  4. iobroker + docker + MACVLAN - fixe IP für bridge möglich ?
36 Beiträge 7 Kommentatoren 5.2k Aufrufe 6 Beobachtet
  • stephan1827S Offline
    stephan1827
    So ich habe jetzt mal parallel einen docker mit macvlan neu aufgesetzt und der läuft einwandfrei bis ich die Backup wieder herstelle. Danach habe ich wieder das gleiche Problem wie vorher. Ich habe darauf geachtet das npm, node und js controller die gleiche Version haben wie vorher.
    strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/certificatesProps" (strictTypes)
    strict mode: missing type "object" for keyword "properties" at "#/definitions/certificatesProps" (strictTypes)
    strict mode: missing type "object" for keyword "required" at "#/definitions/instanceProps" (strictTypes)
    strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/instanceProps" (strictTypes)
    strict mode: missing type "object" for keyword "properties" at "#/definitions/instanceProps" (strictTypes)
    strict mode: missing type "object" for keyword "required" at "#/definitions/objectIdProps" (strictTypes)
    strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/objectIdProps" (strictTypes)
    strict mode: missing type "object" for keyword "properties" at "#/definitions/objectIdProps" (strictTypes)
    ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
    ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
    Terminated
    -------------------------     2024-01-20 12:33:53      -------------------------
    -----              Welcome to your ioBroker Docker container!              -----
    -----                    Startupscript is now running!                     -----
    -----                          Please be patient!                          -----
    -----                          System Information                          -----
    -----                    arch:                x86_64                       -----
    -----                    hostname:            iobroker                     -----
    -----                          Version Information                         -----
    -----                    image:               v9.1.0                       -----
    -----                    build:               2024-01-19T13:46:03+00:00    -----
    -----                    node:                v18.19.0                     -----
    -----                    npm:                 9.2.0                        -----
    -----                        Environment Variables                         -----
    -----                    DEBUG:               true                         -----
    -----                    SETGID:              1000                         -----
    -----                    SETUID:              1000                         -----
    !!!!                            DEBUG LOG ACTIVE                            !!!!
    !!!!               Environment variable DEBUG is set to true.               !!!!
    !!!! This will extend the logging output and may slow down container start. !!!!
    !!!!          Please make sure to deactivate if no longer needed.           !!!!
    !!!!     For more information see ioBroker Docker image documentation:      !!!!
    !!!!           https://docs.buanet.de/iobroker-docker-image/docs/           !!!!
    -----                   Step 1 of 5: Preparing Container                   -----
    This is not the first run of this container. Skipping first run preparation.
    -----             Step 2 of 5: Detecting ioBroker Installation             -----
    Existing installation of ioBroker detected in "/opt/iobroker".
    -----             Step 3 of 5: Checking ioBroker Installation              -----
    (Re)setting permissions (This might take a while! Please be patient!)... Done.
    [DEBUG] Checking multihost settings...
    [DEBUG] No multihost settings detected.
    [DEBUG] Done.
    [DEBUG] Checking custom objects db settings...
    [DEBUG] No custom objects db settings detected.
    [DEBUG] Done.
    [DEBUG] Checking custom states db settings...
    [DEBUG] No custom states db settings detected.
    [DEBUG] Done.
    Checking database connection... Failed.
    [DEBUG] Error message:
    [DEBUG] No connection to databases possible ...
    Please check your configuration and try again.
    For more information see ioBroker Docker image docs (https://docs.buanet.de/iobroker-docker-image/docs).
    [DEBUG] Debug mode prevents the container from exiting on errors.
    [DEBUG] This enables you to investigate or fix your issue on the command line.
    [DEBUG] If you want to stop or restart your container you have to do it manually.
    [DEBUG] IoBroker is not running!
    • stephan1827S stephan1827
      @marc-berg anscheinend kann der container sich nicht mehr mit der Datenbank verbinden, das verstehe ich nicht denn die Datenbank ist die interne von iobroker
      -------------------------     2024-01-19 18:54:37      -------------------------
      [DEBUG] Done.
      [DEBUG] Done.
      [DEBUG] Done.
      GlasfaserG Offline
      GlasfaserG Offline
      @stephan1827 sagte in iobroker + docker + MACVLAN - fixe IP für bridge möglich ?:
      Neuer Container !
      image: v9.1.0
      da passt was nicht zusammen ...
      ich wette du hast diesen Fehler vorhanden :
      https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur
      Schau nach mit
      iob diag
      da kommt bestimmt das raus :
      NodeJS-Installation
      usrbinnodejs v18.19.0
      usrbinnode v18.19.0
      usrbinnpm 9.2.0
      usrbinnpx 9.2.0
      homeiobroker.diag.sh line 281 corepack command not found
      nodejs is NOT correctly installed
      nodejs
      Installed 18.19.0+dfsg-6~deb12u1
      Candidate 18.19.0+dfsg-6~deb12u1
      Version table
      18.19.0+dfsg-6~deb12u1 500
      500 httpdeb.debian.orgdebian-security bookworm-securitymain amd64 Packages
      100 varlibdpkgstatus
      18.19.0-1nodesource1 500
      500 httpsdeb.nodesource.comnode_18.x nodistromain amd64 Packages
      stephan1827S 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        Neuer Container !
        image: v9.1.0
        Schau nach mit
        iob diag
        NodeJS-Installation
        usrbinnode v18.19.0
        usrbinnpm 9.2.0
        usrbinnpx 9.2.0
        nodejs
        Version table
        stephan1827
        @glasfaser Ich habe das mal probiert aber das Ergebnis ist das gleiche. Der Container funktioniert ja auch soweit bis versuche die Backup wieder herzustellen.
          GlasfaserG Offline
          GlasfaserG Offline
          Zeige bitte die aktuelle Full Ausgabe von
          iob diag
          wo du dein Backup her hast . ( Container )
            iob diag
            stephan1827
            @glasfaser hier ist die Ausgabe von Diag. Wie gesagt, das Ganze läuft, bis ich das Backup zurückspiele. Ist es eigentlich möglich nur einzelne Adapter das Backup zurückzuspielen? Dann könnte ich versuchen das Ganze Stück für Stück zurückzuspielen um zu sehen das die Instanz kaputt macht.
            Skript v.2023-10-10
            *** BASE SYSTEM ***
            Hardware Vendor : Synology
            Kernel          : x86_64
            Userland        : amd64
            Docker          : v9.1.0
            Virtualization  : Docker
            Kernel          : x86_64
            Userland        : amd64
            Systemuptime and Load:
             06:52:15 up 6 days, 15:46,  0 user,  load average: 0.43, 0.62, 0.79
            CPU threads: 4
            *** Time and Time Zones ***
            Wed Jan 24 05:52:15 UTC 2024
            Wed Jan 24 06:52:15 CET 2024
            CET +0100
            Etc/UTC
            *** User and Groups ***
            root
            /root
            root
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:
            *** MEMORY ***
            Mem:             12G        5.1G        672M        605M        7.6G        7.3G
            Swap:           2.1G        1.9G        230M
            Total:           14G        7.0G        902M
                    11812 M total memory
                     4854 M used memory
                     5216 M active memory
                     4144 M inactive memory
                      641 M free memory
                       21 M buffer memory
                     7263 M swap cache
                     2047 M total swap
                     1828 M used swap
                      219 M free swap
            *** FILESYSTEM ***
            Filesystem             Type   Size  Used Avail Use% Mounted on
            /dev/mapper/cachedev_0 btrfs  5.3T  3.4T  1.9T  65% /
            tmpfs                  tmpfs   64M     0   64M   0% /dev
            tmpfs                  tmpfs  5.8G     0  5.8G   0% /sys/fs/cgroup
            shm                    tmpfs   64M     0   64M   0% /dev/shm
            /dev/mapper/cachedev_0 btrfs  5.3T  3.4T  1.9T  65% /opt/iobroker
            /dev/mapper/cachedev_0 btrfs  5.3T  3.4T  1.9T  65% /etc/hosts
            tmpfs                  tmpfs  5.8G     0  5.8G   0% /proc/acpi
            tmpfs                  tmpfs  5.8G     0  5.8G   0% /proc/scsi
            tmpfs                  tmpfs  5.8G     0  5.8G   0% /sys/firmware
            TARGET             SOURCE        FSTYPE OPTIONS
            /                  /dev/mapper/cachedev_0[/@syno/@docker/btrfs/subvolumes/8f61f99191ae24afec750236d3556bdb71cf468d8ad1a1f67b4ce1d5aaaf95ad]       btrfs  rw,nodev,relatime,ssd,synoacl,nospace_cache,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=11933,subvol=/@syno/@docker/btrfs/subvolumes/8f61f99191ae24afec750236d3556bdb71cf468d8ad1a1f67b4ce1d5aaaf95ad
            |-/opt/iobroker    /dev/mapper/cachedev_0[/@syno/docker/iobroker]        btrfs  rw,nodev,relatime,ssd,synoacl,nospace_cache,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=259,subvol=/@syno/docker
            |-/etc/resolv.conf /dev/mapper/cachedev_0[/@syno/@docker/containers/6fb14c1d0acc003618c8dd804f894f67ff863ff6c8226945827e6173e507bc0b/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,nospace_cache,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
            |-/etc/hostname    /dev/mapper/cachedev_0[/@syno/@docker/containers/6fb14c1d0acc003618c8dd804f894f67ff863ff6c8226945827e6173e507bc0b/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,nospace_cache,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
            `-/etc/hosts       /dev/mapper/cachedev_0[/@syno/@docker/containers/6fb14c1d0acc003618c8dd804f894f67ff863ff6c8226945827e6173e507bc0b/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,nospace_cache,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
            /var:
            38M     /var/
            35M     /var/lib
            19M     /var/lib/apt/lists
            19M     /var/lib/apt
            17M     /var/lib/dpkg
            /opt/iobroker/backups:
            4.0G    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            50M     /opt/iobroker/iobroker-data/
            16M     /opt/iobroker/iobroker-data/files
            13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
            28M     /opt/iobroker/iobroker-data/objects.jsonl
            6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
            5.2M    /opt/iobroker/iobroker-data/states.jsonl
            2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
            1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
            USB-Devices by-id:
            find: '/dev/serial/by-id/': No such file or directory
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.19.0
            /usr/bin/node           v18.19.0
            /usr/bin/npm            10.2.3
            /usr/bin/npx            10.2.3
            /usr/bin/corepack       0.22.0
            nodejs:
              Installed: 18.19.0-1nodesource1
              Candidate: 18.19.0-1nodesource1
              Version table:
                    500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
             *** 18.19.0-1nodesource1 1001
                    500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                 18.18.2-1nodesource1 1001
                 18.18.1-1nodesource1 1001
                 18.18.0-1nodesource1 1001
                 18.17.1-1nodesource1 1001
                 18.17.0-1nodesource1 1001
                 18.16.1-1nodesource1 1001
                 18.16.0-1nodesource1 1001
                 18.15.0-1nodesource1 1001
                 18.14.2-1nodesource1 1001
                 18.14.1-1nodesource1 1001
                 18.14.0-1nodesource1 1001
                 18.13.0+dfsg1-1 500
                    500 http://deb.debian.org/debian bookworm/main amd64 Packages
                 18.13.0-1nodesource1 1001
                 18.12.0-1nodesource1 1001
                 18.11.0-1nodesource1 1001
                 18.10.0-1nodesource1 1001
                 18.9.1-1nodesource1 1001
                 18.9.0-1nodesource1 1001
                 18.8.0-1nodesource1 1001
                 18.7.0-1nodesource1 1001
                 18.6.0-1nodesource1 1001
                 18.5.0-1nodesource1 1001
                 18.4.0-1nodesource1 1001
                 18.3.0-1nodesource1 1001
                 18.2.0-1nodesource1 1001
                 18.1.0-1nodesource1 1001
                 18.0.0-1nodesource1 1001
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Core adapters versions
            js-controller:  4.0.24
            admin:          6.12.0
            javascript:     "javascript" not found
            Adapters from github:   0
            Adapter State
            ioBroker-Repositories
            Installed ioBroker-Instances
            Objects and States
            Objects:        1
            States:         1
            Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
            Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
            Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 127.0.0.11:44047        0.0.0.0:*               LISTEN      0          99628225   -
            udp        0      0 127.0.0.11:60690        0.0.0.0:*                           0          99628224   -
            2024-01-21 17:35:41.819  - info: admin.0 (234) ==> Connected system.user.admin from ::ffff:192.168.86.90
            2024-01-21 17:35:47.365  - info: admin.0 (234) ==> Connected system.user.admin from ::ffff:192.168.86.90
            2024-01-21 17:36:06.719  - info: host.iobroker received SIGTERM
            2024-01-21 17:36:06.722  - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
            2024-01-21 17:36:06.722  - info: host.iobroker stopInstance system.adapter.discovery.0 (force=false, process=true)
            2024-01-21 17:36:06.723  - info: host.iobroker stopInstance system.adapter.backitup.0 (force=false, process=true)
            2024-01-21 17:36:06.730  - info: discovery.0 (261) Got terminate signal TERMINATE_YOURSELF
            2024-01-21 17:36:06.732  - info: discovery.0 (261) terminating
            2024-01-21 17:36:06.733  - info: discovery.0 (261) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2024-01-21 17:36:06.734  - info: admin.0 (234) Got terminate signal TERMINATE_YOURSELF
            2024-01-21 17:36:06.738  - info: backitup.0 (276) Got terminate signal TERMINATE_YOURSELF
            2024-01-21 17:36:06.739  - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
            2024-01-21 17:36:06.740  - info: host.iobroker stopInstance system.adapter.discovery.0 send kill signal
            2024-01-21 17:36:06.741  - info: host.iobroker stopInstance system.adapter.backitup.0 send kill signal
            2024-01-21 17:36:06.738  - info: admin.0 (234) terminating http server on port 8081
            2024-01-21 17:36:06.743  - info: admin.0 (234) terminating
            2024-01-21 17:36:06.744  - info: admin.0 (234) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2024-01-21 17:36:06.739  - info: backitup.0 (276) cleaned everything up...
            2024-01-21 17:36:06.739  - info: backitup.0 (276) terminating
            2024-01-21 17:36:06.740  - info: backitup.0 (276) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2024-01-21 17:36:07.278  - info: host.iobroker instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-01-21 17:36:07.287  - info: host.iobroker instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-01-21 17:36:07.305  - info: host.iobroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-01-21 17:36:07.307  - info: host.iobroker All instances are stopped.
            2024-01-21 17:36:07.358  - info: host.iobroker terminated
            iob diag has finished.
                                    v.2023-10-10
            model name      : Intel(R) Celeron(R) J4125 CPU @ 2.00GHz
            Kernel          : x86_64
            Userland        : amd64
            Docker          : v9.1.0
            Installation:           Docker
            Kernel:                 x86_64
            Userland:               amd64
            Timezone:               Etc/UTC
            User-ID:                0
            X-Server:               false
            Pending OS-Updates:     0
            Pending iob updates:    0
            Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                    /usr/bin/npm            10.2.3
                                    /usr/bin/npx            10.2.3
            Recommended versions are nodejs No connection to databases possible ... and npm No connection to databases possible ...
            MEMORY:
            Mem:             12G        5.1G        696M        605M        7.6G        7.3G
            Swap:           2.1G        1.9G        228M
            Total:           14G        7.0G        924M
            Active iob-Instances:   0
            ioBroker Core:          js-controller           4.0.24
                                    admin                   6.12.0
            ioBroker Status:        No connection to databases possible ...
            Objects:                1
            States:                 1
            Size of iob-Database:
            === Mark text until here for copying ===
              Skript v.2023-10-10
              *** BASE SYSTEM ***
              Kernel          : x86_64
              Userland        : amd64
              Docker          : v9.1.0
              Kernel          : x86_64
              Userland        : amd64
              CPU threads: 4
              CET +0100
              Etc/UTC
              root
              /root
              root
              X-Server:       false
              Desktop:
              Terminal:
              *** MEMORY ***
                       4854 M used memory
                        641 M free memory
                         21 M buffer memory
                       7263 M swap cache
                       2047 M total swap
                       1828 M used swap
                        219 M free swap
              *** FILESYSTEM ***
              /var:
              38M     /var/
              35M     /var/lib
              19M     /var/lib/apt
              17M     /var/lib/dpkg
              USB-Devices by-id:
              /usr/bin/npm            10.2.3
              /usr/bin/npx            10.2.3
              nodejs:
                Version table:
                   18.13.0+dfsg1-1 500
              Errors in npm tree:
              ioBroker Status
              admin:          6.12.0
              Adapter State
              Objects and States
              Objects:        1
              States:         1
              Pending Updates: 0
                                      v.2023-10-10
              Kernel          : x86_64
              Userland        : amd64
              Docker          : v9.1.0
              Kernel:                 x86_64
              Userland:               amd64
              Timezone:               Etc/UTC
              User-ID:                0
              X-Server:               false
                                      /usr/bin/npm            10.2.3
                                      /usr/bin/npx            10.2.3
              MEMORY:
                                      admin                   6.12.0
              Objects:                1
              States:                 1
              Marc BergM Offline
              Marc BergM Offline
              Marc Berg
              @stephan1827
              Das frische Image kommt mit js-Controller Version 5.x. In dem diag Auszug sehe ich aber 4.0.24. Von welcher Version wurde das Backup erzeugt?
              • Marc BergM Marc Berg
                @stephan1827
                stephan1827
                @marc-berg Ich installiere den neuen Docker mit der Version 7.2.0 die den js controller 4.0.024 enthält.
                  GlasfaserG Offline
                  GlasfaserG Offline
                  So ganz passt das alles nicht !
                  in den Log´s ist das ioBroker Docker Image 9.1.0 , angezeigt und also das aktuellste .
                  du schreibts von "neuen Docker ... Version 7.2.0" , das wäre ab die Synology DSM Version 7.2.0 ( auch nicht aktuell ) das hat aber nichts mit dem Container Image zu tun .
                  dann zu 4.0.24 , dann würdest du es selbstständig auf diese Version bringen , denn :
                  @marc-berg sagte in iobroker + docker + MACVLAN - fixe IP für bridge möglich ?:
                  und ein Backup würde gar nicht von 5.x. auf 4.x funktionieren , da mußt du selber Hand anlegen.
                  Hier liegt ein ganz Großes ? vor .
                  Hier wird nur vom neuen Container ... von dir gezeigt ,
                  aber wie ist der Stand vom alten vorhandenen Container .
                    stephan1827
                    @glasfaser Der Grund für diesen Unterschied ist vermutlich, das der alte Docker zwar auf dem neusten Image beruht (weil er zwischendurch immer wieder geupdated wurde), aber noch den alten js-controller verwendet. Ich habe den früher schon mal versucht js abzudaten, aber das produziert bei mir ohne Ende Fehler. Deswegen ist der noch auf dem alten Stand.
                      OliverIOO Offline
                      OliverIOO Offline
                      OliverIO
                      @stephan1827
                      irgendwie bekomme ich deine terminologie nicht mit der realen welt in überdeckung. um es evtl etwas abzugrenzen, hier mal die verschiedenen ebenen über die man sprechen kann
                      1. host-betriebssystem
                      2. container management software
                      3. docker-virtualisierung
                      4. container/image
                      5. container betriebssystem
                      6. software im container
                      jedes dieser ebenen kann mindestens eine versionsnummer haben
                      bei dir vermute ich folgendes
                      1. synology dsm 7.2.0
                      2. sonology dsm 7.2.0
                      3. docker ?, aber egal, das was mit dsm 7.2.0 mitkommt
                      4. hier wäre es interessant welches image und welche version. nie neueste wäre buanet 9.1.1
                      5. egal, wenn du buanet verwendets
                      6. version deines iobrokers
                      und nun nochmal zu deinem satz
                      wenn du schreibst, ich habe immer wieder geupdatet, meinst du dann
                      4 oder 6? oder noch schlimmer 5?
                      von welcher version auf welche version?
                      was sind die fehlermeldungen?
                      irgendwie ist ja was verkorxt und dann sollte man das grundübel erstmal reparieren, bevor man irgendwie rumdoktert
                      IM container wird nie durch irgendwelche befehle das betriebssystem oder node aktualisiert. das bringt chaos. diese dinge werden nur aktualisiert, in dem man das komplette image aktualisiert. welches betriebssystem und node da dann drin steckt bestimmt buanet.
                      alle diese änderungen überleben eine container aktualisierung nicht
                      iobroker IM container kann aktualisiert werden, aber auch nur weil alles in einer definierten volume steckt und die dann auch eine containeraktualisierung überlebt.
                      Meine Adapter und Widgets
                      Links im Profil
                      • OliverIOO OliverIO
                        @stephan1827
                        4. container/image
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @oliverio sagte in iobroker + docker + MACVLAN - fixe IP für bridge möglich ?:
                        Richtig ...
                        und alles was hier @stephan1827 schreibt , versteht keiner bzw. versuchen WIR hier ins Klare zu rücken .
                        @stephan1827
                        Ich finde es sehr schade ...
                        wir hier im Forum opfern unsere Freizeit und bekommen erst nach und nach Infos die überhaupt nicht im zusammenhand zu diesem eigentlichen Thread sind ,
                        bzw. stellt sich herraus , das dein System verkorxt ist .
