  4. Stiebel-ISG - Modbus
stiebel-isgmodbus
490 Beiträge 36 Kommentatoren 177.9k Aufrufe 31 Beobachtet
  • frana120500F frana120500
    Nach dem Update auf JS Controller 5 erhalte ich im Log die nachfolgenden Fehler und der Adapter bleibt rot:
    stiebel-isg.0
    2023-06-13 09:39:35.438	error	Parameter "options" needs to be a real object but type "object" has been passed
    stiebel-isg.0
    2023-06-13 09:39:35.438	error	Error: Parameter "options" needs to be a real object but type "object" has been passed at Validator.assertObject (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/validator.js:215:19) at AdapterClass.setObjectNotExists (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:3388:35) at main (/opt/iobroker/node_modules/iobroker.stiebel-isg/main.js:703:10) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.stiebel-isg/main.js:63:6) at process.processImmediate (node:internal/timers:478:21)
    stiebel-isg.0
    2023-06-13 09:39:35.436	error	uncaught exception: Parameter "options" needs to be a real object but type "object" has been passed
    stiebel-isg.0
    2023-06-13 09:37:48.624	error	Parameter "options" needs to be a real object but type "object" has been passed
    stiebel-isg.0
    2023-06-13 09:37:48.624	error	Error: Parameter "options" needs to be a real object but type "object" has been passed at Validator.assertObject (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/validator.js:215:19) at AdapterClass.setObjectNotExists (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:3388:35) at main (/opt/iobroker/node_modules/iobroker.stiebel-isg/main.js:703:10) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.stiebel-isg/main.js:63:6) at process.processImmediate (node:internal/timers:478:21)
    stiebel-isg.0
    2023-06-13 09:37:48.622	error	uncaught exception: Parameter "options" needs to be a real object but type "object" has been passed
    stiebel-isg.0
    2023-06-13 09:37:17.185	error	Parameter "options" needs to be a real object but type "object" has been passed
    stiebel-isg.0
    2023-06-13 09:37:17.185	error	Error: Parameter "options" needs to be a real object but type "object" has been passed at Validator.assertObject (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/validator.js:215:19) at AdapterClass.setObjectNotExists (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:3388:35) at main (/opt/iobroker/node_modules/iobroker.stiebel-isg/main.js:703:10) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.stiebel-isg/main.js:63:6) at process.processImmediate (node:internal/timers:478:21)
    stiebel-isg.0
    2023-06-13 09:37:17.183	error	uncaught exception: Parameter "options" needs to be a real object but type "object" has been passed
    stiebel-isg.0
    2023-06-13 09:36:58.404	error	Parameter "options" needs to be a real object but type "object" has been passed
    stiebel-isg.0
    2023-06-13 09:36:58.404	error	Error: Parameter "options" needs to be a real object but type "object" has been passed at Validator.assertObject (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/validator.js:215:19) at AdapterClass.setObjectNotExists (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:3388:35) at main (/opt/iobroker/node_modules/iobroker.stiebel-isg/main.js:703:10) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.stiebel-isg/main.js:63:6) at process.processImmediate (node:internal/timers:478:21)
    stiebel-isg.0
    2023-06-13 09:36:58.402	error	uncaught exception: Parameter "options" needs to be a real object but type "object" has been passed
    unltdnetworxU Offline
    unltdnetworx
    #417
    @frana120500
    Bitte mal über Github updaten. Sollte wieder laufen.
    Gruß, Michael
    Weitere Infos im Profil.
    Wenn euch der Beitrag weitergeholfen hat, könnt ihr die Bewertung rechts unten im Beitrag nutzen.
    frana120500F 1 Antwort Letzte Antwort
    • unltdnetworxU unltdnetworx
      @frana120500
      frana120500F Offline
      frana120500
      #418
      @unltdnetworx Schnell wie die Feuerwehr :-)
      Adapter läuft wieder. Vielen Dank dafür
      • K kreuzundkwer
        @kreuzundkwer
        Könnten diese Meldungen ein Grund dafür sein, dass die holdingRegisters bei mir nur 0 anzeigen?
        Habe grade alle vorhandenen gelöscht und sie neu importiert.
        javascript.0
        2022-10-20 11:14:50.023	warn	This object will not be created in future versions. Please report this to the developer.
        javascript.0
        2022-10-20 11:14:50.021	warn	Object modbus.0.inputRegisters.32003_BUS-Status is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        javascript.0
        2022-10-20 11:14:50.020	warn	This object will not be created in future versions. Please report this to the developer.
        javascript.0
        2022-10-20 11:14:50.020	warn	Object modbus.0.inputRegisters.32002_Fehlerstatus is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        javascript.0
        2022-10-20 11:14:50.018	warn	This object will not be created in future versions. Please report this to the developer.
        javascript.0
        2022-10-20 11:14:50.017	warn	Object modbus.0.holdingRegisters.44003_SG_Ready_Eingang2 is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        javascript.0
        2022-10-20 11:14:50.015	warn	This object will not be created in future versions. Please report this to the developer.
        javascript.0
        2022-10-20 11:14:50.014	warn	Object modbus.0.holdingRegisters.44002_SG_Ready_Eingang1 is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        javascript.0
        2022-10-20 11:14:50.013	warn	This object will not be created in future versions. Please report this to the developer.
        javascript.0
        2022-10-20 11:14:50.012	warn	Object modbus.0.holdingRegisters.44001_SG_Ready_ein-_und_ausschalten is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        javascript.0
        2022-10-20 11:14:50.012	warn	This object will not be created in future versions. Please report this to the developer.
        javascript.0
        2022-10-20 11:14:50.011	warn	Object modbus.0.holdingRegisters.41027_Restart-ISG is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        javascript.0
        2022-10-20 11:14:50.009	warn	This object will not be created in future versions. Please report this to the developer.
        javascript.0
        2022-10-20 11:14:50.008	warn	Object modbus.0.holdingRegisters.41001_Betriebsart is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        Fraat
        schrieb am zuletzt editiert von Fraat
        #419
        @kreuzundkwer @unltdnetworx Hallo, ich habe das gleiche Problem. Alle Holdingregister sind 0 bei einer LWZ 303 SOL. Gibt es dafür eine Lösung?
        unltdnetworxU 1 Antwort Letzte Antwort
        • F Fraat
          unltdnetworx
          #420
          @fraat
          Was zeigt denn die Weboberfläche für die jeweiligen Werte?
          Gruß, Michael
            Android51
            schrieb am zuletzt editiert von Android51
            #421
            Ist das bei eurem isg (bei mir isg Web) auch so, wenn das Gerät stromlos war, dass es nach dem Hochfahren sg ready aktiviert und die forcierten Werte aus dem Energiemanagement ansteuert? Ist halt blöd, wenn sich unnötig der Heizstab einschaltet, wenn z. B. kein PV Überschuss vorhanden ist.
            • A Android51
              unltdnetworx
              schrieb am zuletzt editiert von unltdnetworx
              #422
              @android51
              Das kann ich leider nicht beantworten, da bei mir das ISG nie stromlos ist.
              Gruß, Michael
                Android51
                #423
                Ist bei mir auch nicht der Regelfall. Habe nur die Tage was an meiner Elektroinstallation ergänzt und musste die Sicherung rausnehmen. Da war das isg kurzzeitig stromlos. Als ich die Sicherung wieder eingeschaltet habe, fuhr das isg hoch und die Warmwasserbereitung wurde aktiviert, weil das System die forcierten Werte erreichen wollte. Habe es glücklicherweise sofort erkannt. Wenn aber mal, aus welchen Gründen auch immer, der Netzbetreiber einen Stromausfall verursacht oder durch höhere Gewalt und ich nicht zu Hause bin, würde man es nicht mitbekommen. Nicht dramatisch, aber auch nicht schön.
                • L Offline
                  litithio
                  schrieb am zuletzt editiert von litithio
                  #424
                  Ich habe ein Problem mit der Kombination aus ISG mit EMI Modul und Modbus.
                  Prinzipiell sollte ja seit 2-3 Jahren Modbus auch weiterhin funktionieren, wenn das EMI Modul installiert ist.
                  Vor etwa einem Monat habe ich das EMI Modul bekommen. Modbus funktioniert zwar noch, aber ich kann nur noch ca. 10 Werte abrufen.
                  Speziell ist es zudem bei 32501 Beitriebsstatus. Hier werden ganz andere Zahlen übermittelt als vorher. Im Heizbetrieb steht hier nun z. B. eine 81 und im Warmwasserbetrieb eine 97. Werte dieser Art tauchen in der Modbus-Doku nicht auf ...
                  Bei den anderen Werte kommt entweder nichts an, oder der Modbus-Adapter startet erst gar nicht. Vor der Installation des EMI Moduls hat alles wunderbar geklappt.
                  Gibt es hier andere Nutzer die diese Kombination ebenfalls betreiben? Wie sieht das bei euch aus? Bekommt ihr nach wie vor alle Werte, die auch vor der Installation des EMI Moduls kamen?
                  Auf dem ISG läuft bei mir Version 12.1.2., gibt es da mittlerweile eine neuere Version? Hatte bei der Bestellung des EMI Moduls eigentlich auch darum gebeten, Updates einzuspielen, falls welche verfügbar wären.
                  • L litithio
                    Schimi
                    #425
                    @litithio Die neuste ist "v12.2.3"
                    könnte sein das durch das Modul, Modbus register dazu gekommen sind und nun "verschoben" ausgelesen werden.....
                    Ich wüsste jetzt keine art sich zu helfen... ausser ausprobieren (vielleicht die abfrage auch verkleiner/verlangsamen um das ISG nicht zu überlasten) oder Stiebel mal zu fragen ob sich da was geändert hat.....
                      Android51
                      #426
                      Mein ISG-Web wurde vor kurzem aktualisiert. Bin jetzt auf Version 12.2.3. Habe festgestellt, das mir inzwischen auch die Inverter Aufnahmeleistung angezeigt wird. Weiß jemand zufällig, ob es dafür auch eine Modbus Adresse gibt?
                        SaarlandUHU
                        #427
                        da wir kürzlich eine PV-Anlage bekommen haben, kann ich die Abgerufene Leistung der Heizung nicht mehr direkt am Stromzähler abgreifen, da zum einen die beiden Zähler für Wärme- und Hausstrom hintereinander hängen und zum anderen der Stromzähler ja nichts zählt, wenn die Heizung über den Strom der PV-Anlage läuft. Ich habe zwar die Daten der Erzeugung, die Daten vom anderen Stromzähler usw. und könnte mir die Leistung der Heizung berechnen. Aber bevor ich das umsetze wollte die Daten direkt aus der Heizung abfragen. Über das ISG und den ISG-Adapter wird mit der Tages-Verbrauch von Warmwasser und Heizung ja angezeigt. Hierüber wollte ich dann die aktuelle Leistung als Delta der beiden letzten Werte errechnen. Im ISG-Adapter werden die Werte mit drei Dezimalstellen angezeigt, womit man ja gut arbeiten kann.
                        Ziehe ich mir die Daten über den Modbus, werden mir nur ganze kWh angezeigt. Damit kann ich ja dann relativ wenig mit anfangen, wenn ich einen Tagesverlauf darstellen will.
                        Ist das eine Einstellungssache oder gibt der Modbus die Daten einfach nur als ganze kWh weiter?
                        Vielen Dank schonmal.
                        • S SaarlandUHU
                          derdominik
                          #428
                          @saarlanduhu ich habe keine direkte Lösung für das Modbus-Problem, bei mir sind das auch nur ganze kWh.
                          Aber wenn du eine PV-Anlage hast, hast du dann auch das EMI-Modul? Wenn ja, dann lässt sich der aktuelle Verbrauch per https://github.com/unltdnetworx/ioBroker.stiebel-isg von der EMI-Status-Seite auslesen.
                          • C Offline
                            ChrisWitt
                            schrieb am zuletzt editiert von ChrisWitt
                            #429
                            Ich versuche gerade meine LWZ504 mittels ISG Plus und NEUESTER Software über Modbus anzusteuern.
                            Mit geht es um den SG Ready Eingang den ich ansteuern will.
                            Dies soll dann später automatisiert den Status von Tibber an die Schnittstelle übergeben und die Anlage forcieren.
                            Angelegt habe ich zum Test die Holding Register wie folgt :
                            Steuere ich nun im Baum die Eingänge mit 1/0 kann ich alle 4 Betriebszustände steuern bzw. Sehe ich dann als Betriebszustand.
                            Steuere ich das ganze aber dann via Skript (dies ist nur ein Testskript) , sehe ich zwar auch den sich ändernden Wert im Baum, jedoch ändert sich der Betriebszustand nicht.
                            Was mache ich im Skript falsch bzw. Wie muss das Holding Register angelegt werden ?
                            Ich danke euch
                            • C ChrisWitt
                              Ich danke euch
                              unltdnetworx
                              #430
                              @chriswitt
                              Hallo Chris,
                              ich persönlich würde statt "aktualisiere" die Funktion "setze" (heißt die so?) verwenden, aber das ist nicht das Problem.
                              Du brauchst für deine Funktion einen Trigger. Den einfach um deinen Block herumsetzen. Z.B. "Wenn geändert Wert von Auto 11..."
                              Gruß, Michael
                              C 1 Antwort Letzte Antwort
                                @chriswitt
                                Hallo Chris,
                                ChrisWitt
                                #431
                                @unltdnetworx
                                Habe es auch mit diesem versucht :
                                Trigger ist klar, brauche ich dann später. Aktuell ändere ich im Skript halt manuell die Werte und speichere neu ab.
                                Es ändert sich ja auch der Wert im Baum, nur „überträgt“ es irgendwie nicht auf das ISG . Also vermute ich irgendwo einen Fehler im Modbus- Adapter ?
                                • C ChrisWitt
                                  @unltdnetworx
                                  unltdnetworx
                                  #432
                                  @chriswitt
                                  Ich meinte "steuere Ready1 auf 0". So klappt es jeden Falls bei mir.
                                  Edit:
                                  "Steuere" heißt die Fuktion die ich meinte, nicht "Setze".
                                  Gruß, Michael
                                    @chriswitt
                                    Edit:
                                    ChrisWitt
                                    #433
                                    @unltdnetworx hey super. Scheint zu funktionieren.
                                    Da ich an den Basics offenbar schon scheitere wird es ein Spaß das ganze mit Tibber zu steuern....
                                    Forcieren uns. max werte anzusteuern ist ja kein Problem, aber sicherzustellen, dass Heizung trotzdem x stunden läuft und WW da ist, das wird spannend...
                                    • unltdnetworxU Offline
                                      unltdnetworx
                                      #434
                                      @chriswitt
                                      Naja, der Eingang 1 ist ja eigentlich dafür gedacht, den vorhandenen Stromüberschuss zu verwenden. Dass die Heizung warm ist sollte sie selbst sicherstellen.
                                      Gruß, Michael
                                        @chriswitt
                                        axel
                                        #435
                                        @unltdnetworx Ich verfolge das Thema sehr interessiert. Habe meine TTL 7.6 mit dem Adapter verbunden. Eigentlich ganz ok. Nun wollte ich Werte setzen und stosse an Grenzen. Ich möchte die maximale Vorlauftemperatur verändern, das geht aber nicht. Der neue Wert wird zwar vom Datenpunkt akzeptiert, aber nicht in den WPM geschrieben. Bein nächsten Auslesen ist der alte Wert wieder da. Woran liegt das? Muss ich das wirklich am Display einstellen? Ich wollte meine Heizkurve und den Vorlauf in Abhängigkeit der Wetterprognose optimieren. Kann mir jemand erklären, warum ich die Werte nicht über das Interface verändern kann?
                                        QNAP 677 VM 16 GB, 4 Kerne, 3,4 GHz
                                        29.375 Objekte
                                        24.247 Zustände
                                        • G Offline
                                          gravis
                                          schrieb am zuletzt editiert von gravis
                                          #436
                                          erstmal Danke an den hilfreichen Input hier im Topic bzgl. Einstellungen / Scripte / Modbus Adapter usw.
                                          Ich selbst nutze erfolgreich den Stiebel-ISG Adapter und Modbus TCP/IP zur Informationsgewinnung, weiteren Auswertung (grafana,...) und Steuerung meiner Anlage.
                                          Kurz zu meinem Anliegen: Ich betreibe die WW-Zirkulationspumpe über den Wärmepumpenmanager (Angeschlossen über BUS X2.11). Dadurch kann ich im ISG das Zirkulationsprogramm nutzen und zu festen Zeitpunkten (3x täglich) das erwärmte Wasser durch das Haus pumpen.
                                          Eine Optimierung würde ich gerne noch vornehmen, so dass ich die Zirkulationspumpe "Ad-Hoc" für eine bestimmte Zeit (de-)aktivieren kann. Laut Bedingungsanleitung (Seite 19) kommt man da vielleicht mittels modbus dran:
                                          https://www.stiebel-eltron.ch/content/dam/ste/ch/de/downloads/kundenservice/smart-home/Modbus/Modbus Bedienungsanleitung.pdf
                                          Modbus-Adresse: 47012 7012 boolean Zirkulationspumpe aktivieren
                                          Ich versuchte die Adresse bei den Holding Registern hinzuzufügen, um dann ggfs. die Zirkulationspumpe via iobroker Datenpunkt ansteuern zu können. Leider ohne Erfolg:
                                          Poll error count: 8 code: {"errorCode":131,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                                          Auch die Modbus-Adresse 47011 (Offset -1) klappt nicht.
                                          Hat jemand eine Idee oder ähnliche Anforderung erfolgreich umsetzen können?
                                          Gibt es alternative Möglichkeiten z.B. "Dynamisch" via (Blockly / Scripting) in die ISG-Web "Programme" einzugreifen?
                                          Viele Grüße
                                          EnduranceE 1 Antwort Letzte Antwort
