  4. Test Adapter homeconnect (BSH Home-Connect) v0.0.x
    6.4k
bshbsh home connecthome connecthomeconnect adapter
1.4k Beiträge 202 Kommentatoren 688.7k Aufrufe 153 Beobachtet
  • G GrillSgt
    habe mich heute auch mal etwas mit dem Adapter beschäftigt. Beim Trockner ist alles gut, bei der Kaffeemaschine meckert er aber etwas rum:
    homeconnect.0
    2023-12-10 12:15:16.163	error	{"data":{"active":{"constraints":{"access":"read"}},"programs":[{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.Espresso","name":"Espresso"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.Coffee","name":"Caffè Crema"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.Cappuccino","name":"Cappuccino"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.LatteMacchiato","name":"Latte Macchiato"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.MilkFroth","name":"Milchschaum"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.HotWater","name":"Heißwasser"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.EspressoMacchiato","name":"Espresso Macchiato"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.Beverage.Ristretto","name":"Ristretto"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Americano","name":"Americano"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.FlatWhite","name":"Flat White"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Verlaengerter","name":"Verlängerter"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.RedEye","name":"Red Eye"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.CafeConLeche","name":"Café con leche"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Garoto","name":"Garoto"},{"constraints":{"available":true,"execution":"selectandstart"},"key":"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.WienerMelange","name":"Wiener Melange"}],"selected":{"constraints":{"access":"read"}}}}
    homeconnect.0
    2023-12-10 12:15:16.162	error	/programs
    homeconnect.0
    2023-12-10 12:15:16.162	error	TypeError: returnValue.data[item].forEach is not a function at Homeconnect.getAPIValues (/opt/iobroker/node_modules/iobroker.homeconnect/main.js:573:32) at processTicksAndRejections (node:internal/process/task_queues:95:5)
    homeconnect.0
    2023-12-10 12:15:16.158	error	TypeError: returnValue.data[item].forEach is not a function
    tombox
    #1127
    @grillsgt mit v1.2.2?
    G 2 Antworten Letzte Antwort
    • T tombox
      GrillSgt
      #1128
      @tombox sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
      Ist mit 1.1.1 - der Stable Version.
      Habe jetzt von GitHub die Version 1.2.2 draufgebügelt. Scheint als sei der Fehler damit nicht mehr vorhanden. Ich beobachte es aber noch ein paar Tage und melde mich.
      Viele Grüße
      • werner2000xW Offline
        werner2000x
        #1129
        Ich habe den Brandmelder 2 und versuche vergeblich einen Alarm auszulösen um eine Alarmanlage zu simulieren.
        Beim Status Alarm -> Status kann man zwar was einstellen s.Foto aber es passiert nichts.
        Gibt es dazu eine Lösung?
        Raspi4 8 GB mit Aqara Zigbee USB, iob
        Innogy Smarthome
        Bosch Bridge 2
        HUE Bridge
        OpenWB Wallbox mit EVU Kit
        Google Nest Pro Hub
        HA auf uGreen dxp4800
        • T tombox
          GrillSgt
          #1130
          Wie versprochen die Rückmeldung. Demnach ist der Fehler mit 1.2.2 nicht mehr vorhanden.
          Schöne Feiertage!
          Michael
          • G Offline
            GrillSgt
            #1131
            Schöne Feiertage!
            Michael
            • Merlin123M Offline
              Merlin123M Offline
              Merlin123
              #1132
              Idee gesucht:
              Es kommt bei unserem Bosch Trockner immer mal wieder vor, dass der Kondenswasserbehälter voll ist und das Trocknen stoppt.
              Leider habe ich noch keine Möglichkeit gefunden, dass über den Adapter auszuwerten. Der Trockner steht laut Status auf bereit.
              Kann man das irgendwie direkt auswerten?
              Meine Workaround Idee:
              Ich triggere auf den Status und wenn der von Run auf Ready geht, ist (vermutlich) der Behälter voll. Nach Run geht er ja eigentlich auf Finished.
              Hat jemand ne bessere Idee?
              Beta-Tester
              • Merlin123M Merlin123
                Idee gesucht:
                arteckA Offline
                arteckA Offline
                arteck
                #1133
                @merlin123 sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
                also wir machen den JEDESMAL leer.. :-) so pare ich mir den gang in den Keller wenn der voll sein sollte
                • C Offline
                  captainchaos666
                  #1134
                  hat es schon jemand hin bekommen bei einer Kaffemaschine die Favoriten aufzurufen.
                  Mit: programs.active.BSH_Common_Root_ActiveProgram kann ich über die Objekte die Voreingestellten Kaffeesorten auswählen. Leider fehlt mir hier die Auswahl der Favoriten.
                  Zum testen starte ich gerade noch meine Versuche aus den Objekten heraus, später per Skript wenn ich weiß wie ich auf meine Favoriten komme
                  Unter selected.options finde ich zwar meine Favouriten, kann aber den Voreingestellten Kaffe nicht auswählen
                  Vielen Dank für Eure Unterstützung
                  Alex
                  Frederik BussF T 2 Antworten Letzte Antwort
                  • C captainchaos666
                    Alex
                    Frederik BussF Offline
                    Frederik Buss
                    #1135
                    @captainchaos666 Das geht leider nicht, zumindest ging es nicht, als ich das ausprobiert habe. Ich habe ewig lange eine Möglichkeit gesucht automatisch einen Favoriten auszuwählen, um nicht morgens noch im Halbschlaf auf Milchschaum zu drücken. Am Ende habe ich aufgegeben und wähle seitdem den Standardkaffee "ConsumerProducts.CoffeeMaker.Program.Beverage.Coffee" aus. Übrigens nicht per ActiveProgram sonder über den Datenpunkt SelectedProgram.
                    C 1 Antwort Letzte Antwort
                      TT-Tom
                      #1136
                      @frederik-buss
                      @captainchaos666
                      muss es leider bestätigen, habe auch mehrere Kaffeesession durch, ohne Erfolg. Mache es auch wie Frederick.
                      Gruß Tom
                      Public Transport
                      NSPanel Adapter Wiki
                      • C captainchaos666
                        Alex
                        tombox
                        #1137
                        @captainchaos666
                        Vielleicht kann auch home connect direkt helfen
                        https://developer.home-connect.com/support/contact
                        wie man Favoriten starten kann
                        • Frederik BussF Frederik Buss
                          captainchaos666
                          #1138
                          @frederik-buss
                          Vielen Dank für Eure Rückmeldung. Du schreibst "wähle seitdem den Standardkaffee "ConsumerProducts.CoffeeMaker.Program.Beverage.Coffee""
                          Es wird bei mir nur das Display umgeschaltet. Mit welchem Befehl startest du dann die Maschine?
                          Frederik BussF 1 Antwort Letzte Antwort
                          • T tombox
                            @captainchaos666
                            captainchaos666
                            #1139
                            @tombox
                            Vielen Dank für deine Rückmeldung, glaube nicht, dass man dort eine Antwort bekommt
                            • C captainchaos666
                              @frederik-buss
                              Frederik Buss
                              #1140
                              @captainchaos666 Mit dem Startknopf auf der Maschine ;) Ich wollte nur dass der Standardkaffee ausgewählt wird. Wieso würde ich einen Remotestart wollen?
                                captainchaos666
                                #1141
                                @frederik-buss
                                Wieso nicht! Shellytaster am Bett, da drückst du drauf und wenn du aufstehst steht dein Kaffee schon fertig da. Brauchst nicht einschalten und warten bis der gebrüht ist 😊
                                • C captainchaos666
                                  @tombox
                                  bommel_030
                                  #1142
                                  @captainchaos666
                                  Selber schon probiert. Die antworten auch... Je mehr sich zu einem Thema bei denen melden, desto eher wird angepasst.
                                  • C captainchaos666
                                    @frederik-buss
                                    Frederik Buss
                                    #1143
                                    @captainchaos666 Die Idee ist gut, aber wenn sich die Maschine einschaltet, läuft doch erstmal die Spülung durch. Da muss ich doch so oder so danach erst die Tasse unterstellen?
                                      captainchaos666
                                      #1144
                                      @frederik-buss
                                      das kannst der Maschine austreiben, wenn du den Fernstart aktivierst, dann kannst du das Einschaltspülen deaktivieren 😊 habe es in den Einstellungen bei der App vorgenommen
                                      • C captainchaos666
                                        @frederik-buss
                                        biker1602
                                        #1145
                                        @captainchaos666 said in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
                                        @frederik-buss
                                        Bei meiner Siemens EQ9 kann ich das Einschaltspülen bei Fernstart in der App nicht einstellen. Ich kann nur Fernstart Deaktivieren oder Aktivieren
                                        • B biker1602
                                          @frederik-buss
                                          bob der 1.
                                          #1146
                                          @biker1602
                                          War auch nie vorgesehen also EQ 7 & 9 gehen nicht,alles andere hab ich nicht hier stehen.
                                          Siemens streubt sich auch das im App zu bringen,hatte die angefragt deswegen
