkheider
                              W Online
                              W Online
                              Wildbill
                              @dirkheider Das kannst Du nicht. Es kann gut gehen, es kann aber auch in einem Tag, einer Woche, einem Monat oder noch später zu plötzlichen Problemen kommen, wenn das System doch auf eine der zerstörten Dateien zugreifen will. Von Fehlermeldungen bis zum kompletten Aufhängen ist dann alles drin.
                              Einzig korrekter Weg wäre, das Betriebssyastem neu aufzusetzen und dann ein Backup einzuspielen und iobroker so frisch zu installieren. Alles andere ist eine tickende Zeitbombe.
                              Hast Du mal im laufenden Betrieb den Strom hart weggenommen, ohne vorher sauber runterzufahren? das sind gern gemachte Fehler, die zu zerstörten Dateien führen. Im dümmsten Fall wird dabei gleich das ganze Dateisystem zerstört, bei einem Raspberry wird so auch gerne mal die SD-Karte gekillt, so dass eine neue ansteht.
                              Gruss, Jürgen
                              • D dirkheider
                                HomoranH Offline
                                HomoranH Offline
                                ja! und die Waisen immer im Hinterkopf behalten wenn es "seltsames Verhalten" gibt.
                                Außerdem würde ich jetzt öfter mal iob diag fahren und wenn da nochmal orphans auftauchen sofort komplett neu aufbauen.
                                  dirkheider
                                  Okay...habe ja ein iobroker backup. Dann setze ich einfach das System neu auf und dann spiele ich das Backup vom Iobroker neu ein. Ist dann wohl die beste Lösung.
                                  @Wildbill : Habe ich leider schonmal gemacht........das gehört nun der Vergangenheit an
                                  • D dirkheider
                                    Ich hoffe, das ist nicht mit dem windigen 'Super-Tool' vom Elsterhai gemacht...
                                    Finger weg von dem Ding!
                                    Zum root hast du ja schon was gehört...
                                    Du könntest die Gelegenheit aber nutzen und das aktuelle stabile Release 'Bookworm' von Grund auf neu installieren und dann die bisherigen Fehler vermeiden
                                      dirkheider
                                      habe das tool für backup genutzt.....ist es nicht gut?
                                      soll ich das 32 bit oder das 64 bit Bookworm nehmen? Habe einen Raspberry 4
                                      • D dirkheider
                                        HomoranH Offline
                                        HomoranH Offline
                                        für iobroker Backups gibt es den backitup Adapter!
                                        beim pi4 64 bit lite
                                          dirkheider
                                          ich glaube ich kauf mir direkt ne neue micro SD Karte. Habt ihr eine Empfehlung für mich?
