  4. [Neuer Adapter] Life360
    6.4k
adapterlife360geopositionpräsenzmelder
708 Beiträge 85 Kommentatoren 274.0k Aufrufe 70 Beobachtet
  • S Sandy
    Scheint wieder zu funktionieren. Habe keine Fehlermeldungen mehr. Habe nichts geändert.
    stefu87_CHS Offline
    stefu87_CHS Offline
    stefu87_CH
    #570
    @sandy Bei mir läuft er nicht
    2024-01-04 14:54:26.175 - error: life360.0 (2707463) Connection established but failed to authenticate. Check your credentials!
    2024-01-04 14:54:26.177 - info: life360.0 (2707463) Waiting for online operations to finish ...
    2024-01-04 14:54:26.262 - error: life360.0 (2707463) Connection established but failed to authenticate. Check your credentials!
    2024-01-04 14:54:26.263 - info: life360.0 (2707463) Waiting for online operations to finish ...
    2024-01-04 14:54:26.340 - error: life360.0 (2707463) Connection established but failed to authenticate. Check your credentials!
    2024-01-04 14:54:26.341 - info: life360.0 (2707463) Waiting for online operations to finish ...
    2024-01-04 14:54:26.420 - error: life360.0 (2707463) Connection established but failed to authenticate. Check your credentials!
    2024-01-04 14:54:26.421 - info: life360.0 (2707463) Waiting for online operations to finish ...
    2024-01-04 14:54:26.501 - error: life360.0 (2707463) Connection established but failed to authenticate. Check your credentials!
    2024-01-04 14:54:26.502 - info: life360.0 (2707463) Waiting for online operations to finish ...
    2024-01-04 14:54:26.588 - error: life360.0 (2707463) Connection established but failed to authenticate. Check your credentials!
    2024-01-04 14:54:26.589 - info: life360.0 (2707463) Waiting for online operations to finish ...
    2024-01-04 14:54:26.589 - error: life360.0 (2707463) Failed to connect or to login for 6 times. Aborting ...
    2024-01-04 14:54:26.589 - error: life360.0 (2707463) Error: Error: Connection established but failed to authenticate. Check your credentials!
    Cores: 1 × 8 = 8 cores
    Threads: 16
    mit Proxmox
    LXC Container mit Iobroker
    • S Sandy
      RiffcommanderR Offline
      Riffcommander
      #571
      @sandy Bei mir läuft er auch nicht.
        Sandy
        #572
        bei mir ist er grün
        aber im Protokoll habe ich diese Warnungen
        PS: jetzt habe ich auch wieder errors. Die ganze Zeit nicht ... komisch
          K_o_bold
          #573
          Wie könnte es hier nun weitergehen?
          Ist Life360 damit am Ende und man muss sich nach einer Alternative umschauen, oder gibt es noch Hoffnung dass es mal wieder dauerhaft läuft…
          MiGollerM 1 Antwort Letzte Antwort
          • K K_o_bold
            MiGollerM Offline
            MiGollerM Offline
            MiGoller
            #574
            Ab und an schaffe ich es wieder, mich anzumelden mit meinem Test-Tool, aber die nächste Abfrage der Life360 Kreise beendet das ganze dann sofort wieder.
            Bislang habe ich keinen Ansatzpunkt, wie ich das lösen könnte. Parallel beobachte ich auch die Home-Assistent Community... auch da wird eher über das "Aus" der Integration gesprochen, als das es Hoffnung auf baldige Lösung geben würde.
            Um es ganz deutlich zu sagen: Aktuell habe ich keinen Ansatz, dass ich den Adapter wieder ans Rennen bekomme. So leid es mir tut.
            ioBroker auf Intel Atom x5-Z8350 mit KNX, Gardena, Roomba, MQTT, Sonoff, Life360
            KnallochseK 1 Antwort Letzte Antwort
            • MiGollerM MiGoller
              KnallochseK Offline
              KnallochseK Offline
              Knallochse
              schrieb am zuletzt editiert von Knallochse
              #575
              @migoller Der Github HA Beitrag Link Text von „pantherale0“ hatte mir bisschen Hoffnung verschafft. Ist das kein Lösungsansatz für uns?
              • KnallochseK Knallochse
                MiGollerM Offline
                MiGollerM Offline
                MiGoller
                #576
                @knallochse welchen dieser Posts meinst Du: https://github.com/home-assistant/core/issues/106967#issuecomment-1875699137 oder den hier https://github.com/home-assistant/core/issues/106967#issuecomment-1876123190?
                Ich tippe auf den zweiten Post. Der Ansatz besteht darin, einen eigenen Request-Handler auf niedriger Ebene (für Python) nachzubauen, der sich für eine Web-Application-Firewall (hier Cloudflare) wie die Java-Bibliothek https://square.github.io/okhttp/ unter Android verhält. Ist eine interessante Theorie, die aber auch noch nicht bestätigt ist.
                Wir wissen, dass Android und iOS Geräte funktionieren; ob das allerdings wegen des "Fingerprints" der o.a. Bibliothek ist, oder ob der Cloudflare-Schutz auf einem "Verhalten" der App beruht, ist nicht bekannt. Der Autor der HA-Integration hat auch schon festgehalten, dass er die massiven Änderungen auch nicht mehr kompensieren kann (vgl. https://github.com/home-assistant/core/issues/106967#issuecomment-1875690924).
                Ich behalte das weiter im Blick und schaue, ob sich an einer Stelle eine Lösung abzeichnen könnte. Versprechen kann ich nichts. Meiner Wahrnehmung nach stehen auch andere Entwickler, die unabhängig Integrationen entwickelt haben, vor demselben Problem. Auch die voneinander unabhängigen Problemanalysen haben noch keinen Durchbruch gebracht.
                • malorossM Offline
                  malorossM Offline
                  maloross
                  #577
                  @migoller sagte in [Neuer Adapter] Life360:
                  Du hast ja bisher saubere Arbeit geleistet, der Adapter hat ja auch eine lange Zeit sehr gut funktioniert - dafür noch mal ein fettes Danke.
                  Ich gehe auch davon aus, dass alle evtl. vorhandenen "Löcher" noch gestopft werden und die Beschränkungen weiter intensiviert/verschärft werden.
                  Für Anwesenheitserkennung gibt es Alternativen, alles andere ist für mich eher ein "nice to have".
                  Auch Frauen können sich für Technik begeistern! ;)
                  Equipment:
                  diverse HM-, HMIP-, Aeotec- Tradfri- Sonos- und Fibaro-Geräte, NAS, Proxmox mit div. LXC,
                    KnallochseK Offline
                    KnallochseK Offline
                    Knallochse
                    #578
                    @migoller Danke für deine ausführliche Erklärung.
                    Ich möchte mich ebenfalls für deine bisherige Arbeit bedanken.
                    Du hast immer schnell auf die Änderung von Life360 reagiert.
                    Natürlich wäre es wünschenswert, dass der Adapter wieder funktioniert.
                    Für mich hat er alle Daten für eine Zuverlässige Anwesenheitserkennung geliefert (und eine Menge mehr).
                    Vielen Dank 🙏
                    • PischleuderP Online
                      PischleuderP Online
                      Pischleuder
                      schrieb am zuletzt editiert von Pischleuder
                      #579
                      Hallo Zusammen,
                      den Einsatz von @migoller finde ich auch großartig - Danke dafür.
                      Die E-Mail von life360 habe ich auch bekommen und da mir das Ganze langsam etwas suspekt erscheint, bin ich nun auf owntrack gewechselt, das funktioniert wunderbar.
                      • PischleuderP Pischleuder
                        Hallo Zusammen,
                        juggi1962
                        #580
                        @pischleuder sagte in [Neuer Adapter] Life360:
                        Hallo Zusammen,
                        Kannst du mir, uns sagen wie man das einrichtet. Eine kleine Anleitung wäre super für Handy und iobroker. Adapter und APP sind installiert. Danke im Voraus, Gruß Jürgen
                        BananaJoeB PischleuderP 2 Antworten Letzte Antwort
                        • J juggi1962
                          Hallo Zusammen,
                          BananaJoeB Offline
                          BananaJoeB Offline
                          BananaJoe
                          #581
                          @juggi1962 sagte in [Neuer Adapter] Life360:
                          Das gehört hier nicht her, ggf. ein eigenes Thema dafür aufmachen, aber:
                          • Anleitung des Adapters: https://github.com/iobroker-community-adapters/ioBroker.owntracks
                          • In den Adaptereinstellungen wird ebenfalls auf diese Anleitung verwiesen
                          • Oder das Thema zum Adapter hier im Forum: https://forum.iobroker.net/topic/26501/test-adapter-owntracks-v1-0-x-github?_=1704539129860
                          • BananaJoeB BananaJoe
                            MiGollerM Offline
                            MiGollerM Offline
                            MiGoller
                            #582
                            Die Home-Assistant-Community scheint mehr "Glück" gehabt zu haben und hat eine Antwort auf eine Anfrage zur Nutzung der Life360 API erhalten. Ihr könnt die Einlassung von Life360 zu Home-Automation-Integrationen direkt unter https://github.com/home-assistant/core/issues/106967#issuecomment-1879504648 und https://github.com/home-assistant/core/issues/106967#issuecomment-1879669135 nachlesen:
                            Thank you for contacting Life360 about your feedback and request to reconsider the Home Assistant functionality of the app. I will coordinate this with the appropriate team.
                            We understand the importance of using the Home Assistant program with Life360. However, please be aware that we no longer support home automation programs such as Home Assistant, Google Home, Alexa, IFTTT, and others, and Life360 is no longer compatible with these programs. Currently, we do not have any plans to reintroduce compatibility with these programs yet, we are constantly working to build products our members will love.
                            We appreciate your feedback and thank you so much for bringing this to our attention. I've recorded your feedback so that it can be reviewed and included in the planning of our development team for features to build next.
                            Ich danke Euch für Euer Feedback und Eure Unterstützung in den letzten Jahren. Es tut mir sehr leid, dass ich derzeit keine Lösung mehr liefern kann. Life360 werde ich im Auge behalten, ob sich da vielleicht doch noch etwas tut. Nur wenn Life360 weiterhin auf dem Kurs der Isolation bleibt, dann wird Life360 auch weiterhin alles tun, damit Integrationen praktisch nicht funktionieren werden.
                            malorossM 1 Antwort Letzte Antwort
                            • J juggi1962
                              Hallo Zusammen,
                              PischleuderP Online
                              PischleuderP Online
                              Pischleuder
                              #583
                              @juggi1962
                              es ist genau so, wie @BananaJoe es gesagt hat. Auf die github Seite des Adapters gehen und die Schritte befolgen. Die Einrichtung ist einfach, bei Fragen einfach neues Thema eröffen.
                                malorossM Offline
                                malorossM Offline
                                maloross
                                #584
                                Wenn Platzhirsche wie Amazon, Google & Co ausgeschlossen werden, sehe ich keine Chance, dass eine Öffnung für kleinere Anwendungen überhaupt in Betracht gezogen wird.
                                Hab schon überlegt, meinen Mann mit einem Tractive Tracker auszustatten ;)
                                Equipment:
                                • malorossM maloross
                                  K_o_bold
                                  schrieb am zuletzt editiert von K_o_bold
                                  #585
                                  Auch von mir vielen Dank für die tolle Arbeit von @MiGoller der letzten Jahre...
                                  Du warst immer sehr zuverlässig und sehr Reaktionsschnell... großen DANK!
                                  Ich für meinen Teil, habe mittlerweile eine sehr gute Alternative für IPhone Nutzer entdeckt.
                                  Ganz ohne Drittanbieter, nur mit IOS eigenen Bordmitteln und IoT Adapter des iobroker.
                                  Dazu einfach in der App Kurzbefehle eine Automation anlegen und auf den Ort triggern.
                                  Als Aktion kann ein https Befehl an den Service des IoT Adapters abgesetzt werden.
                                  Damit hat man einen Datenpunkt im iobroker und kann darauf seine Skripte ansetzen.
                                  Bei Interesse erstelle ich ein neues Thema mit der Anleitung dazu...
                                  MiGollerM E 2 Antworten Letzte Antwort
                                  • K K_o_bold
                                    MiGollerM Offline
                                    MiGollerM Offline
                                    MiGoller
                                    #586
                                    @k_o_bold Hmm, könnte ich mir gleich auch einmal ansehen. Du rufst einfach einen Web-Hook, also einen https-Endpunkt des IoT Adapters auf?
                                      K_o_bold
                                      #587
                                      @migoller ,
                                      jup....
                                      Die Automation lautet bei mir so....
                                      Wenn ich einen bestimmten Ort erreiche (Radius kann eingestellt werden), dann rufe Inhalt von URL ab... Die URL habe ich aus dem IoT Adapter und endsprechend abgeändert, nach meinen Bedürfnissen ( gelbe Markierung ändern )
                                      • E Offline
                                        eve11
                                        #588
                                        Ich bin jetzt erst mal auf Traccar umgestiegen. Der eigene Server war in einem LXC Container auf Proxmox in 10 Minuten installiert. Soweit funktioniert alles tadellos. Nur der Traccar Adapter wäre noch ausbaufähig. Ein ähnlicher Funktionsumfang dito Life360 wäre wünschenswert.
                                        Heiko
                                        • K K_o_bold
                                          eve11
                                          #589
                                          @k_o_bold
                                          Btw.
                                          Das funktioniert ähnlich auch mit Android und Tasker. Die Option mit Traccar ist aber natürlich um einiges komfortabler.
