  4. ZigBee neue Version 1.8.x
385 Beiträge 55 Kommentatoren 110.9k Aufrufe 49 Beobachtet
  • David G.D Online
    David G.D Online
    David G.
    #360
    Hatte mit der 1.8.25 auch das Problem. Die git Version hat es behoben.
    • arteckA arteck
      @diwoma
      ist es mit der 1.9.4 immer noch so ?
      D Online
      D Online
      diwoma
      #361
      @arteck
      Hi @arteck
      Ich habe jetzt auf die Version 1.9.5 upgedated, aber das gleiche Verhalten, sobald ich einen Schalter betätige. Jetzt habe ich das Log ohne Filter herauskopiert:
      2023-12-30 07:25:36.820 - info: host.ioBroker instance system.adapter.zigbee.0 started with pid 15027
      2023-12-30 07:25:37.775 - info: host.ioBroker iobroker exit 0
      2023-12-30 07:25:38.196 - info: zigbee.0 (15027) starting. Version 1.9.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.18.1, js-controller: 5.0.17
      2023-12-30 07:25:38.237 - info: zigbee.0 (15027) delete old Backup files. keep only last 10
      2023-12-30 07:25:38.237 - info: zigbee.0 (15027) Starting Zigbee npm ...
      2023-12-30 07:25:38.340 - info: zigbee.0 (15027) Installed Version: iobroker.zigbee@1.9.5
      2023-12-30 07:25:39.798 - info: zigbee.0 (15027) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
      2023-12-30 07:25:39.806 - info: zigbee.0 (15027) Unable to disable LED, unsupported function.
      2023-12-30 07:25:39.811 - info: zigbee.0 (15027) --> transmitPower : low
      2023-12-30 07:25:39.822 - info: zigbee.0 (15027) Currently 45 devices are joined:
      2023-12-30 07:25:39.868 - info: zigbee.0 (15027) 0xa4c13876abf5c23c (addr 63498): TS130F - TuYa Curtain/blind switch (Router)
      2023-12-30 07:25:39.869 - info: zigbee.0 (15027) 0xa4c138cf0f4d6c9d (addr 40245): TS130F - TuYa Curtain/blind switch (Router)
      2023-12-30 07:25:39.869 - info: zigbee.0 (15027) 0xa4c138fa86b402b3 (addr 55323): TS130F - TuYa Curtain/blind switch (Router)
      2023-12-30 07:25:39.870 - info: zigbee.0 (15027) 0xa4c138d03cfd7c87 (addr 16453): TS130F - TuYa Curtain/blind switch (Router)
      2023-12-30 07:25:39.870 - info: zigbee.0 (15027) 0xa4c1389eba0dfb0c (addr 43813): TS130F - TuYa Curtain/blind switch (Router)
      2023-12-30 07:25:39.870 - info: zigbee.0 (15027) 0xa4c1380bcc7198fc (addr 57782): TS130F - TuYa Curtain/blind switch (Router)
      2023-12-30 07:25:39.871 - info: zigbee.0 (15027) 0x00158d0007c0ccb6 (addr 4414): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
      2023-12-30 07:25:39.871 - info: zigbee.0 (15027) 0xa4c138dd7383733e (addr 56754): TS130F - TuYa Curtain/blind switch (Router)
      2023-12-30 07:25:39.871 - info: zigbee.0 (15027) 0xa4c138b098c7b89a (addr 26209): TS130F - TuYa Curtain/blind switch (Router)
      2023-12-30 07:25:39.871 - info: zigbee.0 (15027) 0xa4c138776188659a (addr 53240): TS130F - TuYa Curtain/blind switch (Router)
      2023-12-30 07:25:39.872 - info: zigbee.0 (15027) 0xa4c138f9c456ced4 (addr 9563): TS130F - TuYa Curtain/blind switch (Router)
      2023-12-30 07:25:39.872 - info: zigbee.0 (15027) 0xa4c138ca8b391c07 (addr 16480): TS130F - TuYa Curtain/blind switch (Router)
      2023-12-30 07:25:39.872 - info: zigbee.0 (15027) 0xa4c138b7cb58d6a5 (addr 20661): TS130F - TuYa Curtain/blind switch (Router)
      2023-12-30 07:25:39.872 - info: zigbee.0 (15027) 0x00158d00070b7d44 (addr 59646): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      2023-12-30 07:25:39.873 - info: zigbee.0 (15027) 0xa4c13879937e5fa8 (addr 63902): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
      2023-12-30 07:25:39.873 - info: zigbee.0 (15027) 0x00158d0008381814 (addr 43381): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      2023-12-30 07:25:39.873 - info: zigbee.0 (15027) 0x00158d000705d7eb (addr 19343): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      2023-12-30 07:25:39.874 - info: zigbee.0 (15027) 0x00158d000704fe0a (addr 10152): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      2023-12-30 07:25:39.874 - info: zigbee.0 (15027) 0x00158d000705e33b (addr 54488): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      2023-12-30 07:25:39.874 - info: zigbee.0 (15027) 0x00158d0007e086a3 (addr 58696): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      2023-12-30 07:25:39.874 - info: zigbee.0 (15027) 0x00158d0007e0e614 (addr 62826): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2023-12-30 07:25:39.875 - info: zigbee.0 (15027) 0x54ef44100016e313 (addr 55265): QBKG38LM - Xiaomi Aqara E1 1 gang switch (without neutral) (EndDevice)
      2023-12-30 07:25:39.875 - info: zigbee.0 (15027) 0x5c0272fffe1a08fc (addr 63031): ZTS-EU_2gang - Moes Wall touch light switch (2 gang) (EndDevice)
      2023-12-30 07:25:39.876 - info: zigbee.0 (15027) 0x84fd27fffe636592 (addr 16108): ZTS-EU_1gang - Moes Wall touch light switch (1 gang) (EndDevice)
      2023-12-30 07:25:39.876 - info: zigbee.0 (15027) 0x54ef44100016dbee (addr 61351): QBKG38LM - Xiaomi Aqara E1 1 gang switch (without neutral) (EndDevice)
      2023-12-30 07:25:39.877 - info: zigbee.0 (15027) 0xa4c138a0c9746c97 (addr 42626): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
      2023-12-30 07:25:39.877 - info: zigbee.0 (15027) 0x00158d000839dee4 (addr 53766): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      2023-12-30 07:25:39.878 - info: zigbee.0 (15027) 0xa4c1386c002483ef (addr 30546): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
      2023-12-30 07:25:39.878 - info: zigbee.0 (15027) 0x00158d0007e0a798 (addr 40613): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      2023-12-30 07:25:39.878 - info: zigbee.0 (15027) 0x00158d00075f96be (addr 58534): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2023-12-30 07:25:39.879 - info: zigbee.0 (15027) 0x00158d0007e4df68 (addr 54725): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2023-12-30 07:25:39.879 - info: zigbee.0 (15027) 0x847127fffec6ac1c (addr 52994): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice)
      2023-12-30 07:25:39.879 - info: zigbee.0 (15027) 0x00158d0007014491 (addr 55022): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
      2023-12-30 07:25:39.880 - info: zigbee.0 (15027) 0xb4e3f9fffed0a7d3 (addr 46735): LED1949C5 - IKEA TRADFRI LED bulb E12/E14 450/470 lumen, wireless dimmable white spectrum/chandelier opal white (Router)
      2023-12-30 07:25:39.880 - info: zigbee.0 (15027) 0x00158d0007e0a744 (addr 51448): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      2023-12-30 07:25:39.880 - info: zigbee.0 (15027) 0x00158d0007d49e0d (addr 40105): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2023-12-30 07:25:39.881 - info: zigbee.0 (15027) 0x00158d00075fbd98 (addr 9668): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2023-12-30 07:25:39.881 - info: zigbee.0 (15027) 0x540f57fffe69b55d (addr 10992): ZTS-EU_1gang - Moes Wall touch light switch (1 gang) (EndDevice)
      2023-12-30 07:25:39.881 - info: zigbee.0 (15027) 0x00124b0024c05546 (addr 53231): ZBMINI-L - SONOFF Zigbee smart switch (no neutral) (EndDevice)
      2023-12-30 07:25:39.882 - info: zigbee.0 (15027) 0x00158d000775afd2 (addr 43188): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2023-12-30 07:25:39.882 - info: zigbee.0 (15027) 0x00158d0009422623 (addr 26658): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2023-12-30 07:25:39.882 - info: zigbee.0 (15027) 0x00158d000926bb27 (addr 48772): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      2023-12-30 07:25:39.883 - info: zigbee.0 (15027) 0x3425b4fffe2f9af3 (addr 8545): E1746 - IKEA TRADFRI signal repeater (Router)
      2023-12-30 07:25:39.883 - info: zigbee.0 (15027) 0xa4c1387d37c5bdcc (addr 58825): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
      2023-12-30 07:25:39.883 - info: zigbee.0 (15027) 0x00158d0009ef6862 (addr 10788): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      2023-12-30 07:25:39.884 - info: zigbee.0 (15027) Zigbee started
      2023-12-30 07:25:39.885 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS130F.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS130F.png
      2023-12-30 07:25:39.890 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS130F.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS130F.png
      2023-12-30 07:25:39.892 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS130F.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS130F.png
      2023-12-30 07:25:39.894 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS130F.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS130F.png
      2023-12-30 07:25:39.895 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS130F.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS130F.png
      2023-12-30 07:25:39.896 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS130F.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS130F.png
      2023-12-30 07:25:39.898 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS130F.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS130F.png
      2023-12-30 07:25:39.899 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS130F.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS130F.png
      2023-12-30 07:25:39.900 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS130F.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS130F.png
      2023-12-30 07:25:39.901 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS130F.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS130F.png
      2023-12-30 07:25:39.902 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS130F.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS130F.png
      2023-12-30 07:25:39.903 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS130F.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS130F.png
      2023-12-30 07:25:39.905 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_3.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_3.png
      2023-12-30 07:25:39.909 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/QBKG38LM.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/QBKG38LM.png
      2023-12-30 07:25:39.910 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/ZTS-EU_2gang.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZTS-EU_2gang.png
      2023-12-30 07:25:39.911 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/ZTS-EU_1gang.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZTS-EU_1gang.png
      2023-12-30 07:25:39.912 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/QBKG38LM.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/QBKG38LM.png
      2023-12-30 07:25:39.913 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
      2023-12-30 07:25:39.914 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
      2023-12-30 07:25:39.917 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/LED1949C5.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/LED1949C5.png
      2023-12-30 07:25:39.920 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/ZTS-EU_1gang.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZTS-EU_1gang.png
      2023-12-30 07:25:39.921 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/ZBMINI-L.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZBMINI-L.png
      2023-12-30 07:25:39.925 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
      2023-12-30 07:25:40.169 - info: zigbee.0 (15027) debug devices set to []
      2023-12-30 07:25:40.379 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee SW-005-1G angemeldet
      2023-12-30 07:25:40.381 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee SW-002-2G angemeldet
      2023-12-30 07:25:40.381 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee SW-001-1G angemeldet
      2023-12-30 07:25:40.382 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee SW-003-1G angemeldet
      2023-12-30 07:25:40.391 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee SW-004-1G angemeldet
      2023-12-30 07:25:40.398 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee SW-006-1G angemeldet
      2023-12-30 07:25:40.726 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-006 angemeldet
      2023-12-30 07:25:40.758 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-005 angemeldet
      2023-12-30 07:25:40.826 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-002 angemeldet
      2023-12-30 07:25:40.940 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-001 angemeldet
      2023-12-30 07:25:40.941 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-003 angemeldet
      2023-12-30 07:25:40.942 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-007 angemeldet
      2023-12-30 07:25:40.944 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-004 angemeldet
      2023-12-30 07:25:40.945 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-044 angemeldet
      2023-12-30 07:25:40.947 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-041 angemeldet
      2023-12-30 07:25:40.948 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-040 angemeldet
      2023-12-30 07:25:40.949 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-043 angemeldet
      2023-12-30 07:25:40.984 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-042 angemeldet
      2023-12-30 07:25:40.986 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee PLUG-005 angemeldet
      2023-12-30 07:25:40.997 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee PLUG-007 angemeldet
      2023-12-30 07:25:40.998 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee PLUG-008 angemeldet
      2023-12-30 07:25:41.005 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee TRADFRI-001 angemeldet
      2023-12-30 07:25:41.014 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee REP-001 angemeldet
      2023-12-30 07:26:56.248 - info: javascript.0 (462) script.js.Steuerung.Licht.AutoSwitchOff: Vorratsraum Licht (SW-004-1G): Schalter State true
      2023-12-30 07:26:56.250 - info: javascript.0 (462) script.js.Steuerung.Licht.AutoSwitchOff: Vorratsraum Licht (SW-004-1G): Check Autowitch (0_userdata.0.Light.AutoSwitchOff.Vorratsraum) = true
      2023-12-30 07:26:56.250 - info: javascript.0 (462) script.js.Steuerung.Licht.AutoSwitchOff: Vorratsraum Licht (SW-004-1G): Set Timeout to 5 min
      2023-12-30 07:26:56.250 - info: javascript.0 (462) script.js.Steuerung.Licht.AutoSwitchOff: Vorratsraum Licht (SW-004-1G): Set BlockMovement to false
      2023-12-30 07:26:56.250 - info: javascript.0 (462) script.js.Steuerung.Licht.AutoSwitchOff: Vorratsraum Licht (SW-004-1G): Licht durch Schalter eingeschaltet
      2023-12-30 07:26:56.250 - info: javascript.0 (462) script.js.Steuerung.Allgemein.LogForDevices: $Vorratsraum Licht (SW-004-1G) eingeschaltet
      2023-12-30 07:26:56.464 - error: zigbee.0 (15027) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-12-30 07:26:56.464 - error: zigbee.0 (15027) unhandled promise rejection: Cannot read properties of null (reading 'hasOwnProperty')
      2023-12-30 07:26:56.464 - error: zigbee.0 (15027) TypeError: Cannot read properties of null (reading 'hasOwnProperty')
      at /opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:628:62
      at Array.filter ()
      at StatesController.publishToState (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:628:34)
      2023-12-30 07:26:56.464 - error: zigbee.0 (15027) Cannot read properties of null (reading 'hasOwnProperty')
      2023-12-30 07:26:56.468 - info: zigbee.0 (15027) cleaned everything up...
      2023-12-30 07:26:56.525 - info: zigbee.0 (15027) Zigbee: disabling joining new devices.
      2023-12-30 07:26:56.573 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-006 abgemeldet
      2023-12-30 07:26:56.574 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-005 abgemeldet
      2023-12-30 07:26:56.575 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-002 abgemeldet
      2023-12-30 07:26:56.575 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-001 abgemeldet
      2023-12-30 07:26:56.576 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-003 abgemeldet
      2023-12-30 07:26:56.577 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-007 abgemeldet
      2023-12-30 07:26:56.578 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-004 abgemeldet
      2023-12-30 07:26:56.579 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-044 abgemeldet
      2023-12-30 07:26:56.581 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-041 abgemeldet
      2023-12-30 07:26:56.583 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-040 abgemeldet
      2023-12-30 07:26:56.585 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-043 abgemeldet
      2023-12-30 07:26:56.587 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-042 abgemeldet
      2023-12-30 07:26:56.588 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee PLUG-005 abgemeldet
      2023-12-30 07:26:56.612 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee SW-005-1G abgemeldet
      2023-12-30 07:26:56.614 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee SW-002-2G abgemeldet
      2023-12-30 07:26:56.615 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee SW-001-1G abgemeldet
      2023-12-30 07:26:56.616 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee SW-003-1G abgemeldet
      2023-12-30 07:26:56.619 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee PLUG-007 abgemeldet
      2023-12-30 07:26:56.629 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee PLUG-008 abgemeldet
      2023-12-30 07:26:56.634 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee TRADFRI-001 abgemeldet
      2023-12-30 07:26:56.640 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee SW-004-1G abgemeldet
      2023-12-30 07:26:56.641 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee SW-006-1G abgemeldet
      2023-12-30 07:26:56.644 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee REP-001 abgemeldet
      2023-12-30 07:26:56.968 - info: zigbee.0 (15027) terminating
      2023-12-30 07:26:56.969 - warn: zigbee.0 (15027) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2023-12-30 07:26:57.517 - error: host.ioBroker Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-12-30 07:26:57.517 - error: host.ioBroker Caught by controller[2]: TypeError: Cannot read properties of null (reading 'hasOwnProperty')
      2023-12-30 07:26:57.517 - error: host.ioBroker Caught by controller[2]: at /opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:628:62
      2023-12-30 07:26:57.517 - error: host.ioBroker Caught by controller[2]: at Array.filter ()
      2023-12-30 07:26:57.517 - error: host.ioBroker Caught by controller[2]: at StatesController.publishToState (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:628:34)
      2023-12-30 07:26:57.517 - error: host.ioBroker instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2023-12-30 07:26:57.517 - info: host.ioBroker Restart adapter system.adapter.zigbee.0 because enabled
      Vielleicht sagt das mehr aus.
      Ich schalte wieder auf 1.8.25 zurück, die bei mir funktioniert.
      -- diwoma
      ioBroker in LX-Container in Proxmox
      Zigbee-Coordinator: CC2652P2-TCP FW: 20230507
      D arteckA 2 Antworten Letzte Antwort
      • D diwoma
        @arteck
        Hi @arteck
        at Array.filter ()
        D Online
        D Online
        diwoma
        #362
        @diwoma
        Memo an mich, vor dem nächsten Update einen Snapshot ziehen!
        In der Auswahlliste für die Installation einer früheren Version werden nur 6 Schritte angezeigt. Das ging somit bei mir nur bis V 1.8.27. Wie ich über GIT eine ältere Version auswählen könnte, habe ich nicht herausgefunden.
        Also habe ich das nächtliche Backup wieder eingespielt.
        -- diwoma
        • D diwoma
          @arteck
          Hi @arteck
          at Array.filter ()
          arteckA Offline
          arteckA Offline
          arteck
          #363
          @diwoma ja und jetzt kann ich schauen woran es liegt...
          installier mal von GIT..sollte jetzt gehen
          welche Gerät ist das.SW-004-1G. zeigmal die Info Kachel
          D 3 Antworten Letzte Antwort
          • arteckA arteck
            D Online
            D Online
            diwoma
            #364
            @arteck
            Info-Kachel:
            -- diwoma
            • arteckA arteck
              D Online
              D Online
              diwoma
              #365
              @arteck sagte in ZigBee neue Version 1.8.x:
              Danke, damit scheint der Fehler behoben zu sein, zumindest mit der Schaltaktion. Sicher kann ich erst sein, wenn die batteriebetriebenen Einheiten von sich aus was gemeldet haben.
              -- diwoma
              • arteckA arteck
                D Online
                D Online
                diwoma
                #366
                So jetzt habe ich auch Daten der Thermometer und Bewegungsmelder.
                Kein Error und Restart mehr, nur die üblichen Warnungen wenn ich ein "device_query" absetze.
                Danke.
                -- diwoma
                • Ro75R Online
                  Ro75R Online
                  Ro75
                  #367
                  @arteck Hatte heute den Wechsel von 1.8.10 auf 1.9.5 "gewagt". Install OK, danach - sobald Taster betätigt - Restart Loop. Zurück auf die 1.810 und die 1,.8.24 wieder alles OK.
                  Jetzt
                  letzter GIT-Stand (1.9.5) und alles funktioniert - ohne Meldungen, ohne Loop. Danke. 👍
                  Ro75.
                  • Ro75R Ro75
                    Jetzt
                    Ro75.
                    Meister MopperM Online
                    Meister Mopper
                    #368
                    @ro75 sagte in ZigBee neue Version 1.8.x:
                    Ergänzung: Die 1.9.5 ist mittlerweile im stable repo.
                    Proxmox und HA ...
                    Ro75R 1 Antwort Letzte Antwort
                      Ro75R Online
                      Ro75R Online
                      Ro75
                      #369
                      @meister-mopper sagte in ZigBee neue Version 1.8.x:
                      Anmerkung. Diese habe ich vor ca. 2 Stunden genutzt gehabt. Da traten die schon hier besagten Probleme auf. Deswegen nochmal von GIT (da gabs von @arteck einen Hinweis).
                      Ro75.
                      • H Hadebe
                        @arteck Nach StateCleanup sind -zumindest bei diesem Gerät- dieselben DP wie vorher. Vorsichthalber danach Zigbee-Adapter neugestartet und Objektliste aktualisiert. Schalten aus Objektbrowser nicht möglich. Am DP bleibt ack-flag auf false.
                        Mit Debugmessages kommt im Protokoll:
                        Weiterhin Schalten vom DevTab möglich, Wert wird dann korrekt im Objektbrowser angezeigt, ack-flag auf true. Dieses Schalten erzeugt keine Debugmessage.
                        dermario
                        schrieb am zuletzt editiert von dermario
                        #370
                        @hadebe said in ZigBee neue Version 1.8.x:
                        Leider habe ich den bekannten "failed with no error code (undefined)" - Fehler bei meinem Tuya-2Gang-Switch.
                        (https://github.com/ioBroker/ioBroker.zigbee/issues/1998
                        Sollte ab lt. issue ab 1.9.1 behoben sein, funktioniert aber bei mir weder in dieser noch in der neuesten 1.9.5 - Version :-(
                        (Schalter auch bereits komplett ausgebaut, zurückgesetzt, neu hinzugefügt etc.)
                        • D dermario
                          dimaiv
                          #371
                          @dermario
                          Probiere mal vom Git zu installieren.
                          ioBroker- NUC8i3 / Proxmox / VM
                          Node.js v22.21.0
                          NPM v10.9.4
                          JS controller 7.1.0
                          Admin 7.7.20
                          ZigBee Adapter 3.3.1alpha.0
                          Zigbee LAN Gateway CC2652P
                          Zigbee Firmware 20250321
                          • arteckA Offline
                            arteckA Offline
                            arteck
                            #372
                            1.9.6 ist unterwegs
                            H 1 Antwort Letzte Antwort
                            • arteckA arteck
                              1.9.6 ist unterwegs
                              Hadebe
                              #373
                              @arteck Neue Version gecheckt, Fehlermeldung DeviceConfigure auch bei 1.9.6 GIT wie vorher in den Versionen (näheres siehe in den vorherigen Posts);
                              dieses Mal habe ich sogar vor dem reset und erneuten koppeln das Gerät stromlos gemacht
                              • H Hadebe
                                arteckA Offline
                                arteckA Offline
                                arteck
                                #374
                                @hadebe dann installier nochmal von GIT..jetzt
                                • H Offline
                                  Hadebe
                                  #375
                                  Soeben (15:00) GIT Version gecheckt, Fehlermeldung DeviceConfigure auch bei 1.9.6b GIT wie vorher in den Versionen (näheres siehe in den vorherigen Posts)
                                  • H Offline
                                    Hadebe
                                    #376
                                    @arteck mit der aktuellen (20:00) GIT Version hat sich etwas getan! Eine andere Fehlermeldung zcl AqaraOpple erscheint, die bereits nach dem Koppeln einmal auftrat und jetzt wieder bei jedem Kontakt zum Gerät:
                                    Kopplung:
                                    und dann entweder durch User ausgelöst oder sporadisch dieselbe Fehlermeldung:
                                    Falls es weiterhilft, hier meine Beaobachtung: bislang bezog sich die Fehlermeldung auf den selben Cluster. Die Fehlermeldung bezog sich immer auf Endpunkt 2 (ist bei mir ein Schalter angeschlossen). Bei der jetzigen Fehlermeldung kann ich den Endpunkt nicht erkennen - die Fehlermeldung scheint auch immer als Paar aufzutreten. Die Fehlermeldung wird bei Änderung beider states ausgelöst.
                                    • H Hadebe
                                      Kopplung:
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      #377
                                      @hadebe es würde schon helfen wenn LOG nicht als Bild gepostet werden
                                      H 2 Antworten Letzte Antwort
                                      • arteckA arteck
                                        Hadebe
                                        #378
                                        @arteck jetzt den log vom vorherigen Post als Datei, gefiltert auf zigbee-Meldungen
                                        Prot20240103_Zigbee_Aqara-T2.txt
                                        Ist es das was dir weiterhilft oder kann ich dich mit anderen Info(-formen) besser unterstützen?
                                        • H Hadebe
                                          DJMarc75D Offline
                                          DJMarc75D Offline
                                          DJMarc75
                                          #379
                                          @hadebe sagte in ZigBee neue Version 1.8.x:
                                          als Datei
                                          nicht als Datei sondern in Codetags setzen:
                                          2024-01-03 20:00:05.549 - info: zigbee.0 (138145) Successfully interviewed '0x54ef441000aa11c5', device has successfully been paired
                                          2024-01-03 20:00:05.550 - info: zigbee.0 (138145) Device '0x54ef441000aa11c5' is supported, identified as: Xiaomi Aqara dual relay module T2 (LLKZMK12LM)
                                          2024-01-03 20:00:05.552 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
                                          2024-01-03 20:00:05.563 - warn: zigbee.0 (138145) download icon from https://www.zigbee2mqtt.io/images/devices/LLKZMK12LM.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/LLKZMK12LM.png
                                          2024-01-03 20:00:05.708 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
                                          2024-01-03 20:00:11.994 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
                                          2024-01-03 20:00:12.084 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
                                          2024-01-03 20:00:21.940 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
                                          2024-01-03 20:00:22.086 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
                                          2024-01-03 20:00:22.736 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
                                          2024-01-03 20:00:22.851 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
                                          2024-01-03 20:00:23.944 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
                                          2024-01-03 20:00:24.017 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
                                          2024-01-03 20:00:34.930 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
                                          2024-01-03 20:00:35.019 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
                                          2024-01-03 20:00:35.792 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
                                          2024-01-03 20:00:35.865 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
                                          2024-01-03 20:00:39.438 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
                                          2024-01-03 20:00:39.509 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
                                          2024-01-03 20:00:44.100 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
                                          2024-01-03 20:00:44.175 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
                                          2024-01-03 20:00:48.853 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
                                          2024-01-03 20:00:48.952 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
                                          2024-01-03 20:01:02.354 - info: zigbee.0 (138145) Zigbee: stop joining
                                          2024-01-03 20:02:31.122 - info: zigbee.0 (138145) Device '0x00124b000905236c' announced itself
                                          2024-01-03 20:02:31.127 - info: zigbee.0 (138145) Device '0x00124b000ef97050' announced itself
                                          2024-01-03 20:05:23.986 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
                                          2024-01-03 20:05:24.061 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
                                          2024-01-03 20:05:57.744 - warn: zigbee.0 (138145) ELEVATED Change state 'state_l1' at device 0x54ef441000aa11c5 type 'LLKZMK12LM'
                                          2024-01-03 20:05:58.070 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
                                          2024-01-03 20:05:58.135 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
                                          2024-01-03 20:06:03.549 - warn: zigbee.0 (138145) ELEVATED Change state 'state_l1' at device 0x54ef441000aa11c5 type 'LLKZMK12LM'
                                          2024-01-03 20:06:03.914 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
                                          2024-01-03 20:06:03.990 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
                                          2024-01-03 20:06:04.099 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
                                          2024-01-03 20:06:04.173 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
                                          2024-01-03 20:06:10.586 - warn: zigbee.0 (138145) ELEVATED Change state 'state_l2' at device 0x54ef441000aa11c5 type 'LLKZMK12LM'
                                          2024-01-03 20:06:10.921 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
                                          2024-01-03 20:06:11.002 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
                                          2024-01-03 20:06:17.061 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
                                          2024-01-03 20:06:17.187 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
                                          2024-01-03 20:06:29.500 - warn: zigbee.0 (138145) ELEVATED Change state 'state_l2' at device 0x54ef441000aa11c5 type 'LLKZMK12LM'
                                          2024-01-03 20:06:29.826 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
                                          2024-01-03 20:06:29.963 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
                                          2024-01-03 20:06:30.056 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
                                          2024-01-03 20:06:30.121 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
                                          2024-01-03 20:06:34.609 - info: zigbee.0 (138145) Device '0xec1bbdfffeb7412f' announced itself
                                          2024-01-03 20:10:55.133 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
                                          2024-01-03 20:10:55.225 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
                                          2024-01-03 20:16:10.284 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
                                          2024-01-03 20:16:10.424 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
                                          2024-01-03 20:16:30.517 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
                                          2024-01-03 20:16:30.590 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
                                          2024-01-03 20:21:45.649 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
                                          2024-01-03 20:21:45.727 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
                                          2024-01-03 20:23:19.667 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
                                          2024-01-03 20:23:20.174 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
                                          2024-01-03 20:27:17.262 - warn: zigbee.0 (138145) DeviceAvailability:Stopping to ping 0x001fee0000009307 S2-R (5602) after 4 ping attempts
                                          2024-01-03 20:28:35.259 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
                                          2024-01-03 20:28:35.359 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
                                          2024-01-03 20:29:00.881 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
                                          2024-01-03 20:29:00.969 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
                                          2024-01-03 20:34:16.033 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
                                          2024-01-03 20:34:16.132 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
                                          2024-01-03 20:34:44.169 - info: zigbee.0 (138145) Configuring 0x54ef441000aa11c5 lumi.switch.acn047
                                          2024-01-03 20:34:44.327 - error: zigbee.0 (138145) Error while processing converters DEVICE_ID: '54ef441000aa11c5' cluster 'aqaraOpple' type 'readResponse'
                                          Lehrling seit 1975 !!!
