  4. [ESPHome] Beta release 0.5.0-beta.1 ready
adapter entwicklungadapter updateesphome
134 Beiträge 17 Kommentatoren 21.3k Aufrufe 17 Beobachtet
  • simonf04S simonf04
    @thomas-braun das ganze war eigentlich auch mal dynmisch auf immer die neuste Version, kein plan warum es hier geändert / auf eine Version fixiert wurde: https://github.com/DrozmotiX/ioBroker.esphome/commit/6600a6aeb9a82fcecc5f848aa72a780d73998402
    WebrangerW Offline
    WebrangerW Offline
    Webranger
    Kann mir evtl wer helfen?
    Hab gerade espHome installiert und komme nicht auf das dashbord.
    in den logs taucht dieser Fehler auf.
    [Error caught and send to Sentry, thank you collaborating!] error: Error: Command failed with exit code 1: /home/iobroker/.cache/autopy/python/3.11.7/bin/python3 -m venv /home/iobroker/.cache/autopy/venv/esphomePython path configuration: PYTHONHOME = (not set) PYTHONPATH = (not set) program name = '/home/iobroker/.cache/autopy/python/3.11.7/bin/python3' isolated = 0 environment = 1 user site = 1 safe_path = 0 import site = 1 is in build tree = 0 stdlib dir = '/home/iobroker/.cache/autopy/python/3.11.7/lib/python3.11' sys._base_executable = '/home/iobroker/.cache/autopy/python/3.11.7/bin/python3' sys.base_prefix = '/home/iobroker/.cache/autopy/python/3.11.7' sys.base_exec_prefix = '/home/iobroker/.cache/autopy/python/3.11.7' sys.platlibdir = 'lib' sys.executable = '/home/iobroker/.cache/autopy/python/3.11.7/bin/python3' sys.prefix = '/home/iobroker/.cache/autopy/python/3.11.7' sys.exec_prefix = '/home/iobroker/.cache/autopy/python/3.11.7' sys.path = [ '/home/iobroker/.cache/autopy/python/3.11.7/lib/python311.zip', '/home/iobroker/.cache/autopy/python/3.11.7/lib/python3.11', '/home/iobroker/.cache/autopy/python/3.11.7/lib/python3.11/lib-dynload', ]Fatal Python error: init_fs_encoding: failed to get the Python codec of the filesystem encodingPython runtime state: core initializedLookupError: no codec search functions registered: can't find encodingCurrent thread 0x00007f282281c740 (most recent call first): <no Python frame> at makeError (file:///opt/iobroker/node_modules/autopy/node_modules/execa/lib/error.js:60:11) at handlePromise (file:///opt/iobroker/node_modules/autopy/node_modules/execa/index.js:124:26) at processTicksAndRejections (node:internal/process/task_queues:95:5) at $df9eabe9bda49ea8$export$e522f41234ab669a (file:///opt/iobroker/node_modules/autopy/src/index.ts:228:9) at Esphome.espHomeDashboard (/opt/iobroker/node_modules/iobroker.esphome/main.js:110:19) at Esphome.onReady (/opt/iobroker/node_modules/iobroker.esphome/main.js:78:5)
    Kann damit jemand was anfangen und mir sagen was ich falsch gemacht habe?
    Intel NUC Celeron, Xiaomi Gateway, Fritzbox 7590, XS1
    • WebrangerW Webranger
      bernd33-1
      schrieb am zuletzt editiert von bernd33-1
      Hi, nachdem ich meinen ESPHome Adapter aktualisiert hab (0.5.0. Beta 8), bekomme ich auch die Meldung:
        Please update your pillow installation to 10.1.0. (pip install "pillow==10.1.0").
        - file: arial.ttf
          glyphs:
      Wie kann ich auf pillow 10.1.0 aktualisieren? mit pip install "pillow==10.1.0" bekomm ich pip:command not found
      Danke und Grüße, Bernd
      simonf04S 1 Antwort Letzte Antwort
      • B bernd33-1
          - file: arial.ttf
            glyphs:
        simonf04S Offline
        simonf04S Offline
        simonf04
        @bernd33-1 Hi, teste bitte mal mit install direkt von git: https://github.com/SimonFischer04/ioBroker.esphome/tree/fix/latestpillow
          bernd33-1
          @simon42 Danke für die schnelle Antwort leider kein Erfolg. Oder muss der Raspy neu gestartetet werden?
          INFO ESPHome 2023.12.9
          INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/42display.yaml...
          Failed config
          font: [source <unicode string>:43]
            - file: arial.ttf
              glyphs:
          • B bernd33-1
            Failed config
              - file: arial.ttf
                glyphs:
            bernd33-1
            @bernd33-1 Moment mal... das scheint nur den ESP mit dem EPaper Display zu betreffen. Ein anderer ESP der nur 2 Relais ein/aus schaltet tut. Da kann ich das Projekt compilieren. Scheint mit der arial.ttf Datei zusammen zu hängen?
            • B bernd33-1
              simonf04S Offline
              simonf04S Offline
              simonf04
              @bernd33-1 ja das package braucht er nur für bestimmte esphome Komponenten. pls nochmal probiern, hab jetzt fix auf neuere Version geändert.
                bernd33-1
                @simon42 Hi Simon, jetzt geht es. Ich hab/musste die ESPHome Instanz nach der Installation einmal von Hand neu starten und jetzt geht alles wieder. Log und Installieren via OTA.
                Super vielen lieben Dank für die schnelle hilfe! 👍 😊 👏
                Grüße und noch ein schönes WE, Bernd
                • B bernd33-1
                  simonf04S Offline
                  simonf04S Offline
                  simonf04
                  @bernd33-1 Top 👍, No Problem und danke für die Rückmeldung.
                  • P Offline
                    PhilippIO
                    Guten Abend die Herren!
                    Ich springe auch von Version zu Version, bleibe aber immer beim selben Punkt stecken:
                    Mit der Adapter-Version aus den iobroker.net Beta repositories kam der Pillow-Fehler:
                    Nach diversen Versuchen habe ich dieses Forum gefunden, und auf v0.5.0-beta.10 aktualisiert. Das Fehlerbild war minimal anders: 10.2.0 statt 10.1.0:
                    INFO ESPHome 2024.2.0b1
                    INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/waage1.yaml...
                    Failed config
                    font: [source /opt/iobroker/iobroker-data/esphome.0/waage1.yaml:90]
                      Please update your pillow installation to 10.2.0. (pip install "pillow==10.2.0").
                      - file: fonts/Antenna-Bold.ttf
                    Den letzten Beiträgen folgend, habe ich nochmal auf SimonFischer-latestpillow aktualisiert:
                    Der Fehler blieb unverändert.
                    Mein Setup ist wie folgt:
                    Raspi3B+ mit Debian Bookworm 6.1.73 aarch64
                    iobroker v6.13.16 ... frisch installiert als einzige Software auf dem Raspi
                    ESPhome als quasi einziger Adapter
                    Python 3.11.2
                    NPM version 10.2.3
                    Node.js version 18.19.0
                    Python3-pil und pil-imagetk sind aktuell:
                    philipp@testiobroker:~ $ apt policy python3-pil python3-pil.imagetk
                    python3-pil:
                      Installed: 9.4.0-1.1+b1
                      Candidate: 9.4.0-1.1+b1
                      Version table:
                     *** 9.4.0-1.1+b1 500
                            500 http://deb.debian.org/debian bookworm/main arm64 Packages
                    python3-pil.imagetk:
                      Version table:
                    Ich bin für jeden Hinweis dankbar! :man-bowing:
                    • simonf04S Offline
                      simonf04S Offline
                      simonf04
                      schrieb am zuletzt editiert von simonf04
                      @philippio said in [ESPHome] Beta release 0.5.0-beta.1 ready:
                      Genau das das Problem, gab schonwieder ein notwendiges update.
                      Habs wieder geupdated
                      Pls nochmal probiern: https://github.com/SimonFischer04/ioBroker.esphome/tree/fix/latestpillow
                      liegt halt wahrscheinlich dran das du hier eine beta 2024.2.0b1 dashboard installed hast, sonst hätt 10.1.0 reichen müssen, aber habs jetzt auf 10.2.0 updated
                      P F 3 Antworten Letzte Antwort
                        PhilippIO
                        @simon42 Hallo Simon!
                        Zunächst mal vielen Dank für Deine schnelle Hilfe!
                        Über den Pillow-Fehler ist das Installationsskript hinausgelaufen. 👍
                        Jetzt compiliert er seit einer Stunde vor sich hin ... ich werde berichten.
                          PhilippIO
                          Good news: mit der latestpillow-Version hat es funktioniert: mein Projekt ist online, im Netz, sendet Daten, OTA ist möglich ... Vielen Dank!
                          Kleines Aber: Beim Compilieren bleibt der Raspi jedes 2. Mal hängen ... ich habe schon über Nacht gewartet, kein Erfolg. Ausschalten, neu booten, neuer Versuch ... meistens ging es dann weiter. Jetzt aber nicht mehr: nur eine kleine Änderung am YAML-Skript, und er bleibt immer an dieser Stelle stehen:
                          INFO Generating C++ source...
                          INFO Compiling app...
                          Processing waage1 (board: lolin32_lite; framework: arduino; platform: platformio/espressif32@5.4.0)
                          Cannot read termcap database;
                          using dumb terminal settings.
                          HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
                           - toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
                          Dependency Graph
                          |-- AsyncTCP-esphome @ 2.0.1
                          |-- WiFi @ 2.0.0
                          |-- FS @ 2.0.0
                          |-- Update @ 2.0.0
                          |-- ESPAsyncWebServer-esphome @ 3.1.0
                          |-- DNSServer @ 2.0.0
                          |-- ESPmDNS @ 2.0.0
                          |-- noise-c @ 0.1.4
                          |-- SPI @ 2.0.0
                          Compiling .pioenvs/waage1/src/esphome/components/api/api_connection.cpp.o
                          Compiling .pioenvs/waage1/src/esphome/components/api/api_frame_helper.cpp.o
                          Compiling .pioenvs/waage1/src/esphome/components/api/api_pb2.cpp.o
                          Compiling .pioenvs/waage1/src/esphome/components/api/api_pb2_service.cpp.o
                          Erst dreht sich noch der farbige Kreis, dann "Session expired", neu laden des Dashboards funktioniert nicht, dann habe ich auch über SSH keinen Zugriff mehr auf den Raspi. Soweit reproduzierbar. Gibt es noch andere LOG-Dateien, die zeigen könnten, woran es scheitert?
                          Verzweifelt, Philipp
                          • P PhilippIO
                            Dependency Graph
                            |-- WiFi @ 2.0.0
                            |-- FS @ 2.0.0
                            |-- Update @ 2.0.0
                            |-- ESPmDNS @ 2.0.0
                            |-- noise-c @ 0.1.4
                            |-- SPI @ 2.0.0
                            simonf04S Offline
                            simonf04S Offline
                            simonf04
                            @philippio hm, hat die yaml recht viele komponenten? schaut aus als würds im pi zu viel werden und stürzt ab maybe? glaub nicht, dass hier der adapter schuld ist
                            P 1 Antwort Letzte Antwort
                              PhilippIO
                              @simon42 ... dann mache ich mich mal an den Umzug. Der "nackte" Raspi3 sollte zunächst nur der Erstbetankung via USB dienen. Mein operativer iobroker ist auf einem Raspi4 (mit Docker) daheim. Wenn es an der Rechenleistung hängt, sollte dieser dann mit dem Compilieren und späteren OTA-Update weniger Probleme haben. Ich probiere es aus und werde berichten! Danke soweit. 🙂
                              • P PhilippIO
                                simonf04S Offline
                                simonf04S Offline
                                simonf04
                                @philippio naja pi3 sollte ja eigentlich "nur langsamer" sein und nicht ewig komplett aufhängen. aber mal schauen vielleicht hilft der umzug ja: andere iobroker installation, ... 👍🏾
                                  PhilippIO
                                  Entschuldige die späte Antwort. Ich habe mich einige Abende mit Update und Backup (inkl. der ganzen Docker-Umgebung) beschäftigt, bevor ich mich an den Umzug des ESPhome device machen konnte. Ergebnis: Erfolg! Das Compilieren läuft komplett durch, Flashen OTA funktioniert reibungslos, alles top! 👍
                                  Offenbar reicht ein Raspi3B+ dann doch nicht aus ... wie gesagt: frisch aufgesetzt, iobroker als einzige Software, ESPhome als einziger Adapter. Das yaml-Skript sollte auch keine große Herausforderung gewesen sein: eine HX711-Waage mit Display
                                  Letzter offener Punkt: Ich schaffe es nicht, den Umzug ganz abzuschließen. Ich sehe mein Device unter Instanzeinstellungen.esphome - Geräte als gelistet und connected. Und nach Import des yaml-Files nach /opt/iobroker/iobroker-data/esphome.0/ sehe ich das device auf dem Dashboard. Aber: immer als offline. "edit" und "log" funktionieren problemlos, nachdem ich eine manual-IP im yaml-Skript ergänzt habe.
                                  Fehlt mir da beim Umzug noch ein letzter Schritt? Meine Vermutung ist, dass er den Eintrag unter Geräte und das Device auf dem Dashboard nicht miteinander in Verbindung bringt ... denn sonst hätte er die IP gewusst.
                                  • P PhilippIO
                                    simonf04S Offline
                                    simonf04S Offline
                                    simonf04
                                    @philippio Sorry für die späte Antwort
                                    Völlig korrekt, das Dashboard (https://github.com/esphome/dashboard) hat mit dem adapter direkt nix zu tun. Adapter startet das einfach nur. (dashboard extern betreiben. oder auch gar nicht würd nix an der adapterfunktionalität / steuern und auslesen der existierenden Geräte im iobroker ändern)
                                    Wird das device nach eintragen der IP dann als online angezeigt? Schaut aus als gäbs bei der Probleme mit mDNS / auflösen von hostname zu ip. Aber wie gesagt, das dasboard ist im Prinzip eine "komplett" externe Komponente. Hat so gesehen nix mit dem adapter zu tun, wird "nur aus user-experience Erleichterung" mitinstalliert
                                      PhilippIO
                                      @simon42 sagte in [ESPHome] Beta release 0.5.0-beta.1 ready:
                                      Tatsächlich: nein. Es bleibt auf offline.
                                      Habe ich das Device falsch importiert? Fehlt mir noch eine Eintragung, um hostname zu IP zu verknüpfen?
                                      P.S.: "user-experience" trifft es aber sehr gut. Ich habe schon einige Arduinos, Raspis und Co programmiert. Aber dieser Weg, direkt OTA aus dem Zielsystem (=iobroker) heraus, ist schon eine sehr gelungene Lösung!
                                      • P PhilippIO
                                        simonf04S Offline
                                        simonf04S Offline
                                        simonf04
                                        mDNS sollte eigentlich automatisch funktionieren, solang die Geräte im gleichen Netzwerk sind. Sind sie das bei dir?
                                        Danke!
                                          Fischje
                                          @simon42
                                          iob url https://github.com/SimonFischer04/ioBroker.esphome/tree/fix/latestpillow
                                          Danach komm ich nicht mehr auf das Dashboard:
                                          Fatal error starting ESPHomeDashboard | Error: Command failed with exit code 1: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip install pillow==10.2.0 WARNING: Ignoring invalid distribution ~illow (/home/iobroker/.cache/autopy/venv/esphome/lib/python3.11/site-packages) WARNING: Ignoring invalid distribution ~illow (/home/iobroker/.cache/autopy/venv/esphome/lib/python3.11/site-packages) WARNING: Ignoring invalid distribution ~illow (/home/iobroker/.cache/autopy/venv/esphome/lib/python3.11/site-packages) ERROR: Could not install packages due to an OSError: [Errno 13] Permission denied: '/home/iobroker/.cache/autopy/venv/esphome/lib/python3.11/site-packages/pillow.libs/libharfbuzz-2093a78b.so.0.60830.0' Check the permissions. WARNING: Ignoring invalid distribution ~illow (/home/iobroker/.cache/autopy/venv/esphome/lib/python3.11/site-packages) Collecting pillow==10.2.0 Using cached pillow-10.2.0-cp311-cp311-manylinux_2_28_x86_64.whl.metadata (9.7 kB) Using cached pillow-10.2.0-cp311-cp311-manylinux_2_28_x86_64.whl (4.5 MB) Installing collected packages: pillow | Error: Command failed with exit code 1: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip install pillow==10.2.0 WARNING: Ignoring invalid distribution ~illow (/home/iobroker/.cache/autopy/venv/esphome/lib/python3.11/site-packages) WARNING: Ignoring invalid distribution ~illow (/home/iobroker/.cache/autopy/venv/esphome/lib/python3.11/site-packages) WARNING: Ignoring invalid distribution ~illow (/home/iobroker/.cache/autopy/venv/esphome/lib/python3.11/site-packages) ERROR: Could not install packages due to an OSError: [Errno 13] Permission denied: '/home/iobroker/.cache/autopy/venv/esphome/lib/python3.11/site-packages/pillow.libs/libharfbuzz-2093a78b.so.0.60830.0' Check the permissions. WARNING: Ignoring invalid distribution ~illow (/home/iobroker/.cache/autopy/venv/esphome/lib/python3.11/site-packages) Collecting pillow==10.2.0 Using cached pillow-10.2.0-cp311-cp311-manylinux_2_28_x86_64.whl.metadata (9.7 kB) Using cached pillow-10.2.0-cp311-cp311-manylinux_2_28_x86_64.whl (4.5 MB) Installing collected packages: pillow at makeError (file:///opt/iobroker/node_modules/autopy/node_modules/execa/lib/error.js:60:11) at handlePromise (file:///opt/iobroker/node_modules/autopy/node_modules/execa/index.js:124:26) at processTicksAndRejections (node:internal/process/task_queues:95:5) at $df9eabe9bda49ea8$export$e522f41234ab669a (file:///opt/iobroker/node_modules/autopy/src/index.ts:257:13) at Esphome.espHomeDashboard (/Users/nl69zh/Developer/community/opensource/ioBroker.esphome/main.js:180:7) at Esphome.onReady (/opt/iobroker/node_modules/iobroker.esphome/main.js:66:4)
