  3. Off Topic
  4. Proxmox
  5. Proxmox: Fehlermeldung bei backup - vzdump ?
    1.0k
    3.2k
Geplant Angeheftet Gesperrt Verschoben Proxmox
228 Beiträge 8 Kommentatoren 48.3k Aufrufe 6 Beobachtet
  • G GOETSCHHOFER
    @meister-mopper
    Das Problem wird vermutlich sein, dass ich einfach vollkommen im Rückstand bin, was die updates anbelangt. 🤕
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: IOBROKER
             Icon name: computer-vm
               Chassis: vm
        Virtualization: kvm
      Operating System: Debian GNU/Linux 10 (buster)
                Kernel: Linux 4.19.0-18-amd64
          Architecture: x86-64
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     09:28:40 up  1:26,  2 users,  load average: 0.01, 0.04, 0.00
    CPU threads: 6
    *** Time and Time Zones ***
                   Local time: Fri 2023-12-29 09:28:40 CET
               Universal time: Fri 2023-12-29 08:28:40 UTC
                     RTC time: Fri 2023-12-29 08:28:41
                    Time zone: Europe/Vienna (CET, +0100)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    karl
    /home/karl
    karl cdrom floppy sudo audio dip video plugdev netdev iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           5.5G        195M        4.4G        7.0M        837M        5.0G
    Swap:          974M          0B        974M
    Total:         6.4G        195M        5.4G
             5458 M total memory
              195 M used memory
              528 M active memory
              165 M inactive memory
             4425 M free memory
              154 M buffer memory
              682 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    *** FAILED SERVICES ***
    0 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    udev           devtmpfs  2.7G     0  2.7G   0% /dev
    tmpfs          tmpfs     546M  7.3M  539M   2% /run
    /dev/sda1      ext4       19G  4.1G   14G  23% /
    tmpfs          tmpfs     2.7G     0  2.7G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     2.7G     0  2.7G   0% /sys/fs/cgroup
    tmpfs          tmpfs     546M     0  546M   0% /run/user/1000
    [Fri Dec 29 08:01:49 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Dec 29 08:01:49 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
    TARGET        SOURCE    FSTYPE OPTIONS
    /             /dev/sda1 ext4   rw,relatime,errors=remount-ro
    `-/sys/fs/bpf bpf       bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    /var:
    412M    /var/
    226M    /var/cache
    220M    /var/cache/apt
    168M    /var/lib
    157M    /var/cache/apt/archives
          Users in the 'systemd-journal' group can see all messages. Pass -q to
          turn off this notice.
    No journal files were opened due to insufficient permissions.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    309M    /opt/iobroker/iobroker-data/
    230M    /opt/iobroker/iobroker-data/files
    78M     /opt/iobroker/iobroker-data/backup-objects
    42M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js
    11M     /opt/iobroker/iobroker-data/files/echarts/static/js/2.0a6dd638.chunk.js.map
    11M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/2.0a6dd638.chunk.js.map
    9.3M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.b6edad9e.chunk.js.map
    6.8M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.0aad1268.chunk.js.map
    6.2M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/2.261c158c.chunk.js.map
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v12.22.7
    /usr/bin/node           v12.22.7
    /usr/bin/npm            6.14.15
    /usr/bin/npx            6.14.15
    /home/iobroker/.diag.sh: line 281: corepack: command not found
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 12.22.7-deb-1nodesource1
      Candidate: 12.22.12-deb-1nodesource1
      Version table:
         12.22.12-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x buster/main amd64 Packages
     *** 12.22.7-deb-1nodesource1 100
         10.24.0~dfsg-1~deb10u3 500
            500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
         10.24.0~dfsg-1~deb10u1 500
            500 http://deb.debian.org/debian buster/main amd64 Packages
    No problems detected
    Errors in npm tree:
    npm ERR! peer dep missing: tough-cookie@>=4.0.0, required by axios-cookiejar-support@2.0.3
    npm ERR! peer dep missing: tough-cookie@^4.0.0, required by http-cookie-agent@1.0.4
    *** ioBroker-Installation ***
    ioBroker Status
     Cannot read system.config: null (OK when migrating or restoring)
     Cannot find view "system" for search "host"
    Objects type: file
    States  type: file
    Core adapters versions
    js-controller:  3.2.16
    admin:          5.1.23
    javascript:     5.1.3
    Adapters from github:   24
    Adapter State
    + instance is alive
    ioBroker-Repositories
    Cannot get list: undefined
    Installed ioBroker-Instances
    Error: Object "system.config" not found
    ^C
    karl@IOBROKER:~$
    [/s]
    crunchipC Abwesend
    crunchipC Abwesend
    #67
    @goetschhofer sagte in Proxmox: Fehlermeldung bei backup - vzdump ?:
    allerdings, mit nodejs 12.x kommste nimmer weit
    G 1 Antwort Letzte Antwort
      GOETSCHHOFER
      #68
      @crunchip
      Ja ich weiß. 🤕
      Meister MopperM crunchipC 2 Antworten Letzte Antwort
      • G GOETSCHHOFER
        @crunchip
        Ja ich weiß. 🤕
        Meister MopperM Online
        Meister Mopper
        #69
        @goetschhofer
        Vorschlag:
        Bau da eine neue vm mit einem 64-bit bookworm debian, installier den iobroker mit dem Einzeiler, installier manuell den vis-Adapter und spiel ein (hoffentlich) vorhandenes backitup-Backup ein.
        Proxmox und HA - dank KI/AI endlich "blocklyfrei"
        G Thomas BraunT 2 Antworten Letzte Antwort
        • G GOETSCHHOFER
          @crunchip
          Ja ich weiß. 🤕
          crunchipC Abwesend
          crunchipC Abwesend
          #70
          @goetschhofer ich hatte dir das hier schon geschrieben
          https://forum.iobroker.net/post/985600
            GOETSCHHOFER
            #71
            @crunchip
            Sorry !
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                       Chassis: vm
                Virtualization: kvm
            Docker          : false
            Kernel          : x86_64
            Userland        : amd64
             09:46:56 up 4 min,  1 user,  load average: 0.00, 0.02, 0.00
            CPU threads: 6
                           Local time: Fri 2023-12-29 09:46:56 CET
                       Universal time: Fri 2023-12-29 08:46:56 UTC
                             RTC time: Fri 2023-12-29 08:46:57
                          NTP service: active
                      RTC in local TZ: no
            karl
            /home/karl
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:           5.5G        178M        4.8G        7.0M        521M        5.0G
            Swap:          974M          0B        974M
            Total:         6.4G        178M        5.7G
                     5458 M total memory
                      178 M used memory
                      275 M active memory
                      218 M inactive memory
                     4759 M free memory
                       90 M buffer memory
                      431 M swap cache
                      974 M total swap
                        0 M used swap
                      974 M free swap
            *** FILESYSTEM ***
            [Fri Dec 29 09:42:11 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
            [Fri Dec 29 09:42:11 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
            /var:
            413M    /var/
            226M    /var/cache
            220M    /var/cache/apt
            169M    /var/lib
            298M    /opt/iobroker/iobroker-data/
            67M     /opt/iobroker/iobroker-data/backup-objects
            USB-Devices by-id:
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: file
            States  type: file
            admin:          5.1.23
            javascript:     5.1.3
            Adapter State
            + instance is alive
            • G GOETSCHHOFER
              @meister-mopper
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                         Chassis: vm
                  Virtualization: kvm
              Docker          : false
              Kernel          : x86_64
              Userland        : amd64
              CPU threads: 6
                            NTP service: active
                        RTC in local TZ: no
              karl
              /home/karl
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:          974M          0B        974M
                       5458 M total memory
                        195 M used memory
                        528 M active memory
                       4425 M free memory
                        154 M buffer memory
                        682 M swap cache
                        974 M total swap
                          0 M used swap
                        974 M free swap
              *** FILESYSTEM ***
              /var:
              412M    /var/
              226M    /var/cache
              220M    /var/cache/apt
              168M    /var/lib
              USB-Devices by-id:
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: file
              States  type: file
              admin:          5.1.23
              javascript:     5.1.3
              Adapter State
              + instance is alive
              ^C
              karl@IOBROKER:~$
              [/s]
              #72
              Alleine damit:
              bist du schon weit im Rückstand.
              Bring das auf Debian 12 und nodejs v18.
              Und den ioBroker im Zuge dessen dann auch.
                @goetschhofer
                Vorschlag:
                GOETSCHHOFER
                schrieb am zuletzt editiert von GOETSCHHOFER
                #73
                @meister-mopper
                Vielen Dank für den hilfreichen Tipp, aber ich versteh nur "Bahnhof". 😕
                  @goetschhofer
                  Vorschlag:
                  #74
                  @meister-mopper sagte in Proxmox: Fehlermeldung bei backup - vzdump ?:
                  @goetschhofer
                  Vorschlag:
                  Da würde ich zuvor im Alt-System noch den ioBroker auf einen aktuellen Stand bringen und ein Backup davon im neuen System einspielen.
                    @goetschhofer
                    Vorschlag:
                    GOETSCHHOFER
                    #75
                    Auch dir vielen lieben Dank für die hilfreichen Tipps. 👍
                    Das Problem ist nur, ich brauche eine Schritt für Schritt Anleitung, einfach für "Dummys".
                    Thomas BraunT crunchipC 3 Antworten Letzte Antwort
                    • G GOETSCHHOFER
                      #76
                      Die dürfte es bereits zigfach geben. Bist ja nicht der Erste mit dem 'Problem' der Aufgabe.
                      • G GOETSCHHOFER
                        crunchipC Abwesend
                        crunchipC Abwesend
                        #77
                        @goetschhofer
                        eine Möglichkeit wäre
                        1. deinen aktuellen js-controller aktualisieren
                        2. alle Adapter soweit möglich abzudaten
                        3. iobroker backup via backitup
                        dann geht es weiter mit Schritt 4
                        • G GOETSCHHOFER
                          #78
                          @goetschhofer
                          iob stop
                          iob fix
                          iob nodejs-update
                          sollte erstmal nodejs@18 auf das System zaubern.
                          Dann per
                          iob stop
                          iob update
                          iob upgrade
                          iob upgrade self
                          iob start
                          den ioBroker hochziehen.
                          Davon dann (wie gewohnt?) ein Backup extern ablegen.
                          Dann entweder das Debian 10 via Debian 11 auf Debian 12 hieven oder gleich eine frische Installation von Debian 12 im Container vornehmen. Vermutlich ist letzteres einfacher und schneller erledigt.
                          Dann den iobroker 'leer' installieren und den vis-Adapter schon mal installieren. In dieses Grundgerüst legst du dann das Backup wieder rein.
                          Fertig.
                            @goetschhofer
                            iob stop
                            iob fix
                            iob nodejs-update
                            Dann per
                            iob stop
                            iob update
                            iob upgrade
                            iob upgrade self
                            iob start
                            Fertig.
                            GOETSCHHOFER
                            #79
                            Schritt 1:
                            ioBroker nodejs fixer 2023-10-13
                            No recommendation for a nodejs version found on your system. We recommend to ins                     tall latest version from nodejs v18 tree.
                            Your current setup is:
                            We found these nodejs versions available for installation:
                            nodejs:
                              Version table:
                            Nothing to do - Your installation is using the correct paths.
                            You are running nodejs v12.22.7. Do you want to install latest version from node                     js v.18 tree?
                            Press <y> to continue or any other key to quit
                            Trying to update your installation now. Please be patient.
                            Virtualization: kvm
                            Waiting for ioBroker to shut down - Give me a minute...
                            *** These repos are active on your system:
                            Hit:1 http://security.debian.org/debian-security buster/updates InRelease
                            Hit:2 http://deb.debian.org/debian buster InRelease
                            Hit:3 http://deb.debian.org/debian buster-updates InRelease
                            Get:4 https://repos.influxdata.com/debian buster InRelease [7047 B]
                            Err:4 https://repos.influxdata.com/debian buster InRelease
                              The following signatures couldn't be verified because the public key is not av                     ailable: NO_PUBKEY D8FF8E1F7DF8B07E
                            Fetched 7047 B in 0s (16.9 kB/s)
                            Reading package lists... Done
                            W: An error occurred during the signature verification. The repository is not up                     dated and the previous index files will be used. GPG error: https://repos.influx                     data.com/debian buster InRelease: The following signatures couldn't be verified                      because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                            W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  T                     he following signatures couldn't be verified because the public key is not avail                     able: NO_PUBKEY D8FF8E1F7DF8B07E
                            W: Some index files failed to download. They have been ignored, or old ones used                      instead.
                            *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                            (Reading database ... 50397 files and directories currently installed.)
                            Preparing to unpack .../00-gpg-wks-client_2.2.12-1+deb10u2_amd64.deb ...
                            Unpacking gpg-wks-client (2.2.12-1+deb10u2) over (2.2.12-1+deb10u1) ...
                            Preparing to unpack .../01-dirmngr_2.2.12-1+deb10u2_amd64.deb ...
                            Unpacking dirmngr (2.2.12-1+deb10u2) over (2.2.12-1+deb10u1) ...
                            Preparing to unpack .../02-gpg-wks-server_2.2.12-1+deb10u2_amd64.deb ...
                            Unpacking gpg-wks-server (2.2.12-1+deb10u2) over (2.2.12-1+deb10u1) ...
                            Preparing to unpack .../03-gnupg-utils_2.2.12-1+deb10u2_amd64.deb ...
                            Unpacking gnupg-utils (2.2.12-1+deb10u2) over (2.2.12-1+deb10u1) ...
                            Preparing to unpack .../04-gpg-agent_2.2.12-1+deb10u2_amd64.deb ...
                            Unpacking gpg-agent (2.2.12-1+deb10u2) over (2.2.12-1+deb10u1) ...
                            Preparing to unpack .../05-gpg_2.2.12-1+deb10u2_amd64.deb ...
                            Unpacking gpg (2.2.12-1+deb10u2) over (2.2.12-1+deb10u1) ...
                            Preparing to unpack .../06-gpgconf_2.2.12-1+deb10u2_amd64.deb ...
                            Unpacking gpgconf (2.2.12-1+deb10u2) over (2.2.12-1+deb10u1) ...
                            Preparing to unpack .../07-gnupg-l10n_2.2.12-1+deb10u2_all.deb ...
                            Unpacking gnupg-l10n (2.2.12-1+deb10u2) over (2.2.12-1+deb10u1) ...
                            Preparing to unpack .../08-gnupg_2.2.12-1+deb10u2_all.deb ...
                            Unpacking gnupg (2.2.12-1+deb10u2) over (2.2.12-1+deb10u1) ...
                            Preparing to unpack .../09-gpgsm_2.2.12-1+deb10u2_amd64.deb ...
                            Unpacking gpgsm (2.2.12-1+deb10u2) over (2.2.12-1+deb10u1) ...
                            Preparing to unpack .../10-gpgv_2.2.12-1+deb10u2_amd64.deb ...
                            Unpacking gpgv (2.2.12-1+deb10u2) over (2.2.12-1+deb10u1) ...
                            Setting up gpgv (2.2.12-1+deb10u2) ...
                            Preparing to unpack .../curl_7.64.0-4+deb10u8_amd64.deb ...
                            Unpacking curl (7.64.0-4+deb10u8) over (7.64.0-4+deb10u2) ...
                            Preparing to unpack .../libcurl4_7.64.0-4+deb10u8_amd64.deb ...
                            Unpacking libcurl4:amd64 (7.64.0-4+deb10u8) over (7.64.0-4+deb10u2) ...
                            Setting up gnupg-l10n (2.2.12-1+deb10u2) ...
                            Setting up gpgconf (2.2.12-1+deb10u2) ...
                            Setting up libcurl4:amd64 (7.64.0-4+deb10u8) ...
                            Setting up curl (7.64.0-4+deb10u8) ...
                            Setting up gpg (2.2.12-1+deb10u2) ...
                            Setting up gnupg-utils (2.2.12-1+deb10u2) ...
                            Setting up gpg-agent (2.2.12-1+deb10u2) ...
                            Setting up gpgsm (2.2.12-1+deb10u2) ...
                            Setting up dirmngr (2.2.12-1+deb10u2) ...
                            Setting up gpg-wks-server (2.2.12-1+deb10u2) ...
                            Setting up gpg-wks-client (2.2.12-1+deb10u2) ...
                            Setting up gnupg (2.2.12-1+deb10u2) ...
                            Processing triggers for man-db (2.8.5-2) ...
                            Processing triggers for libc-bin (2.28-10) ...
                            *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                            deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node                     _18.x nodistro main
                            Package: nodejs
                            Pin: origin deb.nodesource.com
                            Pin-Priority: 1001
                            *** These repos are active after the adjustments:
                            Get:5 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
                            Get:6 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [6634 B]
                            Fetched 25.8 kB in 0s (52.0 kB/s)
                            Installing the recommended nodejs version now!
                            Exact recommended version unknown, installing a fallback!
                            Preparing to unpack .../nodejs_18.0.0-1nodesource1_amd64.deb ...
                            Detected old npm client, removing...
                            Unpacking nodejs (18.0.0-1nodesource1) over (12.22.7-deb-1nodesource1) ...
                            Setting up nodejs (18.0.0-1nodesource1) ...
                            Updating fallback to latest nodejs v18 release
                            Extracting templates from packages: 100%
                            Preconfiguring packages ...
                            (Reading database ... 51227 files and directories currently installed.)
                            Preparing to unpack .../base-files_10.3+deb10u13_amd64.deb ...
                            Unpacking base-files (10.3+deb10u13) over (10.3+deb10u11) ...
                            Setting up base-files (10.3+deb10u13) ...
                            Installing new version of config file /etc/debian_version ...
                            Preparing to unpack .../archives/dpkg_1.19.8_amd64.deb ...
                            Unpacking dpkg (1.19.8) over (1.19.7) ...
                            Setting up dpkg (1.19.8) ...
                            Preparing to unpack .../gzip_1.9-3+deb10u1_amd64.deb ...
                            Unpacking gzip (1.9-3+deb10u1) over (1.9-3) ...
                            Setting up gzip (1.9-3+deb10u1) ...
                            Preparing to unpack .../ncurses-bin_6.1+20181013-2+deb10u5_amd64.deb ...
                            Unpacking ncurses-bin (6.1+20181013-2+deb10u5) over (6.1+20181013-2+deb10u2) ...
                            Setting up ncurses-bin (6.1+20181013-2+deb10u5) ...
                            Preparing to unpack .../libc6-dev_2.28-10+deb10u2_amd64.deb ...
                            Unpacking libc6-dev:amd64 (2.28-10+deb10u2) over (2.28-10) ...
                            Preparing to unpack .../libc-dev-bin_2.28-10+deb10u2_amd64.deb ...
                            Unpacking libc-dev-bin (2.28-10+deb10u2) over (2.28-10) ...
                            Preparing to unpack .../linux-libc-dev_4.19.289-2_amd64.deb ...
                            Unpacking linux-libc-dev:amd64 (4.19.289-2) over (4.19.208-1) ...
                            Preparing to unpack .../libc6_2.28-10+deb10u2_amd64.deb ...
                            Unpacking libc6:amd64 (2.28-10+deb10u2) over (2.28-10) ...
                            Setting up libc6:amd64 (2.28-10+deb10u2) ...
                            (Reading database ... 51225 files and directories currently installed.)
                            Preparing to unpack .../libc-bin_2.28-10+deb10u2_amd64.deb ...
                            Unpacking libc-bin (2.28-10+deb10u2) over (2.28-10) ...
                            Setting up libc-bin (2.28-10+deb10u2) ...
                            Preparing to unpack .../ncurses-base_6.1+20181013-2+deb10u5_all.deb ...
                            Unpacking ncurses-base (6.1+20181013-2+deb10u5) over (6.1+20181013-2+deb10u2) ...
                            Setting up ncurses-base (6.1+20181013-2+deb10u5) ...
                            Preparing to unpack .../libudev-dev_241-7~deb10u10_amd64.deb ...
                            Unpacking libudev-dev:amd64 (241-7~deb10u10) over (241-7~deb10u8) ...
                            Preparing to unpack .../libsystemd0_241-7~deb10u10_amd64.deb ...
                            Unpacking libsystemd0:amd64 (241-7~deb10u10) over (241-7~deb10u8) ...
                            Setting up libsystemd0:amd64 (241-7~deb10u10) ...
                            Preparing to unpack .../libpam-systemd_241-7~deb10u10_amd64.deb ...
                            Unpacking libpam-systemd:amd64 (241-7~deb10u10) over (241-7~deb10u8) ...
                            Preparing to unpack .../libnss-systemd_241-7~deb10u10_amd64.deb ...
                            Unpacking libnss-systemd:amd64 (241-7~deb10u10) over (241-7~deb10u8) ...
                            Preparing to unpack .../systemd_241-7~deb10u10_amd64.deb ...
                            Unpacking systemd (241-7~deb10u10) over (241-7~deb10u8) ...
                            Preparing to unpack .../udev_241-7~deb10u10_amd64.deb ...
                            Unpacking udev (241-7~deb10u10) over (241-7~deb10u8) ...
                            Preparing to unpack .../libudev1_241-7~deb10u10_amd64.deb ...
                            Unpacking libudev1:amd64 (241-7~deb10u10) over (241-7~deb10u8) ...
                            Setting up libudev1:amd64 (241-7~deb10u10) ...
                            Setting up systemd (241-7~deb10u10) ...
                            Preparing to unpack .../0-systemd-sysv_241-7~deb10u10_amd64.deb ...
                            Unpacking systemd-sysv (241-7~deb10u10) over (241-7~deb10u8) ...
                            Preparing to unpack .../1-libdbus-1-dev_1.12.28-0+deb10u1_amd64.deb ...
                            Unpacking libdbus-1-dev:amd64 (1.12.28-0+deb10u1) over (1.12.20-0+deb10u1) ...
                            Preparing to unpack .../2-dbus_1.12.28-0+deb10u1_amd64.deb ...
                            Unpacking dbus (1.12.28-0+deb10u1) over (1.12.20-0+deb10u1) ...
                            Preparing to unpack .../3-libdbus-1-3_1.12.28-0+deb10u1_amd64.deb ...
                            Unpacking libdbus-1-3:amd64 (1.12.28-0+deb10u1) over (1.12.20-0+deb10u1) ...
                            Preparing to unpack .../4-libexpat1-dev_2.2.6-2+deb10u6_amd64.deb ...
                            Unpacking libexpat1-dev:amd64 (2.2.6-2+deb10u6) over (2.2.6-2+deb10u1) ...
                            Preparing to unpack .../5-libexpat1_2.2.6-2+deb10u6_amd64.deb ...
                            Unpacking libexpat1:amd64 (2.2.6-2+deb10u6) over (2.2.6-2+deb10u1) ...
                            Preparing to unpack .../6-libgmp10_2%3a6.1.2+dfsg-4+deb10u1_amd64.deb ...
                            Unpacking libgmp10:amd64 (2:6.1.2+dfsg-4+deb10u1) over (2:6.1.2+dfsg-4) ...
                            Setting up libgmp10:amd64 (2:6.1.2+dfsg-4+deb10u1) ...
                            Preparing to unpack .../libtasn1-6_4.13-3+deb10u1_amd64.deb ...
                            Unpacking libtasn1-6:amd64 (4.13-3+deb10u1) over (4.13-3) ...
                            Setting up libtasn1-6:amd64 (4.13-3+deb10u1) ...
                            Preparing to unpack .../libgnutls30_3.6.7-4+deb10u11_amd64.deb ...
                            Unpacking libgnutls30:amd64 (3.6.7-4+deb10u11) over (3.6.7-4+deb10u7) ...
                            Setting up libgnutls30:amd64 (3.6.7-4+deb10u11) ...
                            Preparing to unpack .../libfastjson4_0.99.8-2+deb10u1_amd64.deb ...
                            Unpacking libfastjson4:amd64 (0.99.8-2+deb10u1) over (0.99.8-2) ...
                            Preparing to unpack .../zlib1g-dev_1%3a1.2.11.dfsg-1+deb10u2_amd64.deb ...
                            Unpacking zlib1g-dev:amd64 (1:1.2.11.dfsg-1+deb10u2) over (1:1.2.11.dfsg-1) ...
                            Preparing to unpack .../zlib1g_1%3a1.2.11.dfsg-1+deb10u2_amd64.deb ...
                            Unpacking zlib1g:amd64 (1:1.2.11.dfsg-1+deb10u2) over (1:1.2.11.dfsg-1) ...
                            Setting up zlib1g:amd64 (1:1.2.11.dfsg-1+deb10u2) ...
                            Preparing to unpack .../0-rsyslog_8.1901.0-1+deb10u2_amd64.deb ...
                            Unpacking rsyslog (8.1901.0-1+deb10u2) over (8.1901.0-1) ...
                            Preparing to unpack .../1-libwbclient0_2%3a4.9.5+dfsg-5+deb10u4_amd64.deb ...
                            Unpacking libwbclient0:amd64 (2:4.9.5+dfsg-5+deb10u4) over (2:4.9.5+dfsg-5+deb10u1) ...
                            Preparing to unpack .../2-python2.7-dev_2.7.16-2+deb10u3_amd64.deb ...
                            Unpacking python2.7-dev (2.7.16-2+deb10u3) over (2.7.16-2+deb10u1) ...
                            Preparing to unpack .../3-libpython2.7-dev_2.7.16-2+deb10u3_amd64.deb ...
                            Unpacking libpython2.7-dev:amd64 (2.7.16-2+deb10u3) over (2.7.16-2+deb10u1) ...
                            Preparing to unpack .../4-libpython2.7_2.7.16-2+deb10u3_amd64.deb ...
                            Unpacking libpython2.7:amd64 (2.7.16-2+deb10u3) over (2.7.16-2+deb10u1) ...
                            Preparing to unpack .../5-python2.7_2.7.16-2+deb10u3_amd64.deb ...
                            Unpacking python2.7 (2.7.16-2+deb10u3) over (2.7.16-2+deb10u1) ...
                            Preparing to unpack .../6-libssl1.1_1.1.1n-0+deb10u6_amd64.deb ...
                            Unpacking libssl1.1:amd64 (1.1.1n-0+deb10u6) over (1.1.1d-0+deb10u7) ...
                            Preparing to unpack .../7-bzip2_1.0.6-9.2~deb10u2_amd64.deb ...
                            Unpacking bzip2 (1.0.6-9.2~deb10u2) over (1.0.6-9.2~deb10u1) ...
                            Preparing to unpack .../8-libbz2-1.0_1.0.6-9.2~deb10u2_amd64.deb ...
                            Unpacking libbz2-1.0:amd64 (1.0.6-9.2~deb10u2) over (1.0.6-9.2~deb10u1) ...
                            Setting up libbz2-1.0:amd64 (1.0.6-9.2~deb10u2) ...
                            Preparing to unpack .../libncurses6_6.1+20181013-2+deb10u5_amd64.deb ...
                            Unpacking libncurses6:amd64 (6.1+20181013-2+deb10u5) over (6.1+20181013-2+deb10u2) ...
                            Preparing to unpack .../libtinfo6_6.1+20181013-2+deb10u5_amd64.deb ...
                            Unpacking libtinfo6:amd64 (6.1+20181013-2+deb10u5) over (6.1+20181013-2+deb10u2) ...
                            Setting up libtinfo6:amd64 (6.1+20181013-2+deb10u5) ...
                            Preparing to unpack .../libncursesw6_6.1+20181013-2+deb10u5_amd64.deb ...
                            Unpacking libncursesw6:amd64 (6.1+20181013-2+deb10u5) over (6.1+20181013-2+deb10u2) ...
                            Setting up libncursesw6:amd64 (6.1+20181013-2+deb10u5) ...
                            Preparing to unpack .../0-libsqlite3-0_3.27.2-3+deb10u2_amd64.deb ...
                            Unpacking libsqlite3-0:amd64 (3.27.2-3+deb10u2) over (3.27.2-3+deb10u1) ...
                            Preparing to unpack .../1-libpython2.7-stdlib_2.7.16-2+deb10u3_amd64.deb ...
                            Unpacking libpython2.7-stdlib:amd64 (2.7.16-2+deb10u3) over (2.7.16-2+deb10u1) ...
                            Preparing to unpack .../2-python2.7-minimal_2.7.16-2+deb10u3_amd64.deb ...
                            Unpacking python2.7-minimal (2.7.16-2+deb10u3) over (2.7.16-2+deb10u1) ...
                            Preparing to unpack .../3-libpython2.7-minimal_2.7.16-2+deb10u3_amd64.deb ...
                            Unpacking libpython2.7-minimal:amd64 (2.7.16-2+deb10u3) over (2.7.16-2+deb10u1) ...
                            Preparing to unpack .../4-python3.7_3.7.3-2+deb10u6_amd64.deb ...
                            Unpacking python3.7 (3.7.3-2+deb10u6) over (3.7.3-2+deb10u3) ...
                            Preparing to unpack .../5-libpython3.7-stdlib_3.7.3-2+deb10u6_amd64.deb ...
                            Unpacking libpython3.7-stdlib:amd64 (3.7.3-2+deb10u6) over (3.7.3-2+deb10u3) ...
                            Preparing to unpack .../6-python3.7-minimal_3.7.3-2+deb10u6_amd64.deb ...
                            Unpacking python3.7-minimal (3.7.3-2+deb10u6) over (3.7.3-2+deb10u3) ...
                            Preparing to unpack .../7-libpython3.7-minimal_3.7.3-2+deb10u6_amd64.deb ...
                            Unpacking libpython3.7-minimal:amd64 (3.7.3-2+deb10u6) over (3.7.3-2+deb10u3) ...
                            Preparing to unpack .../8-liblzma5_5.2.4-1+deb10u1_amd64.deb ...
                            Unpacking liblzma5:amd64 (5.2.4-1+deb10u1) over (5.2.4-1) ...
                            Setting up liblzma5:amd64 (5.2.4-1+deb10u1) ...
                            Preparing to unpack .../debian-archive-keyring_2019.1+deb10u2_all.deb ...
                            Unpacking debian-archive-keyring (2019.1+deb10u2) over (2019.1+deb10u1) ...
                            Setting up debian-archive-keyring (2019.1+deb10u2) ...
                            (Reading database ... 51231 files and directories currently installed.)
                            Preparing to unpack .../00-tzdata_2021a-0+deb10u12_all.deb ...
                            Unpacking tzdata (2021a-0+deb10u12) over (2021a-0+deb10u3) ...
                            Preparing to unpack .../01-cpio_2.12+dfsg-9+deb10u1_amd64.deb ...
                            Unpacking cpio (2.12+dfsg-9+deb10u1) over (2.12+dfsg-9) ...
                            Preparing to unpack .../02-libisc-export1100_1%3a9.11.5.P4+dfsg-5.1+deb10u9_amd64.deb ...
                            Unpacking libisc-export1100:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) over (1:9.11.5.P4+dfsg-5.1+deb10u6) ...
                            Preparing to unpack .../03-libdns-export1104_1%3a9.11.5.P4+dfsg-5.1+deb10u9_amd64.deb ...
                            Unpacking libdns-export1104 (1:9.11.5.P4+dfsg-5.1+deb10u9) over (1:9.11.5.P4+dfsg-5.1+deb10u6) ...
                            Preparing to unpack .../04-isc-dhcp-client_4.4.1-2+deb10u3_amd64.deb ...
                            Unpacking isc-dhcp-client (4.4.1-2+deb10u3) over (4.4.1-2+deb10u1) ...
                            Preparing to unpack .../05-isc-dhcp-common_4.4.1-2+deb10u3_amd64.deb ...
                            Unpacking isc-dhcp-common (4.4.1-2+deb10u3) over (4.4.1-2+deb10u1) ...
                            Preparing to unpack .../06-vim-tiny_2%3a8.1.0875-5+deb10u6_amd64.deb ...
                            Unpacking vim-tiny (2:8.1.0875-5+deb10u6) over (2:8.1.0875-5) ...
                            Preparing to unpack .../07-xxd_2%3a8.1.0875-5+deb10u6_amd64.deb ...
                            Unpacking xxd (2:8.1.0875-5+deb10u6) over (2:8.1.0875-5) ...
                            Preparing to unpack .../08-vim-common_2%3a8.1.0875-5+deb10u6_all.deb ...
                            Unpacking vim-common (2:8.1.0875-5+deb10u6) over (2:8.1.0875-5) ...
                            Preparing to unpack .../09-libicu-dev_63.1-6+deb10u3_amd64.deb ...
                            Unpacking libicu-dev:amd64 (63.1-6+deb10u3) over (63.1-6+deb10u1) ...
                            Preparing to unpack .../10-icu-devtools_63.1-6+deb10u3_amd64.deb ...
                            Unpacking icu-devtools (63.1-6+deb10u3) over (63.1-6+deb10u1) ...
                            Preparing to unpack .../11-libicu63_63.1-6+deb10u3_amd64.deb ...
                            Unpacking libicu63:amd64 (63.1-6+deb10u3) over (63.1-6+deb10u1) ...
                            Preparing to unpack .../12-libxml2_2.9.4+dfsg1-7+deb10u6_amd64.deb ...
                            Unpacking libxml2:amd64 (2.9.4+dfsg1-7+deb10u6) over (2.9.4+dfsg1-7+deb10u2) ...
                            Preparing to unpack .../13-bind9-host_1%3a9.11.5.P4+dfsg-5.1+deb10u9_amd64.deb ...
                            Unpacking bind9-host (1:9.11.5.P4+dfsg-5.1+deb10u9) over (1:9.11.5.P4+dfsg-5.1+deb10u6) ...
                            Preparing to unpack .../14-libbind9-161_1%3a9.11.5.P4+dfsg-5.1+deb10u9_amd64.deb ...
                            Unpacking libbind9-161:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) over (1:9.11.5.P4+dfsg-5.1+deb10u6) ...
                            Preparing to unpack .../15-libisccfg163_1%3a9.11.5.P4+dfsg-5.1+deb10u9_amd64.deb ...
                            Unpacking libisccfg163:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) over (1:9.11.5.P4+dfsg-5.1+deb10u6) ...
                            Preparing to unpack .../16-libisccc161_1%3a9.11.5.P4+dfsg-5.1+deb10u9_amd64.deb ...
                            Unpacking libisccc161:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) over (1:9.11.5.P4+dfsg-5.1+deb10u6) ...
                            Preparing to unpack .../17-libdns1104_1%3a9.11.5.P4+dfsg-5.1+deb10u9_amd64.deb ...
                            Unpacking libdns1104:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) over (1:9.11.5.P4+dfsg-5.1+deb10u6) ...
                            Preparing to unpack .../18-libisc1100_1%3a9.11.5.P4+dfsg-5.1+deb10u9_amd64.deb ...
                            Unpacking libisc1100:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) over (1:9.11.5.P4+dfsg-5.1+deb10u6) ...
                            Preparing to unpack .../19-libgssapi-krb5-2_1.17-3+deb10u6_amd64.deb ...
                            Unpacking libgssapi-krb5-2:amd64 (1.17-3+deb10u6) over (1.17-3+deb10u3) ...
                            Preparing to unpack .../20-libkrb5-3_1.17-3+deb10u6_amd64.deb ...
                            Unpacking libkrb5-3:amd64 (1.17-3+deb10u6) over (1.17-3+deb10u3) ...
                            Preparing to unpack .../21-libkrb5support0_1.17-3+deb10u6_amd64.deb ...
                            Unpacking libkrb5support0:amd64 (1.17-3+deb10u6) over (1.17-3+deb10u3) ...
                            Preparing to unpack .../22-libk5crypto3_1.17-3+deb10u6_amd64.deb ...
                            Unpacking libk5crypto3:amd64 (1.17-3+deb10u6) over (1.17-3+deb10u3) ...
                            Preparing to unpack .../23-liblwres161_1%3a9.11.5.P4+dfsg-5.1+deb10u9_amd64.deb ...
                            Unpacking liblwres161:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) over (1:9.11.5.P4+dfsg-5.1+deb10u6) ...
                            Preparing to unpack .../24-krb5-locales_1.17-3+deb10u6_all.deb ...
                            Unpacking krb5-locales (1.17-3+deb10u6) over (1.17-3+deb10u3) ...
                            Preparing to unpack .../25-libc-l10n_2.28-10+deb10u2_all.deb ...
                            Unpacking libc-l10n (2.28-10+deb10u2) over (2.28-10) ...
                            Preparing to unpack .../26-locales_2.28-10+deb10u2_all.deb ...
                            Unpacking locales (2.28-10+deb10u2) over (2.28-10) ...
                            Preparing to unpack .../27-ncurses-term_6.1+20181013-2+deb10u5_all.deb ...
                            Unpacking ncurses-term (6.1+20181013-2+deb10u5) over (6.1+20181013-2+deb10u2) ...
                            Preparing to unpack .../28-openssh-sftp-server_1%3a7.9p1-10+deb10u4_amd64.deb ...
                            Unpacking openssh-sftp-server (1:7.9p1-10+deb10u4) over (1:7.9p1-10+deb10u2) ...
                            Preparing to unpack .../29-openssh-server_1%3a7.9p1-10+deb10u4_amd64.deb ...
                            Unpacking openssh-server (1:7.9p1-10+deb10u4) over (1:7.9p1-10+deb10u2) ...
                            Preparing to unpack .../30-git-man_1%3a2.20.1-2+deb10u8_all.deb ...
                            Unpacking git-man (1:2.20.1-2+deb10u8) over (1:2.20.1-2+deb10u3) ...
                            Preparing to unpack .../31-libsasl2-modules-db_2.1.27+dfsg-1+deb10u2_amd64.deb ...
                            Unpacking libsasl2-modules-db:amd64 (2.1.27+dfsg-1+deb10u2) over (2.1.27+dfsg-1+deb10u1) ...
                            Preparing to unpack .../32-libsasl2-2_2.1.27+dfsg-1+deb10u2_amd64.deb ...
                            Unpacking libsasl2-2:amd64 (2.1.27+dfsg-1+deb10u2) over (2.1.27+dfsg-1+deb10u1) ...
                            Preparing to unpack .../33-libldap-common_2.4.47+dfsg-3+deb10u7_all.deb ...
                            Unpacking libldap-common (2.4.47+dfsg-3+deb10u7) over (2.4.47+dfsg-3+deb10u6) ...
                            Preparing to unpack .../34-libldap-2.4-2_2.4.47+dfsg-3+deb10u7_amd64.deb ...
                            Unpacking libldap-2.4-2:amd64 (2.4.47+dfsg-3+deb10u7) over (2.4.47+dfsg-3+deb10u6) ...
                            Preparing to unpack .../35-libnghttp2-14_1.36.0-2+deb10u2_amd64.deb ...
                            Unpacking libnghttp2-14:amd64 (1.36.0-2+deb10u2) over (1.36.0-2+deb10u1) ...
                            Preparing to unpack .../36-libssh2-1_1.8.0-2.1+deb10u1_amd64.deb ...
                            Unpacking libssh2-1:amd64 (1.8.0-2.1+deb10u1) over (1.8.0-2.1) ...
                            Preparing to unpack .../37-libcurl3-gnutls_7.64.0-4+deb10u8_amd64.deb ...
                            Unpacking libcurl3-gnutls:amd64 (7.64.0-4+deb10u8) over (7.64.0-4+deb10u2) ...
                            Preparing to unpack .../38-libpcre2-8-0_10.32-5+deb10u1_amd64.deb ...
                            Unpacking libpcre2-8-0:amd64 (10.32-5+deb10u1) over (10.32-5) ...
                            Preparing to unpack .../39-git_1%3a2.20.1-2+deb10u8_amd64.deb ...
                            Unpacking git (1:2.20.1-2+deb10u8) over (1:2.20.1-2+deb10u3) ...
                            Preparing to unpack .../40-openssh-client_1%3a7.9p1-10+deb10u4_amd64.deb ...
                            Unpacking openssh-client (1:7.9p1-10+deb10u4) over (1:7.9p1-10+deb10u2) ...
                            Preparing to unpack .../41-reportbug_7.5.3~deb10u2_all.deb ...
                            Unpacking reportbug (7.5.3~deb10u2) over (7.5.3~deb10u1) ...
                            Preparing to unpack .../42-python3-urllib3_1.24.1-1+deb10u2_all.deb ...
                            Unpacking python3-urllib3 (1.24.1-1+deb10u2) over (1.24.1-1) ...
                            Preparing to unpack .../43-python3-requests_2.21.0-1+deb10u1_all.deb ...
                            Unpacking python3-requests (2.21.0-1+deb10u1) over (2.21.0-1) ...
                            Preparing to unpack .../44-python3-reportbug_7.5.3~deb10u2_all.deb ...
                            Unpacking python3-reportbug (7.5.3~deb10u2) over (7.5.3~deb10u1) ...
                            Preparing to unpack .../45-xz-utils_5.2.4-1+deb10u1_amd64.deb ...
                            Unpacking xz-utils (5.2.4-1+deb10u1) over (5.2.4-1) ...
                            Preparing to unpack .../46-cifs-utils_2%3a6.8-2+deb10u1_amd64.deb ...
                            Unpacking cifs-utils (2:6.8-2+deb10u1) over (2:6.8-2) ...
                            Preparing to unpack .../47-distro-info-data_0.41+deb10u8_all.deb ...
                            Unpacking distro-info-data (0.41+deb10u8) over (0.41+deb10u4) ...
                            Preparing to unpack .../48-dpkg-dev_1.19.8_all.deb ...
                            Unpacking dpkg-dev (1.19.8) over (1.19.7) ...
                            Preparing to unpack .../49-libdpkg-perl_1.19.8_all.deb ...
                            Unpacking libdpkg-perl (1.19.8) over (1.19.7) ...
                            Preparing to unpack .../50-libglib2.0-data_2.58.3-2+deb10u5_all.deb ...
                            Unpacking libglib2.0-data (2.58.3-2+deb10u5) over (2.58.3-2+deb10u3) ...
                            Preparing to unpack .../51-libelf1_0.176-1.1+deb10u1_amd64.deb ...
                            Unpacking libelf1:amd64 (0.176-1.1+deb10u1) over (0.176-1.1) ...
                            Preparing to unpack .../52-libglib2.0-dev_2.58.3-2+deb10u5_amd64.deb ...
                            Unpacking libglib2.0-dev:amd64 (2.58.3-2+deb10u5) over (2.58.3-2+deb10u3) ...
                            Preparing to unpack .../53-libglib2.0-dev-bin_2.58.3-2+deb10u5_amd64.deb ...
                            Unpacking libglib2.0-dev-bin (2.58.3-2+deb10u5) over (2.58.3-2+deb10u3) ...
                            Preparing to unpack .../54-libglib2.0-bin_2.58.3-2+deb10u5_amd64.deb ...
                            Unpacking libglib2.0-bin (2.58.3-2+deb10u5) over (2.58.3-2+deb10u3) ...
                            Preparing to unpack .../55-libglib2.0-0_2.58.3-2+deb10u5_amd64.deb ...
                            Unpacking libglib2.0-0:amd64 (2.58.3-2+deb10u5) over (2.58.3-2+deb10u3) ...
                            Preparing to unpack .../56-librsvg2-dev_2.44.10-2.1+deb10u3_amd64.deb ...
                            Unpacking librsvg2-dev:amd64 (2.44.10-2.1+deb10u3) over (2.44.10-2.1) ...
                            Preparing to unpack .../57-librsvg2-common_2.44.10-2.1+deb10u3_amd64.deb ...
                            Unpacking librsvg2-common:amd64 (2.44.10-2.1+deb10u3) over (2.44.10-2.1) ...
                            Preparing to unpack .../58-librsvg2-2_2.44.10-2.1+deb10u3_amd64.deb ...
                            Unpacking librsvg2-2:amd64 (2.44.10-2.1+deb10u3) over (2.44.10-2.1) ...
                            Preparing to unpack .../59-gir1.2-rsvg-2.0_2.44.10-2.1+deb10u3_amd64.deb ...
                            Unpacking gir1.2-rsvg-2.0:amd64 (2.44.10-2.1+deb10u3) over (2.44.10-2.1) ...
                            Preparing to unpack .../60-grub2-common_2.06-3~deb10u4_amd64.deb ...
                            Unpacking grub2-common (2.06-3~deb10u4) over (2.02+dfsg1-20+deb10u4) ...
                            Preparing to unpack .../61-grub-pc_2.06-3~deb10u4_amd64.deb ...
                            Unpacking grub-pc (2.06-3~deb10u4) over (2.02+dfsg1-20+deb10u4) ...
                            Preparing to unpack .../62-grub-pc-bin_2.06-3~deb10u4_amd64.deb ...
                            Unpacking grub-pc-bin (2.06-3~deb10u4) over (2.02+dfsg1-20+deb10u4) ...
                            Preparing to unpack .../63-libfreetype6-dev_2.9.1-3+deb10u3_amd64.deb ...
                            Unpacking libfreetype6-dev:amd64 (2.9.1-3+deb10u3) over (2.9.1-3+deb10u2) ...
                            Preparing to unpack .../64-libfreetype6_2.9.1-3+deb10u3_amd64.deb ...
                            Unpacking libfreetype6:amd64 (2.9.1-3+deb10u3) over (2.9.1-3+deb10u2) ...
                            Preparing to unpack .../65-grub-common_2.06-3~deb10u4_amd64.deb ...
                            Unpacking grub-common (2.06-3~deb10u4) over (2.02+dfsg1-20+deb10u4) ...
                            Preparing to unpack .../66-libavahi-common-dev_0.7-4+deb10u3_amd64.deb ...
                            Unpacking libavahi-common-dev:amd64 (0.7-4+deb10u3) over (0.7-4+deb10u1) ...
                            Preparing to unpack .../67-libavahi-common-data_0.7-4+deb10u3_amd64.deb ...
                            Unpacking libavahi-common-data:amd64 (0.7-4+deb10u3) over (0.7-4+deb10u1) ...
                            Preparing to unpack .../68-libavahi-common3_0.7-4+deb10u3_amd64.deb ...
                            Unpacking libavahi-common3:amd64 (0.7-4+deb10u3) over (0.7-4+deb10u1) ...
                            Preparing to unpack .../69-libavahi-client-dev_0.7-4+deb10u3_amd64.deb ...
                            Unpacking libavahi-client-dev:amd64 (0.7-4+deb10u3) over (0.7-4+deb10u1) ...
                            Preparing to unpack .../70-libavahi-client3_0.7-4+deb10u3_amd64.deb ...
                            Unpacking libavahi-client3:amd64 (0.7-4+deb10u3) over (0.7-4+deb10u1) ...
                            Preparing to unpack .../71-libavahi-compat-libdnssd-dev_0.7-4+deb10u3_amd64.deb ...
                            Unpacking libavahi-compat-libdnssd-dev:amd64 (0.7-4+deb10u3) over (0.7-4+deb10u1) ...
                            Preparing to unpack .../72-libavahi-compat-libdnssd1_0.7-4+deb10u3_amd64.deb ...
                            Unpacking libavahi-compat-libdnssd1:amd64 (0.7-4+deb10u3) over (0.7-4+deb10u1) ...
                            Preparing to unpack .../73-libfribidi-dev_1.0.5-3.1+deb10u2_amd64.deb ...
                            Unpacking libfribidi-dev:amd64 (1.0.5-3.1+deb10u2) over (1.0.5-3.1+deb10u1) ...
                            Preparing to unpack .../74-libfribidi0_1.0.5-3.1+deb10u2_amd64.deb ...
                            Unpacking libfribidi0:amd64 (1.0.5-3.1+deb10u2) over (1.0.5-3.1+deb10u1) ...
                            Preparing to unpack .../75-libgif-dev_5.1.4-3+deb10u1_amd64.deb ...
                            Unpacking libgif-dev (5.1.4-3+deb10u1) over (5.1.4-3) ...
                            Preparing to unpack .../76-libgif7_5.1.4-3+deb10u1_amd64.deb ...
                            Unpacking libgif7:amd64 (5.1.4-3+deb10u1) over (5.1.4-3) ...
                            Preparing to unpack .../77-libksba8_1.3.5-2+deb10u2_amd64.deb ...
                            Unpacking libksba8:amd64 (1.3.5-2+deb10u2) over (1.3.5-2) ...
                            Preparing to unpack .../78-libpixman-1-dev_0.36.0-1+deb10u1_amd64.deb ...
                            Unpacking libpixman-1-dev:amd64 (0.36.0-1+deb10u1) over (0.36.0-1) ...
                            Preparing to unpack .../79-libpixman-1-0_0.36.0-1+deb10u1_amd64.deb ...
                            Unpacking libpixman-1-0:amd64 (0.36.0-1+deb10u1) over (0.36.0-1) ...
                            Preparing to unpack .../80-libsasl2-modules_2.1.27+dfsg-1+deb10u2_amd64.deb ...
                            Unpacking libsasl2-modules:amd64 (2.1.27+dfsg-1+deb10u2) over (2.1.27+dfsg-1+deb10u1) ...
                            Preparing to unpack .../81-libwebp6_0.6.1-2+deb10u3_amd64.deb ...
                            Unpacking libwebp6:amd64 (0.6.1-2+deb10u3) over (0.6.1-2+deb10u1) ...
                            Preparing to unpack .../82-libtiff5_4.1.0+git191117-2~deb10u8_amd64.deb ...
                            Unpacking libtiff5:amd64 (4.1.0+git191117-2~deb10u8) over (4.1.0+git191117-2~deb10u3) ...
                            Preparing to unpack .../83-libtirpc-common_1.1.4-0.4+deb10u1_all.deb ...
                            Unpacking libtirpc-common (1.1.4-0.4+deb10u1) over (1.1.4-0.4) ...
                            Preparing to unpack .../84-libtirpc3_1.1.4-0.4+deb10u1_amd64.deb ...
                            Unpacking libtirpc3:amd64 (1.1.4-0.4+deb10u1) over (1.1.4-0.4) ...
                            Preparing to unpack .../85-libx11-data_2%3a1.6.7-1+deb10u4_all.deb ...
                            Unpacking libx11-data (2:1.6.7-1+deb10u4) over (2:1.6.7-1+deb10u2) ...
                            Preparing to unpack .../86-libx11-dev_2%3a1.6.7-1+deb10u4_amd64.deb ...
                            Unpacking libx11-dev:amd64 (2:1.6.7-1+deb10u4) over (2:1.6.7-1+deb10u2) ...
                            Preparing to unpack .../87-libx11-6_2%3a1.6.7-1+deb10u4_amd64.deb ...
                            Unpacking libx11-6:amd64 (2:1.6.7-1+deb10u4) over (2:1.6.7-1+deb10u2) ...
                            Preparing to unpack .../88-nodejs_18.19.0-1nodesource1_amd64.deb ...
                            Unpacking nodejs (18.19.0-1nodesource1) over (18.0.0-1nodesource1) ...
                            Preparing to unpack .../89-openssl_1.1.1n-0+deb10u6_amd64.deb ...
                            Unpacking openssl (1.1.1n-0+deb10u6) over (1.1.1d-0+deb10u7) ...
                            Preparing to unpack .../90-publicsuffix_20220811.1734-0+deb10u1_all.deb ...
                            Unpacking publicsuffix (20220811.1734-0+deb10u1) over (20190415.1030-1) ...
                            Preparing to unpack .../91-python-ipaddress_1.0.17-1+deb10u1_all.deb ...
                            Unpacking python-ipaddress (1.0.17-1+deb10u1) over (1.0.17-1) ...
                            Preparing to unpack .../92-python-cryptography_2.6.1-3+deb10u4_amd64.deb ...
                            Unpacking python-cryptography (2.6.1-3+deb10u4) over (2.6.1-3+deb10u2) ...
                            Preparing to unpack .../93-sudo_1.8.27-1+deb10u5_amd64.deb ...
                            Unpacking sudo (1.8.27-1+deb10u5) over (1.8.27-1+deb10u3) ...
                            Preparing to unpack .../94-unzip_6.0-23+deb10u3_amd64.deb ...
                            Unpacking unzip (6.0-23+deb10u3) over (6.0-23+deb10u2) ...
                            Setting up libksba8:amd64 (1.3.5-2+deb10u2) ...
                            Setting up libexpat1:amd64 (2.2.6-2+deb10u6) ...
                            Setting up cpio (2.12+dfsg-9+deb10u1) ...
                            Setting up libpixman-1-0:amd64 (0.36.0-1+deb10u1) ...
                            Setting up systemd-sysv (241-7~deb10u10) ...
                            Setting up libc-l10n (2.28-10+deb10u2) ...
                            Setting up libpixman-1-dev:amd64 (0.36.0-1+deb10u1) ...
                            Setting up libglib2.0-0:amd64 (2.58.3-2+deb10u5) ...
                            No schema files found: doing nothing.
                            Setting up distro-info-data (0.41+deb10u8) ...
                            Setting up libfastjson4:amd64 (0.99.8-2+deb10u1) ...
                            Setting up libssl1.1:amd64 (1.1.1n-0+deb10u6) ...
                            Setting up libtirpc-common (1.1.4-0.4+deb10u1) ...
                            Setting up unzip (6.0-23+deb10u3) ...
                            Setting up libsqlite3-0:amd64 (3.27.2-3+deb10u2) ...
                            Setting up libsasl2-modules:amd64 (2.1.27+dfsg-1+deb10u2) ...
                            Setting up rsyslog (8.1901.0-1+deb10u2) ...
                            Setting up libnghttp2-14:amd64 (1.36.0-2+deb10u2) ...
                            Setting up linux-libc-dev:amd64 (4.19.289-2) ...
                            Setting up libnss-systemd:amd64 (241-7~deb10u10) ...
                            Setting up krb5-locales (1.17-3+deb10u6) ...
                            Setting up bzip2 (1.0.6-9.2~deb10u2) ...
                            Setting up locales (2.28-10+deb10u2) ...
                            Generating locales (this might take a while)...
                              de_AT.UTF-8... done
                            Generation complete.
                            Setting up nodejs (18.19.0-1nodesource1) ...
                            Setting up libldap-common (2.4.47+dfsg-3+deb10u7) ...
                            Setting up libpython3.7-minimal:amd64 (3.7.3-2+deb10u6) ...
                            Setting up libwbclient0:amd64 (2:4.9.5+dfsg-5+deb10u4) ...
                            Setting up libicu63:amd64 (63.1-6+deb10u3) ...
                            Setting up xxd (2:8.1.0875-5+deb10u6) ...
                            Setting up libkrb5support0:amd64 (1.17-3+deb10u6) ...
                            Setting up libsasl2-modules-db:amd64 (2.1.27+dfsg-1+deb10u2) ...
                            Setting up tzdata (2021a-0+deb10u12) ...
                            Current default time zone: 'Europe/Vienna'
                            Local time is now:      Fri Dec 29 10:24:54 CET 2023.
                            Universal Time is now:  Fri Dec 29 09:24:54 UTC 2023.
                            Run 'dpkg-reconfigure tzdata' if you wish to change it.
                            Setting up libglib2.0-data (2.58.3-2+deb10u5) ...
                            Setting up libpython2.7-minimal:amd64 (2.7.16-2+deb10u3) ...
                            Setting up vim-common (2:8.1.0875-5+deb10u6) ...
                            Setting up libfreetype6:amd64 (2.9.1-3+deb10u3) ...
                            Setting up libx11-data (2:1.6.7-1+deb10u4) ...
                            Setting up python2.7-minimal (2.7.16-2+deb10u3) ...
                            Setting up libavahi-common-data:amd64 (0.7-4+deb10u3) ...
                            Setting up libncurses6:amd64 (6.1+20181013-2+deb10u5) ...
                            Setting up libdbus-1-3:amd64 (1.12.28-0+deb10u1) ...
                            Setting up dbus (1.12.28-0+deb10u1) ...
                            A reboot is required to replace the running dbus-daemon.
                            Please reboot the system when convenient.
                            Setting up xz-utils (5.2.4-1+deb10u1) ...
                            Setting up libfribidi0:amd64 (1.0.5-3.1+deb10u2) ...
                            Setting up udev (241-7~deb10u10) ...
                            update-initramfs: deferring update (trigger activated)
                            Setting up libwebp6:amd64 (0.6.1-2+deb10u3) ...
                            Setting up icu-devtools (63.1-6+deb10u3) ...
                            Setting up sudo (1.8.27-1+deb10u5) ...
                            Setting up libudev-dev:amd64 (241-7~deb10u10) ...
                            Setting up libpcre2-8-0:amd64 (10.32-5+deb10u1) ...
                            Setting up libk5crypto3:amd64 (1.17-3+deb10u6) ...
                            Setting up python3.7-minimal (3.7.3-2+deb10u6) ...
                            Setting up libdpkg-perl (1.19.8) ...
                            Setting up libsasl2-2:amd64 (2.1.27+dfsg-1+deb10u2) ...
                            Setting up python3-urllib3 (1.24.1-1+deb10u2) ...
                            Setting up libisc-export1100:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) ...
                            Setting up libgif7:amd64 (5.1.4-3+deb10u1) ...
                            Setting up libgif-dev (5.1.4-3+deb10u1) ...
                            Setting up libpam-systemd:amd64 (241-7~deb10u10) ...
                            Setting up git-man (1:2.20.1-2+deb10u8) ...
                            Setting up libx11-6:amd64 (2:1.6.7-1+deb10u4) ...
                            Setting up libssh2-1:amd64 (1.8.0-2.1+deb10u1) ...
                            Setting up isc-dhcp-common (4.4.1-2+deb10u3) ...
                            Setting up libkrb5-3:amd64 (1.17-3+deb10u6) ...
                            Setting up libtiff5:amd64 (4.1.0+git191117-2~deb10u8) ...
                            Setting up libc-dev-bin (2.28-10+deb10u2) ...
                            Setting up openssl (1.1.1n-0+deb10u6) ...
                            Setting up libelf1:amd64 (0.176-1.1+deb10u1) ...
                            Setting up libdns-export1104 (1:9.11.5.P4+dfsg-5.1+deb10u9) ...
                            Setting up publicsuffix (20220811.1734-0+deb10u1) ...
                            Setting up libxml2:amd64 (2.9.4+dfsg1-7+deb10u6) ...
                            Setting up python-ipaddress (1.0.17-1+deb10u1) ...
                            Setting up ncurses-term (6.1+20181013-2+deb10u5) ...
                            Setting up libglib2.0-dev-bin (2.58.3-2+deb10u5) ...
                            Setting up libpython3.7-stdlib:amd64 (3.7.3-2+deb10u6) ...
                            Setting up libfribidi-dev:amd64 (1.0.5-3.1+deb10u2) ...
                            Setting up cifs-utils (2:6.8-2+deb10u1) ...
                            Setting up python-cryptography (2.6.1-3+deb10u4) ...
                            Setting up libavahi-common3:amd64 (0.7-4+deb10u3) ...
                            Setting up libx11-dev:amd64 (2:1.6.7-1+deb10u4) ...
                            Setting up libglib2.0-bin (2.58.3-2+deb10u5) ...
                            Setting up isc-dhcp-client (4.4.1-2+deb10u3) ...
                            Setting up libldap-2.4-2:amd64 (2.4.47+dfsg-3+deb10u7) ...
                            Setting up libisc1100:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) ...
                            Setting up vim-tiny (2:8.1.0875-5+deb10u6) ...
                            Setting up dpkg-dev (1.19.8) ...
                            Setting up libpython2.7-stdlib:amd64 (2.7.16-2+deb10u3) ...
                            Setting up librsvg2-2:amd64 (2.44.10-2.1+deb10u3) ...
                            Setting up grub-common (2.06-3~deb10u4) ...
                            Installing new version of config file /etc/grub.d/00_header ...
                            Installing new version of config file /etc/grub.d/05_debian_theme ...
                            Installing new version of config file /etc/grub.d/10_linux ...
                            Installing new version of config file /etc/grub.d/20_linux_xen ...
                            Installing new version of config file /etc/grub.d/30_os-prober ...
                            Installing new version of config file /etc/grub.d/30_uefi-firmware ...
                            Installing new version of config file /etc/grub.d/41_custom ...
                            Setting up libdbus-1-dev:amd64 (1.12.28-0+deb10u1) ...
                            Setting up liblwres161:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) ...
                            Setting up python3-requests (2.21.0-1+deb10u1) ...
                            Setting up libgssapi-krb5-2:amd64 (1.17-3+deb10u6) ...
                            Setting up librsvg2-common:amd64 (2.44.10-2.1+deb10u3) ...
                            Setting up libavahi-common-dev:amd64 (0.7-4+deb10u3) ...
                            Setting up libisccc161:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) ...
                            Setting up libc6-dev:amd64 (2.28-10+deb10u2) ...
                            Setting up python3-reportbug (7.5.3~deb10u2) ...
                            Setting up gir1.2-rsvg-2.0:amd64 (2.44.10-2.1+deb10u3) ...
                            Setting up libicu-dev:amd64 (63.1-6+deb10u3) ...
                            Setting up libavahi-client3:amd64 (0.7-4+deb10u3) ...
                            Setting up libdns1104:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) ...
                            Setting up libtirpc3:amd64 (1.1.4-0.4+deb10u1) ...
                            Setting up python3.7 (3.7.3-2+deb10u6) ...
                            Setting up libpython2.7:amd64 (2.7.16-2+deb10u3) ...
                            Setting up python2.7 (2.7.16-2+deb10u3) ...
                            Setting up grub2-common (2.06-3~deb10u4) ...
                            Installing new version of config file /etc/kernel/postinst.d/zz-update-grub ...
                            Installing new version of config file /etc/kernel/postrm.d/zz-update-grub ...
                            Setting up openssh-client (1:7.9p1-10+deb10u4) ...
                            Setting up libcurl3-gnutls:amd64 (7.64.0-4+deb10u8) ...
                            Setting up libavahi-client-dev:amd64 (0.7-4+deb10u3) ...
                            Setting up reportbug (7.5.3~deb10u2) ...
                            Setting up libavahi-compat-libdnssd1:amd64 (0.7-4+deb10u3) ...
                            Setting up grub-pc-bin (2.06-3~deb10u4) ...
                            Setting up grub-pc (2.06-3~deb10u4) ...
                            Installing for i386-pc platform.
                            Installation finished. No error reported.
                            Generating grub configuration file ...
                            Found linux image: /boot/vmlinuz-4.19.0-18-amd64
                            Found initrd image: /boot/initrd.img-4.19.0-18-amd64
                            Found linux image: /boot/vmlinuz-4.19.0-17-amd64
                            Found initrd image: /boot/initrd.img-4.19.0-17-amd64
                            Warning: os-prober will be executed to detect other bootable partitions.
                            Its output will be used to detect bootable binaries on them and create new boot entries.
                            done
                            Setting up libexpat1-dev:amd64 (2.2.6-2+deb10u6) ...
                            Setting up git (1:2.20.1-2+deb10u8) ...
                            Setting up zlib1g-dev:amd64 (1:1.2.11.dfsg-1+deb10u2) ...
                            Setting up libisccfg163:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) ...
                            Setting up openssh-sftp-server (1:7.9p1-10+deb10u4) ...
                            Setting up libpython2.7-dev:amd64 (2.7.16-2+deb10u3) ...
                            Setting up openssh-server (1:7.9p1-10+deb10u4) ...
                            rescue-ssh.target is a disabled or a static unit, not starting it.
                            Setting up libavahi-compat-libdnssd-dev:amd64 (0.7-4+deb10u3) ...
                            Setting up libbind9-161:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u9) ...
                            Setting up libfreetype6-dev:amd64 (2.9.1-3+deb10u3) ...
                            Setting up libglib2.0-dev:amd64 (2.58.3-2+deb10u5) ...
                            Setting up librsvg2-dev:amd64 (2.44.10-2.1+deb10u3) ...
                            Setting up bind9-host (1:9.11.5.P4+dfsg-5.1+deb10u9) ...
                            Setting up python2.7-dev (2.7.16-2+deb10u3) ...
                            Processing triggers for libc-bin (2.28-10+deb10u2) ...
                            Processing triggers for systemd (241-7~deb10u10) ...
                            Processing triggers for libgdk-pixbuf2.0-0:amd64 (2.38.1+dfsg-1) ...
                            Processing triggers for mime-support (3.62) ...
                            Processing triggers for initramfs-tools (0.133+deb10u1) ...
                            update-initramfs: Generating /boot/initrd.img-4.19.0-18-amd64
                            v18.19.0 has been installed! You are using the latest version now!
                            W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                            W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                            Installing the recommended nodejs version!
                            *** You need to manually restart your container/virtual machine now! ***
                            We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
                            karl@IOBROKER:~$
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                                       Chassis: vm
                                Virtualization: kvm
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : amd64
                             10:27:51 up 45 min,  1 user,  load average: 0.09, 0.21, 0.09
                            CPU threads: 6
                            This system needs to be REBOOTED!
                                           Local time: Fri 2023-12-29 10:27:51 CET
                                       Universal time: Fri 2023-12-29 09:27:51 UTC
                                             RTC time: Fri 2023-12-29 09:27:52
                                          NTP service: active
                                      RTC in local TZ: no
                            karl
                            /home/karl
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:           5.5G        163M        3.8G        7.0M        1.5G        5.0G
                            Swap:          974M          0B        974M
                            Total:         6.4G        163M        4.8G
                                     5458 M total memory
                                      163 M used memory
                                      380 M active memory
                                      972 M inactive memory
                                     3795 M free memory
                                       17 M buffer memory
                                     1481 M swap cache
                                      974 M total swap
                                        0 M used swap
                                      974 M free swap
                              UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                            * iobroker.service loaded failed failed ioBroker Server
                            1 loaded units listed. Pass --all to see loaded but inactive units, too.
                            *** FILESYSTEM ***
                            /dev/sda1      ext4       19G  4.4G   14G  25% /
                            /var:
                            600M    /var/
                            410M    /var/cache
                            403M    /var/cache/apt
                            342M    /var/cache/apt/archives
                            172M    /var/lib
                            USB-Devices by-id:
                            /usr/bin/nodejs         v18.19.0
                            /usr/bin/node           v18.19.0
                            /usr/bin/npm            10.2.3
                            /usr/bin/npx            10.2.3
                            /usr/bin/corepack       0.22.0
                            nodejs:
                              Installed: 18.19.0-1nodesource1
                              Candidate: 18.19.0-1nodesource1
                              Version table:
                             *** 18.19.0-1nodesource1 1001
                                    500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                 18.18.2-1nodesource1 1001
                                 18.18.1-1nodesource1 1001
                                 18.18.0-1nodesource1 1001
                                 18.17.1-1nodesource1 1001
                                 18.17.0-1nodesource1 1001
                                 18.16.1-1nodesource1 1001
                                 18.16.0-1nodesource1 1001
                                 18.15.0-1nodesource1 1001
                                 18.14.2-1nodesource1 1001
                                 18.14.1-1nodesource1 1001
                                 18.14.0-1nodesource1 1001
                                 18.13.0-1nodesource1 1001
                                 18.12.0-1nodesource1 1001
                                 18.11.0-1nodesource1 1001
                                 18.10.0-1nodesource1 1001
                                 18.9.1-1nodesource1 1001
                                 18.9.0-1nodesource1 1001
                                 18.8.0-1nodesource1 1001
                                 18.7.0-1nodesource1 1001
                                 18.6.0-1nodesource1 1001
                                 18.5.0-1nodesource1 1001
                                 18.4.0-1nodesource1 1001
                                 18.3.0-1nodesource1 1001
                                 18.2.0-1nodesource1 1001
                                 18.1.0-1nodesource1 1001
                                 18.0.0-1nodesource1 1001
                            Errors in npm tree:
                            npm ERR! code ELSPROBLEMS
                            npm ERR! invalid: tough-cookie@2.5.0 /opt/iobroker/node_modules/tough-cookie
                            npm ERR! A complete log of this run can be found in: /home/karl/.npm/_logs/2023-12-29T09_27_54_481Z-debug-0.log
                            ioBroker Status
                            iobroker is not running on this host.
                            Objects type: file
                            States  type: file
                            admin:          5.1.23
                            javascript:     5.1.3
                            Adapters from github:   14
                            Adapter State
                            + instance is alive
                            • G GOETSCHHOFER
                              Schritt 1:
                              nodejs:
                                Version table:
                              Virtualization: kvm
                              Package: nodejs
                              Pin-Priority: 1001
                                de_AT.UTF-8... done
                              done
                              karl@IOBROKER:~$
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                                         Chassis: vm
                                  Virtualization: kvm
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : amd64
                              CPU threads: 6
                                            NTP service: active
                                        RTC in local TZ: no
                              karl
                              /home/karl
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:          974M          0B        974M
                                       5458 M total memory
                                        163 M used memory
                                        380 M active memory
                                       3795 M free memory
                                         17 M buffer memory
                                       1481 M swap cache
                                        974 M total swap
                                          0 M used swap
                                        974 M free swap
                              *** FILESYSTEM ***
                              /var:
                              600M    /var/
                              410M    /var/cache
                              403M    /var/cache/apt
                              172M    /var/lib
                              USB-Devices by-id:
                              /usr/bin/npm            10.2.3
                              /usr/bin/npx            10.2.3
                              nodejs:
                                Version table:
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: file
                              States  type: file
                              admin:          5.1.23
                              javascript:     5.1.3
                              Adapter State
                              + instance is alive
                              #80
                              Hast du das gemacht?
                                GOETSCHHOFER
                                #81
                                @thomas-braun said in Proxmox: Fehlermeldung bei backup - vzdump ?:
                                Ja, habe ich soeben gemacht ! 👍
                                • G GOETSCHHOFER
                                  GOETSCHHOFER
                                  #82
                                  @Thomas-Braun
                                  iob habe ich in proxmox rebootet.
                                  Beim Hochziehen des iob bekomme ich jetzt aber eine Fehlermeldung ?
                                  login as: karl
                                  karl@192.168.1.176's password:
                                  Linux IOBROKER 4.19.0-18-amd64 #1 SMP Debian 4.19.208-1 (2021-09-29) x86_64
                                  permitted by applicable law.
                                  Last login: Fri Dec 29 10:21:17 2023 from 192.168.1.3
                                  karl@IOBROKER:~$ iob stop
                                  karl@IOBROKER:~$ iob update
                                  • G GOETSCHHOFER
                                    @Thomas-Braun
                                    login as: karl
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    #83
                                    das ist ja dein ursprüngliche Problem
                                    https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1616096619995
                                    G 2 Antworten Letzte Antwort
                                      GOETSCHHOFER
                                      #84
                                      @crunchip
                                      Vorhin nach Eingabe iob diag kam gleich am Anfang auch so eine ähnliche Fehlermeldung mit cannot read system.config: null.
                                      The state system.host.IOBROKER.versions.nodeNewestNext was not found!
                                      The state system.host.IOBROKER.versions.npmNewestNext was not found!
                                        GOETSCHHOFER
                                        #85
                                        @crunchip said in Proxmox: Fehlermeldung bei backup - vzdump ?:
                                        karl@IOBROKER:~$ iobroker status
                                        Objects type: file
                                        States  type: file
                                        karl@IOBROKER:~$
                                        Objects type: file
                                        States  type: file
                                        karl@IOBROKER:~$ ^C
                                        karl@IOBROKER:~$ ls -lh /opt/iobroker/iobroker-data/backup-objects/ | grep objec        ts
                                        -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 24 00:00 2023-12-24_00-00_objects.json.        gz
                                        -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 24 09:25 2023-12-24_09-25_objects.json.        gz
                                        -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 24 12:55 2023-12-24_12-55_objects.json.        gz
                                        -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 25 00:00 2023-12-25_00-00_objects.json.        gz
                                        -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 25 12:55 2023-12-25_12-55_objects.json.        gz
                                        -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 26 00:00 2023-12-26_00-00_objects.json.        gz
                                        -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 26 12:55 2023-12-26_12-55_objects.json.        gz
                                        -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 27 00:00 2023-12-27_00-00_objects.json.        gz
                                        -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 27 07:56 2023-12-27_07-56_objects.json.        gz
                                        -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 27 12:55 2023-12-27_12-55_objects.json.        gz
                                        -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 28 00:00 2023-12-28_00-00_objects.json.        gz
                                        -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 28 07:17 2023-12-28_07-17_objects.json.        gz
                                        -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 28 10:33 2023-12-28_10-33_objects.json.        gz
                                        -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 28 12:55 2023-12-28_12-55_objects.json.        gz
                                        -rw-rwxr--+ 1 iobroker iobroker 3,8M Dez 29 07:38 2023-12-29_07-38_objects.json.        gz
                                        -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 07:53 2023-12-29_07-53_objects.json.        gz
                                        -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 08:01 2023-12-29_08-01_objects.json.        gz
                                        -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 08:54 2023-12-29_08-54_objects.json.        gz
                                        -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 09:05 2023-12-29_09-05_objects.json.        gz
                                        -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 09:38 2023-12-29_09-38_objects.json.        gz
                                        -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 09:42 2023-12-29_09-42_objects.json.        gz
                                        -rw-rwxr--+ 1 iobroker iobroker 3,4K Dez 29 09:43 2023-12-29_09-43_objects.json.        gz
                                        -rw-rw-r--+ 1 iobroker iobroker 3,6K Dez 29 11:53 2023-12-29_11-53_objects.json.        gz
                                        -rw-rw-r--+ 1 iobroker iobroker 3,6K Dez 29 11:58 2023-12-29_11-58_objects.json.        gz
                                        -rw-rw-r--+ 1 iobroker iobroker 3,6K Dez 29 12:02 2023-12-29_12-02_objects.json.        gz
                                        karl@IOBROKER:~$
                                        • G GOETSCHHOFER
                                          Objects type: file
                                          States  type: file
                                          karl@IOBROKER:~$
                                          Objects type: file
                                          States  type: file
                                          karl@IOBROKER:~$ ^C
                                          karl@IOBROKER:~$
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          #86
                                          hier hast du deinen Sprung
