  3. Off Topic
  4. Ertrag (Tag, Monat, Jahr) berechnen und in Datei speichern
    6.0k
190 Beiträge 5 Kommentatoren 31.2k Aufrufe 4 Beobachtet
  • B bitwicht
    Entschuldige, ich dachte wir machen erst influx
    hier bitte:
    pi@raspberrypi:~ $ sudo rm /etc/apt/sources.list.d/graf*
    pi@raspberrypi:~ $ sudo apt-get install -y apt-transport-https
    Reading package lists... Done
    apt-transport-https is already the newest version (2.2.4).
    0 upgraded, 0 newly installed, 0 to remove and 39 not upgraded.
    pi@raspberrypi:~ $ sudo apt-get install -y software-properties-common wget
    software-properties-common is already the newest version (0.96.20.2-2.1).
    wget is already the newest version (1.21-1+deb11u1).
    pi@raspberrypi:~ $ sudo wget -q -O /usr/share/keyrings/grafana.key https://apt.grafana.com/gpg.key
    echo "deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main" | sudo tee /etc/apt/sources.list.d/grafana.list
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $ sudo apt update
    apt policy influx*
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Get:5 https://apt.grafana.com stable InRelease [5,983 B]
    Get:6 https://deb.nodesource.com/node_16.x bullseye InRelease [4,586 B]
    Get:7 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5,127 B]
    Get:8 https://apt.grafana.com stable/main armhf Packages [114 kB]
    Get:9 https://apt.grafana.com stable/main arm64 Packages [147 kB]
    Fetched 272 kB in 2s (127 kB/s)
    40 packages can be upgraded. Run 'apt list --upgradable' to see them.
    influxdb2-cli:
      Installed: (none)
      Candidate: (none)
      Version table:
    influxdb-client:
      Installed: (none)
      Candidate: 1.6.7~rc0-1+b5
      Version table:
         1.6.7~rc0-1+b5 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    influxdb-dev:
      Installed: (none)
      Candidate: (none)
      Version table:
    influxdb:
      Installed: (none)
      Version table:
         1.6.7~rc0-1+b5 500
    influxdb2:
      Installed: 2.5.1-1
      Candidate: 2.5.1-1
      Version table:
     *** 2.5.1-1 100
    pi@raspberrypi:~ $
    #78
    @bitwicht
    iob nodejs-update
      bitwicht
      #79
      pi@raspberrypi:~ $ iob nodejs-update
      curl: no URL specified!
      curl: try 'curl --help' or 'curl --manual' for more information
      pi@raspberrypi:~ $
      • B bitwicht
        pi@raspberrypi:~ $
        #80
        @bitwicht
        iob stop
        iob fix
        iob start
        wget -q https://repos.influxdata.com/influxdata-archive_compat.key
        echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
        echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
        rm influxdata-archive_compat.key
        iobroker nodejs-update
          bitwicht
          #81
          ich habe das gemacht aber kann nicht mehr alles kopieren
          es kommt:
          Nothing to do - Your installation is using the correct paths.
          You are running nodejs v16.18.1. Do you want to install recommended version 18.19.0?
          Press <y> to continue or any other key to quit
          alles mit y bestätigen ?
          • B bitwicht
            es kommt:
            #82
            @bitwicht
            Ja, du willst nodejs@18 haben.
              bitwicht
              #83
              @Thomas-Braun
              schaut gut aus
              We tried our best to update or fix your nodejs. Please run iob diag again to verify.
              *** RESTARTING ioBroker NOW! ***
               Please refresh or restart your browser in a few moments.
              This system needs to be REBOOTED NOW!
              reboot oder erst noch was anderes ?
              • B bitwicht
                @Thomas-Braun
                schaut gut aus
                #84
                @bitwicht
                sudo reboot
                Und dann nochmal
                sudo apt update
                apt policy influxdb*
                  bitwicht
                  schrieb am zuletzt editiert von bitwicht
                  #85
                  @Thomas-Braun
                  Hit:4 https://repos.influxdata.com/debian stable InRelease
                  Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Hit:6 https://apt.grafana.com stable InRelease
                  Hit:7 http://archive.raspberrypi.org/debian bullseye InRelease
                  Get:8 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5,127 B]
                  Fetched 5,127 B in 2s (2,799 B/s)
                  2 packages can be upgraded. Run 'apt list --upgradable' to see them.
                  pi@raspberrypi:~ $
                  und
                  pi@raspberrypi:~ $ apt policy influxdb*
                  influxdb2-cli:
                    Installed: (none)
                    Candidate: 2.7.3-1
                    Version table:
                       2.7.3-1 500
                          500 https://repos.influxdata.com/debian stable/main arm64 Packages
                       2.7.1-2 500
                       2.6.1 500
                       2.6.0 500
                       2.5.0 500
                       2.4.0 500
                       2.3.0 500
                  influxdb-client:
                    Installed: (none)
                    Version table:
                       1.6.7~rc0-1+b5 500
                  influxdb-dev:
                    Installed: (none)
                    Candidate: (none)
                    Version table:
                  influxdb2-client:
                    Installed: (none)
                    Candidate: 2.7.1-1
                    Version table:
                       2.7.1-1 500
                  influxdb:
                    Installed: (none)
                    Candidate: 1.8.10-1
                    Version table:
                       1.8.10-1 500
                       1.6.7~rc0-1+b5 500
                  influxdb2:
                    Installed: 2.7.4-1
                    Candidate: 2.7.4-1
                    Version table:
                   *** 2.7.4-1 500
                       2.7.3-1 500
                       2.7.1-1 500
                       2.7.0-1 500
                       2.6.1-1 500
                       2.6.0-1 500
                       2.5.1-1 500
                       2.4.0-1 500
                       2.3.0-1 500
                       2.2.0 500
                  pi@raspberrypi:~ $
                  • B bitwicht
                    @Thomas-Braun
                    pi@raspberrypi:~ $
                    und
                    influxdb2-cli:
                      Installed: (none)
                      Candidate: 2.7.3-1
                      Version table:
                         2.7.3-1 500
                         2.7.1-2 500
                         2.6.1 500
                         2.6.0 500
                         2.5.0 500
                         2.4.0 500
                         2.3.0 500
                    influxdb-client:
                      Installed: (none)
                      Version table:
                         1.6.7~rc0-1+b5 500
                    influxdb-dev:
                      Installed: (none)
                      Candidate: (none)
                      Version table:
                    influxdb2-client:
                      Installed: (none)
                      Candidate: 2.7.1-1
                      Version table:
                         2.7.1-1 500
                    influxdb:
                      Installed: (none)
                      Candidate: 1.8.10-1
                      Version table:
                         1.8.10-1 500
                         1.6.7~rc0-1+b5 500
                    influxdb2:
                      Installed: 2.7.4-1
                      Candidate: 2.7.4-1
                      Version table:
                     *** 2.7.4-1 500
                         2.7.3-1 500
                         2.7.1-1 500
                         2.7.0-1 500
                         2.6.1-1 500
                         2.6.0-1 500
                         2.5.1-1 500
                         2.4.0-1 500
                         2.3.0-1 500
                         2.2.0 500
                    pi@raspberrypi:~ $
                    #86
                    @bitwicht
                    Das schaut schon ganz gut aus.
                    sudo apt full-upgrade
                      bitwicht
                      #87
                      schaut ok aus
                      pi@raspberrypi:~ $ sudo apt full-upgrade
                      Calculating upgrade... Done
                      The following package was automatically installed and is no longer required:
                        raspinfo
                      Use 'sudo apt autoremove' to remove it.
                      The following NEW packages will be installed:
                        kms++-utils musl raspi-utils
                      The following packages will be upgraded:
                        grafana raspinfo
                      2 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
                      Need to get 101 MB of archives.
                      After this operation, 68.9 MB of additional disk space will be used.
                      Do you want to continue? [Y/n]
                      Get:1 http://deb.debian.org/debian bullseye/main arm64 musl arm64 1.2.2-1 [399 kB]
                      Get:2 http://archive.raspberrypi.org/debian bullseye/main arm64 kms++-utils arm64 0~git20221104~171243+adc05b6-1 [81.4 kB]
                      Get:3 http://archive.raspberrypi.org/debian bullseye/main arm64 raspinfo all 20230123-1 [2,564 B]
                      Get:4 http://archive.raspberrypi.org/debian bullseye/main arm64 raspi-utils arm64 20230123-1 [41.8 kB]
                      Get:5 https://apt.grafana.com stable/main arm64 grafana arm64 10.2.3 [100 MB]
                      Fetched 101 MB in 19s (5,315 kB/s)
                      Reading changelogs... Done
                      Selecting previously unselected package musl:arm64.
                      (Reading database ... 59837 files and directories currently installed.)
                      Preparing to unpack .../musl_1.2.2-1_arm64.deb ...
                      Unpacking musl:arm64 (1.2.2-1) ...
                      Preparing to unpack .../grafana_10.2.3_arm64.deb ...
                      Unpacking grafana (10.2.3) over (9.2.4) ...
                      Selecting previously unselected package kms++-utils.
                      Preparing to unpack .../kms++-utils_0~git20221104~171243+adc05b6-1_arm64.deb ...
                      Unpacking kms++-utils (0~git20221104~171243+adc05b6-1) ...
                      Preparing to unpack .../raspinfo_20230123-1_all.deb ...
                      Unpacking raspinfo (20230123-1) over (20190624-1) ...
                      Selecting previously unselected package raspi-utils.
                      Preparing to unpack .../raspi-utils_20230123-1_arm64.deb ...
                      Unpacking raspi-utils (20230123-1) ...
                      Setting up kms++-utils (0~git20221104~171243+adc05b6-1) ...
                      Setting up musl:arm64 (1.2.2-1) ...
                      Setting up grafana (10.2.3) ...
                      Installing new version of config file /etc/init.d/grafana-server ...
                      Installing new version of config file /usr/lib/systemd/system/grafana-server.service ...
                      Restarting grafana-server service... OK
                      Setting up raspi-utils (20230123-1) ...
                      Setting up raspinfo (20230123-1) ...
                      Processing triggers for man-db (2.9.4-2) ...
                      pi@raspberrypi:~ $
                      • B bitwicht
                        schaut ok aus
                          raspinfo
                          grafana raspinfo
                        pi@raspberrypi:~ $
                        #88
                        @bitwicht
                        Jetzt solltest du wieder 'auf Spur' sein.
                        Schau dir das Bild jetzt in Gänze an.
                        iob diag
                        gibt dir den Überblick.
                          bitwicht
                          #89
                          @Thomas-Braun
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                             Static hostname: raspberrypi
                                   Icon name: computer
                            Operating System: Debian GNU/Linux 11 (bullseye)
                                      Kernel: Linux 6.1.21-v8+
                                Architecture: arm64
                          Model           : Raspberry Pi 4 Model B Rev 1.4
                          Docker          : false
                          Virtualization  : none
                          Kernel          : aarch64
                          Userland        : arm64
                          Systemuptime and Load:
                           18:00:00 up 13 min,  1 user,  load average: 0.48, 0.49, 0.39
                          CPU threads: 4
                          *** RASPBERRY THROTTLING ***
                          Current issues:
                          Previously detected issues:
                          *** Time and Time Zones ***
                                         Local time: Mon 2024-01-08 18:00:00 CET
                                     Universal time: Mon 2024-01-08 17:00:00 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          *** User and Groups ***
                          pi
                          /home/pi
                          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                          *** X-Server-Setup ***
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          Boot Target:    multi-user.target
                          *** MEMORY ***
                          Mem:            7.8G        1.2G        5.4G        1.0M        1.3G        6.5G
                          Swap:            99M          0B         99M
                          Total:          7.9G        1.2G        5.5G
                                   7811 M total memory
                                   1169 M used memory
                                   1509 M active memory
                                    760 M inactive memory
                                   5389 M free memory
                                     49 M buffer memory
                                   1202 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FAILED SERVICES ***
                          0 loaded units listed.
                          *** FILESYSTEM ***
                          /dev/root      ext4      220G  5.7G  206G   3% /
                          devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                          tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
                          /dev/sda1      vfat      255M   31M  225M  13% /boot
                          tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
                          [Mon Jan  8 17:46:59 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:5F:78:11 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=c382a905-02 rootfstype=ext4 fsck.repair=yes rootwait
                          [Mon Jan  8 17:47:01 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                          [Mon Jan  8 17:47:01 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                          [Mon Jan  8 17:47:02 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                          TARGET  SOURCE    FSTYPE OPTIONS
                          /       /dev/sda2 ext4   rw,noatime
                          `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                          /var:
                          2.4G    /var/
                          1.1G    /var/log/journal/06df86f59cbd48888af076fdae20e584
                          1.1G    /var/log
                          903M    /var/lib
                          Archived and active journals take up 1.0G in the file system.
                          /opt/iobroker/backups:
                          9.2M    /opt/iobroker/backups/
                          /opt/iobroker/iobroker-data:
                          192M    /opt/iobroker/iobroker-data/
                          113M    /opt/iobroker/iobroker-data/files
                          67M     /opt/iobroker/iobroker-data/files/javascript.admin
                          55M     /opt/iobroker/iobroker-data/backup-objects
                          48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                          22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js.map
                          21M     /opt/iobroker/iobroker-data/objects.jsonl
                          8.9M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js
                          7.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
                          7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.d3cce782.chunk.js.map
                          USB-Devices by-id:
                          find: '/dev/serial/by-id/': No such file or directory
                          *** NodeJS-Installation ***
                          /usr/bin/nodejs         v18.19.0
                          /usr/bin/node           v18.19.0
                          /usr/bin/npm            10.2.3
                          /usr/bin/npx            10.2.3
                          /usr/bin/corepack       0.22.0
                          nodejs:
                            Installed: 18.19.0-1nodesource1
                            Candidate: 18.19.0-1nodesource1
                            Version table:
                           *** 18.19.0-1nodesource1 1001
                                  500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                               18.18.2-1nodesource1 1001
                               18.18.1-1nodesource1 1001
                               18.18.0-1nodesource1 1001
                               18.17.1-1nodesource1 1001
                               18.17.0-1nodesource1 1001
                               18.16.1-1nodesource1 1001
                               18.16.0-1nodesource1 1001
                               18.15.0-1nodesource1 1001
                               18.14.2-1nodesource1 1001
                               18.14.1-1nodesource1 1001
                               18.14.0-1nodesource1 1001
                               18.13.0-1nodesource1 1001
                               18.12.0-1nodesource1 1001
                               18.11.0-1nodesource1 1001
                               18.10.0-1nodesource1 1001
                               18.9.1-1nodesource1 1001
                               18.9.0-1nodesource1 1001
                               18.8.0-1nodesource1 1001
                               18.7.0-1nodesource1 1001
                               18.6.0-1nodesource1 1001
                               18.5.0-1nodesource1 1001
                               18.4.0-1nodesource1 1001
                               18.3.0-1nodesource1 1001
                               18.2.0-1nodesource1 1001
                               18.1.0-1nodesource1 1001
                               18.0.0-1nodesource1 1001
                               12.22.12~dfsg-1~deb11u4 500
                                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                          No problems detected
                          Errors in npm tree:
                          *** ioBroker-Installation ***
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Core adapters versions
                          js-controller:  5.0.17
                          admin:          6.12.0
                          javascript:     7.1.6
                          Adapters from github:   2
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                          + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
                          + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                          + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
                            system.adapter.modbus.1                 : modbus                : raspberrypi                              - disabled
                          + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                          + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                          + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                            system.adapter.solaredge.0              : solaredge             : raspberrypi                              - disabled
                            system.adapter.solarlog.0               : solarlog              : raspberrypi                              - disabled, port: 80
                          + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1884, bind: 0.0.0.0
                          + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
                          + system.adapter.wolf.0                   : wolf                  : raspberrypi                              -  enabled, port: 12004, bind: 0.0.0.0
                          + instance is alive
                          ioBroker-Repositories
                          Active repo(s): stable
                          Installed ioBroker-Instances
                          Used repository: stable
                          Adapter    "admin"        : 6.12.0   , installed 6.12.0
                          Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                          Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                          Adapter    "email"        : 1.2.1    , installed 1.2.1
                          Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                          Controller "js-controller": 5.0.17   , installed 5.0.17
                          Adapter    "modbus"       : 6.0.1    , installed 6.0.1
                          Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
                          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                          Adapter    "solarlog"     : 2.2.8    , installed 2.2.8
                          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                          Adapter    "wolf"         : 1.7.0    , installed 1.7.0
                          Objects and States
                          Objects:        3856
                          States:         3341
                          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                          Hit:2 http://deb.debian.org/debian bullseye InRelease
                          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                          Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
                          Get:6 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5127 B]
                          Hit:7 https://apt.grafana.com stable InRelease
                          Hit:8 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Fetched 5127 B in 2s (2723 B/s)
                          Pending Updates: 0
                          *** Listening Ports ***
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15375      889/iobroker.js-con
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15368      889/iobroker.js-con
                          tcp        0      0 0.0.0.0:12004           0.0.0.0:*               LISTEN      1001       16425      988/io.wolf.0
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13710      542/sshd: /usr/sbin
                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       15489      1035/io.mqtt.0
                          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       14994      1065/io.shelly.1
                          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       15512      1050/io.sonoff.0
                          tcp6       0      0 :::7070                 :::*                    LISTEN      112        24220      2003/evcc
                          tcp6       0      0 :::3000                 :::*                    LISTEN      111        23600      1868/grafana
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13891      916/io.admin.0
                          tcp6       0      0 :::8086                 :::*                    LISTEN      110        12249      768/influxd
                          tcp6       0      0 :::502                  :::*                    LISTEN      112        24218      2003/evcc
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          13712      542/sshd: /usr/sbin
                          tcp6       0      0 :::80                   :::*                    LISTEN      0          14638      553/apache2
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12071      391/avahi-daemon: r
                          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       16495      1020/io.shelly.0
                          udp        0      0 0.0.0.0:51516           0.0.0.0:*                           1001       30382      -
                          udp        0      0 0.0.0.0:52317           0.0.0.0:*                           108        12073      391/avahi-daemon: r
                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13720      762/dhcpcd
                          udp6       0      0 :::5353                 :::*                                108        12072      391/avahi-daemon: r
                          udp6       0      0 :::49554                :::*                                108        12074      391/avahi-daemon: r
                          udp6       0      0 :::546                  :::*                                0          13805      762/dhcpcd
                          2024-01-08 17:59:47.868  - info: influxdb.0 (938) Influx DB Version used: 2.x
                          2024-01-08 17:59:47.876  - error: influxdb.0 (938) HttpError: unauthorized access
                          2024-01-08 17:59:57.875  - info: influxdb.0 (938) Connecting http://localhost:8086/ ...
                          2024-01-08 17:59:57.876  - info: influxdb.0 (938) Influx DB Version used: 2.x
                          2024-01-08 17:59:57.881  - error: influxdb.0 (938) HttpError: unauthorized access
                          2024-01-08 18:00:00.195  - info: javascript.0 (954) script.js.Strom_Shelly_Verbrauch-Historie_mqtt: Shelly Verbrauch: Verbrauchswerte aktualisiert: 1 | Reboots korrigiert: 0 | Unveränderte Werte: 0
                          2024-01-08 18:00:00.283  - info: javascript.0 (954) script.js.Strom_Shelly_Verbrauchs-Historie: Shelly Verbrauch: Verbrauchswerte aktualisiert: 26 | Reboots korrigiert: 0 | Unveränderte Werte: 51
                          2024-01-08 18:00:07.882  - info: influxdb.0 (938) Connecting http://localhost:8086/ ...
                          2024-01-08 18:00:07.882  - info: influxdb.0 (938) Influx DB Version used: 2.x
                          2024-01-08 18:00:07.887  - error: influxdb.0 (938) HttpError: unauthorized access
                          2024-01-08 18:00:17.889  - info: influxdb.0 (938) Connecting http://localhost:8086/ ...
                          2024-01-08 18:00:17.889  - info: influxdb.0 (938) Influx DB Version used: 2.x
                          2024-01-08 18:00:17.894  - error: influxdb.0 (938) HttpError: unauthorized access
                          2024-01-08 18:00:27.897  - info: influxdb.0 (938) Connecting http://localhost:8086/ ...
                          2024-01-08 18:00:27.898  - info: influxdb.0 (938) Influx DB Version used: 2.x
                          2024-01-08 18:00:27.906  - error: influxdb.0 (938) HttpError: unauthorized access
                          2024-01-08 18:00:37.906  - info: influxdb.0 (938) Connecting http://localhost:8086/ ...
                          2024-01-08 18:00:37.907  - info: influxdb.0 (938) Influx DB Version used: 2.x
                          2024-01-08 18:00:37.915  - error: influxdb.0 (938) HttpError: unauthorized access
                          2024-01-08 18:00:47.916  - info: influxdb.0 (938) Connecting http://localhost:8086/ ...
                          2024-01-08 18:00:47.916  - info: influxdb.0 (938) Influx DB Version used: 2.x
                          2024-01-08 18:00:47.921  - error: influxdb.0 (938) HttpError: unauthorized access
                          2024-01-08 18:00:57.921  - info: influxdb.0 (938) Connecting http://localhost:8086/ ...
                          2024-01-08 18:00:57.921  - info: influxdb.0 (938) Influx DB Version used: 2.x
                          2024-01-08 18:00:57.927  - error: influxdb.0 (938) HttpError: unauthorized access
                          iob diag has finished.
                          Press any key for a summary
                          unten sind noch Fehler ?
                            bitwicht
                            #90
                            @Thomas-Braun
                            bitte:
                                                    v.2023-10-10
                                     Icon name: computer
                                  Architecture: arm64
                            Kernel:                 aarch64
                            Userland:               arm64
                            Timezone:               Europe/Berlin (CET, +0100)
                            User-ID:                1000
                            X-Server:               false
                            Pending OS-Updates:     0
                            Pending iob updates:    0
                            Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                                    /usr/bin/npm            10.2.3
                                                    /usr/bin/npx            10.2.3
                            Recommended versions are nodejs 18.19.0 and npm 10.2.3
                            MEMORY:
                            Mem:            7.8G        1.6G        4.9G        1.0M        1.3G        6.1G
                            Swap:            99M          0B         99M
                            Total:          7.9G        1.6G        5.0G
                            Active iob-Instances:   14
                            ioBroker Core:          js-controller           5.0.17
                                                    admin                   6.12.0
                            Objects type: jsonl
                            States  type: jsonl
                            Objects:                3856
                            States:                 3341
                            Size of iob-Database:
                            6.9M    /opt/iobroker/iobroker-data/states.jsonl
                            === Mark text until here for copying ===
                            pi@raspberrypi:~ $
                            • B bitwicht
                              @Thomas-Braun
                              bitte:
                                                      v.2023-10-10
                                       Icon name: computer
                                    Architecture: arm64
                              Kernel:                 aarch64
                              Userland:               arm64
                              User-ID:                1000
                              X-Server:               false
                                                      /usr/bin/npm            10.2.3
                                                      /usr/bin/npx            10.2.3
                              MEMORY:
                              Swap:            99M          0B         99M
                                                      admin                   6.12.0
                              Objects type: jsonl
                              States  type: jsonl
                              Objects:                3856
                              States:                 3341
                              pi@raspberrypi:~ $
                              #91
                              @bitwicht
                              Das System ist jetzt grundsätzlich richtig.
                              Bei den Fehlern aus dem Log kann dir vermutlich @Marc-Berg weiterhelfen. Von influxdb hab ich nämlich keine Ahnung.
                                bitwicht
                                #92
                                Vielen Danke.
                                Das heißt ich kann jetzt immer über den Paketmanager gehen?
                                @Marc-Berg @Thomas-Braun
                                Der Influx Adapter läuft jetzt nicht mehr:
                                influxdb.0
                                2024-01-08 18:38:49.775	error	HttpError: unauthorized access
                                influxdb.0
                                2024-01-08 18:38:49.769	info	Influx DB Version used: 2.x
                                influxdb.0
                                2024-01-08 18:38:49.769	info	Connecting http://localhost:8086/ ...
                                • B bitwicht
                                  Vielen Danke.
                                  influxdb.0
                                  influxdb.0
                                  influxdb.0
                                  #93
                                  @bitwicht sagte in Ertrag (Tag, Monat, Jahr) berechnen und in Datei speichern:
                                  Ja, das schwimmt jetzt alles beim Paketmanager mit.
                                  Per
                                  sudo apt update
                                  regelmäßig dabei bleiben.
                                    bitwicht
                                    #94
                                    @Thomas-Braun @Marc-Berg
                                    jetzt habe ich aber ein Problem.
                                    Wenn ich auf die Weboberfläche der Influx gehe, kommt "Get Started"
                                    Sind jetzt alle meine Daten weg ?
                                    • B bitwicht
                                      #95
                                      Das musst du @Marc-Berg fragen. Wie gesagt, ich verwende influxdb nicht. Da müssen irgendwie irgendwo irgendwelche Tokens (Die hast du noch?) hinterlegt werden, wenn ich das richtig weiß.
                                        bitwicht
                                        #96
                                        @Thomas Braun
                                        Ich warte mal auf @Marc-Berg
                                        Ich habe die Token noch aber es sieht so aus als ob die Influx komplett neu ist.
                                        Auf der Weboberfläche kommt "Get Started" und ich soll den Admin User neu vergeben, etc.
                                        • B bitwicht
                                          @Thomas Braun
                                          #97
                                          @bitwicht
                                          Dann müsste man wohl die alten Datenbanken reinholen können.
