  4. Test ioBroker unter Windows installieren - 2023 Edition
    6.8k
installation iobrokerwindowswindows installation
405 Beiträge 25 Kommentatoren 120.8k Aufrufe 22 Beobachtet
  • K klassisch
    @gaspode
    Jetzt taucht plötzlich die 6er wieder auf
    C:\ioBroker>iob fix
    Windows installation starting... (fixing = true)
    NPM version: 10.2.3
    Usage: npm <command>
    where <command> is one of:
        access, adduser, audit, bin, bugs, c, cache, ci, cit,
        clean-install, clean-install-test, completion, config,
        create, ddp, dedupe, deprecate, dist-tag, docs, doctor,
        edit, explore, fund, get, help, help-search, hook, i, init,
        install, install-ci-test, install-test, it, link, list, ln,
        login, logout, ls, org, outdated, owner, pack, ping, prefix,
        profile, prune, publish, rb, rebuild, repo, restart, root,
        run, run-script, s, se, search, set, shrinkwrap, star,
        stars, start, stop, t, team, test, token, tst, un,
        uninstall, unpublish, unstar, up, update, v, version, view,
        whoami
    npm <command> -h  quick help on <command>
    npm -l            display full usage info
    npm help <term>   search for help on <term>
    npm help npm      involved overview
    Specify configs in the ini-formatted file:
        C:\Users\JS\.npmrc
    or on the command line via: npm <command> --key value
    Config info can be viewed via: npm help config
    npm@6.14.17 C:\ioBroker\node_modules\npm
    node:child_process:965
        throw err;
    Error: Command failed: npm x --yes @iobroker/jsonltool@latest
        at checkExecSyncError (node:child_process:890:11)
        at execSync (node:child_process:962:15)
        at Object.<anonymous> (C:\Users\JS\AppData\Local\npm-cache\_npx\19d197aa1f8fa98c\node_modules\@iobroker\fix\lib-npx\install.js:71:17)
        at Module._compile (node:internal/modules/cjs/loader:1356:14)
        at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
        at Module.load (node:internal/modules/cjs/loader:1197:32)
        at Module._load (node:internal/modules/cjs/loader:1013:12)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
        at node:internal/main/run_main_module:28:49 {
      status: 1,
      signal: null,
      output: [ null, null, null ],
      pid: 5424,
      stdout: null,
      stderr: null
    Node.js v18.19.0
    C:\ioBroker>npm -v
    10.2.3
    C:\ioBroker>
    Ich erinnere mich nicht wissentlich und willentlich npm installiert zu haben. Kann das aber nicht ausschließen. Wie gesagt, das System ist im Grunde recht alt und hat etliche Migrationen hinter sich.
    GaspodeG Online
    GaspodeG Online
    Gaspode
    #210
    @klassisch said in Test ioBroker unter Windows installieren - 2023 Edition:
    Was hast du genau gemacht? npm Ordner in node_modules wieder umbenannt und dann in c:\iobroker "npm uninstall npm" ausgeführt? Hast du davon ein Log?
    • GaspodeG Gaspode
      klassisch
      #211
      @gaspode sagte in Test ioBroker unter Windows installieren - 2023 Edition:
      Ja, das habe ich wohl verkorkst
      Das Rückumbenennen hatte ich leider nicht gemacht. War dumm und wurde mir recht schnell klar.
      Aber nach dem npm uninstall npm war auch der umbenannte Ordner weg.
      Logfile: Hat npm ein eigenes logfile?
      GaspodeG 1 Antwort Letzte Antwort
      • K klassisch
        GaspodeG Online
        GaspodeG Online
        Gaspode
        #212
        Nur was auf der Konsole ausgespuckt wird, wenn man es nicht umleitet, soweit ich weiß.
        • GaspodeG Gaspode
          klassisch
          #213
          @gaspode Den Konsolenoutput hatte ich hier rein kopiert. Nach iob start wird die Konsole ja gelöscht.
          Im ioBroker log habe ich nichts passendes gefunden.
          Sorry, habe es "screwed up"
          • GaspodeG Online
            GaspodeG Online
            Gaspode
            #214
            Kein Problem. Also das Verzeichnis node_modules\npm ist jetzt weg und trotzdem steht im Log
            Das kann eigentlich gar nicht sein. Hmmm.
            • GaspodeG Gaspode
              klassisch
              #215
              @gaspode
              Das von mir in
              \iobroker\node_modules\npm_delete_candidate
              umbenannte Verzeichnis, welches so aussah
              ist jetzt weg
              Dafür gibt es jetzt wieder ein npm, welches heute frisch angelegt wurde - aber nicht von mir
              Warum auch immer. Das npm System ist eben intelligenter als ich.
              • K klassisch
                @gaspode
                Das von mir in
                ist jetzt weg
                GaspodeG Online
                GaspodeG Online
                Gaspode
                #216
                Das ist ja erstaunlich. Wann kam das denn rein? Kannst du nochmal "npm uninstall npm" machen und gucken, ob das denn erst mal weg ist?
                • GaspodeG Gaspode
                  klassisch
                  #217
                  npm uninstall npm
                  Klar
                  C:\ioBroker>npm uninstall npm
                  up to date, audited 2461 packages in 34s
                  192 packages are looking for funding
                    run `npm fund` for details
                  124 vulnerabilities (4 low, 64 moderate, 44 high, 12 critical)
                  To address issues that do not require attention, run:
                    npm audit fix
                  To address all issues possible (including breaking changes), run:
                    npm audit fix --force
                  Some issues need review, and may require choosing
                  a different dependency.
                  Run `npm audit` for details.
                  C:\ioBroker>
                  Das Ding ist persistent oder resistent:
                  • K klassisch
                    npm uninstall npm
                    Klar
                      npm audit fix
                    C:\ioBroker>
                    GaspodeG Online
                    GaspodeG Online
                    Gaspode
                    #218
                    @klassisch
                    Die Frage ist, wer das (wieder) angelegt hat.
                    Du könntest es jetzt nochmal weg putzen und dann den Fixer nochmal starten. Ob uns das aber unterm Strich weiter bringt ...
                    Auf jeden Fall Danke für deine Geduld.
                    • GaspodeG Gaspode
                      @klassisch
                      klassisch
                      #219
                      @klassisch
                      Ich nicht. Da scheint npm einen intelligenten Reparaturmechanismus zu haben, der dann leider auch den Schrott, den man eigentlich loswerden will, repariert
                      Einfach das Verzeichnis
                      löschen?
                      Solange es nichts zerstört
                      Kein Problem
                      Dito. Ist ja ein unerwünschtes Relikt meiner Installations- Update- und Gebrauchsgeschichte.
                      • K klassisch
                        @klassisch
                        löschen?
                        Kein Problem
                        GaspodeG Online
                        GaspodeG Online
                        Gaspode
                        #220
                        löschen?
                        Ja, das hab ich gemeint.
                        Eine Garantie gibt es halt nicht, aber das dürfte nix schaden. 👍
                        Wenn es beim Fix wieder tatsächlich auch diesmal wieder installiert wird, muss ich mir was einfallen lassen, wie wir das irgendwie tracken können. Ich bin demnächst aber mal für ne Weile busy. :)
                        • GaspodeG Gaspode
                          löschen?
                          klassisch
                          #221
                          @gaspode
                          Gelöscht:
                          iob fix
                          C:\ioBroker>iob fix
                          NPM version: 10.2.3
                          node:internal/modules/cjs/loader:1137
                            throw err;
                          Error: Cannot find module 'C:\ioBroker\node_modules\npm\bin\npm-cli.js'
                              at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
                              at Module._load (node:internal/modules/cjs/loader:975:27)
                            code: 'MODULE_NOT_FOUND',
                            requireStack: []
                          Node.js v18.19.0
                              throw err;
                            status: 1,
                            signal: null,
                            pid: 13628,
                            stdout: null,
                            stderr: null
                          Node.js v18.19.0
                          C:\ioBroker>
                          Immer noch weg
                          iob start
                          immer noch weg.
                          Vielleicht kommt es bei nächsten reboot? Wir werden sehen.
                          Hat ja keine Eile. ioBroker läuft ja stabil bei mir.
                          • JB_SullivanJ Offline
                            JB_Sullivan
                            #222
                            Aus gegebenen Anlass hätte ich eine Frage.
                            Die Tage gab es ein Update des Adapter "device-watcher". Irgend etwas wurde dort "falsch" gemacht, was nahezu den gesamten ioBroker zum erliegen brachte (CPU / RAM Ausnutzung = 100%). Damit war ioBroker fast nicht mehr bedienbar (z.B. Instanzen stoppen) . Auch eine korrigierte Adapter Version brauchte Stunden um über GIT eingespielt zu werden.
                            Unter Windows sieht man ja nun im Task Manager alle laufenden NODE Prozesse. Ich gehe davon aus, das jeder Node Prozess, ein laufender Adapter ist. Leider heißen alle Prozesse NODE. Man kann also über den Task Manager nicht gezielt NODE Prozesse (= Adapter) abbrechen oder stoppen.
                            Ist das etwas Windows spezifisches, was man ggf. mit der ioBroker Installation über den WIN Installer lösen könnte? Soll heißen, könnte man jedem Node Prozess in Windows ggf. den Adapter Namen anhängen?
                            Somit könnte man in solchen Ausnahme Situationen wie oben beschrieben, eine Adapter Instanz ggf. auch gezielt über den Windows Task Manager abbrechen / stoppen.
                            Ist diese Idee völliger Bullshit oder Wert, ggf. einmal darüber nachzudenken?
                            mcm1957M UweRLPU apollon77A 3 Antworten Letzte Antwort
                            • JB_SullivanJ JB_Sullivan
                              mcm1957M Online
                              mcm1957M Online
                              mcm1957
                              #223
                              @jb_sullivan
                              Gegenfrage:
                              Wenn du weißt oder vermutest dass es der Adapter xyz ist warum stoppst du dann die Instanz nicht ganz normal?
                              Und wenns via gui nicht geht dann via commandline?
                              Und zu deiner eigentlcihen Frage:
                              Das wird nicht gehen. Der Windows installer installiert nur node und die core componenten. Der hat nichts mit den laufenden INstanzen zu tun.
                              Support Repositoryverwaltung.
                              LESEN - gute Forenbeitrage
                              • mcm1957M mcm1957
                                @jb_sullivan
                                Gegenfrage:
                                JB_Sullivan
                                #224
                                @mcm57 sagte in Test ioBroker unter Windows installieren - 2023 Edition:
                                Ich wusste zu dem Zeitpunkt nicht, welcher Adapter es war. Ich konnte zwar sehen das ein NODE Prozess 75% Systemauslastung produzierte, aber welcher Adapter es war, wusste ich da noch nicht.
                                Ich bin erst durch das Forum durch einen einen entsprechenden Beitrag eines anderen Betroffenen darauf aufmerksam gemacht worden, das der device-watcher die System Last nach oben pusht.
                                Darum ja auch die Anfrage bzgl. der Klarnameszusätze bei den NODE Prozessen.
                                GaspodeG mcm1957M 2 Antworten Letzte Antwort
                                  GaspodeG Online
                                  GaspodeG Online
                                  Gaspode
                                  #225
                                  @jb_sullivan
                                  Also grundsätzlich ist es mal keine gute Idee, irgendwelche Node Prozesse abzuschießen. Und wie @mcm57 schon schrub, ist das nicht wirklich ein Installer Thema.
                                  Wenn ich das Problem hätte, würde ich notfalls wohl den Node Prozess killen und auf der CLI mit ...
                                  iob logs
                                  gucken, welchen Adapter es denn getroffen hat.
                                  • GaspodeG Online
                                    GaspodeG Online
                                    Gaspode
                                    schrieb am zuletzt editiert von Gaspode
                                    #226
                                    Schon neu gebootet? :D
                                    Um zu klären, ob das wirklich wie ich vermute ein npx Thema ist oder doch eins vom Fixer-Script, wäre es toll, wenn du mal folgenden Test machen könntest und den Fixer unter Umgehung von npx starten könntest. Das geht mit:
                                    iob stop
                                    npm install @iobroker/fix
                                    node node_modules\@iobroker\fix\lib-npx\install.js fix
                                    Edit:
                                    Ach ja, aufräumen kannst du anschließend mit
                                    npm uninstall @iobroker/fix
                                    • GaspodeG Gaspode
                                      iob stop
                                      Edit:
                                      klassisch
                                      #227
                                      Gerade jetzt. unverändert, ist weg:
                                      Normalerweise boote ich ja nur nach Win Updates.
                                      Ich verstehe gar nichts:
                                      ioBroker wird beendet.
                                      ioBroker wurde erfolgreich beendet.
                                      C:\ioBroker>npm install @iobroker/fix
                                      added 5 packages, removed 3 packages, changed 3 packages, and audited 2462 packages in 51s
                                      193 packages are looking for funding
                                      121 vulnerabilities (4 low, 62 moderate, 44 high, 11 critical)
                                        npm audit fix
                                      C:\ioBroker> node node_modules\@iobroker\fix\lib-npx\install.js fix
                                      NPM version: 10.2.3
                                      No path given, using C:\ioBroker\iobroker-data
                                      Compressing C:\ioBroker\iobroker-data\states.jsonl
                                      Compressing C:\ioBroker\iobroker-data\objects.jsonl
                                      Compressed 2 JSONL files. Done
                                      NPM version: 10.2.3
                                      Write "iobroker start" to start the ioBroker
                                      npm install node-windows@1.0.0-beta.8 --force --loglevel error --production --save --prefix "C:/ioBroker"
                                      up to date, audited 2462 packages in 7s
                                        npm audit fix
                                      npm install dotenv@^16.0.3 --force --loglevel error --production --save --prefix "C:/ioBroker"
                                      changed 1 package, and audited 2462 packages in 7s
                                        npm audit fix
                                      npm install windows-shortcuts@^0.1.6 --force --loglevel error --production --save --prefix "C:/ioBroker"
                                        npm audit fix
                                      Running Admin shell
                                      ioBroker service name: ioBroker
                                      ioBroker ist nicht gestartet.
                                      Sie erhalten weitere Hilfe, wenn Sie NET HELPMSG 3521 eingeben.
                                      Written iobnodevars.bat successfully.
                                      ioBroker service is already installed.
                                      Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\ioBroker Admin.lnk" created!
                                      Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\ioBroker Command line.lnk" created with Admin flag!
                                      Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\Restart ioBroker Service.lnk" created with Admin flag!
                                      Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\Start ioBroker Service.lnk" created with Admin flag!
                                      Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\Stop ioBroker Service.lnk" created with Admin flag!
                                      Running Admin shell
                                      ioBroker wird gestartet.
                                      ioBroker wurde erfolgreich gestartet.
                                      ioBroker service installed and started. Go to http://localhost:8081 to open the admin UI.
                                      To see the outputs do not start the service, but write "node node_modules/iobroker.js-controller/controller"
                                      C:\ioBroker>
                                      Edit:
                                      ioBroker is automatisch wieder gestartet
                                      • K klassisch
                                          npm audit fix
                                        NPM version: 10.2.3
                                        NPM version: 10.2.3
                                          npm audit fix
                                          npm audit fix
                                          npm audit fix
                                        Running Admin shell
                                        Running Admin shell
                                        C:\ioBroker>
                                        Edit:
                                        GaspodeG Online
                                        GaspodeG Online
                                        Gaspode
                                        #228
                                        Der Fixer ist erfolgreich gelaufen. Es liegt also tatsächlich an einer verkorksten npx Installation auf deinem Rechner.
                                        Ich überleg mir was ...
                                        • GaspodeG Gaspode
                                          klassisch
                                          #229
                                          @gaspode Vielen Dank, dann führe ich mal das Aufräumkommando aus.
                                          War zu befürchten. Alte Installation mit langer Historie.
