  4. (Gelöst)Pegelalarm zeigt angelegte Stationen nicht an
11 Beiträge 5 Kommentatoren 949 Aufrufe 4 Beobachtet
  • Damrak2022D Damrak2022
    Bei mir habe ich das Problem, das Pegelalarm mir von den 4 angelegten Stationen nur eine anzeigt.
    Anbei der Debug Log
    host.homebridge
    2022-08-15 18:53:24.955	info	instance system.adapter.pegelalarm.0 terminated with code 0 (NO_ERROR)
    pegelalarm.0
    2022-08-15 18:53:24.351	info	Terminated (NO_ERROR): Without reason
    pegelalarm.0
    2022-08-15 18:53:24.350	debug	Plugin sentry destroyed
    pegelalarm.0
    2022-08-15 18:53:24.341	debug	cleaned everything up...
    pegelalarm.0
    2022-08-15 18:53:24.176	debug	Check for deleting old states is started
    pegelalarm.0
    2022-08-15 18:53:24.175	debug	Pegelalarm Request is completed
    pegelalarm.0
    2022-08-15 18:53:23.174	debug	Pegelalarm request for measuring station 4 is finish ...
    pegelalarm.0
    2022-08-15 18:53:23.173	debug	Pegelalarm request done
    mihome-vacuum.0
    2022-08-15 18:53:22.820	warn	CANVAS package not installed....please install Canvas package manually or disable Map in config see also https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/blob/master/lib/canvaserror.md
    pegelalarm.0
    2022-08-15 18:53:20.906	debug	Pegelalarm API is available ... Status: 200
    pegelalarm.0
    2022-08-15 18:53:20.807	debug	https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Trave&qWater=Trave&qStationName=Travem%C3%BCnde
    pegelalarm.0
    2022-08-15 18:53:20.806	debug	Pegelalarm request for measuring station 4 is started ...
    pegelalarm.0
    2022-08-15 18:53:19.804	debug	Pegelalarm request for measuring station 3 is finish ...
    pegelalarm.0
    2022-08-15 18:53:19.803	debug	Pegelalarm request done
    pegelalarm.0
    2022-08-15 18:53:19.678	debug	Pegelalarm API is available ... Status: 200
    pegelalarm.0
    2022-08-15 18:53:19.589	debug	https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Trave&qWater=Trave&qStationName=L%C3%BCbeck-Moisling
    pegelalarm.0
    2022-08-15 18:53:19.588	debug	Pegelalarm request for measuring station 3 is started ...
    pegelalarm.0
    2022-08-15 18:53:18.588	debug	Pegelalarm request for measuring station 2 is finish ...
    pegelalarm.0
    2022-08-15 18:53:18.586	debug	Pegelalarm request done
    pegelalarm.0
    2022-08-15 18:53:18.375	debug	Pegelalarm API is available ... Status: 200
    pegelalarm.0
    2022-08-15 18:53:18.286	debug	https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Rhein&qWater=Rhein%20(Rhin,%20Rijn)&qStationName=Bingen
    pegelalarm.0
    2022-08-15 18:53:18.286	debug	Pegelalarm request for measuring station 2 is started ...
    Hat jemand eine Idee wie ich das behebe?
    arteckA Offline
    arteckA Offline
    arteck
    @damrak2022 sagte in Pegelalarm zeigt angelegte Stationen nicht an:
    https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Rhein&qWater=Rhein (Rhin, Rijn)&qStationName=Bingen
    ruf doch den link selber auf und schaue was da rauskommt..
    jier bei dem kommt nix.. da wird nix geliefert
    bei dem hier
    https://api.pegelalarm.at/api/station/1.0/list?countryCode=DE&qRegion=Trave&qWater=Trave&qStationName=Travemünde
    schon
      Anbei der Debug Log
      host.homebridge
      pegelalarm.0
      pegelalarm.0
      pegelalarm.0
      pegelalarm.0
      pegelalarm.0
      pegelalarm.0
      pegelalarm.0
      mihome-vacuum.0
      pegelalarm.0
      pegelalarm.0
      pegelalarm.0
      pegelalarm.0
      pegelalarm.0
      pegelalarm.0
      pegelalarm.0
      pegelalarm.0
      pegelalarm.0
      pegelalarm.0
      pegelalarm.0
      pegelalarm.0
      pegelalarm.0
      NegaleinN Offline
      NegaleinN Offline
      Negalein
      zeig mal Screenshots deiner Konfig.
      ° Fixer ---> iob fix
      • NegaleinN Negalein
        Damrak2022D Offline
        Damrak2022D Offline
        Damrak2022
        @negalein Welche Konfiguration meinstDu, die des Adapters?
        So sehen auf jeden Fall meine Objekte aus, obwohl ich 4 Stationen angelegt habe, wird ir unter den Objekten nur eine angezeigt.
        Angelegt habe ich:
        Region Main - Wasser Main - Stationsname Frankfurt Osthafen
        Region Rhein - Wasser Rhein - Stationsname Bingen
        Region Trave - Wasser Trave - Stationsname Lübeck-Moisling
        Region Trave - Wasser Trave - Stationsname Travemünde
        Selbst wenn Bingen keine Daten liefert, wie Du schreibst, so müssten doch zumindest die Stationsnamen unter Objekten angelegt werden, oder?
        Mit besten Grüßen
        Andy
          Angelegt habe ich:
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          @damrak2022 Der Adapter holt sich die Daten von den Stationen.
          @arteck sagte in Pegelalarm zeigt angelegte Stationen nicht an:
          Warum ? Der Adapter wird so programmiert sein dass nur wenn Daten kommen auch Ordner und DPs angelegt werden ?
          Lehrling seit 1975 !!!
          • DJMarc75D DJMarc75
            Damrak2022D Offline
            Damrak2022D Offline
            Damrak2022
            @djmarc75 Ja, das könnte natürlich sein. Ich wusste nicht das man das so machen kann.
            Mit besten Grüßen
            Andy
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
                Damrak2022D Offline
                Damrak2022D Offline
                Damrak2022
                @djmarc75 so programmieren kann
                Mit besten Grüßen
                Andy
                  Damrak2022D Offline
                  Damrak2022D Offline
                  Damrak2022
                  @djmarc75 Weißt Du zufällig was beim Main die Bezeichnung Griesheim_op und Griesheim_up bedeutet.
                  Mit besten Grüßen
                  Andy
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    Na ich schätze dass das 2 verschiedene Stationen sind?!
                    Ich kenne den Adapter nicht.
                      Tontechniker
                      Ich habe seit einiger Zeit Probleme mit der Anzeige von zwei Stationen.
                      Habe den Adapter gelöscht und neu installiert mit dem gleichen Ergebnis.
                      Das Problem trat nach einem Versionswechsel auf. Früher habe ich als Region "Hessen" eingegeben. Wenn ich das jetzt tue ist der Fluss Fulda nicht mehr aufgelistet. Meine jetzige Version ist V1.3.2.
                      Kann mir jemand sagen, woran das liegt?
