  4. Test Adapter Vaillant multiMatic/senso und myVaillant
    6.8k
multimaticsensovaillanvr900vr920
966 Beiträge 94 Kommentatoren 420.0k Aufrufe 88 Beobachtet
  • T Thuata
    nodejs upgedated. Adapter deinstalliert und neu über GitHup installiert (0.3.0)
    gehen tuts leider immer noch nicht:
    2024-01-07 12:47:58.702 - info: host.raspberrypi "system.adapter.vaillant.0" enabled
    2024-01-07 12:47:58.853 - info: host.raspberrypi instance system.adapter.vaillant.0 started with pid 171020
    2024-01-07 12:48:01.091 - debug: vaillant.0 (171020) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2024-01-07 12:48:01.130 - debug: vaillant.0 (171020) Objects client ready ... initialize now
    2024-01-07 12:48:01.133 - debug: vaillant.0 (171020) Objects create System PubSub Client
    2024-01-07 12:48:01.134 - debug: vaillant.0 (171020) Objects create User PubSub Client
    2024-01-07 12:48:01.176 - debug: vaillant.0 (171020) Objects client initialize lua scripts
    2024-01-07 12:48:01.184 - debug: vaillant.0 (171020) Objects connected to redis: 127.0.0.1:9001
    2024-01-07 12:48:01.218 - debug: vaillant.0 (171020) Redis States: Use Redis connection: 127.0.0.1:9000
    2024-01-07 12:48:01.233 - debug: vaillant.0 (171020) States create System PubSub Client
    2024-01-07 12:48:01.234 - debug: vaillant.0 (171020) States create User PubSub Client
    2024-01-07 12:48:01.297 - debug: vaillant.0 (171020) States connected to redis: 127.0.0.1:9000
    2024-01-07 12:48:01.454 - info: vaillant.0 (171020) starting. Version 0.3.0 (non-npm: TA2k/ioBroker.vaillant) in /opt/iobroker/node_modules/iobroker.vaillant, node: v18.19.0, js-controller: 5.0.17
    2024-01-07 12:48:01.515 - info: vaillant.0 (171020) Generate new Id
    2024-01-07 12:48:01.937 - debug: vaillant.0 (171020) "\n\n\n\n \n \n \n\n \n \n\n \n \n \n \n \n \n \n \n \n \n \n \n\n\n\n
    \n
    \n
    Vaillant Österreich
    \n
    \n
    \n
    \n
    Mit Ihrem Login anmelden\n\n
    \n
    \n
    \n
    \n\n\n
    \n
    \n
    \n
    \n E-Mail\n\n \n\n\n
    \n\n
    \n Passwort\n\n \n\n\n
    \n\n
    \n
    \n
    \n
    \n Passwort zurücksetzen\n
    \n\n
    \n\n
    \n \n \n
    \n
    \n
    \n\n
    \n\n\n\n\n\n
    \n
    \n\n
    \n
    Cookie konnte nicht gefunden werden. Bitte stellen Sie sicher, dass Cookies in Ihrem Browser aktiviert sind.
    \n
    \n \n
        \n \n
        \n Datenschutzerklärung\n
        \n \n
        \n Nutzungsbedingungen und Konditionen\n
        \n \n
    \n \n Support ID: 9f49c682da2803cb252691495032c761\n
    \n
    \n\n"
    2024-01-07 12:48:03.168 - debug: vaillant.0 (171020) "Redirected request failed: Unsupported protocol enduservaillant.page.link:"
    2024-01-07 12:48:03.174 - error: vaillant.0 (171020) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2024-01-07 12:48:03.174 - error: vaillant.0 (171020) unhandled promise rejection: Converting circular structure to JSON
    --> starting at object with constructor 'TLSSocket'
    | property '_httpMessage' -> object with constructor 'ClientRequest'
    --- property 'socket' closes the circle
    2024-01-07 12:48:03.175 - error: vaillant.0 (171020) TypeError: Converting circular structure to JSON
    at JSON.stringify ()
    at /opt/iobroker/node_modules/iobroker.vaillant/main.js:256:31
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    at async Vaillant.myvLoginv2 (/opt/iobroker/node_modules/iobroker.vaillant/main.js:235:22)
    at async Vaillant.onReady (/opt/iobroker/node_modules/iobroker.vaillant/main.js:100:7)
    2024-01-07 12:48:03.176 - error: vaillant.0 (171020) Converting circular structure to JSON
    2024-01-07 12:48:03.186 - info: vaillant.0 (171020) cleaned everything up...
    2024-01-07 12:48:03.188 - info: vaillant.0 (171020) terminating
    2024-01-07 12:48:03.190 - warn: vaillant.0 (171020) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2024-01-07 12:48:03.691 - info: vaillant.0 (171020) terminating
    2024-01-07 12:48:03.754 - error: host.raspberrypi instance system.adapter.vaillant.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2024-01-07 12:48:03.755 - info: host.raspberrypi Restart adapter system.adapter.vaillant.0 because enabled
    2024-01-07 12:48:13.881 - info: host.raspberrypi "system.adapter.vaillant.0" disabled
    tombox
    #612
    @thuata ich habe nochmal was angepasst fürs logging aber ich denke ich brauch kurz die Zugangsdaten um das zu fixen
    tombox2020@gmail.com
    • T tombox
      schlappu
      #613
      @tombox Ich habe den aktualisierten Adapter getestet und das hier steht nun im Log
      vaillant.0
      2024-01-07 16:26:04.668	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
      vaillant.0
      2024-01-07 16:26:04.618	error	adapter disabled
      vaillant.0
      2024-01-07 16:25:33.434	info	terminating
      vaillant.0
      2024-01-07 16:25:32.931	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      vaillant.0
      2024-01-07 16:25:32.930	info	terminating
      vaillant.0
      2024-01-07 16:25:32.928	info	cleaned everything up...
      vaillant.0
      2024-01-07 16:25:32.922	error	Cannot read properties of undefined (reading 'split')
      vaillant.0
      2024-01-07 16:25:32.922	error	TypeError: Cannot read properties of undefined (reading 'split') at /opt/iobroker/node_modules/iobroker.vaillant/main.js:257:55 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async Vaillant.myvLoginv2 (/opt/iobroker/node_modules/iobroker.vaillant/main.js:235:22) at async Vaillant.onReady (/opt/iobroker/node_modules/iobroker.vaillant/main.js:100:7)
      vaillant.0
      2024-01-07 16:25:32.921	error	unhandled promise rejection: Cannot read properties of undefined (reading 'split')
      vaillant.0
      2024-01-07 16:25:32.920	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      vaillant.0
      2024-01-07 16:25:32.918	debug	"enduservaillant.page.link://login#session_state=1dbcf7d5-aea1-4704-a709-66399ac480df&code=2f754737-a5a5-430f-84b2-8a30ec710a57.1dbcf7d5-aea1-4704-a709-66399ac480df.b29f95a6-2177-492a-b160-a9aa8d3defac"
      vaillant.0
      2024-01-07 16:25:32.917	debug	"Redirected request failed: Unsupported protocol enduservaillant.page.link:"
      vaillant.0
      2024-01-07 16:25:29.636	debug	"<!DOCTYPE html>\n<html class=\"\">\n\n<head>\n <meta charset=\"utf-8\">\n <meta http-equiv=\"Content-Type\" content=\"text/html; charset=UTF-8\" />\n <meta name=\"robots\" content=\"noindex, nofollow\">\n\n <meta name=\"viewport\" content=\"width=device-width,initial-scale=1\"/>\n <script>\n if (document.documentElement && document.documentElement.style && document.documentElement.style.setProperty) {\n document.documentElement.style.setProperty('--vh', '' + (window.innerHeight * 0.01) + 'px');\n }\n</script><title>Anmeldung bei Vaillant Deutschland</title>\n\n <link rel=\"apple-touch-icon\" sizes=\"180x180\" href=\"/auth/resources/6fr79/login/vaillant-germany-b2c/favicons/va/apple-touch-icon.png\">\n <link rel=\"icon\" type=\"image/png\" sizes=\"32x32\" href=\"/auth/resources/6fr79/login/vaillant-germany-b2c/favicons/va/favicon-32x32.png\">\n <link rel=\"icon\" type=\"image/png\" sizes=\"16x16\" href=\"/auth/resources/6fr79/login/vaillant-germany-b2c/favicons/va/favicon-16x16.png\">\n <link rel=\"manifest\" href=\"/auth/resources/6fr79/login/vaillant-germany-b2c/favicons/va/site.webmanifest\">\n <link rel=\"mask-icon\" href=\"/auth/resources/6fr79/login/vaillant-germany-b2c/favicons/va/safari-pinned-tab.svg\"\n color=\"#00917e\">\n <link rel=\"shortcut icon\" href=\"/auth/resources/6fr79/login/vaillant-germany-b2c/favicons/va/favicon.ico\">\n <meta name=\"msapplication-TileColor\" content=\"#00917e\">\n <meta name=\"msapplication-config\" content=\"/auth/resources/6fr79/login/vaillant-germany-b2c/favicons/va/browserconfig.xml\">\n <meta name=\"theme-color\" content=\"#ffffff\">\n <link href=\"/auth/resources/6fr79/login/vaillant-germany-b2c/2670/css/login.css\" rel=\"stylesheet\" />\n <link href=\"/auth/resources/6fr79/login/vaillant-germany-b2c/2670/css/brand-vaillant-b2c.css\" rel=\"stylesheet\" />\n <script src=\"/auth/resources/6fr79/login/vaillant-germany-b2c/2670/js/login.js\" type=\"text/javascript\"></script>\n</head>\n\n<body class=\"vaillant-germany-b2c theme-b2c\">\n<div class=\"main-content\">\n <div id=\"kc-header\" class=\"\">\n <div id=\"kc-header-wrapper\"\n class=\"\">Vaillant Deutschland</div>\n </div>\n <div class=\"main-box\">\n <header class=\"\">\n <h1 id=\"kc-page-title\"> Mit Ihrem Login anmelden\n\n</h1>\n </header>\n <div id=\"kc-content\">\n <div id=\"kc-content-wrapper\">\n\n\n <div id=\"kc-form\">\n <div id=\"kc-form-wrapper\">\n <form id=\"kc-form-login\" onsubmit=\"login.disabled = true; return true;\" action=\"https://identity.vaillant-group.com/auth/realms/vaillant-germany-b2c/login-actions/authenticate?session_code=SRu4uQNxPMMbpcaT1n1qo0uVQ7umOin4l-Q4RWjh5gE&amp;execution=aee4ff43-a052-464c-9756-cef6f7ffeeb0&amp;client_id=myvaillant&amp;tab_id=77TtqhVcqQU\" method=\"post\">\n <div class=\"form-group\">\n <label for=\"username\" class=\"\">E-Mail</label>\n\n <input tabindex=\"1\" id=\"username\" placeholder=\"\" class=\"\" name=\"username\" value=\"thorsten.poppe@web.de\" type=\"email\" autofocus autocomplete=\"off\"\n aria-invalid=\"\"\n />\n\n\n </div>\n\n <div class=\"form-group\">\n <label for=\"password\" class=\"\">Passwort</label>\n\n <input tabindex=\"2\" id=\"password\" placeholder=\"\" class=\"\" name=\"password\" type=\"password\" autocomplete=\"off\"\n aria-invalid=\"\"\n />\n\n\n </div>\n\n <div class=\"form-group form-settings\">\n <div id=\"kc-form-options\">\n </div>\n <div class=\"form-options-wrapper\">\n <span><a tabindex=\"5\" href=\"/auth/realms/vaillant-germany-b2c/login-actions/reset-credentials?client_id=myvaillant&amp;tab_id=77TtqhVcqQU\">Passwort zurücksetzen</a></span>\n </div>\n\n </div>\n\n <div id=\"kc-form-buttons\" class=\"form-group\">\n <input type=\"hidden\" id=\"id-hidden-input\" name=\"credentialId\" />\n <input tabindex=\"4\" class=\" \" name=\"login\" id=\"kc-login\" type=\"submit\" value=\"Anmelden\"/>\n </div>\n </form>\n </div>\n\n </div>\n\n\n\n\n\n </div>\n </div>\n\n </div>\n <div class=\"cookie-notice\"><div>Cookie konnte nicht gefunden werden. Bitte stellen Sie sicher, dass Cookies in Ihrem Browser aktiviert sind.</div></div>\n <footer>\n \n <ul>\n \n <li>\n <a href='https://myvaillant.com/vaillant-pp.html?lang=de_DE' target=\"_blank\">Datenschutzerklärung</a>\n </li>\n \n <li>\n <a href='https://myvaillant.com/vaillant-tac.html?lang=de_DE' target=\"_blank\">Nutzungsbedingungen und Konditionen</a>\n </li>\n \n </ul>\n \n <span class=\"support-id\">Support ID: 7c5f3e8f699f62d398663cf8194dce95</span>\n </footer>\n</div></body>\n</html>\n"
      vaillant.0
      2024-01-07 16:25:29.279	info	Generate new Id
      vaillant.0
      2024-01-07 16:25:29.238	info	starting. Version 0.3.0 (non-npm: TA2k/ioBroker.vaillant) in /opt/iobroker/node_modules/iobroker.vaillant, node: v18.19.0, js-controller: 5.0.17
      vaillant.0
      2024-01-07 16:25:29.103	debug	States connected to redis: 127.0.0.1:9000
      vaillant.0
      2024-01-07 16:25:29.027	debug	States create User PubSub Client
      vaillant.0
      2024-01-07 16:25:29.026	debug	States create System PubSub Client
      vaillant.0
      2024-01-07 16:25:29.007	debug	Redis States: Use Redis connection: 127.0.0.1:9000
      vaillant.0
      2024-01-07 16:25:28.968	debug	Objects connected to redis: 127.0.0.1:9001
      vaillant.0
      2024-01-07 16:25:28.963	debug	Objects client initialize lua scripts
      vaillant.0
      2024-01-07 16:25:28.898	debug	Objects create User PubSub Client
      vaillant.0
      2024-01-07 16:25:28.897	debug	Objects create System PubSub Client
      vaillant.0
      2024-01-07 16:25:28.896	debug	Objects client ready ... initialize now
      vaillant.0
      2024-01-07 16:25:28.858	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
      Kannst du damit was anfangen?
      Ich kann dir sonst gerne die Zugangsdaten schicken.
      • S schlappu
        vaillant.0
        vaillant.0
        vaillant.0
        vaillant.0
        vaillant.0
        vaillant.0
        vaillant.0
        vaillant.0
        vaillant.0
        vaillant.0
        vaillant.0
        vaillant.0
        vaillant.0
        vaillant.0
        vaillant.0
        vaillant.0
        vaillant.0
        vaillant.0
        vaillant.0
        vaillant.0
        vaillant.0
        vaillant.0
        vaillant.0
        vaillant.0
        vaillant.0
        tombox
        #614
        @schlappu Nochmal via GitHub installieren und testen
        S T 2 Antworten Letzte Antwort
        • T tombox
          schlappu
          #615
          @tombox 👍 Funktioniert nun wieder!
          Dann hatte das vermutlich gar nichts mit dem Upgrade von iobroker js-controller zu tun, sondern lag an Vaillant selber.
          Vielen Dank für die schnelle Anpassung in deiner Freizeit!!
          • T tombox
            Thuata
            #616
            @tombox
            bei mir gehts jetzt auch wieder - awesome, danke!!!
            • F Offline
              fuerst2626
              #617
              Guten Tag zusammen
              Ich habe den Adapter längere Zeit installiert gehabt mit mäßigem Erfolg.
              Jetzt mit 0.3 über github scheint es zu laufen.
              Dankeschön!!
              Hier trotzdem offene Fragen:
              • Ein Wechsel von Manuel auf zb. zeitgesteuert scheint zu funktionieren, wenn auch nicht sofort?! Gibt es eine ausführliche Anleitung dazu. Ggf. Mache ich ja auch was falsch?!
                (Ich finde immer nur die kurzbeschreibung, welche nicht alles beschreibt?)
              • Ist es möglich den Status „Abwesenheit“ zu setzen, wenn ja wie / wo?!
              Gruss Bastian
                sadir
                #618
                Leider funktioniert der Adapter bei mir nicht mehr nach dem Wechsel auf die neue App.
                Die Instanz wird zwar mit alle 3 Punkte grün angezeigt, aber ich bekommen keine Werte unter den Objekten. Was bedeutet bei den Einstellungen eigentlich der Haken bei my VaiillantApp verwenden? Wenn ich diesen raus lasse bekomme ich keine Verbindung mit dem Gerät/Dienst, ist der Haken dran, dann ist zwar die Verbindung zum Gerät/Dienst grün, aber ich finde keine Werte unter den Objekten, was kann ich tun. Vielen Dank schon mal.
                Sadir
                Grüße aus dem Taunus
                Raspi 4 mit 4GB RAM
                • S sadir
                  Sadir
                  Meister MopperM Online
                  Meister Mopper
                  #619
                  @sadir sagte in Test Adapter Vaillant multiMatic/senso und myVaillant:
                  • Na ja, wenn du auf die neue App umgestellt hast, muss der Haken gesetzt werden.
                  • Weiterhin hast du eventuell beim App-Wechsel den Benutzernamen und/oder das Passwort geändert. Das muss dann auch in der Instanz geändert werden.
                  Ich habe die Instanz komplett gelöscht, von Github die v0.4.0 installiert, eine neue Instanz erstellt, Benutzer und Kennwort neu eingegeben und den Haken bei myVaillant gesetzt.
                  Dann wurde wieder beständig aktualisiert.
                  Proxmox und HA ...
                  S 2 Antworten Letzte Antwort
                    sadir
                    #620
                    @meister-mopper danke, werde es mal so testen.
                    Raspi 4 mit 4GB RAM
                      sadir
                      #621
                      @meister-mopper hat funktioniert mit der Version 4.0, danke noch mal 👍
                      Raspi 4 mit 4GB RAM
                        Toadie
                        #622
                        Ich wurde gestern von der Multimatic zu myVaillant migriert. Mit der v0.4.0 von GitHub bekomme ich nun auch alle Werte und der Adapter läuft bisher stabil. Leider kann ich, anders als bisher unter Multimatic, jetzt mit myVaillant in den Objekten keine Werte mehr ändern. Wenn ich das tue, werden sie in der App nicht übernommen und mit der nächsten Aktualisierung überschrieben. Auch im remote Ordner geht nix. Mach ich was falsch? Bisher konnte ich Temperaturen von Heizung und Warmwasser, sowie Betriebszustand usw. ohne Probleme ändern.
                          Biohazard
                          schrieb am zuletzt editiert von Biohazard
                          #623
                          Hallo zusammen habe heute von der Multimatic zu myVaillant gewechelt.
                          Leider kann ich auch keine Werte mehr ändern 🙄 was zimmlich doff ist da meine Heizung über die PV, Aussentempertur... gesteuert wird. Mittels eines Blockly-Scripts
                          Habe auch den Adapter v0.4.0. Jedes mal wenn ich eine Wert ändere bricht die verbindung zum Host ab und es gibt kein Lebenszeichen mehr nach ca. 20sek. ist alles wieder Grün.
                          Bitte um Hilfe
                          Vielen Dank an alle euch einen Schönen Abend🤗
                          • B Biohazard
                            Bitte um Hilfe
                            Markus0707
                            #624
                            @biohazard
                            Danke für Deinen Hinweis, dass es eine Version .0.4.0 gibt. Ich hatte nicht auf GitHub geschaut.
                            Bei mir läuft der Adapter nun wieder und ohne Restart oder andere Probleme .
                            Hoffe es hat sich bei Dir auch zurecht gerüttelt.
                              bb61
                              schrieb am zuletzt editiert von bb61
                              #625
                              @meister-mopper sagte in Test Adapter Vaillant multiMatic/senso und myVaillant:
                              Habe diesen Tipp befolgt und v0.4.0 vom GIT installiert. Löschen / Reboot / Neue Installation des Adapters hat ohne Fehler funktioniert.
                              ABER: Ich sehe den nur in der Adapter-Liste der Admin bzw. auf der Konsole des HOST per "iob update". In der Instanzen-Liste taucht er dagegen NICHT auf! Es kam dort auch kein Admin-Dialog bei Installation zur Konfiguration, wie bei anderen Adaptern. Wie kann ich das nun konfigurieren? Muss ich bei "aus GIT installierten" das anders / manuell auslösen? Hab bisher nur standardmäßig (stable) installiert, ist mein erster, den ich aus der Admin/Adapter/Kopfzeile / Katze in der Kopfzeile / aus GIT ...usw. installiert habe.
                              Die Repository-Einstellungen des Systems sind ansonsten unverändert seit Installation.
                              ich habe heute auch auf myVaillant umgestellt. Über die Handy-App sehe ich sauber die sich ändernden Werte (Das Teil dient bei mir vor allem zur Überwachung von Therme, Wasserdruck etc. in Pflegewohnung, >200km entfernt, Altbau verliert etwas Druck über Monate, rechtzeitige Planung von Fahrten auch zum Nachfüllen...)
                              ABER: Im alten iOb-Adapter änderten sich nach Umstellung auf myVaillant zwar noch die Zeiten an den Werten, nicht aber die Werte selbst. Handy-App zeigt dagegen wahre Werte. - Dann hier gelesen, dass nach Umstellung auf MyVaillant der o.g. Haken zu setzen ist. ABER: Dann kam der (alte) Adapter nicht wieder hoch, angeblich Loginfehler, trotz identischer Userdaten. - Habe natürlich auch die Userdaten neu eingetragen (gleiche wie auf Handy-App), aber auch statt "Benutzer" die Mailadresse versucht (Adapter-Doku und (alter) Adapter-Konfig-Dialog widersprechen sich da etwas: "Mail-Addr." vs. "Benutzer") und natürlich immer wieder auch diverse Reboots etc. - Deshalb nun Neuinstallation mit 0.4.0 lt. obiger Empfehlng
                              Was kann ich tun, um damit weiterzukommen?
                              Host ist übrigens ein Raspi4 mit genügend (8GB) RAM. Als Multihost-Gerät auch sparsam ausgelastet. Das Gateway an der Heizung ist ein "sensoNET VR 921" und lief mit dem alten Adapter mehr als 2 Jahre nahezu problemlos. ... man sollte wohl wirklich nicht jedem Update-Wahn nachgehen? Aber auf der Handy-App sah es wirklich wie ein Fortschritt aus (Boost-Funktionen, Abwesenheit usw.)
                              Danke, bb61
                              • B bb61
                                Danke, bb61
                                Meister Mopper
                                #626
                                @bb61 sagte in Test Adapter Vaillant multiMatic/senso und myVaillant:
                                So wie ich es verstanden habe, kannst du nach der Umstellung von der alten App auf MyVaillant nicht mehr die "alte" Datenbank abfragen.
                                Ohne das x bei MyVaillant bist du nun raus! Die Daten kommen bei mir nach dem Wechsel zuverlässlich sowohl in der App als auch in der Adapter-Instanz an.
                                Probleme gibt es offenbar bei der Steuerung der Funktionen über die Instanz, aber da ist ein Erstellen eines github issues beim Adapter die richtige Wahl.
                                Proxmox und HA ...
                                  bb61
                                  #627
                                  ich habs inzwischen Lösen können.
                                  Klar, ich brauche nach Update auf MyVailland nun "das x" bei "MyVailland" in der Adapter Config
                                  Mit dem alten Adapter im stable (V0.2.x glaub ich war das) ging das aber nicht. Login Fehler usw. Mit Upgrade auf 0.4.0 sollte es lt. Forum (s.o.) aber gehen.
                                  Um die v0.4.0 "direkt aus Git" zu installieren (und man vorher "aufgeräumt" hat, also den Vaillant Adapter wie empfohlen komplett zuvor deinstalliert hat), gabs aber keine Admin-Gui für den Adapter. Sprich: er war dann zwar installiert, tauchte aber unter "Instanzen" nicht auf. Zumindest wars bei mir so, auch wiederholt und nach reboot usw.
                                  Die Lösung:
                                  nach kompletten Entfernen des alten Adapters (und Reboot des Host):
                                  • erst noch einmal den "stable"-Adapter, also v2.0.x installieren, a erscheint dann auch wie gewohnt die Konfig und anschließend ist unter "Instanzen" auch ne Instanz da
                                  • dann die v0.4.0 drüberinstallieren: unter "Adapter" die Mietzekatze rechts in der Kopfzeile, dann "aus Git ..." (Tab in der Mitte), dann "vaillant..." beginnen einzugeben und den Treffer akzeptieren/Enter. Install erfolgt dann auch ohne Frage nach Instanznummer, bügelt den bestehenden Adapter auf dem aktuell eingestellten Host direkt über. Die alte GUI unter der vorherigen Stable-Instanz-Nr ist danach noch immer verfügbar zum Konfigurieren.
                                  Auch noch wichtig:
                                  unbedingt im Dialog "Benutzer" die alte User-Instanz durch die beim Update ersetzte Mailadresse ersetzen, erst dann klappt es. Das ist etwas konfus, weil bei Handy-App beide "Benutzer" an unterschiedlichen Stellen gebraucht wurden, die eine wohl wirklich für die Handy-App-Authentifizierung, die andere (alter "Benutzer") beim 2. Update-Schritt, wenn das Gateway an der Heizung selbst mit neuer Firmware versorgt wird. Kann auch andersrum gewesen sein, auf jeden fall werden da beide "User" gebraucht
                                  Danach kommt eine doch sehr unterschiedliche Struktur im Vergleich zur alten Objekt-Struktur des Adapters. Das Aufräumen (komplettes Löschen des alten Adapters) ist also wohl wirklich sehr sinnvoll.
                                  Übrigens auch ein vorheriger Test deutet darauf hin (komplettes Löschen, Neu anlegen des alten stable Adapters -> alte Konfig (ohne das X) als enzig den Adapter fehlerlos startbare -> keine Werte-Aktualisierung z.B. bei Wasserdruck, Wassertemperatur usw., sondern nur der Zeitstempel kommt neu). Erst der 0.4.0 funktioniert wirklich!
                                  Mag sein, das Problem hat auch was damit zu tun, dass ich den Adapter auf einem Multihost laufen lasse, oder das ist abhängig von meinem Gateway an der Heizung (Version s.o. erstes Post).
                                  Vielleicht hilft das oben gesagte ja einigen in gleicher Lage!
                                  Auf jeden Fall kann ich nun wieder den Druck aufzeichnen, und rechtzeitig an der Kurve sehen, wann es mal wieder Zeit ist, das Wasserauffüllgerödele mitzunehmen auf die 2mal 220 km-Pflegetour. Es ist nix dööfer, als nach wenigen Std seit letzter Tour zur normalen Vor-Ort-Pflege einen Anruf zu bekommen, dass die Wohnung total kalt ist, weil sich die Therme mangels Wasserdruck (einige marode Leitungen) abgeschaltet hat. Und das natürlich bei inzwischen eingesetztem Glatteisregen usw.... Da hilft ein kleines Script im ioBroker mit rechtzeitiger Schwellwert- und Trend-Warnung schon sehr! ...und schont die Inanspruchnahme von Freundes-Alarmreaktions-Kapazität vor Ort, die besser bei weniger peinlichen Notfällen einsetzbar ist.
                                  Wieder einmal: Danke an allen Beteiligten für den Broker!
                                  Gute Nacht, bb61
                                  P 1 Antwort Letzte Antwort
                                    Biohazard
                                    #628
                                    @bb61
                                    Schönen guten Morgen erstmal vielen Dank für deine ausführliche Beschreibung.
                                    Meine Frage wäre jetzt kannst du auch Werte über iobroker ändern? Oder nur ablesen?
                                    • B bb61
                                      Die Lösung:
                                      Auch noch wichtig:
                                      Gute Nacht, bb61
                                      PeterSCP
                                      #629
                                      @bb61 Servus Frage ich hab jetzt die 0.4 Version installiert funktioniert soweit.
                                      Nur wo sehe ich jetzt den Stromverbrauch von Warmwasser und Heizung ?
                                      vielen Dank für deine Hilfe
                                        Malaguti
                                        #630
                                        @biohazard said in Test Adapter Vaillant multiMatic/senso und myVaillant:
                                        @bb61
                                        Bei mir geht leider auch nur mehr das ablesen seit dem Update auf myVaillant.
                                        Somit ist meine komplett automatisierte Heizungssteuerung außer Betrieb.
                                        LG
                                        • MassiveAttackM Offline
                                          MassiveAttack
                                          #631
                                          Frage in die runde, wird die energieeffizienz auch als DP abgebildet?
                                          Bzw werden historische daten der anlage auch geladen? Sehe aktuell nur die von heute.
                                          Wird jeden tag ein neuer ordner für den verbrauch erstellt, oder gibts auch monats/jahreswerte?
                                          MassiveAttackM 1 Antwort Letzte Antwort
