  4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
    6.8k
17trackamazonbriefedhldpdglsups
1.6k Beiträge 129 Kommentatoren 737.9k Aufrufe 117 Beobachtet
  • DiginixD Offline
    DiginixD Offline
    Diginix
    #1286
    Es ist echt verhext. Nun erhalte ich:
    2024-01-17 10:44:07.317 - info: parcel.0 (1104269) starting. Version 0.2.6 in /opt/iobroker/node_modules/iobroker.parcel, node: v18.17.1, js-controller: 5.0.17
    2024-01-17 10:44:07.386 - info: parcel.0 (1104269) Login to DHL
    2024-01-17 10:45:08.526 - error: parcel.0 (1104269) AxiosError: Request failed with status code 504
    2024-01-17 10:45:08.530 - error: parcel.0 (1104269) "\r\n\r\n\r\n
    504 Gateway Time-out
    \r\n
    nginx
    \r\n\r\n\r\n"
    2024-01-17 10:45:08.530 - error: parcel.0 (1104269) DHL Signin failed
    2024-01-17 10:45:08.533 - warn: parcel.0 (1104269) No login session found
    Beim zweiten Versuch kam wieder de alt bekannte Fehler:
    2024-01-17 10:47:08.336 - debug: parcel.0 (1104833) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2024-01-17 10:47:08.376 - debug: parcel.0 (1104833) Objects client ready ... initialize now
    2024-01-17 10:47:08.441 - debug: parcel.0 (1104833) Objects create System PubSub Client
    2024-01-17 10:47:08.442 - debug: parcel.0 (1104833) Objects create User PubSub Client
    2024-01-17 10:47:08.523 - debug: parcel.0 (1104833) Objects client initialize lua scripts
    2024-01-17 10:47:08.529 - debug: parcel.0 (1104833) Objects connected to redis: 127.0.0.1:9001
    2024-01-17 10:47:08.587 - debug: parcel.0 (1104833) Redis States: Use Redis connection: 127.0.0.1:9000
    2024-01-17 10:47:08.619 - debug: parcel.0 (1104833) States create System PubSub Client
    2024-01-17 10:47:08.621 - debug: parcel.0 (1104833) States create User PubSub Client
    2024-01-17 10:47:08.735 - debug: parcel.0 (1104833) States connected to redis: 127.0.0.1:9000
    2024-01-17 10:47:08.797 - debug: parcel.0 (1104833) Plugin sentry Initialize Plugin (enabled=true)
    2024-01-17 10:47:09.265 - info: parcel.0 (1104833) starting. Version 0.2.6 in /opt/iobroker/node_modules/iobroker.parcel, node: v18.17.1, js-controller: 5.0.17
    2024-01-17 10:47:09.334 - info: parcel.0 (1104833) Login to DHL
    2024-01-17 10:47:10.404 - debug: parcel.0 (1104833) Please close this window to continue.
    2024-01-17 10:47:10.636 - debug: parcel.0 (1104833) (janrain.capture.ui.handleCaptureResponse)({"stat":"ok","result":{"transactionId":"RrOP4lGjA0bA4EGwmdekC45uCeBddyN4rVtq2xmA","status":"success","statusMessage":"signedIn","action":"traditionalSignin","flow":"ciam_flow_001","version":"20230309140056615616","screen":"signIn","form":"signInForm","fields":["emailOrPostNumber","currentPassword"],"oneTime":false,"userData":{"uuid":"574cc929-033f-4ad4-a29a-a8d55657c4a0","email":"***","displayName":"***"},"keepMeLoggedIn":false,"accessToken":"asdcmq6mz985ban2","ssoImplicitLogin":false,"renders":false}});
    2024-01-17 10:47:12.027 - error: parcel.0 (1104833) AxiosError: Request failed with status code 400
    2024-01-17 10:47:12.027 - error: parcel.0 (1104833) {"error":"invalid_request","error_description":"code is missing"}
    2024-01-17 10:47:12.028 - warn: parcel.0 (1104833) No login session found
    ..:: So long! Tom ::..
    • DiginixD Diginix
      \r\n
      nginx
      \r\n\r\n\r\n"
      #1287
      @diginix @Rene55
      2024-01-17 10:55:52.346  - info: parcel.0 (405471) starting. Version 0.2.6 in /opt/iobroker/node_modules/iobroker.parcel, node: v18.19.0, js-controller: 5.0.17
      2024-01-17 10:55:52.427  - info: parcel.0 (405471) Login to DHL
      2024-01-17 10:55:54.848  - info: parcel.0 (405471) Login to DHL successful
      Funktioniert hier...
      Allerdings mit aktuellem nodejs. Bitte auf Stand bringen.
        @diginix @Rene55
        DiginixD Offline
        DiginixD Offline
        Diginix
        #1288
        @thomas-braun Für mein Ubuntu 22.04.3 LTS ist das die aktuelle Ver. und daran wird es wohl nicht liegen. Und es hilft auch nicht wenn sich jetzt alle melden, bei denen es geht. Ich bin nicht allein mit dem Problem und ohne Unterstützung eines Entwicklers wird es bei meinem DHL Konto wohl nicht besser.
        T Thomas BraunT 2 Antworten Letzte Antwort
        • DiginixD Diginix
          tombox
          #1289
          @diginix Hast du mittlerweile ein dummy account der auch nicht geht?
          • T tombox
            DiginixD Offline
            DiginixD Offline
            Diginix
            #1290
            @tombox Nein, den Schritt bin ich noch nich gegangen.
            • DiginixD Diginix
              #1291
              @diginix sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
              Nein, ist es nicht.
              18.19.0 ist die aktuelle empfohlene Version. Auch für dein Ubuntu.
              • Rene55R Offline
                Rene55R Offline
                Rene55
                #1292
                @thomas-braun Ich hab den Rat befolgt und upgedatet. Aber gab es da nicht auch einen kurzen (neuen) Befehl zu?
                • Rene55R Rene55
                  #1293
                  @rene55
                  iob nodejs-update
                  setzt dich da wieder auf das richtige Gleis.
                    Nein, ist es nicht.
                    DiginixD Offline
                    DiginixD Offline
                    Diginix
                    #1294
                    @thomas-braun Ich mache wöchentlich ein:
                    sudo apt update
                    sudo apt -y dist-upgrade
                    Dann musst du mal bei Ubuntu anrufen und denen sagen, dass sie mir nicht das richtige liefern. :-D
                    /etc/apt/sources.list.d/nodesource.list
                    deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x jammy main
                    deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x jammy main
                    Edit:
                    Hab nun in /etc/apt/sources.list.d/nodesource.list:
                    deb [arch=amd64 signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
                    Und damit die 18.19.0 bekommen.
                    Und noch viel erstaunlicher ist, dass damit tatsächlich DHL wieder funktioniert!
                    Bist mein Held! Vielen Dank!
                    PS: Du wirst mir nicht sagen können wieso in der nodesource.list erst "jammy" und nun "nodistro" steht und dadurch das Update klappte?
                    Hatte nur noch mal gemacht und das hat die Quelle geändert
                    curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash -
                    sudo apt install -y nodejs
                    Thomas BraunT ThisoftT 4 Antworten Letzte Antwort
                    • DiginixD Diginix
                      sudo apt update
                      Edit:
                      #1295
                      @diginix
                      Dein Repo ist/war halt nicht aktuell. Da muss ich nicht anrufen, jedenfalls nicht bei Ubuntu sondern wenn überhaupt beim Admin von der Kiste...
                      • DiginixD Offline
                        DiginixD Offline
                        Diginix
                        #1296
                        Hab gerade schon kommentiert dass ich immer das mache wenn eine neue Major Node Ver. kommt
                        Aber bis zu nächsten musste ich das noch nie nochmal machen damit die Quelle stimmt.
                        Dennoch hat es nun "jammy" zu "nodistro" geändert und dadurch kam das Update.
                        • DiginixD Diginix
                          sudo apt update
                          Edit:
                          #1297
                          Doch, kann ich. Ist aber nicht der richtige Thread dafür, davon ab stand das schon im passenden Thread seinerzeit dabei.
                          • DiginixD Diginix
                            sudo apt update
                            Edit:
                            #1298
                            Mach es über
                            iob nodejs-update
                            Das stellt dir das Repo richtig ein. Auch die Priority z.B.
                            • DiginixD Diginix
                              #1299
                              Die hat sich ja auch geändert und die alte Quelle wird nicht mehr mit neuen Versionen gefüttert, die kommen nur noch über das neue Repo.
                              • DiginixD Offline
                                DiginixD Offline
                                Diginix
                                #1300
                                Nochmal abschließend hier, falls es oben in der Menge der Posts unterging:
                                Version 0.2.6 funktioniert mit DHL wenn NodeJS wirklich aktuell ist.
                                Und auch das neue Objekt parcel.0.notDelivered in der Version von git funktioniert.
                                  mctom
                                  #1301
                                  ich habe 2 kleine Herausforderungen mit dem Adapter. Vielleicht hat jemand eine Idee was ich machen könnte.
                                  a)
                                  No UPS address found. Please activate UPS My Choice in the UPS App
                                  myChoice ist aktiviert wenn ich das bei UPS richtig sehe. Was könnte ich noch prüfen ?
                                  b)
                                  parcel.0 2024-01-21 15:51:22.224	error	AxiosError: Request failed with status code 401
                                  parcel.0 2024-01-21 15:51:22.224	error	{"additionalInfo":{"exception":"BadCredentialsException"},"status_code":401}
                                  Mit den Zugangsdaten kann ich mich bei GLS ohne Probleme einloggen. Allerdings ist das ein Zugang für die neue GLS Seite. Kann es damit zu tun haben ?
                                  Velen Dank für eure Hilfe.
                                  Michael
                                  • M mctom
                                    a)
                                    b)
                                    Michael
                                    tombox
                                    #1302
                                    @mctom ups ist mit 0.2.7 gefixt aber gls würde länger dauern
                                    M FlexerF 2 Antworten Letzte Antwort
                                    • T tombox
                                      mctom
                                      #1303
                                      @tombox Danke für die Rückmeldung.
                                      GLS ist auch bei mir nicht dringend. Ich habe nur auch verstanden, dass die alte GLS Seite bald abgeschaltet wird, daher wollte ich den Hinweis hier geben.
                                      • T tombox
                                        FlexerF Offline
                                        FlexerF Offline
                                        Flexer
                                        #1304
                                        @tombox also ich bin auf der 0.2.7 und ups klappt leider nicht.
                                        	{"response":{"transId":"ea5f1e4c-0d1f-48b1-9ed2-f","addressToken":"","shipments":[],"errors":[{"code":"10011","message":"Missing addressToken Value"}]},"isError":true,"isWarning":false,"success":false}
                                        parcel.1
                                        2024-01-22 19:51:07.359	error	AxiosError: Request failed with status code 400
                                        parcel.1
                                        2024-01-22 19:51:07.359	error	https://onlinetools.ups.com/mychoice/v1/shipments/details/AddressToken?loc=de_DE
                                        Unterm Strich ist alles besser.
                                        Ja, voll geil hier!
                                        • FlexerF Flexer
                                          parcel.1
                                          parcel.1
                                          tombox
                                          #1305
                                          @flexer sind noch andere Fehler? ups mychoice ist aktiv?
