  4. Zigbee Stick spinnt *gelöst*
    5.1k
78 Beiträge 8 Kommentatoren 8.2k Aufrufe 8 Beobachtet
  • G Offline
    gluecksmann
    schrieb am zuletzt editiert von gluecksmann
    Guten Morgen Forum, wenn ich die Instanz des Zigbee aufrufe, kommt diese Fehlermeldung.
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     05:52:39 up  8:04,  1 user,  load average: 1.01, 0.86, 0.71
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Tue 2023-12-26 05:52:40 CET
               Universal time: Tue 2023-12-26 04:52:40 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           7.9G        1.6G        4.2G         32M        2.0G        6.0G
    Swap:           99M          0B         99M
    Total:         8.0G        1.6G        4.3G
             7898 M total memory
             1632 M used memory
              380 M active memory
             3078 M inactive memory
             4233 M free memory
              192 M buffer memory
             1840 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
      UNIT            LOAD   ACTIVE SUB    DESCRIPTION
    * lightdm.service loaded failed failed Light Display Manager
    1 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4       29G   14G   15G  50% /
    devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     3.9G   33M  3.9G   1% /run
    tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
    [Mon Dec 25 21:47:50 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:3D:9B:6E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Mon Dec 25 21:47:51 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Mon Dec 25 21:47:51 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Mon Dec 25 21:47:53 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    TARGET        SOURCE         FSTYPE OPTIONS
    /             /dev/mmcblk0p2 ext4   rw,noatime
    |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    407M    /var/
    118M    /var/lib
    102M    /var/cache
    90M     /var/cache/apt
    85M     /var/log
    Archived and active journals take up 32.0M in the file system.
    /opt/iobroker/backups:
    60M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    621M    /opt/iobroker/iobroker-data/
    329M    /opt/iobroker/iobroker-data/files
    143M    /opt/iobroker/iobroker-data/backup-objects
    93M     /opt/iobroker/iobroker-data/sonosCache
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    26M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    12M     /opt/iobroker/iobroker-data/objects.json.migrated
    USB-Devices by-id:
    /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3388-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! invalid: iobroker.govee@0.0.5 /opt/iobroker/node_modules/iobroker.govee
    npm ERR! invalid: iobroker.icons-ultimate-png@1.0.1 /opt/iobroker/node_modules/iobroker.icons-ultimate-png
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-26T04_52_49_143Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.0
    javascript:     7.1.6
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-26T04_53_11_135Z-debug-0.log
    Adapters from github:   2
    Adapter State
      system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
      system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              - disabled
    + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
      system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
      system.adapter.devices.0                : devices               : raspberrypi                              - disabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
    + system.adapter.govee.0                  : govee                 : raspberrypi                              -  enabled
    + system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi                              -  enabled
      system.adapter.history.0                : history               : raspberrypi                              - disabled
    + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
    + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
    + system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
    + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
    + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
    + system.adapter.philips-air.0            : philips-air           : raspberrypi                              -  enabled
    + system.adapter.philips-air.1            : philips-air           : raspberrypi                              -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
    + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              - disabled
    + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
      system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "awtrix-light" : 0.10.0   , installed 0.10.0
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "ble"          : 0.13.4   , installed 0.13.4
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "fullybrowser" : 3.0.6    , installed 3.0.6
    Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
    Adapter    "hue"          : 3.10.1   , installed 3.10.1
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "meross"       : 1.15.1   , installed 1.15.1
    Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
    Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
    Adapter    "musiccast"    : 1.1.3    , installed 1.1.3
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "philips-air"  : 1.0.3    , installed 1.0.3
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-icontwo"  : 1.0.0    , installed 1.0.0
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "zigbee"       : 1.8.25   , installed 1.8.25
    Objects and States
    Objects:        11301
    States:         9374
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          19502      650/sshd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          775037     2448/cupsd
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       21081      1074/io.sonoff.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19713      642/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19706      642/iobroker.js-con
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18097      762/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       26014      2151/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          19504      650/sshd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          775036     2448/cupsd
    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       20991      1056/io.sonos.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       20223      1112/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       20224      1112/io.tuya.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       19939      894/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15322      639/dhcpcd
    udp        0      0 0.0.0.0:40006           0.0.0.0:*                           1001       20196      1092/io.philips-air
    udp        0      0 0.0.0.0:56941           0.0.0.0:*                           108        15073      397/avahi-daemon: r
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          773958     2449/cups-browsed
    udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       24729      1340/io.musiccast.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15071      397/avahi-daemon: r
    udp        0      0 0.0.0.0:39675           0.0.0.0:*                           1001       19387      970/io.philips-air.
    udp6       0      0 :::54275                :::*                                108        15074      397/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          17520      639/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        15072      397/avahi-daemon: r
    2023-12-26 05:53:28.566  - info: philips-air.0 (970) State value to set for "philips-air.0.device.uptime" has to be type "number" but received type "string"
    2023-12-26 05:53:28.626  - info: philips-air.0 (970) State value to set for "philips-air.0.status.pm25" has to be type "number" but received type "string"
    2023-12-26 05:53:28.652  - info: philips-air.0 (970) State value to set for "philips-air.0.control.timerHours" has to be type "number" but received type "string"
    2023-12-26 05:53:28.699  - info: philips-air.0 (970) State value to set for "philips-air.0.status.timerMinutes" has to be type "number" but received type "string"
    2023-12-26 05:53:28.715  - info: philips-air.0 (970) State value to set for "philips-air.0.filter.preFilterCleanInHours" has to be type "number" but received type "string"
    2023-12-26 05:53:28.790  - info: philips-air.0 (970) State value to set for "philips-air.0.filter.hepaFilterReplaceInHours" has to be type "number" but received type "string"
    2023-12-26 05:53:28.797  - info: philips-air.0 (970) State value to set for "philips-air.0.filter.activeCarbonFilterReplaceInHours" has to be type "number" but received type "string"
    2023-12-26 05:53:36.263  - error: govee.0 (1253) AxiosError: Request failed with status code 429
    2023-12-26 05:53:39.973  - error: philips-air.1 (1092) Error by sending: Error: No reply in 247 seconds.
    2023-12-26 05:53:51.400  - error: govee.0 (1253) AxiosError: Request failed with status code 429
    2023-12-26 05:53:56.958  - warn: sonoff.0 (1074) Client [tasmota2] has invalid password or username
    2023-12-26 05:54:06.383  - error: govee.0 (1253) AxiosError: Request failed with status code 429
    2023-12-26 05:54:09.974  - error: philips-air.1 (1092) Error by sending: Error: No reply in 247 seconds.
    2023-12-26 05:54:14.574  - info: philips-air.0 (970) State value to set for "philips-air.0.control.lightBrightness" has to be type "number" but received type "string"
    2023-12-26 05:54:14.581  - info: philips-air.0 (970) State value to set for "philips-air.0.control.airQualityNotificationThreshold" has to be type "number" but received type "string"
    2023-12-26 05:54:14.615  - info: philips-air.0 (970) State value to set for "philips-air.0.status.allergenIndex" has to be type "number" but received type "string"
    2023-12-26 05:54:14.669  - info: philips-air.0 (970) State value to set for "philips-air.0.control.childLock" has to be type "boolean" but received type "string"
    2023-12-26 05:54:14.740  - info: philips-air.0 (970) State value to set for "philips-air.0.device.uptime" has to be type "number" but received type "string"
    2023-12-26 05:54:14.798  - info: philips-air.0 (970) State value to set for "philips-air.0.status.pm25" has to be type "number" but received type "string"
    2023-12-26 05:54:14.822  - info: philips-air.0 (970) State value to set for "philips-air.0.control.timerHours" has to be type "number" but received type "string"
    2023-12-26 05:54:14.832  - info: philips-air.0 (970) State value to set for "philips-air.0.status.timerMinutes" has to be type "number" but received type "string"
    2023-12-26 05:54:14.889  - info: philips-air.0 (970) State value to set for "philips-air.0.filter.preFilterCleanInHours" has to be type "number" but received type "string"
    2023-12-26 05:54:14.896  - info: philips-air.0 (970) State value to set for "philips-air.0.filter.hepaFilterReplaceInHours" has to be type "number" but received type "string"
    2023-12-26 05:54:14.903  - info: philips-air.0 (970) State value to set for "philips-air.0.filter.activeCarbonFilterReplaceInHours" has to be type "number" but received type "string"
    2023-12-26 05:54:21.397  - error: govee.0 (1253) AxiosError: Request failed with status code 429
    Meister MopperM Thomas BraunT 3 Antworten Letzte Antwort
    • G gluecksmann
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm
      Docker          : false
      Kernel          : armv7l
      Userland        : armhf
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           99M          0B         99M
               7898 M total memory
               1632 M used memory
                380 M active memory
               4233 M free memory
                192 M buffer memory
               1840 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      407M    /var/
      118M    /var/lib
      102M    /var/cache
      90M     /var/cache/apt
      85M     /var/log
      USB-Devices by-id:
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.12.0
      javascript:     7.1.6
      Adapter State
      + instance is alive
      Objects and States
      Objects:        11301
      States:         9374
      Pending Updates: 0
      Meister MopperM Online
      Meister Mopper
      @gluecksmann sagte in Zigbee Stick spinnt:
      Dieser Hinweis kommt, wenn keine Verbindung zum USB-Stick möglich ist. Versuch mal
      als COM-Anschlussname einzutragen.
      Bei mir muss teilweise der Adapter mehrmals neu gestartet werden, bis es funktioniert.
      • Zudem reitest du mit Debian buster einen toten Gaul. Installier das aktuelle 64-bit bookworm lite Image.
      • Dein govee-Adapter muckt rum
      Proxmox und HA ...
      Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
      G 1 Antwort Letzte Antwort
        gluecksmann
        @meister-mopper sagte in Zigbee Stick spinnt:
        hab es eingetragen...Adapter..Raspberry mehrmals neu gestartet...kein Erfolg...
        • G gluecksmann
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm
          Docker          : false
          Kernel          : armv7l
          Userland        : armhf
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           99M          0B         99M
                   7898 M total memory
                   1632 M used memory
                    380 M active memory
                   4233 M free memory
                    192 M buffer memory
                   1840 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          407M    /var/
          118M    /var/lib
          102M    /var/cache
          90M     /var/cache/apt
          85M     /var/log
          USB-Devices by-id:
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.12.0
          javascript:     7.1.6
          Adapter State
          + instance is alive
          Objects and States
          Objects:        11301
          States:         9374
          Pending Updates: 0
          @gluecksmann
          Buster ist tot, installier da ganz NEU!
          ein Raspberry OS 12 'Bookworm' in der 64Bit Lite Version.
            @gluecksmann
            gluecksmann
            Ich glaube das wäre für das Forum zuviel... Wenn dann bräuchte ich einen persönlichen 1:1 Support...
            Aber das kann ja nicht das Problem mit dem Zigbee sein, oder?
            • G gluecksmann
              @gluecksmann
              Nee, das ist ein grundsätzliches Problem.
                @gluecksmann
                gluecksmann
                Also so ganz kann ich den Fehler nicht verstehen...einige Zigbee Komponenten funktionieren normal... In der Geräteansicht ändert sich sogar der Status der nicht funktionierenden Geräte wenn ich sie z.B. über Alexa schalte...aber Hardwareseitig passiert nix..
                • G gluecksmann
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm
                  Docker          : false
                  Kernel          : armv7l
                  Userland        : armhf
                  CPU threads: 4
                  Current issues:
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  /home/pi
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:           99M          0B         99M
                           7898 M total memory
                           1632 M used memory
                            380 M active memory
                           4233 M free memory
                            192 M buffer memory
                           1840 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /var:
                  407M    /var/
                  118M    /var/lib
                  102M    /var/cache
                  90M     /var/cache/apt
                  85M     /var/log
                  USB-Devices by-id:
                  /usr/bin/npm            10.2.3
                  /usr/bin/npx            10.2.3
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.12.0
                  javascript:     7.1.6
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        11301
                  States:         9374
                  Pending Updates: 0
                  Meister Mopper
                  Geh mal auf den 1.8.24 zurück, da gibt es im Forum mittlerweile mehrere Beiträge. Da ist noch was buggy.
                  Proxmox und HA ...
                  G ? 2 Antworten Letzte Antwort
                    gluecksmann
                    @meister-mopper Ähm..und das mache ich wie??
                    amg_666A Meister MopperM 2 Antworten Letzte Antwort
                    • G gluecksmann
                      amg_666A Offline
                      amg_666A Offline
                      amg_666
                      @gluecksmann indem du im Reiter Adapter auf die Zigbee Kachel klickst und da unten rechts auf das Plus klickst, dann kannst du eine bestimmte Version auswählen
                        @meister-mopper gab es nicht auch mal ein Fehler, bei dem der Stick nicht mehr richtig erkannt wurde?
                        Thomas BraunT Meister MopperM 2 Antworten Letzte Antwort
                        • G gluecksmann
                          Meister Mopper
                          schrieb am zuletzt editiert von Meister Mopper
                          Oder über die Konsole:
                          iobroker install zigbee@1.8.24
                          Proxmox und HA ...
                            @phantomkommander
                            Ja, das Problem mit udev ist allerdings in aktuellen Versionen behoben.
                              Meister Mopper
                              @phantomkommander sagte in Zigbee Stick spinnt:
                              KA, ich nutze das TI-Board.
                              Proxmox und HA ...
                                @phantomkommander
                                @thomas-braun ah ok, hatte ich nicht mitbekommen.
                                  Meister Mopper
                                  Das udev Problem hatte ich auch, allerdings auf einem bullseye 32-Bit System auf dem Raspberrypi.
                                  Seit 64-Bit bookworm ist das Geschichte. 😊
                                  Proxmox und HA ...
                                    gluecksmann
                                    @meister-mopper
                                    Konsole will er scheinbar nicht... sagt das es schon installiert ist... Die Kachel habe ich merkwürdigerweise nicht...
                                    • G gluecksmann
                                      @meister-mopper
                                      Meister Mopper
                                      Das scheint ein Verständnisproblem zu sein. Mit Konsole meine ich über ssh (Putty oder sonstwas) auf dem iob-Server einloggen und den Befehl eingeben.
                                      Proxmox und HA ...
                                        gluecksmann
                                        @meister-mopper
                                        adapter "zigbee" already installed. Use "upgrade" to upgrade to a newer version.
                                        R Meister MopperM 2 Antworten Letzte Antwort
                                        • G gluecksmann
                                          @meister-mopper
                                          reutli
                                          @gluecksmann
                                          Bitte immer komplette Ein- und Ausgaben der Konsole in CodeTags sonst kann hier keiner sehen, was Du machst und was das Ergebnis ist!
                                          iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
                                          *Wer freundlich ist, dem wird freundlich geholfen *
