  4. Error: Cannot find module 'tar' - iobroker nicht erreichbar
7 Beiträge 4 Kommentatoren 668 Aufrufe 3 Beobachtet
    ThoHilde
    ich habe heute Morgen verschiedene updates eingespilet über die Weboberfläche (u.a. admin, nodered, modbus) und seitdem funktioniert mein iobroker nicht mehr.
    iob fix habe ich laufen lassen, jedoch ohne Erfolg.
    Wenn ich über ssh z.b. die logs bei einem restart ansehen will kommt folgendes:
    pi@raspberrypi:~ $ iob logs --watch
    node:internal/modules/cjs/loader:1137
     throw err;
    Require stack:
    - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js
    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
       at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
       at Module._load (node:internal/modules/cjs/loader:975:27)
       at Module.require (node:internal/modules/cjs/loader:1225:19)
       at require (node:internal/modules/helpers:177:18)
       at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js:12:31)
       at Module._compile (node:internal/modules/cjs/loader:1356:14)
       at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
       at Module.load (node:internal/modules/cjs/loader:1197:32)
       at Module._load (node:internal/modules/cjs/loader:1013:12)
       at Module.require (node:internal/modules/cjs/loader:1225:19) {
     code: 'MODULE_NOT_FOUND',
     requireStack: [
       '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js',
       '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js',
       '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    Node.js v18.19.0
    iob diag sagt folgendes:
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     10:34:36 up  1:15,  1 user,  load average: 0.97, 0.95, 0.87
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Thu 2024-02-01 10:34:36 CET
               Universal time: Thu 2024-02-01 09:34:36 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            1.9G        573M        804M        0.0K        492M        1.3G
    Swap:            99M        1.0M         98M
    Total:          2.0G        574M        903M
             1870 M total memory
              573 M used memory
              208 M active memory
              734 M inactive memory
              804 M free memory
              100 M buffer memory
              392 M swap cache
               99 M total swap
                1 M used swap
               98 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4      110G   11G   95G  11% /
    devtmpfs       devtmpfs  679M     0  679M   0% /dev
    tmpfs          tmpfs     936M     0  936M   0% /dev/shm
    tmpfs          tmpfs     375M  864K  374M   1% /run
    /dev/sda1      vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     188M     0  188M   0% /run/user/1000
    [Thu Feb  1 09:18:46 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:1F:BE:D6 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=16b6bb5a-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Thu Feb  1 09:18:48 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
    [Thu Feb  1 09:18:48 2024] EXT4-fs (sda2): write access will be enabled during recovery
    [Thu Feb  1 09:18:49 2024] EXT4-fs (sda2): orphan cleanup on readonly fs
    [Thu Feb  1 09:18:49 2024] EXT4-fs (sda2): 5 orphan inodes deleted
    [Thu Feb  1 09:18:49 2024] EXT4-fs (sda2): recovery complete
    [Thu Feb  1 09:18:49 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Thu Feb  1 09:18:49 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Thu Feb  1 09:18:52 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
    4.3G    /var/
    3.1G    /var/log
    3.0G    /var/log/journal/3e23e34d17484a28b9473f69f7d9d21c
    852M    /var/lib
    Archived and active journals take up 2.9G in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    478M    /opt/iobroker/iobroker-data/
    392M    /opt/iobroker/iobroker-data/files
    89M     /opt/iobroker/iobroker-data/files/echarts.admin
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    67M     /opt/iobroker/iobroker-data/backup-objects
    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_66b57112301aec11875774e5f01c6278-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: @emnapi/core@ /opt/iobroker/node_modules/@emnapi/core
    npm ERR! extraneous: @emnapi/runtime@ /opt/iobroker/node_modules/@emnapi/runtime
    npm ERR! extraneous: @mongodb-js/saslprep@ /opt/iobroker/node_modules/@mongodb-js/saslprep
    npm ERR! extraneous: @napi-rs/wasm-runtime@ /opt/iobroker/node_modules/@napi-rs/wasm-runtime
    npm ERR! extraneous: @node-red/editor-api@ /opt/iobroker/node_modules/@node-red/editor-api
    npm ERR! extraneous: @node-red/editor-client@ /opt/iobroker/node_modules/@node-red/editor-client
    npm ERR! extraneous: @node-red/nodes@ /opt/iobroker/node_modules/@node-red/nodes
    npm ERR! extraneous: @node-red/registry@ /opt/iobroker/node_modules/@node-red/registry
    npm ERR! extraneous: @node-red/runtime@ /opt/iobroker/node_modules/@node-red/runtime
    npm ERR! extraneous: @node-red/util@ /opt/iobroker/node_modules/@node-red/util
    npm ERR! extraneous: @tybys/wasm-util@ /opt/iobroker/node_modules/@tybys/wasm-util
    npm ERR! extraneous: @types/webidl-conversions@7.0.3 /opt/iobroker/node_modules/@types/webidl-conversions
    npm ERR! extraneous: @types/whatwg-url@11.0.4 /opt/iobroker/node_modules/@types/whatwg-url
    npm ERR! extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
    npm ERR! extraneous: acorn-walk@8.2.0 /opt/iobroker/node_modules/acorn-walk
    npm ERR! extraneous: acorn@ /opt/iobroker/node_modules/acorn
    npm ERR! extraneous: addressparser@1.0.1 /opt/iobroker/node_modules/addressparser
    npm ERR! extraneous: ansi-colors@4.1.3 /opt/iobroker/node_modules/ansi-colors
    npm ERR! extraneous: aproba@1.2.0 /opt/iobroker/node_modules/aproba
    npm ERR! extraneous: array-indexofobject@0.0.1 /opt/iobroker/node_modules/array-indexofobject
    npm ERR! extraneous: async-mutex@ /opt/iobroker/node_modules/async-mutex
    npm ERR! extraneous: basic-auth@2.0.1 /opt/iobroker/node_modules/basic-auth
    npm ERR! extraneous: bcrypt@ /opt/iobroker/node_modules/bcrypt
    npm ERR! extraneous: bcryptjs@2.4.3 /opt/iobroker/node_modules/bcryptjs
    npm ERR! extraneous: better-assert@1.0.2 /opt/iobroker/node_modules/better-assert
    npm ERR! extraneous: bson@ /opt/iobroker/node_modules/bson
    npm ERR! extraneous: cli-table@0.3.11 /opt/iobroker/node_modules/cli-table
    npm ERR! extraneous: clone@2.1.2 /opt/iobroker/node_modules/clone
    npm ERR! extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
    npm ERR! extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
    npm ERR! extraneous: cronosjs@1.7.1 /opt/iobroker/node_modules/cronosjs
    npm ERR! extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
    npm ERR! extraneous: detect-libc@ /opt/iobroker/node_modules/detect-libc
    npm ERR! extraneous: enquirer@ /opt/iobroker/node_modules/enquirer
    npm ERR! extraneous: feedparser@2.2.10 /opt/iobroker/node_modules/feedparser
    npm ERR! extraneous: fs.notify@0.0.4 /opt/iobroker/node_modules/fs.notify
    npm ERR! extraneous: gridstack@0.6.4 /opt/iobroker/node_modules/gridstack
    npm ERR! extraneous: has-binary@0.1.7 /opt/iobroker/node_modules/has-binary
    npm ERR! extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
    npm ERR! extraneous: hash-sum@2.0.0 /opt/iobroker/node_modules/hash-sum
    npm ERR! extraneous: hpagent@ /opt/iobroker/node_modules/hpagent
    npm ERR! extraneous: i18next@ /opt/iobroker/node_modules/i18next
    npm ERR! invalid: iobroker.node-red@ /opt/iobroker/node_modules/iobroker.node-red
    npm ERR! extraneous: is-utf8@0.2.1 /opt/iobroker/node_modules/is-utf8
    npm ERR! invalid: jquery@ /opt/iobroker/node_modules/jquery
    npm ERR! extraneous: jquery@ /opt/iobroker/node_modules/jquery
    npm ERR! extraneous: js2xmlparser@5.0.0 /opt/iobroker/node_modules/js2xmlparser
    npm ERR! extraneous: json3@3.3.2 /opt/iobroker/node_modules/json3
    npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
    npm ERR! extraneous: lodash.assign@4.2.0 /opt/iobroker/node_modules/lodash.assign
    npm ERR! extraneous: lodash.clonedeep@4.5.0 /opt/iobroker/node_modules/lodash.clonedeep
    npm ERR! extraneous: lodash.get@4.4.2 /opt/iobroker/node_modules/lodash.get
    npm ERR! extraneous: lodash.has@4.5.2 /opt/iobroker/node_modules/lodash.has
    npm ERR! extraneous: lodash.uniq@4.5.0 /opt/iobroker/node_modules/lodash.uniq
    npm ERR! extraneous: memory-pager@1.5.0 /opt/iobroker/node_modules/memory-pager
    npm ERR! extraneous: memorystore@1.6.7 /opt/iobroker/node_modules/memorystore
    npm ERR! extraneous: mongodb-connection-string-url@ /opt/iobroker/node_modules/mongodb-connection-string-url
    npm ERR! extraneous: mri@1.2.0 /opt/iobroker/node_modules/mri
    npm ERR! extraneous: mustache@4.2.0 /opt/iobroker/node_modules/mustache
    npm ERR! extraneous: node-disk-info@1.3.0 /opt/iobroker/node_modules/node-disk-info
    npm ERR! extraneous: node-red-admin@ /opt/iobroker/node_modules/node-red-admin
    npm ERR! extraneous: node-red-contrib-aggregator@2.0.0 /opt/iobroker/node_modules/node-red-contrib-aggregator
    npm ERR! extraneous: node-red-contrib-os@0.2.1 /opt/iobroker/node_modules/node-red-contrib-os
    npm ERR! extraneous: node-red-contrib-polymer@0.0.22 /opt/iobroker/node_modules/node-red-contrib-polymer
    npm ERR! extraneous: node-red-dashboard@ /opt/iobroker/node_modules/node-red-dashboard
    npm ERR! extraneous: node-red-node-email@2.1.0 /opt/iobroker/node_modules/node-red-node-email
    npm ERR! extraneous: node-red-node-feedparser@0.3.0 /opt/iobroker/node_modules/node-red-node-feedparser
    npm ERR! extraneous: node-red-node-sentiment@0.1.6 /opt/iobroker/node_modules/node-red-node-sentiment
    npm ERR! extraneous: node-red-node-twitter@1.2.0 /opt/iobroker/node_modules/node-red-node-twitter
    npm ERR! extraneous: node-red@ /opt/iobroker/node_modules/node-red
    npm ERR! extraneous: node-watch@ /opt/iobroker/node_modules/node-watch
    npm ERR! extraneous: nopt@5.0.0 /opt/iobroker/node_modules/nopt
    npm ERR! extraneous: oauth@0.10.0 /opt/iobroker/node_modules/oauth
    npm ERR! extraneous: oauth2orize@1.11.1 /opt/iobroker/node_modules/oauth2orize
    npm ERR! extraneous: object-component@0.0.3 /opt/iobroker/node_modules/object-component
    npm ERR! extraneous: options@0.0.6 /opt/iobroker/node_modules/options
    npm ERR! extraneous: parsejson@0.0.3 /opt/iobroker/node_modules/parsejson
    npm ERR! extraneous: passport-http-bearer@1.0.1 /opt/iobroker/node_modules/passport-http-bearer
    npm ERR! extraneous: passport-oauth2-client-password@0.1.2 /opt/iobroker/node_modules/passport-oauth2-client-password
    npm ERR! extraneous: pseudomap@1.0.2 /opt/iobroker/node_modules/pseudomap
    npm ERR! extraneous: sentiment@2.1.0 /opt/iobroker/node_modules/sentiment
    npm ERR! extraneous: simple-statistics@2.5.0 /opt/iobroker/node_modules/simple-statistics
    npm ERR! extraneous: sparse-bitfield@3.0.3 /opt/iobroker/node_modules/sparse-bitfield
    npm ERR! extraneous: tar@ /opt/iobroker/node_modules/tar
    npm ERR! extraneous: twitter-ng@0.6.2 /opt/iobroker/node_modules/twitter-ng
    npm ERR! extraneous: uglify-js@ /opt/iobroker/node_modules/uglify-js
    npm ERR! extraneous: uid2@0.0.4 /opt/iobroker/node_modules/uid2
    npm ERR! extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
    npm ERR! extraneous: wtf-8@1.0.0 /opt/iobroker/node_modules/wtf-8
    npm ERR! extraneous: xmlcreate@2.0.4 /opt/iobroker/node_modules/xmlcreate
    npm ERR! extraneous: tslib@ /opt/iobroker/node_modules/@emnapi/core/node_modules/tslib
    npm ERR! extraneous: tslib@ /opt/iobroker/node_modules/@emnapi/runtime/node_modules/tslib
    npm ERR! extraneous: bcrypt@ /opt/iobroker/node_modules/@node-red/editor-api/node_modules/bcrypt
    npm ERR! extraneous: body-parser@ /opt/iobroker/node_modules/@node-red/editor-api/node_modules/body-parser
    npm ERR! extraneous: mime@ /opt/iobroker/node_modules/@node-red/editor-api/node_modules/mime
    npm ERR! extraneous: node-addon-api@ /opt/iobroker/node_modules/@node-red/editor-api/node_modules/node-addon-api
    npm ERR! extraneous: raw-body@2.5.2 /opt/iobroker/node_modules/@node-red/editor-api/node_modules/raw-body
    npm ERR! extraneous: @sindresorhus/is@ /opt/iobroker/node_modules/@node-red/nodes/node_modules/@sindresorhus/is
    npm ERR! extraneous: @szmarczak/http-timer@5.0.1 /opt/iobroker/node_modules/@node-red/nodes/node_modules/@szmarczak/http-timer
    npm ERR! extraneous: ajv@ /opt/iobroker/node_modules/@node-red/nodes/node_modules/ajv
    npm ERR! extraneous: body-parser@ /opt/iobroker/node_modules/@node-red/nodes/node_modules/body-parser
    npm ERR! extraneous: cacheable-lookup@7.0.0 /opt/iobroker/node_modules/@node-red/nodes/node_modules/cacheable-lookup
    npm ERR! extraneous: cacheable-request@ /opt/iobroker/node_modules/@node-red/nodes/node_modules/cacheable-request
    npm ERR! extraneous: fs-extra@ /opt/iobroker/node_modules/@node-red/nodes/node_modules/fs-extra
    npm ERR! extraneous: get-stream@6.0.1 /opt/iobroker/node_modules/@node-red/nodes/node_modules/get-stream
    npm ERR! extraneous: got@ /opt/iobroker/node_modules/@node-red/nodes/node_modules/got
    npm ERR! extraneous: http2-wrapper@ /opt/iobroker/node_modules/@node-red/nodes/node_modules/http2-wrapper
    npm ERR! extraneous: lowercase-keys@3.0.0 /opt/iobroker/node_modules/@node-red/nodes/node_modules/lowercase-keys
    npm ERR! extraneous: mimic-response@4.0.0 /opt/iobroker/node_modules/@node-red/nodes/node_modules/mimic-response
    npm ERR! extraneous: normalize-url@8.0.0 /opt/iobroker/node_modules/@node-red/nodes/node_modules/normalize-url
    npm ERR! extraneous: p-cancelable@3.0.0 /opt/iobroker/node_modules/@node-red/nodes/node_modules/p-cancelable
    npm ERR! extraneous: raw-body@2.5.2 /opt/iobroker/node_modules/@node-red/nodes/node_modules/raw-body
    npm ERR! extraneous: responselike@3.0.0 /opt/iobroker/node_modules/@node-red/nodes/node_modules/responselike
    npm ERR! extraneous: tough-cookie@ /opt/iobroker/node_modules/@node-red/nodes/node_modules/tough-cookie
    npm ERR! extraneous: uuid@ /opt/iobroker/node_modules/@node-red/nodes/node_modules/uuid
    npm ERR! extraneous: fs-extra@ /opt/iobroker/node_modules/@node-red/registry/node_modules/fs-extra
    npm ERR! extraneous: fs-extra@ /opt/iobroker/node_modules/@node-red/runtime/node_modules/fs-extra
    npm ERR! extraneous: fs-extra@ /opt/iobroker/node_modules/@node-red/util/node_modules/fs-extra
    npm ERR! extraneous: tslib@ /opt/iobroker/node_modules/@tybys/wasm-util/node_modules/tslib
    npm ERR! extraneous: tslib@ /opt/iobroker/node_modules/async-mutex/node_modules/tslib
    npm ERR! extraneous: safe-buffer@5.1.2 /opt/iobroker/node_modules/basic-auth/node_modules/safe-buffer
    npm ERR! extraneous: node-addon-api@ /opt/iobroker/node_modules/bcrypt/node_modules/node-addon-api
    npm ERR! extraneous: isarray@1.0.0 /opt/iobroker/node_modules/feedparser/node_modules/isarray
    npm ERR! extraneous: readable-stream@2.3.7 /opt/iobroker/node_modules/feedparser/node_modules/readable-stream
    npm ERR! extraneous: safe-buffer@5.1.2 /opt/iobroker/node_modules/feedparser/node_modules/safe-buffer
    npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/feedparser/node_modules/string_decoder
    npm ERR! extraneous: async@0.1.22 /opt/iobroker/node_modules/fs.notify/node_modules/async
    npm ERR! extraneous: retry@0.6.1 /opt/iobroker/node_modules/fs.notify/node_modules/retry
    npm ERR! invalid: xml2js@ /opt/iobroker/node_modules/xml2js
    npm ERR! extraneous: @iobroker/adapter-core@ /opt/iobroker/node_modules/iobroker.node-red/node_modules/@iobroker/adapter-core
    npm ERR! extraneous: gaxios@ /opt/iobroker/node_modules/iobroker.node-red/node_modules/gaxios
    npm ERR! extraneous: gcp-metadata@ /opt/iobroker/node_modules/iobroker.node-red/node_modules/gcp-metadata
    npm ERR! extraneous: mongodb@ /opt/iobroker/node_modules/iobroker.node-red/node_modules/mongodb
    npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/memorystore/node_modules/debug
    npm ERR! extraneous: lru-cache@4.1.5 /opt/iobroker/node_modules/memorystore/node_modules/lru-cache
    npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/memorystore/node_modules/ms
    npm ERR! extraneous: yallist@2.1.2 /opt/iobroker/node_modules/memorystore/node_modules/yallist
    npm ERR! extraneous: tr46@ /opt/iobroker/node_modules/mongodb-connection-string-url/node_modules/tr46
    npm ERR! extraneous: whatwg-url@ /opt/iobroker/node_modules/mongodb-connection-string-url/node_modules/whatwg-url
    npm ERR! extraneous: iconv-lite@0.6.3 /opt/iobroker/node_modules/node-disk-info/node_modules/iconv-lite
    npm ERR! extraneous: accepts@1.3.3 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/accepts
    npm ERR! extraneous: arraybuffer.slice@0.0.6 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/arraybuffer.slice
    npm ERR! extraneous: base64-arraybuffer@0.1.5 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/base64-arraybuffer
    npm ERR! extraneous: base64id@1.0.0 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/base64id
    npm ERR! extraneous: blob@0.0.4 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/blob
    npm ERR! extraneous: component-emitter@1.1.2 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/component-emitter
    npm ERR! extraneous: cookie@0.3.1 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/cookie
    npm ERR! extraneous: debug@2.3.3 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/debug
    npm ERR! extraneous: engine.io-client@1.8.6 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/engine.io-client
    npm ERR! extraneous: engine.io-parser@1.3.2 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/engine.io-parser
    npm ERR! extraneous: engine.io@1.8.5 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/engine.io
    npm ERR! extraneous: ms@0.7.2 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/ms
    npm ERR! extraneous: negotiator@0.6.1 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/negotiator
    npm ERR! extraneous: object-assign@4.1.0 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/object-assign
    npm ERR! extraneous: parseqs@0.0.5 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/parseqs
    npm ERR! extraneous: parseuri@0.0.5 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/parseuri
    npm ERR! extraneous: socket.io-adapter@0.5.0 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/socket.io-adapter
    npm ERR! extraneous: socket.io-client@1.7.4 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/socket.io-client
    npm ERR! extraneous: socket.io-parser@2.3.1 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/socket.io-parser
    npm ERR! extraneous: socket.io@1.7.4 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/socket.io
    npm ERR! extraneous: ultron@1.0.2 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/ultron
    npm ERR! extraneous: ws@1.1.5 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/ws
    npm ERR! extraneous: debug@ /opt/iobroker/node_modules/node-red-dashboard/node_modules/debug
    npm ERR! extraneous: engine.io-parser@ /opt/iobroker/node_modules/node-red-dashboard/node_modules/engine.io-parser
    npm ERR! extraneous: engine.io@ /opt/iobroker/node_modules/node-red-dashboard/node_modules/engine.io
    npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/node-red-dashboard/node_modules/ms
    npm ERR! extraneous: socket.io@ /opt/iobroker/node_modules/node-red-dashboard/node_modules/socket.io
    npm ERR! extraneous: @selderee/plugin-htmlparser2@0.11.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/@selderee/plugin-htmlparser2
    npm ERR! extraneous: base32.js@0.1.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/base32.js
    npm ERR! extraneous: core-util-is@1.0.3 /opt/iobroker/node_modules/node-red-node-email/node_modules/core-util-is
    npm ERR! extraneous: deepmerge@4.3.1 /opt/iobroker/node_modules/node-red-node-email/node_modules/deepmerge
    npm ERR! extraneous: dom-serializer@2.0.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/dom-serializer
    npm ERR! extraneous: domelementtype@2.3.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/domelementtype
    npm ERR! extraneous: domhandler@5.0.3 /opt/iobroker/node_modules/node-red-node-email/node_modules/domhandler
    npm ERR! extraneous: domutils@3.1.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/domutils
    npm ERR! extraneous: encoding-japanese@2.0.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese
    npm ERR! extraneous: entities@4.5.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/entities
    npm ERR! extraneous: he@1.2.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/he
    npm ERR! extraneous: html-to-text@9.0.5 /opt/iobroker/node_modules/node-red-node-email/node_modules/html-to-text
    npm ERR! extraneous: htmlparser2@8.0.2 /opt/iobroker/node_modules/node-red-node-email/node_modules/htmlparser2
    npm ERR! extraneous: iconv-lite@0.6.3 /opt/iobroker/node_modules/node-red-node-email/node_modules/iconv-lite
    npm ERR! extraneous: imap@0.8.19 /opt/iobroker/node_modules/node-red-node-email/node_modules/imap
    npm ERR! extraneous: inherits@2.0.4 /opt/iobroker/node_modules/node-red-node-email/node_modules/inherits
    npm ERR! extraneous: ipv6-normalize@1.0.1 /opt/iobroker/node_modules/node-red-node-email/node_modules/ipv6-normalize
    npm ERR! extraneous: isarray@0.0.1 /opt/iobroker/node_modules/node-red-node-email/node_modules/isarray
    npm ERR! extraneous: leac@0.6.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/leac
    npm ERR! extraneous: libbase64@1.2.1 /opt/iobroker/node_modules/node-red-node-email/node_modules/libbase64
    npm ERR! extraneous: libmime@5.2.1 /opt/iobroker/node_modules/node-red-node-email/node_modules/libmime
    npm ERR! extraneous: libqp@2.0.1 /opt/iobroker/node_modules/node-red-node-email/node_modules/libqp
    npm ERR! extraneous: linkify-it@4.0.1 /opt/iobroker/node_modules/node-red-node-email/node_modules/linkify-it
    npm ERR! extraneous: mailparser@3.6.5 /opt/iobroker/node_modules/node-red-node-email/node_modules/mailparser
    npm ERR! extraneous: mailsplit@5.4.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/mailsplit
    npm ERR! extraneous: node-pop3@0.9.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/node-pop3
    npm ERR! extraneous: nodemailer@6.9.7 /opt/iobroker/node_modules/node-red-node-email/node_modules/nodemailer
    npm ERR! extraneous: parseley@0.12.1 /opt/iobroker/node_modules/node-red-node-email/node_modules/parseley
    npm ERR! extraneous: peberminta@0.9.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/peberminta
    npm ERR! extraneous: readable-stream@1.1.14 /opt/iobroker/node_modules/node-red-node-email/node_modules/readable-stream
    npm ERR! extraneous: safer-buffer@2.1.2 /opt/iobroker/node_modules/node-red-node-email/node_modules/safer-buffer
    npm ERR! extraneous: selderee@0.11.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/selderee
    npm ERR! extraneous: semver@5.3.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/semver
    npm ERR! extraneous: smtp-server@3.13.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/smtp-server
    npm ERR! extraneous: string_decoder@0.10.31 /opt/iobroker/node_modules/node-red-node-email/node_modules/string_decoder
    npm ERR! extraneous: tlds@1.240.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/tlds
    npm ERR! extraneous: uc.micro@1.0.6 /opt/iobroker/node_modules/node-red-node-email/node_modules/uc.micro
    npm ERR! extraneous: utf7@1.0.2 /opt/iobroker/node_modules/node-red-node-email/node_modules/utf7
    npm ERR! extraneous: bcrypt@ /opt/iobroker/node_modules/node-red/node_modules/bcrypt
    npm ERR! extraneous: fs-extra@ /opt/iobroker/node_modules/node-red/node_modules/fs-extra
    npm ERR! extraneous: node-addon-api@ /opt/iobroker/node_modules/node-red/node_modules/node-addon-api
    npm ERR! extraneous: minipass@ /opt/iobroker/node_modules/tar/node_modules/minipass
    npm ERR! extraneous: iconv-lite@0.4.24 /opt/iobroker/node_modules/@node-red/nodes/node_modules/raw-body/node_modules/iconv-lite
    npm ERR! extraneous: universalify@0.2.0 /opt/iobroker/node_modules/@node-red/nodes/node_modules/tough-cookie/node_modules/universalify
    npm ERR! invalid: @mapbox/node-pre-gyp@ /opt/iobroker/node_modules/@mapbox/node-pre-gyp
    npm ERR! invalid: moment-timezone@ /opt/iobroker/node_modules/moment-timezone
    npm ERR! extraneous: component-emitter@1.2.1 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/engine.io-client/node_modules/component-emitter
    npm ERR! extraneous: component-emitter@1.2.1 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/socket.io-client/node_modules/component-emitter
    npm ERR! extraneous: debug@2.2.0 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/socket.io-parser/node_modules/debug
    npm ERR! extraneous: ms@0.7.1 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/socket.io-parser/node_modules/ms
    npm ERR! extraneous: nodemailer@6.9.3 /opt/iobroker/node_modules/node-red-node-email/node_modules/mailparser/node_modules/nodemailer
    npm ERR! extraneous: libmime@5.2.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/mailsplit/node_modules/libmime
    npm ERR! extraneous: nodemailer@6.9.4 /opt/iobroker/node_modules/node-red-node-email/node_modules/smtp-server/node_modules/nodemailer
    npm ERR! invalid: fsevents@ /opt/iobroker/node_modules/fsevents
    npm ERR! invalid: @node-rs/jieba-android-arm-eabi@ /opt/iobroker/node_modules/@node-rs/jieba-android-arm-eabi
    npm ERR! invalid: @node-rs/jieba-android-arm64@ /opt/iobroker/node_modules/@node-rs/jieba-android-arm64
    npm ERR! invalid: @node-rs/jieba-darwin-arm64@ /opt/iobroker/node_modules/@node-rs/jieba-darwin-arm64
    npm ERR! invalid: @node-rs/jieba-darwin-x64@ /opt/iobroker/node_modules/@node-rs/jieba-darwin-x64
    npm ERR! invalid: @node-rs/jieba-freebsd-x64@ /opt/iobroker/node_modules/@node-rs/jieba-freebsd-x64
    npm ERR! invalid: @node-rs/jieba-linux-arm64-gnu@ /opt/iobroker/node_modules/@node-rs/jieba-linux-arm64-gnu
    npm ERR! invalid: @node-rs/jieba-linux-arm64-musl@ /opt/iobroker/node_modules/@node-rs/jieba-linux-arm64-musl
    npm ERR! invalid: @node-rs/jieba-linux-x64-gnu@ /opt/iobroker/node_modules/@node-rs/jieba-linux-x64-gnu
    npm ERR! invalid: @node-rs/jieba-linux-x64-musl@ /opt/iobroker/node_modules/@node-rs/jieba-linux-x64-musl
    npm ERR! invalid: @node-rs/jieba-wasm32-wasi@ /opt/iobroker/node_modules/@node-rs/jieba-wasm32-wasi
    npm ERR! invalid: @node-rs/jieba-win32-arm64-msvc@ /opt/iobroker/node_modules/@node-rs/jieba-win32-arm64-msvc
    npm ERR! invalid: @node-rs/jieba-win32-ia32-msvc@ /opt/iobroker/node_modules/@node-rs/jieba-win32-ia32-msvc
    npm ERR! invalid: @node-rs/jieba-win32-x64-msvc@ /opt/iobroker/node_modules/@node-rs/jieba-win32-x64-msvc
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-02-01T09_34_50_992Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.19.0
    Core adapters versions
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.19.0
    js-controller:
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.19.0
    admin:
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.19.0
    javascript:
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-02-01T09_35_04_737Z-debug-0.log
    Adapters from github:   0
    Adapter State
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.19.0
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.19.0
    ioBroker-Repositories
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.19.0
    Installed ioBroker-Instances
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.19.0
    Objects and States
    Objects:        0
    States:         0
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-backports InRelease
    Hit:4 http://deb.debian.org/debian bullseye-proposed-updates InRelease
    Hit:5 https://repos.influxdata.com/debian stable InRelease
    Hit:6 https://repos.influxdata.com/debian bullseye InRelease
    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
    Hit:8 https://apt.pivccu.de/piVCCU stable InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          15401      926/dnsmasq
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          43890      7048/sshd: /usr/sbi
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      998        13284      845/influxd
    tcp6       0      0 :::51216                :::*                    LISTEN      999        16741      1759/homebridge
    tcp6       0      0 :::22                   :::*                    LISTEN      0          43892      7048/sshd: /usr/sbi
    tcp6       0      0 :::8581                 :::*                    LISTEN      999        15845      1564/hb-service
    tcp6       0      0 :::8086                 :::*                    LISTEN      998        16514      845/influxd
    udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          15400      926/dnsmasq
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          15397      926/dnsmasq
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          772        724/dhclient
    udp        0      0 0.0.0.0:41549           0.0.0.0:*                           108        12903      463/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           999        16742      1759/homebridge
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           999        15842      1564/hb-service
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12901      463/avahi-daemon: r
    udp6       0      0 :::33747                :::*                                108        12904      463/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        12902      463/avahi-daemon: r
    2024-02-01 08:59:03.012  - info: host.raspberrypi instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
    2024-02-01 08:59:03.012  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
    2024-02-01 08:59:03.365  - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2024-02-01 08:59:03.365  - error: host.raspberrypi Caught by controller[0]: Error: DB closed
    2024-02-01 08:59:03.365  - error: host.raspberrypi Caught by controller[0]:     at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
    2024-02-01 08:59:03.366  - error: host.raspberrypi Caught by controller[0]:     at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
    2024-02-01 08:59:03.366  - error: host.raspberrypi Caught by controller[0]:     at Object.onceWrapper (node:events:629:26)
    2024-02-01 08:59:03.366  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:events:514:28)
    2024-02-01 08:59:03.366  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:domain:489:12)
    2024-02-01 08:59:03.366  - error: host.raspberrypi Caught by controller[0]:     at TCP.<anonymous> (node:net:323:12)
    2024-02-01 08:59:03.366  - info: host.raspberrypi instance system.adapter.shelly.0 terminated with code 0 (NO_ERROR)
    2024-02-01 08:59:03.368  - info: host.raspberrypi instance system.adapter.jarvis.0 terminated with code 0 (NO_ERROR)
    2024-02-01 08:59:03.369  - warn: host.raspberrypi instance system.adapter.hm-rega.0 terminated due to SIGTERM
    2024-02-01 08:59:03.369  - info: host.raspberrypi instance system.adapter.hm-rega.0 terminated with code null ()
    2024-02-01 08:59:03.369  - warn: host.raspberrypi instance system.adapter.zigbee.0 terminated due to SIGTERM
    2024-02-01 08:59:03.369  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code null ()
    2024-02-01 08:59:03.442  - warn: host.raspberrypi instance system.adapter.psa.0 terminated due to SIGTERM
    2024-02-01 08:59:03.442  - info: host.raspberrypi instance system.adapter.psa.0 terminated with code null ()
    2024-02-01 08:59:03.443  - warn: host.raspberrypi instance system.adapter.telegram.0 terminated due to SIGTERM
    2024-02-01 08:59:03.443  - info: host.raspberrypi instance system.adapter.telegram.0 terminated with code null ()
    2024-02-01 08:59:03.443  - warn: host.raspberrypi instance system.adapter.web.0 terminated due to SIGTERM
    2024-02-01 08:59:03.443  - info: host.raspberrypi instance system.adapter.web.0 terminated with code null ()
    2024-02-01 08:59:03.511  - info: host.raspberrypi instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
    2024-02-01 08:59:03.511  - info: host.raspberrypi All instances are stopped.
    2024-02-01 08:59:03.725  - info: host.raspberrypi terminated
                            v.2023-10-10
             Icon name: computer
          Architecture: arm
    Kernel:                 armv7l
    Userland:               armhf
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.19.0
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                            /usr/bin/npm            10.2.3
                            /usr/bin/npx            10.2.3
    Recommended versions are nodejs  and npm
    MEMORY:
    Mem:            1.9G        571M        628M        0.0K        670M        1.3G
    Swap:            99M        1.0M         98M
    Total:          2.0G        572M        727M
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.19.0
    Active iob-Instances:   0
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.19.0
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.19.0
    ioBroker Core:          js-controller
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.19.0
                            admin
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.19.0
    ioBroker Status:
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.19.0
    Objects:                0
    States:                 0
    Size of iob-Database:
    7.3M    /opt/iobroker/iobroker-data/objects.jsonl
    4.6M    /opt/iobroker/iobroker-data/objects.json.migrated
    4.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    912K    /opt/iobroker/iobroker-data/states.jsonl
    540K    /opt/iobroker/iobroker-data/states.json.migrated
    540K    /opt/iobroker/iobroker-data/states.json.bak.migrated
    Auf dem RaspberryPi läuft zusätzlich noch eine pivccu, diese funktioniert ohne Probleme. Backups vom Zustand vor den Updates sind vorhanden. Ich habe diese testweise in einer iobroker proxmoxx Installation eingespielt, hierbei kam es zu keinen Fehlern.
    Kann ich die aktuelle Installation retten oder komme ich um eine (komplette) Neuinstalltion nicht herum?
    • arteckA Offline
      arteckA Offline
      arteck
      machmal
      iob fix
      • T ThoHilde
         throw err;
        Require stack:
         requireStack: [
        Node.js v18.19.0
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm
        Docker          : false
        Kernel          : armv7l
        Userland        : armhf
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M        1.0M         98M
                 1870 M total memory
                  573 M used memory
                  208 M active memory
                  804 M free memory
                  100 M buffer memory
                  392 M swap cache
                   99 M total swap
                    1 M used swap
                   98 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        4.3G    /var/
        3.1G    /var/log
        852M    /var/lib
        USB-Devices by-id:
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.0
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.0
        js-controller:
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.0
        admin:
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.0
        javascript:
        Adapter State
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.0
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.0
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.0
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.0
        Objects and States
        Objects:        0
        States:         0
        Pending Updates: 0
                                v.2023-10-10
                 Icon name: computer
              Architecture: arm
        Kernel:                 armv7l
        Userland:               armhf
        User-ID:                1000
        X-Server:               false
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.0
                                /usr/bin/npm            10.2.3
                                /usr/bin/npx            10.2.3
        MEMORY:
        Swap:            99M        1.0M         98M
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.0
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.0
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.0
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.0
                                admin
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.0
        ioBroker Status:
          throw err;
        Require stack:
          requireStack: [
        Node.js v18.19.0
        Objects:                0
        States:                 0
        @thohilde sagte in Error: Cannot find module 'tar' - iobroker nicht erreichbar:
        Strom-weg-Exekution? Dein Dateisystem hat jetzt Lücken.
        Wenn der fixer nicht zum Erfolg führt versuch:
        cd /opt/iobroker
        sudo -H -u iobroker npm install iobroker.js-controller
        Und dann installier den
        node-red-Adapter nochmal neu.
          cd /opt/iobroker
          ThoHilde
          @thomas-braun Danke! Funktioniert wieder. Ich komme auf die weboberfläche und konnte nodered darüber installieren. Update wurde mir dort angezeigt.
          Bezüglich Strom-weg: am Pi ist eine SSD angeschlossen. Dies lief bisher ohne Probleme, aber werde ich beobachten, ob der Hardwareadapter oder die SSD vielleicht einen Fehler haben.
          @arteck iob fix hatte ich als erstes versucht. Leider ohne Erfolg.
          • T ThoHilde
            Wenn die inodes bei einem sauberen Reboot / nach einem ordentlichen ShutDown gelöscht werden mussten, dann ist die SD-Karte definitiv fällig...
            iob diag
            sagt?
            • T ThoHilde
              ist das Netzteil dafür stark genug?
                Ja, scheint stark genug zu sein:
                Current issues:
