  3. Einsteigerfragen
  4. Iobroker VIS keine Visualisierung
    5.5k
Geplant Angeheftet Gesperrt Verschoben Ungelöst Einsteigerfragen
73 Beiträge 6 Kommentatoren 8.6k Aufrufe 5 Beobachtet
  • M Meintre 0
    @glasfaser
    kleinen Augenblick bin gerade dabei IOB Diag auszuführen - ist ja ellenlang
    GlasfaserG Offline
    GlasfaserG Offline
    @meintre-0 sagte in Iobroker VIS keine Visualisierung:
    ist ja ellenlang
    das ganze dann bitte , in Code-Tags </> posten !!
    • M Meintre 0
      @glasfaser
      Meintre 0
      @meintre-0
      Skript v.2023-10-10
      *** BASE SYSTEM ***
      /Users/meinhard/.diag.sh: line 63: hostnamectl: command not found
      grep: /proc/cpuinfo: No such file or directory
      Docker          : false
      Virtualization  : Docker
      Kernel          : x86_64
      /Users/meinhard/.diag.sh: line 83: dpkg: command not found
      Userland        :
      Systemuptime and Load:
      17:51  up 27 days, 20:16, 2 users, load averages: 2.21 2.25 2.27
      CPU threads:
      *** Time and Time Zones ***
      /Users/meinhard/.diag.sh: line 188: timedatectl: command not found
      *** User and Groups ***
      meinhard
      /Users/meinhard
      staff everyone localaccounts _appserverusr admin _appserveradm _lpadmin com.apple.access_screensharing com.apple.access_ssh com.apple.access_remote_ae _appstore _lpoperator _developer _analyticsusers com.apple.access_ftp com.apple.sharepoint.group.1
      *** X-Server-Setup ***
      X-Server: 	false
      Desktop:
      Terminal:
      /Users/meinhard/.diag.sh: line 211: systemctl: command not found
      Boot Target:
      *** MEMORY ***
      /Users/meinhard/.diag.sh: line 215: free: command not found
      /Users/meinhard/.diag.sh: line 217: vmstat: command not found
      *** FAILED SERVICES ***
      /Users/meinhard/.diag.sh: line 232: systemctl: command not found
      *** FILESYSTEM ***
      Password:
      usage: sudo dmesg
      /Users/meinhard/.diag.sh: line 242: findmnt: command not found
      /var:
      du: /var//networkd/db: Operation not permitted
      du: /var//db/appinstalld: Operation not permitted
      du: /var//db/ExtensibleSSO/Configuration: Operation not permitted
      du: /var//db/Spotlight: Operation not permitted
      du: /var//db/sysdiagnose/com.apple.sysdiagnose: Operation not permitted
      du: /var//db/DumpPanic: Operation not permitted
      du: /var//db/rmd/secure: Operation not permitted
      du: /var//db/com.apple.backgroundtaskmanagement: Operation not permitted
      du: /var//db/fpsd/dvp: Operation not permitted
      du: /var//db/installcoordinationd: Operation not permitted
      du: /var//db/Spotlight-V100: Operation not permitted
      du: /var//db/oah: Operation not permitted
      du: /var//db/Sandbox: Operation not permitted
      du: /var//db/lockdown: Operation not permitted
      du: /var//db/biome: Operation not permitted
      du: /var//db/KernelExtensionManagement/Staging: Operation not permitted
      du: /var//db/DifferentialPrivacy: Operation not permitted
      du: /var//db/MobileIdentityService: Operation not permitted
      du: /var//db/searchparty: Operation not permitted
      du: /var//db/CoreDuet: Operation not permitted
      du: /var//db/ConfigurationProfiles/Store: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/0/com.apple.ScreenTimeAgent/Store: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/0/com.apple.lockoutagent: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/0/com.apple.progressd/ClassKit: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/0/com.apple.exchangesync: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/0/com.apple.LaunchServices.dv: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/0/dmd: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/0/com.apple.nsurlsessiond: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/0/com.apple.SharedWebCredentials: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/0/com.apple.routined/dv: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.appleaccountd/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.ScreenTimeAgent/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.syncdefaultsd/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.weather.widget/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.transparencyd/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.photolibraryd/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.triald/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.BKAgentService/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.mediastream.mstreamd/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.Safari/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.photoanalysisd/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.appstoreagent/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.notificationcenterui/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.icloud.searchpartyd/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.parsec-fbf/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.nsurlsessiond/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.passd/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.calaccessd/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.remindd/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.parsecd/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.identityservicesd/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.sharingd/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.geod/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.bird/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.stocks.widget/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.WindowManager/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/homed/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.pluginkit/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.donotdisturbd/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/itunescloudd/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.amsengagementd/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/T/com.apple.mediaanalysisd/TemporaryItems: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/C/com.apple.WebKit.WebContent.Sandbox: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/C/com.apple.WebKit.Networking.Sandbox: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/C/com.apple.quicklook.ThumbnailsAgent/com.apple.QuickLook.thumbnailcache: Operation not permitted
      du: /var//folders/l2/2xc424h96_sfm8qrdm2r4c2m0000gn/C/com.apple.WebKit.GPU.Sandbox: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n00000sm00006d/0: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n00000sm00006d/C: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n000013800008t/T/com.apple.trustd/TemporaryItems: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n00000y800007k/0/com.apple.nsurlsessiond: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n00000y800007k/T/com.apple.nsurlsessiond/TemporaryItems: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n00000z000007r/0/com.apple.ScreenTimeAgent/Store: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n00000z000007r/0/com.apple.lockoutagent: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n00000z000007r/0/dmd: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n00000z000007r/0/com.apple.nsurlsessiond: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n00000z000007r/0/com.apple.SharedWebCredentials: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n00000z000007r/0/com.apple.routined/dv: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n00000z000007r/C/com.apple.quicklook.ThumbnailsAgent/com.apple.QuickLook.thumbnailcache: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n00000s0000068/T/TemporaryItems: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n00000s0000068/C/com.apple.WebKit.WebContent.Sandbox: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n00000s0000068/C/com.apple.WebKit.Networking.Sandbox: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n00000s0000068/C/com.apple.WebKit.GPU.Sandbox: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n000012r00008p/T/com.apple.MobileAccessoryUpdater/TemporaryItems: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n00000xc00007b/T/TemporaryItems: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/0/com.apple.LaunchServices.dv: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/com.apple.mobileassetd/TemporaryItems: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/com.apple.dasd/TemporaryItems: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/com.apple.revisiond/TemporaryItems: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/TemporaryItems: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/com.apple.nehelper/TemporaryItems: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/com.apple.GSSCred/TemporaryItems: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/com.apple.kernelmanagerd/TemporaryItems: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/com.apple.wifianalyticsd/TemporaryItems: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/C/com.apple.WebKit.WebContent.Sandbox: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/C/com.apple.WebKit.Networking.Sandbox: Operation not permitted
      du: /var//folders/zz/zyxvpxvq6csfxvn_n0000000000000/C/com.apple.WebKit.GPU.Sandbox: Operation not permitted
      du: /var//protected/trustd/private: Operation not permitted
      5.3G	/var/
      4.0G	/var//vm
      900M	/var//db
      565M	/var//db/diagnostics
      506M	/var//db/diagnostics/Persist
      /Users/meinhard/.diag.sh: line 256: journalctl: command not found
      /opt/iobroker/backups:
      du: /opt/iobroker/backups/: No such file or directory
      /opt/iobroker/iobroker-data:
      du: /opt/iobroker/iobroker-data/: No such file or directory
      find: /opt/iobroker/iobroker-data: No such file or directory
      USB-Devices by-id:
      find: /dev/serial/by-id/: No such file or directory
      *** NodeJS-Installation ***
      /Users/meinhard/.diag.sh: line 277: nodejs: command not found
      /usr/local/bin/node 		v16.17.1
      /usr/local/bin/npm 		8.15.0
      /usr/local/bin/npx 		8.15.0
      /usr/local/bin/corepack 	0.12.1
      /Users/meinhard/.diag.sh: line 288: nodejs: command not found
      *** nodejs is NOT correctly installed ***
      /Users/meinhard/.diag.sh: line 334: apt-cache: command not found
      find: /opt/iobroker/node_modules: No such file or directory
      Temp directories causing npm8 problem:        0
      No problems detected
      Errors in npm tree:
      /Users/meinhard/.diag.sh: line 360: cd: /opt/iobroker: No such file or directory
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller: 	5.0.17
      admin: 		6.13.16
      javascript: 	7.1.6
      /Users/meinhard/.diag.sh: line 375: cd: /opt/iobroker: No such file or directory
      Adapters from github:
      Adapter State
      + system.adapter.admin.0                  : admin                 : macbook.fritz.box                        -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alias-manager.0          : alias-manager         : macbook.fritz.box                        -  enabled
      + system.adapter.backitup.0               : backitup              : macbook.fritz.box                        -  enabled
      + system.adapter.cloud.0                  : cloud                 : macbook.fritz.box                        -  enabled
        system.adapter.flot.0                   : flot                  : macbook.fritz.box                        -  enabled
      + system.adapter.history.0                : history               : macbook.fritz.box                        -  enabled
        system.adapter.homeconnect.0            : homeconnect           : macbook.fritz.box                        - disabled
        system.adapter.ical.0                   : ical                  : macbook.fritz.box                        -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: macbook.fritz.box                        -  enabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : macbook.fritz.box                        -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : macbook.fritz.box                        -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : macbook.fritz.box                        -  enabled
      + system.adapter.jarvis.0                 : jarvis                : macbook.fritz.box                        -  enabled
      + system.adapter.javascript.0             : javascript            : macbook.fritz.box                        -  enabled
      + system.adapter.shelly.0                 : shelly                : macbook.fritz.box                        -  enabled, port: 1895, bind: 0.0.0.0
      + system.adapter.sonoff.0                 : sonoff                : macbook.fritz.box                        -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.sonoff.1                 : sonoff                : macbook.fritz.box                        -  enabled, port: 1881, bind: 0.0.0.0
      + system.adapter.sonoff.10                : sonoff                : macbook.fritz.box                        -  enabled, port: 1892, bind: 0.0.0.0
        system.adapter.sonoff.11                : sonoff                : macbook.fritz.box                        - disabled, port: 1893, bind: 0.0.0.0
      + system.adapter.sonoff.2                 : sonoff                : macbook.fritz.box                        -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sonoff.3                 : sonoff                : macbook.fritz.box                        -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sonoff.4                 : sonoff                : macbook.fritz.box                        -  enabled, port: 1884, bind: 0.0.0.0
      + system.adapter.sonoff.5                 : sonoff                : macbook.fritz.box                        -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.sonoff.6                 : sonoff                : macbook.fritz.box                        -  enabled, port: 1887, bind: 0.0.0.0
      + system.adapter.sonoff.7                 : sonoff                : macbook.fritz.box                        -  enabled, port: 1888, bind: 0.0.0.0
        system.adapter.tesla-motors.0           : tesla-motors          : macbook.fritz.box                        - disabled
      + system.adapter.trashschedule.0          : trashschedule         : macbook.fritz.box                        -  enabled
      + system.adapter.tuya.0                   : tuya                  : macbook.fritz.box                        -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : macbook.fritz.box                        -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : macbook.fritz.box                        -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : macbook.fritz.box                        -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : macbook.fritz.box                        -  enabled
        system.adapter.vis-metro.0              : vis-metro             : macbook.fritz.box                        -  enabled
        system.adapter.vis-plumb.0              : vis-plumb             : macbook.fritz.box                        -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : macbook.fritz.box                        -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : macbook.fritz.box                        -  enabled
        system.adapter.vis.0                    : vis                   : macbook.fritz.box                        -  enabled
      + system.adapter.web.0                    : web                   : macbook.fritz.box                        -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.ws.0                     : ws                    : macbook.fritz.box                        -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.13.16  , installed 6.13.16
      Adapter    "alias-manager": 1.2.6    , installed 1.2.6
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
      Adapter    "ebus"         : 3.2.5    , installed 3.2.5
      Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
      Adapter    "ical"         : 1.13.3   , installed 1.13.3
      Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
      Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "socketio"     : 6.6.0    , installed 6.6.0
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
      Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "vis"          : 1.5.4    , installed 1.4.13 [Updatable]
      Adapter    "vis-icontwo"  : 1.3.0    , installed 1.1.0  [Updatable]
      Adapter    "web"          : 6.2.3    , installed 6.2.3
      Adapter    "ws"           : 2.5.10   , installed 2.5.10
      Objects and States
      Objects: 	    7587
      States: 	    5847
      sudo: apt-get: command not found
      /Users/meinhard/.diag.sh: line 398: apt-get: command not found
      grep: invalid option -- P
      usage: grep [-abcdDEFGHhIiJLlMmnOopqRSsUVvwXxZz] [-A num] [-B num] [-C[num]]
      	[-e pattern] [-f file] [--binary-files=value] [--color=when]
      	[--context[=num]] [--directories=action] [--label] [--line-buffered]
      	[--null] [pattern] [file ...]
      Pending Updates:
      *** Listening Ports ***
      netstat: en: unknown or uninstrumented protocol
      tail: /opt/iobroker/log/iobroker.current.log: No such file or directory
      iob diag has finished.
      Press any key for a summary
      Copy text starting here:
      			v.2023-10-10
      /Users/meinhard/.diag.sh: line 457: hostnamectl: command not found
      Installation:
      Kernel: 		x86_64
      /Users/meinhard/.diag.sh: line 462: dpkg: command not found
      Userland:
      /Users/meinhard/.diag.sh: line 466: timedatectl: command not found
      Timezone:
      User-ID: 		501
      X-Server: 		false
      /Users/meinhard/.diag.sh: line 473: systemctl: command not found
      Boot Target:
      Pending OS-Updates:
      Pending iob updates: 	2
      /Users/meinhard/.diag.sh: line 486: nodejs: command not found
      Nodejs-Installation:
      Recommended versions are nodejs 18.19.0 and npm 10.2.3
      Wrong installation path detected. This needs to be fixed.
      Please check
      https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
      for more information on how to fix these errors.
      MEMORY:
      /Users/meinhard/.diag.sh: line 542: free: command not found
      Active iob-Instances: 	22
      ioBroker Core: 		js-controller 		5.0.17
      			admin 			6.13.16
      ioBroker Status: 	iobroker is running on this host.
      Objects type: jsonl
      States  type: jsonl
      Objects: 		    7587
      States: 		    5847
      Size of iob-Database:
      === Mark text until here for copying ===
      meinhard@macbook ~ %
      M GlasfaserG 3 Antworten Letzte Antwort
      • M Meintre 0
        @meintre-0
        Skript v.2023-10-10
        *** BASE SYSTEM ***
        Docker          : false
        Kernel          : x86_64
        Userland        :
        CPU threads:
        meinhard
        /Users/meinhard
        X-Server: 	false
        Desktop:
        Terminal:
        Boot Target:
        *** MEMORY ***
        *** FILESYSTEM ***
        Password:
        usage: sudo dmesg
        /var:
        5.3G	/var/
        4.0G	/var//vm
        900M	/var//db
        USB-Devices by-id:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin: 		6.13.16
        javascript: 	7.1.6
        Adapter State
        + instance is alive
        Objects and States
        Objects: 	    7587
        States: 	    5847
        Pending Updates:
        			v.2023-10-10
        Installation:
        Kernel: 		x86_64
        Userland:
        Timezone:
        User-ID: 		501
        X-Server: 		false
        Boot Target:
        Pending OS-Updates:
        Please check
        MEMORY:
        			admin 			6.13.16
        Objects type: jsonl
        States  type: jsonl
        Objects: 		    7587
        States: 		    5847
        Meintre 0
        @meintre-0
        Ich hoffe Du kannst mir helfen?
        • GlasfaserG Offline
          GlasfaserG Offline
          Was hast du denn da gemacht !
          zeige mal die Ausgabe von :
          cat /opt/scripts/.docker_config/.thisisdocker
            Meintre 0
            @glasfaser sagte in Iobroker VIS keine Visualisierung:
            gibt es nicht
            • M Meintre 0
              @meintre-0
              Skript v.2023-10-10
              *** BASE SYSTEM ***
              Docker          : false
              Kernel          : x86_64
              Userland        :
              CPU threads:
              meinhard
              /Users/meinhard
              X-Server: 	false
              Desktop:
              Terminal:
              Boot Target:
              *** MEMORY ***
              *** FILESYSTEM ***
              Password:
              usage: sudo dmesg
              /var:
              5.3G	/var/
              4.0G	/var//vm
              900M	/var//db
              USB-Devices by-id:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin: 		6.13.16
              javascript: 	7.1.6
              Adapter State
              + instance is alive
              Objects and States
              Objects: 	    7587
              States: 	    5847
              Pending Updates:
              			v.2023-10-10
              Installation:
              Kernel: 		x86_64
              Userland:
              Timezone:
              User-ID: 		501
              X-Server: 		false
              Boot Target:
              Pending OS-Updates:
              Please check
              MEMORY:
              			admin 			6.13.16
              Objects type: jsonl
              States  type: jsonl
              Objects: 		    7587
              States: 		    5847
              GlasfaserG Offline
              GlasfaserG Offline
              macbook
              mit Docker oder !?
                Meintre 0
                cat
                mein System läuft auf ein MacBook
                • M Meintre 0
                  cat
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @meintre-0
                  ok , dann ist /usr/local richtig !
                  • M Meintre 0
                    @meintre-0
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                    Docker          : false
                    Kernel          : x86_64
                    Userland        :
                    CPU threads:
                    meinhard
                    /Users/meinhard
                    X-Server: 	false
                    Desktop:
                    Terminal:
                    Boot Target:
                    *** MEMORY ***
                    *** FILESYSTEM ***
                    Password:
                    usage: sudo dmesg
                    /var:
                    5.3G	/var/
                    4.0G	/var//vm
                    900M	/var//db
                    USB-Devices by-id:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin: 		6.13.16
                    javascript: 	7.1.6
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects: 	    7587
                    States: 	    5847
                    Pending Updates:
                    			v.2023-10-10
                    Installation:
                    Kernel: 		x86_64
                    Userland:
                    Timezone:
                    User-ID: 		501
                    X-Server: 		false
                    Boot Target:
                    Pending OS-Updates:
                    Please check
                    MEMORY:
                    			admin 			6.13.16
                    Objects type: jsonl
                    States  type: jsonl
                    Objects: 		    7587
                    States: 		    5847
                    GlasfaserG Offline
                    GlasfaserG Offline
                    • system.adapter.ws.0 : ws : macbook.fritz.box - enabled, port: 8084, bind: 0.0.0.0, run as: admin
                    Ich sehe du hast den WS Adapter nachinstalliert ... und ist es besser .
                    mit :
                    kenne ich mich leider nicht aus
                      Meintre 0
                      Bis jetzt konnte ich auch alle update machen, eben Vis nur bis 1.4.13
                      Mein Macbook läuft mit 2,2 W, weniger geht nicht
                        Meintre 0
                        probiere es gerade aus
                          Meintre 0
                          nein ist immer noch der gleiche "Fehler"
                          • M Meintre 0
                            GlasfaserG Offline
                            GlasfaserG Offline
                            du hast nur :
                            v16.17.1
                            Stand ist 18.x.x. da viele aktuelle Adapter auch erst damit funktionieren / bzw. Vorraussetzung !
                            • M Meintre 0
                              GlasfaserG Offline
                              GlasfaserG Offline
                              hast du den Haken im Web Adapter rein gemacht / aktiviert !?
                                Meintre 0
                                wo muß ich einen Haken machen - er ist grün
                                  GlasfaserG Offline
                                    Meintre 0
                                    "natürlich nicht"
                                      Meintre 0
                                      wuß ich den gleichen port wie bei Web.0 nehmen?
                                      • M Meintre 0
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        Nein ... so lassen
                                          Meintre 0
                                          funktioniert nicht
                                          soll ich auf V 18.... Update ?
                                          wie mache ich das?
