  4. hm-rpc Probleme
hm-rpc Probleme
73 Beiträge 5 Kommentatoren 11.4k Aufrufe 3 Beobachtet
    @glasfaser sagte in hm-rpc Probleme:
    Aus dem Thread:
    der erste Satz in deinem Link
    Ich werde nun mal IPV6 wieder aktivieren
    passt genau zu meinem allerersten Verdacht, dass das Netz mit IPv6 Probleme haben könnte
    EDIT:
    Ich hoffe ich bringe hier gerade nicht drei Threads durcheinander.
    GlasfaserG Offline
    GlasfaserG Offline
    oder
    @Mephisto090
    2023-12-28 12:06:54: (../src/gw_backend.c.274) establishing connection failed: socket: tcp:127.0.0.1:8183: Connection refused
    Mappe den Port 8183:8183 auch mal weiter . ( Firewall )
    https://groups.google.com/g/homekey-app/c/Lhrq3oqnXJA/m/ZjaDggHbvQYJ?pli=1
    EDIT :
    Issues :##https://github.com/jens-maus/RaspberryMatic/issues/2415
    • GlasfaserG Glasfaser
      oder
      @Mephisto090
      EDIT :
      Mephisto090
      @glasfaser said in hm-rpc Probleme:
      Habe ich. Jetzt steht es Plain da
      2023-12-29 15:40:03: (../src/server.c.2078) server stopped by UID = 0 PID = 27178
      2023-12-29 15:40:03: (../src/server.c.1704) server started (lighttpd/1.4.69)
      2023-12-29 15:40:33: (../src/mod_auth.c.850) password doesn't match for /rega.exe username: ioBroker IP: 192.168.178.61
      2023-12-29 15:41:03: (../src/mod_auth.c.850) password doesn't match for /rega.exe username: ioBroker IP: 192.168.178.61
      2023-12-29 15:41:33: (../src/mod_auth.c.850) password doesn't match for /rega.exe username: ioBroker IP: 192.168.178.61
      2023-12-29 15:42:03: (../src/mod_auth.c.850) password doesn't match for /rega.exe username: ioBroker IP: 192.168.178.61
      2023-12-29 15:42:33: (../src/mod_auth.c.850) password doesn't match for /rega.exe username: ioBroker IP: 192.168.178.61
      2023-12-29 15:43:03: (../src/mod_auth.c.850) password doesn't match for /rega.exe username: ioBroker IP: 192.168.178.61
      2023-12-29 15:43:33: (../src/mod_auth.c.850) password doesn't match for /rega.exe username: ioBroker IP: 192.168.178.61
      2023-12-29 15:44:04: (../src/mod_auth.c.850) password doesn't match for /rega.exe username: ioBroker IP: 192.168.178.61
      2023-12-29 15:44:33: (../src/mod_auth.c.850) password doesn't match for /rega.exe username: ioBroker IP: 192.168.178.61
      2023-12-29 15:45:04: (../src/mod_auth.c.850) password doesn't match for /rega.exe username: ioBroker IP: 192.168.178.61
      2023-12-29 15:45:34: (../src/mod_auth.c.850) password doesn't match for /rega.exe username: ioBroker IP: 192.168.178.61
      2023-12-29 15:46:04: (../src/mod_auth.c.850) password doesn't match for /rega.exe username: ioBroker IP: 192.168.178.61
      Das einloggen mit Nutzerdaten geht trotzdem nicht
      GlasfaserG HomoranH 2 Antworten Letzte Antwort
      • M Mephisto090
        GlasfaserG Offline
        GlasfaserG Offline
        #66
        @mephisto090 sagte in hm-rpc Probleme:
        username: ioBroker
        jetzt taucht auch der Benutzer auf.
        Ich selber habe es ohne https , Benutzer und Passwort laufen . ( Ist ja alles im Haus )
        • M Mephisto090
          #67
          ioBroker != iobroker
          • M Mephisto090
            ist deine Liste gekürzt ...
            denn du nutzt Redis , ist der Redis Server außerhalb des Containers !?
            version: "3.4"
            services:
              iobroker:
                container_name: Iobroker
                image: buanet/iobroker:latest
                pull_policy: always
                hostname: iobroker
                restart: always
                labels:
                  - "autoheal=true"
                  - "com.centurylinklabs.watchtower.enable=true"
                healthcheck:
                  test: ["CMD", "curl", "-f", "http://localhost:8081"]
                  interval: 30s
                  timeout: 2s
                  retries: 2
                  start_period: 3m30s
                networks:
                  io-network:
                    ipv4_address: 172.18.0.2
                ports:
                  - "1884:1884"
                  - "8081-8083:8081-8083"
                  - "8400:8400"
                  - "42010:42010"
                  - "2010:2010"
                environment:
                  - IOB_STATESDB_HOST=iobroker-redis
                  - IOB_STATESDB_PORT=6379
                  - IOB_STATESDB_TYPE=redis
                  - IOB_BACKITUP_EXTDB=true
                  - PACKAGES=default-mysql-client redis-tools
                  - TZ=Europe/Berlin
                volumes:
                  - io-data:/opt/iobroker
                  - userscripts:/opt/userscripts
                depends_on:
                  redis:
                    condition: service_healthy
                #mem_swappiness: -1
              redis:
                container_name: Iobroker-Redis
                image: redis:7
                hostname: iobroker-redis
                restart: always
                labels:
                  - "autoheal=true"
                healthcheck:
                  test: [ "CMD", "redis-cli", "--raw", "incr", "ping" ]
                  interval: 30s
                  timeout: 2s
                  retries: 2
                  start_period: 20s
                networks:
                  io-network:
                    ipv4_address: 172.18.0.3
                volumes:
                  - redis-data:/data
                #mem_swappiness: -1
              deconz:
                image: deconzcommunity/deconz:stable
                container_name: Iobroker-Deconz
                hostname: iobroker-deconz
                pull_policy: always
                restart: always
                privileged: true                # This is important! Without it, the deCONZ image won't be able to connect to Conbee II.
                ports:
                  - 4080:80
                  - 4443:443
                  - 5900:5900
                volumes:
                  - /etc/localtime:/etc/localtime:ro
                  - deconz:/opt/deCONZ
                devices:
                  - /dev/ttyACM0                # This is the USB device that Conbee II is running on.
                environment:
                  - TZ=Europe/Berlin
                  - DECONZ_WEB_PORT=80
                  - DECONZ_WS_PORT=443
                  - DEBUG_INFO=1
                  - DEBUG_APS=0
                  - DEBUG_ZCL=0
                  - DEBUG_ZDP=0
                  - DEBUG_OTA=0
                  - DEBUG_HTTP=0
                  - DECONZ_DEVICE=/dev/ttyACM0   # This is the USB device that Conbee II is running on.
                  - DECONZ_START_VERBOSE=0
                  - DECONZ_VNC_MODE=1
                  - DECONZ_VNC_PORT=5900
                  - DECONZ_VNC_PASSWORD=*****
                logging:
                  driver: "json-file"
                  options:
                    max-size: "50m"
                networks:
                  io-network:
                    ipv4_address: 172.18.0.4
            volumes:
              userscripts:
              io-data:
              redis-data:
              deconz:
            networks:
              io-network:
                driver: bridge
                ipam:
                  config:
                    - subnet: 172.18.0.0/16
                      gateway: 172.18.0.1
                      ip_range: 172.18.0.1/24
            GlasfaserG Offline
            GlasfaserG Offline
            #68
                labels:
                  - "autoheal=true"
                healthcheck:
                  interval: 30s
                  timeout: 2s
                  retries: 2
                  start_period: 3m30s
            Ist OT ..
            Watchtower ist mir klar ...
            Aber healthcheck hat das Image doch selber !?
            bzw. wo hast du die Compose her !?
              Mephisto090
              #69
              @homoran said in hm-rpc Probleme:
              habe beides probiert. Er zeigt komischerweise immer ioBroker an. Habe sogar kleingeschrieben den Nutzer neu angelegt.
              Ist OT ..
              Habe ich mir irgendwann mal selbst zusammengebaut
              • M Mephisto090
                Ist OT ..
                #70
                hast du noch andere hm-rpc Instanzen?
                  Mephisto090
                  #71
                  Nein, da ich nur HmIP Geräte habe.
                  • M Mephisto090
                    #72
                    @mephisto090 boote mal beides neu!
                    ccu und iob
                      ccu und iob
                      Mephisto090
                      #73
                      ccu und iob
                      Hatte ich bei beiden um die Portweiterleitung eingeben zu können
