  4. ERROR: Process exited with code 1 / keine Updates möglich
41 Beiträge 4 Kommentatoren 5.4k Aufrufe 3 Beobachtet
  • B Belei
    Bin dabei.
    Nach 4-5 Adaptern kommen jetzt wieder Fehler:
    Would you like to upgrade tr-064 from @4.2.17 to @4.2.18 now? [(y)es, (n)o]: y
    Update tr-064 from @4.2.17 to @4.2.18
    NPM version: 10.2.3
    Installing iobroker.tr-064@4.2.18... (System call)
    host.ioBrokerNuc Cannot install iobroker.tr-064@4.2.18: 244
    root@ioBrokerNuc:~# iob upgrade all
    This upgrade of "socketio" will at least introduce the following changes:
    -> 6.6.0:
    Corrected adapter termination if the alias has no target
    -> 6.5.7:
    upgrade socket-classes to fix error with vis subscriptions
    -> 6.5.6:
    upgraded socket-classes to correct the error by unsubscribing on client disconnect
    -> 6.5.5:
    upgrade socket-classes to fix crash cases
    -> 6.5.4:
    -> 6.5.3:
    added missing node16 requirement
    -> 6.5.2:
    Added the subscribing on the specific instance messages
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade socketio from @4.2.0 to @6.6.0 now? [(y)es, (n)o]: y
    Update socketio from @4.2.0 to @6.6.0
    NPM version: 10.2.3
    Installing iobroker.socketio@6.6.0... (System call)
    host.ioBrokerNuc Cannot install iobroker.socketio@6.6.0: 217
    @belei sagte in ERROR: Process exited with code 1 / keine Updates möglich:
    Wo siehst du da Fehler?
    Edit:
    iobroker upgrade tr-064@4.2.18 --debug
    B Thomas BraunT 3 Antworten Letzte Antwort
      Edit:
      Belei
      Zeile 5
      Zeile 37
        Edit:
        Belei
        root@ioBrokerNuc:~# iobroker upgrade tr-064@4.2.18 --debug
        Would you like to reinstall version 4.2.18 of tr-064 now? [(y)es, (n)o]: y
        Update tr-064 from @4.2.18 to @4.2.18
        NPM version: 10.2.3
        npm ERR! code ENOTEMPTY
        npm ERR! syscall rename
        npm ERR! path /opt/iobroker/node_modules/JSV
        npm ERR! dest /opt/iobroker/node_modules/.JSV-Lv4q8JLo
        npm ERR! errno -39
        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/JSV' -> '/opt/iobroker/node_modules/.JSV-Lv4q8JLo'
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-06T21_16_06_713Z-debug-0.log
        host.ioBrokerNuc Cannot install iobroker.tr-064@4.2.18: 217
          Edit:
          iobroker upgrade tr-064@4.2.18 --host ioBrokerNuc --debug
          HomoranH B 2 Antworten Letzte Antwort
            @thomas-braun Screenshot_20240106-222238_Firefox.jpg 😁
              Belei
              root@ioBrokerNuc:~# iobroker upgrade tr-064@4.2.18 --host ioBrokerNuc --debug
              NPM version: 10.2.3
              npm ERR! errno -39
              npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-06T21_20_55_945Z-debug-0.log
              • B Belei
                Moin,
                Meinst System läuft in einer VM auf Proxmox. Leider hab ich einige Zeit updates versäumt und somit ziemlich stau gehabt, auch in den Abhängigkeiten.
                -Erst hab ich meine Stretch auf Buster upgedatet
                -Dann hab ich node upgedatet und den fix script durchlaufen lassen
                -jetzt bekomme ich bei allen adapter updates den fehler code 1 in der gui
                root@ioBrokerNuc:~# node -v
                v16.20.2
                root@ioBrokerNuc:~# npm -v
                8.19.4
                Bsp.
                root@ioBrokerNuc:~# iobroker upgrade backitup --debug
                Would you like to upgrade backitup from @2.6.19 to @2.9.8 now? [(y)es, (n)o]: y
                Update backitup from @2.6.19 to @2.9.8
                NPM version: 8.19.4
                Installing iobroker.backitup@2.9.8... (System call)
                npm ERR! path /opt/iobroker/node_modules/abab
                npm ERR! dest /opt/iobroker/node_modules/.abab-bvmibCm3
                npm ERR! errno -39
                npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/abab' -> '/opt/iobroker/node_modules/.abab-bvmibCm3'
                npm ERR!     /root/.npm/_logs/2024-01-06T19_42_16_764Z-debug-0.log
                host.ioBrokerNuc Cannot install iobroker.backitup@2.9.8: 217
                Dann hab ich das angemeckerte VS umbenannt
                root@ioBrokerNuc:~# mv /opt/iobroker/node_modules/abab /opt/iobroker/node_modules/.abab-bvmibCm3
                Dann macht er das
                Would you like to upgrade backitup from @2.6.19 to @2.9.8 now? [(y)es, (n)o]: y        Update backitup from @2.6.19 to @2.9.8
                NPM version: 8.19.4
                npm ERR! path /opt/iobroker/node_modules/abbrev
                npm ERR! dest /opt/iobroker/node_modules/.abbrev-5eNud0FY
                npm ERR! errno -39
                npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/abbrev' -> '/opt/iobroker/node_modules/.abbrev-5eNud0FY'
                npm ERR!     /root/.npm/_logs/2024-01-06T19_49_54_685Z-debug-0.log
                Momentan weiss ich nicht weiter.... kann jmd helfen?
                Hier noch mal paar Infos:
                root@ioBrokerNuc:~# iob list adapters
                system.adapter.admin                   : admin          - v6.12.0
                system.adapter.alexa2                  : alexa2         - v3.26.3
                system.adapter.amazon-dash             : amazon-dash    - v1.2.0
                system.adapter.backitup                : backitup       - v2.6.19
                system.adapter.ble                     : ble            - v0.13.0
                system.adapter.cloud                   : cloud          - v4.4.1
                system.adapter.discovery               : discovery      - v3.1.0
                system.adapter.fb-checkpresence        : fb-checkpresence - v1.1.25
                system.adapter.feiertage               : feiertage      - v1.1.0
                system.adapter.flot                    : flot           - v1.11.0
                system.adapter.fritzdect               : fritzdect      - v2.2.6
                system.adapter.history                 : history        - v2.2.4
                system.adapter.hm-rega                 : hm-rega        - v1.7.1
                system.adapter.hm-rpc                  : hm-rpc         - v1.15.16
                system.adapter.hue                     : hue            - v3.7.1
                system.adapter.hue-extended            : hue-extended   - v2.0.0
                system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
                system.adapter.info                    : info           - v1.9.19
                system.adapter.iot                     : iot            - v2.0.11
                system.adapter.iqontrol                : iqontrol       - v2.1.0
                system.adapter.javascript              : javascript     - v6.1.4
                system.adapter.lovelace                : lovelace       - v3.0.1
                system.adapter.mihome-vacuum           : mihome-vacuum  - v3.11.0
                system.adapter.mobile                  : mobile         - v1.0.1
                system.adapter.ping                    : ping           - v1.5.3
                system.adapter.proxmox                 : proxmox        - v1.3.4
                system.adapter.pushover                : pushover       - v3.0.3
                system.adapter.radar                   : radar          - v1.1.3
                system.adapter.radar2                  : radar2         - v2.0.3
                system.adapter.rflink                  : rflink         - v2.1.6
                system.adapter.scenes                  : scenes         - v2.3.9
                system.adapter.shelly                  : shelly         - v6.4.1
                system.adapter.shuttercontrol          : shuttercontrol - v1.4.18
                system.adapter.simple-api              : simple-api     - v2.7.2
                system.adapter.socketio                : socketio       - v4.2.0
                system.adapter.tr-064                  : tr-064         - v4.2.17
                system.adapter.vis                     : vis            - v1.4.15
                system.adapter.vis-timeandweather      : vis-timeandweather - v1.2.2
                system.adapter.weatherunderground      : weatherunderground - v3.4.2
                system.adapter.web                     : web            - v4.3.0
                system.adapter.web-speedy              : web-speedy     - v0.2.0
                system.adapter.weishaupt-wem           : weishaupt-wem  - v0.0.15
                system.adapter.zigbee                  : zigbee         - v1.8.10
                NPM version: 8.19.4
                alles vorhanden!
                die Lösung sollte in dem Thread stehen.
                • B Belei
                  NPM version: 10.2.3
                  npm ERR! errno -39
                  @belei
                  Schmeiß ein
                  iob fix
                  ein.
                    @belei
                    Schmeiß ein
                    iob fix
                    ein.
                    Belei
                    schrieb am zuletzt editiert von Belei
                    Hat er gemacht.
                     iob fix
                    library: loaded
                    Library version=2024-01-04
                        Welcome to the ioBroker installation fixer!
                        Script version: 2024-01-04
                        Installing prerequisites (1/5)
                    OK:1 http://security.debian.org/debian-security buster/updates InRelease
                    OK:2 http://ftp.de.debian.org/debian buster InRelease
                    OK:3 http://ftp.de.debian.org/debian buster-updates InRelease
                    OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                        Checking ioBroker user and directory permissions (2/5)
                        Check and cleanup npm temporary directories (3/5)
                    Done.
                        Database maintenance (4/5)
                    Checking for uncompressed JSONL databases... This might take a while!
                    No relevant JSONL files found to compress, skip
                        Checking autostart (5/5)
                    Enabling autostart...
                    Autostart enabled!
                        Your installation was fixed successfully
                        Run iobroker start to start ioBroker again!
                    Was nun?
                    iobroker starten oder upgrade?
                    • B Belei
                      Hat er gemacht.
                       iob fix
                      library: loaded
                      Done.
                      Autostart enabled!
                      Was nun?
                      @belei dann versuch noch ein update
                      ggf. solltest du vorher nodejs auf die aktuell empfohlene Verdion 18.xxx bringen
                        @homoran sagte in ERROR: Process exited with code 1 / keine Updates möglich:
                        Schon passiert... ;-)
                        • B Belei
                          Hat er gemacht.
                           iob fix
                          library: loaded
                          Done.
                          Autostart enabled!
                          Was nun?
                          Weiter updates reinschaufeln. Bis da nix mehr gemeldet wird.
                            Belei
                            Jetzt wird er geschwätzich, hat er es jetzt re-installiert?
                            NPM version: 10.2.3
                            npm WARN skipping integrity check for git dependency ssh://git@github.com/noopka                  t/browser-serialport.git
                            npm WARN deprecated dgram@1.0.1: npm is holding this package for security reason                  s. As it's a core Node module, we will not transfer it over to other users. You                   may safely remove the package from your dependencies.
                            npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now                   a built-in Node module. If you've depended on crypto, you should switch to the o                  ne that's built-in.
                            npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provide                  s its own type definitions, so you do not need this installed.
                            npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                            npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated b                  ecause it extends the now deprecated request package, see https://github.com/req                  uest/request/issues/3142
                            npm WARN deprecated abab@2.0.6: Use your platform's native atob() and btoa() met                  hods instead
                            npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JS                  ON 3
                            npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy.                   new code should use the URLSearchParams API instead.
                            npm WARN deprecated domexception@4.0.0: Use your platform's native DOMException                   instead
                            npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and                   does not need to be installed separately. It is now unmaintained.
                            npm WARN deprecated jscs-preset-wikimedia@1.0.1: No longer maintained. We recomm                  ent migrating to ESLint with eslint-config-wikimedia.
                            npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 hav                  e a low-severity ReDos regression when used in a Node.js environment. It is reco                  mmended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/iss                  ues/797)
                            npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@n                  pmjs.com for more info.
                            npm WARN deprecated uuid@2.0.3: Please upgrade  to version 7 or higher.  Older v                  ersions may use Math.random() in certain circumstances, which is known to be pro                  blematic.  See https://v8.dev/blog/math-random for details.
                            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older v                  ersions may use Math.random() in certain circumstances, which is known to be pro                  blematic.  See https://v8.dev/blog/math-random for details.
                            npm WARN deprecated request@2.88.2: request has been deprecated, see https://git                  hub.com/request/request/issues/3142
                            npm WARN deprecated jscs@3.0.7: JSCS has merged with ESLint! See - https://mediu                  m.com/@markelog/jscs-end-of-the-line-bc9bf0b3fdb2
                            npm WARN deprecated core-js@2.6.12: core-js@<3.23.3 is no longer maintained and                   not recommended for usage due to the number of issues. Because of the V8 engine                   whims, feature detection in old core-js versions could cause a slowdown up to 10                  0x even if nothing is polyfilled. Some versions have web compatibility issues. P                  lease, upgrade your dependencies to the actual version of core-js.
                            changed 1382 packages in 7m
                            127 packages are looking for funding
                              run `npm fund` for details
                            Update "system.adapter.tr-064.0"
                            upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
                            upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
                            upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
                            GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                            • B Belei
                              NPM version: 10.2.3
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Ist nur Werbung :)
                              • B Belei
                                NPM version: 10.2.3
                                Ja.
                                Am Rande: Zieh das Fenster von deinem puTTY breiter. Das schwindelige Ding fabriziert da komische Zeilenumbrüche.
                                • GlasfaserG Glasfaser
                                  Ist nur Werbung :)
                                  Belei
                                  @glasfaser
                                  npm fund ?? Spendenanfrage oder was? :-)
                                  • B Belei
                                    @glasfaser
                                    Ja.
                                    • B Belei
                                      @glasfaser
                                      @belei
                                      Wie schaut es bei
                                      iob update
                                      aus?
                                        @belei
                                        Wie schaut es bei
                                        iob update
                                        aus?
                                        Belei
                                        Sind noch paar... Aber es geht voran. Wundert mich nur das jeder einzel abgefragt wird und es pro Adapter im mindestens 5 minuten braucht.
                                        Used repository: stable
                                        Adapter    "admin"        : 6.12.0   , installed 6.12.0
                                        Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
                                        Adapter    "amazon-dash"  : 1.2.0    , installed 1.2.0
                                        Adapter    "backitup"     : 2.9.8    , installed 2.6.19 [Updatable]
                                        Adapter    "ble"          : 0.13.4   , installed 0.13.0 [Updatable]
                                        Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                                        Adapter    "discovery"    : 4.2.0    , installed 3.1.0  [Updatable]
                                        Adapter    "fb-checkpresence": 1.2.2 , installed 1.1.25 [Updatable]
                                        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                                        Adapter    "flot"         : 1.12.0   , installed 1.11.0 [Updatable]
                                        Adapter    "fritzdect"    : 2.5.9    , installed 2.2.6  [Updatable]
                                        Adapter    "history"      : 3.0.1    , installed 2.2.4  [Updatable]
                                        Adapter    "hm-rega"      : 4.0.0    , installed 3.0.46 [Updatable]
                                        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.16 [Updatable]
                                        Adapter    "hue"          : 3.10.1   , installed 3.7.1  [Updatable]
                                        Adapter    "info"         : 2.0.0    , installed 1.9.26 [Updatable]
                                        Adapter    "iot"          : 2.0.11   , installed 2.0.11
                                        Adapter    "iqontrol"     : 2.3.0    , installed 2.1.0  [Updatable]
                                        Adapter    "javascript"   : 7.1.6    , installed 6.1.4  [Updatable]
                                        Controller "js-controller": 5.0.17   , installed 4.0.24 [Updatable]
                                        Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
                                        Adapter    "mihome-vacuum": 4.1.0    , installed 3.11.0 [Updatable]
                                        Adapter    "proxmox"      : 2.2.2    , installed 1.3.5  [Updatable]
                                        Adapter    "pushover"     : 3.0.6    , installed 3.0.3  [Updatable]
                                        Adapter    "radar2"       : 2.1.0    , installed 2.1.0
                                        Adapter    "rflink"       : 2.1.6    , installed 2.1.6
                                        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                                        Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
                                        Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                                        Adapter    "vis"          : 1.5.4    , installed 1.5.4
                                        Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                                        Adapter    "web"          : 6.1.10   , installed 6.1.10
                                        Adapter    "weishaupt-wem": 0.0.15   , installed 0.0.15
                                        Adapter    "ws"           : 2.5.8    , installed 2.5.8
                                        Adapter    "zigbee"       : 1.9.5    , installed 1.9.5
                                        • B Belei
                                          Mit
                                          iob upgrade all -y
                                          fragt die Kiste nicht mehr bei jedem Adapter.
