  4. lametric Adapter müllt Protokoll voll
18 Beiträge 4 Kommentatoren 1.8k Aufrufe 4 Beobachtet
    Meckii
    So nochmal mit dem lametric adapter im debug-modus (hab heute Morgen erst rausgefunden wie das geht)
    2023-12-27 07:38:02.267 - info: host.iobroker stopInstance system.adapter.lametric.0 (force=false, process=true)
    2023-12-27 07:38:02.282 - info: lametric.0 (1109) Got terminate signal TERMINATE_YOURSELF
    2023-12-27 07:38:02.289 - debug: lametric.0 (1109) clearing refresh state timeout
    2023-12-27 07:38:02.291 - debug: lametric.0 (1109) clearing refresh app timeout
    2023-12-27 07:38:02.295 - info: lametric.0 (1109) terminating
    2023-12-27 07:38:02.299 - debug: lametric.0 (1109) Plugin sentry destroyed
    2023-12-27 07:38:02.304 - info: lametric.0 (1109) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-12-27 07:38:02.347 - info: host.iobroker stopInstance system.adapter.lametric.0 send kill signal
    2023-12-27 07:38:02.808 - info: lametric.0 (1109) terminating
    2023-12-27 07:38:02.904 - info: host.iobroker instance system.adapter.lametric.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-12-27 07:38:05.467 - info: host.iobroker instance system.adapter.lametric.0 started with pid 1125
    2023-12-27 07:38:08.899 - debug: lametric.0 (1125) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2023-12-27 07:38:08.969 - debug: lametric.0 (1125) Objects client ready ... initialize now
    2023-12-27 07:38:08.974 - debug: lametric.0 (1125) Objects create System PubSub Client
    2023-12-27 07:38:08.977 - debug: lametric.0 (1125) Objects create User PubSub Client
    2023-12-27 07:38:09.020 - debug: lametric.0 (1125) Objects client initialize lua scripts
    2023-12-27 07:38:09.036 - debug: lametric.0 (1125) Objects connected to redis: 127.0.0.1:9001
    2023-12-27 07:38:09.075 - debug: lametric.0 (1125) Redis States: Use Redis connection: 127.0.0.1:9000
    2023-12-27 07:38:09.092 - debug: lametric.0 (1125) States create System PubSub Client
    2023-12-27 07:38:09.094 - debug: lametric.0 (1125) States create User PubSub Client
    2023-12-27 07:38:09.153 - debug: lametric.0 (1125) States connected to redis: 127.0.0.1:9000
    2023-12-27 07:38:09.224 - debug: lametric.0 (1125) Plugin sentry Initialize Plugin (enabled=true)
    2023-12-27 07:38:10.537 - info: lametric.0 (1125) starting. Version 3.1.1 in /opt/iobroker/node_modules/iobroker.lametric, node: v18.18.2, js-controller: 5.0.16
    2023-12-27 07:38:10.620 - info: lametric.0 (1125) Starting - connecting to http://192.168.7.45:8080
    2023-12-27 07:38:10.624 - debug: lametric.0 (1125) re-creating refresh state timeout
    2023-12-27 07:38:10.629 - debug: lametric.0 (1125) sending "GET" request to "/api/v2/device" with http on port 8080 without data
    2023-12-27 07:38:10.818 - debug: lametric.0 (1125) received 200 response from "http://192.168.7.45:8080/api/v2/device" with content: {"audio":{"available":true,"volume":46,"volume_limit":{"max":100,"min":0},"volume_range":{"max":100,"min":0}},"bluetooth":{"active":false,"address":"14:F5:F9:31:C3:63","available":true,"discoverable":true,"mac":"14:F5:F9:31:C3:63","name":"LM3161","pairable":false},"display":{"brightness":100,"brightness_limit":{"max":100,"min":2},"brightness_mode":"auto","brightness_range":{"max":100,"min":0},"height":8,"on":true,"screensaver":{"enabled":true,"modes":{"time_based":{"enabled":false},"when_dark":{"enabled":true}},"widget":"1_com.lametric.clock"},"type":"mixed","width":37},"id":"62745","mode":"auto","model":"sa8","name":"TIME","os_version":"3.0.21","serial_number":"SA830100316100W00BP9","wifi":{"active":true,"address":"14:F5:F9:30:B4:F3","available":true,"encryption":"WPA","essid":"Laubhaufen","ip":"192.168.7.45","mode":"dhcp","netmask":"255.255.255.0","strength":100}}
    2023-12-27 07:38:10.848 - debug: lametric.0 (1125) API is online
    2023-12-27 07:38:10.856 - debug: lametric.0 (1125) [apps] re-creating refresh timeout
    2023-12-27 07:38:10.857 - debug: lametric.0 (1125) sending "GET" request to "/api/v2/device/apps" with http on port 8080 without data
    2023-12-27 07:38:10.906 - debug: lametric.0 (1125) received 200 response from "http://192.168.7.45:8080/api/v2/device/apps" with content: {"com.lametric.clock":{"actions":{"clock.alarm":{"enabled":{"data_type":"bool","name":"enabled","required":false},"time":{"data_type":"string","format":"[0-9]{2}:[0-9]{2}(?::[0-9]{2})?","name":"time","required":false},"wake_with_radio":{"data_type":"bool","name":"wake_with_radio","required":false}},"clock.clockface":{"icon":{"data_type":"string","name":"icon","required":false},"type":{"data_type":"string","format":"weather|page_a_day|custom|none","name":"type","required":false}},"settings.dateFormats":{}},"package":"com.lametric.clock","title":"Clock","triggers":{"alarm":{"snooze":{"data_type":"bool","name":"snooze"}}},"vendor":"LaMetric","version":"2.8.3","version_code":"44","widgets":{"1_com.lametric.clock":{"index":0,"package":"com.lametric.clock","settings":{"_title":"Uhr"},"visible":false}}},"com.lametric.countdown":{"actions":{"countdown.configure":{"duration":{"data_type":"int","name":"duration","required":false},"start_now":{"data_type":"bool","name":"start_now","required":false}},"countdown.pause":{},"countdown.reset":{},"countdown.start":{}},"package":"com.lametric.countdown","title":"Timer","triggers":{"finished":{"duration":{"data_type":"int","name":"duration"}},"paused":{"duration":{"data_type":"int","name":"duration"}},"reset":{"duration":{"data_type":"int","name":"duration"}},"resumed":{"duration":{"data_type":"int","name":"duration"}},"started":{"duration":{"data_type":"int","name":"duration"}}},"vendor":"LaMetric","version":"1.2.1","version_code":"19","widgets":{"6_com.lametric.countdown":{"index":6,"package":"com.lametric.countdown","settings":{"_title":"Timer"},"visible":false}}},"com.lametric.custommessage":{"package":"com.lametric.custommessage","title":"Message Board","triggers":{},"vendor":"LaMetric","version":"1.2.8","version_code":"28","widgets":{"3_com.lametric.custommessage":{"index":3,"package":"com.lametric.custommessage","settings":{"_title":"Message Board"},"visible":false}}},"com.lametric.diy.devwidget":{"actions":{"status":{}},"package":"com.lametric.diy.devwidget","title":"My Data DIY","triggers":{},"vendor":"LaMetric","version":"2.0.2","version_code":"48","widgets":{"xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx":{"index":2,"package":"com.lametric.diy.devwidget","settings":{"_title":"My Data DIY"},"visible":false}}},"com.lametric.radio":{"actions":{"radio.next":{},"radio.play":{},"radio.play.at":{"idx":{"data_type":"int","name":"idx","required":false}},"radio.prev":{},"radio.state":{},"radio.stop":{}},"package":"com.lametric.radio","title":"Radio","triggers":{},"vendor":"LaMetric","version":"1.4.20","version_code":"74","widgets":{"4_com.lametric.radio":{"index":4,"package":"com.lametric.radio","settings":{"_title":"Radio"},"visible":false}}},"com.lametric.stopwatch":{"actions":{"stopwatch.pause":{},"stopwatch.reset":{},"stopwatch.start":{}},"package":"com.lametric.stopwatch","title":"Stopwatch","triggers":{},"vendor":"LaMetric","version":"1.2.0","version_code":"16","widgets":{"5_com.lametric.stopwatch":{"index":5,"package":"com.lametric.stopwatch","settings":{"_title":"Stopwatch"},"visible":false}}},"com.lametric.weather":{"actions":{"weather.forecast":{},"weather.get.cc":{},"weather.setProduct":{}},"package":"com.lametric.weather","title":"Weather","triggers":{},"vendor":"LaMetric","version":"1.2.2","version_code":"32","widgets":{"2_com.lametric.weather":{"index":1,"package":"com.lametric.weather","settings":{"_title":"Wetter"},"visible":true}}}}
    2023-12-27 07:38:10.933 - debug: lametric.0 (1125) [apps] found (keep): apps.1_com_lametric.clock
    2023-12-27 07:38:11.044 - debug: lametric.0 (1125) [apps] found (keep): apps.6_com_lametric.countdown
    2023-12-27 07:38:11.099 - debug: lametric.0 (1125) [apps] found (keep): apps.3_com_lametric.custommessage
    2023-12-27 07:38:11.144 - debug: lametric.0 (1125) [apps] found (keep): apps.xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    2023-12-27 07:38:11.145 - debug: lametric.0 (1125) [mydatadiy] found app widget with uuid "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
    2023-12-27 07:38:11.279 - debug: lametric.0 (1125) [apps] found (keep): apps.4_com_lametric.radio
    2023-12-27 07:38:11.343 - debug: lametric.0 (1125) [apps] found (keep): apps.5_com_lametric.stopwatch
    2023-12-27 07:38:11.394 - debug: lametric.0 (1125) [apps] found (keep): apps.2_com_lametric.weather
    2023-12-27 07:38:11.504 - warn: lametric.0 (1125) (device) Unable to execute action: TypeError: Cannot read properties of undefined (reading 'active')
    2023-12-27 07:38:11.507 - debug: lametric.0 (1125) [mydatadiy] collecting states
    2023-12-27 07:38:11.508 - debug: lametric.0 (1125) [mydatadiy] found 0 dynamic states: []
    2023-12-27 07:38:11.510 - debug: lametric.0 (1125) [mydatadiy] found foreign states: []
    2023-12-27 07:38:11.511 - debug: lametric.0 (1125) [mydatadiy] refresh output state with config: [{"icon":"3983","text":"Meckii","hideif":"","duration":5},{"icon":"2867","text":"Lina","hideif":"","duration":5},{"icon":"7756","text":"Paul","hideif":"","duration":5}]
    2023-12-27 07:38:11.513 - debug: lametric.0 (1125) [mydatadiy] completed - frame update to [{"text":"Meckii","duration":5000,"icon":"3983"},{"text":"Lina","duration":5000,"icon":"2867"},{"text":"Paul","duration":5000,"icon":"7756"}]
    2023-12-27 07:38:11.541 - debug: lametric.0 (1125) [mydatadiy] pusing changes to device - app xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    2023-12-27 07:38:11.543 - debug: lametric.0 (1125) sending "POST" request to "/api/v2/widget/update/com.lametric.diy.devwidget/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" with http on port 8080 with data: {"frames":[{"text":"Meckii","duration":5000,"icon":"3983"},{"text":"Lina","duration":5000,"icon":"2867"},{"text":"Paul","duration":5000,"icon":"7756"}]}
    2023-12-27 07:38:11.720 - debug: lametric.0 (1125) API is offline
    2023-12-27 07:38:11.750 - debug: lametric.0 (1125) received 200 response from "http://192.168.7.45:8080/api/v2/widget/update/com.lametric.diy.devwidget/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" with content: ""
    • M Meckii
      @meckii
      Warum zieht die Kiste denn hier eine alte nodejs ran?
        @meckii
        Meckii
        schrieb am zuletzt editiert von Meckii
        Oh das kann sein.
        Ich glaube ich habe bei dier vielen Rumprobiererrei den Log mit einem anderen Raspberry mit einem 32bit system gemacht. Ich wollte das 32/64 Bit ausschließen...
        Also das war dann Bullseye 32bit das erste Bookworm 64bit...
          Meckii
          Inzwischen gibt es einen issue bei github...
          https://github.com/klein0r/ioBroker.lametric/issues/169
          • M Meckii
            haus-automatisierungH Offline
            @meckii Danke, ist gelöst ab 3.1.2 - lag daran, dass die 2022er Modelle über die API scheinbar kein bluetooth low energy status ausliefern. Bitte schauen, ob Du die aktuellste Firmware 3.0.21 installiert hast (gibts erst ein paar Tage). Da sind wohl auch einige Bugfixes enthalten.
            📚 Meine Dokumentation
              Meckii
              @haus-automatisierung
              Die Version 3.0.21 gibt es schon und wurde bereits am 24.12.23 installiert.
              (Habe die Lametric von meiner Frau bekommen)
              Vielen Dank den lametric Adapter habe ich bereits über github installiert - beim starten wird er nun grün und der Fehler ist weg...
              • M Meckii
                @meckii Bitte nie über GitHub installieren. Lieber über npm wenn Du die letzte klar definiere Version haben möchtest.
                  Meckii
                  Da war der Adapter in der heute von dir angepassten Version aber noch nicht verfügber...Screenshot 2023-12-27 145800.png
                  • M Meckii
                    @meckii Klar, der liegt seit heute morgen auf npm
                      Meckii
                      Habe es jetzt wieder aus npm installiert - vielen Dank fürs fixen und die Tipps!
