  4. Test lovelace 5.x
Test lovelace 5.x
1.1k Beiträge 96 Kommentatoren 579.7k Aufrufe 78 Beobachtet
    andi2055
    #470
    nach dem Update von 3 auf 4.1.0 konnte ich die Instanz nicht mehr starten.
    lovelace.0
    2023-12-18 21:21:21.859	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    lovelace.0
    2023-12-18 21:21:21.856	error	Cannot read properties of null (reading 'length')
    lovelace.0
    2023-12-18 21:21:21.855	error	TypeError: Cannot read properties of null (reading 'length') at TodoModule.processManualEntity (/opt/iobroker/node_modules/iobroker.lovelace/lib/modules/todo.js:349:46)
    lovelace.0
    2023-12-18 21:21:21.855	error	unhandled promise rejection: Cannot read properties of null (reading 'length')
    lovelace.0
    2023-12-18 21:21:21.855	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    lovelace.0
    2023-12-18 21:21:21.854	warn	Cannot parse todo items of lovelace.0.control.shopping_list: null, TypeError: todoList.items is not iterable
    lovelace.0
    2023-12-18 21:21:21.492	warn	Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
    lovelace.0
    2023-12-18 21:21:18.979	warn	Cannot parse todo items of lovelace.0.control.shopping_list: null, TypeError: Cannot read properties of null (reading 'length')
    lovelace.0
    2023-12-18 21:21:18.699	warn	Hue present but no saturation id found for alias.0.OG.Ankleide_Licht_Hue.HUE. Saturation won't work.
    lovelace.0
    2023-12-18 21:21:18.498	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    lovelace.0
    2023-12-18 21:21:18.495	error	Cannot read properties of null (reading 'length')
    lovelace.0
    2023-12-18 21:21:18.495	error	TypeError: Cannot read properties of null (reading 'length') at TodoModule.processManualEntity (/opt/iobroker/node_modules/iobroker.lovelace/lib/modules/todo.js:349:46)
    lovelace.0
    2023-12-18 21:21:18.494	error	unhandled promise rejection: Cannot read properties of null (reading 'length')
    lovelace.0
    2023-12-18 21:21:18.494	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    In den Datenpunkten steht wirklich "NULL" als String drin. Keine Ahnung woher das kommt. Habe ich manuell gelöscht und danach startete der Adapter. Vielleicht haben andere auch das Problem?
      andi2055
      #471
      Hat jemand noch eine Idee wie ich diese Meldung weg bekomme?
      Im Alias gibt es auch SATURATION
      Danke!
      • P pafade89
        @garfonso
        Besteht eine Chance, das du dir das nochmal genauer anguckst ?
        Hätte einige Anwendungsfälle dafür und custom gibt es leider nicht so viel Auswahl.
        Außerdem passiert bei den custom auch viel direkt in der Karte was nicht so nett ist.
        VG P
        GarfonsoG Offline
        GarfonsoG Offline
        Garfonso
        schrieb am zuletzt editiert von Garfonso
        #472
        @pafade89 said in Test lovelace 4.x:
        Ja, das gucke ich mir an. Weiß nur nicht wann.
        Kann die denn mehr als die normale History-Graph-Card? Oder Sensor?
        @andi2055 said in Test lovelace 4.x:
        Danke für den Report. Fixe ich.
        Wie ist denn die Rolle? Wie sehen die Attribute aus (lovelace-Instanzeinstellungen, letzter Tab, Attribute anzeigen und mal beim entity gucken)? Wie sieht das Gerät im Geräte-Tab aus? Steht da der State (noch) unter SATURATION?
        Irgendwie scheint das Saturation nicht als Saturation erkannt zu werden. :-/
        Ultimativer Lovelace Leitfaden: https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
        Lovelace UI Beispiele: https://forum.iobroker.net/topic/35950/zeigt-her-eure-lovelace-visualisierung
        P 1 Antwort Letzte Antwort
        • P Offline
          pafade89
          #473
          @Garfonso
          ich habe gestern folgenden Fehler im Log gehabt:
          2023-12-20 21:40:14.449 - warn: lovelace.0 (65110) No browser ID in browser_mod request: {"type":"browser_mod/recall_id","id":2}
          Dieser Fehler war schon in der 3.0.1 bei mir vorhanden, sah nur ein bisschen anders aus.
          Was kann man hier tun?
          VG P
          GarfonsoG 1 Antwort Letzte Antwort
          • Skyx3S Skyx3
            @garfonso Nachdem Update auf 4.X startet der Adapter nicht mehr, im Log kommt unentwegt der Fehler "Could not get user id for admin - Trying with username"
            Skyx3S Offline
            Skyx3S Offline
            Skyx3
            #474
            @skyx3 said in Test lovelace 4.x:
            Gibt es schon etwas Neues zu dieser Fehlermeldung?
              andi2055
              #475
              Wenn ich bei neuen Datenpunkten "Lovelace" aktivieren möchte, kommt folgender Fehler:
              Liegt das an Lovelace 4.1.0 oder an Admin 6.13.5?
              David G.D A 2 Antworten Letzte Antwort
              • A andi2055
                David G.D Online
                David G.D Online
                David G.
                #476
                @andi2055
                Bei mir geht es.
                Admin 6.12.0
                Lovelace 4.0.12
                • A andi2055
                  andi2055
                  #477
                  @andi2055
                  ok, mit Admin 6.13.11 funktioniert es wieder...
                  • P pafade89
                    @Garfonso
                    VG P
                    GarfonsoG Offline
                    GarfonsoG Offline
                    Garfonso
                    #478
                    Du:
                    das hier melden. Und vielleicht versuchen rauszufinden, was passiert, damit diese Meldung kommt, damit ich mir das genauer angucken kann.
                    Ich:
                    ich muss da was implementieren... den request "recall_id" kannte ich bisher aber nicht und die Warnung bemängelt auch, dass da keine Browser ID drin steht (sieht man ja auch nicht). Da müsste ich suchen, was da los ist. Hab ich bei mir noch nicht gesehen -> von daher wäre es ech hilfreich, wenn du irgendwie mal rumspielen könntest und gucken, wann das im log kommt, also was du (vermutlich mit browser mod?) da machst.
                    Oh, das hab ich übersehen. Danke, dass du nachfragst...
                    Dazu nachfragen:
                    0) passiert dsa mit 4.1 auch?
                    1. hast du authentifizierung an?
                    2. hat dein User "admin" irgendwie einen Namen oder so? Bzw. Warum ist der kleingeschrieben? (oder ist der das immer?)
                    • XBiTX Offline
                      XBiTX Offline
                      XBiT
                      #479
                      @Garfonso
                      Mit v4.1.0 habe ich folgende Probleme:
                      Beim starten vom Adapter kommt über 99x diese Meldung im Log
                      warn	Could not get user id for admin - Trying with username
                      läuft danach aber soweit...
                      Beim öffnen einer "MAP" Karte kommen x mal diese Meldungen im Log
                      mit einen Adroid Tablet:
                      Log from UI Unhandled promise rejection from Chrome WebView 120.0.6099.144 on Android 13TypeError: Cannot read properties of undefined (reading 'latitude')computeDomain (src/panels/lovelace/cards/hui-map-card.ts:387:41)apply (node_modules/memoize-one/dist/memoize-one.esm.js:37:34)render (src/panels/lovelace/cards/hui-map-card.ts:166:26)render (src/lit-element.ts:160:23)update (src/reactive-element.ts:1329:13)performUpdate (src/reactive-element.ts:1261:16)scheduleUpdate (src/reactive-element.ts:1233:24)
                      mit einen Win_11 PC:
                      Log from UI Unhandled promise rejection from Chrome 120.0.0.0 on Windows 10 TypeError: Cannot read properties of undefined (reading 'latitude') computeDomain (src/panels/lovelace/cards/hui-map-card.ts:387:41) apply (node_modules/memoize-one/dist/memoize-one.esm.js:37:34) render (src/panels/lovelace/cards/hui-map-card.ts:166:26) render (src/lit-element.ts:160:23) update (src/reactive-element.ts:1329:13) performUpdate (src/reactive-element.ts:1261:16) scheduleUpdate (src/reactive-element.ts:1233:24)
                      danach ist Lovelace fast nicht mehr bedienbar, alles ist träge und zäh erst ein Neustart der Instanz hilft hier bis man wieder auf eine Seite mit einer Map geht.
                      Auch wird auf der Map Karte nicht mehr der Verlauf/Bewegung angezeigt.
                      • XBiTX XBiT
                        @Garfonso
                        GarfonsoG Offline
                        GarfonsoG Offline
                        Garfonso
                        #480
                        @xbit
                        Hm.. hab ich beides bei mir nicht. :-/
                        Rein aus Interesse, wie sieht bei dir das system.user.admin Objekt aus? Hat das ein common.name Feld?
                        Der Crash beim Laden der Map sieht auch merkwürdig aus. Hast du geo_location entities, die keine History aktiviert haben? Dann hab ich den Fehler vielleicht gefunden (und in der nächsten Version behoben). Ansonsten hab ich auf gut Glück attribute drinnen gelassen. kopfkratz Du nutzt aber die standard Map Karte und nicht eine custom, oder?
                        XBiTX 2 Antworten Letzte Antwort
                        • GarfonsoG Garfonso
                          @xbit
                          XBiTX Offline
                          XBiTX Offline
                          XBiT
                          #481
                          @garfonso
                          system.user.admin
                            "type": "user",
                            "common": {
                              "name": "Stephan",
                              "password": "*EDIT einganzlangercode*",
                              "dontDelete": true,
                              "enabled": true
                            "native": {},
                            "_id": "system.user.admin",
                            "acl": {
                              "object": 1636,
                              "owner": "system.user.admin",
                            "enums": {},
                            "user": "system.user.admin",
                            "ts": 1651084242439
                          History ist bei folgenden Daten von google-sharedlocations an (accuracy, address, battery, lat, long).
                          Karte ist die Standard Map.
                            @xbit
                            XBiTX Offline
                            XBiTX Offline
                            XBiT
                            #482
                            @garfonso
                            Besten Dank 4.1.1 läuft wieder. 👍
                              pafade89
                              schrieb am zuletzt editiert von pafade89
                              #483
                              @garfonso sagte in Test lovelace 4.x:
                              Habe folgendes gefunden:
                              "The statistics graph card allows you to display a graph of statistics data for each of the entities listed."
                              Damit kann man also zum Beispiel auch Balkendiagramme anzeigen lassen.
                              Du:
                              das hier melden. Und vielleicht versuchen rauszufinden, was passiert, damit diese Meldung kommt, damit ich mir das >genauer angucken kann.
                              Ich:
                              ich muss da was implementieren... den request "recall_id" kannte ich bisher aber nicht und die Warnung bemängelt auch, >dass da keine Browser ID drin steht (sieht man ja auch nicht). Da müsste ich suchen, was da los ist. Hab ich bei mir noch >nicht gesehen -> von daher wäre es ech hilfreich, wenn du irgendwie mal rumspielen könntest und gucken, wann das im >log kommt, also was du (vermutlich mit browser mod?) da machst.
                              Seit dem letzten Update habe ich diesen Fehler nicht mehr reproduzieren können.
                              VG P
                                kptkip
                                #484
                                Beim Iphone/Ipad kann man sich ja Ne Website als Webapp auf den Home Bildschirm legen.
                                Bei manchen Seiten wird das dann auch nicht als Tab im Safari angezeigt sondern ohne Browser-Adressleiste als eigenständiges Programm.
                                Dazu benötigt die Website laut Apple folgende Meta-Tags:
                                <meta name="apple-mobile-web-app-capable" content="yes" />
                                Obwohl in der HTML-Ausgabe des Lovelace-Adapters dieser Tag angegeben ist, erscheint die Visualisierung auf meinem IPhone ganz normal im Browser, wenn ich mir ne webapp angelegt habe.
                                Ist das bei euch auch so?
                                L 1 Antwort Letzte Antwort
                                • K kptkip
                                  lessthanmore
                                  #485
                                  @kptkip Nein, läuft hier auf iPad und iPhone wie es soll ohne Adressleiste.
                                  Dazu habe ich einfach die URL in Safari aufgerufen und ein Lesezeichen dem Home-Bildschirm hinzugefügt.
                                  Auf dem iPad nutze ich allerdings Kiosker Pro, aber auch da wird es ohne Adressleiste angezeigt.
                                  • L lessthanmore
                                    kptkip
                                    schrieb am zuletzt editiert von kptkip
                                    #486
                                    @lessthanmore Danke für die Rückmeldung. Genau so habe ich es auch gemacht.
                                    Habs gerade nochmal auf dem Handy meiner Frau ausprobiert - dort klappt es.
                                    Komisch... Dann liegt es wohl an meinem Handy...
                                    • K kptkip
                                      kptkip
                                      #487
                                      Hab nun eine spezifischere Beobachtung:
                                      Bei einem Bookmark von der Startseite ([IP_DES_SERVERS]:8091) klappt das mit der Web-App.
                                      Bei einem Bookmark von einer Unterseite (z.B. [IP_DES_SERVERS]:8091/lovelace/eingang) klappt es nicht. Da taucht die Browserleiste wieder auf
                                        Du:
                                        Ich:
                                        Dazu nachfragen:
                                        pafade89
                                        #488
                                        @Garfonso
                                        Ich habe nun heraus gefunden wann die Meldung kommt:
                                        lovelace.0 (599) No browser ID in browser_mod request: {"type":"browser_mod/recall_id","id":2}
                                        Wenn ich lovelace zum Beispiel auf dem Smartphone öffne und dann den Browser für viele Stunden nicht benutze. Wird er dann direkt mit Lovelace geöffnet wieder aufgerufen kommt die Meldung.
                                        VG P
                                        • P pafade89
                                          @Garfonso
                                          VG P
                                          GarfonsoG Offline
                                          GarfonsoG Offline
                                          Garfonso
                                          #489
                                          @pafade89
                                          danke für die Meldung. :-)
                                          Seit 4.1.1 gibt es auch support dafür. Aber ich hab wohl übersehen die Meldung rauszunehmen. ;-)
