  4. Zigbee Probleme
Zigbee Probleme
19 Beiträge 4 Kommentatoren 2.0k Aufrufe 4 Beobachtet
  • M michihorn
    @dp20eic sagte in Zigbee Probleme:
    Wenn man einer Stelle den Port ändert, dann muss man das an der anderen Stelle auch machen, wo hast Du denn was, wie geändert?
    Der Port wurde in der Konfig der Harware geändert und natürlich im Adapter.
    Ich habe im Adapter den Herdman-Debug eingeschaltet, anbei das Resultat:
    zigbee.1
    2023-11-20 15:57:38.644	debug	zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
    zigbee.1
    2023-11-20 15:57:38.645	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
    zigbee.1
    2023-11-20 15:57:40.687	info	Try to reconnect.
    zigbee.1
    2023-11-20 15:57:40.688	info	Starting Zigbee npm ...
    zigbee.1
    2023-11-20 15:57:40.738	debug	Starting zigbee-herdsman...
    zigbee.1
    2023-11-20 15:57:40.748	debug	zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,223],"channelList":[12]},"serialPort":{"baudRate":115200,"rtscts":false,"path":"tcp://192.168.178.151:6639","adapter":"zstack"},"databasePath":"/opt/iobroker/iobroker-data/zigbee_1/shepherd.db","databaseBackupPath":null,"backupPath":"/opt/iobroker/iobroker-data/zigbee_1/nvbackup.json","adapter":{"disableLED":false,"forceStartWithInconsistentAdapterConfiguration":true},"acceptJoiningDeviceHandler":null}'
    zigbee.1
    2023-11-20 15:57:40.749	debug	zigbee-herdsman:adapter:zStack:znp:log Opening TCP socket with 192.168.178.151:6639
    zigbee.1
    2023-11-20 15:57:40.751	info	Installed Version: iobroker.zigbee@1.8.23
    zigbee.1
    2023-11-20 15:57:40.753	debug	zigbee-herdsman:adapter:zStack:znp:log Socket connected
    zigbee.1
    2023-11-20 15:57:40.759	debug	zigbee-herdsman:adapter:zStack:znp:log Socket ready
    zigbee.1
    2023-11-20 15:57:40.759	debug	zigbee-herdsman:adapter:zStack:znp:log Writing CC2530/CC2531 skip bootloader payload
    zigbee.1
    2023-11-20 15:57:40.759	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> buffer [239]
    zigbee.1
    2023-11-20 15:57:40.763	debug	zigbee-herdsman:adapter:zStack:znp:log Port closed
    zigbee.1
    2023-11-20 15:57:41.761	debug	zigbee-herdsman:adapter:zStack:znp:log Skip bootloader for CC2652/CC1352
    zigbee.1
    2023-11-20 15:57:41.761	debug	zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
    zigbee.1
    2023-11-20 15:57:41.761	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
    zigbee.1
    2023-11-20 15:57:44.645	debug	zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
    zigbee.1
    2023-11-20 15:57:44.646	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
    zigbee.1
    2023-11-20 15:57:47.763	debug	zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
    zigbee.1
    2023-11-20 15:57:47.763	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
    zigbee.1
    2023-11-20 15:57:50.651	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    zigbee.1
    2023-11-20 15:57:50.651	error	Failed to start Zigbee
    zigbee.1
    2023-11-20 15:57:50.654	error	Error herdsman start
    zigbee.1
    2023-11-20 15:57:53.765	debug	zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
    zigbee.1
    2023-11-20 15:57:53.765	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
    zigbee.1
    2023-11-20 15:57:59.771	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    zigbee.1
    2023-11-20 15:57:59.779	error	Failed to start Zigbee
    zigbee.1
    2023-11-20 15:57:59.779	error	Error herdsman start
    zigbee.1
    2023-11-20 15:58:00.657	info	Try to reconnect.
    zigbee.1
    2023-11-20 15:58:00.658	info	Starting Zigbee npm ...
    zigbee.1
    2023-11-20 15:58:00.771	debug	Starting zigbee-herdsman...
    zigbee.1
    2023-11-20 15:58:00.773	debug	zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,223],"channelList":[12]},"serialPort":{"baudRate":115200,"rtscts":false,"path":"tcp://192.168.178.151:6639","adapter":"zstack"},"databasePath":"/opt/iobroker/iobroker-data/zigbee_1/shepherd.db","databaseBackupPath":null,"backupPath":"/opt/iobroker/iobroker-data/zigbee_1/nvbackup.json","adapter":{"disableLED":false,"forceStartWithInconsistentAdapterConfiguration":true},"acceptJoiningDeviceHandler":null}'
    zigbee.1
    2023-11-20 15:58:00.773	debug	zigbee-herdsman:adapter:zStack:znp:log Opening TCP socket with 192.168.178.151:6639
    zigbee.1
    2023-11-20 15:58:00.774	info	Installed Version: iobroker.zigbee@1.8.23
    zigbee.1
    2023-11-20 15:58:00.778	debug	zigbee-herdsman:adapter:zStack:znp:log Socket connected
    zigbee.1
    2023-11-20 15:58:00.779	debug	zigbee-herdsman:adapter:zStack:znp:log Socket ready
    zigbee.1
    2023-11-20 15:58:00.780	debug	zigbee-herdsman:adapter:zStack:znp:log Writing CC2530/CC2531 skip bootloader payload
    zigbee.1
    2023-11-20 15:58:00.781	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> buffer [239]
    zigbee.1
    2023-11-20 15:58:00.784	debug	zigbee-herdsman:adapter:zStack:znp:log Socket error
    zigbee.1
    2023-11-20 15:58:00.806	error	Starting zigbee-herdsman problem : "Error while opening socket"
    zigbee.1
    2023-11-20 15:58:00.812	error	Failed to start Zigbee
    zigbee.1
    2023-11-20 15:58:00.812	error	Error herdsman start
    zigbee.1
    2023-11-20 15:58:00.822	debug	zigbee-herdsman:adapter:zStack:znp:log Port closed
    zigbee.1
    2023-11-20 15:58:01.782	debug	zigbee-herdsman:adapter:zStack:znp:log Skip bootloader for CC2652/CC1352
    zigbee.1
    2023-11-20 15:58:09.781	info	Try to reconnect.
    zigbee.1
    2023-11-20 15:58:09.782	info	Starting Zigbee npm ...
    zigbee.1
    2023-11-20 15:58:09.791	debug	Starting zigbee-herdsman...
    zigbee.1
    2023-11-20 15:58:09.793	debug	zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,223],"channelList":[12]},"serialPort":{"baudRate":115200,"rtscts":false,"path":"tcp://192.168.178.151:6639","adapter":"zstack"},"databasePath":"/opt/iobroker/iobroker-data/zigbee_1/shepherd.db","databaseBackupPath":null,"backupPath":"/opt/iobroker/iobroker-data/zigbee_1/nvbackup.json","adapter":{"disableLED":false,"forceStartWithInconsistentAdapterConfiguration":true},"acceptJoiningDeviceHandler":null}'
    zigbee.1
    2023-11-20 15:58:09.794	debug	zigbee-herdsman:adapter:zStack:znp:log Opening TCP socket with 192.168.178.151:6639
    zigbee.1
    2023-11-20 15:58:09.797	info	Installed Version: iobroker.zigbee@1.8.23
    zigbee.1
    2023-11-20 15:58:09.798	debug	zigbee-herdsman:adapter:zStack:znp:log Socket connected
    zigbee.1
    2023-11-20 15:58:09.799	debug	zigbee-herdsman:adapter:zStack:znp:log Socket ready
    zigbee.1
    2023-11-20 15:58:09.799	debug	zigbee-herdsman:adapter:zStack:znp:log Writing CC2530/CC2531 skip bootloader payload
    zigbee.1
    2023-11-20 15:58:09.799	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> buffer [239]
    zigbee.1
    2023-11-20 15:58:09.803	debug	zigbee-herdsman:adapter:zStack:znp:log Socket error
    zigbee.1
    2023-11-20 15:58:09.811	error	Starting zigbee-herdsman problem : "Error while opening socket"
    zigbee.1
    2023-11-20 15:58:09.811	error	Failed to start Zigbee
    zigbee.1
    2023-11-20 15:58:09.812	error	Error herdsman start
    zigbee.1
    2023-11-20 15:58:09.819	debug	zigbee-herdsman:adapter:zStack:znp:log Port closed
    zigbee.1
    2023-11-20 15:58:10.801	debug	zigbee-herdsman:adapter:zStack:znp:log Skip bootloader for CC2652/CC1352
    zigbee.1
    2023-11-20 15:58:10.814	info	Try to reconnect.
    zigbee.1
    2023-11-20 15:58:10.816	info	Starting Zigbee npm ...
    zigbee.1
    2023-11-20 15:58:10.823	debug	Starting zigbee-herdsman...
    zigbee.1
    2023-11-20 15:58:10.830	debug	zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,223],"channelList":[12]},"serialPort":{"baudRate":115200,"rtscts":false,"path":"tcp://192.168.178.151:6639","adapter":"zstack"},"databasePath":"/opt/iobroker/iobroker-data/zigbee_1/shepherd.db","databaseBackupPath":null,"backupPath":"/opt/iobroker/iobroker-data/zigbee_1/nvbackup.json","adapter":{"disableLED":false,"forceStartWithInconsistentAdapterConfiguration":true},"acceptJoiningDeviceHandler":null}'
    zigbee.1
    2023-11-20 15:58:10.832	debug	zigbee-herdsman:adapter:zStack:znp:log Opening TCP socket with 192.168.178.151:6639
    zigbee.1
    2023-11-20 15:58:10.834	info	Installed Version: iobroker.zigbee@1.8.23
    zigbee.1
    2023-11-20 15:58:10.838	debug	zigbee-herdsman:adapter:zStack:znp:log Socket connected
    zigbee.1
    2023-11-20 15:58:10.838	debug	zigbee-herdsman:adapter:zStack:znp:log Socket ready
    zigbee.1
    2023-11-20 15:58:10.839	debug	zigbee-herdsman:adapter:zStack:znp:log Writing CC2530/CC2531 skip bootloader payload
    zigbee.1
    2023-11-20 15:58:10.840	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> buffer [239]
    zigbee.1
    2023-11-20 15:58:10.843	debug	zigbee-herdsman:adapter:zStack:znp:log Port closed
    zigbee.1
    2023-11-20 15:58:11.609	debug	DeviceAvailability:Non-pingable device 0x00158d00044eca87 lumi.sensor_ht was last seen '1455.67' seconds ago.
    zigbee.1
    2023-11-20 15:58:11.610	debug	DeviceAvailability:Non-pingable device 0x00158d0001e09c1a lumi.weather was last seen '417346.987' seconds ago.
    zigbee.1
    2023-11-20 15:58:11.620	debug	DeviceAvailability:Non-pingable device 0xa4c138640defbd3a TS0201 was last seen '1156.096' seconds ago.
    zigbee.1
    2023-11-20 15:58:11.621	debug	DeviceAvailability:Non-pingable device 0x54ef4410006bce0b lumi.motion.ac02 was last seen '453.75' seconds ago.
    zigbee.1
    2023-11-20 15:58:11.622	debug	DeviceAvailability:Non-pingable device 0x00158d0007e3ac5e lumi.weather was last seen '2070.838' seconds ago.
    zigbee.1
    2023-11-20 15:58:11.622	debug	DeviceAvailability:Non-pingable device 0x00158d00044b768a lumi.sensor_motion was last seen '2697.795' seconds ago.
    zigbee.1
    2023-11-20 15:58:11.623	debug	DeviceAvailability:Non-pingable device 0x54ef4410006bda97 lumi.motion.ac02 was last seen '1803.478' seconds ago.
    zigbee.1
    2023-11-20 15:58:11.630	debug	DeviceAvailability:Non-pingable device 0x54ef44100052beed lumi.motion.ac02 was last seen '2442.487' seconds ago.
    zigbee.1
    2023-11-20 15:58:11.631	debug	DeviceAvailability:Non-pingable device 0xa4c1387dbec3451f TS0201 was last seen '1398.483' seconds ago.
    zigbee.1
    2023-11-20 15:58:11.631	debug	DeviceAvailability:Non-pingable device 0x00158d0009ea2d8d lumi.sensor_magnet.aq2 was last seen '3192.974' seconds ago.
    zigbee.1
    2023-11-20 15:58:11.841	debug	zigbee-herdsman:adapter:zStack:znp:log Skip bootloader for CC2652/CC1352
    zigbee.1
    2023-11-20 15:58:11.841	debug	zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
    zigbee.1
    2023-11-20 15:58:11.842	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
    zigbee.1
    2023-11-20 15:58:17.843	debug	zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
    zigbee.1
    2023-11-20 15:58:17.843	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
    zigbee.1
    2023-11-20 15:58:19.814	info	Try to reconnect.
    zigbee.1
    2023-11-20 15:58:19.815	info	Starting Zigbee npm ...
    zigbee.1
    2023-11-20 15:58:19.819	debug	Starting zigbee-herdsman...
    zigbee.1
    2023-11-20 15:58:19.821	debug	zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,223],"channelList":[12]},"serialPort":{"baudRate":115200,"rtscts":false,"path":"tcp://192.168.178.151:6639","adapter":"zstack"},"databasePath":"/opt/iobroker/iobroker-data/zigbee_1/shepherd.db","databaseBackupPath":null,"backupPath":"/opt/iobroker/iobroker-data/zigbee_1/nvbackup.json","adapter":{"disableLED":false,"forceStartWithInconsistentAdapterConfiguration":true},"acceptJoiningDeviceHandler":null}'
    zigbee.1
    2023-11-20 15:58:19.821	debug	zigbee-herdsman:adapter:zStack:znp:log Opening TCP socket with 192.168.178.151:6639
    zigbee.1
    2023-11-20 15:58:19.822	info	Installed Version: iobroker.zigbee@1.8.23
    zigbee.1
    2023-11-20 15:58:19.826	debug	zigbee-herdsman:adapter:zStack:znp:log Socket connected
    zigbee.1
    2023-11-20 15:58:19.826	debug	zigbee-herdsman:adapter:zStack:znp:log Socket ready
    zigbee.1
    2023-11-20 15:58:19.827	debug	zigbee-herdsman:adapter:zStack:znp:log Writing CC2530/CC2531 skip bootloader payload
    zigbee.1
    2023-11-20 15:58:19.827	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> buffer [239]
    zigbee.1
    2023-11-20 15:58:19.829	debug	zigbee-herdsman:adapter:zStack:znp:log Port closed
    zigbee.1
    2023-11-20 15:58:20.829	debug	zigbee-herdsman:adapter:zStack:znp:log Skip bootloader for CC2652/CC1352
    zigbee.1
    2023-11-20 15:58:20.829	debug	zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
    zigbee.1
    2023-11-20 15:58:20.829	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
    zigbee.1
    2023-11-20 15:58:23.845	debug	zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
    zigbee.1
    2023-11-20 15:58:23.845	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
    zigbee.1
    2023-11-20 15:58:26.830	debug	zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
    zigbee.1
    2023-11-20 15:58:26.831	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
    zigbee.1
    2023-11-20 15:58:29.851	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    zigbee.1
    2023-11-20 15:58:29.851	error	Failed to start Zigbee
    zigbee.1
    2023-11-20 15:58:29.851	error	Error herdsman start
    zigbee.1
    2023-11-20 15:58:32.833	debug	zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
    zigbee.1
    2023-11-20 15:58:32.833	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
    zigbee.1
    2023-11-20 15:58:38.838	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    zigbee.1
    2023-11-20 15:58:38.839	error	Failed to start Zigbee
    zigbee.1
    2023-11-20 15:58:38.839	error	Error herdsman start
    zigbee.1
    2023-11-20 15:58:39.853	info	Try to reconnect.
    zigbee.1
    2023-11-20 15:58:39.854	info	Starting Zigbee npm ...
    zigbee.1
    2023-11-20 15:58:39.859	debug	Starting zigbee-herdsman...
    zigbee.1
    2023-11-20 15:58:39.861	debug	zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,223],"channelList":[12]},"serialPort":{"baudRate":115200,"rtscts":false,"path":"tcp://192.168.178.151:6639","adapter":"zstack"},"databasePath":"/opt/iobroker/iobroker-data/zigbee_1/shepherd.db","databaseBackupPath":null,"backupPath":"/opt/iobroker/iobroker-data/zigbee_1/nvbackup.json","adapter":{"disableLED":false,"forceStartWithInconsistentAdapterConfiguration":true},"acceptJoiningDeviceHandler":null}'
    zigbee.1
    2023-11-20 15:58:39.861	debug	zigbee-herdsman:adapter:zStack:znp:log Opening TCP socket with 192.168.178.151:6639
    zigbee.1
    2023-11-20 15:58:39.863	info	Installed Version: iobroker.zigbee@1.8.23
    zigbee.1
    2023-11-20 15:58:39.864	debug	zigbee-herdsman:adapter:zStack:znp:log Socket connected
    zigbee.1
    2023-11-20 15:58:39.865	debug	zigbee-herdsman:adapter:zStack:znp:log Socket ready
    zigbee.1
    2023-11-20 15:58:39.865	debug	zigbee-herdsman:adapter:zStack:znp:log Writing CC2530/CC2531 skip bootloader payload
    zigbee.1
    2023-11-20 15:58:39.866	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> buffer [239]
    zigbee.1
    2023-11-20 15:58:39.869	debug	zigbee-herdsman:adapter:zStack:znp:log Socket error
    zigbee.1
    2023-11-20 15:58:39.874	error	Starting zigbee-herdsman problem : "Error while opening socket"
    zigbee.1
    2023-11-20 15:58:39.874	error	Failed to start Zigbee
    zigbee.1
    2023-11-20 15:58:39.874	error	Error herdsman start
    zigbee.1
    2023-11-20 15:58:39.884	debug	zigbee-herdsman:adapter:zStack:znp:log Port closed
    zigbee.1
    2023-11-20 15:58:40.868	debug	zigbee-herdsman:adapter:zStack:znp:log Skip bootloader for CC2652/CC1352
    zigbee.1
    2023-11-20 15:58:48.841	info	Try to reconnect.
    zigbee.1
    2023-11-20 15:58:48.842	info	Starting Zigbee npm ...
    zigbee.1
    2023-11-20 15:58:48.881	debug	Starting zigbee-herdsman...
    zigbee.1
    2023-11-20 15:58:48.883	debug	zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,223],"channelList":[12]},"serialPort":{"baudRate":115200,"rtscts":false,"path":"tcp://192.168.178.151:6639","adapter":"zstack"},"databasePath":"/opt/iobroker/iobroker-data/zigbee_1/shepherd.db","databaseBackupPath":null,"backupPath":"/opt/iobroker/iobroker-data/zigbee_1/nvbackup.json","adapter":{"disableLED":false,"forceStartWithInconsistentAdapterConfiguration":true},"acceptJoiningDeviceHandler":null}'
    zigbee.1
    2023-11-20 15:58:48.884	debug	zigbee-herdsman:adapter:zStack:znp:log Opening TCP socket with 192.168.178.151:6639
    zigbee.1
    2023-11-20 15:58:48.887	info	Installed Version: iobroker.zigbee@1.8.23
    zigbee.1
    2023-11-20 15:58:48.890	debug	zigbee-herdsman:adapter:zStack:znp:log Socket connected
    zigbee.1
    2023-11-20 15:58:48.890	debug	zigbee-herdsman:adapter:zStack:znp:log Socket ready
    zigbee.1
    2023-11-20 15:58:48.891	debug	zigbee-herdsman:adapter:zStack:znp:log Writing CC2530/CC2531 skip bootloader payload
    zigbee.1
    2023-11-20 15:58:48.891	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> buffer [239]
    zigbee.1
    2023-11-20 15:58:48.894	debug	zigbee-herdsman:adapter:zStack:znp:log Port closed
    zigbee.1
    2023-11-20 15:58:49.877	info	Try to reconnect.
    zigbee.1
    2023-11-20 15:58:49.878	info	Starting Zigbee npm ...
    zigbee.1
    2023-11-20 15:58:49.889	debug	Starting zigbee-herdsman...
    zigbee.1
    2023-11-20 15:58:49.890	debug	zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,223],"channelList":[12]},"serialPort":{"baudRate":115200,"rtscts":false,"path":"tcp://192.168.178.151:6639","adapter":"zstack"},"databasePath":"/opt/iobroker/iobroker-data/zigbee_1/shepherd.db","databaseBackupPath":null,"backupPath":"/opt/iobroker/iobroker-data/zigbee_1/nvbackup.json","adapter":{"disableLED":false,"forceStartWithInconsistentAdapterConfiguration":true},"acceptJoiningDeviceHandler":null}'
    zigbee.1
    2023-11-20 15:58:49.893	debug	zigbee-herdsman:adapter:zStack:znp:log Opening TCP socket with 192.168.178.151:6639
    zigbee.1
    2023-11-20 15:58:49.894	debug	zigbee-herdsman:adapter:zStack:znp:log Skip bootloader for CC2652/CC1352
    zigbee.1
    2023-11-20 15:58:49.895	debug	zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
    zigbee.1
    2023-11-20 15:58:49.895	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
    zigbee.1
    2023-11-20 15:58:49.896	info	Installed Version: iobroker.zigbee@1.8.23
    zigbee.1
    2023-11-20 15:58:49.897	debug	zigbee-herdsman:adapter:zStack:znp:log Socket connected
    zigbee.1
    2023-11-20 15:58:49.898	debug	zigbee-herdsman:adapter:zStack:znp:log Socket ready
    zigbee.1
    2023-11-20 15:58:49.898	debug	zigbee-herdsman:adapter:zStack:znp:log Writing CC2530/CC2531 skip bootloader payload
    zigbee.1
    2023-11-20 15:58:49.898	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> buffer [239]
    zigbee.1
    2023-11-20 15:58:49.902	debug	zigbee-herdsman:adapter:zStack:znp:log Socket error
    zigbee.1
    2023-11-20 15:58:49.907	error	Starting zigbee-herdsman problem : "Error while opening socket"
    zigbee.1
    2023-11-20 15:58:49.907	error	Failed to start Zigbee
    zigbee.1
    2023-11-20 15:58:49.907	error	Error herdsman start
    zigbee.1
    2023-11-20 15:58:49.915	debug	zigbee-herdsman:adapter:zStack:znp:log Port closed
    zigbee.1
    2023-11-20 15:58:50.900	debug	zigbee-herdsman:adapter:zStack:znp:log Skip bootloader for CC2652/CC1352
    zigbee.1
    2023-11-20 15:58:55.897	debug	zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
    zigbee.1
    2023-11-20 15:58:55.897	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
    zigbee.1
    2023-11-20 15:58:59.910	info	Try to reconnect.
    zigbee.1
    2023-11-20 15:58:59.911	info	Starting Zigbee npm ...
    zigbee.1
    2023-11-20 15:58:59.996	debug	Starting zigbee-herdsman...
    zigbee.1
    2023-11-20 15:58:59.997	debug	zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,223],"channelList":[12]},"serialPort":{"baudRate":115200,"rtscts":false,"path":"tcp://192.168.178.151:6639","adapter":"zstack"},"databasePath":"/opt/iobroker/iobroker-data/zigbee_1/shepherd.db","databaseBackupPath":null,"backupPath":"/opt/iobroker/iobroker-data/zigbee_1/nvbackup.json","adapter":{"disableLED":false,"forceStartWithInconsistentAdapterConfiguration":true},"acceptJoiningDeviceHandler":null}'
    zigbee.1
    2023-11-20 15:58:59.998	debug	zigbee-herdsman:adapter:zStack:znp:log Opening TCP socket with 192.168.178.151:6639
    zigbee.1
    2023-11-20 15:58:59.999	info	Installed Version: iobroker.zigbee@1.8.23
    zigbee.1
    2023-11-20 15:59:00.000	debug	zigbee-herdsman:adapter:zStack:znp:log Socket connected
    zigbee.1
    2023-11-20 15:59:00.001	debug	zigbee-herdsman:adapter:zStack:znp:log Socket ready
    zigbee.1
    2023-11-20 15:59:00.001	debug	zigbee-herdsman:adapter:zStack:znp:log Writing CC2530/CC2531 skip bootloader payload
    zigbee.1
    2023-11-20 15:59:00.001	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> buffer [239]
    zigbee.1
    2023-11-20 15:59:00.006	debug	zigbee-herdsman:adapter:zStack:znp:log Socket error
    zigbee.1
    2023-11-20 15:59:00.011	error	Starting zigbee-herdsman problem : "Error while opening socket"
    zigbee.1
    2023-11-20 15:59:00.011	error	Failed to start Zigbee
    zigbee.1
    2023-11-20 15:59:00.012	error	Error herdsman start
    zigbee.1
    2023-11-20 15:59:00.042	debug	zigbee-herdsman:adapter:zStack:znp:log Port closed
    zigbee.1
    2023-11-20 15:59:01.002	debug	zigbee-herdsman:adapter:zStack:znp:log Skip bootloader for CC2652/CC1352
    zigbee.1
    2023-11-20 15:59:01.899	debug	zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
    zigbee.1
    2023-11-20 15:59:01.900	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
    zigbee.1
    2023-11-20 15:59:07.904	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    zigbee.1
    2023-11-20 15:59:07.905	error	Failed to start Zigbee
    zigbee.1
    2023-11-20 15:59:07.905	error	Error herdsman start
    zigbee.1
    2023-11-20 15:59:10.014	info	Try to reconnect.
    zigbee.1
    2023-11-20 15:59:10.015	info	Starting Zigbee npm ...
    zigbee.1
    2023-11-20 15:59:10.021	debug	Starting zigbee-herdsman...
    zigbee.1
    2023-11-20 15:59:10.023	debug	zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,223],"channelList":[12]},"serialPort":{"baudRate":115200,"rtscts":false,"path":"tcp://192.168.178.151:6639","adapter":"zstack"},"databasePath":"/opt/iobroker/iobroker-data/zigbee_1/shepherd.db","databaseBackupPath":null,"backupPath":"/opt/iobroker/iobroker-data/zigbee_1/nvbackup.json","adapter":{"disableLED":false,"forceStartWithInconsistentAdapterConfiguration":true},"acceptJoiningDeviceHandler":null}'
    zigbee.1
    2023-11-20 15:59:10.023	debug	zigbee-herdsman:adapter:zStack:znp:log Opening TCP socket with 192.168.178.151:6639
    zigbee.1
    2023-11-20 15:59:10.024	info	Installed Version: iobroker.zigbee@1.8.23
    zigbee.1
    2023-11-20 15:59:11.609	debug	DeviceAvailability:Non-pingable device 0x00158d00044eca87 lumi.sensor_ht was last seen '1515.67' seconds ago.
    zigbee.1
    2023-11-20 15:59:11.610	debug	DeviceAvailability:Non-pingable device 0x00158d0001e09c1a lumi.weather was last seen '417406.987' seconds ago.
    zigbee.1
    2023-11-20 15:59:11.620	debug	DeviceAvailability:Non-pingable device 0xa4c138640defbd3a TS0201 was last seen '1216.096' seconds ago.
    zigbee.1
    2023-11-20 15:59:11.621	debug	DeviceAvailability:Non-pingable device 0x54ef4410006bce0b lumi.motion.ac02 was last seen '513.75' seconds ago.
    zigbee.1
    2023-11-20 15:59:11.622	debug	DeviceAvailability:Non-pingable device 0x00158d0007e3ac5e lumi.weather was last seen '2130.838' seconds ago.
    zigbee.1
    2023-11-20 15:59:11.622	debug	DeviceAvailability:Non-pingable device 0x00158d00044b768a lumi.sensor_motion was last seen '2757.795' seconds ago.
    zigbee.1
    2023-11-20 15:59:11.624	debug	DeviceAvailability:Non-pingable device 0x54ef4410006bda97 lumi.motion.ac02 was last seen '1863.478' seconds ago.
    zigbee.1
    2023-11-20 15:59:11.629	debug	DeviceAvailability:Non-pingable device 0x54ef44100052beed lumi.motion.ac02 was last seen '2502.486' seconds ago.
    zigbee.1
    2023-11-20 15:59:11.631	debug	DeviceAvailability:Non-pingable device 0xa4c1387dbec3451f TS0201 was last seen '1458.483' seconds ago.
    zigbee.1
    2023-11-20 15:59:11.631	debug	DeviceAvailability:Non-pingable device 0x00158d0009ea2d8d lumi.sensor_magnet.aq2 was last seen '3252.974' seconds ago.
    zigbee.1
    2023-11-20 16:23:05.061	error	Starting zigbee-herdsman problem : "Struct length mismatch (expected=1/2, got=24)"
    zigbee.1
    2023-11-20 16:23:05.062	error	Failed to start Zigbee
    zigbee.1
    2023-11-20 16:23:05.063	error	Error herdsman start
    zigbee.1
    2023-11-20 16:23:05.117	error	Starting zigbee-herdsman problem : "Struct length mismatch (expected=1/2, got=24)"
    zigbee.1
    2023-11-20 16:23:05.117	error	Failed to start Zigbee
    zigbee.1
    2023-11-20 16:23:05.118	error	Error herdsman start
    zigbee.1
    2023-11-20 16:23:05.279	error	Starting zigbee-herdsman problem : "offset is out of bounds"
    zigbee.1
    2023-11-20 16:23:05.280	error	Failed to start Zigbee
    zigbee.1
    2023-11-20 16:23:05.281	error	Error herdsman start
    zigbee.1
    2023-11-20 16:23:08.107	error	Starting zigbee-herdsman problem : "SREQ '--> AF - register - {\"appdeviceid\":5,\"appdevver\":0,\"appnuminclusters\":0,\"appinclusterlist\":[],\"appnumoutclusters\":0,\"appoutclusterlist\":[],\"latencyreq\":0,\"endpoint\":3,\"appprofid\":260}' failed with status '(0xb8: APS_DUPLICATE_ENTRY)' (expected '(0x00: SUCCESS)')"
    zigbee.1
    2023-11-20 16:23:08.108	error	Failed to start Zigbee
    zigbee.1
    2023-11-20 16:23:08.109	error	Error herdsman start
    zigbee.1
    2023-11-20 16:23:08.123	error	Starting zigbee-herdsman problem : "SREQ '--> AF - register - {\"appdeviceid\":5,\"appdevver\":0,\"appnuminclusters\":0,\"appinclusterlist\":[],\"appnumoutclusters\":0,\"appoutclusterlist\":[],\"latencyreq\":0,\"endpoint\":3,\"appprofid\":260}' failed with status '(0xb8: APS_DUPLICATE_ENTRY)' (expected '(0x00: SUCCESS)')"
    zigbee.1
    2023-11-20 16:23:08.124	error	Failed to start Zigbee
    zigbee.1
    2023-11-20 16:23:08.124	error	Error herdsman start
    Den Key habe ich hier in der Doku aus Sicherheitsgünden geändert ;-)
    @michihorn sagte in Zigbee Probleme:
    Moin,
    das ist die IP, und der Port, vom Zigbee, kommst Du denn mit einem Browser auf diese Adresse drauf?
    Hast Du den ioBroker auch schon mal neu gestartet, vielleicht hat der ja das Problem?
    Gibt es auf dem Zigbee Device noch ein Log, das vielleicht mehr Auskunft gibt?
    Ich habe immer noch im Hinterkopf, dass es mal ein Problem gab, das da auf einem LAN/WLAN Zigbee, ein Verzeichnis, glaube, es war /var/log voll gewesen ist und deswegen der Zigbee nicht mehr lief, kann mich aber auch täuschen, dass ich da was verwechsel.
    Bernd
      Moin,
      Bernd
      M Online
      M Online
      michihorn
      schrieb am zuletzt editiert von michihorn
      @dp20eic Es gibt auf dem Device ein FSBrowser, die dort sichtbaren json Dateien sind von der Größe überschaubar. Sonst sehe ich nichts
      • M michihorn
        Moin,
        ich auch nicht, dann kann ich da nicht weiter helfen, dann noch viel Erfolg, beim Lösen des Problems.
        Bernd
        • M michihorn
          ich habe zwei Zigbee Instanzen laufen, eine über einen USB Anschluß und eine über einen tcp.
          Die tcp macht seit einigen Tagen Probleme und donnert meine Protokolle zu zu, das mein verfügbarer RAM in die Knie geht.
          Die Fehlermeldungen sehen so aus:
          zigbee.1
          2023-11-20 11:59:27.152	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
          zigbee.1
          2023-11-20 11:59:27.152	error	Failed to start Zigbee
          zigbee.1
          2023-11-20 12:00:03.741	error	Error herdsman start
          zigbee.1
          2023-11-20 12:00:03.751	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet)"
          zigbee.1
          2023-11-20 12:00:03.752	error	Failed to start Zigbee
          Ich habe bislang die Adapter Version 1.8.24 installiert.
          Michael
          D4RKKN1GHT84D Offline
          D4RKKN1GHT84
          @michihorn hast du Dein Problem lösen können? Ich habe seit Mitte letzter Woche genau die selbe Meldung! Zum verzweifeln. Ich habe bereits mein Texas Instruments ZigBee Board auf die neueste Firmware aktualisiert und sogar einen neuen Wandler von LAN auf RT/TX verbaut. Keine Chance...ich betreibe ioBroker auf meiner NAS. LG Holger
          • D4RKKN1GHT84D D4RKKN1GHT84
            arteckA Offline
            arteckA Offline
            arteck
            @d4rkkn1ght84 zeigmal die adapter einstellung
            un die 50 logzeilen vom adapter start
            D4RKKN1GHT84D 1 Antwort Letzte Antwort
            • arteckA arteck
              D4RKKN1GHT84
              schrieb am zuletzt editiert von D4RKKN1GHT84
              @arteck vielen Dank für Deine Hilfe!
              Anbei die Bilder...
                Anbei die Bilder...
                arteckA Offline
                arteckA Offline
                arteck
                @d4rkkn1ght84 dreh mal evtl die "baudRate":115200 runnter...
                da scheint dein interface zu mucken.. hast mal das Kabel getuascht.. so richtig viel kann ich nicht shen
                • arteckA arteck
                  D4RKKN1GHT84
                  @arteck
                  Habe die Baudrate verringert - selbe Meldung.
                  Habe die Jumper Kabel getauscht - selber Meldung.
                  Zuvor bereits die Firmware neu auf das Board gespielt sowie den LAN2RX getauscht.
                  Zuvor einen neuen Container auf der NAS mit einer frischen ioBroker installation durchgeführt.
                  In der NAS den Port 20108 zur Sicherheit freigegeben....
                  Anbei Bilder meiner Dose wie es auch zuvor monatelang Problemlos lief...
                  Hoffe du hast noch eine Idee..... Notfalls muss ich wieder auf Conbee3 umsteigen...oder mir ein Raspi besorgen.
                  PXL_20240114_144311822.jpg PXL_20240114_144220287.jpg PXL_20240114_144002959.jpg
                    @arteck
                    arteckA Offline
                    arteckA Offline
                    arteck
                    @d4rkkn1ght84 wenn das schon mal lief ..dann hat sich irgendwas geändert.. und das nicht vo selbst sondern du hast was gemacht..
                    meistens sind es Updates.. oder Upgrades..(kabel port umgestellt..pihole Einstellung.. Energieoptionen)
                    • arteckA arteck
                      D4RKKN1GHT84
                      @arteck said in Zigbee Probleme:
                      Nicht das ich wüsste... ich werde jetzt von der NAS auf ein NUC umsteigen damit ich hier autark bin....mal sehen was passiert :-)
