  4. ERROR: Process exited with code 1 / keine Updates möglich
41 Beiträge 4 Kommentatoren 5.4k Aufrufe 3 Beobachtet
  • B Belei
    root@ioBrokerNuc:~# iobroker upgrade tr-064@4.2.18 --host ioBrokerNuc --debug
    Would you like to reinstall version 4.2.18 of tr-064 now? [(y)es, (n)o]: y
    Update tr-064 from @4.2.18 to @4.2.18
    NPM version: 10.2.3
    Installing iobroker.tr-064@4.2.18... (System call)
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/JSV
    npm ERR! dest /opt/iobroker/node_modules/.JSV-Lv4q8JLo
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/JSV' -> '/opt/iobroker/node_modules/.JSV-Lv4q8JLo'
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-06T21_20_55_945Z-debug-0.log
    host.ioBrokerNuc Cannot install iobroker.tr-064@4.2.18: 217
    @belei
    Schmeiß ein
    iob fix
    ein.
      @belei
      Schmeiß ein
      iob fix
      ein.
      Belei
      schrieb am zuletzt editiert von Belei
      Hat er gemacht.
       iob fix
      library: loaded
      Library version=2024-01-04
          Welcome to the ioBroker installation fixer!
          Script version: 2024-01-04
          Installing prerequisites (1/5)
      OK:1 http://security.debian.org/debian-security buster/updates InRelease
      OK:2 http://ftp.de.debian.org/debian buster InRelease
      OK:3 http://ftp.de.debian.org/debian buster-updates InRelease
      OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease
          Checking ioBroker user and directory permissions (2/5)
          Check and cleanup npm temporary directories (3/5)
      Done.
          Database maintenance (4/5)
      Checking for uncompressed JSONL databases... This might take a while!
      No relevant JSONL files found to compress, skip
          Checking autostart (5/5)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      Was nun?
      iobroker starten oder upgrade?
      • B Belei
        Hat er gemacht.
         iob fix
        library: loaded
        Done.
        Autostart enabled!
        Was nun?
        @belei dann versuch noch ein update
        ggf. solltest du vorher nodejs auf die aktuell empfohlene Verdion 18.xxx bringen
          @homoran sagte in ERROR: Process exited with code 1 / keine Updates möglich:
          Schon passiert... ;-)
          • B Belei
            Hat er gemacht.
             iob fix
            library: loaded
            Done.
            Autostart enabled!
            Was nun?
            @belei sagte in ERROR: Process exited with code 1 / keine Updates möglich:
            Weiter updates reinschaufeln. Bis da nix mehr gemeldet wird.
              Belei
              Jetzt wird er geschwätzich, hat er es jetzt re-installiert?
              NPM version: 10.2.3
              npm WARN skipping integrity check for git dependency ssh://git@github.com/noopka                  t/browser-serialport.git
              npm WARN deprecated dgram@1.0.1: npm is holding this package for security reason                  s. As it's a core Node module, we will not transfer it over to other users. You                   may safely remove the package from your dependencies.
              npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now                   a built-in Node module. If you've depended on crypto, you should switch to the o                  ne that's built-in.
              npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provide                  s its own type definitions, so you do not need this installed.
              npm WARN deprecated har-validator@5.1.5: this library is no longer supported
              npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated b                  ecause it extends the now deprecated request package, see https://github.com/req                  uest/request/issues/3142
              npm WARN deprecated abab@2.0.6: Use your platform's native atob() and btoa() met                  hods instead
              npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JS                  ON 3
              npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy.                   new code should use the URLSearchParams API instead.
              npm WARN deprecated domexception@4.0.0: Use your platform's native DOMException                   instead
              npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and                   does not need to be installed separately. It is now unmaintained.
              npm WARN deprecated jscs-preset-wikimedia@1.0.1: No longer maintained. We recomm                  ent migrating to ESLint with eslint-config-wikimedia.
              npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 hav                  e a low-severity ReDos regression when used in a Node.js environment. It is reco                  mmended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/iss                  ues/797)
              npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@n                  pmjs.com for more info.
              npm WARN deprecated uuid@2.0.3: Please upgrade  to version 7 or higher.  Older v                  ersions may use Math.random() in certain circumstances, which is known to be pro                  blematic.  See https://v8.dev/blog/math-random for details.
              npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older v                  ersions may use Math.random() in certain circumstances, which is known to be pro                  blematic.  See https://v8.dev/blog/math-random for details.
              npm WARN deprecated request@2.88.2: request has been deprecated, see https://git                  hub.com/request/request/issues/3142
              npm WARN deprecated jscs@3.0.7: JSCS has merged with ESLint! See - https://mediu                  m.com/@markelog/jscs-end-of-the-line-bc9bf0b3fdb2
              npm WARN deprecated core-js@2.6.12: core-js@<3.23.3 is no longer maintained and                   not recommended for usage due to the number of issues. Because of the V8 engine                   whims, feature detection in old core-js versions could cause a slowdown up to 10                  0x even if nothing is polyfilled. Some versions have web compatibility issues. P                  lease, upgrade your dependencies to the actual version of core-js.
              changed 1382 packages in 7m
              127 packages are looking for funding
                run `npm fund` for details
              Update "system.adapter.tr-064.0"
              upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
              upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
              upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
              GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
              • B Belei
                NPM version: 10.2.3
                GlasfaserG Offline
                GlasfaserG Offline
                Ist nur Werbung :)
                • B Belei
                  NPM version: 10.2.3
                  Ja.
                  Am Rande: Zieh das Fenster von deinem puTTY breiter. Das schwindelige Ding fabriziert da komische Zeilenumbrüche.
                  • GlasfaserG Glasfaser
                    Ist nur Werbung :)
                    Belei
                    @glasfaser
                    npm fund ?? Spendenanfrage oder was? :-)
                    • B Belei
                      @glasfaser
                      Ja.
                      • B Belei
                        @glasfaser
                        @belei
                        Wie schaut es bei
                        iob update
                        aus?
                          @belei
                          Wie schaut es bei
                          iob update
                          aus?
                          Belei
                          Sind noch paar... Aber es geht voran. Wundert mich nur das jeder einzel abgefragt wird und es pro Adapter im mindestens 5 minuten braucht.
                          Used repository: stable
                          Adapter    "admin"        : 6.12.0   , installed 6.12.0
                          Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
                          Adapter    "amazon-dash"  : 1.2.0    , installed 1.2.0
                          Adapter    "backitup"     : 2.9.8    , installed 2.6.19 [Updatable]
                          Adapter    "ble"          : 0.13.4   , installed 0.13.0 [Updatable]
                          Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                          Adapter    "discovery"    : 4.2.0    , installed 3.1.0  [Updatable]
                          Adapter    "fb-checkpresence": 1.2.2 , installed 1.1.25 [Updatable]
                          Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                          Adapter    "flot"         : 1.12.0   , installed 1.11.0 [Updatable]
                          Adapter    "fritzdect"    : 2.5.9    , installed 2.2.6  [Updatable]
                          Adapter    "history"      : 3.0.1    , installed 2.2.4  [Updatable]
                          Adapter    "hm-rega"      : 4.0.0    , installed 3.0.46 [Updatable]
                          Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.16 [Updatable]
                          Adapter    "hue"          : 3.10.1   , installed 3.7.1  [Updatable]
                          Adapter    "info"         : 2.0.0    , installed 1.9.26 [Updatable]
                          Adapter    "iot"          : 2.0.11   , installed 2.0.11
                          Adapter    "iqontrol"     : 2.3.0    , installed 2.1.0  [Updatable]
                          Adapter    "javascript"   : 7.1.6    , installed 6.1.4  [Updatable]
                          Controller "js-controller": 5.0.17   , installed 4.0.24 [Updatable]
                          Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
                          Adapter    "mihome-vacuum": 4.1.0    , installed 3.11.0 [Updatable]
                          Adapter    "proxmox"      : 2.2.2    , installed 1.3.5  [Updatable]
                          Adapter    "pushover"     : 3.0.6    , installed 3.0.3  [Updatable]
                          Adapter    "radar2"       : 2.1.0    , installed 2.1.0
                          Adapter    "rflink"       : 2.1.6    , installed 2.1.6
                          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                          Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
                          Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                          Adapter    "vis"          : 1.5.4    , installed 1.5.4
                          Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                          Adapter    "web"          : 6.1.10   , installed 6.1.10
                          Adapter    "weishaupt-wem": 0.0.15   , installed 0.0.15
                          Adapter    "ws"           : 2.5.8    , installed 2.5.8
                          Adapter    "zigbee"       : 1.9.5    , installed 1.9.5
                          • B Belei
                            Mit
                            iob upgrade all -y
                            fragt die Kiste nicht mehr bei jedem Adapter.
                              Mit
                              iob upgrade all -y
                              Belei
                              Erstmal vielen Dank für die super kompetente schnelle Hilfe hier von allen!! 👍 👏
                              Die gute Nachricht ist, es ist alles durchgeupdatet und iob wieder gestartet.
                              Die schlechte ist, es kam der einrichtungsassistent und nun sind nur 3 Instanzen aktiv statt über 20.
                              Die korekten Adapter stehen aber noch unter Adapter. Es fehlt auch der Punkte Scripte im Menü.
                              Habe Scripte mal als Instanz aktiviert, die Scripte sind auch wech.....
                              • B Belei
                                @belei
                                iob diag
                                sagt?
                                B 2 Antworten Letzte Antwort
                                  @belei
                                  iob diag
                                  sagt?
                                  Belei
                                  @thomas-braun said in ERROR: Process exited with code 1 / keine Updates möglich:
                                  iob diag
                                  Wenn ich den als root ausführe sagt er, mach nicht als root.
                                  Wenn ich ihn mit einem standard User ausführe sagt er:
                                  [sudo] Passwort für benni:
                                  Leider darf der Benutzer benni »/usr/bin/curl -sLf https://iobroker.net/diag.sh --output /home/iobroker/.diag.sh« als iobroker auf ioBrokerNuc nicht ausführen
                                  EDIT:
                                  Hab ihm jetzt in die sudo Gruppe gepackt
                                    @belei
                                    iob diag
                                    sagt?
                                    Belei
                                                            v.2023-10-10
                                       Static hostname: ioBrokerNuc
                                             Icon name: computer-vm
                                               Chassis: vm
                                        Virtualization: kvm
                                      Operating System: Debian GNU/Linux 10 (buster)
                                                Kernel: Linux 4.19.0-25-amd64
                                          Architecture: x86-64
                                    Installation:           kvm
                                    Kernel:                 x86_64
                                    Userland:               amd64
                                    Timezone:               Europe/Berlin (CET, +0100)
                                    User-ID:                1000
                                    X-Server:               false
                                    Pending OS-Updates:     0
                                    Pending iob updates:    0
                                    Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                                            /usr/bin/node           v18.19.0
                                                            /usr/bin/npm            10.2.3
                                                            /usr/bin/npx            10.2.3
                                                            /usr/bin/corepack       0.22.0
                                    Recommended versions are nodejs 18.19.0 and npm 10.2.3
                                    MEMORY:
                                    Mem:           2.0G        972M        312M        1.0M        709M        856M
                                    Swap:          2.0G         29M        2.0G
                                    Total:         4.0G        1.0G        2.3G
                                    Active iob-Instances:   6
                                    Active repo(s): stable
                                    ioBroker Core:          js-controller           5.0.17
                                                            admin                   6.12.0
                                    Objects type: jsonl
                                    States  type: redis
                                    + system.adapter.admin.0                  : admin                 : ioBrokerNuc                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    Objects:                198
                                    States:                 7866
                                    Size of iob-Database:
                                    4.1M    /opt/iobroker/iobroker-data/objects.jsonl
                                    108K    /opt/iobroker/iobroker-data/objects.json.migrated
                                    68K     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                    8.0K    /opt/iobroker/iobroker-data/states.json.bak
                                    === Mark text until here for copying ===
                                    • B Belei
                                                              v.2023-10-10
                                                 Chassis: vm
                                          Virtualization: kvm
                                      Installation:           kvm
                                      Kernel:                 x86_64
                                      Userland:               amd64
                                      User-ID:                1000
                                      X-Server:               false
                                                              /usr/bin/npm            10.2.3
                                                              /usr/bin/npx            10.2.3
                                      MEMORY:
                                      Swap:          2.0G         29M        2.0G
                                                              admin                   6.12.0
                                      Objects type: jsonl
                                      States  type: redis
                                      Objects:                198
                                      States:                 7866
                                      @belei
                                      Die Langfassung.
                                        @belei
                                        Die Langfassung.
                                        Belei
                                        Guten Morgen,
                                        ich hab gestern Nacht noch ein Backup vom Backitup Adapter eingespielt.
                                        Jetzt sind die Instancen wieder da. Hab dann noch mal wieder die Adpater upgedatet und den fix laufen lassen. Jetzt kommen Fehler beim starten der Adapter:
                                        Aber hier erstmal der diag:
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                                   Chassis: vm
                                            Virtualization: kvm
                                        model name      : Common KVM processor
                                        Docker          : false
                                        Virtualization  : kvm
                                        Kernel          : x86_64
                                        Userland        : amd64
                                        Systemuptime and Load:
                                         11:12:12 up  2:09,  1 user,  load average: 0.14, 0.27, 0.58
                                        CPU threads: 8
                                        *** Time and Time Zones ***
                                                       Local time: Sun 2024-01-07 11:12:12 CET
                                                   Universal time: Sun 2024-01-07 10:12:12 UTC
                                                         RTC time: Sun 2024-01-07 10:12:13
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        *** User and Groups ***
                                        benni
                                        /home/benni
                                        benni cdrom floppy sudo audio dip video plugdev netdev
                                        *** X-Server-Setup ***
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Mem:           2.0G        484M        794M        4.0M        716M        1.3G
                                        Swap:          2.0G         26M        2.0G
                                        Total:         4.0G        510M        2.8G
                                                 1994 M total memory
                                                  484 M used memory
                                                  703 M active memory
                                                  281 M inactive memory
                                                  794 M free memory
                                                  168 M buffer memory
                                                  547 M swap cache
                                                 2044 M total swap
                                                   26 M used swap
                                                 2018 M free swap
                                        *** FAILED SERVICES ***
                                        0 loaded units listed. Pass --all to see loaded but inactive units, too.
                                        To show all installed unit files use 'systemctl list-unit-files'.
                                        *** FILESYSTEM ***
                                        udev           devtmpfs  983M     0  983M   0% /dev
                                        tmpfs          tmpfs     200M  5.6M  194M   3% /run
                                        /dev/sda1      ext4       14G  9.0G  4.1G  69% /
                                        tmpfs          tmpfs     998M     0  998M   0% /dev/shm
                                        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                                        tmpfs          tmpfs     998M     0  998M   0% /sys/fs/cgroup
                                        tmpfs          tmpfs     200M     0  200M   0% /run/user/0
                                        [Sun Jan  7 09:02:54 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                                        [Sun Jan  7 09:02:57 2024] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
                                        TARGET        SOURCE    FSTYPE OPTIONS
                                        /             /dev/sda1 ext4   rw,relatime,errors=remount-ro
                                        `-/sys/fs/bpf bpf       bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                                        /var:
                                        439M    /var/
                                        249M    /var/cache
                                        241M    /var/cache/apt
                                        178M    /var/cache/apt/archives
                                        171M    /var/lib
                                              Users in the 'systemd-journal' group can see all messages. Pass -q to
                                              turn off this notice.
                                        No journal files were opened due to insufficient permissions.
                                        /opt/iobroker/backups:
                                        544M    /opt/iobroker/backups/
                                        /opt/iobroker/iobroker-data:
                                        481M    /opt/iobroker/iobroker-data/
                                        284M    /opt/iobroker/iobroker-data/files
                                        142M    /opt/iobroker/iobroker-data/backup-objects
                                        76M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js
                                        find: Failed to change directory: /root: Permission denied
                                        find: Failed to restore initial working directory: /root: Permission denied
                                        USB-Devices by-id:
                                        /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2231944-if00
                                        /dev/serial/by-id/usb-Arduino__www.arduino.cc__0042_95635333930351A0A2D0-if00
                                        *** NodeJS-Installation ***
                                        /usr/bin/npm            10.2.3
                                        /usr/bin/npx            10.2.3
                                        nodejs:
                                          Installed: 18.19.0-1nodesource1
                                          Candidate: 18.19.0-1nodesource1
                                          Version table:
                                         *** 18.19.0-1nodesource1 1001
                                                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                             18.18.2-1nodesource1 1001
                                             18.18.1-1nodesource1 1001
                                             18.18.0-1nodesource1 1001
                                             18.17.1-1nodesource1 1001
                                             18.17.0-1nodesource1 1001
                                             18.16.1-1nodesource1 1001
                                             18.16.0-1nodesource1 1001
                                             18.15.0-1nodesource1 1001
                                             18.14.2-1nodesource1 1001
                                             18.14.1-1nodesource1 1001
                                             18.14.0-1nodesource1 1001
                                             18.13.0-1nodesource1 1001
                                             18.12.0-1nodesource1 1001
                                             18.11.0-1nodesource1 1001
                                             18.10.0-1nodesource1 1001
                                             18.9.1-1nodesource1 1001
                                             18.9.0-1nodesource1 1001
                                             18.8.0-1nodesource1 1001
                                             18.7.0-1nodesource1 1001
                                             18.6.0-1nodesource1 1001
                                             18.5.0-1nodesource1 1001
                                             18.4.0-1nodesource1 1001
                                             18.3.0-1nodesource1 1001
                                             18.2.0-1nodesource1 1001
                                             18.1.0-1nodesource1 1001
                                             18.0.0-1nodesource1 1001
                                             10.24.0~dfsg-1~deb10u3 500
                                                500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
                                             10.24.0~dfsg-1~deb10u1 500
                                                500 http://ftp.de.debian.org/debian buster/main amd64 Packages
                                        No problems detected
                                        Errors in npm tree:
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: redis
                                        Core adapters versions
                                        js-controller:  5.0.17
                                        admin:          6.12.0
                                        javascript:     3.6.4
                                        Adapters from github:   0
                                        Adapter State
                                        + system.adapter.admin.0                  : admin                 : ioBrokerNuc                              -  enabled, port: 8081, bind: 192.168.178.32, run as: admin
                                          system.adapter.alexa2.0                 : alexa2                : ioBrokerNuc                              -  enabled
                                          system.adapter.amazon-dash.0            : amazon-dash           : ioBrokerNuc                              -  enabled
                                        + system.adapter.backitup.0               : backitup              : ioBrokerNuc                              -  enabled
                                          system.adapter.ble.0                    : ble                   : ioBrokerNuc                              - disabled
                                          system.adapter.discovery.0              : discovery             : ioBrokerNuc                              - disabled
                                          system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBrokerNuc                              - disabled
                                          system.adapter.feiertage.0              : feiertage             : ioBrokerNuc                              - disabled
                                          system.adapter.flot.0                   : flot                  : ioBrokerNuc                              - disabled
                                          system.adapter.fritzdect.0              : fritzdect             : ioBrokerNuc                              - disabled
                                          system.adapter.history.0                : history               : ioBrokerNuc                              - disabled
                                        + system.adapter.hm-rega.0                : hm-rega               : ioBrokerNuc                              - disabled
                                        + system.adapter.hm-rpc.0                 : hm-rpc                : ioBrokerNuc                              - disabled, port: 0
                                        + system.adapter.hm-rpc.1                 : hm-rpc                : ioBrokerNuc                              - disabled, port: 18701
                                        + system.adapter.hm-rpc.3                 : hm-rpc                : ioBrokerNuc                              - disabled, port: 12010
                                        + system.adapter.hue.0                    : hue                   : ioBrokerNuc                              -  enabled, port: 443
                                          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBrokerNuc                              - disabled
                                        + system.adapter.info.0                   : info                  : ioBrokerNuc                              -  enabled
                                        + system.adapter.iot.0                    : iot                   : ioBrokerNuc                              - disabled
                                        + system.adapter.javascript.0             : javascript            : ioBrokerNuc                              - disabled
                                          system.adapter.lovelace.0               : lovelace              : ioBrokerNuc                              - disabled, port: 8091, bind: 0.0.0.0, run as: admin
                                          system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBrokerNuc                              - disabled, port: 54321
                                          system.adapter.mobile.0                 : mobile                : ioBrokerNuc                              - disabled
                                        + system.adapter.ping.0                   : ping                  : ioBrokerNuc                              - disabled
                                        + system.adapter.pushover.0               : pushover              : ioBrokerNuc                              - disabled
                                        + system.adapter.rflink.0                 : rflink                : ioBrokerNuc                              - disabled
                                        + system.adapter.shelly.0                 : shelly                : ioBrokerNuc                              - disabled, port: 1882, bind: 0.0.0.0
                                        + system.adapter.tr-064.0                 : tr-064                : ioBrokerNuc                              - disabled
                                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBrokerNuc                              - disabled
                                          system.adapter.vis.0                    : vis                   : ioBrokerNuc                              - disabled
                                          system.adapter.weatherunderground.0     : weatherunderground    : ioBrokerNuc                              - disabled
                                          system.adapter.web-speedy.0             : web-speedy            : ioBrokerNuc                              - disabled
                                        + system.adapter.web.0                    : web                   : ioBrokerNuc                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                          system.adapter.weishaupt-wem.0          : weishaupt-wem         : ioBrokerNuc                              - disabled
                                        + system.adapter.zigbee.0                 : zigbee                : ioBrokerNuc                              - disabled, port: /dev/ttyACM1
                                        + instance is alive
                                        ioBroker-Repositories
                                        Installed ioBroker-Instances
                                        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                                        Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                                        Adapter    "hue"          : 3.10.1   , installed 3.10.1
                                        Adapter    "info"         : 2.0.0    , installed 2.0.0
                                        Controller "js-controller": 5.0.17   , installed 5.0.17
                                        Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
                                        Objects and States
                                        Objects:        9477
                                        States:         7735
                                        Hit:1 http://security.debian.org/debian-security buster/updates InRelease
                                        Hit:2 http://ftp.de.debian.org/debian buster InRelease
                                        Hit:3 http://ftp.de.debian.org/debian buster-updates InRelease
                                        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                                        Reading package lists...
                                        Pending Updates: 0
                                        *** Listening Ports ***
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14812      695/sshd
                                        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          16850      691/exim4
                                        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       63068      18600/iobroker.js-c
                                        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      108        15514      505/redis-server 12
                                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          10492      1/init
                                        tcp        0      0 192.168.178.32:8081     0.0.0.0:*               LISTEN      1001       63114      18625/io.admin.0
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          14814      695/sshd
                                        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          16851      691/exim4
                                        tcp6       0      0 :::111                  :::*                    LISTEN      0          10495      1/init
                                        udp        0      0 0.0.0.0:41002           0.0.0.0:*                           107        16387      376/avahi-daemon: r
                                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13802      370/dhclient
                                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          9927       1/init
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        16385      376/avahi-daemon: r
                                        udp6       0      0 :::111                  :::*                                0          9932       1/init
                                        udp6       0      0 :::5353                 :::*                                107        16386      376/avahi-daemon: r
                                        udp6       0      0 :::57837                :::*                                107        16388      376/avahi-daemon: r
                                        2024-01-07 11:12:38.956  - error: host.ioBrokerNuc Caught by controller[0]:             throw 'Unknown objects type: ' + config.objects.type;
                                        2024-01-07 11:12:38.957  - error: host.ioBrokerNuc Caught by controller[0]:             ^
                                        2024-01-07 11:12:38.957  - error: host.ioBrokerNuc Caught by controller[0]: Unknown objects type: jsonl
                                        2024-01-07 11:12:38.957  - error: host.ioBrokerNuc Caught by controller[0]: (Use `node --trace-uncaught ...` to show where the exception was thrown)
                                        2024-01-07 11:12:38.957  - error: host.ioBrokerNuc Caught by controller[0]: Node.js v18.19.0
                                        2024-01-07 11:12:38.958  - error: host.ioBrokerNuc instance system.adapter.amazon-dash.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        2024-01-07 11:12:38.958  - info: host.ioBrokerNuc Restart adapter system.adapter.amazon-dash.0 because enabled
                                        2024-01-07 11:13:03.356  - info: host.ioBrokerNuc instance system.adapter.alexa2.0 started with pid 29459
                                        2024-01-07 11:13:04.079  - error: host.ioBrokerNuc Caught by controller[0]: /node_modules/iobroker.js-controller/lib/adapter.js:194
                                        2024-01-07 11:13:04.080  - error: host.ioBrokerNuc Caught by controller[0]:             throw 'Unknown objects type: ' + config.objects.type;
                                        2024-01-07 11:13:04.080  - error: host.ioBrokerNuc Caught by controller[0]:             ^
                                        2024-01-07 11:13:04.081  - error: host.ioBrokerNuc Caught by controller[0]: Unknown objects type: jsonl
                                        2024-01-07 11:13:04.082  - error: host.ioBrokerNuc Caught by controller[0]: (Use `node --trace-uncaught ...` to show where the exception was thrown)
                                        2024-01-07 11:13:04.082  - error: host.ioBrokerNuc Caught by controller[0]: Node.js v18.19.0
                                        2024-01-07 11:13:04.083  - error: host.ioBrokerNuc instance system.adapter.alexa2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        2024-01-07 11:13:04.084  - info: host.ioBrokerNuc Restart adapter system.adapter.alexa2.0 because enabled
                                        2024-01-07 11:13:08.998  - info: host.ioBrokerNuc instance system.adapter.amazon-dash.0 started with pid 29519
                                        2024-01-07 11:13:09.570  - error: host.ioBrokerNuc Caught by controller[0]: /node_modules/iobroker.js-controller/lib/adapter.js:194
                                        2024-01-07 11:13:09.570  - error: host.ioBrokerNuc Caught by controller[0]:             throw 'Unknown objects type: ' + config.objects.type;
                                        2024-01-07 11:13:09.571  - error: host.ioBrokerNuc Caught by controller[0]:             ^
                                        2024-01-07 11:13:09.571  - error: host.ioBrokerNuc Caught by controller[1]: Unknown objects type: jsonl
                                        2024-01-07 11:13:09.571  - error: host.ioBrokerNuc Caught by controller[2]: (Use `node --trace-uncaught ...` to show where the exception was thrown)
                                        2024-01-07 11:13:09.572  - error: host.ioBrokerNuc Caught by controller[3]: Node.js v18.19.0
                                        2024-01-07 11:13:09.572  - error: host.ioBrokerNuc instance system.adapter.amazon-dash.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        2024-01-07 11:13:09.573  - info: host.ioBrokerNuc Restart adapter system.adapter.amazon-dash.0 because enabled
                                        iob diag has finished.
                                        • B Belei
                                          Guten Morgen,
                                          Skript v.2023-10-10
                                          *** BASE SYSTEM ***
                                                     Chassis: vm
                                              Virtualization: kvm
                                          Docker          : false
                                          Kernel          : x86_64
                                          Userland        : amd64
                                          CPU threads: 8
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          benni
                                          /home/benni
                                          X-Server:       false
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Swap:          2.0G         26M        2.0G
                                                   1994 M total memory
                                                    484 M used memory
                                                    703 M active memory
                                                    794 M free memory
                                                    168 M buffer memory
                                                    547 M swap cache
                                                   2044 M total swap
                                                     26 M used swap
                                                   2018 M free swap
                                          *** FILESYSTEM ***
                                          /var:
                                          439M    /var/
                                          249M    /var/cache
                                          241M    /var/cache/apt
                                          171M    /var/lib
                                          USB-Devices by-id:
                                          /usr/bin/npm            10.2.3
                                          /usr/bin/npx            10.2.3
                                          nodejs:
                                            Version table:
                                          Errors in npm tree:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: redis
                                          admin:          6.12.0
                                          javascript:     3.6.4
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        9477
                                          States:         7735
                                          Pending Updates: 0
                                          Welche Fehler? Die mit dem /root cwd?
                                          Die kommen durch dein herumgehampel als root.
                                          Bring auch die letzten Adapter noch auf Stand und dann ziehst du mit dem Backup auf ein frisches System um. Ohne aktiven root.
