  3. Einsteigerfragen
  4. Iobroker VIS keine Visualisierung
    5.5k
Geplant Angeheftet Gesperrt Verschoben Ungelöst Einsteigerfragen
73 Beiträge 6 Kommentatoren 8.6k Aufrufe 5 Beobachtet
  • M Meintre 0
    @meintre-0
    Skript v.2023-10-10
    *** BASE SYSTEM ***
    /Users/meinhard/.diag.sh: line 63: hostnamectl: command not found
    grep: /proc/cpuinfo: No such file or directory
    Docker          : false
    Virtualization  : Docker
    Kernel          : x86_64
    /Users/meinhard/.diag.sh: line 83: dpkg: command not found
    Userland        :
    Systemuptime and Load:
    17:51  up 27 days, 20:16, 2 users, load averages: 2.21 2.25 2.27
    CPU threads:
    *** Time and Time Zones ***
    /Users/meinhard/.diag.sh: line 188: timedatectl: command not found
    *** User and Groups ***
    meinhard
    /Users/meinhard
    staff everyone localaccounts _appserverusr admin _appserveradm _lpadmin com.apple.access_screensharing com.apple.access_ssh com.apple.access_remote_ae _appstore _lpoperator _developer _analyticsusers com.apple.access_ftp com.apple.sharepoint.group.1
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal:
    /Users/meinhard/.diag.sh: line 211: systemctl: command not found
    Boot Target:
    *** MEMORY ***
    /Users/meinhard/.diag.sh: line 215: free: command not found
    /Users/meinhard/.diag.sh: line 217: vmstat: command not found
    *** FAILED SERVICES ***
    /Users/meinhard/.diag.sh: line 232: systemctl: command not found
    *** FILESYSTEM ***
    Password:
    usage: sudo dmesg
    /Users/meinhard/.diag.sh: line 242: findmnt: command not found
    /var:
    du: /var//networkd/db: Operation not permitted
    du: /var//db/appinstalld: Operation not permitted
    du: /var//db/ExtensibleSSO/Configuration: Operation not permitted
    du: /var//db/Spotlight: Operation not permitted
    du: /var//db/sysdiagnose/com.apple.sysdiagnose: Operation not permitted
    du: /var//db/DumpPanic: Operation not permitted
    du: /var//db/rmd/secure: Operation not permitted
    du: /var//db/com.apple.backgroundtaskmanagement: Operation not permitted
    du: /var//db/fpsd/dvp: Operation not permitted
    du: /var//db/installcoordinationd: Operation not permitted
    du: /var//db/Spotlight-V100: Operation not permitted
    du: /var//db/oah: Operation not permitted
    du: /var//db/Sandbox: Operation not permitted
    du: /var//db/lockdown: Operation not permitted
    du: /var//db/biome: Operation not permitted
    du: /var//db/KernelExtensionManagement/Staging: Operation not permitted
    du: /var//db/DifferentialPrivacy: Operation not permitted
    du: /var//db/MobileIdentityService: Operation not permitted
    du: /var//db/searchparty: Operation not permitted
    du: /var//db/CoreDuet: Operation not permitted
    du: /var//db/ConfigurationProfiles/Store: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/0/com.apple.ScreenTimeAgent/Store: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/0/com.apple.lockoutagent: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/0/com.apple.progressd/ClassKit: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/0/com.apple.exchangesync: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/0/com.apple.LaunchServices.dv: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/0/dmd: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/0/com.apple.nsurlsessiond: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/0/com.apple.SharedWebCredentials: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/0/com.apple.routined/dv: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.appleaccountd/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.ScreenTimeAgent/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.syncdefaultsd/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.weather.widget/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.transparencyd/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.photolibraryd/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.triald/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.BKAgentService/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.mediastream.mstreamd/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.Safari/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.photoanalysisd/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.appstoreagent/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.notificationcenterui/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.icloud.searchpartyd/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.parsec-fbf/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.nsurlsessiond/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.passd/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.calaccessd/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.remindd/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.parsecd/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.identityservicesd/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.sharingd/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.geod/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.bird/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.stocks.widget/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.WindowManager/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/homed/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.pluginkit/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.donotdisturbd/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/itunescloudd/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.amsengagementd/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.mediaanalysisd/TemporaryItems: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/C/com.apple.WebKit.WebContent.Sandbox: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/C/com.apple.WebKit.Networking.Sandbox: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/C/com.apple.quicklook.ThumbnailsAgent/com.apple.QuickLook.thumbnailcache: Operation not permitted
    du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/C/com.apple.WebKit.GPU.Sandbox: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n00000sm00006d/0: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n00000sm00006d/C: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n000013800008t/T/com.apple.trustd/TemporaryItems: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n00000y800007k/0/com.apple.nsurlsessiond: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n00000y800007k/T/com.apple.nsurlsessiond/TemporaryItems: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n00000z000007r/0/com.apple.ScreenTimeAgent/Store: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n00000z000007r/0/com.apple.lockoutagent: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n00000z000007r/0/dmd: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n00000z000007r/0/com.apple.nsurlsessiond: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n00000z000007r/0/com.apple.SharedWebCredentials: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n00000z000007r/0/com.apple.routined/dv: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n00000z000007r/C/com.apple.quicklook.ThumbnailsAgent/com.apple.QuickLook.thumbnailcache: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n00000s0000068/T/TemporaryItems: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n00000s0000068/C/com.apple.WebKit.WebContent.Sandbox: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n00000s0000068/C/com.apple.WebKit.Networking.Sandbox: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n00000s0000068/C/com.apple.WebKit.GPU.Sandbox: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n000012r00008p/T/com.apple.MobileAccessoryUpdater/TemporaryItems: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n00000xc00007b/T/TemporaryItems: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/0/com.apple.LaunchServices.dv: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/com.apple.mobileassetd/TemporaryItems: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/com.apple.dasd/TemporaryItems: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/com.apple.revisiond/TemporaryItems: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/TemporaryItems: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/com.apple.nehelper/TemporaryItems: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/com.apple.GSSCred/TemporaryItems: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/com.apple.kernelmanagerd/TemporaryItems: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/com.apple.wifianalyticsd/TemporaryItems: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/C/com.apple.WebKit.WebContent.Sandbox: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/C/com.apple.WebKit.Networking.Sandbox: Operation not permitted
    du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/C/com.apple.WebKit.GPU.Sandbox: Operation not permitted
    du: /var//protected/trustd/private: Operation not permitted
    5.3G	/var/
    4.0G	/var//vm
    900M	/var//db
    565M	/var//db/diagnostics
    506M	/var//db/diagnostics/Persist
    /Users/meinhard/.diag.sh: line 256: journalctl: command not found
    /opt/iobroker/backups:
    du: /opt/iobroker/backups/: No such file or directory
    /opt/iobroker/iobroker-data:
    du: /opt/iobroker/iobroker-data/: No such file or directory
    find: /opt/iobroker/iobroker-data: No such file or directory
    USB-Devices by-id:
    find: /dev/serial/by-id/: No such file or directory
    *** NodeJS-Installation ***
    /Users/meinhard/.diag.sh: line 277: nodejs: command not found
    /usr/local/bin/node 		v16.17.1
    /usr/local/bin/npm 		8.15.0
    /usr/local/bin/npx 		8.15.0
    /usr/local/bin/corepack 	0.12.1
    /Users/meinhard/.diag.sh: line 288: nodejs: command not found
    *** nodejs is NOT correctly installed ***
    /Users/meinhard/.diag.sh: line 334: apt-cache: command not found
    find: /opt/iobroker/node_modules: No such file or directory
    Temp directories causing npm8 problem:        0
    No problems detected
    Errors in npm tree:
    /Users/meinhard/.diag.sh: line 360: cd: /opt/iobroker: No such file or directory
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	5.0.17
    admin: 		6.13.16
    javascript: 	7.1.6
    /Users/meinhard/.diag.sh: line 375: cd: /opt/iobroker: No such file or directory
    Adapters from github:
    Adapter State
    + system.adapter.admin.0                  : admin                 : macbook.fritz.box                        -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : macbook.fritz.box                        -  enabled
    + system.adapter.backitup.0               : backitup              : macbook.fritz.box                        -  enabled
    + system.adapter.cloud.0                  : cloud                 : macbook.fritz.box                        -  enabled
      system.adapter.flot.0                   : flot                  : macbook.fritz.box                        -  enabled
    + system.adapter.history.0                : history               : macbook.fritz.box                        -  enabled
      system.adapter.homeconnect.0            : homeconnect           : macbook.fritz.box                        - disabled
      system.adapter.ical.0                   : ical                  : macbook.fritz.box                        -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: macbook.fritz.box                        -  enabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : macbook.fritz.box                        -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : macbook.fritz.box                        -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : macbook.fritz.box                        -  enabled
    + system.adapter.jarvis.0                 : jarvis                : macbook.fritz.box                        -  enabled
    + system.adapter.javascript.0             : javascript            : macbook.fritz.box                        -  enabled
    + system.adapter.shelly.0                 : shelly                : macbook.fritz.box                        -  enabled, port: 1895, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : macbook.fritz.box                        -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.sonoff.1                 : sonoff                : macbook.fritz.box                        -  enabled, port: 1881, bind: 0.0.0.0
    + system.adapter.sonoff.10                : sonoff                : macbook.fritz.box                        -  enabled, port: 1892, bind: 0.0.0.0
      system.adapter.sonoff.11                : sonoff                : macbook.fritz.box                        - disabled, port: 1893, bind: 0.0.0.0
    + system.adapter.sonoff.2                 : sonoff                : macbook.fritz.box                        -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.3                 : sonoff                : macbook.fritz.box                        -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sonoff.4                 : sonoff                : macbook.fritz.box                        -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.sonoff.5                 : sonoff                : macbook.fritz.box                        -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.sonoff.6                 : sonoff                : macbook.fritz.box                        -  enabled, port: 1887, bind: 0.0.0.0
    + system.adapter.sonoff.7                 : sonoff                : macbook.fritz.box                        -  enabled, port: 1888, bind: 0.0.0.0
      system.adapter.tesla-motors.0           : tesla-motors          : macbook.fritz.box                        - disabled
    + system.adapter.trashschedule.0          : trashschedule         : macbook.fritz.box                        -  enabled
    + system.adapter.tuya.0                   : tuya                  : macbook.fritz.box                        -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : macbook.fritz.box                        -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : macbook.fritz.box                        -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : macbook.fritz.box                        -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : macbook.fritz.box                        -  enabled
      system.adapter.vis-metro.0              : vis-metro             : macbook.fritz.box                        -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : macbook.fritz.box                        -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : macbook.fritz.box                        -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : macbook.fritz.box                        -  enabled
      system.adapter.vis.0                    : vis                   : macbook.fritz.box                        -  enabled
    + system.adapter.web.0                    : web                   : macbook.fritz.box                        -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.ws.0                     : ws                    : macbook.fritz.box                        -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "ebus"         : 3.2.5    , installed 3.2.5
    Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
    Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
    Adapter    "vis"          : 1.5.4    , installed 1.4.13 [Updatable]
    Adapter    "vis-icontwo"  : 1.3.0    , installed 1.1.0  [Updatable]
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Objects and States
    Objects: 	    7587
    States: 	    5847
    sudo: apt-get: command not found
    /Users/meinhard/.diag.sh: line 398: apt-get: command not found
    grep: invalid option -- P
    usage: grep [-abcdDEFGHhIiJLlMmnOopqRSsUVvwXxZz] [-A num] [-B num] [-C[num]]
    	[-e pattern] [-f file] [--binary-files=value] [--color=when]
    	[--context[=num]] [--directories=action] [--label] [--line-buffered]
    	[--null] [pattern] [file ...]
    Pending Updates:
    *** Listening Ports ***
    netstat: en: unknown or uninstrumented protocol
    tail: /opt/iobroker/log/iobroker.current.log: No such file or directory
    iob diag has finished.
    Press any key for a summary
    Copy text starting here:
    			v.2023-10-10
    /Users/meinhard/.diag.sh: line 457: hostnamectl: command not found
    Installation:
    Kernel: 		x86_64
    /Users/meinhard/.diag.sh: line 462: dpkg: command not found
    Userland:
    /Users/meinhard/.diag.sh: line 466: timedatectl: command not found
    Timezone:
    User-ID: 		501
    X-Server: 		false
    /Users/meinhard/.diag.sh: line 473: systemctl: command not found
    Boot Target:
    Pending OS-Updates:
    Pending iob updates: 	2
    /Users/meinhard/.diag.sh: line 486: nodejs: command not found
    Nodejs-Installation:
    Recommended versions are nodejs 18.19.0 and npm 10.2.3
    Wrong installation path detected. This needs to be fixed.
    Please check
    https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
    for more information on how to fix these errors.
    MEMORY:
    /Users/meinhard/.diag.sh: line 542: free: command not found
    Active iob-Instances: 	22
    ioBroker Core: 		js-controller 		5.0.17
    			admin 			6.13.16
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects: 		    7587
    States: 		    5847
    Size of iob-Database:
    === Mark text until here for copying ===
    meinhard@macbook ~ %
    GlasfaserG Offline
    GlasfaserG Offline
    @meintre-0 sagte in Iobroker VIS keine Visualisierung:
    • system.adapter.ws.0 : ws : macbook.fritz.box - enabled, port: 8084, bind: 0.0.0.0, run as: admin
    Ich sehe du hast den WS Adapter nachinstalliert ... und ist es besser .
    mit :
    mein System läuft auf ein MacBook
    kenne ich mich leider nicht aus
      Meintre 0
      Bis jetzt konnte ich auch alle update machen, eben Vis nur bis 1.4.13
      Mein Macbook läuft mit 2,2 W, weniger geht nicht
        Meintre 0
        probiere es gerade aus
          Meintre 0
          nein ist immer noch der gleiche "Fehler"
          • M Meintre 0
            GlasfaserG Offline
            GlasfaserG Offline
            du hast nur :
            v16.17.1
            Stand ist 18.x.x. da viele aktuelle Adapter auch erst damit funktionieren / bzw. Vorraussetzung !
            • M Meintre 0
              GlasfaserG Offline
              GlasfaserG Offline
              hast du den Haken im Web Adapter rein gemacht / aktiviert !?
                Meintre 0
                wo muß ich einen Haken machen - er ist grün
                • GlasfaserG Offline
                  GlasfaserG Offline
                    Meintre 0
                    "natürlich nicht"
                      Meintre 0
                      wuß ich den gleichen port wie bei Web.0 nehmen?
                      • M Meintre 0
                        GlasfaserG Offline
                        GlasfaserG Offline
                        Nein ... so lassen
                          Meintre 0
                          funktioniert nicht
                          soll ich auf V 18.... Update ?
                          wie mache ich das?
                          • M Meintre 0
                            funktioniert nicht
                            wie mache ich das?
                            GlasfaserG Offline
                            GlasfaserG Offline
                            wie mache ich das?
                            Kann ich dir leider nicht helfen , wie schon oben geschrieben !
                            @meintre-0 sagte> mein System läuft auf ein MacBook
                            @glasfaser sagte in Iobroker VIS keine Visualisierung:
                              Meintre 0
                              @glasfaser
                              versuche Node.js zu updates.
                              Trotzdem vielen Dank
                              • GlasfaserG Glasfaser
                                mit :
                                Meister MopperM Online
                                Meister Mopper
                                schrieb am zuletzt editiert von Meister Mopper
                                @Meintre-0
                                Die Info, was WS Websocket ist, kann hier gelesen werden (eine natürlich nicht validierte Erklärung von Wikipeda).
                                Allgemeinsprachlich ist es eine Standleitung zwischen Server und Client wenn sie etabliert wurde.
                                Proxmox und HA ...
                                Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
                                  @Meintre-0
                                  Meintre 0
                                  @meister-mopper
                                  Danke für die Antwort, habe ich verstanden!
                                  Habe nun ein update auf v 20.... gemacht
                                  zeigt aber immer noch Fehler
                                  /usr/local/bin/node v20.11.0
                                  /usr/local/bin/npm 10.2.4
                                  /usr/local/bin/npx 10.2.4
                                  /usr/local/bin/corepack 0.23.0
                                  kann mir jemand sagen, was ich machen muß
                                  • M Meintre 0
                                    @meister-mopper
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    Stand ist 18.x.x.
                                      Stand ist 18.x.x.
                                      Meintre 0
                                      @glasfaser
                                      Habe Installationsprogramm von Mac genutzt, da gibt es nur noch v20.....
                                      • M Meintre 0
                                        @glasfaser
                                        @meintre-0
                                        https://nodejs.org/download/release/v18.19.0/
                                          @meintre-0
                                          Meintre 0
                                          ok danke, aber es installiert immer auf
                                          Node.js v18.19.0 to /usr/local/bin/node
                                          npm v10.2.3 to /usr/local/bin/npm
                                          es soll aber in usr/bin/node installiert werden
                                          wie mache ich das?
                                          GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
