  3. Einsteigerfragen
  4. Iobroker VIS keine Visualisierung
    5.5k
Geplant Angeheftet Gesperrt Verschoben Ungelöst Einsteigerfragen
73 Beiträge 6 Kommentatoren 8.6k Aufrufe 5 Beobachtet
  • GlasfaserG Offline
    GlasfaserG Offline
    @meintre-0 sagte in Iobroker VIS keine Visualisierung:
    /usr/local/bin/node v16.17.1
    /usr/local/bin/npm 8.15.0
    /usr/local/bin/npx 8.15.0
    Was hast du denn da gemacht !
    Virtualization : Docker
    zeige mal die Ausgabe von :
    cat /opt/scripts/.docker_config/.thisisdocker
      Meintre 0
      @glasfaser sagte in Iobroker VIS keine Visualisierung:
      gibt es nicht
      • M Meintre 0
        @meintre-0
        Skript v.2023-10-10
        *** BASE SYSTEM ***
        /Users/meinhard/.diag.sh: line 63: hostnamectl: command not found
        grep: /proc/cpuinfo: No such file or directory
        Docker          : false
        Kernel          : x86_64
        /Users/meinhard/.diag.sh: line 83: dpkg: command not found
        Userland        :
        Systemuptime and Load:
        17:51  up 27 days, 20:16, 2 users, load averages: 2.21 2.25 2.27
        CPU threads:
        *** Time and Time Zones ***
        /Users/meinhard/.diag.sh: line 188: timedatectl: command not found
        *** User and Groups ***
        meinhard
        /Users/meinhard
        staff everyone localaccounts _appserverusr admin _appserveradm _lpadmin com.apple.access_screensharing com.apple.access_ssh com.apple.access_remote_ae _appstore _lpoperator _developer _analyticsusers com.apple.access_ftp com.apple.sharepoint.group.1
        *** X-Server-Setup ***
        X-Server: 	false
        Desktop:
        Terminal:
        /Users/meinhard/.diag.sh: line 211: systemctl: command not found
        Boot Target:
        *** MEMORY ***
        /Users/meinhard/.diag.sh: line 215: free: command not found
        /Users/meinhard/.diag.sh: line 217: vmstat: command not found
        *** FAILED SERVICES ***
        /Users/meinhard/.diag.sh: line 232: systemctl: command not found
        *** FILESYSTEM ***
        Password:
        usage: sudo dmesg
        /Users/meinhard/.diag.sh: line 242: findmnt: command not found
        /var:
        du: /var//networkd/db: Operation not permitted
        du: /var//db/appinstalld: Operation not permitted
        du: /var//db/ExtensibleSSO/Configuration: Operation not permitted
        du: /var//db/Spotlight: Operation not permitted
        du: /var//db/sysdiagnose/com.apple.sysdiagnose: Operation not permitted
        du: /var//db/DumpPanic: Operation not permitted
        du: /var//db/rmd/secure: Operation not permitted
        du: /var//db/com.apple.backgroundtaskmanagement: Operation not permitted
        du: /var//db/fpsd/dvp: Operation not permitted
        du: /var//db/installcoordinationd: Operation not permitted
        du: /var//db/Spotlight-V100: Operation not permitted
        du: /var//db/oah: Operation not permitted
        du: /var//db/Sandbox: Operation not permitted
        du: /var//db/lockdown: Operation not permitted
        du: /var//db/biome: Operation not permitted
        du: /var//db/KernelExtensionManagement/Staging: Operation not permitted
        du: /var//db/DifferentialPrivacy: Operation not permitted
        du: /var//db/MobileIdentityService: Operation not permitted
        du: /var//db/searchparty: Operation not permitted
        du: /var//db/CoreDuet: Operation not permitted
        du: /var//db/ConfigurationProfiles/Store: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/0/com.apple.ScreenTimeAgent/Store: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/0/com.apple.lockoutagent: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/0/com.apple.progressd/ClassKit: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/0/com.apple.exchangesync: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/0/com.apple.LaunchServices.dv: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/0/dmd: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/0/com.apple.nsurlsessiond: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/0/com.apple.SharedWebCredentials: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/0/com.apple.routined/dv: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.appleaccountd/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.ScreenTimeAgent/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.syncdefaultsd/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.weather.widget/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.transparencyd/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.photolibraryd/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.triald/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.BKAgentService/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.mediastream.mstreamd/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.Safari/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.photoanalysisd/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.appstoreagent/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.notificationcenterui/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.icloud.searchpartyd/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.parsec-fbf/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.nsurlsessiond/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.passd/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.calaccessd/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.remindd/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.parsecd/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.identityservicesd/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.sharingd/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.geod/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.bird/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.stocks.widget/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.WindowManager/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/homed/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.pluginkit/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.donotdisturbd/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/itunescloudd/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.amsengagementd/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.mediaanalysisd/TemporaryItems: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/C/com.apple.WebKit.WebContent.Sandbox: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/C/com.apple.WebKit.Networking.Sandbox: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/C/com.apple.quicklook.ThumbnailsAgent/com.apple.QuickLook.thumbnailcache: Operation not permitted
        du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/C/com.apple.WebKit.GPU.Sandbox: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n00000sm00006d/0: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n00000sm00006d/C: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n000013800008t/T/com.apple.trustd/TemporaryItems: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n00000y800007k/0/com.apple.nsurlsessiond: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n00000y800007k/T/com.apple.nsurlsessiond/TemporaryItems: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n00000z000007r/0/com.apple.ScreenTimeAgent/Store: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n00000z000007r/0/com.apple.lockoutagent: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n00000z000007r/0/dmd: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n00000z000007r/0/com.apple.nsurlsessiond: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n00000z000007r/0/com.apple.SharedWebCredentials: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n00000z000007r/0/com.apple.routined/dv: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n00000z000007r/C/com.apple.quicklook.ThumbnailsAgent/com.apple.QuickLook.thumbnailcache: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n00000s0000068/T/TemporaryItems: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n00000s0000068/C/com.apple.WebKit.WebContent.Sandbox: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n00000s0000068/C/com.apple.WebKit.Networking.Sandbox: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n00000s0000068/C/com.apple.WebKit.GPU.Sandbox: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n000012r00008p/T/com.apple.MobileAccessoryUpdater/TemporaryItems: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n00000xc00007b/T/TemporaryItems: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/0/com.apple.LaunchServices.dv: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/com.apple.mobileassetd/TemporaryItems: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/com.apple.dasd/TemporaryItems: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/com.apple.revisiond/TemporaryItems: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/TemporaryItems: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/com.apple.nehelper/TemporaryItems: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/com.apple.GSSCred/TemporaryItems: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/com.apple.kernelmanagerd/TemporaryItems: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/com.apple.wifianalyticsd/TemporaryItems: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/C/com.apple.WebKit.WebContent.Sandbox: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/C/com.apple.WebKit.Networking.Sandbox: Operation not permitted
        du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/C/com.apple.WebKit.GPU.Sandbox: Operation not permitted
        du: /var//protected/trustd/private: Operation not permitted
        5.3G	/var/
        4.0G	/var//vm
        900M	/var//db
        565M	/var//db/diagnostics
        506M	/var//db/diagnostics/Persist
        /Users/meinhard/.diag.sh: line 256: journalctl: command not found
        /opt/iobroker/backups:
        du: /opt/iobroker/backups/: No such file or directory
        /opt/iobroker/iobroker-data:
        du: /opt/iobroker/iobroker-data/: No such file or directory
        find: /opt/iobroker/iobroker-data: No such file or directory
        USB-Devices by-id:
        find: /dev/serial/by-id/: No such file or directory
        *** NodeJS-Installation ***
        /Users/meinhard/.diag.sh: line 277: nodejs: command not found
        /usr/local/bin/corepack 	0.12.1
        /Users/meinhard/.diag.sh: line 288: nodejs: command not found
        *** nodejs is NOT correctly installed ***
        /Users/meinhard/.diag.sh: line 334: apt-cache: command not found
        find: /opt/iobroker/node_modules: No such file or directory
        Temp directories causing npm8 problem:        0
        No problems detected
        Errors in npm tree:
        /Users/meinhard/.diag.sh: line 360: cd: /opt/iobroker: No such file or directory
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller: 	5.0.17
        admin: 		6.13.16
        javascript: 	7.1.6
        /Users/meinhard/.diag.sh: line 375: cd: /opt/iobroker: No such file or directory
        Adapters from github:
        Adapter State
        + system.adapter.admin.0                  : admin                 : macbook.fritz.box                        -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.alias-manager.0          : alias-manager         : macbook.fritz.box                        -  enabled
        + system.adapter.backitup.0               : backitup              : macbook.fritz.box                        -  enabled
        + system.adapter.cloud.0                  : cloud                 : macbook.fritz.box                        -  enabled
          system.adapter.flot.0                   : flot                  : macbook.fritz.box                        -  enabled
        + system.adapter.history.0                : history               : macbook.fritz.box                        -  enabled
          system.adapter.homeconnect.0            : homeconnect           : macbook.fritz.box                        - disabled
          system.adapter.ical.0                   : ical                  : macbook.fritz.box                        -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: macbook.fritz.box                        -  enabled
          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : macbook.fritz.box                        -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : macbook.fritz.box                        -  enabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : macbook.fritz.box                        -  enabled
        + system.adapter.jarvis.0                 : jarvis                : macbook.fritz.box                        -  enabled
        + system.adapter.javascript.0             : javascript            : macbook.fritz.box                        -  enabled
        + system.adapter.shelly.0                 : shelly                : macbook.fritz.box                        -  enabled, port: 1895, bind: 0.0.0.0
        + system.adapter.sonoff.0                 : sonoff                : macbook.fritz.box                        -  enabled, port: 1880, bind: 0.0.0.0
        + system.adapter.sonoff.1                 : sonoff                : macbook.fritz.box                        -  enabled, port: 1881, bind: 0.0.0.0
        + system.adapter.sonoff.10                : sonoff                : macbook.fritz.box                        -  enabled, port: 1892, bind: 0.0.0.0
          system.adapter.sonoff.11                : sonoff                : macbook.fritz.box                        - disabled, port: 1893, bind: 0.0.0.0
        + system.adapter.sonoff.2                 : sonoff                : macbook.fritz.box                        -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.sonoff.3                 : sonoff                : macbook.fritz.box                        -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.sonoff.4                 : sonoff                : macbook.fritz.box                        -  enabled, port: 1884, bind: 0.0.0.0
        + system.adapter.sonoff.5                 : sonoff                : macbook.fritz.box                        -  enabled, port: 1885, bind: 0.0.0.0
        + system.adapter.sonoff.6                 : sonoff                : macbook.fritz.box                        -  enabled, port: 1887, bind: 0.0.0.0
        + system.adapter.sonoff.7                 : sonoff                : macbook.fritz.box                        -  enabled, port: 1888, bind: 0.0.0.0
          system.adapter.tesla-motors.0           : tesla-motors          : macbook.fritz.box                        - disabled
        + system.adapter.trashschedule.0          : trashschedule         : macbook.fritz.box                        -  enabled
        + system.adapter.tuya.0                   : tuya                  : macbook.fritz.box                        -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : macbook.fritz.box                        -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : macbook.fritz.box                        -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : macbook.fritz.box                        -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : macbook.fritz.box                        -  enabled
          system.adapter.vis-metro.0              : vis-metro             : macbook.fritz.box                        -  enabled
          system.adapter.vis-plumb.0              : vis-plumb             : macbook.fritz.box                        -  enabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : macbook.fritz.box                        -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : macbook.fritz.box                        -  enabled
          system.adapter.vis.0                    : vis                   : macbook.fritz.box                        -  enabled
        + system.adapter.web.0                    : web                   : macbook.fritz.box                        -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.ws.0                     : ws                    : macbook.fritz.box                        -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.13.16  , installed 6.13.16
        Adapter    "alias-manager": 1.2.6    , installed 1.2.6
        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
        Adapter    "cloud"        : 4.4.1    , installed 4.4.1
        Adapter    "ebus"         : 3.2.5    , installed 3.2.5
        Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
        Adapter    "ical"         : 1.13.3   , installed 1.13.3
        Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
        Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
        Controller "js-controller": 5.0.17   , installed 5.0.17
        Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "socketio"     : 6.6.0    , installed 6.6.0
        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
        Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
        Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
        Adapter    "trashschedule": 2.3.0    , installed 2.3.0
        Adapter    "tuya"         : 3.15.0   , installed 3.15.0
        Adapter    "vis"          : 1.5.4    , installed 1.4.13 [Updatable]
        Adapter    "vis-icontwo"  : 1.3.0    , installed 1.1.0  [Updatable]
        Adapter    "web"          : 6.2.3    , installed 6.2.3
        Adapter    "ws"           : 2.5.10   , installed 2.5.10
        Objects and States
        Objects: 	    7587
        States: 	    5847
        sudo: apt-get: command not found
        /Users/meinhard/.diag.sh: line 398: apt-get: command not found
        grep: invalid option -- P
        usage: grep [-abcdDEFGHhIiJLlMmnOopqRSsUVvwXxZz] [-A num] [-B num] [-C[num]]
        	[-e pattern] [-f file] [--binary-files=value] [--color=when]
        	[--context[=num]] [--directories=action] [--label] [--line-buffered]
        	[--null] [pattern] [file ...]
        Pending Updates:
        *** Listening Ports ***
        netstat: en: unknown or uninstrumented protocol
        tail: /opt/iobroker/log/iobroker.current.log: No such file or directory
        iob diag has finished.
        Press any key for a summary
        Copy text starting here:
        			v.2023-10-10
        /Users/meinhard/.diag.sh: line 457: hostnamectl: command not found
        Installation:
        Kernel: 		x86_64
        /Users/meinhard/.diag.sh: line 462: dpkg: command not found
        Userland:
        /Users/meinhard/.diag.sh: line 466: timedatectl: command not found
        Timezone:
        User-ID: 		501
        X-Server: 		false
        /Users/meinhard/.diag.sh: line 473: systemctl: command not found
        Boot Target:
        Pending OS-Updates:
        Pending iob updates: 	2
        /Users/meinhard/.diag.sh: line 486: nodejs: command not found
        Nodejs-Installation:
        Recommended versions are nodejs 18.19.0 and npm 10.2.3
        Wrong installation path detected. This needs to be fixed.
        Please check
        https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
        for more information on how to fix these errors.
        MEMORY:
        /Users/meinhard/.diag.sh: line 542: free: command not found
        Active iob-Instances: 	22
        ioBroker Core: 		js-controller 		5.0.17
        			admin 			6.13.16
        ioBroker Status: 	iobroker is running on this host.
        Objects type: jsonl
        States  type: jsonl
        Objects: 		    7587
        States: 		    5847
        Size of iob-Database:
        === Mark text until here for copying ===
        meinhard@macbook ~ %
        GlasfaserG Offline
        GlasfaserG Offline
        macbook
        mit Docker oder !?
          Meintre 0
          cat
          mein System läuft auf ein MacBook
          • M Meintre 0
            cat
            GlasfaserG Offline
            GlasfaserG Offline
            @meintre-0
            ok , dann ist /usr/local richtig !
            • M Meintre 0
              @meintre-0
              Skript v.2023-10-10
              *** BASE SYSTEM ***
              Docker          : false
              Kernel          : x86_64
              Userland        :
              CPU threads:
              meinhard
              /Users/meinhard
              X-Server: 	false
              Desktop:
              Terminal:
              Boot Target:
              *** MEMORY ***
              *** FILESYSTEM ***
              Password:
              usage: sudo dmesg
              /var:
              5.3G	/var/
              4.0G	/var//vm
              900M	/var//db
              USB-Devices by-id:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin: 		6.13.16
              javascript: 	7.1.6
              Adapter State
              + instance is alive
              Objects and States
              Objects: 	    7587
              States: 	    5847
              Pending Updates:
              			v.2023-10-10
              Installation:
              Kernel: 		x86_64
              Userland:
              Timezone:
              User-ID: 		501
              X-Server: 		false
              Boot Target:
              Pending OS-Updates:
              Please check
              MEMORY:
              			admin 			6.13.16
              Objects type: jsonl
              States  type: jsonl
              Objects: 		    7587
              States: 		    5847
              GlasfaserG Offline
              GlasfaserG Offline
              • system.adapter.ws.0 : ws : macbook.fritz.box - enabled, port: 8084, bind: 0.0.0.0, run as: admin
              Ich sehe du hast den WS Adapter nachinstalliert ... und ist es besser .
              mit :
              kenne ich mich leider nicht aus
                Meintre 0
                Bis jetzt konnte ich auch alle update machen, eben Vis nur bis 1.4.13
                Mein Macbook läuft mit 2,2 W, weniger geht nicht
                  Meintre 0
                  probiere es gerade aus
                    Meintre 0
                    nein ist immer noch der gleiche "Fehler"
                    • M Meintre 0
                      GlasfaserG Offline
                      GlasfaserG Offline
                      du hast nur :
                      v16.17.1
                      Stand ist 18.x.x. da viele aktuelle Adapter auch erst damit funktionieren / bzw. Vorraussetzung !
                      • M Meintre 0
                        GlasfaserG Offline
                        GlasfaserG Offline
                        hast du den Haken im Web Adapter rein gemacht / aktiviert !?
                          Meintre 0
                          wo muß ich einen Haken machen - er ist grün
                            GlasfaserG Offline
                              Meintre 0
                              "natürlich nicht"
                                Meintre 0
                                wuß ich den gleichen port wie bei Web.0 nehmen?
                                • M Meintre 0
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Nein ... so lassen
                                    Meintre 0
                                    funktioniert nicht
                                    soll ich auf V 18.... Update ?
                                    wie mache ich das?
                                    • M Meintre 0
                                      funktioniert nicht
                                      wie mache ich das?
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      wie mache ich das?
                                      Kann ich dir leider nicht helfen , wie schon oben geschrieben !
                                      @meintre-0 sagte> mein System läuft auf ein MacBook
                                        Meintre 0
                                        @glasfaser
                                        versuche Node.js zu updates.
                                        Trotzdem vielen Dank
                                        • GlasfaserG Glasfaser
                                          mit :
                                          Meister MopperM Online
                                          Meister Mopper
                                          schrieb am zuletzt editiert von Meister Mopper
                                          @Meintre-0
                                          Die Info, was WS Websocket ist, kann hier gelesen werden (eine natürlich nicht validierte Erklärung von Wikipeda).
                                          Allgemeinsprachlich ist es eine Standleitung zwischen Server und Client wenn sie etabliert wurde.
                                          Proxmox und HA ...
                                          Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
