  4. Router gewechselt, kein Zugriff auf Weboberfläche mehr
94 Beiträge 10 Kommentatoren 6.5k Aufrufe 8 Beobachtet
  • fiedlesF Offline
    fiedlesF Offline
    fiedles
    #73
    2024-01-24 22:16:35.667 - debug: backitup.0 (24907) The local storage check was completed successfully. On the host "iobroker" are currently 106713 MB free space available!
    2024-01-24 22:16:35.675 - debug: backitup.0 (24907) Backup has started ...
    2024-01-24 22:16:41.412 - debug: backitup.0 (24907) [iobroker/iobroker] host.iobroker 7656 states saved
    2024-01-24 22:16:44.711 - debug: backitup.0 (24907) [iobroker/iobroker] host.iobroker 9737 objects saved
    2024-01-24 22:16:51.928 - debug: backitup.0 (24907) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2024_01_24-22_16_35_backupiobroker.tar.gz
    2024-01-24 22:16:51.929 - debug: backitup.0 (24907) [iobroker/iobroker] This backup can only be restored with js-controller version up from 4.1
    2024-01-24 22:16:52.986 - debug: backitup.0 (24907) [iobroker/iobroker] done
    2024-01-24 22:16:53.138 - debug: backitup.0 (24907) [iobroker/influxDB] InfluxDB-Backup started ...
    2024-01-24 22:16:53.139 - debug: backitup.0 (24907) [iobroker/influxDB] Start InfluxDB Backup ...
    2024-01-24 22:16:53.141 - debug: backitup.0 (24907) [iobroker/influxDB] InfluxDB Backup tmp directory created
    2024-01-24 22:16:53.154 - debug: backitup.0 (24907) [iobroker/influxDB] Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_01_24-22_16_53_backupiobroker"
    2024-01-24 22:16:53.158 - debug: backitup.0 (24907) [iobroker/influxDB] InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_01_24-22_16_53_backupiobroker" successfully deleted
    2024-01-24 22:16:53.159 - error: backitup.0 (24907) [iobroker/influxDB] Error: Command failed: influxd backup -portable -database iobroker "/opt/iobroker/backups/influxDB_2024_01_24-22_16_53_backupiobroker"
    2024-01-24 22:16:53.160 - error: backitup.0 (24907) [iobroker/influxDB] /bin/sh: 1: influxd: not found
    2024-01-24 22:16:53.160 - error: backitup.0 (24907) [iobroker] Error: Command failed: influxd backup -portable -database iobroker "/opt/iobroker/backups/influxDB_2024_01_24-22_16_53_backupiobroker"
    2024-01-24 22:16:53.162 - debug: backitup.0 (24907) [iobroker/influxDB] InfluxDB-Backup for is finish
    2024-01-24 22:16:53.163 - debug: backitup.0 (24907) [iobroker/influxDB] done
    2024-01-24 22:16:53.314 - debug: backitup.0 (24907) [iobroker/mysql] MySql-Backup started ...
    2024-01-24 22:16:53.323 - error: backitup.0 (24907) [iobroker/mysql] Error: Command failed: mysqldump -u -p**** iobroker -h localhost -P 3306 > /opt/iobroker/backups/mysql_2024_01_24-22_16_53_backupiobroker.sql
    2024-01-24 22:16:53.324 - error: backitup.0 (24907) [iobroker/mysql] /bin/sh: 1: mysqldump: not found
    2024-01-24 22:16:53.324 - error: backitup.0 (24907) [iobroker] Error: Command failed: mysqldump -u -p**** iobroker -h localhost -P 3306 > /opt/iobroker/backups/mysql_2024_01_24-22_16_53_backupiobroker.sql
    2024-01-24 22:16:53.325 - debug: backitup.0 (24907) [iobroker/mysql] MySql-Backup for is finish
    2024-01-24 22:16:53.325 - debug: backitup.0 (24907) [iobroker/mysql] done
    2024-01-24 22:16:53.476 - debug: backitup.0 (24907) [iobroker/pgsql] PgSql-Backup started ...
    2024-01-24 22:16:53.494 - error: backitup.0 (24907) [iobroker/pgsql] Error: Command failed: pg_dump --dbname=postgresql://:****@:5432/ > /opt/iobroker/backups/pgsql_2024_01_24-22_16_53_backupiobroker.sql
    2024-01-24 22:16:53.495 - error: backitup.0 (24907) [iobroker/pgsql] /bin/sh: 1: pg_dump: not found
    2024-01-24 22:16:53.496 - error: backitup.0 (24907) [iobroker] Error: Command failed: pg_dump --dbname=postgresql://:****@:5432/ > /opt/iobroker/backups/pgsql_2024_01_24-22_16_53_backupiobroker.sql
    2024-01-24 22:16:53.497 - debug: backitup.0 (24907) [iobroker/pgsql] PgSql-Backup for is finish
    2024-01-24 22:16:53.498 - debug: backitup.0 (24907) [iobroker/pgsql] done
    2024-01-24 22:16:53.649 - debug: backitup.0 (24907) [iobroker/sqlite] Start SQLite3 Backup ...
    2024-01-24 22:16:53.740 - error: backitup.0 (24907) [iobroker/sqlite] Error: Command failed: sqlite3 /opt/sqlite/data.db .dump > /opt/iobroker/backups/sqlite_2024_01_24-22_16_53_backupiobroker.sql
    2024-01-24 22:16:53.741 - error: backitup.0 (24907) [iobroker/sqlite] /bin/sh: 1: sqlite3: not found
    2024-01-24 22:16:53.742 - error: backitup.0 (24907) [iobroker/sqlite] Error: Command failed: sqlite3 /opt/sqlite/data.db .dump > /opt/iobroker/backups/sqlite_2024_01_24-22_16_53_backupiobroker.sql
    2024-01-24 22:16:53.743 - error: backitup.0 (24907) [iobroker/sqlite] /bin/sh: 1: sqlite3: not found
    2024-01-24 22:16:53.744 - error: backitup.0 (24907) [iobroker] Error: Command failed: sqlite3 /opt/sqlite/data.db .dump > /opt/iobroker/backups/sqlite_2024_01_24-22_16_53_backupiobroker.sql
    2024-01-24 22:19:12.322 - info: javascript.0 (14974) script.js.common.Vorgarten_Licht_Steuerung: telegram: Bewegung Haustür
    2024-01-24 22:20:15.170 - info: admin.0 (14963) <== Disconnect system.user.admin from ::ffff:192.168.178.35 admin
    2024-01-24 22:20:15.893 - info: admin.0 (14963) ==> Connected system.user.admin from ::ffff:192.168.178.35
      @sebastian-fiedler sagte in Router gewechselt, kein Zugriff auf Weboberfläche mehr:
      @homoran was muss ich machen ?
      logstufe der instanz auf debug stellen.
      danach backup lostreten
      das debug davon hier in code-tags posten
      fiedlesF Offline
      fiedlesF Offline
      fiedles
      #74
      @homoran gibt es eine Alternative zum Backup adapter?
      • fiedlesF fiedles
        #75
        @fiedles sagte in Router gewechselt, kein Zugriff auf Weboberfläche mehr:
        Da fehlt der influxdb-client auf dem System von wo aus das Backup ausgelöst wird.
        Und du hast da drei verschiedene Datenbanksysteme am Start?
        Auch dafür gibt es bestimmte Voraussetzungen. Stehen aber alle in der Anleitung zu Backitup drin.
        fiedlesF 1 Antwort Letzte Antwort
          fiedlesF Offline
          fiedlesF Offline
          fiedles
          #76
          @thomas-braun 3 Datenbanksysteme? woran sehe ich das, wie kommt das, und wie kann ich das korrigieren?
          • fiedlesF fiedles
            #77
            @fiedles
            influxdb, mysql und pgsql sollen da laut Log gesichert werden.
            Es fehlen aber jeweils die entsprechenden Pakete auf der Kiste.
              @fiedles
              fiedlesF Offline
              fiedlesF Offline
              fiedles
              #78
              @thomas-braun ich dachte ich harke alles an, damit er einfach alles speichert. ist das ein Problem?
              Thomas BraunT da_WoodyD 2 Antworten Letzte Antwort
              • fiedlesF fiedles
                #79
                Äh, wenn du das Zeug gar nicht verwendest? Macht gar keinen Sinn und führt nur zu Fehlern.
                fiedlesF 2 Antworten Letzte Antwort
                • fiedlesF fiedles
                  da_WoodyD Offline
                  da_WoodyD Offline
                  #80
                  @fiedles harken? Tut man im Garten.
                  Was soll gesichert werden wenn nicht benutzt?
                  • da_WoodyD da_Woody
                    fiedlesF Offline
                    fiedlesF Offline
                    fiedles
                    #81
                    @da_woody 😌
                      fiedlesF Offline
                      fiedlesF Offline
                      fiedles
                      #82
                      @thomas-braun tatsächlich läuft Backup jetzt durch, ist aber nur 2k groß. war ja mal 16mb, ich denke er sichert da nicht alles?
                        fiedlesF Offline
                        fiedlesF Offline
                        fiedles
                        #83
                        pi@iobroker:~ $ ls -lh /opt/iobroker/backups
                        total 5.7G
                        -rw-rwxr--+ 1 iobroker iobroker 2.1M Dec  1  2021 2021_12_01-11_50_18_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2.1M Jan 11  2022 2022_01_11-17_59_15_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct  5  2022 2022_10_05-15_39_16_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct  5  2022 2022_10_05-15_58_52_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Nov 23  2022 2022_11_23-16_43_45_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker   89 Jan 24 20:02 historyDB_2024_01_24-20_02_39_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker   89 Jan 26 10:44 historyDB_2024_01_26-10_44_11_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker   89 Jan 26 10:45 historyDB_2024_01_26-10_45_09_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2.3M Mar  7  2022 iobroker_2022_03_07-02_40_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2.3M Mar  8  2022 iobroker_2022_03_08-02_40_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2.3M Mar  9  2022 iobroker_2022_03_09-02_40_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2.4M Mar 10  2022 iobroker_2022_03_10-02_40_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2.4M Mar 11  2022 iobroker_2022_03_11-02_40_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2.4M Mar 12  2022 iobroker_2022_03_12-02_40_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2.4M Mar 13  2022 iobroker_2022_03_13-02_40_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2.4M Mar 14  2022 iobroker_2022_03_14-02_40_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2.4M Mar 15  2022 iobroker_2022_03_15-02_40_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2.4M Mar 16  2022 iobroker_2022_03_16-02_40_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 2.5M Jul 22  2022 iobroker_2022_07_22-12_01_57_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.7M Jul 23  2022 iobroker_2022_07_23-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.7M Jul 25  2022 iobroker_2022_07_25-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.7M Jul 27  2022 iobroker_2022_07_27-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.7M Jul 29  2022 iobroker_2022_07_29-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.7M Jul 31  2022 iobroker_2022_07_31-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug  1  2022 iobroker_2022_08_01-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug  3  2022 iobroker_2022_08_03-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug  5  2022 iobroker_2022_08_05-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug  7  2022 iobroker_2022_08_07-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug  9  2022 iobroker_2022_08_09-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug 11  2022 iobroker_2022_08_11-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug 13  2022 iobroker_2022_08_13-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug 15  2022 iobroker_2022_08_15-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug 17  2022 iobroker_2022_08_17-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug 19  2022 iobroker_2022_08_19-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug 21  2022 iobroker_2022_08_21-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug 23  2022 iobroker_2022_08_23-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug 25  2022 iobroker_2022_08_25-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug 27  2022 iobroker_2022_08_27-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.7M Aug 29  2022 iobroker_2022_08_29-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.8M Aug 31  2022 iobroker_2022_08_31-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep  1  2022 iobroker_2022_09_01-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep  3  2022 iobroker_2022_09_03-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep  5  2022 iobroker_2022_09_05-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep  7  2022 iobroker_2022_09_07-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep  9  2022 iobroker_2022_09_09-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.7M Sep 11  2022 iobroker_2022_09_11-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep 13  2022 iobroker_2022_09_13-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep 15  2022 iobroker_2022_09_15-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep 17  2022 iobroker_2022_09_17-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep 19  2022 iobroker_2022_09_19-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep 20  2022 iobroker_2022_09_20-12_09_06_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep 20  2022 iobroker_2022_09_20-13_09_49_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep 21  2022 iobroker_2022_09_21-02_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep 21  2022 iobroker_2022_09_21-12_15_28_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep 21  2022 iobroker_2022_09_21-14_52_53_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.8M Sep 22  2022 iobroker_2022_09_22-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Sep 23  2022 iobroker_2022_09_23-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Sep 24  2022 iobroker_2022_09_24-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Sep 25  2022 iobroker_2022_09_25-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Sep 26  2022 iobroker_2022_09_26-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Sep 27  2022 iobroker_2022_09_27-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Sep 28  2022 iobroker_2022_09_28-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Sep 29  2022 iobroker_2022_09_29-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Sep 30  2022 iobroker_2022_09_30-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct  1  2022 iobroker_2022_10_01-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct  2  2022 iobroker_2022_10_02-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct  3  2022 iobroker_2022_10_03-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct  4  2022 iobroker_2022_10_04-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct  5  2022 iobroker_2022_10_05-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct  5  2022 iobroker_2022_10_05-14_34_20_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct  6  2022 iobroker_2022_10_06-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct  7  2022 iobroker_2022_10_07-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct  8  2022 iobroker_2022_10_08-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct  9  2022 iobroker_2022_10_09-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 10  2022 iobroker_2022_10_10-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 11  2022 iobroker_2022_10_11-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 12  2022 iobroker_2022_10_12-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 13  2022 iobroker_2022_10_13-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 14  2022 iobroker_2022_10_14-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 15  2022 iobroker_2022_10_15-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 16  2022 iobroker_2022_10_16-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 17  2022 iobroker_2022_10_17-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 18  2022 iobroker_2022_10_18-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 19  2022 iobroker_2022_10_19-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 20  2022 iobroker_2022_10_20-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 21  2022 iobroker_2022_10_21-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 22  2022 iobroker_2022_10_22-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 23  2022 iobroker_2022_10_23-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 24  2022 iobroker_2022_10_24-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 25  2022 iobroker_2022_10_25-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 26  2022 iobroker_2022_10_26-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 27  2022 iobroker_2022_10_27-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 28  2022 iobroker_2022_10_28-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 29  2022 iobroker_2022_10_29-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 30  2022 iobroker_2022_10_30-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Oct 31  2022 iobroker_2022_10_31-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Nov  1  2022 iobroker_2022_11_01-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 4.9M Nov  2  2022 iobroker_2022_11_02-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 5.0M Nov  3  2022 iobroker_2022_11_03-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 5.0M Nov  4  2022 iobroker_2022_11_04-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 7.2M Nov  5  2022 iobroker_2022_11_05-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker 7.2M Nov  6  2022 iobroker_2022_11_06-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Nov  7  2022 iobroker_2022_11_07-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Nov  8  2022 iobroker_2022_11_08-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Nov  9  2022 iobroker_2022_11_09-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Nov 10  2022 iobroker_2022_11_10-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Nov 11  2022 iobroker_2022_11_11-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Nov 12  2022 iobroker_2022_11_12-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Nov 13  2022 iobroker_2022_11_13-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Nov 14  2022 iobroker_2022_11_14-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Nov 15  2022 iobroker_2022_11_15-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Nov 16  2022 iobroker_2022_11_16-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Nov 17  2022 iobroker_2022_11_17-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Nov 18  2022 iobroker_2022_11_18-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Nov 19  2022 iobroker_2022_11_19-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Nov 20  2022 iobroker_2022_11_20-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Nov 21  2022 iobroker_2022_11_21-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Nov 22  2022 iobroker_2022_11_22-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Nov 23  2022 iobroker_2022_11_23-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Nov 24  2022 iobroker_2022_11_24-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Nov 25  2022 iobroker_2022_11_25-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Nov 26  2022 iobroker_2022_11_26-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Nov 27  2022 iobroker_2022_11_27-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Nov 28  2022 iobroker_2022_11_28-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Nov 30  2022 iobroker_2022_11_30-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec  1  2022 iobroker_2022_12_01-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec  2  2022 iobroker_2022_12_02-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec  3  2022 iobroker_2022_12_03-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec  4  2022 iobroker_2022_12_04-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec  5  2022 iobroker_2022_12_05-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec  6  2022 iobroker_2022_12_06-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec  7  2022 iobroker_2022_12_07-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec  8  2022 iobroker_2022_12_08-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec  9  2022 iobroker_2022_12_09-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec 10  2022 iobroker_2022_12_10-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec 11  2022 iobroker_2022_12_11-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec 12  2022 iobroker_2022_12_12-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec 13  2022 iobroker_2022_12_13-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec 14  2022 iobroker_2022_12_14-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec 15  2022 iobroker_2022_12_15-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec 16  2022 iobroker_2022_12_16-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec 17  2022 iobroker_2022_12_17-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec 18  2022 iobroker_2022_12_18-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec 19  2022 iobroker_2022_12_19-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec 20  2022 iobroker_2022_12_20-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec 21  2022 iobroker_2022_12_21-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec 22  2022 iobroker_2022_12_22-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec 23  2022 iobroker_2022_12_23-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec 24  2022 iobroker_2022_12_24-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec 25  2022 iobroker_2022_12_25-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec 26  2022 iobroker_2022_12_26-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec 27  2022 iobroker_2022_12_27-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec 28  2022 iobroker_2022_12_28-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec 29  2022 iobroker_2022_12_29-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec 30  2022 iobroker_2022_12_30-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Dec 31  2022 iobroker_2022_12_31-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Jan  1  2023 iobroker_2023_01_01-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Jan  2  2023 iobroker_2023_01_02-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  12M Jan  3  2023 iobroker_2023_01_03-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan  4  2023 iobroker_2023_01_04-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan  5  2023 iobroker_2023_01_05-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan  6  2023 iobroker_2023_01_06-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan  7  2023 iobroker_2023_01_07-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan  8  2023 iobroker_2023_01_08-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan  9  2023 iobroker_2023_01_09-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan 10  2023 iobroker_2023_01_10-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan 11  2023 iobroker_2023_01_11-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan 12  2023 iobroker_2023_01_12-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan 13  2023 iobroker_2023_01_13-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan 14  2023 iobroker_2023_01_14-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan 15  2023 iobroker_2023_01_15-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan 16  2023 iobroker_2023_01_16-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan 17  2023 iobroker_2023_01_17-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan 18  2023 iobroker_2023_01_18-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan 19  2023 iobroker_2023_01_19-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan 20  2023 iobroker_2023_01_20-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan 21  2023 iobroker_2023_01_21-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan 22  2023 iobroker_2023_01_22-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan 23  2023 iobroker_2023_01_23-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan 24  2023 iobroker_2023_01_24-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan 25  2023 iobroker_2023_01_25-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan 26  2023 iobroker_2023_01_26-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan 27  2023 iobroker_2023_01_27-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan 28  2023 iobroker_2023_01_28-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan 29  2023 iobroker_2023_01_29-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan 30  2023 iobroker_2023_01_30-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Jan 31  2023 iobroker_2023_01_31-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb  1  2023 iobroker_2023_02_01-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb  2  2023 iobroker_2023_02_02-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb  3  2023 iobroker_2023_02_03-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb  4  2023 iobroker_2023_02_04-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb  5  2023 iobroker_2023_02_05-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb  6  2023 iobroker_2023_02_06-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb  7  2023 iobroker_2023_02_07-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb  8  2023 iobroker_2023_02_08-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb  9  2023 iobroker_2023_02_09-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb 10  2023 iobroker_2023_02_10-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb 11  2023 iobroker_2023_02_11-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb 12  2023 iobroker_2023_02_12-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb 13  2023 iobroker_2023_02_13-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb 14  2023 iobroker_2023_02_14-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb 15  2023 iobroker_2023_02_15-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb 16  2023 iobroker_2023_02_16-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb 17  2023 iobroker_2023_02_17-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb 18  2023 iobroker_2023_02_18-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb 19  2023 iobroker_2023_02_19-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb 20  2023 iobroker_2023_02_20-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb 21  2023 iobroker_2023_02_21-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb 22  2023 iobroker_2023_02_22-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb 23  2023 iobroker_2023_02_23-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb 24  2023 iobroker_2023_02_24-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb 25  2023 iobroker_2023_02_25-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb 26  2023 iobroker_2023_02_26-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb 27  2023 iobroker_2023_02_27-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Feb 28  2023 iobroker_2023_02_28-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar  1  2023 iobroker_2023_03_01-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar  2  2023 iobroker_2023_03_02-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar  3  2023 iobroker_2023_03_03-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar  4  2023 iobroker_2023_03_04-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar  5  2023 iobroker_2023_03_05-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar  6  2023 iobroker_2023_03_06-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar  7  2023 iobroker_2023_03_07-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar  8  2023 iobroker_2023_03_08-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar  9  2023 iobroker_2023_03_09-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar 10  2023 iobroker_2023_03_10-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar 11  2023 iobroker_2023_03_11-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar 12  2023 iobroker_2023_03_12-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar 13  2023 iobroker_2023_03_13-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar 14  2023 iobroker_2023_03_14-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar 15  2023 iobroker_2023_03_15-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar 16  2023 iobroker_2023_03_16-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar 17  2023 iobroker_2023_03_17-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar 18  2023 iobroker_2023_03_18-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar 19  2023 iobroker_2023_03_19-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar 20  2023 iobroker_2023_03_20-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar 21  2023 iobroker_2023_03_21-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar 22  2023 iobroker_2023_03_22-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar 23  2023 iobroker_2023_03_23-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar 24  2023 iobroker_2023_03_24-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar 25  2023 iobroker_2023_03_25-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar 26  2023 iobroker_2023_03_26-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar 27  2023 iobroker_2023_03_27-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar 28  2023 iobroker_2023_03_28-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar 29  2023 iobroker_2023_03_29-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar 30  2023 iobroker_2023_03_30-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Mar 31  2023 iobroker_2023_03_31-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Apr  1  2023 iobroker_2023_04_01-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Apr  2  2023 iobroker_2023_04_02-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Apr  3  2023 iobroker_2023_04_03-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Apr  4  2023 iobroker_2023_04_04-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Apr  5  2023 iobroker_2023_04_05-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Apr  6  2023 iobroker_2023_04_06-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Apr  7  2023 iobroker_2023_04_07-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Apr  8  2023 iobroker_2023_04_08-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Apr  9  2023 iobroker_2023_04_09-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Apr 10  2023 iobroker_2023_04_10-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Apr 11  2023 iobroker_2023_04_11-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Apr 12  2023 iobroker_2023_04_12-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Apr 13  2023 iobroker_2023_04_13-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Apr 14  2023 iobroker_2023_04_14-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Apr 15  2023 iobroker_2023_04_15-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Apr 16  2023 iobroker_2023_04_16-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Apr 17  2023 iobroker_2023_04_17-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Apr 18  2023 iobroker_2023_04_18-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Apr 19  2023 iobroker_2023_04_19-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Apr 20  2023 iobroker_2023_04_20-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Apr 21  2023 iobroker_2023_04_21-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Apr 22  2023 iobroker_2023_04_22-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Apr 23  2023 iobroker_2023_04_23-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Apr 24  2023 iobroker_2023_04_24-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Apr 25  2023 iobroker_2023_04_25-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Apr 26  2023 iobroker_2023_04_26-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Apr 27  2023 iobroker_2023_04_27-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Apr 28  2023 iobroker_2023_04_28-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Apr 29  2023 iobroker_2023_04_29-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Apr 30  2023 iobroker_2023_04_30-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May  1  2023 iobroker_2023_05_01-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May  2  2023 iobroker_2023_05_02-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May  3  2023 iobroker_2023_05_03-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May  4  2023 iobroker_2023_05_04-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May  5  2023 iobroker_2023_05_05-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May  6  2023 iobroker_2023_05_06-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May  7  2023 iobroker_2023_05_07-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May  8  2023 iobroker_2023_05_08-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May  9  2023 iobroker_2023_05_09-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May 10  2023 iobroker_2023_05_10-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May 11  2023 iobroker_2023_05_11-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May 12  2023 iobroker_2023_05_12-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May 13  2023 iobroker_2023_05_13-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May 14  2023 iobroker_2023_05_14-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May 15  2023 iobroker_2023_05_15-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May 16  2023 iobroker_2023_05_16-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May 17  2023 iobroker_2023_05_17-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May 18  2023 iobroker_2023_05_18-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May 19  2023 iobroker_2023_05_19-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May 20  2023 iobroker_2023_05_20-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May 21  2023 iobroker_2023_05_21-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May 22  2023 iobroker_2023_05_22-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May 23  2023 iobroker_2023_05_23-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May 24  2023 iobroker_2023_05_24-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May 25  2023 iobroker_2023_05_25-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May 26  2023 iobroker_2023_05_26-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May 27  2023 iobroker_2023_05_27-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May 28  2023 iobroker_2023_05_28-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May 29  2023 iobroker_2023_05_29-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May 30  2023 iobroker_2023_05_30-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M May 31  2023 iobroker_2023_05_31-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun  1  2023 iobroker_2023_06_01-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun  2  2023 iobroker_2023_06_02-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun  3  2023 iobroker_2023_06_03-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun  4  2023 iobroker_2023_06_04-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun  5  2023 iobroker_2023_06_05-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun  6  2023 iobroker_2023_06_06-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun  7  2023 iobroker_2023_06_07-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun  8  2023 iobroker_2023_06_08-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun  9  2023 iobroker_2023_06_09-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun 10  2023 iobroker_2023_06_10-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun 11  2023 iobroker_2023_06_11-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun 12  2023 iobroker_2023_06_12-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun 13  2023 iobroker_2023_06_13-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun 14  2023 iobroker_2023_06_14-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun 15  2023 iobroker_2023_06_15-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun 16  2023 iobroker_2023_06_16-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun 17  2023 iobroker_2023_06_17-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun 18  2023 iobroker_2023_06_18-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun 19  2023 iobroker_2023_06_19-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun 20  2023 iobroker_2023_06_20-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun 21  2023 iobroker_2023_06_21-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun 22  2023 iobroker_2023_06_22-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun 23  2023 iobroker_2023_06_23-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun 24  2023 iobroker_2023_06_24-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun 25  2023 iobroker_2023_06_25-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun 26  2023 iobroker_2023_06_26-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun 27  2023 iobroker_2023_06_27-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun 28  2023 iobroker_2023_06_28-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun 29  2023 iobroker_2023_06_29-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jun 30  2023 iobroker_2023_06_30-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jul  1  2023 iobroker_2023_07_01-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jul  2  2023 iobroker_2023_07_02-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jul  3  2023 iobroker_2023_07_03-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jul  4  2023 iobroker_2023_07_04-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jul  5  2023 iobroker_2023_07_05-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jul  6  2023 iobroker_2023_07_06-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jul  7  2023 iobroker_2023_07_07-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jul  8  2023 iobroker_2023_07_08-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jul  9  2023 iobroker_2023_07_09-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jul 10  2023 iobroker_2023_07_10-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jul 11  2023 iobroker_2023_07_11-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jul 12  2023 iobroker_2023_07_12-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jul 13  2023 iobroker_2023_07_13-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jul 14  2023 iobroker_2023_07_14-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jul 15  2023 iobroker_2023_07_15-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jul 16  2023 iobroker_2023_07_16-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jul 17  2023 iobroker_2023_07_17-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jul 18  2023 iobroker_2023_07_18-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jul 19  2023 iobroker_2023_07_19-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jul 20  2023 iobroker_2023_07_20-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jul 21  2023 iobroker_2023_07_21-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jul 22  2023 iobroker_2023_07_22-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jul 23  2023 iobroker_2023_07_23-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jul 24  2023 iobroker_2023_07_24-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jul 25  2023 iobroker_2023_07_25-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Jul 26  2023 iobroker_2023_07_26-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Jul 27  2023 iobroker_2023_07_27-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Jul 28 03:30 iobroker_2023_07_28-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Jul 29 03:30 iobroker_2023_07_29-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Jul 30 03:30 iobroker_2023_07_30-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Jul 31 03:30 iobroker_2023_07_31-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug  1 03:30 iobroker_2023_08_01-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug  2 03:30 iobroker_2023_08_02-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug  3 03:30 iobroker_2023_08_03-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug  4 03:30 iobroker_2023_08_04-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug  5 03:30 iobroker_2023_08_05-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug  6 03:30 iobroker_2023_08_06-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug  7 03:30 iobroker_2023_08_07-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug  8 03:30 iobroker_2023_08_08-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug  9 03:30 iobroker_2023_08_09-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug 10 03:30 iobroker_2023_08_10-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug 11 03:30 iobroker_2023_08_11-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug 12 03:30 iobroker_2023_08_12-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug 13 03:30 iobroker_2023_08_13-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug 14 03:30 iobroker_2023_08_14-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug 15 03:30 iobroker_2023_08_15-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug 16 03:30 iobroker_2023_08_16-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug 17 03:30 iobroker_2023_08_17-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug 18 03:30 iobroker_2023_08_18-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug 19 03:30 iobroker_2023_08_19-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug 20 03:30 iobroker_2023_08_20-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug 21 03:30 iobroker_2023_08_21-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug 22 03:30 iobroker_2023_08_22-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug 23 03:30 iobroker_2023_08_23-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug 24 03:30 iobroker_2023_08_24-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug 25 03:30 iobroker_2023_08_25-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug 26 03:30 iobroker_2023_08_26-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug 27 03:30 iobroker_2023_08_27-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug 28 03:30 iobroker_2023_08_28-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug 29 03:30 iobroker_2023_08_29-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug 30 03:30 iobroker_2023_08_30-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Aug 31 03:30 iobroker_2023_08_31-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep  1 03:30 iobroker_2023_09_01-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep  2 03:30 iobroker_2023_09_02-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep  3 03:30 iobroker_2023_09_03-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep  4 03:30 iobroker_2023_09_04-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  15M Sep  5 03:30 iobroker_2023_09_05-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep  6 03:30 iobroker_2023_09_06-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep  7 03:30 iobroker_2023_09_07-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep  8 03:30 iobroker_2023_09_08-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep  9 03:30 iobroker_2023_09_09-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep 10 03:30 iobroker_2023_09_10-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep 11 03:30 iobroker_2023_09_11-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep 12 03:30 iobroker_2023_09_12-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep 13 03:30 iobroker_2023_09_13-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep 14 03:30 iobroker_2023_09_14-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep 15 03:30 iobroker_2023_09_15-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep 16 03:30 iobroker_2023_09_16-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep 17 03:30 iobroker_2023_09_17-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep 18 03:30 iobroker_2023_09_18-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep 19 03:30 iobroker_2023_09_19-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep 20 03:30 iobroker_2023_09_20-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep 21 03:30 iobroker_2023_09_21-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep 22 03:30 iobroker_2023_09_22-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep 23 03:30 iobroker_2023_09_23-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep 24 03:30 iobroker_2023_09_24-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep 25 03:30 iobroker_2023_09_25-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep 26 03:30 iobroker_2023_09_26-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep 27 03:30 iobroker_2023_09_27-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep 28 03:30 iobroker_2023_09_28-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep 29 03:30 iobroker_2023_09_29-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Sep 30 03:30 iobroker_2023_09_30-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct  1 03:30 iobroker_2023_10_01-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct  2 03:30 iobroker_2023_10_02-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct  3 03:30 iobroker_2023_10_03-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct  3 19:19 iobroker_2023_10_03-19_19_30_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct  3 19:40 iobroker_2023_10_03-19_40_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct  4 03:30 iobroker_2023_10_04-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct  5 03:30 iobroker_2023_10_05-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct  6 03:30 iobroker_2023_10_06-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct  7 03:30 iobroker_2023_10_07-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct  8 03:30 iobroker_2023_10_08-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct  9 03:30 iobroker_2023_10_09-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct 10 03:30 iobroker_2023_10_10-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct 11 03:30 iobroker_2023_10_11-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct 12 03:30 iobroker_2023_10_12-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct 13 03:30 iobroker_2023_10_13-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct 14 03:30 iobroker_2023_10_14-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct 15 03:30 iobroker_2023_10_15-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct 16 03:30 iobroker_2023_10_16-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct 17 03:30 iobroker_2023_10_17-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct 18 03:30 iobroker_2023_10_18-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct 19 03:30 iobroker_2023_10_19-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct 20 03:30 iobroker_2023_10_20-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct 21 03:30 iobroker_2023_10_21-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct 22 03:30 iobroker_2023_10_22-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct 23 03:30 iobroker_2023_10_23-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct 24 03:30 iobroker_2023_10_24-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct 25 03:30 iobroker_2023_10_25-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct 26 03:30 iobroker_2023_10_26-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct 27 03:30 iobroker_2023_10_27-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct 28 03:30 iobroker_2023_10_28-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct 29 03:30 iobroker_2023_10_29-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct 30 03:30 iobroker_2023_10_30-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Oct 31 03:30 iobroker_2023_10_31-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Nov  1 03:30 iobroker_2023_11_01-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Nov  2 03:30 iobroker_2023_11_02-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Nov  3 03:30 iobroker_2023_11_03-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Nov  4 03:30 iobroker_2023_11_04-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Nov  5 03:30 iobroker_2023_11_05-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Nov  6 03:30 iobroker_2023_11_06-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Nov  7 03:30 iobroker_2023_11_07-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  16M Nov  8 03:30 iobroker_2023_11_08-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Nov  9 03:30 iobroker_2023_11_09-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Nov 10 03:30 iobroker_2023_11_10-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Nov 11 03:30 iobroker_2023_11_11-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Nov 12 03:30 iobroker_2023_11_12-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Nov 13 03:30 iobroker_2023_11_13-03_30_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker  13M Nov 14 03:30 iobroker_2023_11_14-03_30_10_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker  13M Jan 22 23:01 iobroker_2024_01_22-23_01_41_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker  13M Jan 22 23:04 iobroker_2024_01_22-23_04_12_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker  13M Jan 23 03:30 iobroker_2024_01_23-03_30_10_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker  13M Jan 23 23:09 iobroker_2024_01_23-23_09_02_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker  13M Jan 24 03:30 iobroker_2024_01_24-03_30_10_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker  13M Jan 24 20:02 iobroker_2024_01_24-20_02_22_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker  13M Jan 24 20:06 iobroker_2024_01_24-20_06_20_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker  13M Jan 24 22:07 iobroker_2024_01_24-22_07_24_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker  13M Jan 24 22:16 iobroker_2024_01_24-22_16_35_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker  13M Jan 25 02:48 iobroker_2024_01_25-02_48_10_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker  13M Jan 26 00:05 iobroker_2024_01_26-00_05_23_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker  13M Jan 26 02:48 iobroker_2024_01_26-02_48_10_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker  13M Jan 26 09:55 iobroker_2024_01_26-09_55_17_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker  13M Jan 26 10:44 iobroker_2024_01_26-10_43_55_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker  13M Jan 26 10:45 iobroker_2024_01_26-10_44_53_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker 1.2K Jan 26 10:44 jarvis.0_2024_01_26-10_44_12_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker 1.2K Jan 26 10:45 jarvis.0_2024_01_26-10_45_10_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker  36K Jan 24 20:02 javascripts_2024_01_24-20_02_40_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker  36K Jan 26 10:44 javascripts_2024_01_26-10_44_12_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker  36K Jan 26 10:45 javascripts_2024_01_26-10_45_10_backupiobroker.tar.gz
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 14 03:30 mysql_2023_10_14-03_30_29_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 15 03:30 mysql_2023_10_15-03_30_31_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 16 03:30 mysql_2023_10_16-03_30_30_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 17 03:30 mysql_2023_10_17-03_30_31_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 18 03:30 mysql_2023_10_18-03_30_40_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 19 03:30 mysql_2023_10_19-03_30_38_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 20 03:30 mysql_2023_10_20-03_30_36_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 21 03:30 mysql_2023_10_21-03_30_29_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 22 03:30 mysql_2023_10_22-03_30_34_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 23 03:30 mysql_2023_10_23-03_30_31_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 24 03:30 mysql_2023_10_24-03_30_36_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 25 03:30 mysql_2023_10_25-03_30_37_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 26 03:30 mysql_2023_10_26-03_30_34_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 27 03:30 mysql_2023_10_27-03_30_40_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 28 03:30 mysql_2023_10_28-03_30_28_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 29 03:30 mysql_2023_10_29-03_30_27_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 30 03:30 mysql_2023_10_30-03_30_34_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 31 03:30 mysql_2023_10_31-03_30_27_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov  1 03:30 mysql_2023_11_01-03_30_33_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov  2 03:30 mysql_2023_11_02-03_30_35_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov  3 03:30 mysql_2023_11_03-03_30_27_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov  4 03:30 mysql_2023_11_04-03_30_30_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov  5 03:30 mysql_2023_11_05-03_30_27_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov  6 03:30 mysql_2023_11_06-03_30_27_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov  7 03:30 mysql_2023_11_07-03_30_27_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov  8 03:30 mysql_2023_11_08-03_30_42_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov  9 03:30 mysql_2023_11_09-03_30_25_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov 10 03:30 mysql_2023_11_10-03_30_25_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov 11 03:30 mysql_2023_11_11-03_30_27_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov 12 03:30 mysql_2023_11_12-03_30_25_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov 13 03:30 mysql_2023_11_13-03_30_25_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov 14 03:30 mysql_2023_11_14-03_30_25_backupiobroker.sql
                        -rw-rw-r--+ 1 iobroker iobroker    0 Jan 23 23:09 mysql_2024_01_23-23_09_18_backupiobroker.sql
                        -rw-rw-r--+ 1 iobroker iobroker    0 Jan 24 03:30 mysql_2024_01_24-03_30_26_backupiobroker.sql
                        -rw-rw-r--+ 1 iobroker iobroker    0 Jan 24 20:06 mysql_2024_01_24-20_06_36_backupiobroker.sql
                        -rw-rw-r--+ 1 iobroker iobroker    0 Jan 24 22:07 mysql_2024_01_24-22_07_40_backupiobroker.sql
                        -rw-rw-r--+ 1 iobroker iobroker    0 Jan 24 22:16 mysql_2024_01_24-22_16_53_backupiobroker.sql
                        -rw-rw-r--+ 1 iobroker iobroker    0 Jan 25 02:48 mysql_2024_01_25-02_48_36_backupiobroker.sql
                        -rw-rw-r--+ 1 iobroker iobroker    0 Jan 26 00:05 mysql_2024_01_26-00_05_41_backupiobroker.sql
                        -rw-rw-r--+ 1 iobroker iobroker    0 Jan 26 02:48 mysql_2024_01_26-02_48_28_backupiobroker.sql
                        -rw-rw-r--+ 1 iobroker iobroker    0 Jan 26 09:55 mysql_2024_01_26-09_55_33_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 14 03:30 pgsql_2023_10_14-03_30_29_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 15 03:30 pgsql_2023_10_15-03_30_31_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 16 03:30 pgsql_2023_10_16-03_30_30_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 17 03:30 pgsql_2023_10_17-03_30_31_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 18 03:30 pgsql_2023_10_18-03_30_40_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 19 03:30 pgsql_2023_10_19-03_30_38_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 20 03:30 pgsql_2023_10_20-03_30_36_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 21 03:30 pgsql_2023_10_21-03_30_29_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 22 03:30 pgsql_2023_10_22-03_30_35_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 23 03:30 pgsql_2023_10_23-03_30_31_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 24 03:30 pgsql_2023_10_24-03_30_36_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 25 03:30 pgsql_2023_10_25-03_30_37_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 26 03:30 pgsql_2023_10_26-03_30_34_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 27 03:30 pgsql_2023_10_27-03_30_40_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 28 03:30 pgsql_2023_10_28-03_30_28_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 29 03:30 pgsql_2023_10_29-03_30_27_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 30 03:30 pgsql_2023_10_30-03_30_34_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Oct 31 03:30 pgsql_2023_10_31-03_30_27_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov  1 03:30 pgsql_2023_11_01-03_30_33_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov  2 03:30 pgsql_2023_11_02-03_30_35_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov  3 03:30 pgsql_2023_11_03-03_30_27_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov  4 03:30 pgsql_2023_11_04-03_30_30_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov  5 03:30 pgsql_2023_11_05-03_30_27_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov  6 03:30 pgsql_2023_11_06-03_30_27_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov  7 03:30 pgsql_2023_11_07-03_30_27_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov  8 03:30 pgsql_2023_11_08-03_30_43_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov  9 03:30 pgsql_2023_11_09-03_30_25_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov 10 03:30 pgsql_2023_11_10-03_30_25_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov 11 03:30 pgsql_2023_11_11-03_30_27_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov 12 03:30 pgsql_2023_11_12-03_30_26_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov 13 03:30 pgsql_2023_11_13-03_30_25_backupiobroker.sql
                        -rw-rwxr--+ 1 iobroker iobroker    0 Nov 14 03:30 pgsql_2023_11_14-03_30_26_backupiobroker.sql
                        -rw-rw-r--+ 1 iobroker iobroker    0 Jan 23 23:09 pgsql_2024_01_23-23_09_18_backupiobroker.sql
                        -rw-rw-r--+ 1 iobroker iobroker    0 Jan 24 03:30 pgsql_2024_01_24-03_30_26_backupiobroker.sql
                        -rw-rw-r--+ 1 iobroker iobroker    0 Jan 24 20:06 pgsql_2024_01_24-20_06_36_backupiobroker.sql
                        -rw-rw-r--+ 1 iobroker iobroker    0 Jan 24 22:07 pgsql_2024_01_24-22_07_40_backupiobroker.sql
                        -rw-rw-r--+ 1 iobroker iobroker    0 Jan 24 22:16 pgsql_2024_01_24-22_16_53_backupiobroker.sql
                        -rw-rw-r--+ 1 iobroker iobroker    0 Jan 25 02:48 pgsql_2024_01_25-02_48_36_backupiobroker.sql
                        -rw-rw-r--+ 1 iobroker iobroker    0 Jan 26 00:05 pgsql_2024_01_26-00_05_41_backupiobroker.sql
                        -rw-rw-r--+ 1 iobroker iobroker    0 Jan 26 02:48 pgsql_2024_01_26-02_48_28_backupiobroker.sql
                        -rw-rw-r--+ 1 iobroker iobroker    0 Jan 26 09:55 pgsql_2024_01_26-09_55_33_backupiobroker.sql
                        drwxrwxr-x+ 2 iobroker iobroker 4.0K Nov 14 03:30 redistmp
                        -rw-rw-r--+ 1 iobroker iobroker    0 Jan 23 23:09 sqlite_2024_01_23-23_09_18_backupiobroker.sql
                        -rw-rw-r--+ 1 iobroker iobroker    0 Jan 24 03:30 sqlite_2024_01_24-03_30_26_backupiobroker.sql
                        -rw-rw-r--+ 1 iobroker iobroker    0 Jan 24 20:06 sqlite_2024_01_24-20_06_36_backupiobroker.sql
                        -rw-rw-r--+ 1 iobroker iobroker    0 Jan 24 22:07 sqlite_2024_01_24-22_07_41_backupiobroker.sql
                        -rw-rw-r--+ 1 iobroker iobroker    0 Jan 24 22:16 sqlite_2024_01_24-22_16_53_backupiobroker.sql
                        -rw-rw-r--+ 1 iobroker iobroker    0 Jan 25 02:48 sqlite_2024_01_25-02_48_37_backupiobroker.sql
                        -rw-rw-r--+ 1 iobroker iobroker    0 Jan 26 00:05 sqlite_2024_01_26-00_05_42_backupiobroker.sql
                        -rw-rw-r--+ 1 iobroker iobroker    0 Jan 26 02:48 sqlite_2024_01_26-02_48_28_backupiobroker.sql
                        -rw-rw-r--+ 1 iobroker iobroker    0 Jan 26 09:55 sqlite_2024_01_26-09_55_33_backupiobroker.sql
                        -rw-rw-r--+ 1 iobroker iobroker 9.3K Jan 24 20:02 yahka.0_2024_01_24-20_02_41_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker 9.3K Jan 26 10:44 yahka.0_2024_01_26-10_44_13_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker 9.3K Jan 26 10:45 yahka.0_2024_01_26-10_45_10_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker 2.4K Jan 24 20:02 yahka.1_2024_01_24-20_02_41_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker 2.4K Jan 26 10:44 yahka.1_2024_01_26-10_44_13_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker 2.4K Jan 26 10:45 yahka.1_2024_01_26-10_45_10_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker 2.1K Jan 26 10:44 zigbee.0_2024_01_26-10_44_11_backupiobroker.tar.gz
                        -rw-rw-r--+ 1 iobroker iobroker 2.1K Jan 26 10:45 zigbee.0_2024_01_26-10_45_09_backupiobroker.tar.gz
                        • fiedlesF fiedles
                          #84
                          nur 2k groß
                          2.4k ist das Backup bei einer nagelneuen Installation ohne alles
                            @fiedles sagte in Router gewechselt, kein Zugriff auf Weboberfläche mehr:
                            nur 2k groß
                            fiedlesF Offline
                            fiedlesF Offline
                            fiedles
                            #85
                            @homoran wie kann das sein, habe über 20 Skripte am laufen und hunderte Objekte
                            HomoranH CodierknechtC 2 Antworten Letzte Antwort
                            • fiedlesF fiedles
                              total 5.7G
                              DJMarc75D Offline
                              DJMarc75D Offline
                              DJMarc75
                              #86
                              13 MB ;)
                              Lehrling seit 1975 !!!
                              • fiedlesF fiedles
                                #87
                                sieh genau hin, die 2,4 sind nicht das iobroker backup
                                • fiedlesF fiedles
                                  CodierknechtC Offline
                                  Codierknecht
                                  #88
                                  Das Ganze wird gepackt. Da das reine Textdaten sind, ist die Kompressionsrate ziemlich hoch.
                                  Aber @Homoran sprach ja auch von einer "nackten" Installation.
                                  Bei meinen 34 Instanzen und mit etlichen Scripten sind das aktuell ~ 10 MB.
                                  HmIP|ZigBee|Tasmota|Unifi
                                  Zabbix Certified Specialist
                                  • fiedlesF Offline
                                    fiedlesF Offline
                                    fiedles
                                    #89
                                    seid ihr alle Programmierer oder bin ich einfach nur so kluk 😅 ?
                                    anscheinend ist dann jetzt ein Backup mit 13mb durchgelaufen. Nächstes Problem, ich hab die SD im PC aber kann auf das Dateiensystem nicht zugreifen, bekomme nur bootverzeichnis angezeigt. pls help
                                    • fiedlesF fiedles
                                      #90
                                      @fiedles
                                      Windows kann mit einem Linux-Dateisystem (hier wohl ext4) nix anfangen. Was willst du denn da überhaupt anstellen?
                                      • fiedlesF Offline
                                        fiedlesF Offline
                                        fiedles
                                        #91
                                        ich möchte das Backup sichern, damit ich es auf die neue Brokerinstallation überspielen kann.
                                        ... Hat sich auch schon geklärt, ich hab jetzt vom laufenden Broker (Karte wieder rein/Backup/Sicherung download.)
                                        jetzt zur Installation von Bookworm 😇
                                          @fiedles
                                          da_WoodyD Offline
                                          da_WoodyD Offline
                                          #92
                                          @thomas-braun och, da gibts genug progrämmchen...
                                          rumfummeln steht auf einem anderen blatt... ;)
