  4. Raspberry Pi plötzlich nicht mehr erreichbar
    5.1k
13 Beiträge 4 Kommentatoren 2.4k Aufrufe 3 Beobachtet
  • G gammler2003
    @thomas-braun said in Raspberry Pi in plötzlich nicht mehr erreichbar:
    iob diag
    Vielen Dank dir für den Hinweis. So sieht die Summary bei mir aus. Lässt sich daraus irgendein Hinweis auf das Phänomen ableiten?
    			v.2023-10-10
       Static hostname: phoscon
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Installation: 		native
    Kernel: 		armv7l
    Userland: 		armhf
    Timezone: 		Europe/Berlin (CET, +0100)
    User-ID: 		1000
    X-Server: 		true
    Boot Target: 		graphical.target
    Pending OS-Updates: 	282
    Pending iob updates: 	8
    /home/iobroker/.diag.sh: line 486: nodejs: command not found
    Nodejs-Installation:
    			/usr/local/bin/node 		v16.15.0
    			/usr/local/bin/npm 		8.5.5
    			/usr/local/bin/npx 		8.5.5
    			/usr/local/bin/corepack 	0.10.0
    Recommended versions are nodejs 18.18.2 and npm 9.8.1
    *** nodejs is NOT correctly installed ***
    Wrong installation path detected. This needs to be fixed.
    Please check
    https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
    for more information on how to fix these errors.
    MEMORY:
    Mem:           3.8G        1.6G        1.5G         46M        718M        2.5G
    Swap:           99M          0B         99M
    Total:         3.9G        1.6G        1.6G
    Active iob-Instances: 	28
    ioBroker Core: 		js-controller 		5.0.16
    			admin 			6.12.0
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : phoscon                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : phoscon                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects: 		13244
    States: 		10145
    Size of iob-Database:
    28M	/opt/iobroker/iobroker-data/objects.jsonl
    17M	/opt/iobroker/iobroker-data/objects.json.migrated
    17M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
    4.8M	/opt/iobroker/iobroker-data/states.jsonl
    3.0M	/opt/iobroker/iobroker-data/states.json.migrated
    3.0M	/opt/iobroker/iobroker-data/states.json.bak.migrated
    @gammler2003 sagte in Raspberry Pi plötzlich nicht mehr erreichbar:
    (buster)
    Ist EOL, muss ersetzt werden. Aktuell ist Raspberry OS 12 'Bookworm'.
    X-Server: true
    Schalt den Desktop-Mumpitz aus.
    Halte das System immer auf Stand.
    Installier nodejs ordentlich.
    G 1 Antwort Letzte Antwort
      (buster)
      X-Server: true
      gammler2003
      schrieb am zuletzt editiert von gammler2003
      @thomas-braun Vielen Dank dir für die Hinweise, die ich direkt umgesetzt habe! Jetzt warte ich mal ab, ob das System nun stabiler läuft. Ich berichte...
      			v.2023-10-10
               Icon name: computer
        Operating System: Raspbian GNU/Linux 12 (bookworm)
            Architecture: arm
      Kernel: 		armv7l
      Userland: 		armhf
      User-ID: 		1000
      X-Server: 		false
      Boot Target: 		multi-user.target
      Pending OS-Updates: 	0
      Pending iob updates: 	1
      Nodejs-Installation: 	/usr/bin/nodejs 	v18.18.2
      			/usr/bin/node 		v18.18.2
      			/usr/bin/npm 		9.8.1
      			/usr/bin/npx 		9.8.1
      			/usr/bin/corepack 	0.19.0
      MEMORY:
      Mem:            3.8G        1.2G        2.0G        1.0M        622M        2.5G
      Swap:            99M          0B         99M
      Total:          3.9G        1.2G        2.1G
      			admin 			6.12.0
      Objects type: jsonl
      States  type: jsonl
      Objects: 		13250
      States: 		10150
      18M	/opt/iobroker/iobroker-data/objects.jsonl
      24M	/opt/iobroker/iobroker-data/states.jsonl
      • G gammler2003
        			v.2023-10-10
                 Icon name: computer
              Architecture: arm
        Kernel: 		armv7l
        Userland: 		armhf
        User-ID: 		1000
        X-Server: 		false
        			/usr/bin/npm 		9.8.1
        			/usr/bin/npx 		9.8.1
        MEMORY:
        Swap:            99M          0B         99M
        			admin 			6.12.0
        Objects type: jsonl
        States  type: jsonl
        Objects: 		13250
        States: 		10150
        @gammler2003
        Das ist nicht richtig. Bookworm kommt mit einem Kernel 6.1 daher.
          @gammler2003
          gammler2003
          @thomas-braun Mhh...ok. Hast du mir einen Tipp, wie ich das mache? Hätte erwartet, das passiert automatisch mit dem Debian Upgrade. Danke dir.
          • G gammler2003
            Bei Debian passiert das auch, aber nicht bei Raspberry OS.
            Gibt aber mindestens zwei Threads dazu.
            Die Empfehlung ist und bleibt aber in dem Fall: Neuinstallation. Dann käme auch eine 64Bit-Installation in Frage (passende Hardware vorausgesetzt)
              thoml
              @gammler2003
              Was hast du als Speicher an dem Pi?
              Betreibst du zufällig ne SSD über nen USB Adapter daran?
              • T thoml
                @gammler2003
                gammler2003
                @thoml Eine SanDisk Extreme Pro 64 GB microSDXC Memory Card, welche direkt im Pi steckt.
                  gammler2003
                  @thomas-braun Alles klar, ich danke dir. Dann setze ich mich die Tage wohl tatsächlich mal an eine Neuinstallation und setze alles sauber auf.
                  Hast du eine Empfehlung, wie ich das am besten angehe (welches OS, fertiges Image, etc.)?
                  Nutze aktuell einen Raspberry Pi 4 Modell B; 4 GB, ARM-Cortex-A72 4 x, 1,50 GHz, 4 GB RAM. Macht es Sinn, mir direkt neue Hardware anzuschaffen oder reicht mein aktueller Raspberry Pi "locker" für ein bisschen ioBroker?
                  • G gammler2003
                    Raspberry Pi OS light 64 bit
                    • G Offline
                      gammler2003
                      nochmals vielen Dank für eure Hilfe und die Denkanstöße.
                      Ich habe mein System neu aufgesetzt und siehe da...es läuft wie geschmiert. Bisher konnte ich keine Ausfälle mehr feststellen.
