  4. Zigbee Stick spinnt *gelöst*
    5.1k
78 Beiträge 8 Kommentatoren 8.2k Aufrufe 8 Beobachtet
  • G gluecksmann
    @frank579
    *** BASE SYSTEM ***
      Static hostname: raspberrypi
            Icon name: computer
     Operating System: Raspbian GNU/Linux 10 (buster)
               Kernel: Linux 5.10.103-v7l+
         Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
    17:33:54 up  3:22,  1 user,  load average: 0.68, 3.79, 4.41
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                  Local time: Thu 2023-12-28 17:33:54 CET
              Universal time: Thu 2023-12-28 16:33:54 UTC
                    RTC time: n/a
                 NTP service: active
             RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:           7.9G        1.6G        4.9G        8.0M        1.5G        6.1G
    Swap:           99M          0B         99M
    Total:         8.0G        1.6G        5.0G
            7898 M total memory
            1554 M used memory
             300 M active memory
            2506 M inactive memory
            4885 M free memory
             184 M buffer memory
            1273 M swap cache
              99 M total swap
               0 M used swap
              99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
     UNIT            LOAD   ACTIVE SUB    DESCRIPTION
    * lightdm.service loaded failed failed Light Display Manager
    1 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4       29G   14G   15G  50% /
    devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     3.9G  8.5M  3.9G   1% /run
    tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
    [Thu Dec 28 14:11:43 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:3D:9B:6E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Thu Dec 28 14:11:44 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Thu Dec 28 14:11:44 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Thu Dec 28 14:11:46 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    TARGET        SOURCE         FSTYPE OPTIONS
    /             /dev/mmcblk0p2 ext4   rw,noatime
    |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    413M    /var/
    118M    /var/lib
    102M    /var/cache
    91M     /var/log
    90M     /var/cache/apt
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    63M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    621M    /opt/iobroker/iobroker-data/
    322M    /opt/iobroker/iobroker-data/files
    143M    /opt/iobroker/iobroker-data/backup-objects
    93M     /opt/iobroker/iobroker-data/sonosCache
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    30M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    12M     /opt/iobroker/iobroker-data/objects.json.migrated
    USB-Devices by-id:
    /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3388-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
     Installed: 18.19.0-1nodesource1
     Candidate: 18.19.0-1nodesource1
     Version table:
    *** 18.19.0-1nodesource1 1001
           500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
        18.18.2-1nodesource1 1001
        18.18.1-1nodesource1 1001
        18.18.0-1nodesource1 1001
        18.17.1-1nodesource1 1001
        18.17.0-1nodesource1 1001
        18.16.1-1nodesource1 1001
        18.16.0-1nodesource1 1001
        18.15.0-1nodesource1 1001
        18.14.2-1nodesource1 1001
        18.14.1-1nodesource1 1001
        18.14.0-1nodesource1 1001
        18.13.0-1nodesource1 1001
        18.12.0-1nodesource1 1001
        18.11.0-1nodesource1 1001
        18.10.0-1nodesource1 1001
        18.9.1-1nodesource1 1001
        18.9.0-1nodesource1 1001
        18.8.0-1nodesource1 1001
        18.7.0-1nodesource1 1001
        18.6.0-1nodesource1 1001
        18.5.0-1nodesource1 1001
        18.4.0-1nodesource1 1001
        18.3.0-1nodesource1 1001
        18.2.0-1nodesource1 1001
        18.1.0-1nodesource1 1001
        18.0.0-1nodesource1 1001
        10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! invalid: iobroker.govee@0.0.5 /opt/iobroker/node_modules/iobroker.govee
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-28T16_34_03_703Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.0
    javascript:     7.1.6
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-28T16_34_25_768Z-debug-0.log
    Adapters from github:   1
    Adapter State
     system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
     system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              - disabled
    + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
     system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
     system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
     system.adapter.devices.0                : devices               : raspberrypi                              - disabled
     system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
    + system.adapter.govee.0                  : govee                 : raspberrypi                              -  enabled
    + system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi                              -  enabled
     system.adapter.history.0                : history               : raspberrypi                              - disabled
    + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
     system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
     system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
     system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
    + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
    + system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
    + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
    + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
    + system.adapter.philips-air.0            : philips-air           : raspberrypi                              -  enabled
    + system.adapter.philips-air.1            : philips-air           : raspberrypi                              -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
    + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
     system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              - disabled
    + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
     system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
     system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
     system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
     system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
     system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
     system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
     system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
     system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3388-if00
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "awtrix-light" : 0.10.0   , installed 0.10.0
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "ble"          : 0.13.4   , installed 0.13.4
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "fullybrowser" : 3.0.6    , installed 3.0.6
    Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
    Adapter    "hue"          : 3.10.1   , installed 3.10.1
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "meross"       : 1.15.1   , installed 1.15.1
    Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
    Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
    Adapter    "musiccast"    : 1.1.3    , installed 1.1.3
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "philips-air"  : 1.0.3    , installed 1.0.3
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-icontwo"  : 1.0.0    , installed 1.0.0
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "zigbee"       : 1.8.25   , installed 1.8.24 [Updatable]
    Objects and States
    Objects:        11296
    States:         9373
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18008      642/sshd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14831      363/cupsd
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       20705      999/io.sonoff.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       18400      632/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19317      632/iobroker.js-con
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       178386     15017/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       363390     9027/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          18010      642/sshd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14830      363/cupsd
    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       21820      980/io.sonos.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       19741      1036/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       19742      1036/io.tuya.0
    udp        0      0 0.0.0.0:37928           0.0.0.0:*                           1001       21652      911/io.philips-air.
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       21575      856/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18449      631/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16300      460/cups-browsed
    udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       24005      1320/io.musiccast.0
    udp        0      0 0.0.0.0:60062           0.0.0.0:*                           108        17435      356/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17433      356/avahi-daemon: r
    udp        0      0 0.0.0.0:48886           0.0.0.0:*                           1001       21952      1017/io.philips-air
    udp6       0      0 :::546                  :::*                                0          18466      631/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        17434      356/avahi-daemon: r
    udp6       0      0 :::39823                :::*                                108        17436      356/avahi-daemon: r
    2023-12-28 17:33:48.594  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.hepaFilterReplaceInHours" has to be type "number" but received type "string"
    2023-12-28 17:33:48.644  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.activeCarbonFilterReplaceInHours" has to be type "number" but received type "string"
    2023-12-28 17:33:52.420  - info: philips-air.0 (911) State value to set for "philips-air.0.control.lightBrightness" has to be type "number" but received type "string"
    2023-12-28 17:33:52.429  - info: philips-air.0 (911) State value to set for "philips-air.0.control.airQualityNotificationThreshold" has to be type "number" but received type "string"
    2023-12-28 17:33:52.481  - info: philips-air.0 (911) State value to set for "philips-air.0.status.allergenIndex" has to be type "number" but received type "string"
    2023-12-28 17:33:52.493  - info: philips-air.0 (911) State value to set for "philips-air.0.control.childLock" has to be type "boolean" but received type "string"
    2023-12-28 17:33:52.542  - info: philips-air.0 (911) State value to set for "philips-air.0.device.uptime" has to be type "number" but received type "string"
    2023-12-28 17:33:52.600  - info: philips-air.0 (911) State value to set for "philips-air.0.status.pm25" has to be type "number" but received type "string"
    2023-12-28 17:33:52.618  - info: philips-air.0 (911) State value to set for "philips-air.0.control.timerHours" has to be type "number" but received type "string"
    2023-12-28 17:33:52.625  - info: philips-air.0 (911) State value to set for "philips-air.0.status.timerMinutes" has to be type "number" but received type "string"
    2023-12-28 17:33:52.640  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.preFilterCleanInHours" has to be type "number" but received type "string"
    2023-12-28 17:33:52.695  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.hepaFilterReplaceInHours" has to be type "number" but received type "string"
    2023-12-28 17:33:52.701  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.activeCarbonFilterReplaceInHours" has to be type "number" but received type "string"
    2023-12-28 17:34:18.240  - error: philips-air.1 (1017) Error by sending: Error: No reply in 247 seconds.
    2023-12-28 17:34:24.323  - warn: sonoff.0 (999) Client [tasmota2] has invalid password or username
    2023-12-28 17:34:38.463  - warn: sonos.0 (980) State "sonos.0.root.192_168_2_145.queue_html" has no existing object, this might lead to an error in future versions
    2023-12-28 17:34:38.598  - warn: sonos.0 (980) State "sonos.0.root.192_168_2_145.queue_html" has no existing object, this might lead to an error in future versions
    2023-12-28 17:34:48.242  - error: philips-air.1 (1017) Error by sending: Error: No reply in 247 seconds.
    2023-12-28 17:35:00.048  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 303
    2023-12-28 17:35:04.662  - info: dwd.0 (303) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
    2023-12-28 17:35:05.205  - info: web.0 (9027) ==> Connected system.user.admin from ::ffff:192.168.2.148
    2023-12-28 17:35:07.075  - info: dwd.0 (303) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-12-28 17:35:07.617  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-12-28 17:35:15.042  - info: web.0 (9027) ==> Connected system.user.admin from ::ffff:192.168.2.148
    2023-12-28 17:35:18.242  - error: philips-air.1 (1017) Error by sending: Error: No reply in 247 seconds.
    @gluecksmann
    iobroker.govee
    nochmal installieren.
    R G 3 Antworten Letzte Antwort
      @gluecksmann
      iobroker.govee
      reutli
      @gluecksmann
      reboot gemacht?
      debug modus im Adapter aktiviert?
      Adapter neu gestartet?
      Wenn ja: zeigen
      Wenn nein: machen und dann zeigen
      Sonst kann hier wahrscheinlich keiner mehr weiter helfen...
      iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
      *Wer freundlich ist, dem wird freundlich geholfen *
      G 1 Antwort Letzte Antwort
        @gluecksmann
        iobroker.govee
        gluecksmann
        der ist aktuell nicht das Problem...glaub den werfe ich erst mal raus...
        • R reutli
          @gluecksmann
          reboot gemacht?
          Wenn ja: zeigen
          gluecksmann
          #66
          @reutli
          Reboot und Adapter neu starten kann ich... Debug Modus ist wo?
          F 1 Antwort Letzte Antwort
          • G gluecksmann
            @reutli
            Frank579
            #67
            @gluecksmann
            @gluecksmann sagte in Zigbee Stick spinnt:
            Debug Modus ist wo?
            Auf dem IOBroker im Expertenmodus auf Instanzen Zigbee aufklappen
            mit Bleistift umstellen
            Dann mal den ganzen Start aus dem log
            • F Frank579
              @gluecksmann
              Debug Modus ist wo?
              gluecksmann
              #68
              @frank579
              Hallo, habe den Adapter neu gestartet...jetzt läuft es wieder... komisch...
              F R 2 Antworten Letzte Antwort
                @gluecksmann
                iobroker.govee
                gluecksmann
                #69
                Da wir gerade so plaudern... welchen Zigbee Stick könnt Ihr empfehlen? Gibt da ja den Sonoff ZBDongle ...aber den wohl mit zwei verschiedenen Chipsätzen..
                • G gluecksmann
                  @frank579
                  Frank579
                  #70
                  @gluecksmann Okay dann bleib trotzdem erst mal auf der Version, bis es was neues gibt :)
                  @thomas-braun sagte in Zigbee Stick spinnt:
                  @gluecksmann
                  iobroker.govee
                  Hast du das gemacht einfach nochmal drüber, das alles sauber ist, dann sollte bei iob diag auch nichts auffällige mehr sein ...
                  • F Frank579
                    @gluecksmann
                    iobroker.govee
                    gluecksmann
                    #71
                    @frank579
                    Traue mich das kaum... jetzt wo es so schön läuft..
                    • G gluecksmann
                      Frank579
                      #72
                      @gluecksmann
                      Ich hab Hier den von @dimaiv aber als LAN Version. und super Zufrieden, klarer Vorteil ist der LAN Anschluss, muss also nicht im Netzwerkschrank liegen, Liegt bei mir im Büro (zentral) auf dem Schrank
                      • G gluecksmann
                        @frank579
                        Frank579
                        #73
                        doch mach das, nicht das dich das irgendwann einholt ...
                        • F Frank579
                          gluecksmann
                          #74
                          @frank579
                          Den Adapter gibt es scheinbar nicht mehr... macht erst mal auch nix... bin zufrieden das alles wieder läuft...muss aber mal echt über eine Neuinstallation nachdenken
                          • G gluecksmann
                            @frank579
                            #75
                            @gluecksmann sagte in Zigbee Stick spinnt *gelöst*:
                            Doch, aus dem github.
                            Das ist auch der Grund, warum der als invalid angezeigt wird.
                            Also nochmal in aktueller Version aus dem github fischen.
                              gluecksmann
                              #76
                              Da finde ich nur govee Local... da erschließt sich mir aber die Funktion, bzw. Inbetriebnahme nicht...aber wie gesagt...nicht schlimm
                              • G gluecksmann
                                #77
                                @gluecksmann
                                https://github.com/nbuenger/ioBroker.govee
                                • G gluecksmann
                                  @frank579
                                  reutli
                                  schrieb am zuletzt editiert von reutli
                                  #78
                                  Edit:
                                  war quatsch.
