  4. Nach Update Adapter "admin" 6.13.16 kein Port 8081 mehr
24 Beiträge 7 Kommentatoren 3.0k Aufrufe 5 Beobachtet
  • meuteM meute
    @djmarc75 sagte in Nach Update Adapter "admin" 6.13.16 kein Port 8081 mehr:
    @meute sagte in Nach Update Adapter "admin" 6.13.16 kein Port 8081 mehr:
    $ sudo iobroker stop
    iob Befehle NIE mit Sudo anpacken bitte !
    Danke. Das habe ich gleich in meiner Doku vermerkt.
    dann zeig mal die Langfassung von
    iob diag
    Bitte schön:
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspi01
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 3 Model B Plus Rev 1.3
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     18:41:24 up  1:36,  1 user,  load average: 0.72, 0.70, 0.42
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    *** Time and Time Zones ***
                   Local time: Fri 2024-02-09 18:41:25 CET
               Universal time: Fri 2024-02-09 17:41:25 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    mf
    /home/mf
    mf adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin docker gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            909M        576M        106M        0.0K        227M        274M
    Swap:            99M        3.0M         96M
    Total:          1.0G        579M        202M
              909 M total memory
              576 M used memory
              371 M active memory
              339 M inactive memory
              106 M free memory
                3 M buffer memory
              223 M swap cache
               99 M total swap
                3 M used swap
               96 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
      UNIT                   LOAD   ACTIVE SUB    DESCRIPTION
    * plymouth-start.service loaded failed failed Show Plymouth Boot Screen
    1 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                              Type      Size  Used Avail Use% Mounted on
    /dev/root                               ext4       15G  8.3G  5.4G  61% /
    devtmpfs                                devtmpfs  325M     0  325M   0% /dev
    tmpfs                                   tmpfs     455M     0  455M   0% /dev/shm
    tmpfs                                   tmpfs     182M  780K  182M   1% /run
    tmpfs                                   tmpfs     5.0M  4.0K  5.0M   1% /run/lock
    /dev/sda1                               vfat      253M   31M  222M  13% /boot
    192.168.23.82:/media/nfs_usb_ssd_backup nfs4      110G   47G   58G  45% /media/raspi02_usb_ssd_backup
    tmpfs                                   tmpfs      91M   20K   91M   1% /run/user/1000
    [Fri Feb  9 17:05:22 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=fc635420-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Fri Feb  9 17:05:28 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Fri Feb  9 17:05:28 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Fri Feb  9 17:05:31 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET                          SOURCE                                  FSTYPE OPTIONS
    /                               /dev/sda2                               ext4   rw,noatime
    |-/media/raspi02_usb_ssd_backup 192.168.23.82:/media/nfs_usb_ssd_backup nfs4   rw,relatime,vers=4.2,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.23.81,local_lock=none,addr=192.168.23.82
    `-/boot                         /dev/sda1                               vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    3.9G    /var/
    2.2G    /var/lib
    2.0G    /var/lib/docker/overlay2
    1.4G    /var/log/journal/dbb184e505344dae88426d3e21a16a3f
    Archived and active journals take up 1.3G in the file system.
    /opt/iobroker/backups:
    50M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    136M    /opt/iobroker/iobroker-data/
    82M     /opt/iobroker/iobroker-data/files
    35M     /opt/iobroker/iobroker-data/backup-objects
    31M     /opt/iobroker/iobroker-data/files/web.admin/static
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    14M     /opt/iobroker/iobroker-data/objects.jsonl
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    5.1M    /opt/iobroker/iobroker-data/states.jsonl
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.20.2
    /usr/bin/node           v16.20.2
    /usr/bin/npm            8.19.4
    /usr/bin/npx            8.19.4
    /usr/bin/corepack       0.17.0
    nodejs:
      Installed: 16.20.2-deb-1nodesource1
      Candidate: 16.20.2-deb-1nodesource1
      Version table:
     *** 16.20.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.13.16
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
      system.adapter.admin.0                  : admin                 : raspi01                                  - disabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : raspi01                                  -  enabled
    + system.adapter.backitup.0               : backitup              : raspi01                                  -  enabled
    + system.adapter.discovery.0              : discovery             : raspi01                                  -  enabled
      system.adapter.fritzdect.0              : fritzdect             : raspi01                                  - disabled
    + system.adapter.influxdb.0               : influxdb              : raspi01                                  -  enabled, port: 8086
    + system.adapter.iqontrol.0               : iqontrol              : raspi01                                  -  enabled
      system.adapter.net-tools.0              : net-tools             : raspi01                                  - disabled
      system.adapter.ping.0                   : ping                  : raspi01                                  - disabled
    + system.adapter.shelly.0                 : shelly                : raspi01                                  -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : raspi01                                  -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.web.0                    : web                   : raspi01                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Objects and States
    Objects:        452
    States:         301
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://repos.influxdata.com/debian bullseye InRelease
    Hit:6 https://apt.syncthing.net syncthing InRelease
    Get:7 https://deb.nodesource.com/node_16.x bullseye InRelease [4586 B]
    Fetched 4586 B in 4s (1148 B/s)
    Reading package lists...
    Pending Updates: 4
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13957      477/cupsd
    tcp        0      0 192.168.23.81:8384      0.0.0.0:*               LISTEN      1000       15687      924/syncthing
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       37791      1767/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       38548      1767/iobroker.js-co
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       37840      1811/io.sonoff.0
    tcp        0      0 0.0.0.0:2388            0.0.0.0:*               LISTEN      0          13087      537/sshd: /usr/sbin
    tcp6       0      0 :::80                   :::*                    LISTEN      0          14509      589/apache2
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       39465      1856/io.web.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        13257      499/influxd
    tcp6       0      0 :::22000                :::*                    LISTEN      1000       13270      924/syncthing
    tcp6       0      0 :::2388                 :::*                    LISTEN      0          13089      537/sshd: /usr/sbin
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13956      477/cupsd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13782      378/avahi-daemon: r
    udp        0      0 0.0.0.0:50961           0.0.0.0:*                           108        13784      378/avahi-daemon: r
    udp        0      0 0.0.0.0:21027           0.0.0.0:*                           1000       13287      924/syncthing
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       36492      1796/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15482      442/dhcpcd
    udp        0      0 0.0.0.0:51820           0.0.0.0:*                           0          13098      -
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13981      731/cups-browsed
    udp        0      0 0.0.0.0:41669           0.0.0.0:*                           1000       15690      924/syncthing
    udp6       0      0 :::5353                 :::*                                108        13783      378/avahi-daemon: r
    udp6       0      0 :::37685                :::*                                108        13785      378/avahi-daemon: r
    udp6       0      0 :::37838                :::*                                1000       15688      924/syncthing
    udp6       0      0 :::22000                :::*                                1000       14635      924/syncthing
    udp6       0      0 :::546                  :::*                                0          15532      442/dhcpcd
    udp6       0      0 :::21027                :::*                                1000       13285      924/syncthing
    udp6       0      0 :::51820                :::*                                0          13099      -
    2024-02-09 18:38:24.796  - info: shelly.0 (1796) [CoAP] Device 192.168.23.112 (shelly1 / shelly1-F4CFA2749BBD / SHSW-1#F4CFA2749BBD#1) connected! Polltime set to 15 sec.
    2024-02-09 18:38:25.514  - info: sonoff.0 (1811) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.sonoff, node: v16.20.2, js-controller: 5.0.17
    2024-02-09 18:38:25.666  - info: sonoff.0 (1811) Starting MQTT authenticated  server on port 1885
    2024-02-09 18:38:26.762  - info: shelly.0 (1796) [CoAP] Device 192.168.23.111 (shelly1 / shelly1-500291F08F5D / SHSW-1#500291F08F5D#1) connected! Polltime set to 15 sec.
    2024-02-09 18:38:28.342  - info: host.raspi01 instance system.adapter.backitup.0 started with pid 1841
    2024-02-09 18:38:30.307  - info: discovery.0 (1826) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.20.2, js-controller: 5.0.17
    2024-02-09 18:38:32.327  - info: host.raspi01 instance system.adapter.web.0 started with pid 1856
    2024-02-09 18:38:34.460  - info: backitup.0 (1841) starting. Version 2.9.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.2, js-controller: 5.0.17
    2024-02-09 18:38:34.685  - info: backitup.0 (1841) [iobroker] backup will be activated at 02:40 every 1 day(s)
    2024-02-09 18:38:36.351  - info: host.raspi01 instance system.adapter.iqontrol.0 started with pid 1871
    2024-02-09 18:38:38.273  - info: web.0 (1856) starting. Version 6.2.3 in /opt/iobroker/node_modules/iobroker.web, node: v16.20.2, js-controller: 5.0.17
    2024-02-09 18:38:38.961  - info: web.0 (1856) socket.io server listening on port 8082
    2024-02-09 18:38:38.982  - info: web.0 (1856) http server listening on port 8082
    2024-02-09 18:38:41.642  - info: iqontrol.0 (1871) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.iqontrol, node: v16.20.2, js-controller: 5.0.17
    2024-02-09 18:38:41.814  - info: iqontrol.0 (1871) systemLanguage = de
    2024-02-09 18:38:41.817  - info: iqontrol.0 (1871) Creating Passphrase...
    2024-02-09 18:38:41.834  - info: iqontrol.0 (1871) Creating Popup States...
    2024-02-09 18:38:42.068  - info: iqontrol.0 (1871) Creating Widget States...
    2024-02-09 18:38:42.071  - info: iqontrol.0 (1871) Lists deactivated.
    2024-02-09 18:38:42.072  - info: iqontrol.0 (1871) Deleting unused Objects...
    2024-02-09 18:38:42.075  - info: iqontrol.0 (1871) Subscribing to states...
    2024-02-09 18:38:42.080  - info: iqontrol.0 (1871) iQontrol ready.
    2024-02-09 18:38:50.099  - info: sonoff.0 (1811) Client [Stromzaehler] connected with secret 1707500330082_5136
    2024-02-09 18:39:04.899  - info: web.0 (1856) ==> Connected system.user.admin from ::ffff:192.168.23.27
    2024-02-09 18:39:08.885  - info: web.0 (1856) <== Disconnect system.user.admin from ::ffff:192.168.23.27 iqontrol.0
                            v.2023-10-10
             Icon name: computer
          Architecture: arm64
    Kernel:                 aarch64
    Userland:               arm64
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     4
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v16.20.2
                            /usr/bin/npm            8.19.4
                            /usr/bin/npx            8.19.4
    Recommended versions are nodejs  and npm
    MEMORY:
    Mem:            909M        518M         77M        0.0K        313M        327M
    Swap:            99M         99M        0.0K
    Total:          1.0G        618M         77M
    Active iob-Instances:   8
    ioBroker Core:          js-controller           5.0.17
                            admin                   6.13.16
    Objects type: jsonl
    States  type: jsonl
    Objects:                452
    States:                 301
    Size of iob-Database:
    5.2M    /opt/iobroker/iobroker-data/states.jsonl
    GlasfaserG Offline
    GlasfaserG Offline
    @meute
    iob start admin
    meuteM 1 Antwort Letzte Antwort
    • CodierknechtC Offline
      Codierknecht
      @meute
      Node und NPM sind steinalt.
      Die gehören dringend auf aktuellen Stand.
      Aber nicht wieder googeln.
      https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-16-und-18
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
      • meuteM meute
        iob diag
        Bitte schön:
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : arm64
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        mf
        /home/mf
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M        3.0M         96M
                  909 M total memory
                  576 M used memory
                  371 M active memory
                  106 M free memory
                    3 M buffer memory
                  223 M swap cache
                   99 M total swap
                    3 M used swap
                   96 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        3.9G    /var/
        2.2G    /var/lib
        USB-Devices by-id:
        /usr/bin/npm            8.19.4
        /usr/bin/npx            8.19.4
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.13.16
        Adapter State
        + instance is alive
        Objects and States
        Objects:        452
        States:         301
        Pending Updates: 4
                                v.2023-10-10
                 Icon name: computer
              Architecture: arm64
        Kernel:                 aarch64
        Userland:               arm64
        User-ID:                1000
        X-Server:               false
                                /usr/bin/npm            8.19.4
                                /usr/bin/npx            8.19.4
        MEMORY:
        Swap:            99M         99M        0.0K
                                admin                   6.13.16
        Objects type: jsonl
        States  type: jsonl
        Objects:                452
        States:                 301
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        @meute System nicht aktuell, Hardware zu schwach (RPI3 - 1GB Ram)
        Lehrling seit 1975 !!!
        CodierknechtC meuteM 2 Antworten Letzte Antwort
        • DJMarc75D DJMarc75
          Codierknecht
          @djmarc75
          Stimmt auch wieder. Mit so einer kleinen Kiste wird das eher nix.
          @meute
          Du solltest mal in neue Hardware investieren.
          Einen Pi 3 mit 1GB kann man heute höchstens noch zum „reinschnuppern“ verwenden.
          Für ein Produktivsystem ist der kaum zu gebrauchen.
          • Meister MopperM Online
            Meister Mopper
            @homoran sagte in Nach Update Adapter "admin" 6.13.16 kein Port 8081 mehr:
            the internet never forgets
            Diese Äußerung habe ich von dir schon häufiger gelesen, und doch bin ich der Meinung, dass ihr mit dem Archivieren und Vorhalten von alten (und teils nicht mehr gültigen Informationen) zur Verwirrung beitragt.
            Vor ein paar Jahren betreute ich eine Projektseite hospitalkonzert.de. Dort wurden Konzerte präsentiert.
            Die Seite habe ich entfernt und man findet noch ein paar google Einträge über die Seite aber sicherlich keine Inhalte mehr, zumindest ist es mir noch nicht gelungen, irgendwelche Inhalte zu laden.
            Da sollte meines Erachtens ein Umdenken erfolgen, damit endlich diese z. B. sudo iobroker Miseren ein Ende haben.
            Proxmox und HA ...
            HomoranH Michael SchmittM 2 Antworten Letzte Antwort
              HomoranH Offline
              HomoranH Offline
              @meister-mopper sagte in Nach Update Adapter "admin" 6.13.16 kein Port 8081 mehr:
              wenn das so wäre, gäbe ich dir recht.
              aber ich weiß nicht was @meute gefunden hat und wo.
              wahrscheinlich sogar hier im Forum. Da gibt es ebenfalls Beiträge aus 2014/15 in denen noch sudo verwendet wurde, da es damals die heutige Rechtevergabe noch nicht fab.
              in den letzten archivierten Dokumenten sollte schon längst kein sudo in Verbindung mit ioBroker mehr drin sein
              spätestens wenn irgendwelche User ihre sudo iobroker... Konstrukte gepostet haben findet google diese. Auch wenn sue zu dem Zeitpunkt des Postens schon lange obsolet waren.
              Wer soll das alles prüfen und korrigieren?
              und das noch ohne den "historischen Zusammenhang" zu zerstören
                Michael SchmittM Offline
                Michael Schmitt
                @meister-mopper
                https://web.archive.org/web/20131007171024/http://hospitalkonzert.de/index.php
                • GlasfaserG Glasfaser
                  @meute
                  iob start admin
                  meuteM Offline
                  meuteM Offline
                  meute
                  schrieb am zuletzt editiert von meute
                  @glasfaser sagte in Nach Update Adapter "admin" 6.13.16 kein Port 8081 mehr:
                  iob start admin
                  Besten Dank. Das war die Lösung. Läuft auch noch nach einem Neustart.
                  Dann war nur der Adapter aus.
                  Das disabled ist mir nach iob diag auch aufgefallen.
                  Ein Thin Client mit Proxmox und ioBroker im LXC-Container steht schon einige Zeit da.
                  Aber ich kam noch nicht dazu, den umzuziehen.
                  Zeit ist endlich...
                  fraenk for friends Code: MATF103
                  • meuteM meute
                    iob start admin
                    Zeit ist endlich...
                    HomoranH Offline
                    HomoranH Offline
                    gab es hier im Editor nicht mal eine Inline-Codierung
                    die gibt es immer noch!
                    must du nur manuell mit `immer` machen
                    • CodierknechtC Codierknecht
                      @meute
                      meuteM Offline
                      meuteM Offline
                      meute
                      @codierknecht sagte in Nach Update Adapter "admin" 6.13.16 kein Port 8081 mehr:
                      @meute
                      Habe ich gemacht.
                      Das sollte jetzt passen:
                      $ type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      /usr/bin/npx
                      v18.19.0
                      v18.19.0
                      10.2.3
                      10.2.3
                      • Michael SchmittM Michael Schmitt
                        @meister-mopper
                        Meister Mopper
                        @michael-schmitt sagte in Nach Update Adapter "admin" 6.13.16 kein Port 8081 mehr:
                        @meister-mopper
                        Sehr gut, hast du das ergoogelt?
                        Würde mich interessieren, es war mir allerdings unbekannt, dass es ein solches Archiv gibt.
                        Vielen Dank.
                        Ich glaube aber nicht, dass @meute dort nachgesehen hat.
                        Proxmox und HA ...
                        Michael SchmittM 1 Antwort Letzte Antwort
                          @meister-mopper
                          Vielen Dank.
                          Michael Schmitt
                          @meister-mopper
                          Ich kannte die Seite schon davor (Wayback Machine). Hatte da mal nach meiner alten Clan Homepage gesucht.
                            iob diag
                            meuteM Offline
                            meuteM Offline
                            meute
                            Nach kurzem googeln habe ich 4 folgende Befehle gefunden und ausgeführt.
                            sudo iobroker stop
                            sudo iobroker update
                            sudo iobroker upgrade self
                            sudo iobroker start
                            eher für den JS-Controller !
                            @meister-mopper
                            Nein, da habe ich sicher nicht nachgesehen. 😊
                            Ich löse auf:
                            Diese Seite hatte ich mir auf die Schnelle für meinen Eingangsbeitrag ergoogelt:
                            https://forum.iobroker.net/topic/72452/update-js-controller-3-x-auf-5-x-funktioniert-nicht?_=1707646843801
                            Ich hatte die Hoffnung, dass ein ioBroker-Update das admin-Adapter-Problem fixt.
                            Ich wusste zu dem Zeitpunkt ja noch nicht, dass der admin-Adapter nur disabled ist.
                            • meuteM meute
                              sudo iobroker stop
                              sudo iobroker start
                              @meister-mopper
                              Ich löse auf:
                              HomoranH Offline
                              HomoranH Offline
                              Ich löse auf:
                              DANKE!
                              also wie vermutet
                                meuteM Offline
                                meuteM Offline
                                meute
                                @meute
                                Zeit ist endlich...
                                Ich habe heute über Mittag den ioBroker auf den Proxmox-Thin Client in einen LXC-Container umgezogen.
                                Vorbereitet hatte ich das ja schon die letzten Wochen.
                                Aktuell hat ioBroker 2 GB RAM.
                                Reicht das oder sollte ich mehr geben?
                                                        v.2023-10-10
                                 Static hostname: iobroker84
                                       Icon name: computer-container
                                         Chassis: container ?
                                  Virtualization: lxc
                                          Kernel: Linux 6.5.11-8-pve
                                    Architecture: x86-64
                                Installation:           lxc
                                Kernel:                 x86_64
                                Userland:               amd64
                                User-ID:                1000
                                X-Server:               false
                                Pending OS-Updates:     0
                                Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                                        /usr/bin/node           v18.19.0
                                                        /usr/bin/npm            10.2.3
                                                        /usr/bin/npx            10.2.3
                                                        /usr/bin/corepack       0.22.0
                                Recommended versions are nodejs 18.19.0 and npm 10.2.3
                                MEMORY:
                                Mem:            2.1G        1.5G         88M        1.5M        528M        616M
                                Swap:           536M         37M        499M
                                Total:          2.7G        1.6G        587M
                                Active iob-Instances:   9
                                                        admin                   6.13.16
                                Objects type: jsonl
                                States  type: jsonl
                                + system.adapter.admin.0                  : admin                 : iobroker84                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                + system.adapter.web.0                    : web                   : iobroker84                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                Objects:                468
                                States:                 324
                                22M     /opt/iobroker/iobroker-data/objects.jsonl
                                6.7M    /opt/iobroker/iobroker-data/states.jsonl
                                • meuteM meute
                                  @meute
                                  Zeit ist endlich...
                                                          v.2023-10-10
                                    Virtualization: lxc
                                  Installation:           lxc
                                  Kernel:                 x86_64
                                  Userland:               amd64
                                  User-ID:                1000
                                  X-Server:               false
                                                          /usr/bin/npm            10.2.3
                                                          /usr/bin/npx            10.2.3
                                  MEMORY:
                                  Swap:           536M         37M        499M
                                                          admin                   6.13.16
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Objects:                468
                                  States:                 324
                                  DJMarc75D Offline
                                  DJMarc75D Offline
                                  DJMarc75
                                  4 GB wären eher sinnvoll da ja schon:
                                  MEMORY:               total        used        free      shared  buff/cache   available
                                  was läuft denn da noch ausser ioBroker drauf ?
                                    meuteM Offline
                                    meuteM Offline
                                    meute
                                    Eine InfluxDB läuft noch, in der die Werte des Stromzähler gespeichert werden.
                                    Nutzen/testen will ich demnächst mal den Adapter eCharts.
                                    Das war der Auslöser, warum ich überhaupt auf Proxmox bin.
                                    Den wollte ich Ende 2023 installieren und der RPi ging in die Grätsche.
                                    Gibt auch hier einen Thread von mir zu dem Thema.
                                    Ich werde dem ioBroker dann mal 4 GB geben.
                                    • meuteM meute
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      aber nicht im gleichen Container !?
                                      @DJMarc75 fragt nur nach , da noch 88M frei sind .
                                        meuteM Offline
                                        meuteM Offline
                                        meute
                                        Doch, im gleichen Container wie ioBroker.
