  4. Test ioBroker unter Windows installieren - 2023 Edition
    6.8k
installation iobrokerwindowswindows installation
405 Beiträge 25 Kommentatoren 120.8k Aufrufe 22 Beobachtet
  • K klassisch
    @gaspode sagte in Test ioBroker unter Windows installieren - 2023 Edition:
    Schon neu gebootet? :D
    Gerade jetzt. unverändert, ist weg:
    Normalerweise boote ich ja nur nach Win Updates.
    Ich verstehe gar nichts:
    ioBroker wird beendet.
    ioBroker wurde erfolgreich beendet.
    C:\ioBroker>npm install @iobroker/fix
    added 5 packages, removed 3 packages, changed 3 packages, and audited 2462 packages in 51s
    193 packages are looking for funding
      run `npm fund` for details
    121 vulnerabilities (4 low, 62 moderate, 44 high, 11 critical)
    To address issues that do not require attention, run:
      npm audit fix
    To address all issues possible (including breaking changes), run:
      npm audit fix --force
    Some issues need review, and may require choosing
    a different dependency.
    Run `npm audit` for details.
    C:\ioBroker> node node_modules\@iobroker\fix\lib-npx\install.js fix
    Windows installation starting... (fixing = true)
    NPM version: 10.2.3
    No path given, using C:\ioBroker\iobroker-data
    Compressing C:\ioBroker\iobroker-data\states.jsonl
    Compressing C:\ioBroker\iobroker-data\objects.jsonl
    Compressed 2 JSONL files. Done
    NPM version: 10.2.3
    Write "iobroker start" to start the ioBroker
    npm install node-windows@1.0.0-beta.8 --force --loglevel error --production --save --prefix "C:/ioBroker"
    up to date, audited 2462 packages in 7s
      npm audit fix
    npm install dotenv@^16.0.3 --force --loglevel error --production --save --prefix "C:/ioBroker"
    changed 1 package, and audited 2462 packages in 7s
    192 packages are looking for funding
      npm audit fix
    npm install windows-shortcuts@^0.1.6 --force --loglevel error --production --save --prefix "C:/ioBroker"
      npm audit fix
    Running Admin shell
    ioBroker service name: ioBroker
    ioBroker ist nicht gestartet.
    Sie erhalten weitere Hilfe, wenn Sie NET HELPMSG 3521 eingeben.
    Written iobnodevars.bat successfully.
    ioBroker service is already installed.
    Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\ioBroker Admin.lnk" created!
    Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\ioBroker Command line.lnk" created with Admin flag!
    Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\Restart ioBroker Service.lnk" created with Admin flag!
    Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\Start ioBroker Service.lnk" created with Admin flag!
    Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\Stop ioBroker Service.lnk" created with Admin flag!
    Running Admin shell
    ioBroker wird gestartet.
    ioBroker wurde erfolgreich gestartet.
    ioBroker service installed and started. Go to http://localhost:8081 to open the admin UI.
    To see the outputs do not start the service, but write "node node_modules/iobroker.js-controller/controller"
    C:\ioBroker>
    Edit:
    Ach ja, aufräumen kannst du anschließend mit
    npm uninstall @iobroker/fix
    ioBroker is automatisch wieder gestartet
    GaspodeG Online
    GaspodeG Online
    Gaspode
    #228
    @klassisch said in Test ioBroker unter Windows installieren - 2023 Edition:
    Der Fixer ist erfolgreich gelaufen. Es liegt also tatsächlich an einer verkorksten npx Installation auf deinem Rechner.
    Ich überleg mir was ...
    • GaspodeG Gaspode
      klassisch
      #229
      @gaspode Vielen Dank, dann führe ich mal das Aufräumkommando aus.
      War zu befürchten. Alte Installation mit langer Historie.
      GaspodeG 1 Antwort Letzte Antwort
      • K klassisch
        GaspodeG Online
        GaspodeG Online
        Gaspode
        #230
        @klassisch
        Mir fällt nur dazu ein, dass du Node mal komplett deinstallieren könntest. eine Anleitung findest du z.B- hier:
        https://www.geeksforgeeks.org/how-to-completely-remove-node-js-from-windows/
        ioBroker natürlich vorher anhalten.
        Anschließend dann den ioBroker Installer starten, der sollte erkennen, dass Node.js installiert werden muss.
        • JB_SullivanJ JB_Sullivan
          @mcm57 sagte in Test ioBroker unter Windows installieren - 2023 Edition:
          Wenn du weißt oder vermutest dass es der Adapter xyz ist warum stoppst du dann die Instanz nicht ganz normal?
          Und wenns via gui nicht geht dann via commandline?
          Ich wusste zu dem Zeitpunkt nicht, welcher Adapter es war. Ich konnte zwar sehen das ein NODE Prozess 75% Systemauslastung produzierte, aber welcher Adapter es war, wusste ich da noch nicht.
          Ich bin erst durch das Forum durch einen einen entsprechenden Beitrag eines anderen Betroffenen darauf aufmerksam gemacht worden, das der device-watcher die System Last nach oben pusht.
          Darum ja auch die Anfrage bzgl. der Klarnameszusätze bei den NODE Prozessen.
          mcm1957M Online
          mcm1957M Online
          mcm1957
          #231
          @jb_sullivan said in Test ioBroker unter Windows installieren - 2023 Edition:
          Im Resourcen Monitor kannst du dir die File Handles ansehen. Da siehst du welches js der Prozess offen hat.
          Hier z.B. der backitup:
          Ist hier OT. Wenn du da mehr Diskussionsbedarf siehst, sollten wir neue Topic öffnen.
          Support Repositoryverwaltung.
          LESEN - gute Forenbeitrage
            Aus gegebenen Anlass hätte ich eine Frage.
            Die Tage gab es ein Update des Adapter "device-watcher". Irgend etwas wurde dort "falsch" gemacht, was nahezu den gesamten ioBroker zum erliegen brachte (CPU / RAM Ausnutzung = 100%). Damit war ioBroker fast nicht mehr bedienbar (z.B. Instanzen stoppen) . Auch eine korrigierte Adapter Version brauchte Stunden um über GIT eingespielt zu werden.
            Unter Windows sieht man ja nun im Task Manager alle laufenden NODE Prozesse. Ich gehe davon aus, das jeder Node Prozess, ein laufender Adapter ist. Leider heißen alle Prozesse NODE. Man kann also über den Task Manager nicht gezielt NODE Prozesse (= Adapter) abbrechen oder stoppen.
            Ist das etwas Windows spezifisches, was man ggf. mit der ioBroker Installation über den WIN Installer lösen könnte? Soll heißen, könnte man jedem Node Prozess in Windows ggf. den Adapter Namen anhängen?
            Somit könnte man in solchen Ausnahme Situationen wie oben beschrieben, eine Adapter Instanz ggf. auch gezielt über den Windows Task Manager abbrechen / stoppen.
            Ist diese Idee völliger Bullshit oder Wert, ggf. einmal darüber nachzudenken?
            UweRLPU Offline
            UweRLPU Offline
            UweRLP
            #232
            @jb_sullivan sagte in Test ioBroker unter Windows installieren - 2023 Edition:
            Geht schon:
            Über die Befehlszeile kann eine Zuordnug erfolgen.
            • JB_SullivanJ Offline
              JB_Sullivan
              #233
              Danke für die Antworten an mich - aber wie schon erwähnt ist das in diesem Thread alles OT, darum bitte hier weitermachen -> https://forum.iobroker.net/topic/71664/dfsg-node-bug-auch-bei-windows/9?_=1704554411649
              Vielleicht kann ein Admin die Beiträge zu dem bestehenden Thread zusammenführen.
              @UweRLP
              Wie geht das? - Bitte im neuen Thread antworten. Bei mir wird da nix angezeigt und es gibt auch keine Einstellung die Ansicht entsprechend zu erweitern.
                #234
                Welche npm version?
                JB_SullivanJ mcm1957M 2 Antworten Letzte Antwort
                • apollon77A apollon77
                  Welche npm version?
                  JB_Sullivan
                  #235
                  @apollon77
                  NPM 10.2.3
                    Welche npm version?
                    mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    #236
                    @apollon77 said in Test ioBroker unter Windows installieren - 2023 Edition:
                    Welche npm version?
                    Wenn ich die Sache richtig verfolgt habe ist damit gemeint, dass
                    a) ein Adapter Amok gelaufen ist und die CPU bzw. js-controller dicht gemacht hat
                    b) der Adapter "nicht gestoppt werden konnte" und der Update bei überlastetem System ewig gedauert hat (no na, wenn die CPU dicht ist ...
                    War wenn ich mich nicht irre zu 100% ein Adapterproblem.
                    • mcm1957M mcm1957
                      Welche npm version?
                      JB_Sullivan
                      #237
                      @mcm57 Genau so war es - hatte nichts mit der Download Geschwindigkeit zu tun, sondern weil das lokale System nahezu eingefroren war.
                        @apollon77
                        NPM 10.2.3
                        #238
                        @jb_sullivan Ok, dann ists nicht das "offensichtliche" ;-) Gab mal npm versionen wo es bei GitHub updates solche effekte gab. Aber nicht in Npm 10
                        • GaspodeG Online
                          GaspodeG Online
                          Gaspode
                          #239
                          wer hat Lust, bei einem kleinen Test der nächsten Installer-Version mitzumachen?
                          Es wird zunächst zwei kleinere Änderungen geben:
                          1. Der Installer prüft beim Start, ob es eine neuere Version gibt
                          2. Die empfohlene Node.js Version wird auf eine andere Art ermittelt als bisher, da die alte Quelle nicht länger supportet wird.
                          Zunächst würde ich gerne Punkt 1 von euch testen lassen. Dafür müsstet ihr aber eine spezielle Testversion des Installers installieren. Wer Interesse hat, bitte per Mail an gaspode@online.de melden.
                          sigi234S arteckA mcm1957M 3 Antworten Letzte Antwort
                          • GaspodeG Gaspode
                            sigi234S Online
                            sigi234S Online
                            #240
                            @gaspode
                            Bin dabei
                            • GaspodeG Gaspode
                              arteckA Offline
                              arteckA Offline
                              arteck
                              #241
                              @gaspode stell die Test Version doch ins GIT ..
                              • arteckA arteck
                                GaspodeG Online
                                GaspodeG Online
                                Gaspode
                                schrieb am zuletzt editiert von Gaspode
                                #242
                                @arteck said in Test ioBroker unter Windows installieren - 2023 Edition:
                                Nee, ist ein unsigniertes EXE File, das möchte ich eigentlich nicht in der Öffentlichkeit haben. In Kürze gibt es auch die endgültige signierte Version 3.0.0. Der aktuelle Test testet wirklich nur die Versionsprüfung.
                                • sigi234S sigi234
                                  @gaspode
                                  Bin dabei
                                  GaspodeG Online
                                  GaspodeG Online
                                  Gaspode
                                  #243
                                  @sigi234 said in Test ioBroker unter Windows installieren - 2023 Edition:
                                  Bin dabei
                                  Super, Danke! Du hast Post. :)
                                  • GaspodeG Gaspode
                                    klassisch
                                    #244
                                    Ich habe nur ein Produktivsystem, welches auch wirklich laufen muß.
                                    Wenn man den Installer nach der Versionsprüfung abbrechen und ein log (oder so) hier posten kann, bin ich dabei.
                                    Schließlich hat mir die aktuelle Version ein einfaches nodejs Update ermöglicht. Nochmans Danke dafür.
                                    • GaspodeG Gaspode
                                      mcm1957M Online
                                      mcm1957M Online
                                      mcm1957
                                      #245
                                      @gaspode
                                      Wenn du magst kann ichs testen. (Mail geschickt)
                                      Windows Systeme (win 10) sind bei mir nur Testsysteme / Scratchsysteme.
                                      • K klassisch
                                        GaspodeG Online
                                        GaspodeG Online
                                        Gaspode
                                        #246
                                        Danke, für den Test sollte schon ein kompletter Update Durchlauf gemacht werden, das kann aber auch nur das Ändern der Firewall Regeln oder des Windows Service Startmodus sein, also minimal invasiv. ;)
                                        Aber ich denke, wenn @mcm57 und @sigi234 diesen Teil (hoffentlich erfolgreich) getestet haben, können wir danach recht zügig zu einem allgemeinen Test übergehen.
                                        @mcm57
                                        Du hast Post. Vielen Dank!
                                        • GaspodeG Online
                                          GaspodeG Online
                                          Gaspode
                                          #247
                                          Da @sigi234 bereits erfolgreich das Update und den Installer selbst getestet hat (vielen Dank dafür) und mit @mcm57 noch ein weiterer Update Tester in den Startlöchern steht, können wir, denke ich, mit dem öffentlichen Test beginnen. Die Version 3.0.0 kann hier heruntergeladen werden: https://iobroker.live/images/win/iobroker-installer-3.0.0.exe
                                          Es gibt wie gesagt nur diese beiden Änderungen:
                                          Viel Spaß beim Testen!
