  4. Lupusec - keine Verbindung nach Neuinstallation [gelöst]
    6.1k
37 Beiträge 3 Kommentatoren 2.2k Aufrufe 3 Beobachtet
  • M mkreu
    @glasfaser
    Hier der Log-Auszug:
    2024-01-06 23:40:48.432 - info: host.ct-iobroker01 "system.adapter.lupusec.0" enabled
    2024-01-06 23:40:48.495 - info: host.ct-iobroker01 instance system.adapter.lupusec.0 started with pid 930
    2024-01-06 23:40:49.921 - debug: lupusec.0 (930) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2024-01-06 23:40:49.944 - debug: lupusec.0 (930) Objects client ready ... initialize now
    2024-01-06 23:40:49.946 - debug: lupusec.0 (930) Objects create System PubSub Client
    2024-01-06 23:40:49.948 - debug: lupusec.0 (930) Objects create User PubSub Client
    2024-01-06 23:40:49.964 - debug: lupusec.0 (930) Objects client initialize lua scripts
    2024-01-06 23:40:49.971 - debug: lupusec.0 (930) Objects connected to redis: 127.0.0.1:9001
    2024-01-06 23:40:49.987 - debug: lupusec.0 (930) Redis States: Use Redis connection: 127.0.0.1:9000
    2024-01-06 23:40:49.995 - debug: lupusec.0 (930) States create System PubSub Client
    2024-01-06 23:40:49.996 - debug: lupusec.0 (930) States create User PubSub Client
    2024-01-06 23:40:50.005 - debug: lupusec.0 (930) States connected to redis: 127.0.0.1:9000
    2024-01-06 23:40:50.033 - debug: lupusec.0 (930) Plugin sentry Do not initialize Plugin (enabled=false)
    2024-01-06 23:40:50.040 - debug: lupusec.0 (930) Plugin sentry destroyed because not initialized correctly
    2024-01-06 23:40:50.138 - info: lupusec.0 (930) starting. Version 1.3.6 in /opt/iobroker/node_modules/iobroker.lupusec, node: v18.19.0, js-controller: 5.0.17
    2024-01-06 23:40:50.157 - info: lupusec.0 (930) Starting Adapter lupusec.0 in version 1.3.6
    2024-01-06 23:40:50.205 - error: lupusec.0 (930) Lupusec Alarmsystem 192.168.140.22 is not reachable
    2024-01-06 23:40:50.206 - info: lupusec.0 (930) Terminated (ADAPTER_REQUESTED_TERMINATION): Not reachable
    2024-01-06 23:40:50.755 - info: host.ct-iobroker01 instance system.adapter.lupusec.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    2024-01-06 23:40:50.756 - info: host.ct-iobroker01 Do not restart adapter system.adapter.lupusec.0 because desired by instance
    Ich hoffe, ich hab's richtig gemacht... ;-)
    GlasfaserG Offline
    GlasfaserG Offline
    @mkreu sagte in Lupusec Adapter - keine Verbindung nach Neuinstallation:
    Ja ...
    und wo ist die Ein und Ausgabe zu deinem Ping , die fehlt noch !?
    • GlasfaserG Glasfaser
      Ja ...
      mkreu
      @glasfaser
      root@ct-iobroker01:/home/mkreu# ping 192.168.140.22
      PING 192.168.140.22 (192.168.140.22) 56(84) bytes of data.
      64 bytes from 192.168.140.22: icmp_seq=1 ttl=63 time=1.81 ms
      64 bytes from 192.168.140.22: icmp_seq=2 ttl=63 time=2.25 ms
      64 bytes from 192.168.140.22: icmp_seq=3 ttl=63 time=1.74 ms
      64 bytes from 192.168.140.22: icmp_seq=4 ttl=63 time=0.781 ms
      64 bytes from 192.168.140.22: icmp_seq=5 ttl=63 time=2.08 ms
      64 bytes from 192.168.140.22: icmp_seq=6 ttl=63 time=1.68 ms
      64 bytes from 192.168.140.22: icmp_seq=7 ttl=63 time=1.56 ms
      64 bytes from 192.168.140.22: icmp_seq=8 ttl=63 time=1.86 ms
      64 bytes from 192.168.140.22: icmp_seq=9 ttl=63 time=2.27 ms
      64 bytes from 192.168.140.22: icmp_seq=10 ttl=63 time=1.22 ms
      ^C
      --- 192.168.140.22 ping statistics ---
      10 packets transmitted, 10 received, 0% packet loss, time 9039ms
      rtt min/avg/max/mdev = 0.781/1.724/2.273/0.435 ms
      DJMarc75D GlasfaserG 2 Antworten Letzte Antwort
      • M mkreu
        @glasfaser
        ^C
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        root
        bitte nicht - leg Dir einen normalen User an
        Lehrling seit 1975 !!!
        • M mkreu
          @glasfaser
          ^C
          GlasfaserG Offline
          GlasfaserG Offline
          Erstmal ist es nicht der Benutzer iobroker der den Befehl ausführt ..
          und zweitens bitte nicht als root sondern als User anmelden .
          Pings du von iobroker aus von der VM !?
          /home/mkreu
            /home/mkreu
            mkreu
            schrieb am zuletzt editiert von mkreu
            @glasfaser
            Sorry, ich bin nicht wirklich der Held in Linux...
            Ja, ich pinge direkt aus der VM bzw. von dem LXC-Container...
            Kann ich mich mit dem User iobroker anmelden..?
            • M mkreu
              @glasfaser
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              Du hast doch bestimmt einen Vornamen ;) Dann leg Dir einen User mit Deinem Vornamen an und melde Dich damit an !
              • GlasfaserG Offline
                GlasfaserG Offline
                dann vermute ich mal der ping ist root
                zeigen
                ls -la /bin/ping
                • DJMarc75D DJMarc75
                  mkreu
                  @djmarc75
                  Ich hab ja einen User "mkreu" angelegt. Nur da fehlt es mir irgendwie noch an Rechten...
                  Dann brauche ich ein sudo zum pingen...
                    zeigen
                    ls -la /bin/ping
                    mkreu
                    @glasfaser ```
                    mkreu@ct-iobroker01:~$ ls -la /bin/ping
                    -rwxr-xr-x 1 root root 90568 Nov 27 2022 /bin/ping
                    • M mkreu
                      @glasfaser ```
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @mkreu
                      dann :
                      sudo chmod u+s /bin/ping
                      und danach den Adapter neu starten
                        @mkreu
                        dann :
                        mkreu
                        @glasfaser
                        Okay, jetzt ist der Adapter zumindest schon mal grün - und bleibt es auch...
                        Was war das jetzt..?
                        Aber unter den Objekten tauchen die Devices nicht auf. Hast du da eine Idee..?
                          GlasfaserG Offline
                          dein System ioBroker mit root .
                          und was braucht man dazu ... mhh .
                          Zeige mal ein Debug Log davon ;)
                          • M mkreu
                            @glasfaser
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @mkreu
                            und ein Hinweis noch von mir ...
                            ich habe diesen Adapter nicht ,deshalb sind Infos / Inputs immer hilfreich !
                              @mkreu
                              mkreu
                              @glasfaser ```
                              await lupusecAsync.deviceGet();
                              await lupusecAsync.deviceListGet();
                              await lupusecAsync.devicePSSListGet();
                              await lupusecAsync.panelCondGet();
                              await lupusecAsync.deviceListUPICGet();
                              await lupusecAsync.deviceEditAllGet();
                              await lupusecAsync.deviceAllGet();
                              await lupusecAsync.logsGetPost();
                              if (adapter.config.webcam_providing) await lupusecAsync.getWebcamSnapshots();
                              2024-01-07 00:12:55.380 - debug: lupusec.0 (1089) Process: {"key":1704582738600,"functname":"async () => {\n /
                              \n await lupusecAsync.deviceGet();\n /\n await lupusecAsync.deviceListGet();\n await lupusecAsync.devicePSSListGet();\n await lupusecAsync.panelCondGet();\n await lupusecAsync.deviceListUPICGet();\n await lupusecAsync.deviceEditAllGet();\n await lupusecAsync.deviceAllGet();\n await lupusecAsync.logsGetPost();\n if (adapter.config.webcam_providing) await lupusecAsync.getWebcamSnapshots();\n }","loop":true,"time":0,"localtime":1704582774369}
                              2024-01-07 00:12:56.389 - debug: lupusec.0 (1089) Process Queue: [{"key":1704582738600,"functname":"async () => {\n /
                              \n await lupusecAsync.deviceGet();\n /\n await lupusecAsync.deviceListGet();\n await lupusecAsync.devicePSSListGet();\n await lupusecAsync.panelCondGet();\n await lupusecAsync.deviceListUPICGet();\n await lupusecAsync.deviceEditAllGet();\n await lupusecAsync.deviceAllGet();\n await lupusecAsync.logsGetPost();\n if (adapter.config.webcam_providing) await lupusecAsync.getWebcamSnapshots();\n }","loop":true,"time":0,"localtime":1704582775379}]
                              2024-01-07 00:12:56.389 - debug: lupusec.0 (1089) Function: async () => {
                              2024-01-07 00:12:56.390 - debug: lupusec.0 (1089) Process: {"key":1704582738600,"functname":"async () => {\n /
                              2024-01-07 00:12:57.398 - debug: lupusec.0 (1089) Process Queue: [{"key":1704582738600,"functname":"async () => {\n /
                              \n await lupusecAsync.deviceGet();\n /\n await lupusecAsync.deviceListGet();\n await lupusecAsync.devicePSSListGet();\n await lupusecAsync.panelCondGet();\n await lupusecAsync.deviceListUPICGet();\n await lupusecAsync.deviceEditAllGet();\n await lupusecAsync.deviceAllGet();\n await lupusecAsync.logsGetPost();\n if (adapter.config.webcam_providing) await lupusecAsync.getWebcamSnapshots();\n }","loop":true,"time":0,"localtime":1704582776389}]
                              2024-01-07 00:12:57.398 - debug: lupusec.0 (1089) Function: async () => {
                              • M mkreu
                                @glasfaser ```
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @mkreu
                                bitte ab Start des Adapters !
                                  @mkreu
                                  mkreu
                                  @glasfaser
                                  Okay, da hat der Adapter ein falsches Passwort angemeckert. Ich habe das Passwort nochmal reinkopiert und den Adapter neu gestartet.
                                  Danach sind die Devices aufgetaucht.
                                  Aber wie konnte der Adapter dann grün werden...?
                                  • M mkreu
                                    @glasfaser
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    Verbindung steht ... der Adapter Pingt erstmal .
                                    deshalb ist das Log immer ausschlaggebend !
                                      mkreu
                                      @glasfaser
                                      Ja, das sind gute Tipps. Ich da eher noch Anfänger.
                                      Und vielen Dank für die schnelle Hilfe.
                                      Und nochmals sorry für meinen Fauxpas...
                                      Gruß,
                                      Marko
                                      • M mkreu
                                        @glasfaser
                                        Gruß,
                                        Marko
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @glasfaser
                                        Alles gut ... dafür ist das Forum da .. um zu helfen ;)
                                        dann kannst du noch :
                                        Dann setze den Thread auf [gelöst]
                                        Den Titel ändern mit [gelöst]
                                        Im Startbeitrag gehen und bei den 3 Punkten kannst du es ändern
