  4. [gelöst] Hilfe, IoBroker startet nach reboot nicht mehr
34 Beiträge 5 Kommentatoren 2.5k Aufrufe 5 Beobachtet
    @christophh sagte in Hilfe, IoBroker startet nach reboot nicht mehr:
    SUMMARY
    bitte die Langfassung
    ChristophH
    Gerne:
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: nas
             Icon name: computer-desktop
               Chassis: desktop
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.0-0.deb11.13-amd64
          Architecture: x86-64
    model name      : AMD Ryzen 7 5700G with Radeon Graphics
    Docker          : false
    Virtualization  : none
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     13:31:23 up 22:04,  1 user,  load average: 0.24, 0.16, 0.11
    CPU threads: 16
    *** Time and Time Zones ***
                   Local time: Mon 2023-12-25 13:31:23 CET
               Universal time: Mon 2023-12-25 12:31:23 UTC
                     RTC time: Mon 2023-12-25 12:31:23
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    christoph
    /srv/dev-disk-by-uuid-0cff48bc-8d9b-4ea1-87b6-cb420a6194c0/christoph
    users root daemon bin sys mail man sudo backup src input crontab ssh clamav qbittorrent-nox openmediavault-notify openmediavault-webgui openmediavault-admin openmediavault-engined openmediavault-config iobroker christoph nogroup
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:             27G        1.0G        224M        4.0M         26G         26G
    Swap:           975M         11M        964M
    Total:           28G        1.0G        1.2G
            27946 M total memory
             1004 M used memory
             1652 M active memory
            24349 M inactive memory
              223 M free memory
              663 M buffer memory
            26055 M swap cache
              975 M total swap
               11 M used swap
              964 M free swap
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs   14G     0   14G   0% /dev
    tmpfs          tmpfs     2.8G  1.1M  2.8G   1% /run
    /dev/sdb2      ext4       28G  7.7G   19G  29% /
    tmpfs          tmpfs      14G     0   14G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs      14G     0   14G   0% /tmp
    /dev/sda1      ext4       13T  1.4T   12T  11% /export/AllesTorrents
    /dev/sdb1      vfat      511M  152K  511M   1% /boot/efi
    /dev/md0       btrfs      22T   17T  5.4T  76% /export/AllesNAS
    /dev/md0       btrfs      22T   17T  5.4T  76% /export/Filme
    [sudo] password for christoph:
    [Sun Dec 24 15:26:42 2023] EXT4-fs (sdb2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Dec 24 15:26:42 2023] EXT4-fs (sdb2): re-mounted. Quota mode: none.
    [Sun Dec 24 15:26:43 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: journalled.
    TARGET                    SOURCE                               FSTYPE OPTIONS
    /                         /dev/sdb2                            ext4   rw,relatime,errors=remount-ro
    |-/srv/dev-disk-by-uuid-0cff48bc-8d9b-4ea1-87b6-cb420a6194c0
    |                         /dev/sda1                            ext4   rw,relatime,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
    |-/export/AllesTorrents   /dev/sda1                            ext4   rw,relatime,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
    |-/boot/efi               /dev/sdb1                            vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,er
    |-/export/AllesNAS        /dev/md0                             btrfs  rw,relatime,space_cache,subvolid=5,subvol=/
    |-/srv/dev-disk-by-uuid-21c83eb5-90ea-43e1-a71b-a31d1e29b79a
    |-/export/Filme           /dev/md0[/NAS/Medien/Filme]          btrfs  rw,relatime,space_cache,subvolid=257,subvol=/NAS
    |-/export/Filmsammlungen  /dev/md0[/NAS/Medien/Filmsammlungen] btrfs  rw,relatime,space_cache,subvolid=257,subvol=/NAS
    |-/export/Serien          /dev/md0[/NAS/Medien/Serien]         btrfs  rw,relatime,space_cache,subvolid=257,subvol=/NAS
    `-/export/Weihnachtsfilme /dev/md0[/NAS/Medien/Weihnachtsfilme]
    /var:
    1.9G    /var/
    1.5G    /var/log
    1.4G    /var/log/journal/104e3bac8cdd4bebbd38c61f89b56acb
    259M    /var/cache
    Archived and active journals take up 112.0M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    529M    /opt/iobroker/iobroker-data/
    275M    /opt/iobroker/iobroker-data/files
    104M    /opt/iobroker/iobroker-data/node-red
    91M     /opt/iobroker/iobroker-data/node-red/node_modules
    84M     /opt/iobroker/iobroker-data/backup-objects
    51M     /opt/iobroker/iobroker-data/objects.jsonl
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    17M     /opt/iobroker/iobroker-data/states.jsonl
    11M     /opt/iobroker/iobroker-data/node-red/paramsets.json
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.18.2-1nodesource1 500
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
         12.22.12~dfsg-1~deb11u4 500
            500 http://ftp.de.debian.org/debian bullseye/main amd64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Core adapters versions
    js-controller:
    admin:
    javascript:
    Adapters from github:   1
    Adapter State
    ioBroker-Repositories
    Installed ioBroker-Instances
    Objects and States
    Objects:        0
    States:         0
    Get:1 file:/var/cache/openmediavault/archives  InRelease
    Ign:1 file:/var/cache/openmediavault/archives  InRelease
    Get:2 file:/var/cache/openmediavault/archives  Release
    Ign:2 file:/var/cache/openmediavault/archives  Release
    Get:3 file:/var/cache/openmediavault/archives  Packages
    Ign:3 file:/var/cache/openmediavault/archives  Packages
    Get:4 file:/var/cache/openmediavault/archives  Translation-de
    Ign:4 file:/var/cache/openmediavault/archives  Translation-de
    Get:5 file:/var/cache/openmediavault/archives  Translation-en
    Ign:5 file:/var/cache/openmediavault/archives  Translation-en
    Get:6 file:/var/cache/openmediavault/archives  Translation-de_DE
    Ign:6 file:/var/cache/openmediavault/archives  Translation-de_DE
    Hit:7 http://packages.openmediavault.org/public shaitan InRelease
    Hit:8 http://httpredir.debian.org/debian bullseye-backports InRelease
    Hit:9 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:10 http://ftp.de.debian.org/debian bullseye InRelease
    Hit:11 http://ftp.de.debian.org/debian bullseye-updates InRelease
    Hit:12 https://openmediavault.github.io/packages shaitan InRelease
    Hit:13 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists... Done
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          20438      1/init
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          18690      3385/nginx: master
    tcp        0      0 0.0.0.0:23              0.0.0.0:*               LISTEN      0          28466      3522/inetd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          31109      3375/sshd: /usr/sbi
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      114        28389      3363/mosquitto
    tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          17714      -
    tcp        0      0 0.0.0.0:35339           0.0.0.0:*               LISTEN      0          17734      -
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        32199      3257/systemd-resolv
    tcp        0      0 192.168.178.7:51000     0.0.0.0:*               LISTEN      113        31469      3381/qbittorrent-no
    tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      102        32193      3257/systemd-resolv
    tcp        0      0 0.0.0.0:56327           0.0.0.0:*               LISTEN      110        28358      3364/rpc.statd
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          15707      3685/master
    tcp        0      0 127.0.0.1:51000         0.0.0.0:*               LISTEN      113        23960      3381/qbittorrent-no
    tcp        0      0 0.0.0.0:45189           0.0.0.0:*               LISTEN      0          16886      3365/rpc.mountd
    tcp6       0      0 :::111                  :::*                    LISTEN      0          20441      1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          31111      3375/sshd: /usr/sbi
    tcp6       0      0 :::1883                 :::*                    LISTEN      114        28390      3363/mosquitto
    tcp6       0      0 :::2049                 :::*                    LISTEN      0          17725      -
    tcp6       0      0 :::54121                :::*                    LISTEN      0          16890      3365/rpc.mountd
    tcp6       0      0 :::5355                 :::*                    LISTEN      102        32196      3257/systemd-resolv
    tcp6       0      0 :::38463                :::*                    LISTEN      0          17736      -
    tcp6       0      0 :::8282                 :::*                    LISTEN      113        31121      3381/qbittorrent-no
    tcp6       0      0 ::1:51000               :::*                    LISTEN      113        23963      3381/qbittorrent-no
    tcp6       0      0 :::46167                :::*                    LISTEN      110        28362      3364/rpc.statd
    udp        0      0 0.0.0.0:59046           0.0.0.0:*                           0          16884      3365/rpc.mountd
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        32198      3257/systemd-resolv
    udp        0      0 192.168.178.7:68        0.0.0.0:*                           101        22202      496/systemd-network
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          16601      1/init
    udp        0      0 127.0.0.1:323           0.0.0.0:*                           0          15579      3367/chronyd
    udp        0      0 127.0.0.1:996           0.0.0.0:*                           0          28347      3364/rpc.statd
    udp        0      0 0.0.0.0:50747           0.0.0.0:*                           110        28356      3364/rpc.statd
    udp        0    768 192.168.178.7:51000     0.0.0.0:*                           113        31470      3381/qbittorrent-no
    udp        0      0 127.0.0.1:51000         0.0.0.0:*                           113        23961      3381/qbittorrent-no
    udp        0      0 0.0.0.0:2049            0.0.0.0:*                           0          17724      -
    udp        0      0 0.0.0.0:36420           0.0.0.0:*                           111        22916      3265/avahi-daemon:
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           111        22914      3265/avahi-daemon:
    udp        0      0 0.0.0.0:5355            0.0.0.0:*                           102        32192      3257/systemd-resolv
    udp        0      0 0.0.0.0:40391           0.0.0.0:*                           0          17733      -
    udp6       0      0 :::45101                :::*                                0          16888      3365/rpc.mountd
    udp6       0      0 :::111                  :::*                                0          20919      1/init
    udp6       0      0 ::1:323                 :::*                                0          15580      3367/chronyd
    udp6       0      0 ::1:51000               :::*                                113        23964      3381/qbittorrent-no
    udp6       0      0 :::2049                 :::*                                0          17726      -
    udp6       0      0 :::53917                :::*                                0          17735      -
    udp6       0      0 :::5353                 :::*                                111        22915      3265/avahi-daemon:
    udp6       0      0 :::5355                 :::*                                102        32195      3257/systemd-resolv
    udp6       0      0 :::38581                :::*                                110        28360      3364/rpc.statd
    udp6       0      0 :::57184                :::*                                111        22917      3265/avahi-daemon:
    2023-12-24 15:10:09.001  - info: host.nas stopInstance system.adapter.scenes.0 killing pid 921151
    2023-12-24 15:10:09.001  - info: host.nas stopInstance system.adapter.hm-rpc.0 killing pid 175368
    2023-12-24 15:10:09.001  - info: host.nas stopInstance system.adapter.mqtt.0 killing pid 921495
    2023-12-24 15:10:09.001  - info: host.nas stopInstance system.adapter.tr-064.0 killing pid 921521
    2023-12-24 15:10:09.001  - info: host.nas stopInstance system.adapter.discovery.0 killing pid 921575
    2023-12-24 15:10:09.001  - info: host.nas stopInstance system.adapter.fritzdect.0 killing pid 2339124
    2023-12-24 15:10:09.001  - info: host.nas stopInstance system.adapter.bwt.0 killing pid 922427
    2023-12-24 15:10:09.001  - info: host.nas stopInstance system.adapter.parser.0 killing pid 922477
    2023-12-24 15:10:09.001  - info: host.nas stopInstance system.adapter.vis-inventwo.0 killing pid 922628
    2023-12-24 15:10:09.058  - info: host.nas instance system.adapter.hm-rega.0 terminated with code 0 (NO_ERROR)
    2023-12-24 15:10:09.058  - info: host.nas instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
    2023-12-24 15:10:09.163  - info: host.nas instance system.adapter.email.0 terminated with code 0 (NO_ERROR)
    2023-12-24 15:10:09.163  - info: host.nas instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
    2023-12-24 15:10:09.163  - info: host.nas instance system.adapter.bwt.0 terminated with code 0 (NO_ERROR)
    2023-12-24 15:10:09.163  - warn: host.nas instance system.adapter.parser.0 terminated due to SIGTERM
    2023-12-24 15:10:09.163  - info: host.nas instance system.adapter.parser.0 terminated with code null ()
    2023-12-24 15:10:09.191  - info: host.nas instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
    2023-12-24 15:10:09.345  - info: host.nas instance system.adapter.scenes.0 terminated with code 0 (NO_ERROR)
    2023-12-24 15:10:09.345  - info: host.nas instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
    2023-12-24 15:10:09.345  - info: host.nas instance system.adapter.vis-inventwo.0 terminated with code 0 (NO_ERROR)
    2023-12-24 15:10:09.345  - info: host.nas instance system.adapter.fritzdect.0 terminated with code 0 (NO_ERROR)
    2023-12-24 15:10:09.345  - info: host.nas instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
    2023-12-24 15:10:09.422  - info: host.nas instance system.adapter.node-red.0 terminated with code 0 (NO_ERROR)
    2023-12-24 15:10:09.422  - info: host.nas All instances are stopped.
    2023-12-24 15:10:09.569  - info: host.nas terminated
    • C Offline
      ChristophH
      Nur kurz zur Info:
      Wir haben für heute Nachmittag Karten für den Zirkus Flic Flac und müssen gleich los.
      Ich melde mich dann nachher wieder, wenn wir wieder da sind.
      • C ChristophH
        Gerne:
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                   Chassis: desktop
        Docker          : false
        Kernel          : x86_64
        Userland        : amd64
        CPU threads: 16
                      NTP service: active
                  RTC in local TZ: no
        christoph
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Swap:           975M         11M        964M
                 1004 M used memory
                  223 M free memory
                  663 M buffer memory
                26055 M swap cache
                  975 M total swap
                   11 M used swap
                  964 M free swap
        *** FILESYSTEM ***
        /var:
        1.9G    /var/
        1.5G    /var/log
        259M    /var/cache
        USB-Devices by-id:
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        js-controller:
        admin:
        javascript:
        Adapter State
        Objects and States
        Objects:        0
        States:         0
        Pending Updates: 0
        @christophh da ist nix von iobroker zu sehen 🤔
        C 1 Antwort Letzte Antwort
        • C ChristophH
          Vor über 10 Minuten gestartet, gerade eben abgebrochen, da sich nichts tat und die Status-Abfrage in einem zweiten Terminalfenster immer noch dead anzeigte.
          @ESP8266
          Ich hatte Thomas Braun noch nicht geantwortet, weil der Startversuch bis eben gerade lief und dann von mir abgebrochen wurde, da sich nichts tat.
          Das Netzteil ist ein Seasonic Focus GX 750W und gerade mal ein halbes Jahr alt, da das alte den Geist aufgegeben hatte.
          Es würde mich wundern, wenn das schon nach einem halben Jahr defekt sein sollte. Ist kein NoName und auch kein Billig-Netzteil.
          ESP8266E Offline
          ESP8266E Offline
          ESP8266
          schrieb am zuletzt editiert von ESP8266
          Das ist keine Garantie dafür. Ich glaube kaum, das jedes Gerät bei der Produktion überprüft wird. Nur Stichproben.
          Das wäre sonst unbezahlbar. Selbst bei Panasonic TV´s und anderen hochpreisigen Geräten ist das nicht der Fall. Wenn ein Elko schon Taub eingebaut wurde, weiß das der Hersteller auch nicht. Auf sowas würde ich nicht bauen. Ich könnte dein Netzteil überprüfen auf Restwelligkeit , Belastungstest usw. Aber der Aufwand ist zu groß. Dann hör dich mal in deiner Umgebung um, wer das mal prüfen könnte. Dann kann man das als evtl. Fehlerquelle ausschließen.
          OTon
          Mir brachte jemand mal eine defekte Endstufe zum reparieren vorbei. Linker Kanal def.
          Zitat von ihm:
          ".....der kann doch nicht schon Defekt sein"
          Die Endstufe hatte schon 25 Jahre auf dem Buckel. 🤔
          OToff
            ChristophH
            Laut dem Diagnose-Script sind die IoBroker-Dateien ja da.
            Und laut der Statusausgabe wird der IoBroker.service ja auch geladen.
            :man-shrugging:
            @ESP8266
            Mich wundert dann nur, daß alles andere einwandfrei startet und läuft.
            Nur IoBroker nicht.
            Und das repoduzierbar, egal wie lange der Rechner beim Startversuch von Iobroker schon gelaufen ist.
            Alle anderen Services lassen sich problemlos manuell stoppen und wieder starten.
            Ich hab in einem anderen Rechner noch ein Netzteil mit 700W. Ich tausche die beiden mal probehalber. Es dürfte ziemlich unwahrscheinlich sein, daß das andere Netzteil den gleichen Fehler aufweist.
            • C ChristophH
              :man-shrugging:
              @ESP8266
              Nur IoBroker nicht.
              Vielleicht die Dateien
              Aber ab hier
              ioBroker Status
              fehlt alles
              keine Adapter, keine Instanzen
              0 Objects, 0 States
              • C Offline
                ChristophH
                Sorry, aber ich muß Schluß machen für heute. Meine Mutter hatte vorhin einen Schwächeanfall, darum hatte ich auch nichts mehr geschrieben. War heute wohl alles ein bisschen viel für sie.
                Ich melde mich morgen wieder.
                Vielen Dank nochmal.
                ESP8266E 1 Antwort Letzte Antwort
                • C ChristophH
                  ESP8266E Offline
                  ESP8266E Offline
                  ESP8266
                  @christophh , naja man will dir helfen, weil du selber die Ursache wissen willst,
                  aber was ich schreibe wird in Frage gestellt.
                  Such mal schön nach der Ursache selber. Waren alles nur Tipps. Im Endeffekt wird dir keiner helfen können und musst neu aufsetzen. Mit dem Gedanken, das es jederzeit wieder passiert.
                  Glauben ist nicht wissen.
                  • ESP8266E ESP8266
                    ChristophH
                    schrieb am zuletzt editiert von ChristophH
                    @esp8266
                    Ich habe nicht bezweifelt, daß Netzteile mit zunehmendem Alter oder überhaupt Probleme machen können.
                    Ich habe in den letzten 35 Jahren alle Rechner, egal ob meine eigenen oder die in der Familie, selber zusammengebaut, eingerichtet und gewartet.
                    Und ich habe in den 35 Jahren mehr als ein Netzteil gehabt, was irgendwann Probleme machte.
                    Aber die durch die Netzteile verursachten Probleme beschränkten sich nie reproduzierbar auf den Start eines einzigen Programmes.
                    Außerdem äußerten sich die Probleme immer allmählich nach und nach. Schon im laufenden Betrieb gab es dann immer mal hier und da Probleme. Aber noch nie innerhalb von den 10 Minuten, die ich für den Plattentausch und den Reboot benötigt habe.
                    Von daher meine leichten Zweifel, daß das Netzeil schuld sein soll.
                    Das war jetzt nichts gegen deine Sachkenntnis und Erfahrungen.
                    Ich finde es toll, daß du hier so hilfst und bin unendlich dankbar für jede Hilfe, die ich hier kriege.
                    Ich habe daher auch heute morgen mal die beiden Netzteile getauscht.
                    Das andere ist ein 700 Watt be quiet! Pure Power 11.
                    Der andere Rechner startet mit dem Seasonic einwandfrei, alles wird problemlos geladen und gestartet.
                    Das NAS hat mit dem be quiet! die gleichen Probleme wie mit dem Seasonic.
                    Ich denke, damit dürfte erwiesen sein, daß es nicht am Netzteil liegt.
                    @Alle
                    Ich schreibe erst jetzt wieder, da ich nach der letzten Nacht erst gegen 12 Uhr aufgestanden bin.
                    Erst um 2:50 Uhr und 4:20 Uhr Evakuierungsmeldungen wegen Hochwasser über das Handy-Warnsystem (Bundesweiter Probewarntag), die zwar nicht uns direkt betrafen, aber den nahegelegenen Nachbarort.
                    Und dann ist meine Mutter noch gegen 6 Uhr heute morgen mit einem Herzanfall ins Krankenhaus gekommen 😧
                    Irgendwann heute nachmittag kann ich hin, warte aber auf den entsprechenden Anruf.
                    Wenn ich also irgendwann heute Nachmittag nicht antworten sollte, wisst ihr, weshalb. Ich melde mich dann auf jeden Fall später wieder.
                    • ESP8266E Offline
                      ESP8266E Offline
                      ESP8266
                      @christophh , eigentlich braucht man sich hier nicht Rechtfertigen. Das geht keinen was an.
                      Bleibt dir aber überlassen.
                      • ESP8266E ESP8266
                        ChristophH
                        @esp8266
                        Das sollte keine Rechtfertigung sein.
                        Ich lese hier schon eine ganze Weile mit und möchte einfach nicht den Eindruck erwecken, daß ich mich hier auf einmal nicht mehr melde, wie es bei so manchen Fragestellern ja durchaus ist.
                        • ESP8266E Offline
                          ESP8266E Offline
                          ESP8266
                          @christophh , da hast du schon Recht, aber so ins Detail wills keiner wissen...😊
                          • C Offline
                            ChristophH
                            So, muß erst weg. Bis später.
                            • C Offline
                              ChristophH
                              das Problem ist gelöst!!!!
                              Fragt mich nicht, wie es geht, aber eine defekte Tastatur hat das ganze ausgelöst.
                              Warum ich das nicht eher gemerkt habe? Weil am NAS nicht permanent ein Monitor angeschlossen ist, ich aber eine kleine Tatstaur für Wartungszwecke permanent angeschlossen habe. Ich weiß, ist unnötig, und ich kann auch nicht mehr sagen, was ich mir damals dabei gedacht hatte.
                              Ich hab das NAS heute morgen mit angeschlossenem Monitor nochmal komplatt neu starten lassen und gesehen, daß da eine Fehlermeldung auftauchte, die im Endeffekt auf die Tastatur hindeutete. Diese also abgestöpselt, neu gestartet und es lief alles einwandfrei.
                              Fragt mich nicht, wie die Tastatur das reproduzierbar verursacht haben kann.
                              Ich weiß es einfach nicht. Ich hatte es aber vorher eben auch nicht gemerkt, da ich normalerweise nur über SSH auf das Terminal gehe.
                              Ich danke nochmals allen, die versucht haben, mir zu helfen.
                              Macht bitte weiter so, eure Hilfe ist Gold wert für alle, die mit Problemen bei IoBroker alleine nicht klarkommen.
                              • C ChristophH
                                ESP8266E Offline
                                ESP8266E Offline
                                ESP8266
                                @christophh , ich habe hier am System auch eine kleine Funktastatur für Notfälle dran. Die schaltet sich nach nicht gebrauch einfach ab.
                                Für die richtige Einbindung gibt es sogar ein Patch.
                                • ESP8266E ESP8266
                                  ChristophH
                                  @esp8266
                                  Bei mir war's eine Kabelgebundene USB-Tatstatur.
